mm: use memdup_user
Use memdup_user when user data is immediately copied into the
allocated region.
The semantic patch that makes this change is as follows:
(http://coccinelle.lip6.fr/)
expression from,to,size,flag;
position p;
identifier l1,l2;
-  to = \(kmalloc@p\|kzalloc@p\)(size,flag);
+  to = memdup_user(from,size);
   if (
-      to==NULL
+      IS_ERR(to)
   <+... when != goto l1;
-  -ENOMEM
+  PTR_ERR(to)
-  if (copy_from_user(to, from, size) != 0) {
-    <+... when != goto l2;
-    -EFAULT
Signed-off-by: Julia Lawall
Cc: KOSAKI Motohiro
Signed-off-by: Andrew Morton
Signed-off-by: Linus Torvalds
 mm/util.c | 11 +++--------
 1 file changed, 3 insertions(+), 8 deletions(-)
diff --git a/mm/util.c b/mm/util.c
index f5712e8..4735ea4 100644
--- a/mm/util.c
+++ b/mm/util.c
@@ -225,15 +225,10 @@ char *strndup_user(const char __user *s, long n)
 	if (length > n)
 		return ERR_PTR(-EINVAL);
-	p = kmalloc(length, GFP_KERNEL);
+	p = memdup_user(s, length);
-	if (!p)
-		return ERR_PTR(-ENOMEM);
-	if (copy_from_user(p, s, length)) {
-		kfree(p);
-		return ERR_PTR(-EFAULT);
+	if (IS_ERR(p))
+		return p;
 	p[length - 1] = '\0';
BtrLinux
Privacy Overview
