arch/mips/cavium-octeon/flash_setup.c | 2 +-
drivers/mtd/devices/spear_smi.c | 2 +-
drivers/mtd/devices/sst25l.c | 6 +++---
drivers/mtd/maps/bfin-async-flash.c | 4 ++--
drivers/mtd/maps/dc21285.c | 2 +-
drivers/mtd/maps/gpio-addr-flash.c | 4 ++--
drivers/mtd/maps/h720x-flash.c | 4 ++--
drivers/mtd/maps/impa7.c | 2 +-
drivers/mtd/maps/intel_vr_nor.c | 2 +-
drivers/mtd/maps/ixp2000.c | 2 +-
drivers/mtd/maps/lantiq-flash.c | 5 +++--
drivers/mtd/maps/latch-addr-flash.c | 5 +++--
drivers/mtd/maps/physmap.c | 2 +-
drivers/mtd/maps/plat-ram.c | 5 +++--
drivers/mtd/maps/pxa2xx-flash.c | 3 ++-
drivers/mtd/maps/rbtx4939-flash.c | 4 ++--
drivers/mtd/maps/sa1100-flash.c | 4 ++--
drivers/mtd/maps/solutionengine.c | 4 ++--
drivers/mtd/maps/wr_sbc82xx_flash.c | 2 +-
drivers/mtd/nand/atmel_nand.c | 4 ++--
drivers/mtd/nand/bcm_umi_nand.c | 2 +-
drivers/mtd/nand/cafe_nand.c | 2 +-
drivers/mtd/nand/cmx270_nand.c | 2 +-
drivers/mtd/nand/cs553x_nand.c | 2 +-
drivers/mtd/nand/davinci_nand.c | 4 ++--
drivers/mtd/nand/fsmc_nand.c | 14 +++++++-------
drivers/mtd/nand/h1910.c | 4 ++--
drivers/mtd/nand/jz4740_nand.c | 6 +++---
drivers/mtd/nand/mxc_nand.c | 4 ++--
drivers/mtd/nand/omap2.c | 4 ++--
drivers/mtd/nand/orion_nand.c | 4 ++--
drivers/mtd/nand/plat_nand.c | 5 +++--
drivers/mtd/nand/ppchameleonevb.c | 18 ++++++++----------
drivers/mtd/nand/pxa3xx_nand.c | 5 +++--
drivers/mtd/nand/s3c2410.c | 4 ++--
drivers/mtd/nand/sharpsl.c | 4 ++--
drivers/mtd/nand/tmio_nand.c | 6 +++---
drivers/mtd/nand/txx9ndfmc.c | 2 +-
drivers/mtd/onenand/generic.c | 6 +++---
drivers/mtd/onenand/omap2.c | 6 +++---
drivers/mtd/onenand/samsung.c | 2 +-
41 files changed, 89 insertions(+), 85 deletions(-)
diff --git a/arch/mips/cavium-octeon/flash_setup.c b/arch/mips/cavium-octeon/flash_setup.c
index 0a430e0..e44a55b 100644
--- a/arch/mips/cavium-octeon/flash_setup.c
+++ b/arch/mips/cavium-octeon/flash_setup.c
@@ -60,7 +60,7 @@ static int __init flash_init(void)
if (mymtd) {
mymtd->owner = THIS_MODULE;
mtd_device_parse_register(mymtd, part_probe_types,
- 0, NULL, 0);
+ NULL, NULL, 0);
} else {
pr_err("Failed to register MTD device for flash\n");
diff --git a/drivers/mtd/devices/spear_smi.c b/drivers/mtd/devices/spear_smi.c
index f45dd37..f2016b5 100644
--- a/drivers/mtd/devices/spear_smi.c
+++ b/drivers/mtd/devices/spear_smi.c
@@ -851,7 +851,7 @@ static int spear_smi_setup_banks(struct platform_device *pdev, u32 bank)
goto err_map;
- ret = mtd_device_parse_register(&flash->mtd, NULL, 0, parts, count);
+ ret = mtd_device_parse_register(&flash->mtd, NULL, NULL, parts, count);
if (ret)
dev_err(&dev->pdev->dev, "Err MTD partition=%d\n", ret);
diff --git a/drivers/mtd/devices/sst25l.c b/drivers/mtd/devices/sst25l.c
index 51b2df3..ab8a2f4 100644
--- a/drivers/mtd/devices/sst25l.c
