[MTD] [NAND] alauda: use USB API functions rather than constants
This set of patches introduces calls to the following set of functions:
usb_endpoint_dir_in(epd)
usb_endpoint_dir_out(epd)
usb_endpoint_is_bulk_in(epd)
usb_endpoint_is_bulk_out(epd)
usb_endpoint_is_int_in(epd)
usb_endpoint_is_int_out(epd)
usb_endpoint_num(epd)
usb_endpoint_type(epd)
usb_endpoint_xfer_bulk(epd)
usb_endpoint_xfer_control(epd)
usb_endpoint_xfer_int(epd)
usb_endpoint_xfer_isoc(epd)
In some cases, introducing one of these functions is not possible, and it
just replaces an explicit integer value by one of the following constants:
USB_ENDPOINT_XFER_BULK
USB_ENDPOINT_XFER_CONTROL
USB_ENDPOINT_XFER_INT
USB_ENDPOINT_XFER_ISOC
An extract of the semantic patch that makes these changes is as follows:
(http://www.emn.fr/x-info/coccinelle/)
@r1@ struct usb_endpoint_descriptor *epd; @@
- ((epd->bmAttributes & \(USB_ENDPOINT_XFERTYPE_MASK\|3\)) ==
- \(USB_ENDPOINT_XFER_CONTROL\|0\))
+ usb_endpoint_xfer_control(epd)
@r5@ struct usb_endpoint_descriptor *epd; @@
- ((epd->bEndpointAddress & \(USB_ENDPOINT_DIR_MASK\|0x80\)) ==
-  \(USB_DIR_IN\|0x80\))
+ usb_endpoint_dir_in(epd)
@inc@
#include
@depends on !inc && (r1||r5)@
+ #include
  #include
Signed-off-by: Julia Lawall
Signed-off-by: David Woodhouse
 drivers/mtd/nand/alauda.c | 6 +++---
 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/drivers/mtd/nand/alauda.c b/drivers/mtd/nand/alauda.c
index 9623803..6d96491 100644
--- a/drivers/mtd/nand/alauda.c
+++ b/drivers/mtd/nand/alauda.c
@@ -676,11 +676,11 @@ static int alauda_probe(struct usb_interface *interface,
 		goto error;
 	al->write_out = usb_sndbulkpipe(al->dev,
-			ep_wr->bEndpointAddress & USB_ENDPOINT_NUMBER_MASK);
+			usb_endpoint_num(ep_wr));
 	al->bulk_in = usb_rcvbulkpipe(al->dev,
-			ep_in->bEndpointAddress & USB_ENDPOINT_NUMBER_MASK);
+			usb_endpoint_num(ep_in));
 	al->bulk_out = usb_sndbulkpipe(al->dev,
-			ep_out->bEndpointAddress & USB_ENDPOINT_NUMBER_MASK);
+			usb_endpoint_num(ep_out));
 	/* second device is identical up to now */
 	memcpy(al+1, al, sizeof(*al));
BtrLinux
Privacy Overview
