mm, fs: get rid of PAGE_CACHE_* and page_cache_{get,release} macros
Author: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
PAGE_CACHE_{SIZE,SHIFT,MASK,ALIGN} macros were introduced *long* time
ago with promise that one day it will be possible to implement page
cache with bigger chunks than PAGE_SIZE.
This promise never materialized.  And unlikely will.
We have many places where PAGE_CACHE_SIZE assumed to be equal to
PAGE_SIZE.  And it's constant source of confusion on whether
PAGE_CACHE_* or PAGE_* constant should be used in a particular case,
especially on the border between fs and mm.
Global switching to PAGE_CACHE_SIZE != PAGE_SIZE would cause to much
breakage to be doable.
Let's stop pretending that pages in page cache are special.  They are
not.
The changes are pretty straight-forward:
 -  << (PAGE_CACHE_SHIFT - PAGE_SHIFT) -> ;
 -  >> (PAGE_CACHE_SHIFT - PAGE_SHIFT) -> ;
 - PAGE_CACHE_{SIZE,SHIFT,MASK,ALIGN} -> PAGE_{SIZE,SHIFT,MASK,ALIGN};
 - page_cache_get() -> get_page();
 - page_cache_release() -> put_page();
This patch contains automated changes generated with coccinelle using
script below.  For some reason, coccinelle doesn't patch header files.
I've called spatch for them manually.
The only adjustment after coccinelle is revert of changes to
PAGE_CAHCE_ALIGN definition: we are going to drop it later.
There are few places in the code where coccinelle didn't reach.  I'll
fix them manually in a separate patch.  Comments and documentation also
will be addressed with the separate patch.
virtual patch
expression E;
- E << (PAGE_CACHE_SHIFT - PAGE_SHIFT)
+ E
expression E;
- E >> (PAGE_CACHE_SHIFT - PAGE_SHIFT)
+ E
- PAGE_CACHE_SHIFT
+ PAGE_SHIFT
- PAGE_CACHE_SIZE
+ PAGE_SIZE
- PAGE_CACHE_MASK
+ PAGE_MASK
expression E;
- PAGE_CACHE_ALIGN(E)
+ PAGE_ALIGN(E)
expression E;
- page_cache_get(E)
+ get_page(E)
expression E;
- page_cache_release(E)
+ put_page(E)
Signed-off-by: Kirill A. Shutemov
Acked-by: Michal Hocko
Signed-off-by: Linus Torvalds
 arch/arc/mm/cache.c                                |   2 +-
 arch/arm/mm/flush.c                                |   4 +-
 arch/parisc/kernel/cache.c                         |   2 +-
 arch/powerpc/platforms/cell/spufs/inode.c          |   4 +-
 arch/s390/hypfs/inode.c                            |   4 +-
 block/bio.c                                        |   8 +-
 block/blk-core.c                                   |   2 +-
 block/blk-settings.c                               |  12 +-
 block/blk-sysfs.c                                  |   8 +-
 block/cfq-iosched.c                                |   2 +-
 block/compat_ioctl.c                               |   4 +-
 block/ioctl.c                                      |   4 +-
 block/partition-generic.c                          |   8 +-
 drivers/block/aoe/aoeblk.c                         |   2 +-
 drivers/block/brd.c                                |   2 +-
 drivers/block/drbd/drbd_nl.c                       |   2 +-
 drivers/gpu/drm/amd/amdgpu/amdgpu_ttm.c            |   2 +-
 drivers/gpu/drm/armada/armada_gem.c                |   4 +-
 drivers/gpu/drm/drm_gem.c                          |   4 +-
 drivers/gpu/drm/i915/i915_gem.c                    |   8 +-
 drivers/gpu/drm/i915/i915_gem_userptr.c            |   2 +-
 drivers/gpu/drm/radeon/radeon_ttm.c                |   2 +-
 drivers/gpu/drm/ttm/ttm_tt.c                       |   4 +-
 drivers/gpu/drm/via/via_dmablit.c                  |   2 +-
 drivers/md/bitmap.c                                |   2 +-
 drivers/media/v4l2-core/videobuf-dma-sg.c          |   2 +-
 drivers/misc/ibmasm/ibmasmfs.c                     |   4 +-
 drivers/misc/vmw_vmci/vmci_queue_pair.c            |   2 +-
 drivers/mmc/core/host.c                            |   6 +-
 drivers/mmc/host/sh_mmcif.c                        |   2 +-
 drivers/mmc/host/tmio_mmc_dma.c                    |   4 +-
 drivers/mmc/host/tmio_mmc_pio.c                    |   2 +-
 drivers/mmc/host/usdhi6rol0.c                      |   2 +-
 drivers/mtd/devices/block2mtd.c                    |   6 +-
 drivers/mtd/nand/nandsim.c                         |   6 +-
 drivers/nvdimm/btt.c                               |   2 +-
 drivers/nvdimm/pmem.c                              |   2 +-
 drivers/oprofile/oprofilefs.c                      |   4 +-
 drivers/scsi/sd.c                                  |   2 +-
 drivers/scsi/st.c                                  |   4 +-
 .../lustre/include/linux/libcfs/libcfs_private.h   |   2 +-
 .../lustre/include/linux/libcfs/linux/linux-mem.h  |   4 +-
 .../lustre/lnet/klnds/socklnd/socklnd_lib.c        |   2 +-
 drivers/staging/lustre/lnet/libcfs/debug.c         |   2 +-
 drivers/staging/lustre/lnet/libcfs/tracefile.c     |  16 +-
 drivers/staging/lustre/lnet/libcfs/tracefile.h     |   6 +-
 drivers/staging/lustre/lnet/lnet/lib-md.c          |   2 +-
 drivers/staging/lustre/lnet/lnet/lib-move.c        |   6 +-
 drivers/staging/lustre/lnet/lnet/lib-socket.c      |   4 +-
 drivers/staging/lustre/lnet/lnet/router.c          |   6 +-
 drivers/staging/lustre/lnet/selftest/brw_test.c    |  20 +-
 drivers/staging/lustre/lnet/selftest/conctl.c      |   4 +-
 drivers/staging/lustre/lnet/selftest/conrpc.c      |  10 +-
 drivers/staging/lustre/lnet/selftest/framework.c   |   2 +-
 drivers/staging/lustre/lnet/selftest/rpc.c         |   2 +-
 drivers/staging/lustre/lnet/selftest/selftest.h    |   2 +-
 .../lustre/include/linux/lustre_patchless_compat.h |   2 +-
 .../lustre/lustre/include/lustre/lustre_idl.h      |   2 +-
 drivers/staging/lustre/lustre/include/lustre_mdc.h |   4 +-
 drivers/staging/lustre/lustre/include/lustre_net.h |   6 +-
 drivers/staging/lustre/lustre/include/obd.h        |   2 +-
 .../staging/lustre/lustre/include/obd_support.h    |   2 +-
 drivers/staging/lustre/lustre/lclient/lcommon_cl.c |   4 +-
 drivers/staging/lustre/lustre/ldlm/ldlm_lib.c      |  12 +-
 drivers/staging/lustre/lustre/ldlm/ldlm_pool.c     |   2 +-
 drivers/staging/lustre/lustre/ldlm/ldlm_request.c  |   2 +-
 drivers/staging/lustre/lustre/llite/dir.c          |  18 +-
 .../staging/lustre/lustre/llite/llite_internal.h   |   8 +-
 drivers/staging/lustre/lustre/llite/llite_lib.c    |   8 +-
 drivers/staging/lustre/lustre/llite/llite_mmap.c   |   8 +-
 drivers/staging/lustre/lustre/llite/lloop.c        |  12 +-
 drivers/staging/lustre/lustre/llite/lproc_llite.c  |  18 +-
 drivers/staging/lustre/lustre/llite/rw.c           |  22 +-
 drivers/staging/lustre/lustre/llite/rw26.c         |  28 +--
 drivers/staging/lustre/lustre/llite/vvp_io.c       |   8 +-
 drivers/staging/lustre/lustre/llite/vvp_page.c     |   8 +-
 drivers/staging/lustre/lustre/lmv/lmv_obd.c        |   4 +-
 drivers/staging/lustre/lustre/mdc/mdc_request.c    |   6 +-
 drivers/staging/lustre/lustre/mgc/mgc_request.c    |  22 +-
 drivers/staging/lustre/lustre/obdclass/cl_page.c   |   6 +-
 drivers/staging/lustre/lustre/obdclass/class_obd.c |   6 +-
 .../lustre/lustre/obdclass/linux/linux-obdo.c      |   4 +-
 .../lustre/lustre/obdclass/linux/linux-sysctl.c    |   6 +-
 drivers/staging/lustre/lustre/obdclass/lu_object.c |   6 +-
 .../staging/lustre/lustre/obdecho/echo_client.c    |  30 +--
 drivers/staging/lustre/lustre/osc/lproc_osc.c      |  16 +-
 drivers/staging/lustre/lustre/osc/osc_cache.c      |  42 ++--
 drivers/staging/lustre/lustre/osc/osc_page.c       |   6 +-
 drivers/staging/lustre/lustre/osc/osc_request.c    |  26 +-
 drivers/staging/lustre/lustre/ptlrpc/client.c      |   6 +-
 drivers/staging/lustre/lustre/ptlrpc/import.c      |   2 +-
 .../staging/lustre/lustre/ptlrpc/lproc_ptlrpc.c    |   4 +-
 drivers/staging/lustre/lustre/ptlrpc/recover.c     |   2 +-
 drivers/staging/lustre/lustre/ptlrpc/sec_bulk.c    |   2 +-
 drivers/usb/gadget/function/f_fs.c                 |   4 +-
 drivers/usb/gadget/legacy/inode.c                  |   4 +-
 drivers/usb/storage/scsiglue.c                     |   2 +-
 drivers/video/fbdev/pvr2fb.c                       |   2 +-
 fs/9p/vfs_addr.c                                   |  18 +-
 fs/9p/vfs_file.c                                   |   4 +-
 fs/9p/vfs_super.c                                  |   2 +-
 fs/affs/file.c                                     |  26 +-
 fs/afs/dir.c                                       |   2 +-
 fs/afs/file.c                                      |   4 +-
 fs/afs/mntpt.c                                     |   6 +-
 fs/afs/super.c                                     |   4 +-
 fs/afs/write.c                                     |  26 +-
 fs/binfmt_elf.c                                    |   2 +-
 fs/binfmt_elf_fdpic.c                              |   2 +-
 fs/block_dev.c                                     |   4 +-
 fs/btrfs/check-integrity.c                         |  60 ++---
 fs/btrfs/compression.c                             |  84 +++----
 fs/btrfs/disk-io.c                                 |  14 +-
 fs/btrfs/extent-tree.c                             |   4 +-
 fs/btrfs/extent_io.c                               | 262 ++++++++++-----------
 fs/btrfs/extent_io.h                               |   6 +-
 fs/btrfs/file-item.c                               |   4 +-
 fs/btrfs/file.c                                    |  40 ++--
 fs/btrfs/free-space-cache.c                        |  30 +--
 fs/btrfs/inode-map.c                               |  10 +-
 fs/btrfs/inode.c                                   | 104 ++++----
 fs/btrfs/ioctl.c                                   |  84 +++----
 fs/btrfs/lzo.c                                     |  32 +--
 fs/btrfs/raid56.c                                  |  28 +--
 fs/btrfs/reada.c                                   |  30 +--
 fs/btrfs/relocation.c                              |  16 +-
 fs/btrfs/scrub.c                                   |  24 +-
 fs/btrfs/send.c                                    |  16 +-
 fs/btrfs/tests/extent-io-tests.c                   |  42 ++--
 fs/btrfs/tests/free-space-tests.c                  |   2 +-
 fs/btrfs/volumes.c                                 |  14 +-
 fs/btrfs/zlib.c                                    |  38 +--
 fs/buffer.c                                        | 100 ++++----
 fs/cachefiles/rdwr.c                               |  38 +--
 fs/ceph/addr.c                                     | 114 ++++-----
 fs/ceph/caps.c                                     |   2 +-
 fs/ceph/dir.c                                      |   4 +-
 fs/ceph/file.c                                     |  32 +--
 fs/ceph/inode.c                                    |   6 +-
 fs/ceph/mds_client.c                               |   2 +-
 fs/ceph/mds_client.h                               |   2 +-
 fs/ceph/super.c                                    |   8 +-
 fs/cifs/cifsfs.c                                   |   2 +-
 fs/cifs/cifssmb.c                                  |  16 +-
 fs/cifs/connect.c                                  |   2 +-
 fs/cifs/file.c                                     |  94 ++++----
 fs/cifs/inode.c                                    |  10 +-
 fs/configfs/mount.c                                |   4 +-
 fs/cramfs/inode.c                                  |  30 +--
 fs/crypto/crypto.c                                 |   8 +-
 fs/dax.c                                           |  30 +--
 fs/direct-io.c                                     |  26 +-
 fs/dlm/lowcomms.c                                  |   8 +-
 fs/ecryptfs/crypto.c                               |  22 +-
 fs/ecryptfs/inode.c                                |   4 +-
 fs/ecryptfs/keystore.c                             |   2 +-
 fs/ecryptfs/main.c                                 |   8 +-
 fs/ecryptfs/mmap.c                                 |  44 ++--
 fs/ecryptfs/read_write.c                           |  14 +-
 fs/efivarfs/super.c                                |   4 +-
 fs/exofs/dir.c                                     |  30 +--
 fs/exofs/inode.c                                   |  34 +--
 fs/exofs/namei.c                                   |   4 +-
 fs/ext2/dir.c                                      |  32 +--
 fs/ext2/namei.c                                    |   6 +-
 fs/ext4/crypto.c                                   |   8 +-
 fs/ext4/dir.c                                      |   4 +-
 fs/ext4/file.c                                     |   4 +-
 fs/ext4/inline.c                                   |  18 +-
 fs/ext4/inode.c                                    | 116 ++++-----
 fs/ext4/mballoc.c                                  |  36 +--
 fs/ext4/move_extent.c                              |  16 +-
 fs/ext4/page-io.c                                  |   4 +-
 fs/ext4/readpage.c                                 |  10 +-
 fs/ext4/super.c                                    |   4 +-
 fs/ext4/symlink.c                                  |   4 +-
 fs/f2fs/data.c                                     |  52 ++--
 fs/f2fs/debug.c                                    |   6 +-
 fs/f2fs/dir.c                                      |   4 +-
 fs/f2fs/f2fs.h                                     |   2 +-
 fs/f2fs/file.c                                     |  74 +++---
 fs/f2fs/inline.c                                   |  10 +-
 fs/f2fs/namei.c                                    |   4 +-
 fs/f2fs/node.c                                     |  10 +-
 fs/f2fs/recovery.c                                 |   2 +-
 fs/f2fs/segment.c                                  |  16 +-
 fs/f2fs/super.c                                    |   4 +-
 fs/freevxfs/vxfs_immed.c                           |   4 +-
 fs/freevxfs/vxfs_lookup.c                          |  12 +-
 fs/freevxfs/vxfs_subr.c                            |   2 +-
 fs/fs-writeback.c                                  |   2 +-
 fs/fscache/page.c                                  |  10 +-
 fs/fuse/dev.c                                      |  26 +-
 fs/fuse/file.c                                     |  72 +++---
 fs/fuse/inode.c                                    |  16 +-
 fs/gfs2/aops.c                                     |  44 ++--
 fs/gfs2/bmap.c                                     |  12 +-
 fs/gfs2/file.c                                     |  16 +-
 fs/gfs2/meta_io.c                                  |   4 +-
 fs/gfs2/quota.c                                    |  14 +-
 fs/gfs2/rgrp.c                                     |   5 +-
 fs/hfs/bnode.c                                     |  12 +-
 fs/hfs/btree.c                                     |  20 +-
 fs/hfs/inode.c                                     |   8 +-
 fs/hfsplus/bitmap.c                                |   2 +-
 fs/hfsplus/bnode.c                                 |  90 +++----
 fs/hfsplus/btree.c                                 |  22 +-
 fs/hfsplus/inode.c                                 |   8 +-
 fs/hfsplus/super.c                                 |   2 +-
 fs/hfsplus/xattr.c                                 |   6 +-
 fs/hostfs/hostfs_kern.c                            |  18 +-
 fs/hugetlbfs/inode.c                               |   8 +-
 fs/isofs/compress.c                                |  36 +--
 fs/isofs/inode.c                                   |   2 +-
 fs/jbd2/commit.c                                   |   4 +-
 fs/jbd2/journal.c                                  |   2 +-
 fs/jbd2/transaction.c                              |   4 +-
 fs/jffs2/debug.c                                   |   8 +-
 fs/jffs2/file.c                                    |  23 +-
 fs/jffs2/fs.c                                      |   8 +-
 fs/jffs2/gc.c                                      |   8 +-
 fs/jffs2/nodelist.c                                |   8 +-
 fs/jffs2/write.c                                   |   7 +-
 fs/jfs/jfs_metapage.c                              |  42 ++--
 fs/jfs/jfs_metapage.h                              |   4 +-
 fs/jfs/super.c                                     |   2 +-
 fs/kernfs/mount.c                                  |   4 +-
 fs/libfs.c                                         |  24 +-
 fs/logfs/dev_bdev.c                                |   2 +-
 fs/logfs/dev_mtd.c                                 |  10 +-
 fs/logfs/dir.c                                     |  12 +-
 fs/logfs/file.c                                    |  26 +-
 fs/logfs/readwrite.c                               |  20 +-
