mtd: block2mtd: Use kasprintf
kasprintf combines kmalloc and sprintf, and takes care of the size
calculation itself.
The semantic patch that makes this change is as follows:
(http://coccinelle.lip6.fr/)
expression a,flag;
expression list args;
statement S;
  a =
-  \(kmalloc\|kzalloc\)(...,flag)
+  kasprintf(flag,args)
  <... when != a
  if (a == NULL || ...) S
- sprintf(a,args);
Signed-off-by: Julia Lawall
Signed-off-by: David Woodhouse
 drivers/mtd/devices/block2mtd.c | 4 +---
 1 file changed, 1 insertion(+), 3 deletions(-)
diff --git a/drivers/mtd/devices/block2mtd.c b/drivers/mtd/devices/block2mtd.c
index 8c295f4..4281f3e 100644
--- a/drivers/mtd/devices/block2mtd.c
+++ b/drivers/mtd/devices/block2mtd.c
@@ -275,12 +275,10 @@ static struct block2mtd_dev *add_device(char *devname, int erase_size)
 	/* Setup the MTD structure */
 	/* make the name contain the block device in */
-	name = kmalloc(sizeof("block2mtd: ") + strlen(devname) + 1,
-			GFP_KERNEL);
+	name = kasprintf(GFP_KERNEL, "block2mtd: %s", devname);
 	if (!name)
 		goto devinit_err;
-	sprintf(name, "block2mtd: %s", devname);
 	dev->mtd.name = name;
 	dev->mtd.size = dev->blkdev->bd_inode->i_size & PAGE_MASK;
BtrLinux
Privacy Overview
