[MTD] drivers/mtd/maps/nettel.c: use ARRAY_SIZE
ARRAY_SIZE is more concise to use when the size of an array is divided by
the size of its type or the size of its first element.
The semantic patch that makes this change is as follows:
(http://www.emn.fr/x-info/coccinelle/)
@i@
#include
@depends on i using "paren.iso"@
type T;
T[] E;
- (sizeof(E)/sizeof(E[...]))
+ ARRAY_SIZE(E)
Signed-off-by: Julia Lawall
Signed-off-by: Andrew Morton
Signed-off-by: David Woodhouse
 drivers/mtd/maps/nettel.c | 3 +--
 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/drivers/mtd/maps/nettel.c b/drivers/mtd/maps/nettel.c
index a8723a6..df68266 100644
--- a/drivers/mtd/maps/nettel.c
+++ b/drivers/mtd/maps/nettel.c
@@ -362,8 +362,7 @@ static int __init nettel_init(void)
 	intel_mtd->owner = THIS_MODULE;
-	num_intel_partitions = sizeof(nettel_intel_partitions) /
-		sizeof(nettel_intel_partitions[0]);
+	num_intel_partitions = ARRAY_SIZE(nettel_intel_partitions);
 	if (intelboot) {
BtrLinux
Privacy Overview