 fs/logfs/segment.c                                 |  28 +--
 fs/logfs/super.c                                   |  16 +-
 fs/minix/dir.c                                     |  18 +-
 fs/minix/namei.c                                   |   4 +-
 fs/mpage.c                                         |  20 +-
 fs/ncpfs/dir.c                                     |  10 +-
 fs/ncpfs/ncplib_kernel.h                           |   2 +-
 fs/nfs/blocklayout/blocklayout.c                   |  24 +-
 fs/nfs/blocklayout/blocklayout.h                   |   4 +-
 fs/nfs/client.c                                    |   8 +-
 fs/nfs/dir.c                                       |   4 +-
 fs/nfs/direct.c                                    |   8 +-
 fs/nfs/file.c                                      |  20 +-
 fs/nfs/internal.h                                  |   6 +-
 fs/nfs/nfs4xdr.c                                   |   2 +-
 fs/nfs/objlayout/objio_osd.c                       |   2 +-
 fs/nfs/pagelist.c                                  |   6 +-
 fs/nfs/pnfs.c                                      |   6 +-
 fs/nfs/read.c                                      |  16 +-
 fs/nfs/write.c                                     |   4 +-
 fs/nilfs2/bmap.c                                   |   2 +-
 fs/nilfs2/btnode.c                                 |  10 +-
 fs/nilfs2/dir.c                                    |  32 +--
 fs/nilfs2/gcinode.c                                |   2 +-
 fs/nilfs2/inode.c                                  |   4 +-
 fs/nilfs2/mdt.c                                    |  14 +-
 fs/nilfs2/namei.c                                  |   4 +-
 fs/nilfs2/page.c                                   |  18 +-
 fs/nilfs2/recovery.c                               |   4 +-
 fs/nilfs2/segment.c                                |   2 +-
 fs/ntfs/aops.c                                     |  48 ++--
 fs/ntfs/aops.h                                     |   2 +-
 fs/ntfs/attrib.c                                   |  28 +--
 fs/ntfs/bitmap.c                                   |  10 +-
 fs/ntfs/compress.c                                 |  56 ++---
 fs/ntfs/dir.c                                      |  40 ++--
 fs/ntfs/file.c                                     |  54 ++---
 fs/ntfs/index.c                                    |  12 +-
 fs/ntfs/inode.c                                    |   8 +-
 fs/ntfs/lcnalloc.c                                 |   6 +-
 fs/ntfs/logfile.c                                  |  16 +-
 fs/ntfs/mft.c                                      |  34 +--
 fs/ntfs/ntfs.h                                     |   2 +-
 fs/ntfs/super.c                                    |  58 ++---
 fs/ocfs2/alloc.c                                   |  28 +--
 fs/ocfs2/aops.c                                    |  48 ++--
 fs/ocfs2/cluster/heartbeat.c                       |  10 +-
 fs/ocfs2/dlmfs/dlmfs.c                             |   4 +-
 fs/ocfs2/file.c                                    |  14 +-
 fs/ocfs2/mmap.c                                    |   6 +-
 fs/ocfs2/ocfs2.h                                   |  20 +-
 fs/ocfs2/refcounttree.c                            |  22 +-
 fs/ocfs2/super.c                                   |   4 +-
 fs/orangefs/inode.c                                |  10 +-
 fs/orangefs/orangefs-bufmap.c                      |   4 +-
 fs/orangefs/orangefs-utils.c                       |   2 +-
 fs/pipe.c                                          |   6 +-
 fs/proc/task_mmu.c                                 |   2 +-
 fs/proc/vmcore.c                                   |   4 +-
 fs/pstore/inode.c                                  |   4 +-
 fs/qnx6/dir.c                                      |  16 +-
 fs/qnx6/inode.c                                    |   4 +-
 fs/qnx6/qnx6.h                                     |   2 +-
 fs/ramfs/inode.c                                   |   4 +-
 fs/reiserfs/file.c                                 |   4 +-
 fs/reiserfs/inode.c                                |  44 ++--
 fs/reiserfs/ioctl.c                                |   4 +-
 fs/reiserfs/journal.c                              |   4 +-
 fs/reiserfs/stree.c                                |   4 +-
 fs/reiserfs/tail_conversion.c                      |   4 +-
 fs/reiserfs/xattr.c                                |  18 +-
 fs/splice.c                                        |  32 +--
 fs/squashfs/block.c                                |   4 +-
 fs/squashfs/cache.c                                |  14 +-
 fs/squashfs/decompressor.c                         |   2 +-
 fs/squashfs/file.c                                 |  22 +-
 fs/squashfs/file_direct.c                          |  22 +-
 fs/squashfs/lz4_wrapper.c                          |   8 +-
 fs/squashfs/lzo_wrapper.c                          |   8 +-
 fs/squashfs/page_actor.c                           |   4 +-
 fs/squashfs/page_actor.h                           |   2 +-
 fs/squashfs/super.c                                |   2 +-
 fs/squashfs/symlink.c                              |   6 +-
 fs/squashfs/xz_wrapper.c                           |   4 +-
 fs/squashfs/zlib_wrapper.c                         |   4 +-
 fs/sync.c                                          |   4 +-
 fs/sysv/dir.c                                      |  18 +-
 fs/sysv/namei.c                                    |   4 +-
 fs/ubifs/file.c                                    |  52 ++--
 fs/ubifs/super.c                                   |   4 +-
 fs/ubifs/ubifs.h                                   |   4 +-
 fs/udf/file.c                                      |   6 +-
 fs/udf/inode.c                                     |   4 +-
 fs/ufs/balloc.c                                    |   6 +-
 fs/ufs/dir.c                                       |  32 +--
 fs/ufs/inode.c                                     |   4 +-
 fs/ufs/namei.c                                     |   6 +-
 fs/ufs/util.c                                      |   4 +-
 fs/ufs/util.h                                      |   2 +-
 fs/xfs/libxfs/xfs_bmap.c                           |   4 +-
 fs/xfs/xfs_aops.c                                  |  18 +-
 fs/xfs/xfs_bmap_util.c                             |   4 +-
 fs/xfs/xfs_file.c                                  |  12 +-
 fs/xfs/xfs_linux.h                                 |   2 +-
 fs/xfs/xfs_mount.c                                 |   2 +-
 fs/xfs/xfs_mount.h                                 |   4 +-
 fs/xfs/xfs_pnfs.c                                  |   4 +-
 fs/xfs/xfs_super.c                                 |   4 +-
 include/linux/bio.h                                |   2 +-
 include/linux/blkdev.h                             |   2 +-
 include/linux/buffer_head.h                        |   4 +-
 include/linux/ceph/libceph.h                       |   4 +-
 include/linux/f2fs_fs.h                            |   4 +-
 include/linux/fs.h                                 |   4 +-
 include/linux/nfs_page.h                           |   2 +-
 include/linux/pagemap.h                            |  14 +-
 include/linux/swap.h                               |   2 +-
 ipc/mqueue.c                                       |   4 +-
 kernel/events/uprobes.c                            |   8 +-
 mm/fadvise.c                                       |   8 +-
 mm/filemap.c                                       | 126 +++++-----
 mm/hugetlb.c                                       |   8 +-
 mm/madvise.c                                       |   6 +-
 mm/memory-failure.c                                |   2 +-
 mm/memory.c                                        |  54 ++---
 mm/mincore.c                                       |   4 +-
 mm/nommu.c                                         |   2 +-
 mm/page-writeback.c                                |  12 +-
 mm/page_io.c                                       |   2 +-
 mm/readahead.c                                     |  20 +-
 mm/rmap.c                                          |   2 +-
 mm/shmem.c                                         | 130 +++++-----
 mm/swap.c                                          |  12 +-
 mm/swap_state.c                                    |  12 +-
 mm/swapfile.c                                      |  12 +-
 mm/truncate.c                                      |  40 ++--
 mm/userfaultfd.c                                   |   4 +-
 mm/zswap.c                                         |   4 +-
 net/ceph/messenger.c                               |   6 +-
 net/ceph/pagelist.c                                |   4 +-
 net/ceph/pagevec.c                                 |  30 +--
 net/sunrpc/auth_gss/auth_gss.c                     |   8 +-
 net/sunrpc/auth_gss/gss_krb5_crypto.c              |   2 +-
 net/sunrpc/auth_gss/gss_krb5_wrap.c                |   4 +-
 net/sunrpc/cache.c                                 |   4 +-
 net/sunrpc/rpc_pipe.c                              |   4 +-
 net/sunrpc/socklib.c                               |   6 +-
 net/sunrpc/xdr.c                                   |  48 ++--
 381 files changed, 2722 insertions(+), 2721 deletions(-)
diff --git a/arch/arc/mm/cache.c b/arch/arc/mm/cache.c
index d7709e3..9e5eddb 100644
--- a/arch/arc/mm/cache.c
+++ b/arch/arc/mm/cache.c
@@ -628,7 +628,7 @@ void flush_dcache_page(struct page *page)
 		/* kernel reading from page with U-mapping */
 		phys_addr_t paddr = (unsigned long)page_address(page);
-		unsigned long vaddr = page->index << PAGE_CACHE_SHIFT;
+		unsigned long vaddr = page->index << PAGE_SHIFT;
 		if (addr_not_cache_congruent(paddr, vaddr))
 			__flush_dcache_page(paddr, vaddr);
diff --git a/arch/arm/mm/flush.c b/arch/arm/mm/flush.c
index d0ba3551..3cced84 100644
--- a/arch/arm/mm/flush.c
+++ b/arch/arm/mm/flush.c
@@ -235,7 +235,7 @@ void __flush_dcache_page(struct address_space *mapping, struct page *page)
 	if (mapping && cache_is_vipt_aliasing())
 		flush_pfn_alias(page_to_pfn(page),
-				page->index << PAGE_CACHE_SHIFT);
+				page->index << PAGE_SHIFT);
 static void __flush_dcache_aliases(struct address_space *mapping, struct page *page)
@@ -250,7 +250,7 @@ static void __flush_dcache_aliases(struct address_space *mapping, struct page *p
 	 *   data in the current VM view associated with this page.
 	 * - aliasing VIPT: we only need to find one mapping of this page.
-	pgoff = page->index << (PAGE_CACHE_SHIFT - PAGE_SHIFT);
+	pgoff = page->index;
 	flush_dcache_mmap_lock(mapping);
 	vma_interval_tree_foreach(mpnt, &mapping->i_mmap, pgoff, pgoff) {
diff --git a/arch/parisc/kernel/cache.c b/arch/parisc/kernel/cache.c
index 91c2a39..6700127 100644
--- a/arch/parisc/kernel/cache.c
+++ b/arch/parisc/kernel/cache.c
@@ -319,7 +319,7 @@ void flush_dcache_page(struct page *page)
 	if (!mapping)
 		return;
 	/* We have carefully arranged in arch_get_unmapped_area() that
 	 * *any* mappings of a file are always congruently mapped (whether
diff --git a/arch/powerpc/platforms/cell/spufs/inode.c b/arch/powerpc/platforms/cell/spufs/inode.c
index dfa8638..6ca5f05 100644
--- a/arch/powerpc/platforms/cell/spufs/inode.c
+++ b/arch/powerpc/platforms/cell/spufs/inode.c
@@ -732,8 +732,8 @@ spufs_fill_super(struct super_block *sb, void *data, int silent)
 		return -ENOMEM;
 	sb->s_maxbytes = MAX_LFS_FILESIZE;
-	sb->s_blocksize = PAGE_CACHE_SIZE;
-	sb->s_blocksize_bits = PAGE_CACHE_SHIFT;
+	sb->s_blocksize = PAGE_SIZE;
+	sb->s_blocksize_bits = PAGE_SHIFT;
 	sb->s_magic = SPUFS_MAGIC;
 	sb->s_op = &s_ops;
 	sb->s_fs_info = info;
diff --git a/arch/s390/hypfs/inode.c b/arch/s390/hypfs/inode.c
index 0f3da2c..255c7ee 100644
--- a/arch/s390/hypfs/inode.c
+++ b/arch/s390/hypfs/inode.c
@@ -278,8 +278,8 @@ static int hypfs_fill_super(struct super_block *sb, void *data, int silent)
 	sbi->uid = current_uid();
 	sbi->gid = current_gid();
 	sb->s_fs_info = sbi;
 	sb->s_magic = HYPFS_MAGIC;
 	sb->s_op = &hypfs_s_ops;
 	if (hypfs_parse_options(data, sb))
diff --git a/block/bio.c b/block/bio.c
index f124a0a..1685315 100644
--- a/block/bio.c
+++ b/block/bio.c
@@ -1339,7 +1339,7 @@ struct bio *bio_map_user_iov(struct request_queue *q,
 		 * release the pages we didn't map into the bio, if any
 		while (j < page_limit)
-			page_cache_release(pages[j++]);
+			put_page(pages[j++]);
 	kfree(pages);
@@ -1365,7 +1365,7 @@ struct bio *bio_map_user_iov(struct request_queue *q,
 	for (j = 0; j < nr_pages; j++) {
 		if (!pages[j])
 			break;
-		page_cache_release(pages[j]);
+		put_page(pages[j]);
  out:
 	kfree(pages);
@@ -1385,7 +1385,7 @@ static void __bio_unmap_user(struct bio *bio)
 		if (bio_data_dir(bio) == READ)
 			set_page_dirty_lock(bvec->bv_page);
-		page_cache_release(bvec->bv_page);
+		put_page(bvec->bv_page);
 	bio_put(bio);
@@ -1658,7 +1658,7 @@ void bio_check_pages_dirty(struct bio *bio)
 		struct page *page = bvec->bv_page;
 		if (PageDirty(page) || PageCompound(page)) {
-			page_cache_release(page);
+			put_page(page);
 			bvec->bv_page = NULL;
 		} else {
 			nr_clean_pages++;
diff --git a/block/blk-core.c b/block/blk-core.c
index 827f8ba..b60537b 100644
--- a/block/blk-core.c
+++ b/block/blk-core.c
@@ -706,7 +706,7 @@ struct request_queue *blk_alloc_queue_node(gfp_t gfp_mask, int node_id)
 		goto fail_id;
 	q->backing_dev_info.ra_pages =
-			(VM_MAX_READAHEAD * 1024) / PAGE_CACHE_SIZE;
+			(VM_MAX_READAHEAD * 1024) / PAGE_SIZE;
 	q->backing_dev_info.capabilities = BDI_CAP_CGROUP_WRITEBACK;
 	q->backing_dev_info.name = "block";
 	q->node = node_id;
diff --git a/block/blk-settings.c b/block/blk-settings.c
index c7bb666..331e4ee 100644
--- a/block/blk-settings.c
+++ b/block/blk-settings.c
@@ -239,8 +239,8 @@ void blk_queue_max_hw_sectors(struct request_queue *q, unsigned int max_hw_secto
 	struct queue_limits *limits = &q->limits;
 	unsigned int max_sectors;
-	if ((max_hw_sectors << 9) < PAGE_CACHE_SIZE) {
-		max_hw_sectors = 1 << (PAGE_CACHE_SHIFT - 9);
+	if ((max_hw_sectors << 9) < PAGE_SIZE) {
+		max_hw_sectors = 1 << (PAGE_SHIFT - 9);
 		printk(KERN_INFO "%s: set to minimum %d\n",
 		       __func__, max_hw_sectors);
@@ -329,8 +329,8 @@ EXPORT_SYMBOL(blk_queue_max_segments);
 void blk_queue_max_segment_size(struct request_queue *q, unsigned int max_size)
-	if (max_size < PAGE_CACHE_SIZE) {
-		max_size = PAGE_CACHE_SIZE;
+	if (max_size < PAGE_SIZE) {
+		max_size = PAGE_SIZE;
 		       __func__, max_size);
@@ -760,8 +760,8 @@ EXPORT_SYMBOL_GPL(blk_queue_dma_drain);
 void blk_queue_segment_boundary(struct request_queue *q, unsigned long mask)
-	if (mask < PAGE_CACHE_SIZE - 1) {
-		mask = PAGE_CACHE_SIZE - 1;
+	if (mask < PAGE_SIZE - 1) {
+		mask = PAGE_SIZE - 1;
 		printk(KERN_INFO "%s: set to minimum %lx\n",
 		       __func__, mask);
diff --git a/block/blk-sysfs.c b/block/blk-sysfs.c
index dd93763..995b58d 100644
--- a/block/blk-sysfs.c
+++ b/block/blk-sysfs.c
@@ -76,7 +76,7 @@ queue_requests_store(struct request_queue *q, const char *page, size_t count)
 static ssize_t queue_ra_show(struct request_queue *q, char *page)
 	unsigned long ra_kb = q->backing_dev_info.ra_pages <<
-					(PAGE_CACHE_SHIFT - 10);
+					(PAGE_SHIFT - 10);
 	return queue_var_show(ra_kb, (page));
@@ -90,7 +90,7 @@ queue_ra_store(struct request_queue *q, const char *page, size_t count)
 	if (ret < 0)
 		return ret;
-	q->backing_dev_info.ra_pages = ra_kb >> (PAGE_CACHE_SHIFT - 10);
+	q->backing_dev_info.ra_pages = ra_kb >> (PAGE_SHIFT - 10);
 	return ret;
@@ -117,7 +117,7 @@ static ssize_t queue_max_segment_size_show(struct request_queue *q, char *page)
 	if (blk_queue_cluster(q))
 		return queue_var_show(queue_max_segment_size(q), (page));
-	return queue_var_show(PAGE_CACHE_SIZE, (page));
+	return queue_var_show(PAGE_SIZE, (page));
 static ssize_t queue_logical_block_size_show(struct request_queue *q, char *page)
@@ -198,7 +198,7 @@ queue_max_sectors_store(struct request_queue *q, const char *page, size_t count)
 	unsigned long max_sectors_kb,
 		max_hw_sectors_kb = queue_max_hw_sectors(q) >> 1,
-			page_kb = 1 << (PAGE_CACHE_SHIFT - 10);
+			page_kb = 1 << (PAGE_SHIFT - 10);
 	ssize_t ret = queue_var_store(&max_sectors_kb, page, count);
 	if (ret < 0)
diff --git a/block/cfq-iosched.c b/block/cfq-iosched.c
index e3c591d..4a34978 100644
--- a/block/cfq-iosched.c
+++ b/block/cfq-iosched.c
@@ -4075,7 +4075,7 @@ cfq_rq_enqueued(struct cfq_data *cfqd, struct cfq_queue *cfqq,
 		 * idle timer unplug to continue working.