+++ b/drivers/mtd/devices/sst25l.c
@@ -399,9 +399,9 @@ static int __devinit sst25l_probe(struct spi_device *spi)
flash->mtd.numeraseregions);
- data ? data->parts : NULL,
- data ? data->nr_parts : 0);
+ data ? data->parts : NULL,
+ data ? data->nr_parts : 0);
if (ret) {
kfree(flash);
dev_set_drvdata(&spi->dev, NULL);
diff --git a/drivers/mtd/maps/bfin-async-flash.c b/drivers/mtd/maps/bfin-async-flash.c
index 650126c..ef5cde8 100644
--- a/drivers/mtd/maps/bfin-async-flash.c
+++ b/drivers/mtd/maps/bfin-async-flash.c
@@ -164,8 +164,8 @@ static int __devinit bfin_flash_probe(struct platform_device *pdev)
return -ENXIO;
- mtd_device_parse_register(state->mtd, part_probe_types, 0,
- pdata->parts, pdata->nr_parts);
+ mtd_device_parse_register(state->mtd, part_probe_types, NULL,
+ pdata->parts, pdata->nr_parts);
platform_set_drvdata(pdev, state);
diff --git a/drivers/mtd/maps/dc21285.c b/drivers/mtd/maps/dc21285.c
index f43b365..080f060 100644
--- a/drivers/mtd/maps/dc21285.c
+++ b/drivers/mtd/maps/dc21285.c
@@ -196,7 +196,7 @@ static int __init init_dc21285(void)
dc21285_mtd->owner = THIS_MODULE;
- mtd_device_parse_register(dc21285_mtd, probes, 0, NULL, 0);
+ mtd_device_parse_register(dc21285_mtd, probes, NULL, NULL, 0);
if(machine_is_ebsa285()) {
diff --git a/drivers/mtd/maps/gpio-addr-flash.c b/drivers/mtd/maps/gpio-addr-flash.c
index 33cce89..e4de96b 100644
--- a/drivers/mtd/maps/gpio-addr-flash.c
+++ b/drivers/mtd/maps/gpio-addr-flash.c
@@ -252,8 +252,8 @@ static int __devinit gpio_flash_probe(struct platform_device *pdev)
return 0;
diff --git a/drivers/mtd/maps/h720x-flash.c b/drivers/mtd/maps/h720x-flash.c
index 49c1418..8ed6cb4 100644
--- a/drivers/mtd/maps/h720x-flash.c
+++ b/drivers/mtd/maps/h720x-flash.c
@@ -85,8 +85,8 @@ static int __init h720x_mtd_init(void)
if (mymtd) {
- mtd_device_parse_register(mymtd, NULL, 0,
- h720x_partitions, NUM_PARTITIONS);
+ mtd_device_parse_register(mymtd, NULL, NULL,
+ h720x_partitions, NUM_PARTITIONS);
return 0;
diff --git a/drivers/mtd/maps/impa7.c b/drivers/mtd/maps/impa7.c
index f47aedb..834a06c 100644
--- a/drivers/mtd/maps/impa7.c
+++ b/drivers/mtd/maps/impa7.c
@@ -91,7 +91,7 @@ static int __init init_impa7(void)
if (impa7_mtd[i]) {
impa7_mtd[i]->owner = THIS_MODULE;
devicesfound++;
- mtd_device_parse_register(impa7_mtd[i], NULL, 0,
+ mtd_device_parse_register(impa7_mtd[i], NULL, NULL,
partitions,
ARRAY_SIZE(partitions));
diff --git a/drivers/mtd/maps/intel_vr_nor.c b/drivers/mtd/maps/intel_vr_nor.c
index 08c2396..92e1f41 100644
--- a/drivers/mtd/maps/intel_vr_nor.c
+++ b/drivers/mtd/maps/intel_vr_nor.c
@@ -72,7 +72,7 @@ static int __devinit vr_nor_init_partitions(struct vr_nor_mtd *p)
/* register the flash bank */
/* partition the flash bank */
- return mtd_device_parse_register(p->info, NULL, 0, NULL, 0);
