mtd: nand: make PCI device id constant
Author: Márton Németh <nm127@freemail.hu>
The id_table field of the struct pci_driver is constant in
so it is worth to make cafe_nand_tbl also constant.
The semantic match that finds this kind of pattern is as follows:
(http://coccinelle.lip6.fr/)
@r@
disable decl_init,const_decl_init;
identifier I1, I2, x;
	struct I1 {
	  const struct I2 *x;
@s@
identifier r.I1, y;
identifier r.x, E;
	struct I1 y = {
	  .x = E,
@c@
identifier r.I2;
identifier s.E;
	const struct I2 E[] = ... ;
@depends on !c@
identifier r.I2;
identifier s.E;
+	const
	struct I2 E[] = ...;
Signed-off-by: Márton Németh
Cc: Julia Lawall
Cc: cocci@diku.dk
Signed-off-by: Artem Bityutskiy
Signed-off-by: David Woodhouse
 drivers/mtd/nand/cafe_nand.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/mtd/nand/cafe_nand.c b/drivers/mtd/nand/cafe_nand.c
index c828d9a..67e2b33 100644
--- a/drivers/mtd/nand/cafe_nand.c
+++ b/drivers/mtd/nand/cafe_nand.c
@@ -848,7 +848,7 @@ static void __devexit cafe_nand_remove(struct pci_dev *pdev)
 	kfree(mtd);
-static struct pci_device_id cafe_nand_tbl[] = {
+static const struct pci_device_id cafe_nand_tbl[] = {
 	{ PCI_VENDOR_ID_MARVELL, PCI_DEVICE_ID_MARVELL_88ALP01_NAND,
 	  PCI_ANY_ID, PCI_ANY_ID },
BtrLinux
Privacy Overview