 		if (cfq_cfqq_wait_request(cfqq)) {
-			if (blk_rq_bytes(rq) > PAGE_CACHE_SIZE ||
+			if (blk_rq_bytes(rq) > PAGE_SIZE ||
 			    cfqd->busy_queues > 1) {
 				cfq_del_timer(cfqd, cfqq);
 				cfq_clear_cfqq_wait_request(cfqq);
diff --git a/block/compat_ioctl.c b/block/compat_ioctl.c
index f678c73..556826a 100644
--- a/block/compat_ioctl.c
+++ b/block/compat_ioctl.c
@@ -710,7 +710,7 @@ long compat_blkdev_ioctl(struct file *file, unsigned cmd, unsigned long arg)
 			return -EINVAL;
 		bdi = blk_get_backing_dev_info(bdev);
 		return compat_put_long(arg,
-				       (bdi->ra_pages * PAGE_CACHE_SIZE) / 512);
+				       (bdi->ra_pages * PAGE_SIZE) / 512);
 	case BLKROGET: /* compatible */
 		return compat_put_int(arg, bdev_read_only(bdev) != 0);
 	case BLKBSZGET_32: /* get the logical block size (cf. BLKSSZGET) */
@@ -729,7 +729,7 @@ long compat_blkdev_ioctl(struct file *file, unsigned cmd, unsigned long arg)
 		if (!capable(CAP_SYS_ADMIN))
 			return -EACCES;
-		bdi->ra_pages = (arg * 512) / PAGE_CACHE_SIZE;
+		bdi->ra_pages = (arg * 512) / PAGE_SIZE;
 		return 0;
 	case BLKGETSIZE:
 		size = i_size_read(bdev->bd_inode);
diff --git a/block/ioctl.c b/block/ioctl.c
index d8996bb..4ff1f92 100644
--- a/block/ioctl.c
+++ b/block/ioctl.c
@@ -550,7 +550,7 @@ int blkdev_ioctl(struct block_device *bdev, fmode_t mode, unsigned cmd,
 		if (!arg)
 			return -EINVAL;
-		return put_long(arg, (bdi->ra_pages * PAGE_CACHE_SIZE) / 512);
+		return put_long(arg, (bdi->ra_pages * PAGE_SIZE) / 512);
 	case BLKROGET:
 		return put_int(arg, bdev_read_only(bdev) != 0);
 	case BLKBSZGET: /* get block device soft block size (cf. BLKSSZGET) */
@@ -578,7 +578,7 @@ int blkdev_ioctl(struct block_device *bdev, fmode_t mode, unsigned cmd,
 		if(!capable(CAP_SYS_ADMIN))
 			return -EACCES;
 		return 0;
 	case BLKBSZSET:
 		return blkdev_bszset(bdev, mode, argp);
diff --git a/block/partition-generic.c b/block/partition-generic.c
index 5d87019..2c6ae2a 100644
--- a/block/partition-generic.c
+++ b/block/partition-generic.c
@@ -566,8 +566,8 @@ static struct page *read_pagecache_sector(struct block_device *bdev, sector_t n)
 	struct address_space *mapping = bdev->bd_inode->i_mapping;
-	return read_mapping_page(mapping, (pgoff_t)(n >> (PAGE_CACHE_SHIFT-9)),
-			NULL);
+	return read_mapping_page(mapping, (pgoff_t)(n >> (PAGE_SHIFT-9)),
+				 NULL);
 unsigned char *read_dev_sector(struct block_device *bdev, sector_t n, Sector *p)
@@ -584,9 +584,9 @@ unsigned char *read_dev_sector(struct block_device *bdev, sector_t n, Sector *p)
 		if (PageError(page))
 			goto fail;
 		p->v = page;
-		return (unsigned char *)page_address(page) +  ((n & ((1 << (PAGE_CACHE_SHIFT - 9)) - 1)) << 9);
+		return (unsigned char *)page_address(page) +  ((n & ((1 << (PAGE_SHIFT - 9)) - 1)) << 9);
 fail:
+		put_page(page);
 	p->v = NULL;
 	return NULL;
diff --git a/drivers/block/aoe/aoeblk.c b/drivers/block/aoe/aoeblk.c
index dd73e1f..ec9d861 100644
--- a/drivers/block/aoe/aoeblk.c
+++ b/drivers/block/aoe/aoeblk.c
@@ -397,7 +397,7 @@ aoeblk_gdalloc(void *vp)
 	WARN_ON(d->flags & DEVFL_UP);
 	blk_queue_max_hw_sectors(q, BLK_DEF_MAX_SECTORS);
 	q->backing_dev_info.name = "aoe";
-	q->backing_dev_info.ra_pages = READ_AHEAD / PAGE_CACHE_SIZE;
+	q->backing_dev_info.ra_pages = READ_AHEAD / PAGE_SIZE;
 	d->bufpool = mp;
 	d->blkq = gd->queue = q;
 	q->queuedata = d;
diff --git a/drivers/block/brd.c b/drivers/block/brd.c
index f7ecc28..51a071e 100644
--- a/drivers/block/brd.c
+++ b/drivers/block/brd.c
@@ -374,7 +374,7 @@ static int brd_rw_page(struct block_device *bdev, sector_t sector,
 		       struct page *page, int rw)
 	struct brd_device *brd = bdev->bd_disk->private_data;
-	int err = brd_do_bvec(brd, page, PAGE_CACHE_SIZE, 0, rw, sector);
+	int err = brd_do_bvec(brd, page, PAGE_SIZE, 0, rw, sector);
 	page_endio(page, rw & WRITE, err);
 	return err;
diff --git a/drivers/block/drbd/drbd_nl.c b/drivers/block/drbd/drbd_nl.c
index 226eb0c..1fd1dcc 100644
--- a/drivers/block/drbd/drbd_nl.c
+++ b/drivers/block/drbd/drbd_nl.c
@@ -1178,7 +1178,7 @@ static void drbd_setup_queue_param(struct drbd_device *device, struct drbd_backi
 	blk_queue_max_hw_sectors(q, max_hw_sectors);
 	/* This is the workaround for "bio would need to, but cannot, be split" */
 	blk_queue_max_segments(q, max_segments ? max_segments : BLK_MAX_SEGMENTS);
-	blk_queue_segment_boundary(q, PAGE_CACHE_SIZE-1);
+	blk_queue_segment_boundary(q, PAGE_SIZE-1);
 	if (b) {
 		struct drbd_connection *connection = first_peer_device(device)->connection;
diff --git a/drivers/gpu/drm/amd/amdgpu/amdgpu_ttm.c b/drivers/gpu/drm/amd/amdgpu/amdgpu_ttm.c
index ab34190..c018b02 100644
--- a/drivers/gpu/drm/amd/amdgpu/amdgpu_ttm.c
+++ b/drivers/gpu/drm/amd/amdgpu/amdgpu_ttm.c
@@ -616,7 +616,7 @@ static void amdgpu_ttm_tt_unpin_userptr(struct ttm_tt *ttm)
 			set_page_dirty(page);
 		mark_page_accessed(page);
+		put_page(page);
 	sg_free_table(ttm->sg);
diff --git a/drivers/gpu/drm/armada/armada_gem.c b/drivers/gpu/drm/armada/armada_gem.c
index 6e731db..aca7f9c 100644
--- a/drivers/gpu/drm/armada/armada_gem.c
+++ b/drivers/gpu/drm/armada/armada_gem.c
@@ -481,7 +481,7 @@ armada_gem_prime_map_dma_buf(struct dma_buf_attachment *attach,
  release:
 	for_each_sg(sgt->sgl, sg, num, i)
-		page_cache_release(sg_page(sg));
+		put_page(sg_page(sg));
  free_table:
 	sg_free_table(sgt);
  free_sgt:
@@ -502,7 +502,7 @@ static void armada_gem_prime_unmap_dma_buf(struct dma_buf_attachment *attach,
 	if (dobj->obj.filp) {
 		struct scatterlist *sg;
 		for_each_sg(sgt->sgl, sg, sgt->nents, i)
 	sg_free_table(sgt);
diff --git a/drivers/gpu/drm/drm_gem.c b/drivers/gpu/drm/drm_gem.c
index 2e8c77e..da0c532 100644
--- a/drivers/gpu/drm/drm_gem.c
+++ b/drivers/gpu/drm/drm_gem.c
@@ -534,7 +534,7 @@ struct page **drm_gem_get_pages(struct drm_gem_object *obj)
 fail:
 	while (i--)
-		page_cache_release(pages[i]);
+		put_page(pages[i]);
 	drm_free_large(pages);
 	return ERR_CAST(p);
@@ -569,7 +569,7 @@ void drm_gem_put_pages(struct drm_gem_object *obj, struct page **pages,
 			mark_page_accessed(pages[i]);
 		/* Undo the reference we took when populating the table */
diff --git a/drivers/gpu/drm/i915/i915_gem.c b/drivers/gpu/drm/i915/i915_gem.c
index 3d31d3a..dabc089 100644
--- a/drivers/gpu/drm/i915/i915_gem.c
+++ b/drivers/gpu/drm/i915/i915_gem.c
@@ -177,7 +177,7 @@ i915_gem_object_get_pages_phys(struct drm_i915_gem_object *obj)
 		drm_clflush_virt_range(vaddr, PAGE_SIZE);
 		kunmap_atomic(src);
+		put_page(page);
 		vaddr += PAGE_SIZE;
@@ -243,7 +243,7 @@ i915_gem_object_put_pages_phys(struct drm_i915_gem_object *obj)
 			if (obj->madv == I915_MADV_WILLNEED)
+			put_page(page);
 			vaddr += PAGE_SIZE;
 		obj->dirty = 0;
@@ -2206,7 +2206,7 @@ i915_gem_object_put_pages_gtt(struct drm_i915_gem_object *obj)
+		put_page(page);
 	obj->dirty = 0;
@@ -2346,7 +2346,7 @@ i915_gem_object_get_pages_gtt(struct drm_i915_gem_object *obj)
 err_pages:
 	sg_mark_end(sg);
 	for_each_sg_page(st->sgl, &sg_iter, st->nents, 0)
-		page_cache_release(sg_page_iter_page(&sg_iter));
+		put_page(sg_page_iter_page(&sg_iter));
 	sg_free_table(st);
 	kfree(st);
diff --git a/drivers/gpu/drm/i915/i915_gem_userptr.c b/drivers/gpu/drm/i915/i915_gem_userptr.c
index 6be40f3..18ba813 100644
--- a/drivers/gpu/drm/i915/i915_gem_userptr.c
+++ b/drivers/gpu/drm/i915/i915_gem_userptr.c
@@ -683,7 +683,7 @@ i915_gem_userptr_put_pages(struct drm_i915_gem_object *obj)
+		put_page(page);
 	obj->dirty = 0;
diff --git a/drivers/gpu/drm/radeon/radeon_ttm.c b/drivers/gpu/drm/radeon/radeon_ttm.c
index 6d8c323..0deb7f0 100644
--- a/drivers/gpu/drm/radeon/radeon_ttm.c
+++ b/drivers/gpu/drm/radeon/radeon_ttm.c
@@ -609,7 +609,7 @@ static void radeon_ttm_tt_unpin_userptr(struct ttm_tt *ttm)
+		put_page(page);
diff --git a/drivers/gpu/drm/ttm/ttm_tt.c b/drivers/gpu/drm/ttm/ttm_tt.c
index 4e19d0f..077ae9b 100644
--- a/drivers/gpu/drm/ttm/ttm_tt.c
+++ b/drivers/gpu/drm/ttm/ttm_tt.c
@@ -311,7 +311,7 @@ int ttm_tt_swapin(struct ttm_tt *ttm)
 			goto out_err;
 		copy_highpage(to_page, from_page);
-		page_cache_release(from_page);
+		put_page(from_page);
 	if (!(ttm->page_flags & TTM_PAGE_FLAG_PERSISTENT_SWAP))
@@ -361,7 +361,7 @@ int ttm_tt_swapout(struct ttm_tt *ttm, struct file *persistent_swap_storage)
 		set_page_dirty(to_page);
 		mark_page_accessed(to_page);
-		page_cache_release(to_page);
+		put_page(to_page);
 	ttm_tt_unpopulate(ttm);
diff --git a/drivers/gpu/drm/via/via_dmablit.c b/drivers/gpu/drm/via/via_dmablit.c
index e797dfc..7e2a12c 100644
--- a/drivers/gpu/drm/via/via_dmablit.c
+++ b/drivers/gpu/drm/via/via_dmablit.c
@@ -188,7 +188,7 @@ via_free_sg_info(struct pci_dev *pdev, drm_via_sg_info_t *vsg)
 			if (NULL != (page = vsg->pages[i])) {
 				if (!PageReserved(page) && (DMA_FROM_DEVICE == vsg->direction))
 					SetPageDirty(page);
+				put_page(page);
 	case dr_via_pages_alloc:
diff --git a/drivers/md/bitmap.c b/drivers/md/bitmap.c
index 7df6b4f..bef7175 100644
--- a/drivers/md/bitmap.c
+++ b/drivers/md/bitmap.c
@@ -322,7 +322,7 @@ __clear_page_buffers(struct page *page)
 	ClearPagePrivate(page);
 	set_page_private(page, 0);
+	put_page(page);
 static void free_buffers(struct page *page)
diff --git a/drivers/media/v4l2-core/videobuf-dma-sg.c b/drivers/media/v4l2-core/videobuf-dma-sg.c
index df4c052c..f300f06 100644
--- a/drivers/media/v4l2-core/videobuf-dma-sg.c
+++ b/drivers/media/v4l2-core/videobuf-dma-sg.c
@@ -349,7 +349,7 @@ int videobuf_dma_free(struct videobuf_dmabuf *dma)
 	if (dma->pages) {
 		for (i = 0; i < dma->nr_pages; i++)
-			page_cache_release(dma->pages[i]);
+			put_page(dma->pages[i]);
 		kfree(dma->pages);
 		dma->pages = NULL;
diff --git a/drivers/misc/ibmasm/ibmasmfs.c b/drivers/misc/ibmasm/ibmasmfs.c
index e8b9331..9c677f3 100644
--- a/drivers/misc/ibmasm/ibmasmfs.c
+++ b/drivers/misc/ibmasm/ibmasmfs.c
@@ -116,8 +116,8 @@ static int ibmasmfs_fill_super (struct super_block *sb, void *data, int silent)
 	struct inode *root;
 	sb->s_magic = IBMASMFS_MAGIC;
 	sb->s_op = &ibmasmfs_s_ops;
 	sb->s_time_gran = 1;
diff --git a/drivers/misc/vmw_vmci/vmci_queue_pair.c b/drivers/misc/vmw_vmci/vmci_queue_pair.c
index f42d9c4..f84a427 100644
--- a/drivers/misc/vmw_vmci/vmci_queue_pair.c
+++ b/drivers/misc/vmw_vmci/vmci_queue_pair.c
@@ -728,7 +728,7 @@ static void qp_release_pages(struct page **pages,
 		if (dirty)
 			set_page_dirty(pages[i]);
 		pages[i] = NULL;
diff --git a/drivers/mmc/core/host.c b/drivers/mmc/core/host.c
index 1d94607..6e4c55a 100644
--- a/drivers/mmc/core/host.c
+++ b/drivers/mmc/core/host.c
@@ -356,11 +356,11 @@ struct mmc_host *mmc_alloc_host(int extra, struct device *dev)
 	 * They have to set these according to their abilities.