+ return mtd_device_parse_register(p->info, NULL, NULL, NULL, 0);
static void __devexit vr_nor_destroy_mtd_setup(struct vr_nor_mtd *p)
diff --git a/drivers/mtd/maps/ixp2000.c b/drivers/mtd/maps/ixp2000.c
index fc7d4d0..4a41ced 100644
--- a/drivers/mtd/maps/ixp2000.c
+++ b/drivers/mtd/maps/ixp2000.c
@@ -226,7 +226,7 @@ static int ixp2000_flash_probe(struct platform_device *dev)
info->mtd->owner = THIS_MODULE;
- err = mtd_device_parse_register(info->mtd, probes, 0, NULL, 0);
+ err = mtd_device_parse_register(info->mtd, probes, NULL, NULL, 0);
if (err)
goto Error;
diff --git a/drivers/mtd/maps/lantiq-flash.c b/drivers/mtd/maps/lantiq-flash.c
index cf7a3cd..b5401e3 100644
--- a/drivers/mtd/maps/lantiq-flash.c
+++ b/drivers/mtd/maps/lantiq-flash.c
@@ -169,8 +169,9 @@ ltq_mtd_probe(struct platform_device *pdev)
cfi->addr_unlock1 ^= 1;
cfi->addr_unlock2 ^= 1;
- err = mtd_device_parse_register(ltq_mtd->mtd, ltq_probe_types, 0,
- ltq_mtd_data->parts, ltq_mtd_data->nr_parts);
+ err = mtd_device_parse_register(ltq_mtd->mtd, ltq_probe_types, NULL,
+ ltq_mtd_data->parts,
+ ltq_mtd_data->nr_parts);
if (err) {
dev_err(&pdev->dev, "failed to add partitions\n");
goto err_destroy;
diff --git a/drivers/mtd/maps/latch-addr-flash.c b/drivers/mtd/maps/latch-addr-flash.c
index 8fed58e..3c7ad17 100644
--- a/drivers/mtd/maps/latch-addr-flash.c
+++ b/drivers/mtd/maps/latch-addr-flash.c
@@ -199,8 +199,9 @@ static int __devinit latch_addr_flash_probe(struct platform_device *dev)
- mtd_device_parse_register(info->mtd, NULL, 0,
- latch_addr_data->parts, latch_addr_data->nr_parts);
+ mtd_device_parse_register(info->mtd, NULL, NULL,
+ latch_addr_data->parts,
+ latch_addr_data->nr_parts);
return 0;
iounmap:
diff --git a/drivers/mtd/maps/physmap.c b/drivers/mtd/maps/physmap.c
index 7e9233c..21b0b71 100644
--- a/drivers/mtd/maps/physmap.c
+++ b/drivers/mtd/maps/physmap.c
@@ -192,7 +192,7 @@ static int physmap_flash_probe(struct platform_device *dev)
part_types = physmap_data->part_probe_types ? : part_probe_types;
- mtd_device_parse_register(info->cmtd, part_types, 0,
+ mtd_device_parse_register(info->cmtd, part_types, NULL,
physmap_data->parts, physmap_data->nr_parts);
return 0;
diff --git a/drivers/mtd/maps/plat-ram.c b/drivers/mtd/maps/plat-ram.c
index 45876d0..891558d 100644
--- a/drivers/mtd/maps/plat-ram.c
+++ b/drivers/mtd/maps/plat-ram.c
@@ -222,8 +222,9 @@ static int platram_probe(struct platform_device *pdev)
/* check to see if there are any available partitions, or wether
* to add this device whole */
- err = mtd_device_parse_register(info->mtd, pdata->probes, 0,
- pdata->partitions, pdata->nr_partitions);
+ err = mtd_device_parse_register(info->mtd, pdata->probes, NULL,
+ pdata->partitions,
+ pdata->nr_partitions);
if (!err)
dev_info(&pdev->dev, "registered mtd device\n");
