mmc: Remove redundant spi driver bus initialization
Author: Lars-Peter Clausen <lars@metafoo.de>
In ancient times it was necessary to manually initialize the bus field of an
spi_driver to spi_bus_type. These days this is done in spi_driver_register(),
so we can drop the manual assignment.
The patch was generated using the following coccinelle semantic patch:
identifier _driver;
struct spi_driver _driver = {
	.driver = {
-		.bus = &spi_bus_type,
Signed-off-by: Lars-Peter Clausen
Signed-off-by: Chris Ball
 drivers/mmc/host/mmc_spi.c | 1 -
 1 file changed, 1 deletion(-)
diff --git a/drivers/mmc/host/mmc_spi.c b/drivers/mmc/host/mmc_spi.c
index 92946b8..273306c 100644
--- a/drivers/mmc/host/mmc_spi.c
+++ b/drivers/mmc/host/mmc_spi.c
@@ -1525,7 +1525,6 @@ static struct of_device_id mmc_spi_of_match_table[] __devinitdata = {
 static struct spi_driver mmc_spi_driver = {
 	.driver = {
 		.name =		"mmc_spi",
 		.owner =	THIS_MODULE,
 		.of_match_table = mmc_spi_of_match_table,
BtrLinux
Privacy Overview