 	host->max_segs = 1;
-	host->max_seg_size = PAGE_CACHE_SIZE;
+	host->max_seg_size = PAGE_SIZE;
-	host->max_req_size = PAGE_CACHE_SIZE;
+	host->max_req_size = PAGE_SIZE;
 	host->max_blk_size = 512;
-	host->max_blk_count = PAGE_CACHE_SIZE / 512;
+	host->max_blk_count = PAGE_SIZE / 512;
 	return host;
diff --git a/drivers/mmc/host/sh_mmcif.c b/drivers/mmc/host/sh_mmcif.c
index 8d870ce..d9a655f 100644
--- a/drivers/mmc/host/sh_mmcif.c
+++ b/drivers/mmc/host/sh_mmcif.c
@@ -1513,7 +1513,7 @@ static int sh_mmcif_probe(struct platform_device *pdev)
 		mmc->caps |= pd->caps;
 	mmc->max_segs = 32;
 	mmc->max_blk_size = 512;
-	mmc->max_req_size = PAGE_CACHE_SIZE * mmc->max_segs;
+	mmc->max_req_size = PAGE_SIZE * mmc->max_segs;
 	mmc->max_blk_count = mmc->max_req_size / mmc->max_blk_size;
 	mmc->max_seg_size = mmc->max_req_size;
diff --git a/drivers/mmc/host/tmio_mmc_dma.c b/drivers/mmc/host/tmio_mmc_dma.c
index 6754358..7fb0c03 100644
--- a/drivers/mmc/host/tmio_mmc_dma.c
+++ b/drivers/mmc/host/tmio_mmc_dma.c
@@ -63,7 +63,7 @@ static void tmio_mmc_start_dma_rx(struct tmio_mmc_host *host)
-	if ((!aligned && (host->sg_len > 1 || sg->length > PAGE_CACHE_SIZE ||
+	if ((!aligned && (host->sg_len > 1 || sg->length > PAGE_SIZE ||
 			  (align & PAGE_MASK))) || !multiple) {
 		ret = -EINVAL;
 		goto pio;
@@ -133,7 +133,7 @@ static void tmio_mmc_start_dma_tx(struct tmio_mmc_host *host)
 		ret = -EINVAL;
 		goto pio;
diff --git a/drivers/mmc/host/tmio_mmc_pio.c b/drivers/mmc/host/tmio_mmc_pio.c
index 03f6e74..0521b46 100644
--- a/drivers/mmc/host/tmio_mmc_pio.c
+++ b/drivers/mmc/host/tmio_mmc_pio.c
@@ -1125,7 +1125,7 @@ int tmio_mmc_host_probe(struct tmio_mmc_host *_host,
 	mmc->caps2 |= pdata->capabilities2;
 	mmc->max_segs = 32;
-	mmc->max_blk_count = (PAGE_CACHE_SIZE / mmc->max_blk_size) *
+	mmc->max_blk_count = (PAGE_SIZE / mmc->max_blk_size) *
 		mmc->max_segs;
 	mmc->max_req_size = mmc->max_blk_size * mmc->max_blk_count;
diff --git a/drivers/mmc/host/usdhi6rol0.c b/drivers/mmc/host/usdhi6rol0.c
index b2752fe..807c06e 100644
--- a/drivers/mmc/host/usdhi6rol0.c
+++ b/drivers/mmc/host/usdhi6rol0.c
@@ -1789,7 +1789,7 @@ static int usdhi6_probe(struct platform_device *pdev)
 	/* Set .max_segs to some random number. Feel free to adjust. */
 	mmc->max_segs = 32;
 	 * Setting .max_seg_size to 1 page would simplify our page-mapping code,
diff --git a/drivers/mtd/devices/block2mtd.c b/drivers/mtd/devices/block2mtd.c
index e2c0057..7c887f1 100644
--- a/drivers/mtd/devices/block2mtd.c
+++ b/drivers/mtd/devices/block2mtd.c
@@ -75,7 +75,7 @@ static int _block2mtd_erase(struct block2mtd_dev *dev, loff_t to, size_t len)
 				break;
+		put_page(page);
 		pages--;
 		index++;
@@ -124,7 +124,7 @@ static int block2mtd_read(struct mtd_info *mtd, loff_t from, size_t len,
 			return PTR_ERR(page);
 		memcpy(buf, page_address(page) + offset, cpylen);
+		put_page(page);
 		if (retlen)
 			*retlen += cpylen;
@@ -164,7 +164,7 @@ static int _block2mtd_write(struct block2mtd_dev *dev, const u_char *buf,
 			unlock_page(page);
 			balance_dirty_pages_ratelimited(mapping);
+		put_page(page);
 		if (retlen)
 			*retlen += cpylen;
diff --git a/drivers/mtd/nand/nandsim.c b/drivers/mtd/nand/nandsim.c
index 1fd5195..a58169a2 100644
--- a/drivers/mtd/nand/nandsim.c
+++ b/drivers/mtd/nand/nandsim.c
@@ -1339,7 +1339,7 @@ static void put_pages(struct nandsim *ns)
 	int i;
 	for (i = 0; i < ns->held_cnt; i++)
-		page_cache_release(ns->held_pages[i]);
+		put_page(ns->held_pages[i]);
 /* Get page cache pages in advance to provide NOFS memory allocation */
@@ -1349,8 +1349,8 @@ static int get_pages(struct nandsim *ns, struct file *file, size_t count, loff_t
 	struct page *page;
 	struct address_space *mapping = file->f_mapping;
-	start_index = pos >> PAGE_CACHE_SHIFT;
-	end_index = (pos + count - 1) >> PAGE_CACHE_SHIFT;
+	start_index = pos >> PAGE_SHIFT;
+	end_index = (pos + count - 1) >> PAGE_SHIFT;
 	if (end_index - start_index + 1 > NS_MAX_HELD_PAGES)
 		return -EINVAL;
 	ns->held_cnt = 0;
diff --git a/drivers/nvdimm/btt.c b/drivers/nvdimm/btt.c
index c32cbb5..f068b65 100644
--- a/drivers/nvdimm/btt.c
+++ b/drivers/nvdimm/btt.c
@@ -1204,7 +1204,7 @@ static int btt_rw_page(struct block_device *bdev, sector_t sector,
 	struct btt *btt = bdev->bd_disk->private_data;
-	btt_do_bvec(btt, NULL, page, PAGE_CACHE_SIZE, 0, rw, sector);
+	btt_do_bvec(btt, NULL, page, PAGE_SIZE, 0, rw, sector);
 	page_endio(page, rw & WRITE, 0);
 	return 0;
diff --git a/drivers/nvdimm/pmem.c b/drivers/nvdimm/pmem.c
index cc31c6f..12c86fa 100644
--- a/drivers/nvdimm/pmem.c
+++ b/drivers/nvdimm/pmem.c
@@ -151,7 +151,7 @@ static int pmem_rw_page(struct block_device *bdev, sector_t sector,
 	struct pmem_device *pmem = bdev->bd_disk->private_data;
 	int rc;
-	rc = pmem_do_bvec(pmem, page, PAGE_CACHE_SIZE, 0, rw, sector);
+	rc = pmem_do_bvec(pmem, page, PAGE_SIZE, 0, rw, sector);
 	if (rw & WRITE)
 		wmb_pmem();
diff --git a/drivers/oprofile/oprofilefs.c b/drivers/oprofile/oprofilefs.c
index b48ac630..a0e5260 100644
--- a/drivers/oprofile/oprofilefs.c
+++ b/drivers/oprofile/oprofilefs.c
@@ -239,8 +239,8 @@ static int oprofilefs_fill_super(struct super_block *sb, void *data, int silent)
 	struct inode *root_inode;
 	sb->s_magic = OPROFILEFS_MAGIC;
 	sb->s_op = &s_ops;
diff --git a/drivers/scsi/sd.c b/drivers/scsi/sd.c
index 5a5457a..1bd0753 100644
--- a/drivers/scsi/sd.c
+++ b/drivers/scsi/sd.c
@@ -2891,7 +2891,7 @@ static int sd_revalidate_disk(struct gendisk *disk)
 	if (sdkp->opt_xfer_blocks &&
 	    sdkp->opt_xfer_blocks <= dev_max &&
 	    sdkp->opt_xfer_blocks <= SD_DEF_XFER_BLOCKS &&
-	    sdkp->opt_xfer_blocks * sdp->sector_size >= PAGE_CACHE_SIZE)
+	    sdkp->opt_xfer_blocks * sdp->sector_size >= PAGE_SIZE)
 		rw_max = q->limits.io_opt =
 			sdkp->opt_xfer_blocks * sdp->sector_size;
 	else
diff --git a/drivers/scsi/st.c b/drivers/scsi/st.c
index 71c5138..dbf1882c 100644
--- a/drivers/scsi/st.c
+++ b/drivers/scsi/st.c
@@ -4941,7 +4941,7 @@ static int sgl_map_user_pages(struct st_buffer *STbp,
  out_unmap:
 	if (res > 0) {
 		for (j=0; j < res; j++)
 		res = 0;
 	kfree(pages);
@@ -4963,7 +4963,7 @@ static int sgl_unmap_user_pages(struct st_buffer *STbp,
 		/* FIXME: cache flush missing for rw==READ
 		 * FIXME: call the correct reference counting function
+		put_page(page);
 	kfree(STbp->mapped_pages);
 	STbp->mapped_pages = NULL;
diff --git a/drivers/staging/lustre/include/linux/libcfs/libcfs_private.h b/drivers/staging/lustre/include/linux/libcfs/libcfs_private.h
index dab4862..1333543 100644
--- a/drivers/staging/lustre/include/linux/libcfs/libcfs_private.h
+++ b/drivers/staging/lustre/include/linux/libcfs/libcfs_private.h
@@ -88,7 +88,7 @@ do {								    \
 } while (0)
 #ifndef LIBCFS_VMALLOC_SIZE
-#define LIBCFS_VMALLOC_SIZE	(2 << PAGE_CACHE_SHIFT) /* 2 pages */
+#define LIBCFS_VMALLOC_SIZE	(2 << PAGE_SHIFT) /* 2 pages */
 #endif
 #define LIBCFS_ALLOC_PRE(size, mask)					    \
diff --git a/drivers/staging/lustre/include/linux/libcfs/linux/linux-mem.h b/drivers/staging/lustre/include/linux/libcfs/linux/linux-mem.h
index 0f2fd79..837eb22 100644
--- a/drivers/staging/lustre/include/linux/libcfs/linux/linux-mem.h
+++ b/drivers/staging/lustre/include/linux/libcfs/linux/linux-mem.h
@@ -57,7 +57,7 @@
 #include "../libcfs_cpu.h"
 #endif
-#define CFS_PAGE_MASK		   (~((__u64)PAGE_CACHE_SIZE-1))
+#define CFS_PAGE_MASK		   (~((__u64)PAGE_SIZE-1))
 #define page_index(p)       ((p)->index)
 #define memory_pressure_get() (current->flags & PF_MEMALLOC)
@@ -67,7 +67,7 @@
 #if BITS_PER_LONG == 32
 /* limit to lowmem on 32-bit systems */
 #define NUM_CACHEPAGES \
-	min(totalram_pages, 1UL << (30 - PAGE_CACHE_SHIFT) * 3 / 4)
+	min(totalram_pages, 1UL << (30 - PAGE_SHIFT) * 3 / 4)
 #else
 #define NUM_CACHEPAGES totalram_pages
 #endif
diff --git a/drivers/staging/lustre/lnet/klnds/socklnd/socklnd_lib.c b/drivers/staging/lustre/lnet/klnds/socklnd/socklnd_lib.c
index 3e1f24e..d4ce06d 100644
--- a/drivers/staging/lustre/lnet/klnds/socklnd/socklnd_lib.c
+++ b/drivers/staging/lustre/lnet/klnds/socklnd/socklnd_lib.c
@@ -291,7 +291,7 @@ ksocknal_lib_kiov_vmap(lnet_kiov_t *kiov, int niov,
 	for (nob = i = 0; i < niov; i++) {
 		if ((kiov[i].kiov_offset && i > 0) ||
-		    (kiov[i].kiov_offset + kiov[i].kiov_len != PAGE_CACHE_SIZE && i < niov - 1))
+		    (kiov[i].kiov_offset + kiov[i].kiov_len != PAGE_SIZE && i < niov - 1))
 			return NULL;
 		pages[i] = kiov[i].kiov_page;
diff --git a/drivers/staging/lustre/lnet/libcfs/debug.c b/drivers/staging/lustre/lnet/libcfs/debug.c
index c90e510..c3d628b 100644
--- a/drivers/staging/lustre/lnet/libcfs/debug.c
+++ b/drivers/staging/lustre/lnet/libcfs/debug.c
@@ -517,7 +517,7 @@ int libcfs_debug_init(unsigned long bufsize)
 		max = TCD_MAX_PAGES;
 	} else {
 		max = max / num_possible_cpus();
-		max <<= (20 - PAGE_CACHE_SHIFT);
+		max <<= (20 - PAGE_SHIFT);
 	rc = cfs_tracefile_init(max);
diff --git a/drivers/staging/lustre/lnet/libcfs/tracefile.c b/drivers/staging/lustre/lnet/libcfs/tracefile.c
index ec3bc04..244eb89 100644
--- a/drivers/staging/lustre/lnet/libcfs/tracefile.c
+++ b/drivers/staging/lustre/lnet/libcfs/tracefile.c
@@ -182,7 +182,7 @@ cfs_trace_get_tage_try(struct cfs_trace_cpu_data *tcd, unsigned long len)
 	if (tcd->tcd_cur_pages > 0) {
 		__LASSERT(!list_empty(&tcd->tcd_pages));
 		tage = cfs_tage_from_list(tcd->tcd_pages.prev);
-		if (tage->used + len <= PAGE_CACHE_SIZE)
+		if (tage->used + len <= PAGE_SIZE)
 			return tage;
@@ -260,7 +260,7 @@ static struct cfs_trace_page *cfs_trace_get_tage(struct cfs_trace_cpu_data *tcd,
 	 * from here: this will lead to infinite recursion.
-	if (len > PAGE_CACHE_SIZE) {
+	if (len > PAGE_SIZE) {
 		pr_err("cowardly refusing to write %lu bytes in a page\n", len);
 		return NULL;
@@ -349,7 +349,7 @@ int libcfs_debug_vmsg2(struct libcfs_debug_msg_data *msgdata,
 	for (i = 0; i < 2; i++) {
 		tage = cfs_trace_get_tage(tcd, needed + known_size + 1);
 		if (!tage) {
-			if (needed + known_size > PAGE_CACHE_SIZE)
+			if (needed + known_size > PAGE_SIZE)
 				mask |= D_ERROR;
 			cfs_trace_put_tcd(tcd);
@@ -360,7 +360,7 @@ int libcfs_debug_vmsg2(struct libcfs_debug_msg_data *msgdata,
 		string_buf = (char *)page_address(tage->page) +
 					tage->used + known_size;
-		max_nob = PAGE_CACHE_SIZE - tage->used - known_size;
+		max_nob = PAGE_SIZE - tage->used - known_size;
 		if (max_nob <= 0) {
 			printk(KERN_EMERG "negative max_nob: %d\n",
 			       max_nob);
@@ -424,7 +424,7 @@ int libcfs_debug_vmsg2(struct libcfs_debug_msg_data *msgdata,
 	__LASSERT(debug_buf == string_buf);
 	tage->used += needed;
-	__LASSERT(tage->used <= PAGE_CACHE_SIZE);
+	__LASSERT(tage->used <= PAGE_SIZE);
 console:
 	if ((mask & libcfs_printk) == 0) {
@@ -835,7 +835,7 @@ EXPORT_SYMBOL(cfs_trace_copyout_string);
 int cfs_trace_allocate_string_buffer(char **str, int nob)
-	if (nob > 2 * PAGE_CACHE_SIZE)	    /* string must be "sensible" */
+	if (nob > 2 * PAGE_SIZE)	    /* string must be "sensible" */
 		return -EINVAL;
 	*str = kmalloc(nob, GFP_KERNEL | __GFP_ZERO);
@@ -951,7 +951,7 @@ int cfs_trace_set_debug_mb(int mb)
 	mb /= num_possible_cpus();
-	pages = mb << (20 - PAGE_CACHE_SHIFT);
+	pages = mb << (20 - PAGE_SHIFT);
 	cfs_tracefile_write_lock();
@@ -977,7 +977,7 @@ int cfs_trace_get_debug_mb(void)
 	cfs_tracefile_read_unlock();
-	return (total_pages >> (20 - PAGE_CACHE_SHIFT)) + 1;
+	return (total_pages >> (20 - PAGE_SHIFT)) + 1;
 static int tracefiled(void *arg)
diff --git a/drivers/staging/lustre/lnet/libcfs/tracefile.h b/drivers/staging/lustre/lnet/libcfs/tracefile.h
index 4c77f90..ac84e7f 100644
--- a/drivers/staging/lustre/lnet/libcfs/tracefile.h
+++ b/drivers/staging/lustre/lnet/libcfs/tracefile.h
@@ -87,7 +87,7 @@ void libcfs_unregister_panic_notifier(void);
 extern int  libcfs_panic_in_progress;
 int cfs_trace_max_debug_mb(void);
-#define TCD_MAX_PAGES (5 << (20 - PAGE_CACHE_SHIFT))
+#define TCD_MAX_PAGES (5 << (20 - PAGE_SHIFT))
 #define TCD_STOCK_PAGES (TCD_MAX_PAGES)
 #define CFS_TRACEFILE_SIZE (500 << 20)
@@ -96,7 +96,7 @@ int cfs_trace_max_debug_mb(void);
  * Private declare for tracefile
@@ -257,7 +257,7 @@ do {								    \
 do {								    \
 	__LASSERT(tage);					\
 	__LASSERT(tage->page);				  \
-	__LASSERT(tage->used <= PAGE_CACHE_SIZE);			 \
+	__LASSERT(tage->used <= PAGE_SIZE);			 \
 	__LASSERT(page_count(tage->page) > 0);		      \
 } while (0)
diff --git a/drivers/staging/lustre/lnet/lnet/lib-md.c b/drivers/staging/lustre/lnet/lnet/lib-md.c
index c74514f..75d3121 100644
--- a/drivers/staging/lustre/lnet/lnet/lib-md.c
+++ b/drivers/staging/lustre/lnet/lnet/lib-md.c
@@ -139,7 +139,7 @@ lnet_md_build(lnet_libmd_t *lmd, lnet_md_t *umd, int unlink)
 		for (i = 0; i < (int)niov; i++) {
 			/* We take the page pointer on trust */
 			if (lmd->md_iov.kiov[i].kiov_offset +
-			    lmd->md_iov.kiov[i].kiov_len > PAGE_CACHE_SIZE)
+			    lmd->md_iov.kiov[i].kiov_len > PAGE_SIZE)
 				return -EINVAL; /* invalid length */
 			total_length += lmd->md_iov.kiov[i].kiov_len;
diff --git a/drivers/staging/lustre/lnet/lnet/lib-move.c b/drivers/staging/lustre/lnet/lnet/lib-move.c
index 0009a8d..f19aa93 100644
--- a/drivers/staging/lustre/lnet/lnet/lib-move.c
+++ b/drivers/staging/lustre/lnet/lnet/lib-move.c
@@ -549,12 +549,12 @@ lnet_extract_kiov(int dst_niov, lnet_kiov_t *dst,
 		if (len <= frag_len) {
 			dst->kiov_len = len;
 			LASSERT(dst->kiov_offset + dst->kiov_len
-					<= PAGE_CACHE_SIZE);
+					<= PAGE_SIZE);
 			return niov;
 		dst->kiov_len = frag_len;
-		LASSERT(dst->kiov_offset + dst->kiov_len <= PAGE_CACHE_SIZE);
+		LASSERT(dst->kiov_offset + dst->kiov_len <= PAGE_SIZE);
 		len -= frag_len;
 		dst++;
@@ -887,7 +887,7 @@ lnet_msg2bufpool(lnet_msg_t *msg)
 	rbp = &the_lnet.ln_rtrpools[cpt][0];
 	LASSERT(msg->msg_len <= LNET_MTU);
-	while (msg->msg_len > (unsigned int)rbp->rbp_npages * PAGE_CACHE_SIZE) {
+	while (msg->msg_len > (unsigned int)rbp->rbp_npages * PAGE_SIZE) {
 		rbp++;
 		LASSERT(rbp < &the_lnet.ln_rtrpools[cpt][LNET_NRBPOOLS]);
diff --git a/drivers/staging/lustre/lnet/lnet/lib-socket.c b/drivers/staging/lustre/lnet/lnet/lib-socket.c
index cc0c275..891fd59 100644
--- a/drivers/staging/lustre/lnet/lnet/lib-socket.c
+++ b/drivers/staging/lustre/lnet/lnet/lib-socket.c
@@ -166,9 +166,9 @@ lnet_ipif_enumerate(char ***namesp)
 	nalloc = 16;	/* first guess at max interfaces */
 	toobig = 0;
 	for (;;) {
-		if (nalloc * sizeof(*ifr) > PAGE_CACHE_SIZE) {
+		if (nalloc * sizeof(*ifr) > PAGE_SIZE) {
 			toobig = 1;
-			nalloc = PAGE_CACHE_SIZE / sizeof(*ifr);
+			nalloc = PAGE_SIZE / sizeof(*ifr);
 			CWARN("Too many interfaces: only enumerating first %d\n",
 			      nalloc);
diff --git a/drivers/staging/lustre/lnet/lnet/router.c b/drivers/staging/lustre/lnet/lnet/router.c
index 61459cf..b01dc42 100644
--- a/drivers/staging/lustre/lnet/lnet/router.c
+++ b/drivers/staging/lustre/lnet/lnet/router.c
@@ -27,8 +27,8 @@
 #define LNET_NRB_SMALL_PAGES	1
 #define LNET_NRB_LARGE_MIN	256	/* min value for each CPT */
 #define LNET_NRB_LARGE		(LNET_NRB_LARGE_MIN * 4)
-#define LNET_NRB_LARGE_PAGES   ((LNET_MTU + PAGE_CACHE_SIZE - 1) >> \
-				 PAGE_CACHE_SHIFT)
+#define LNET_NRB_LARGE_PAGES   ((LNET_MTU + PAGE_SIZE - 1) >> \
+				 PAGE_SHIFT)
 static char *forwarding = "";
 module_param(forwarding, charp, 0444);
@@ -1338,7 +1338,7 @@ lnet_new_rtrbuf(lnet_rtrbufpool_t *rbp, int cpt)
 			return NULL;
-		rb->rb_kiov[i].kiov_len = PAGE_CACHE_SIZE;
+		rb->rb_kiov[i].kiov_len = PAGE_SIZE;
 		rb->rb_kiov[i].kiov_offset = 0;
 		rb->rb_kiov[i].kiov_page = page;
diff --git a/drivers/staging/lustre/lnet/selftest/brw_test.c b/drivers/staging/lustre/lnet/selftest/brw_test.c
index eebc924..dcb6e50 100644
--- a/drivers/staging/lustre/lnet/selftest/brw_test.c
+++ b/drivers/staging/lustre/lnet/selftest/brw_test.c
@@ -90,7 +90,7 @@ brw_client_init(sfw_test_instance_t *tsi)
 		 * NB: this is not going to work for variable page size,
 		 * but we have to keep it for compatibility
-		len = npg * PAGE_CACHE_SIZE;
+		len = npg * PAGE_SIZE;
 	} else {
 		test_bulk_req_v1_t *breq = &tsi->tsi_u.bulk_v1;
@@ -104,7 +104,7 @@ brw_client_init(sfw_test_instance_t *tsi)
 		opc = breq->blk_opc;
 		flags = breq->blk_flags;
 		len = breq->blk_len;
-		npg = (len + PAGE_CACHE_SIZE - 1) >> PAGE_CACHE_SHIFT;
+		npg = (len + PAGE_SIZE - 1) >> PAGE_SHIFT;
 	if (npg > LNET_MAX_IOV || npg <= 0)
@@ -167,13 +167,13 @@ brw_fill_page(struct page *pg, int pattern, __u64 magic)
 	if (pattern == LST_BRW_CHECK_SIMPLE) {
 		memcpy(addr, &magic, BRW_MSIZE);
-		addr += PAGE_CACHE_SIZE - BRW_MSIZE;
+		addr += PAGE_SIZE - BRW_MSIZE;
 		return;
 	if (pattern == LST_BRW_CHECK_FULL) {
-		for (i = 0; i < PAGE_CACHE_SIZE / BRW_MSIZE; i++)
+		for (i = 0; i < PAGE_SIZE / BRW_MSIZE; i++)
 			memcpy(addr + i * BRW_MSIZE, &magic, BRW_MSIZE);
 		return;
@@ -198,7 +198,7 @@ brw_check_page(struct page *pg, int pattern, __u64 magic)
 		if (data != magic)
 			goto bad_data;
 		data = *((__u64 *)addr);
 		if (data != magic)
 			goto bad_data;
@@ -207,7 +207,7 @@ brw_check_page(struct page *pg, int pattern, __u64 magic)
-		for (i = 0; i < PAGE_CACHE_SIZE / BRW_MSIZE; i++) {
+		for (i = 0; i < PAGE_SIZE / BRW_MSIZE; i++) {
 			data = *(((__u64 *)addr) + i);
 			if (data != magic)
 				goto bad_data;
@@ -278,7 +278,7 @@ brw_client_prep_rpc(sfw_test_unit_t *tsu,
 		npg = breq->blk_npg;
 	} else {
@@ -292,7 +292,7 @@ brw_client_prep_rpc(sfw_test_unit_t *tsu,
 	rc = sfw_create_test_rpc(tsu, dest, sn->sn_features, npg, len, &rpc);
@@ -463,10 +463,10 @@ brw_server_handle(struct srpc_server_rpc *rpc)
 			reply->brw_status = EINVAL;
 			return 0;
-		npg = reqst->brw_len >> PAGE_CACHE_SHIFT;
+		npg = reqst->brw_len >> PAGE_SHIFT;
 	} else {
-		npg = (reqst->brw_len + PAGE_CACHE_SIZE - 1) >> PAGE_CACHE_SHIFT;
+		npg = (reqst->brw_len + PAGE_SIZE - 1) >> PAGE_SHIFT;
 	replymsg->msg_ses_feats = reqstmsg->msg_ses_feats;
diff --git a/drivers/staging/lustre/lnet/selftest/conctl.c b/drivers/staging/lustre/lnet/selftest/conctl.c
index 5c7cb72..79ee6c0 100644
--- a/drivers/staging/lustre/lnet/selftest/conctl.c
+++ b/drivers/staging/lustre/lnet/selftest/conctl.c
@@ -743,7 +743,7 @@ static int lst_test_add_ioctl(lstio_test_args_t *args)
 	if (args->lstio_tes_param &&
 	    (args->lstio_tes_param_len <= 0 ||
 	     args->lstio_tes_param_len >
-	     PAGE_CACHE_SIZE - sizeof(lstcon_test_t)))
+	     PAGE_SIZE - sizeof(lstcon_test_t)))
 		return -EINVAL;
 	LIBCFS_ALLOC(batch_name, args->lstio_tes_bat_nmlen + 1);
@@ -819,7 +819,7 @@ lstcon_ioctl_entry(unsigned int cmd, struct libcfs_ioctl_hdr *hdr)
 	opc = data->ioc_u32[0];
-	if (data->ioc_plen1 > PAGE_CACHE_SIZE)
+	if (data->ioc_plen1 > PAGE_SIZE)
 		return -EINVAL;
 	LIBCFS_ALLOC(buf, data->ioc_plen1);
diff --git a/drivers/staging/lustre/lnet/selftest/conrpc.c b/drivers/staging/lustre/lnet/selftest/conrpc.c
index bcd7888..35a227d 100644
--- a/drivers/staging/lustre/lnet/selftest/conrpc.c
+++ b/drivers/staging/lustre/lnet/selftest/conrpc.c
@@ -786,8 +786,8 @@ lstcon_bulkrpc_v0_prep(lst_test_bulk_param_t *param, srpc_test_reqst_t *req)
 	test_bulk_req_t *brq = &req->tsr_u.bulk_v0;
 	brq->blk_opc = param->blk_opc;
-	brq->blk_npg = (param->blk_size + PAGE_CACHE_SIZE - 1) /
-			PAGE_CACHE_SIZE;
+	brq->blk_npg = (param->blk_size + PAGE_SIZE - 1) /
+			PAGE_SIZE;
 	brq->blk_flags = param->blk_flags;
 	return 0;
@@ -822,7 +822,7 @@ lstcon_testrpc_prep(lstcon_node_t *nd, int transop, unsigned feats,
 	if (transop == LST_TRANS_TSBCLIADD) {
 		npg = sfw_id_pages(test->tes_span);
 		nob = !(feats & LST_FEAT_BULK_LEN) ?
