mmc: sdhci: host: fix odd_ptr_err.cocci warnings
Author: Wu Fengguang <fengguang.wu@intel.com>
drivers/mmc/host/sdhci_f_sdh30.c:143:5-11: inconsistent IS_ERR and PTR_ERR, PTR_ERR on line 144
 PTR_ERR should access the value just tested by IS_ERR
Semantic patch information:
 There can be false positives in the patch case, where it is the call
 IS_ERR that is wrong.
Generated by: scripts/coccinelle/tests/odd_ptr_err.cocci
CC: Vincent Yang
Signed-off-by: Fengguang Wu
Signed-off-by: Ulf Hansson
 drivers/mmc/host/sdhci_f_sdh30.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/mmc/host/sdhci_f_sdh30.c b/drivers/mmc/host/sdhci_f_sdh30.c
index c1bb156..2fe8b91 100644
--- a/drivers/mmc/host/sdhci_f_sdh30.c
+++ b/drivers/mmc/host/sdhci_f_sdh30.c
@@ -141,7 +141,7 @@ static int sdhci_f_sdh30_probe(struct platform_device *pdev)
 	res = platform_get_resource(pdev, IORESOURCE_MEM, 0);
 	host->ioaddr = devm_ioremap_resource(&pdev->dev, res);
 	if (IS_ERR(host->ioaddr)) {
-		ret = PTR_ERR(host);
+		ret = PTR_ERR(host->ioaddr);
 		goto err;
BtrLinux
Privacy Overview