diff --git a/drivers/mtd/maps/pxa2xx-flash.c b/drivers/mtd/maps/pxa2xx-flash.c
index 436d121..81884c2 100644
--- a/drivers/mtd/maps/pxa2xx-flash.c
+++ b/drivers/mtd/maps/pxa2xx-flash.c
@@ -98,7 +98,8 @@ static int __devinit pxa2xx_flash_probe(struct platform_device *pdev)
- mtd_device_parse_register(info->mtd, probes, 0, flash->parts, flash->nr_parts);
+ mtd_device_parse_register(info->mtd, probes, NULL, flash->parts,
+ flash->nr_parts);
platform_set_drvdata(pdev, info);
return 0;
diff --git a/drivers/mtd/maps/rbtx4939-flash.c b/drivers/mtd/maps/rbtx4939-flash.c
index 3da63fc..6f52e1f 100644
--- a/drivers/mtd/maps/rbtx4939-flash.c
+++ b/drivers/mtd/maps/rbtx4939-flash.c
@@ -102,8 +102,8 @@ static int rbtx4939_flash_probe(struct platform_device *dev)
if (err)
goto err_out;
- err = mtd_device_parse_register(info->mtd, NULL, 0,
+ err = mtd_device_parse_register(info->mtd, NULL, NULL, pdata->parts,
+ pdata->nr_parts);
if (err)
goto err_out;
diff --git a/drivers/mtd/maps/sa1100-flash.c b/drivers/mtd/maps/sa1100-flash.c
index 1eaf7b6..a675bdb 100644
--- a/drivers/mtd/maps/sa1100-flash.c
+++ b/drivers/mtd/maps/sa1100-flash.c
@@ -264,8 +264,8 @@ static int __devinit sa1100_mtd_probe(struct platform_device *pdev)
* Partition selection stuff.
- mtd_device_parse_register(info->mtd, part_probes, 0,
- plat->parts, plat->nr_parts);
+ mtd_device_parse_register(info->mtd, part_probes, NULL, plat->parts,
+ plat->nr_parts);
err = 0;
diff --git a/drivers/mtd/maps/solutionengine.c b/drivers/mtd/maps/solutionengine.c
index 496c407..9d900ad 100644
--- a/drivers/mtd/maps/solutionengine.c
+++ b/drivers/mtd/maps/solutionengine.c
@@ -92,8 +92,8 @@ static int __init init_soleng_maps(void)
mtd_device_register(eprom_mtd, NULL, 0);
- mtd_device_parse_register(flash_mtd, probes, 0,
- superh_se_partitions, NUM_PARTITIONS);
+ mtd_device_parse_register(flash_mtd, probes, NULL,
+ superh_se_partitions, NUM_PARTITIONS);
return 0;
diff --git a/drivers/mtd/maps/wr_sbc82xx_flash.c b/drivers/mtd/maps/wr_sbc82xx_flash.c
index aa7e0cb..71b0ba7 100644
--- a/drivers/mtd/maps/wr_sbc82xx_flash.c
+++ b/drivers/mtd/maps/wr_sbc82xx_flash.c
@@ -142,7 +142,7 @@ static int __init init_sbc82xx_flash(void)
nr_parts = ARRAY_SIZE(smallflash_parts);
- mtd_device_parse_register(sbcmtd[i], part_probes, 0,
+ mtd_device_parse_register(sbcmtd[i], part_probes, NULL,
defparts, nr_parts);
return 0;
diff --git a/drivers/mtd/nand/atmel_nand.c b/drivers/mtd/nand/atmel_nand.c
index 35b4fb5..7769519 100644
--- a/drivers/mtd/nand/atmel_nand.c
+++ b/drivers/mtd/nand/atmel_nand.c
@@ -650,8 +650,8 @@ static int __init atmel_nand_probe(struct platform_device *pdev)
mtd->name = "atmel_nand";
- res = mtd_device_parse_register(mtd, NULL, 0,
- host->board->parts, host->board->num_parts);
