mtd: cfi_cmdset_0002: use swap() in cfi_cmdset_0002()
Author: Fabian Frederick <fabf@skynet.be>
Use kernel.h macro definition.
Thanks to Julia Lawall for Coccinelle scripting support.
Signed-off-by: Fabian Frederick
Signed-off-by: Brian Norris
drivers/mtd/chips/cfi_cmdset_0002.c | 6 ++----
1 file changed, 2 insertions(+), 4 deletions(-)
diff --git a/drivers/mtd/chips/cfi_cmdset_0002.c b/drivers/mtd/chips/cfi_cmdset_0002.c
index c3624eb..9dca881 100644
--- a/drivers/mtd/chips/cfi_cmdset_0002.c
+++ b/drivers/mtd/chips/cfi_cmdset_0002.c
@@ -615,11 +615,9 @@ struct mtd_info *cfi_cmdset_0002(struct map_info *map, int primary)
for (i=0; i<cfi->cfiq->NumEraseRegions / 2; i++) {
int j = (cfi->cfiq->NumEraseRegions-1)-i;
- __u32 swap;
- swap = cfi->cfiq->EraseRegionInfo[i];
- cfi->cfiq->EraseRegionInfo[i] = cfi->cfiq->EraseRegionInfo[j];
- cfi->cfiq->EraseRegionInfo[j] = swap;
+ swap(cfi->cfiq->EraseRegionInfo[i],
+ cfi->cfiq->EraseRegionInfo[j]);
/* Set the default CFI lock/unlock addresses */ |
- __u32 swap;
