mn10300: Convert genirq namespace
Author: Thomas Gleixner <tglx@linutronix.de>
Convert to new function names. Converted with coccinelle.
Signed-off-by: Thomas Gleixner
 arch/mn10300/kernel/irq.c            |  6 +++---
 arch/mn10300/kernel/mn10300-serial.c |  2 +-
 arch/mn10300/kernel/smp.c            | 12 ++++++------
 arch/mn10300/unit-asb2364/irq-fpga.c |  3 ++-
 4 files changed, 12 insertions(+), 11 deletions(-)
diff --git a/arch/mn10300/kernel/irq.c b/arch/mn10300/kernel/irq.c
index 5f7fc3e..4755122 100644
--- a/arch/mn10300/kernel/irq.c
+++ b/arch/mn10300/kernel/irq.c
@@ -263,7 +263,7 @@ void set_intr_level(int irq, u16 level)
 void mn10300_set_lateack_irq_type(int irq)
-	set_irq_chip_and_handler(irq, &mn10300_cpu_pic_level,
+	irq_set_chip_and_handler(irq, &mn10300_cpu_pic_level,
 				 handle_level_irq);
@@ -275,12 +275,12 @@ void __init init_IRQ(void)
 	int irq;
 	for (irq = 0; irq < NR_IRQS; irq++)
-		if (get_irq_chip(irq) == &no_irq_chip)
+		if (irq_get_chip(irq) == &no_irq_chip)
 			/* due to the PIC latching interrupt requests, even
 			 * when the IRQ is disabled, IRQ_PENDING is superfluous
 			 * and we can use handle_level_irq() for edge-triggered
 			 * interrupts */
-			set_irq_chip_and_handler(irq, &mn10300_cpu_pic_edge,
+			irq_set_chip_and_handler(irq, &mn10300_cpu_pic_edge,
 						 handle_level_irq);
 	unit_init_IRQ();
diff --git a/arch/mn10300/kernel/mn10300-serial.c b/arch/mn10300/kernel/mn10300-serial.c
index efca426..94901c5 100644
--- a/arch/mn10300/kernel/mn10300-serial.c
+++ b/arch/mn10300/kernel/mn10300-serial.c
@@ -933,7 +933,7 @@ static int mn10300_serial_startup(struct uart_port *_port)
 		NUM2GxICR_LEVEL(CONFIG_MN10300_SERIAL_IRQ_LEVEL));
 	set_intr_level(port->tx_irq,
-	set_irq_chip(port->tm_irq, &mn10300_serial_pic);
+	irq_set_chip(port->tm_irq, &mn10300_serial_pic);
 	if (request_irq(port->rx_irq, mn10300_serial_interrupt,
 			IRQF_DISABLED, port->rx_name, port) < 0)
diff --git a/arch/mn10300/kernel/smp.c b/arch/mn10300/kernel/smp.c
index 51c02f9..226c826 100644
--- a/arch/mn10300/kernel/smp.c
+++ b/arch/mn10300/kernel/smp.c
@@ -156,15 +156,15 @@ static void init_ipi(void)
 	u16 tmp16;
 	/* set up the reschedule IPI */
-	set_irq_chip_and_handler(RESCHEDULE_IPI,
-				 &mn10300_ipi_type, handle_percpu_irq);
+	irq_set_chip_and_handler(RESCHEDULE_IPI, &mn10300_ipi_type,
+				 handle_percpu_irq);
 	setup_irq(RESCHEDULE_IPI, &reschedule_ipi);
 	set_intr_level(RESCHEDULE_IPI, RESCHEDULE_GxICR_LV);
 	mn10300_ipi_enable(RESCHEDULE_IPI);
 	/* set up the call function IPI */
-	set_irq_chip_and_handler(CALL_FUNC_SINGLE_IPI,
+	irq_set_chip_and_handler(CALL_FUNC_SINGLE_IPI, &mn10300_ipi_type,
 	setup_irq(CALL_FUNC_SINGLE_IPI, &call_function_ipi);
 	set_intr_level(CALL_FUNC_SINGLE_IPI, CALL_FUNCTION_GxICR_LV);
 	mn10300_ipi_enable(CALL_FUNC_SINGLE_IPI);
@@ -172,8 +172,8 @@ static void init_ipi(void)
 	/* set up the local timer IPI */
 #if !defined(CONFIG_GENERIC_CLOCKEVENTS) || \
     defined(CONFIG_GENERIC_CLOCKEVENTS_BROADCAST)
-	set_irq_chip_and_handler(LOCAL_TIMER_IPI,
+	irq_set_chip_and_handler(LOCAL_TIMER_IPI, &mn10300_ipi_type,
 	setup_irq(LOCAL_TIMER_IPI, &local_timer_ipi);
 	set_intr_level(LOCAL_TIMER_IPI, LOCAL_TIMER_GxICR_LV);
 	mn10300_ipi_enable(LOCAL_TIMER_IPI);
diff --git a/arch/mn10300/unit-asb2364/irq-fpga.c b/arch/mn10300/unit-asb2364/irq-fpga.c
index ee84e62..e16c216 100644
--- a/arch/mn10300/unit-asb2364/irq-fpga.c
+++ b/arch/mn10300/unit-asb2364/irq-fpga.c
@@ -100,7 +100,8 @@ void __init irq_fpga_init(void)
 	SyncExBus();
 	for (irq = NR_CPU_IRQS; irq < NR_IRQS; irq++)
-		set_irq_chip_and_handler(irq, &asb2364_fpga_pic, handle_level_irq);
+		irq_set_chip_and_handler(irq, &asb2364_fpga_pic,
+					 handle_level_irq);
 	/* the FPGA drives the XIRQ1 input on the CPU PIC */
 	setup_irq(XIRQ1, &fpga_irq[0]);
BtrLinux
Résumé de la politique de confidentialité
Ce site utilise des cookies afin que nous puissions vous fournir la meilleure expérience utilisateur possible. Les informations sur les cookies sont stockées dans votre navigateur et remplissent des fonctions telles que vous reconnaître lorsque vous revenez sur notre site Web et aider notre équipe à comprendre les sections du site que vous trouvez les plus intéressantes et utiles.