+ res = mtd_device_parse_register(mtd, NULL, NULL, host->board->parts,
+ host->board->num_parts);
if (!res)
return res;
diff --git a/drivers/mtd/nand/bcm_umi_nand.c b/drivers/mtd/nand/bcm_umi_nand.c
index 50387fd..ee81b63 100644
--- a/drivers/mtd/nand/bcm_umi_nand.c
+++ b/drivers/mtd/nand/bcm_umi_nand.c
@@ -488,7 +488,7 @@ static int __devinit bcm_umi_nand_probe(struct platform_device *pdev)
/* Register the partitions */
board_mtd->name = "bcm_umi-nand";
- mtd_device_parse_register(board_mtd, NULL, 0, NULL, 0);
+ mtd_device_parse_register(board_mtd, NULL, NULL, NULL, 0);
/* Return happy */
return 0;
diff --git a/drivers/mtd/nand/cafe_nand.c b/drivers/mtd/nand/cafe_nand.c
index 72d3f23..c23c07c 100644
--- a/drivers/mtd/nand/cafe_nand.c
+++ b/drivers/mtd/nand/cafe_nand.c
@@ -799,7 +799,7 @@ static int __devinit cafe_nand_probe(struct pci_dev *pdev,
pci_set_drvdata(pdev, mtd);
mtd->name = "cafe_nand";
- mtd_device_parse_register(mtd, part_probes, 0, NULL, 0);
+ mtd_device_parse_register(mtd, part_probes, NULL, NULL, 0);
goto out;
diff --git a/drivers/mtd/nand/cmx270_nand.c b/drivers/mtd/nand/cmx270_nand.c
index 737ef9a..1024bfc 100644
--- a/drivers/mtd/nand/cmx270_nand.c
+++ b/drivers/mtd/nand/cmx270_nand.c
@@ -219,7 +219,7 @@ static int __init cmx270_init(void)
- ret = mtd_device_parse_register(cmx270_nand_mtd, NULL, 0,
+ ret = mtd_device_parse_register(cmx270_nand_mtd, NULL, NULL,
partition_info, NUM_PARTITIONS);
if (ret)
goto err_scan;
diff --git a/drivers/mtd/nand/cs553x_nand.c b/drivers/mtd/nand/cs553x_nand.c
index 414afa7..e2b7c9e 100644
--- a/drivers/mtd/nand/cs553x_nand.c
+++ b/drivers/mtd/nand/cs553x_nand.c
@@ -313,7 +313,7 @@ static int __init cs553x_init(void)
for (i = 0; i < NR_CS553X_CONTROLLERS; i++) {
if (cs553x_mtd[i]) {
/* If any devices registered, return success. Else the last error. */
- mtd_device_parse_register(cs553x_mtd[i], NULL, 0,
+ mtd_device_parse_register(cs553x_mtd[i], NULL, NULL,
NULL, 0);
err = 0;
diff --git a/drivers/mtd/nand/davinci_nand.c b/drivers/mtd/nand/davinci_nand.c
index 6e56615..b81afc7 100644
--- a/drivers/mtd/nand/davinci_nand.c
+++ b/drivers/mtd/nand/davinci_nand.c
@@ -752,8 +752,8 @@ syndrome_done:
if (ret < 0)
goto err_scan;
- ret = mtd_device_parse_register(&info->mtd, NULL, 0,
+ ret = mtd_device_parse_register(&info->mtd, NULL, NULL, pdata->parts,
+ pdata->nr_parts);
if (ret < 0)
goto err_scan;
diff --git a/drivers/mtd/nand/fsmc_nand.c b/drivers/mtd/nand/fsmc_nand.c
index 4a018d0..341086c 100644
--- a/drivers/mtd/nand/fsmc_nand.c
+++ b/drivers/mtd/nand/fsmc_nand.c
@@ -940,13 +940,13 @@ static int __init fsmc_nand_probe(struct platform_device *pdev)
* Check for partition info passed
host->mtd.name = "nand";
- ret = mtd_device_parse_register(&host->mtd, NULL, 0,
- host->mtd.size <= 0x04000000 ?