-		      npg * PAGE_CACHE_SIZE :
+		      npg * PAGE_SIZE :
 		      sizeof(lnet_process_id_packed_t) * test->tes_span;
@@ -851,8 +851,8 @@ lstcon_testrpc_prep(lstcon_node_t *nd, int transop, unsigned feats,
 			LASSERT(nob > 0);
 			len = !(feats & LST_FEAT_BULK_LEN) ?
-			      PAGE_CACHE_SIZE :
-			      min_t(int, nob, PAGE_CACHE_SIZE);
+			      PAGE_SIZE :
+			      min_t(int, nob, PAGE_SIZE);
 			nob -= len;
 			bulk->bk_iovs[i].kiov_offset = 0;
diff --git a/drivers/staging/lustre/lnet/selftest/framework.c b/drivers/staging/lustre/lnet/selftest/framework.c
index 926c397..e2c5323 100644
--- a/drivers/staging/lustre/lnet/selftest/framework.c
+++ b/drivers/staging/lustre/lnet/selftest/framework.c
@@ -1161,7 +1161,7 @@ sfw_add_test(struct srpc_server_rpc *rpc)
 		int len;
 		if (!(sn->sn_features & LST_FEAT_BULK_LEN)) {
 		} else {
 			len = sizeof(lnet_process_id_packed_t) *
diff --git a/drivers/staging/lustre/lnet/selftest/rpc.c b/drivers/staging/lustre/lnet/selftest/rpc.c
index 69be7d6..7d7748d 100644
--- a/drivers/staging/lustre/lnet/selftest/rpc.c
+++ b/drivers/staging/lustre/lnet/selftest/rpc.c
@@ -90,7 +90,7 @@ void srpc_set_counters(const srpc_counters_t *cnt)
 static int
 srpc_add_bulk_page(srpc_bulk_t *bk, struct page *pg, int i, int nob)
-	nob = min_t(int, nob, PAGE_CACHE_SIZE);
+	nob = min_t(int, nob, PAGE_SIZE);
 	LASSERT(nob > 0);
 	LASSERT(i >= 0 && i < bk->bk_niov);
diff --git a/drivers/staging/lustre/lnet/selftest/selftest.h b/drivers/staging/lustre/lnet/selftest/selftest.h
index 288522d..5321dde 100644
--- a/drivers/staging/lustre/lnet/selftest/selftest.h
+++ b/drivers/staging/lustre/lnet/selftest/selftest.h
@@ -393,7 +393,7 @@ typedef struct sfw_test_instance {
 /* XXX: trailing (PAGE_CACHE_SIZE % sizeof(lnet_process_id_t)) bytes at
  * the end of pages are not used */
 #define SFW_MAX_CONCUR	   LST_MAX_CONCUR
-#define SFW_ID_PER_PAGE    (PAGE_CACHE_SIZE / sizeof(lnet_process_id_packed_t))
+#define SFW_ID_PER_PAGE    (PAGE_SIZE / sizeof(lnet_process_id_packed_t))
 #define SFW_MAX_NDESTS	   (LNET_MAX_IOV * SFW_ID_PER_PAGE)
 #define sfw_id_pages(n)    (((n) + SFW_ID_PER_PAGE - 1) / SFW_ID_PER_PAGE)
diff --git a/drivers/staging/lustre/lustre/include/linux/lustre_patchless_compat.h b/drivers/staging/lustre/lustre/include/linux/lustre_patchless_compat.h
index 33e0b99..c6c7f54 100644
--- a/drivers/staging/lustre/lustre/include/linux/lustre_patchless_compat.h
+++ b/drivers/staging/lustre/lustre/include/linux/lustre_patchless_compat.h
@@ -52,7 +52,7 @@ truncate_complete_page(struct address_space *mapping, struct page *page)
 		return;
 	if (PagePrivate(page))
-		page->mapping->a_ops->invalidatepage(page, 0, PAGE_CACHE_SIZE);
+		page->mapping->a_ops->invalidatepage(page, 0, PAGE_SIZE);
 	cancel_dirty_page(page);
 	ClearPageMappedToDisk(page);
diff --git a/drivers/staging/lustre/lustre/include/lustre/lustre_idl.h b/drivers/staging/lustre/lustre/include/lustre/lustre_idl.h
index da8bc6e..1e2ebe5 100644
--- a/drivers/staging/lustre/lustre/include/lustre/lustre_idl.h
+++ b/drivers/staging/lustre/lustre/include/lustre/lustre_idl.h
@@ -1031,7 +1031,7 @@ static inline int lu_dirent_size(struct lu_dirent *ent)
 #define LU_PAGE_SIZE  (1UL << LU_PAGE_SHIFT)
 #define LU_PAGE_MASK  (~(LU_PAGE_SIZE - 1))
-#define LU_PAGE_COUNT (1 << (PAGE_CACHE_SHIFT - LU_PAGE_SHIFT))
+#define LU_PAGE_COUNT (1 << (PAGE_SHIFT - LU_PAGE_SHIFT))
 /** @} lu_dir */
diff --git a/drivers/staging/lustre/lustre/include/lustre_mdc.h b/drivers/staging/lustre/lustre/include/lustre_mdc.h
index df94f9f..af77eb3 100644
--- a/drivers/staging/lustre/lustre/include/lustre_mdc.h
+++ b/drivers/staging/lustre/lustre/include/lustre_mdc.h
@@ -155,12 +155,12 @@ static inline void mdc_update_max_ea_from_body(struct obd_export *exp,
 		if (cli->cl_max_mds_easize < body->max_mdsize) {
 			cli->cl_max_mds_easize = body->max_mdsize;
 			cli->cl_default_mds_easize =
-			    min_t(__u32, body->max_mdsize, PAGE_CACHE_SIZE);
+			    min_t(__u32, body->max_mdsize, PAGE_SIZE);
 		if (cli->cl_max_mds_cookiesize < body->max_cookiesize) {
 			cli->cl_max_mds_cookiesize = body->max_cookiesize;
 			cli->cl_default_mds_cookiesize =
-			    min_t(__u32, body->max_cookiesize, PAGE_CACHE_SIZE);
+			    min_t(__u32, body->max_cookiesize, PAGE_SIZE);
diff --git a/drivers/staging/lustre/lustre/include/lustre_net.h b/drivers/staging/lustre/lustre/include/lustre_net.h
index 4fa1a18..a5e9095 100644
--- a/drivers/staging/lustre/lustre/include/lustre_net.h
+++ b/drivers/staging/lustre/lustre/include/lustre_net.h
@@ -99,13 +99,13 @@
 #define PTLRPC_MAX_BRW_BITS	(LNET_MTU_BITS + PTLRPC_BULK_OPS_BITS)
 #define PTLRPC_MAX_BRW_SIZE	(1 << PTLRPC_MAX_BRW_BITS)
-#define PTLRPC_MAX_BRW_PAGES	(PTLRPC_MAX_BRW_SIZE >> PAGE_CACHE_SHIFT)
+#define PTLRPC_MAX_BRW_PAGES	(PTLRPC_MAX_BRW_SIZE >> PAGE_SHIFT)
 #define ONE_MB_BRW_SIZE		(1 << LNET_MTU_BITS)
 #define MD_MAX_BRW_SIZE		(1 << LNET_MTU_BITS)
-#define MD_MAX_BRW_PAGES	(MD_MAX_BRW_SIZE >> PAGE_CACHE_SHIFT)
+#define MD_MAX_BRW_PAGES	(MD_MAX_BRW_SIZE >> PAGE_SHIFT)
 #define DT_MAX_BRW_SIZE		PTLRPC_MAX_BRW_SIZE
-#define DT_MAX_BRW_PAGES	(DT_MAX_BRW_SIZE >> PAGE_CACHE_SHIFT)
+#define DT_MAX_BRW_PAGES	(DT_MAX_BRW_SIZE >> PAGE_SHIFT)
 #define OFD_MAX_BRW_SIZE	(1 << LNET_MTU_BITS)
 /* When PAGE_SIZE is a constant, we can check our arithmetic here with cpp! */
diff --git a/drivers/staging/lustre/lustre/include/obd.h b/drivers/staging/lustre/lustre/include/obd.h
index 4a0f2e8..f4167db 100644
--- a/drivers/staging/lustre/lustre/include/obd.h
+++ b/drivers/staging/lustre/lustre/include/obd.h
@@ -1318,7 +1318,7 @@ bad_format:
 static inline int cli_brw_size(struct obd_device *obd)
-	return obd->u.cli.cl_max_pages_per_rpc << PAGE_CACHE_SHIFT;
+	return obd->u.cli.cl_max_pages_per_rpc << PAGE_SHIFT;
 #endif /* __OBD_H */
diff --git a/drivers/staging/lustre/lustre/include/obd_support.h b/drivers/staging/lustre/lustre/include/obd_support.h
index 225262fa..f8ee3a3 100644
--- a/drivers/staging/lustre/lustre/include/obd_support.h
+++ b/drivers/staging/lustre/lustre/include/obd_support.h
@@ -500,7 +500,7 @@ extern char obd_jobid_var[];
 #ifdef POISON_BULK
 #define POISON_PAGE(page, val) do {		  \
-	memset(kmap(page), val, PAGE_CACHE_SIZE); \
+	memset(kmap(page), val, PAGE_SIZE); \
 	kunmap(page);				  \
 } while (0)
 #else
diff --git a/drivers/staging/lustre/lustre/lclient/lcommon_cl.c b/drivers/staging/lustre/lustre/lclient/lcommon_cl.c
index aced41a..96141d1 100644
--- a/drivers/staging/lustre/lustre/lclient/lcommon_cl.c
+++ b/drivers/staging/lustre/lustre/lclient/lcommon_cl.c
@@ -758,9 +758,9 @@ int ccc_prep_size(const struct lu_env *env, struct cl_object *obj,
 				 * --bug 17336
 				loff_t size = cl_isize_read(inode);
-				loff_t cur_index = start >> PAGE_CACHE_SHIFT;
+				loff_t cur_index = start >> PAGE_SHIFT;
 				loff_t size_index = (size - 1) >>
-						    PAGE_CACHE_SHIFT;
+						    PAGE_SHIFT;
 				if ((size == 0 && cur_index != 0) ||
 				    size_index < cur_index)
diff --git a/drivers/staging/lustre/lustre/ldlm/ldlm_lib.c b/drivers/staging/lustre/lustre/ldlm/ldlm_lib.c
index b586d5a..7dd7df5 100644
--- a/drivers/staging/lustre/lustre/ldlm/ldlm_lib.c
+++ b/drivers/staging/lustre/lustre/ldlm/ldlm_lib.c
@@ -307,8 +307,8 @@ int client_obd_setup(struct obd_device *obddev, struct lustre_cfg *lcfg)
 	cli->cl_avail_grant = 0;
 	/* FIXME: Should limit this for the sum of all cl_dirty_max. */
 	cli->cl_dirty_max = OSC_MAX_DIRTY_DEFAULT * 1024 * 1024;
-	if (cli->cl_dirty_max >> PAGE_CACHE_SHIFT > totalram_pages / 8)
-		cli->cl_dirty_max = totalram_pages << (PAGE_CACHE_SHIFT - 3);
+	if (cli->cl_dirty_max >> PAGE_SHIFT > totalram_pages / 8)
+		cli->cl_dirty_max = totalram_pages << (PAGE_SHIFT - 3);
 	INIT_LIST_HEAD(&cli->cl_cache_waiters);
 	INIT_LIST_HEAD(&cli->cl_loi_ready_list);
 	INIT_LIST_HEAD(&cli->cl_loi_hp_ready_list);
@@ -353,15 +353,15 @@ int client_obd_setup(struct obd_device *obddev, struct lustre_cfg *lcfg)
 	 * In the future this should likely be increased. LU-1431
 	cli->cl_max_pages_per_rpc = min_t(int, PTLRPC_MAX_BRW_PAGES,
-					  LNET_MTU >> PAGE_CACHE_SHIFT);
+					  LNET_MTU >> PAGE_SHIFT);
 	if (!strcmp(name, LUSTRE_MDC_NAME)) {
 		cli->cl_max_rpcs_in_flight = MDC_MAX_RIF_DEFAULT;
-	} else if (totalram_pages >> (20 - PAGE_CACHE_SHIFT) <= 128 /* MB */) {
+	} else if (totalram_pages >> (20 - PAGE_SHIFT) <= 128 /* MB */) {
 		cli->cl_max_rpcs_in_flight = 2;
-	} else if (totalram_pages >> (20 - PAGE_CACHE_SHIFT) <= 256 /* MB */) {
+	} else if (totalram_pages >> (20 - PAGE_SHIFT) <= 256 /* MB */) {
 		cli->cl_max_rpcs_in_flight = 3;
-	} else if (totalram_pages >> (20 - PAGE_CACHE_SHIFT) <= 512 /* MB */) {
+	} else if (totalram_pages >> (20 - PAGE_SHIFT) <= 512 /* MB */) {
 		cli->cl_max_rpcs_in_flight = 4;
 	} else {
 		cli->cl_max_rpcs_in_flight = OSC_MAX_RIF_DEFAULT;
diff --git a/drivers/staging/lustre/lustre/ldlm/ldlm_pool.c b/drivers/staging/lustre/lustre/ldlm/ldlm_pool.c
index 3e937b0..b913ba9 100644
--- a/drivers/staging/lustre/lustre/ldlm/ldlm_pool.c
+++ b/drivers/staging/lustre/lustre/ldlm/ldlm_pool.c
@@ -107,7 +107,7 @@
  * 50 ldlm locks for 1MB of RAM.
