mm/slab_common.c: use kmem_cache_free()
Author: Vaishali Thakkar <vthakkar1994@gmail.com>
Here, free memory is allocated using kmem_cache_zalloc.  So, use
kmem_cache_free instead of kfree.
This is done using Coccinelle and semantic patch used
is as follows:
expression x,E,c;
 x = \(kmem_cache_alloc\|kmem_cache_zalloc\|kmem_cache_alloc_node\)(c,...)
 ... when != x = E
     when != &x
?-kfree(x)
+kmem_cache_free(c,x)
Signed-off-by: Vaishali Thakkar
Acked-by: Christoph Lameter
Cc: Pekka Enberg
Acked-by: David Rientjes
Cc: Joonsoo Kim
Signed-off-by: Andrew Morton
Signed-off-by: Linus Torvalds
 mm/slab_common.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/mm/slab_common.c b/mm/slab_common.c
index e03dd6f..67f182c 100644
--- a/mm/slab_common.c
+++ b/mm/slab_common.c
@@ -331,7 +331,7 @@ out:
 out_free_cache:
 	memcg_free_cache_params(s);
-	kfree(s);
+	kmem_cache_free(kmem_cache, s);
 	goto out;
BtrLinux
Privacy Overview