- partition_info_16KB_blk :
- partition_info_128KB_blk,
- ARRAY_SIZE(partition_info_16KB_blk) :
- ARRAY_SIZE(partition_info_128KB_blk));
+ ret = mtd_device_parse_register(&host->mtd, NULL, NULL,
+ host->mtd.size <= 0x04000000 ?
+ partition_info_16KB_blk :
+ partition_info_128KB_blk,
+ ARRAY_SIZE(partition_info_16KB_blk) :
+ ARRAY_SIZE(partition_info_128KB_blk));
if (ret)
goto err_probe;
diff --git a/drivers/mtd/nand/h1910.c b/drivers/mtd/nand/h1910.c
index 5dc6f0d..11e4878 100644
--- a/drivers/mtd/nand/h1910.c
+++ b/drivers/mtd/nand/h1910.c
@@ -135,8 +135,8 @@ static int __init h1910_init(void)
- mtd_device_parse_register(h1910_nand_mtd, NULL, 0,
- partition_info, NUM_PARTITIONS);
+ mtd_device_parse_register(h1910_nand_mtd, NULL, NULL, partition_info,
+ NUM_PARTITIONS);
/* Return happy */
return 0;
diff --git a/drivers/mtd/nand/jz4740_nand.c b/drivers/mtd/nand/jz4740_nand.c
index ac3b9f2..cc50e35 100644
--- a/drivers/mtd/nand/jz4740_nand.c
+++ b/drivers/mtd/nand/jz4740_nand.c
@@ -367,9 +367,9 @@ static int __devinit jz_nand_probe(struct platform_device *pdev)
goto err_gpio_free;
- ret = mtd_device_parse_register(mtd, NULL, 0,
- pdata ? pdata->partitions : NULL,
- pdata ? pdata->num_partitions : 0);
+ ret = mtd_device_parse_register(mtd, NULL, NULL,
+ pdata ? pdata->partitions : NULL,
+ pdata ? pdata->num_partitions : 0);
if (ret) {
dev_err(&pdev->dev, "Failed to add mtd device\n");
diff --git a/drivers/mtd/nand/mxc_nand.c b/drivers/mtd/nand/mxc_nand.c
index 74a43b8..3c4c053 100644
--- a/drivers/mtd/nand/mxc_nand.c
+++ b/drivers/mtd/nand/mxc_nand.c
@@ -1226,8 +1226,8 @@ static int __init mxcnd_probe(struct platform_device *pdev)
+ mtd_device_parse_register(mtd, part_probes, NULL, pdata->parts,
+ pdata->nr_parts);
platform_set_drvdata(pdev, host);
diff --git a/drivers/mtd/nand/omap2.c b/drivers/mtd/nand/omap2.c
index b3a883e..d2e7a7d 100644
--- a/drivers/mtd/nand/omap2.c
+++ b/drivers/mtd/nand/omap2.c
@@ -1101,8 +1101,8 @@ static int __devinit omap_nand_probe(struct platform_device *pdev)
goto out_release_mem_region;
- mtd_device_parse_register(&info->mtd, NULL, 0,
+ mtd_device_parse_register(&info->mtd, NULL, NULL, pdata->parts,
+ pdata->nr_parts);
platform_set_drvdata(pdev, &info->mtd);
diff --git a/drivers/mtd/nand/orion_nand.c b/drivers/mtd/nand/orion_nand.c
index 29f505a..1d3bfb2 100644
--- a/drivers/mtd/nand/orion_nand.c
+++ b/drivers/mtd/nand/orion_nand.c
@@ -129,8 +129,8 @@ static int __init orion_nand_probe(struct platform_device *pdev)
mtd->name = "orion_nand";
- board->parts, board->nr_parts);
+ ret = mtd_device_parse_register(mtd, NULL, NULL, board->parts,
+ board->nr_parts);
if (ret) {
nand_release(mtd);
goto no_dev;