-#define LDLM_POOL_HOST_L ((NUM_CACHEPAGES >> (20 - PAGE_CACHE_SHIFT)) * 50)
+#define LDLM_POOL_HOST_L ((NUM_CACHEPAGES >> (20 - PAGE_SHIFT)) * 50)
  * Maximal possible grant step plan in %.
diff --git a/drivers/staging/lustre/lustre/ldlm/ldlm_request.c b/drivers/staging/lustre/lustre/ldlm/ldlm_request.c
index c7904a9..74e193e 100644
--- a/drivers/staging/lustre/lustre/ldlm/ldlm_request.c
+++ b/drivers/staging/lustre/lustre/ldlm/ldlm_request.c
@@ -546,7 +546,7 @@ static inline int ldlm_req_handles_avail(int req_size, int off)
 	int avail;
-	avail = min_t(int, LDLM_MAXREQSIZE, PAGE_CACHE_SIZE - 512) - req_size;
+	avail = min_t(int, LDLM_MAXREQSIZE, PAGE_SIZE - 512) - req_size;
 	if (likely(avail >= 0))
 		avail /= (int)sizeof(struct lustre_handle);
 	else
diff --git a/drivers/staging/lustre/lustre/llite/dir.c b/drivers/staging/lustre/lustre/llite/dir.c
index 4e0a3e5..a7c02e0 100644
--- a/drivers/staging/lustre/lustre/llite/dir.c
+++ b/drivers/staging/lustre/lustre/llite/dir.c
@@ -153,7 +153,7 @@ static int ll_dir_filler(void *_hash, struct page *page0)
 	struct page **page_pool;
 	struct page *page;
 	struct lu_dirpage *dp;
-	int max_pages = ll_i2sbi(inode)->ll_md_brw_size >> PAGE_CACHE_SHIFT;
+	int max_pages = ll_i2sbi(inode)->ll_md_brw_size >> PAGE_SHIFT;
 	int nrdpgs = 0; /* number of pages read actually */
 	int npages;
 	int i;
@@ -193,8 +193,8 @@ static int ll_dir_filler(void *_hash, struct page *page0)
 		if (body->valid & OBD_MD_FLSIZE)
 			cl_isize_write(inode, body->size);
-		nrdpgs = (request->rq_bulk->bd_nob_transferred+PAGE_CACHE_SIZE-1)
-			 >> PAGE_CACHE_SHIFT;
+		nrdpgs = (request->rq_bulk->bd_nob_transferred+PAGE_SIZE-1)
+			 >> PAGE_SHIFT;
 		SetPageUptodate(page0);
 	unlock_page(page0);
@@ -209,7 +209,7 @@ static int ll_dir_filler(void *_hash, struct page *page0)
 		page = page_pool[i];
 		if (rc < 0 || i >= nrdpgs) {
+			put_page(page);
 			continue;
@@ -230,7 +230,7 @@ static int ll_dir_filler(void *_hash, struct page *page0)
 			CDEBUG(D_VFSTRACE, "page %lu add to page cache failed: %d\n",
 			       offset, ret);
+		put_page(page);
 	if (page_pool != &page0)
@@ -247,7 +247,7 @@ void ll_release_page(struct page *page, int remove)
 			truncate_complete_page(page->mapping, page);
 		unlock_page(page);
+	put_page(page);
@@ -273,7 +273,7 @@ static struct page *ll_dir_page_locate(struct inode *dir, __u64 *hash,
 	if (found > 0 && !radix_tree_exceptional_entry(page)) {
-		page_cache_get(page);
+		get_page(page);
 		spin_unlock_irq(&mapping->tree_lock);
 		 * In contrast to find_lock_page() we are sure that directory
@@ -313,7 +313,7 @@ static struct page *ll_dir_page_locate(struct inode *dir, __u64 *hash,
 				page = NULL;
 		} else {
+			put_page(page);
 			page = ERR_PTR(-EIO);
@@ -1507,7 +1507,7 @@ skip_lmm:
 			st.st_gid     = body->gid;
 			st.st_rdev    = body->rdev;
 			st.st_size    = body->size;
-			st.st_blksize = PAGE_CACHE_SIZE;
+			st.st_blksize = PAGE_SIZE;
 			st.st_blocks  = body->blocks;
 			st.st_atime   = body->atime;
 			st.st_mtime   = body->mtime;
diff --git a/drivers/staging/lustre/lustre/llite/llite_internal.h b/drivers/staging/lustre/lustre/llite/llite_internal.h
index 3e1572c..e3c0f1d 100644
--- a/drivers/staging/lustre/lustre/llite/llite_internal.h
+++ b/drivers/staging/lustre/lustre/llite/llite_internal.h
@@ -310,10 +310,10 @@ static inline struct ll_inode_info *ll_i2info(struct inode *inode)
 /* default to about 40meg of readahead on a given system.  That much tied
  * up in 512k readahead requests serviced at 40ms each is about 1GB/s.
-#define SBI_DEFAULT_READAHEAD_MAX (40UL << (20 - PAGE_CACHE_SHIFT))
+#define SBI_DEFAULT_READAHEAD_MAX (40UL << (20 - PAGE_SHIFT))
 /* default to read-ahead full files smaller than 2MB on the second read */
-#define SBI_DEFAULT_READAHEAD_WHOLE_MAX (2UL << (20 - PAGE_CACHE_SHIFT))
+#define SBI_DEFAULT_READAHEAD_WHOLE_MAX (2UL << (20 - PAGE_SHIFT))
 enum ra_stat {
 	RA_STAT_HIT = 0,
@@ -975,13 +975,13 @@ struct vm_area_struct *our_vma(struct mm_struct *mm, unsigned long addr,
 static inline void ll_invalidate_page(struct page *vmpage)
 	struct address_space *mapping = vmpage->mapping;
-	loff_t offset = vmpage->index << PAGE_CACHE_SHIFT;
+	loff_t offset = vmpage->index << PAGE_SHIFT;
 	LASSERT(PageLocked(vmpage));
 	if (!mapping)
 		return;
-	ll_teardown_mmaps(mapping, offset, offset + PAGE_CACHE_SIZE);
+	ll_teardown_mmaps(mapping, offset, offset + PAGE_SIZE);
 	truncate_complete_page(mapping, vmpage);
diff --git a/drivers/staging/lustre/lustre/llite/llite_lib.c b/drivers/staging/lustre/lustre/llite/llite_lib.c
index 6d6bb33..b57a992 100644
--- a/drivers/staging/lustre/lustre/llite/llite_lib.c
+++ b/drivers/staging/lustre/lustre/llite/llite_lib.c
@@ -85,7 +85,7 @@ static struct ll_sb_info *ll_init_sbi(struct super_block *sb)
 	si_meminfo(&si);
 	pages = si.totalram - si.totalhigh;
-	if (pages >> (20 - PAGE_CACHE_SHIFT) < 512)
+	if (pages >> (20 - PAGE_SHIFT) < 512)
 		lru_page_max = pages / 2;
 	else
 		lru_page_max = (pages / 4) * 3;
@@ -272,12 +272,12 @@ static int client_common_fill_super(struct super_block *sb, char *md, char *dt,
 	    valid != CLIENT_CONNECT_MDT_REQD) {
 		char *buf;
-		buf = kzalloc(PAGE_CACHE_SIZE, GFP_KERNEL);
+		buf = kzalloc(PAGE_SIZE, GFP_KERNEL);
 		if (!buf) {
 			err = -ENOMEM;
 			goto out_md_fid;
-		obd_connect_flags2str(buf, PAGE_CACHE_SIZE,
+		obd_connect_flags2str(buf, PAGE_SIZE,
 				      valid ^ CLIENT_CONNECT_MDT_REQD, ",");
 		LCONSOLE_ERROR_MSG(0x170, "Server %s does not support feature(s) needed for correct operation of this client (%s). Please upgrade server or downgrade client.\n",
 				   sbi->ll_md_exp->exp_obd->obd_name, buf);
@@ -335,7 +335,7 @@ static int client_common_fill_super(struct super_block *sb, char *md, char *dt,
 	if (data->ocd_connect_flags & OBD_CONNECT_BRW_SIZE)
 		sbi->ll_md_brw_size = data->ocd_brw_size;
 	else
-		sbi->ll_md_brw_size = PAGE_CACHE_SIZE;
+		sbi->ll_md_brw_size = PAGE_SIZE;
 	if (data->ocd_connect_flags & OBD_CONNECT_LAYOUTLOCK) {
 		LCONSOLE_INFO("Layout lock feature supported.\n");
diff --git a/drivers/staging/lustre/lustre/llite/llite_mmap.c b/drivers/staging/lustre/lustre/llite/llite_mmap.c
index 69445a9..5b484e6 100644
--- a/drivers/staging/lustre/lustre/llite/llite_mmap.c
+++ b/drivers/staging/lustre/lustre/llite/llite_mmap.c
@@ -58,7 +58,7 @@ void policy_from_vma(ldlm_policy_data_t *policy,
 		     size_t count)
 	policy->l_extent.start = ((addr - vma->vm_start) & CFS_PAGE_MASK) +
-				 (vma->vm_pgoff << PAGE_CACHE_SHIFT);
+				 (vma->vm_pgoff << PAGE_SHIFT);
 	policy->l_extent.end = (policy->l_extent.start + count - 1) |
 			       ~CFS_PAGE_MASK;
@@ -321,7 +321,7 @@ static int ll_fault0(struct vm_area_struct *vma, struct vm_fault *vmf)
 		vmpage = vio->u.fault.ft_vmpage;
 		if (result != 0 && vmpage) {
-			page_cache_release(vmpage);
+			put_page(vmpage);
 			vmf->page = NULL;
@@ -360,7 +360,7 @@ restart:
 		lock_page(vmpage);
 		if (unlikely(!vmpage->mapping)) { /* unlucky */
 			unlock_page(vmpage);
+			put_page(vmpage);
 			vmf->page = NULL;
 			if (!printed && ++count > 16) {
@@ -457,7 +457,7 @@ int ll_teardown_mmaps(struct address_space *mapping, __u64 first, __u64 last)
 	LASSERTF(last > first, "last %llu first %llu\n", last, first);
 	if (mapping_mapped(mapping)) {
 		rc = 0;
-		unmap_mapping_range(mapping, first + PAGE_CACHE_SIZE - 1,
+		unmap_mapping_range(mapping, first + PAGE_SIZE - 1,
 				    last - first + 1, 0);
diff --git a/drivers/staging/lustre/lustre/llite/lloop.c b/drivers/staging/lustre/lustre/llite/lloop.c
index b725fc1..f169c0d 100644
--- a/drivers/staging/lustre/lustre/llite/lloop.c
+++ b/drivers/staging/lustre/lustre/llite/lloop.c
@@ -218,7 +218,7 @@ static int do_bio_lustrebacked(struct lloop_device *lo, struct bio *head)
 		offset = (pgoff_t)(bio->bi_iter.bi_sector << 9) + lo->lo_offset;
 		bio_for_each_segment(bvec, bio, iter) {
 			BUG_ON(bvec.bv_offset != 0);
-			BUG_ON(bvec.bv_len != PAGE_CACHE_SIZE);
+			BUG_ON(bvec.bv_len != PAGE_SIZE);
 			pages[page_count] = bvec.bv_page;
 			offsets[page_count] = offset;
@@ -232,7 +232,7 @@ static int do_bio_lustrebacked(struct lloop_device *lo, struct bio *head)
 			(rw == WRITE) ? LPROC_LL_BRW_WRITE : LPROC_LL_BRW_READ,
 			page_count);
-	pvec->ldp_size = page_count << PAGE_CACHE_SHIFT;
+	pvec->ldp_size = page_count << PAGE_SHIFT;
 	pvec->ldp_nr = page_count;
 	/* FIXME: in ll_direct_rw_pages, it has to allocate many cl_page{}s to
@@ -507,7 +507,7 @@ static int loop_set_fd(struct lloop_device *lo, struct file *unused,
 	set_device_ro(bdev, (lo_flags & LO_FLAGS_READ_ONLY) != 0);
-	lo->lo_blocksize = PAGE_CACHE_SIZE;
+	lo->lo_blocksize = PAGE_SIZE;
 	lo->lo_device = bdev;
 	lo->lo_flags = lo_flags;
 	lo->lo_backing_file = file;
@@ -525,11 +525,11 @@ static int loop_set_fd(struct lloop_device *lo, struct file *unused,
 	lo->lo_queue->queuedata = lo;
 	/* queue parameters */
-	CLASSERT(PAGE_CACHE_SIZE < (1 << (sizeof(unsigned short) * 8)));
+	CLASSERT(PAGE_SIZE < (1 << (sizeof(unsigned short) * 8)));
 	blk_queue_logical_block_size(lo->lo_queue,
-				     (unsigned short)PAGE_CACHE_SIZE);
+				     (unsigned short)PAGE_SIZE);
 	blk_queue_max_hw_sectors(lo->lo_queue,
-				 LLOOP_MAX_SEGMENTS << (PAGE_CACHE_SHIFT - 9));
+				 LLOOP_MAX_SEGMENTS << (PAGE_SHIFT - 9));
 	blk_queue_max_segments(lo->lo_queue, LLOOP_MAX_SEGMENTS);
 	set_capacity(disks[lo->lo_number], size);
diff --git a/drivers/staging/lustre/lustre/llite/lproc_llite.c b/drivers/staging/lustre/lustre/llite/lproc_llite.c
index 45941a6..27ab126 100644
--- a/drivers/staging/lustre/lustre/llite/lproc_llite.c
+++ b/drivers/staging/lustre/lustre/llite/lproc_llite.c
@@ -233,7 +233,7 @@ static ssize_t max_read_ahead_mb_show(struct kobject *kobj,
 	pages_number = sbi->ll_ra_info.ra_max_pages;
 	spin_unlock(&sbi->ll_lock);
-	mult = 1 << (20 - PAGE_CACHE_SHIFT);
+	mult = 1 << (20 - PAGE_SHIFT);
 	return lprocfs_read_frac_helper(buf, PAGE_SIZE, pages_number, mult);
@@ -251,12 +251,12 @@ static ssize_t max_read_ahead_mb_store(struct kobject *kobj,
 	if (rc)
 		return rc;
-	pages_number *= 1 << (20 - PAGE_CACHE_SHIFT); /* MB -> pages */
+	pages_number *= 1 << (20 - PAGE_SHIFT); /* MB -> pages */
 	if (pages_number > totalram_pages / 2) {
 		CERROR("can't set file readahead more than %lu MB\n",
-		       totalram_pages >> (20 - PAGE_CACHE_SHIFT + 1)); /*1/2 of RAM*/
+		       totalram_pages >> (20 - PAGE_SHIFT + 1)); /*1/2 of RAM*/
 		return -ERANGE;
@@ -281,7 +281,7 @@ static ssize_t max_read_ahead_per_file_mb_show(struct kobject *kobj,
 	pages_number = sbi->ll_ra_info.ra_max_pages_per_file;
@@ -326,7 +326,7 @@ static ssize_t max_read_ahead_whole_mb_show(struct kobject *kobj,
 	pages_number = sbi->ll_ra_info.ra_max_read_ahead_whole_pages;
@@ -349,7 +349,7 @@ static ssize_t max_read_ahead_whole_mb_store(struct kobject *kobj,
 	if (pages_number > sbi->ll_ra_info.ra_max_pages_per_file) {
 		CERROR("can't set max_read_ahead_whole_mb more than max_read_ahead_per_file_mb: %lu\n",
-		       sbi->ll_ra_info.ra_max_pages_per_file >> (20 - PAGE_CACHE_SHIFT));
+		       sbi->ll_ra_info.ra_max_pages_per_file >> (20 - PAGE_SHIFT));
 		return -ERANGE;
@@ -366,7 +366,7 @@ static int ll_max_cached_mb_seq_show(struct seq_file *m, void *v)
 	struct super_block     *sb    = m->private;
 	struct ll_sb_info      *sbi   = ll_s2sbi(sb);
 	struct cl_client_cache *cache = &sbi->ll_cache;
-	int shift = 20 - PAGE_CACHE_SHIFT;
+	int shift = 20 - PAGE_SHIFT;
 	int max_cached_mb;
 	int unused_mb;
@@ -405,7 +405,7 @@ static ssize_t ll_max_cached_mb_seq_write(struct file *file,
 		return -EFAULT;
 	kernbuf[count] = 0;
 	buffer += lprocfs_find_named_value(kernbuf, "max_cached_mb:", &count) -
 		  kernbuf;
 	rc = lprocfs_write_frac_helper(buffer, count, &pages_number, mult);
@@ -415,7 +415,7 @@ static ssize_t ll_max_cached_mb_seq_write(struct file *file,
 	if (pages_number < 0 || pages_number > totalram_pages) {
 		CERROR("%s: can't set max cache more than %lu MB\n",
 		       ll_get_fsname(sb, NULL, 0),
-		       totalram_pages >> (20 - PAGE_CACHE_SHIFT));
+		       totalram_pages >> (20 - PAGE_SHIFT));
 		return -ERANGE;
diff --git a/drivers/staging/lustre/lustre/llite/rw.c b/drivers/staging/lustre/lustre/llite/rw.c
index 34614ac..4c7250a 100644
--- a/drivers/staging/lustre/lustre/llite/rw.c
+++ b/drivers/staging/lustre/lustre/llite/rw.c
@@ -146,10 +146,10 @@ static struct ll_cl_context *ll_cl_init(struct file *file,
 		io->ci_lockreq = CILR_NEVER;
-		pos = vmpage->index << PAGE_CACHE_SHIFT;
+		pos = vmpage->index << PAGE_SHIFT;
 		/* Create a temp IO to serve write. */
-		result = cl_io_rw_init(env, io, CIT_WRITE, pos, PAGE_CACHE_SIZE);
+		result = cl_io_rw_init(env, io, CIT_WRITE, pos, PAGE_SIZE);
 		if (result == 0) {
 			cio->cui_fd = LUSTRE_FPRIVATE(file);
 			cio->cui_iter = NULL;
@@ -498,7 +498,7 @@ static int ll_read_ahead_page(const struct lu_env *env, struct cl_io *io,
 		if (rc != 1)
+		put_page(vmpage);
 	} else {
 		which = RA_STAT_FAILED_GRAB_PAGE;
 		msg   = "g_c_p_n failed";
@@ -527,7 +527,7 @@ static int ll_read_ahead_page(const struct lu_env *env, struct cl_io *io,
  * and max_read_ahead_per_file_mb otherwise the readahead budget can be used
  * up quickly which will affect read performance significantly. See LU-2816
-#define RAS_INCREASE_STEP(inode) (ONE_MB_BRW_SIZE >> PAGE_CACHE_SHIFT)
+#define RAS_INCREASE_STEP(inode) (ONE_MB_BRW_SIZE >> PAGE_SHIFT)
 static inline int stride_io_mode(struct ll_readahead_state *ras)
@@ -739,7 +739,7 @@ int ll_readahead(const struct lu_env *env, struct cl_io *io,
 			end = rpc_boundary;
 		/* Truncate RA window to end of file */
-		end = min(end, (unsigned long)((kms - 1) >> PAGE_CACHE_SHIFT));
+		end = min(end, (unsigned long)((kms - 1) >> PAGE_SHIFT));
 		ras->ras_next_readahead = max(end, end + 1);
 		RAS_CDEBUG(ras);
@@ -776,7 +776,7 @@ int ll_readahead(const struct lu_env *env, struct cl_io *io,
 	if (reserved != 0)
 		ll_ra_count_put(ll_i2sbi(inode), reserved);
-	if (ra_end == end + 1 && ra_end == (kms >> PAGE_CACHE_SHIFT))
+	if (ra_end == end + 1 && ra_end == (kms >> PAGE_SHIFT))
 		ll_ra_stats_inc(mapping, RA_STAT_EOF);
 	/* if we didn't get to the end of the region we reserved from
@@ -985,8 +985,8 @@ void ras_update(struct ll_sb_info *sbi, struct inode *inode,
 	if (ras->ras_requests == 2 && !ras->ras_request_index) {
 		__u64 kms_pages;
-		kms_pages = (i_size_read(inode) + PAGE_CACHE_SIZE - 1) >>
-			    PAGE_CACHE_SHIFT;
+		kms_pages = (i_size_read(inode) + PAGE_SIZE - 1) >>
+			    PAGE_SHIFT;
 		CDEBUG(D_READA, "kmsp %llu mwp %lu mp %lu\n", kms_pages,
 		       ra->ra_max_read_ahead_whole_pages, ra->ra_max_pages_per_file);
@@ -1173,7 +1173,7 @@ int ll_writepage(struct page *vmpage, struct writeback_control *wbc)
 		 * PageWriteback or clean the page.
 		result = cl_sync_file_range(inode, offset,
-					    offset + PAGE_CACHE_SIZE - 1,
+					    offset + PAGE_SIZE - 1,
 					    CL_FSYNC_LOCAL, 1);
 		if (result > 0) {
 			/* actually we may have written more than one page.
