mtd: nand: make Open Firmware device id constant
Author: Márton Németh <nm127@freemail.hu>
The match_table field of the struct of_device_id is constant in
so it is worth to make xps2_of_match also constant.
The semantic match that finds this kind of pattern is as follows:
(http://coccinelle.lip6.fr/)
@r@
disable decl_init,const_decl_init;
identifier I1, I2, x;
	struct I1 {
	  const struct I2 *x;
@s@
identifier r.I1, y;
identifier r.x, E;
	struct I1 y = {
	  .x = E,
@c@
identifier r.I2;
identifier s.E;
	const struct I2 E[] = ... ;
@depends on !c@
identifier r.I2;
identifier s.E;
+	const
	struct I2 E[] = ...;
Signed-off-by: Márton Németh
Cc: Julia Lawall
Cc: cocci@diku.dk
Signed-off-by: Artem Bityutskiy
Signed-off-by: David Woodhouse
 drivers/mtd/nand/fsl_upm.c       | 2 +-
 drivers/mtd/nand/pasemi_nand.c   | 2 +-
 drivers/mtd/nand/socrates_nand.c | 2 +-
 3 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/drivers/mtd/nand/fsl_upm.c b/drivers/mtd/nand/fsl_upm.c
index ab06a5b..d721ec0 100644
--- a/drivers/mtd/nand/fsl_upm.c
+++ b/drivers/mtd/nand/fsl_upm.c
@@ -349,7 +349,7 @@ static int __devexit fun_remove(struct of_device *ofdev)
 	return 0;
-static struct of_device_id of_fun_match[] = {
+static const struct of_device_id of_fun_match[] = {
 	{ .compatible = "fsl,upm-nand" },
diff --git a/drivers/mtd/nand/pasemi_nand.c b/drivers/mtd/nand/pasemi_nand.c
index a8b9376..090a05c 100644
--- a/drivers/mtd/nand/pasemi_nand.c
+++ b/drivers/mtd/nand/pasemi_nand.c
@@ -209,7 +209,7 @@ static int __devexit pasemi_nand_remove(struct of_device *ofdev)
 	return 0;
-static struct of_device_id pasemi_nand_match[] =
+static const struct of_device_id pasemi_nand_match[] =
 		.compatible   = "pasemi,localbus-nand",
diff --git a/drivers/mtd/nand/socrates_nand.c b/drivers/mtd/nand/socrates_nand.c
index a4519a7..65748ea 100644
--- a/drivers/mtd/nand/socrates_nand.c
+++ b/drivers/mtd/nand/socrates_nand.c
@@ -290,7 +290,7 @@ static int __devexit socrates_nand_remove(struct of_device *ofdev)
 	return 0;
-static struct of_device_id socrates_nand_match[] =
+static const struct of_device_id socrates_nand_match[] =
 		.compatible   = "abb,socrates-nand",
BtrLinux
Privacy Overview