diff --git a/drivers/mtd/nand/plat_nand.c b/drivers/mtd/nand/plat_nand.c
index 7f2da69..6404e6e 100644
--- a/drivers/mtd/nand/plat_nand.c
+++ b/drivers/mtd/nand/plat_nand.c
@@ -99,8 +99,9 @@ static int __devinit plat_nand_probe(struct platform_device *pdev)
err = mtd_device_parse_register(&data->mtd,
- pdata->chip.part_probe_types, 0,
- pdata->chip.partitions, pdata->chip.nr_partitions);
+ pdata->chip.part_probe_types, NULL,
+ pdata->chip.partitions,
+ pdata->chip.nr_partitions);
if (!err)
return err;
diff --git a/drivers/mtd/nand/ppchameleonevb.c b/drivers/mtd/nand/ppchameleonevb.c
index 7e52af5..0ddd90e 100644
--- a/drivers/mtd/nand/ppchameleonevb.c
+++ b/drivers/mtd/nand/ppchameleonevb.c
@@ -275,11 +275,10 @@ static int __init ppchameleonevb_init(void)
ppchameleon_mtd->name = "ppchameleon-nand";
- mtd_device_parse_register(ppchameleon_mtd, NULL, 0,
- ppchameleon_mtd->size == NAND_SMALL_SIZE ?
- partition_info_me :
- partition_info_hi,
- NUM_PARTITIONS);
+ mtd_device_parse_register(ppchameleon_mtd, NULL, NULL,
+ ppchameleon_mtd->size == NAND_SMALL_SIZE ?
+ partition_info_me : partition_info_hi,
+ NUM_PARTITIONS);
nand_evb_init:
@@ -365,11 +364,10 @@ static int __init ppchameleonevb_init(void)
ppchameleonevb_mtd->name = NAND_EVB_MTD_NAME;
- mtd_device_parse_register(ppchameleonevb_mtd, NULL, 0,
- NUM_PARTITIONS);
+ mtd_device_parse_register(ppchameleonevb_mtd, NULL, NULL,
+ NUM_PARTITIONS);
/* Return happy */
return 0;
diff --git a/drivers/mtd/nand/pxa3xx_nand.c b/drivers/mtd/nand/pxa3xx_nand.c
index 5c3d719..d3bdc90 100644
--- a/drivers/mtd/nand/pxa3xx_nand.c
+++ b/drivers/mtd/nand/pxa3xx_nand.c
@@ -1228,8 +1228,9 @@ static int pxa3xx_nand_probe(struct platform_device *pdev)
continue;
- ret = mtd_device_parse_register(info->host[cs]->mtd, NULL, 0,
- pdata->parts[cs], pdata->nr_parts[cs]);
+ ret = mtd_device_parse_register(info->host[cs]->mtd, NULL,
+ NULL, pdata->parts[cs],
+ pdata->nr_parts[cs]);
if (!ret)
probe_success = 1;
diff --git a/drivers/mtd/nand/s3c2410.c b/drivers/mtd/nand/s3c2410.c
index 868685d..97623be 100644
--- a/drivers/mtd/nand/s3c2410.c
+++ b/drivers/mtd/nand/s3c2410.c
@@ -751,8 +751,8 @@ static int s3c2410_nand_add_partition(struct s3c2410_nand_info *info,
if (set)
mtd->mtd.name = set->name;
- return mtd_device_parse_register(&mtd->mtd, NULL, 0,
- set->partitions, set->nr_partitions);
+ return mtd_device_parse_register(&mtd->mtd, NULL, NULL,
+ set->partitions, set->nr_partitions);
diff --git a/drivers/mtd/nand/sharpsl.c b/drivers/mtd/nand/sharpsl.c
index b175c0f..2d269a5 100644
--- a/drivers/mtd/nand/sharpsl.c
+++ b/drivers/mtd/nand/sharpsl.c
@@ -181,8 +181,8 @@ static int __devinit sharpsl_nand_probe(struct platform_device *pdev)
sharpsl->mtd.name = "sharpsl-nand";