@@ -1211,7 +1211,7 @@ int ll_writepages(struct address_space *mapping, struct writeback_control *wbc)
 	int ignore_layout = 0;
 	if (wbc->range_cyclic) {
-		start = mapping->writeback_index << PAGE_CACHE_SHIFT;
+		start = mapping->writeback_index << PAGE_SHIFT;
 		end = OBD_OBJECT_EOF;
 	} else {
 		start = wbc->range_start;
@@ -1241,7 +1241,7 @@ int ll_writepages(struct address_space *mapping, struct writeback_control *wbc)
 	if (wbc->range_cyclic || (range_whole && wbc->nr_to_write > 0)) {
 		if (end == OBD_OBJECT_EOF)
 			end = i_size_read(inode);
-		mapping->writeback_index = (end >> PAGE_CACHE_SHIFT) + 1;
+		mapping->writeback_index = (end >> PAGE_SHIFT) + 1;
 	return result;
diff --git a/drivers/staging/lustre/lustre/llite/rw26.c b/drivers/staging/lustre/lustre/llite/rw26.c
index 7a5db67..69aa15e 100644
--- a/drivers/staging/lustre/lustre/llite/rw26.c
+++ b/drivers/staging/lustre/lustre/llite/rw26.c
@@ -87,7 +87,7 @@ static void ll_invalidatepage(struct page *vmpage, unsigned int offset,
 	 * below because they are run with page locked and all our io is
 	 * happening with locked page too
-	if (offset == 0 && length == PAGE_CACHE_SIZE) {
+	if (offset == 0 && length == PAGE_SIZE) {
 		env = cl_env_get(&refcheck);
 		if (!IS_ERR(env)) {
 			inode = vmpage->mapping->host;
@@ -193,8 +193,8 @@ static inline int ll_get_user_pages(int rw, unsigned long user_addr,
 		return -EFBIG;
-	*max_pages = (user_addr + size + PAGE_CACHE_SIZE - 1) >> PAGE_CACHE_SHIFT;
-	*max_pages -= user_addr >> PAGE_CACHE_SHIFT;
+	*max_pages = (user_addr + size + PAGE_SIZE - 1) >> PAGE_SHIFT;
+	*max_pages -= user_addr >> PAGE_SHIFT;
 	*pages = libcfs_kvzalloc(*max_pages * sizeof(**pages), GFP_NOFS);
 	if (*pages) {
@@ -217,7 +217,7 @@ static void ll_free_user_pages(struct page **pages, int npages, int do_dirty)
 	for (i = 0; i < npages; i++) {
 		if (do_dirty)
 			set_page_dirty_lock(pages[i]);
 	kvfree(pages);
@@ -357,7 +357,7 @@ static ssize_t ll_direct_IO_26_seg(const struct lu_env *env, struct cl_io *io,
  * up to 22MB for 128kB kmalloc and up to 682MB for 4MB kmalloc.
 #define MAX_DIO_SIZE ((KMALLOC_MAX_SIZE / sizeof(struct brw_page) *	  \
-		       PAGE_CACHE_SIZE) & ~(DT_MAX_BRW_SIZE - 1))
+		       PAGE_SIZE) & ~(DT_MAX_BRW_SIZE - 1))
 static ssize_t ll_direct_IO_26(struct kiocb *iocb, struct iov_iter *iter,
 			       loff_t file_offset)
@@ -382,8 +382,8 @@ static ssize_t ll_direct_IO_26(struct kiocb *iocb, struct iov_iter *iter,
 	CDEBUG(D_VFSTRACE,
 	       "VFS Op:inode=%lu/%u(%p), size=%zd (max %lu), offset=%lld=%llx, pages %zd (max %lu)\n",
 	       inode->i_ino, inode->i_generation, inode, count, MAX_DIO_SIZE,
-	       file_offset, file_offset, count >> PAGE_CACHE_SHIFT,
-	       MAX_DIO_SIZE >> PAGE_CACHE_SHIFT);
+	       file_offset, file_offset, count >> PAGE_SHIFT,
+	       MAX_DIO_SIZE >> PAGE_SHIFT);
 	/* Check that all user buffers are aligned as well */
 	if (iov_iter_alignment(iter) & ~CFS_PAGE_MASK)
@@ -432,8 +432,8 @@ static ssize_t ll_direct_IO_26(struct kiocb *iocb, struct iov_iter *iter,
 			 * page worth of page pointers = 4MB on i386.
 			if (result == -ENOMEM &&
-			    size > (PAGE_CACHE_SIZE / sizeof(*pages)) *
-				   PAGE_CACHE_SIZE) {
+			    size > (PAGE_SIZE / sizeof(*pages)) *
+			    PAGE_SIZE) {
 				size = ((((size / 2) - 1) |
 					 ~CFS_PAGE_MASK) + 1) &
 					CFS_PAGE_MASK;
@@ -474,10 +474,10 @@ static int ll_write_begin(struct file *file, struct address_space *mapping,
 			  loff_t pos, unsigned len, unsigned flags,
 			  struct page **pagep, void **fsdata)
-	pgoff_t index = pos >> PAGE_CACHE_SHIFT;
+	pgoff_t index = pos >> PAGE_SHIFT;
 	struct page *page;
 	int rc;
-	unsigned from = pos & (PAGE_CACHE_SIZE - 1);
+	unsigned from = pos & (PAGE_SIZE - 1);
 	page = grab_cache_page_write_begin(mapping, index, flags);
 	if (!page)
@@ -488,7 +488,7 @@ static int ll_write_begin(struct file *file, struct address_space *mapping,
 	rc = ll_prepare_write(file, page, from, from + len);
 	if (rc) {
 		unlock_page(page);
+		put_page(page);
 	return rc;
@@ -497,12 +497,12 @@ static int ll_write_end(struct file *file, struct address_space *mapping,
 			loff_t pos, unsigned len, unsigned copied,
 			struct page *page, void *fsdata)
 	int rc;
 	rc = ll_commit_write(file, page, from, from + copied);
 	unlock_page(page);
+	put_page(page);
 	return rc ?: copied;
diff --git a/drivers/staging/lustre/lustre/llite/vvp_io.c b/drivers/staging/lustre/lustre/llite/vvp_io.c
index fb0c26e..75d4df7 100644
--- a/drivers/staging/lustre/lustre/llite/vvp_io.c
+++ b/drivers/staging/lustre/lustre/llite/vvp_io.c
@@ -514,7 +514,7 @@ static int vvp_io_read_start(const struct lu_env *env,
 		 * XXX: explicit PAGE_CACHE_SIZE
-		bead->lrr_count = cl_index(obj, tot + PAGE_CACHE_SIZE - 1);
+		bead->lrr_count = cl_index(obj, tot + PAGE_SIZE - 1);
 		ll_ra_read_in(file, bead);
@@ -959,7 +959,7 @@ static int vvp_io_prepare_write(const struct lu_env *env,
 		 * We're completely overwriting an existing page, so _don't_
 		 * set it up to date until commit_write
-		if (from == 0 && to == PAGE_CACHE_SIZE) {
+		if (from == 0 && to == PAGE_SIZE) {
 			CL_PAGE_HEADER(D_PAGE, env, pg, "full page write\n");
 			POISON_PAGE(page, 0x11);
 		} else
@@ -1022,7 +1022,7 @@ static int vvp_io_commit_write(const struct lu_env *env,
 			set_page_dirty(vmpage);
 			vvp_write_pending(cl2ccc(obj), cp);
 		} else if (result == -EDQUOT) {
-			pgoff_t last_index = i_size_read(inode) >> PAGE_CACHE_SHIFT;
+			pgoff_t last_index = i_size_read(inode) >> PAGE_SHIFT;
 			bool need_clip = true;
@@ -1040,7 +1040,7 @@ static int vvp_io_commit_write(const struct lu_env *env,
 			 * being.
 			if (last_index > pg->cp_index) {
-				to = PAGE_CACHE_SIZE;
+				to = PAGE_SIZE;
 				need_clip = false;
 			} else if (last_index == pg->cp_index) {
 				int size_to = i_size_read(inode) & ~CFS_PAGE_MASK;
diff --git a/drivers/staging/lustre/lustre/llite/vvp_page.c b/drivers/staging/lustre/lustre/llite/vvp_page.c
index 850bae7..33ca3eb 100644
--- a/drivers/staging/lustre/lustre/llite/vvp_page.c
+++ b/drivers/staging/lustre/lustre/llite/vvp_page.c
@@ -57,7 +57,7 @@ static void vvp_page_fini_common(struct ccc_page *cp)
 	struct page *vmpage = cp->cpg_page;
 	LASSERT(vmpage);
+	put_page(vmpage);
 static void vvp_page_fini(const struct lu_env *env,
@@ -164,12 +164,12 @@ static int vvp_page_unmap(const struct lu_env *env,
 	LASSERT(vmpage);
-	offset = vmpage->index << PAGE_CACHE_SHIFT;
+	offset = vmpage->index << PAGE_SHIFT;
 	 * XXX is it safe to call this with the page lock held?
-	ll_teardown_mmaps(vmpage->mapping, offset, offset + PAGE_CACHE_SIZE);
+	ll_teardown_mmaps(vmpage->mapping, offset, offset + PAGE_SIZE);
 	return 0;
@@ -537,7 +537,7 @@ int vvp_page_init(const struct lu_env *env, struct cl_object *obj,
 	CLOBINVRNT(env, obj, ccc_object_invariant(obj));
 	cpg->cpg_page = vmpage;
-	page_cache_get(vmpage);
+	get_page(vmpage);
 	INIT_LIST_HEAD(&cpg->cpg_pending_linkage);
 	if (page->cp_type == CPT_CACHEABLE) {
diff --git a/drivers/staging/lustre/lustre/lmv/lmv_obd.c b/drivers/staging/lustre/lustre/lmv/lmv_obd.c
index 0f776cf..ce7e8b7 100644
--- a/drivers/staging/lustre/lustre/lmv/lmv_obd.c
+++ b/drivers/staging/lustre/lustre/lmv/lmv_obd.c
@@ -2129,8 +2129,8 @@ static int lmv_readpage(struct obd_export *exp, struct md_op_data *op_data,
 	if (rc != 0)
 		return rc;
-	ncfspgs = ((*request)->rq_bulk->bd_nob_transferred + PAGE_CACHE_SIZE - 1)
+	ncfspgs = ((*request)->rq_bulk->bd_nob_transferred + PAGE_SIZE - 1)
+		 >> PAGE_SHIFT;
 	nlupgs = (*request)->rq_bulk->bd_nob_transferred >> LU_PAGE_SHIFT;
 	LASSERT(!((*request)->rq_bulk->bd_nob_transferred & ~LU_PAGE_MASK));
 	LASSERT(ncfspgs > 0 && ncfspgs <= op_data->op_npages);
diff --git a/drivers/staging/lustre/lustre/mdc/mdc_request.c b/drivers/staging/lustre/lustre/mdc/mdc_request.c
index 55dd8ef..b91d3ff 100644
--- a/drivers/staging/lustre/lustre/mdc/mdc_request.c
+++ b/drivers/staging/lustre/lustre/mdc/mdc_request.c
@@ -1002,10 +1002,10 @@ restart_bulk:
 	/* NB req now owns desc and will free it when it gets freed */
 	for (i = 0; i < op_data->op_npages; i++)
-		ptlrpc_prep_bulk_page_pin(desc, pages[i], 0, PAGE_CACHE_SIZE);
+		ptlrpc_prep_bulk_page_pin(desc, pages[i], 0, PAGE_SIZE);
 	mdc_readdir_pack(req, op_data->op_offset,
-			 PAGE_CACHE_SIZE * op_data->op_npages,
+			 PAGE_SIZE * op_data->op_npages,
 			 &op_data->op_fid1);
 	ptlrpc_request_set_replen(req);
@@ -1037,7 +1037,7 @@ restart_bulk:
 	if (req->rq_bulk->bd_nob_transferred & ~LU_PAGE_MASK) {
 		CERROR("Unexpected # bytes transferred: %d (%ld expected)\n",
 		       req->rq_bulk->bd_nob_transferred,
-		       PAGE_CACHE_SIZE * op_data->op_npages);
+		       PAGE_SIZE * op_data->op_npages);
 		ptlrpc_req_finished(req);
 		return -EPROTO;
diff --git a/drivers/staging/lustre/lustre/mgc/mgc_request.c b/drivers/staging/lustre/lustre/mgc/mgc_request.c
index b7dc872..3924b09 100644
--- a/drivers/staging/lustre/lustre/mgc/mgc_request.c
+++ b/drivers/staging/lustre/lustre/mgc/mgc_request.c
@@ -1113,7 +1113,7 @@ static int mgc_import_event(struct obd_device *obd,
 enum {
-	CONFIG_READ_NRPAGES_INIT = 1 << (20 - PAGE_CACHE_SHIFT),
+	CONFIG_READ_NRPAGES_INIT = 1 << (20 - PAGE_SHIFT),
 	CONFIG_READ_NRPAGES      = 4
@@ -1137,19 +1137,19 @@ static int mgc_apply_recover_logs(struct obd_device *mgc,
 	LASSERT(cfg->cfg_instance);
 	LASSERT(cfg->cfg_sb == cfg->cfg_instance);
-	inst = kzalloc(PAGE_CACHE_SIZE, GFP_KERNEL);
+	inst = kzalloc(PAGE_SIZE, GFP_KERNEL);
 	if (!inst)
 		return -ENOMEM;
-	pos = snprintf(inst, PAGE_CACHE_SIZE, "%p", cfg->cfg_instance);
-	if (pos >= PAGE_CACHE_SIZE) {
+	pos = snprintf(inst, PAGE_SIZE, "%p", cfg->cfg_instance);
+	if (pos >= PAGE_SIZE) {
 		kfree(inst);
 		return -E2BIG;
 	++pos;
 	buf   = inst + pos;
-	bufsz = PAGE_CACHE_SIZE - pos;
+	bufsz = PAGE_SIZE - pos;
 	while (datalen > 0) {
 		int   entry_len = sizeof(*entry);
@@ -1181,7 +1181,7 @@ static int mgc_apply_recover_logs(struct obd_device *mgc,
 		/* Keep this swab for normal mixed endian handling. LU-1644 */
 		if (mne_swab)
 			lustre_swab_mgs_nidtbl_entry(entry);
-		if (entry->mne_length > PAGE_CACHE_SIZE) {
+		if (entry->mne_length > PAGE_SIZE) {
 			CERROR("MNE too large (%u)\n", entry->mne_length);
 			break;
@@ -1371,7 +1371,7 @@ again:
 	body->mcb_offset = cfg->cfg_last_idx + 1;
 	body->mcb_type   = cld->cld_type;
-	body->mcb_bits   = PAGE_CACHE_SHIFT;
+	body->mcb_bits   = PAGE_SHIFT;
 	body->mcb_units  = nrpages;
 	/* allocate bulk transfer descriptor */
@@ -1383,7 +1383,7 @@ again:
 	for (i = 0; i < nrpages; i++)
 	rc = ptlrpc_queue_wait(req);
@@ -1411,7 +1411,7 @@ again:
 		goto out;
-	if (ealen > nrpages << PAGE_CACHE_SHIFT) {
+	if (ealen > nrpages << PAGE_SHIFT) {
 		rc = -EINVAL;
 		goto out;
@@ -1439,7 +1439,7 @@ again:
 		ptr = kmap(pages[i]);
 		rc2 = mgc_apply_recover_logs(obd, cld, res->mcr_offset, ptr,
-					     min_t(int, ealen, PAGE_CACHE_SIZE),
+					     min_t(int, ealen, PAGE_SIZE),
 					     mne_swab);
 		kunmap(pages[i]);
 		if (rc2 < 0) {
@@ -1448,7 +1448,7 @@ again:
 			break;
-		ealen -= PAGE_CACHE_SIZE;
+		ealen -= PAGE_SIZE;
 out:
diff --git a/drivers/staging/lustre/lustre/obdclass/cl_page.c b/drivers/staging/lustre/lustre/obdclass/cl_page.c
index 231a2f2..3945800 100644
--- a/drivers/staging/lustre/lustre/obdclass/cl_page.c
+++ b/drivers/staging/lustre/lustre/obdclass/cl_page.c
@@ -1477,7 +1477,7 @@ loff_t cl_offset(const struct cl_object *obj, pgoff_t idx)
 	 * XXX for now.
-	return (loff_t)idx << PAGE_CACHE_SHIFT;
+	return (loff_t)idx << PAGE_SHIFT;
 EXPORT_SYMBOL(cl_offset);
@@ -1489,13 +1489,13 @@ pgoff_t cl_index(const struct cl_object *obj, loff_t offset)
 	 * XXX for now.
-	return offset >> PAGE_CACHE_SHIFT;
+	return offset >> PAGE_SHIFT;
 EXPORT_SYMBOL(cl_index);
 int cl_page_size(const struct cl_object *obj)
-	return 1 << PAGE_CACHE_SHIFT;
+	return 1 << PAGE_SHIFT;
 EXPORT_SYMBOL(cl_page_size);
diff --git a/drivers/staging/lustre/lustre/obdclass/class_obd.c b/drivers/staging/lustre/lustre/obdclass/class_obd.c
index 1a938e1..c2cf015 100644
--- a/drivers/staging/lustre/lustre/obdclass/class_obd.c
+++ b/drivers/staging/lustre/lustre/obdclass/class_obd.c
@@ -461,9 +461,9 @@ static int obd_init_checks(void)
 		CWARN("LPD64 wrong length! strlen(%s)=%d != 2\n", buf, len);
 		ret = -EINVAL;
-	if ((u64val & ~CFS_PAGE_MASK) >= PAGE_CACHE_SIZE) {
+	if ((u64val & ~CFS_PAGE_MASK) >= PAGE_SIZE) {
 		CWARN("mask failed: u64val %llu >= %llu\n", u64val,
-		      (__u64)PAGE_CACHE_SIZE);
+		      (__u64)PAGE_SIZE);
 		ret = -EINVAL;
@@ -509,7 +509,7 @@ static int __init obdclass_init(void)
 	 * For clients with less memory, a larger fraction is needed
 	 * for other purposes (mostly for BGL).