- err = mtd_device_parse_register(&sharpsl->mtd, NULL, 0,
- data->partitions, data->nr_partitions);
+ err = mtd_device_parse_register(&sharpsl->mtd, NULL, NULL,
+ data->partitions, data->nr_partitions);
if (err)
goto err_add;
diff --git a/drivers/mtd/nand/tmio_nand.c b/drivers/mtd/nand/tmio_nand.c
index 6caa0cd..060848a 100644
--- a/drivers/mtd/nand/tmio_nand.c
+++ b/drivers/mtd/nand/tmio_nand.c
@@ -456,9 +456,9 @@ static int tmio_probe(struct platform_device *dev)
goto err_scan;
- retval = mtd_device_parse_register(mtd, NULL, 0,
- data ? data->partition : NULL,
- data ? data->num_partitions : 0);
+ retval = mtd_device_parse_register(mtd, NULL, NULL,
+ data ? data->partition : NULL,
+ data ? data->num_partitions : 0);
if (!retval)
return retval;
diff --git a/drivers/mtd/nand/txx9ndfmc.c b/drivers/mtd/nand/txx9ndfmc.c
index c7c4f1d..8db0acb 100644
--- a/drivers/mtd/nand/txx9ndfmc.c
+++ b/drivers/mtd/nand/txx9ndfmc.c
@@ -386,7 +386,7 @@ static int __init txx9ndfmc_probe(struct platform_device *dev)
mtd->name = txx9_priv->mtdname;
- mtd_device_parse_register(mtd, NULL, 0, NULL, 0);
+ mtd_device_parse_register(mtd, NULL, NULL, NULL, 0);
drvdata->mtds[i] = mtd;
diff --git a/drivers/mtd/onenand/generic.c b/drivers/mtd/onenand/generic.c
index 0ccd5bf..1c4f97c 100644
--- a/drivers/mtd/onenand/generic.c
+++ b/drivers/mtd/onenand/generic.c
@@ -70,9 +70,9 @@ static int __devinit generic_onenand_probe(struct platform_device *pdev)
goto out_iounmap;
- err = mtd_device_parse_register(&info->mtd, NULL, 0,
- pdata ? pdata->parts : NULL,
- pdata ? pdata->nr_parts : 0);
+ err = mtd_device_parse_register(&info->mtd, NULL, NULL,
+ pdata ? pdata->parts : NULL,
+ pdata ? pdata->nr_parts : 0);
diff --git a/drivers/mtd/onenand/omap2.c b/drivers/mtd/onenand/omap2.c
index 7e9ea68..398a827 100644
--- a/drivers/mtd/onenand/omap2.c
+++ b/drivers/mtd/onenand/omap2.c
@@ -751,9 +751,9 @@ static int __devinit omap2_onenand_probe(struct platform_device *pdev)
if ((r = onenand_scan(&c->mtd, 1)) < 0)
goto err_release_regulator;
- r = mtd_device_parse_register(&c->mtd, NULL, 0,
+ r = mtd_device_parse_register(&c->mtd, NULL, NULL,
if (r)
goto err_release_onenand;
diff --git a/drivers/mtd/onenand/samsung.c b/drivers/mtd/onenand/samsung.c
index deaf762..8e4b3f2 100644
--- a/drivers/mtd/onenand/samsung.c
+++ b/drivers/mtd/onenand/samsung.c
@@ -1014,7 +1014,7 @@ static int s3c_onenand_probe(struct platform_device *pdev)
if (s3c_read_reg(MEM_CFG_OFFSET) & ONENAND_SYS_CFG1_SYNC_READ)
dev_info(&onenand->pdev->dev, "OneNAND Sync. Burst Read enabled\n");
- err = mtd_device_parse_register(mtd, NULL, 0,
+ err = mtd_device_parse_register(mtd, NULL, NULL,
pdata ? pdata->nr_parts : 0); |