-	if (totalram_pages <= 512 << (20 - PAGE_CACHE_SHIFT))
+	if (totalram_pages <= 512 << (20 - PAGE_SHIFT))
 		obd_max_dirty_pages = totalram_pages / 4;
 	else
 		obd_max_dirty_pages = totalram_pages / 2;
diff --git a/drivers/staging/lustre/lustre/obdclass/linux/linux-obdo.c b/drivers/staging/lustre/lustre/obdclass/linux/linux-obdo.c
index 9496c09..4a2baaf 100644
--- a/drivers/staging/lustre/lustre/obdclass/linux/linux-obdo.c
+++ b/drivers/staging/lustre/lustre/obdclass/linux/linux-obdo.c
@@ -71,8 +71,8 @@ void obdo_refresh_inode(struct inode *dst, struct obdo *src, u32 valid)
 	if (valid & OBD_MD_FLBLKSZ && src->o_blksize > (1 << dst->i_blkbits))
 		dst->i_blkbits = ffs(src->o_blksize) - 1;
-	if (dst->i_blkbits < PAGE_CACHE_SHIFT)
-		dst->i_blkbits = PAGE_CACHE_SHIFT;
+	if (dst->i_blkbits < PAGE_SHIFT)
+		dst->i_blkbits = PAGE_SHIFT;
 	/* allocation of space */
 	if (valid & OBD_MD_FLBLOCKS && src->o_blocks > dst->i_blocks)
diff --git a/drivers/staging/lustre/lustre/obdclass/linux/linux-sysctl.c b/drivers/staging/lustre/lustre/obdclass/linux/linux-sysctl.c
index fd333b9..e6bf414 100644
--- a/drivers/staging/lustre/lustre/obdclass/linux/linux-sysctl.c
+++ b/drivers/staging/lustre/lustre/obdclass/linux/linux-sysctl.c
@@ -100,7 +100,7 @@ static ssize_t max_dirty_mb_show(struct kobject *kobj, struct attribute *attr,
 				 char *buf)
 	return sprintf(buf, "%ul\n",
-			obd_max_dirty_pages / (1 << (20 - PAGE_CACHE_SHIFT)));
+			obd_max_dirty_pages / (1 << (20 - PAGE_SHIFT)));
 static ssize_t max_dirty_mb_store(struct kobject *kobj, struct attribute *attr,
@@ -113,14 +113,14 @@ static ssize_t max_dirty_mb_store(struct kobject *kobj, struct attribute *attr,
 	if (rc)
 		return rc;
-	val *= 1 << (20 - PAGE_CACHE_SHIFT); /* convert to pages */
+	val *= 1 << (20 - PAGE_SHIFT); /* convert to pages */
 	if (val > ((totalram_pages / 10) * 9)) {
 		/* Somebody wants to assign too much memory to dirty pages */
 		return -EINVAL;
-	if (val < 4 << (20 - PAGE_CACHE_SHIFT)) {
+	if (val < 4 << (20 - PAGE_SHIFT)) {
 		/* Less than 4 Mb for dirty cache is also bad */
 		return -EINVAL;
diff --git a/drivers/staging/lustre/lustre/obdclass/lu_object.c b/drivers/staging/lustre/lustre/obdclass/lu_object.c
index 65a4746..978568a 100644
--- a/drivers/staging/lustre/lustre/obdclass/lu_object.c
+++ b/drivers/staging/lustre/lustre/obdclass/lu_object.c
@@ -840,8 +840,8 @@ static int lu_htable_order(void)
 	/* limit hashtable size for lowmem systems to low RAM */
-	if (cache_size > 1 << (30 - PAGE_CACHE_SHIFT))
-		cache_size = 1 << (30 - PAGE_CACHE_SHIFT) * 3 / 4;
+	if (cache_size > 1 << (30 - PAGE_SHIFT))
+		cache_size = 1 << (30 - PAGE_SHIFT) * 3 / 4;
 #endif
 	/* clear off unreasonable cache setting. */
@@ -853,7 +853,7 @@ static int lu_htable_order(void)
 		lu_cache_percent = LU_CACHE_PERCENT_DEFAULT;
 	cache_size = cache_size / 100 * lu_cache_percent *
-		(PAGE_CACHE_SIZE / 1024);
+		(PAGE_SIZE / 1024);
 	for (bits = 1; (1 << bits) < cache_size; ++bits) {
diff --git a/drivers/staging/lustre/lustre/obdecho/echo_client.c b/drivers/staging/lustre/lustre/obdecho/echo_client.c
index 64ffe24..1e83669 100644
--- a/drivers/staging/lustre/lustre/obdecho/echo_client.c
+++ b/drivers/staging/lustre/lustre/obdecho/echo_client.c
@@ -278,7 +278,7 @@ static void echo_page_fini(const struct lu_env *env,
 	struct page *vmpage      = ep->ep_vmpage;
 	atomic_dec(&eco->eo_npages);
+	put_page(vmpage);
 static int echo_page_prep(const struct lu_env *env,
@@ -373,7 +373,7 @@ static int echo_page_init(const struct lu_env *env, struct cl_object *obj,
 	struct echo_object *eco = cl2echo_obj(obj);
 	ep->ep_vmpage = vmpage;
+	get_page(vmpage);
 	mutex_init(&ep->ep_lock);
 	cl_page_slice_add(page, &ep->ep_cl, obj, &echo_page_ops);
 	atomic_inc(&eco->eo_npages);
@@ -1138,7 +1138,7 @@ static int cl_echo_object_brw(struct echo_object *eco, int rw, u64 offset,
 	LASSERT(rc == 0);
 	rc = cl_echo_enqueue0(env, eco, offset,
-			      offset + npages * PAGE_CACHE_SIZE - 1,
+			      offset + npages * PAGE_SIZE - 1,
 			      rw == READ ? LCK_PR : LCK_PW, &lh.cookie,
 			      CEF_NEVER);
 	if (rc < 0)
@@ -1311,11 +1311,11 @@ echo_client_page_debug_setup(struct page *page, int rw, u64 id,
 	int      delta;
 	/* no partial pages on the client */
-	LASSERT(count == PAGE_CACHE_SIZE);
+	LASSERT(count == PAGE_SIZE);
 	addr = kmap(page);
-	for (delta = 0; delta < PAGE_CACHE_SIZE; delta += OBD_ECHO_BLOCK_SIZE) {
+	for (delta = 0; delta < PAGE_SIZE; delta += OBD_ECHO_BLOCK_SIZE) {
 		if (rw == OBD_BRW_WRITE) {
 			stripe_off = offset + delta;
 			stripe_id = id;
@@ -1341,11 +1341,11 @@ static int echo_client_page_debug_check(struct page *page, u64 id,
 	int     rc2;
 	addr = kmap(page);
-	for (rc = delta = 0; delta < PAGE_CACHE_SIZE; delta += OBD_ECHO_BLOCK_SIZE) {
+	for (rc = delta = 0; delta < PAGE_SIZE; delta += OBD_ECHO_BLOCK_SIZE) {
 		stripe_id = id;
@@ -1391,7 +1391,7 @@ static int echo_client_kbrw(struct echo_device *ed, int rw, struct obdo *oa,
 		return -EINVAL;
 	/* XXX think again with misaligned I/O */
-	npages = count >> PAGE_CACHE_SHIFT;
+	npages = count >> PAGE_SHIFT;
 		brw_flags = OBD_BRW_ASYNC;
@@ -1408,7 +1408,7 @@ static int echo_client_kbrw(struct echo_device *ed, int rw, struct obdo *oa,
 	for (i = 0, pgp = pga, off = offset;
 	     i < npages;
-	     i++, pgp++, off += PAGE_CACHE_SIZE) {
+	     i++, pgp++, off += PAGE_SIZE) {
 		LASSERT(!pgp->pg);      /* for cleanup */
@@ -1418,7 +1418,7 @@ static int echo_client_kbrw(struct echo_device *ed, int rw, struct obdo *oa,
 			goto out;
 		pages[i] = pgp->pg;
-		pgp->count = PAGE_CACHE_SIZE;
+		pgp->count = PAGE_SIZE;
 		pgp->off = off;
 		pgp->flag = brw_flags;
@@ -1473,8 +1473,8 @@ static int echo_client_prep_commit(const struct lu_env *env,
 	if (count <= 0 || (count & (~CFS_PAGE_MASK)) != 0)
 		return -EINVAL;
-	npages = batch >> PAGE_CACHE_SHIFT;
-	tot_pages = count >> PAGE_CACHE_SHIFT;
+	npages = batch >> PAGE_SHIFT;
+	tot_pages = count >> PAGE_SHIFT;
 	lnb = kcalloc(npages, sizeof(struct niobuf_local), GFP_NOFS);
 	rnb = kcalloc(npages, sizeof(struct niobuf_remote), GFP_NOFS);
@@ -1497,9 +1497,9 @@ static int echo_client_prep_commit(const struct lu_env *env,
 		if (tot_pages < npages)
 			npages = tot_pages;
-		for (i = 0; i < npages; i++, off += PAGE_CACHE_SIZE) {
+		for (i = 0; i < npages; i++, off += PAGE_SIZE) {
 			rnb[i].offset = off;
-			rnb[i].len = PAGE_CACHE_SIZE;
+			rnb[i].len = PAGE_SIZE;
 			rnb[i].flags = brw_flags;
@@ -1878,7 +1878,7 @@ static int __init obdecho_init(void)
 	LCONSOLE_INFO("Echo OBD driver; http://www.lustre.org/\n");
-	LASSERT(PAGE_CACHE_SIZE % OBD_ECHO_BLOCK_SIZE == 0);
+	LASSERT(PAGE_SIZE % OBD_ECHO_BLOCK_SIZE == 0);
 	return echo_client_init();
diff --git a/drivers/staging/lustre/lustre/osc/lproc_osc.c b/drivers/staging/lustre/lustre/osc/lproc_osc.c
index 57c43c5..a3358c3 100644
--- a/drivers/staging/lustre/lustre/osc/lproc_osc.c
+++ b/drivers/staging/lustre/lustre/osc/lproc_osc.c
@@ -162,15 +162,15 @@ static ssize_t max_dirty_mb_store(struct kobject *kobj,
 	if (rc)
 		return rc;
 	if (pages_number <= 0 ||
-	    pages_number > OSC_MAX_DIRTY_MB_MAX << (20 - PAGE_CACHE_SHIFT) ||
+	    pages_number > OSC_MAX_DIRTY_MB_MAX << (20 - PAGE_SHIFT) ||
 	    pages_number > totalram_pages / 4) /* 1/4 of RAM */
 		return -ERANGE;
 	client_obd_list_lock(&cli->cl_loi_list_lock);
-	cli->cl_dirty_max = (u32)(pages_number << PAGE_CACHE_SHIFT);
+	cli->cl_dirty_max = (u32)(pages_number << PAGE_SHIFT);
 	osc_wake_cache_waiters(cli);
 	client_obd_list_unlock(&cli->cl_loi_list_lock);
@@ -182,7 +182,7 @@ static int osc_cached_mb_seq_show(struct seq_file *m, void *v)
 	struct obd_device *dev = m->private;
 	struct client_obd *cli = &dev->u.cli;
 	seq_printf(m,
 		   "used_mb: %d\n"
@@ -211,7 +211,7 @@ static ssize_t osc_cached_mb_seq_write(struct file *file,
 		return -EFAULT;
 	kernbuf[count] = 0;
 	buffer += lprocfs_find_named_value(kernbuf, "used_mb:", &count) -
 		  kernbuf;
@@ -569,12 +569,12 @@ static ssize_t max_pages_per_rpc_store(struct kobject *kobj,
 	/* if the max_pages is specified in bytes, convert to pages */
 	if (val >= ONE_MB_BRW_SIZE)
-		val >>= PAGE_CACHE_SHIFT;
+		val >>= PAGE_SHIFT;
-	chunk_mask = ~((1 << (cli->cl_chunkbits - PAGE_CACHE_SHIFT)) - 1);
+	chunk_mask = ~((1 << (cli->cl_chunkbits - PAGE_SHIFT)) - 1);
 	/* max_pages_per_rpc must be chunk aligned */
 	val = (val + ~chunk_mask) & chunk_mask;
-	if (val == 0 || val > ocd->ocd_brw_size >> PAGE_CACHE_SHIFT) {
+	if (val == 0 || val > ocd->ocd_brw_size >> PAGE_SHIFT) {
 		return -ERANGE;
diff --git a/drivers/staging/lustre/lustre/osc/osc_cache.c b/drivers/staging/lustre/lustre/osc/osc_cache.c
index 6336311..4e0a357 100644
--- a/drivers/staging/lustre/lustre/osc/osc_cache.c
+++ b/drivers/staging/lustre/lustre/osc/osc_cache.c
@@ -544,7 +544,7 @@ static int osc_extent_merge(const struct lu_env *env, struct osc_extent *cur,
 		return -ERANGE;
 	LASSERT(cur->oe_osclock == victim->oe_osclock);
-	ppc_bits = osc_cli(obj)->cl_chunkbits - PAGE_CACHE_SHIFT;
+	ppc_bits = osc_cli(obj)->cl_chunkbits - PAGE_SHIFT;
 	chunk_start = cur->oe_start >> ppc_bits;
 	chunk_end = cur->oe_end >> ppc_bits;
 	if (chunk_start != (victim->oe_end >> ppc_bits) + 1 &&
@@ -647,8 +647,8 @@ static struct osc_extent *osc_extent_find(const struct lu_env *env,
 	lock = cl_lock_at_pgoff(env, osc2cl(obj), index, NULL, 1, 0);
 	LASSERT(lock->cll_descr.cld_mode >= CLM_WRITE);
-	LASSERT(cli->cl_chunkbits >= PAGE_CACHE_SHIFT);
-	ppc_bits = cli->cl_chunkbits - PAGE_CACHE_SHIFT;
+	LASSERT(cli->cl_chunkbits >= PAGE_SHIFT);
+	ppc_bits = cli->cl_chunkbits - PAGE_SHIFT;
 	chunk_mask = ~((1 << ppc_bits) - 1);
 	chunksize = 1 << cli->cl_chunkbits;
 	chunk = index >> ppc_bits;
@@ -871,8 +871,8 @@ int osc_extent_finish(const struct lu_env *env, struct osc_extent *ext,
 	if (!sent) {
 		lost_grant = ext->oe_grants;
-	} else if (blocksize < PAGE_CACHE_SIZE &&
-		   last_count != PAGE_CACHE_SIZE) {
+	} else if (blocksize < PAGE_SIZE &&
+		   last_count != PAGE_SIZE) {
 		/* For short writes we shouldn't count parts of pages that
 		 * span a whole chunk on the OST side, or our accounting goes
 		 * wrong.  Should match the code in filter_grant_check.
@@ -884,7 +884,7 @@ int osc_extent_finish(const struct lu_env *env, struct osc_extent *ext,
 		if (end)
 			count += blocksize - end;
-		lost_grant = PAGE_CACHE_SIZE - count;
+		lost_grant = PAGE_SIZE - count;
 	if (ext->oe_grants > 0)
 		osc_free_grant(cli, nr_pages, lost_grant);
@@ -967,7 +967,7 @@ static int osc_extent_truncate(struct osc_extent *ext, pgoff_t trunc_index,
 	struct osc_async_page *oap;
 	struct osc_async_page *tmp;
 	int pages_in_chunk = 0;
-	int ppc_bits = cli->cl_chunkbits - PAGE_CACHE_SHIFT;
+	int ppc_bits = cli->cl_chunkbits - PAGE_SHIFT;
 	__u64 trunc_chunk = trunc_index >> ppc_bits;
 	int grants = 0;
 	int nr_pages = 0;
@@ -1125,7 +1125,7 @@ static int osc_extent_make_ready(const struct lu_env *env,
 	if (!(last->oap_async_flags & ASYNC_COUNT_STABLE)) {
 		last->oap_count = osc_refresh_count(env, last, OBD_BRW_WRITE);
 		LASSERT(last->oap_count > 0);
-		LASSERT(last->oap_page_off + last->oap_count <= PAGE_CACHE_SIZE);
+		LASSERT(last->oap_page_off + last->oap_count <= PAGE_SIZE);
 		last->oap_async_flags |= ASYNC_COUNT_STABLE;
@@ -1134,7 +1134,7 @@ static int osc_extent_make_ready(const struct lu_env *env,
 	list_for_each_entry(oap, &ext->oe_pages, oap_pending_item) {
 		if (!(oap->oap_async_flags & ASYNC_COUNT_STABLE)) {
-			oap->oap_count = PAGE_CACHE_SIZE - oap->oap_page_off;
+			oap->oap_count = PAGE_SIZE - oap->oap_page_off;
 			oap->oap_async_flags |= ASYNC_COUNT_STABLE;
@@ -1158,7 +1158,7 @@ static int osc_extent_expand(struct osc_extent *ext, pgoff_t index, int *grants)
 	struct osc_object *obj = ext->oe_obj;
 	struct client_obd *cli = osc_cli(obj);
 	struct osc_extent *next;
 	pgoff_t chunk = index >> ppc_bits;
 	pgoff_t end_chunk;
 	pgoff_t end_index;
@@ -1293,9 +1293,9 @@ static int osc_refresh_count(const struct lu_env *env,
 		return 0;
 	else if (cl_offset(obj, page->cp_index + 1) > kms)
 		/* catch sub-page write at end of file */
-		return kms % PAGE_CACHE_SIZE;
+		return kms % PAGE_SIZE;
 	else
-		return PAGE_CACHE_SIZE;
+		return PAGE_SIZE;
 static int osc_completion(const struct lu_env *env, struct osc_async_page *oap,
@@ -1376,10 +1376,10 @@ static void osc_consume_write_grant(struct client_obd *cli,
 	assert_spin_locked(&cli->cl_loi_list_lock.lock);
 	LASSERT(!(pga->flag & OBD_BRW_FROM_GRANT));
 	atomic_inc(&obd_dirty_pages);
-	cli->cl_dirty += PAGE_CACHE_SIZE;
+	cli->cl_dirty += PAGE_SIZE;
 	pga->flag |= OBD_BRW_FROM_GRANT;
 	CDEBUG(D_CACHE, "using %lu grant credits for brw %p page %p\n",
-	       PAGE_CACHE_SIZE, pga, pga->pg);
+	       PAGE_SIZE, pga, pga->pg);
 	osc_update_next_shrink(cli);
@@ -1396,11 +1396,11 @@ static void osc_release_write_grant(struct client_obd *cli,
 	pga->flag &= ~OBD_BRW_FROM_GRANT;
 	atomic_dec(&obd_dirty_pages);
-	cli->cl_dirty -= PAGE_CACHE_SIZE;
+	cli->cl_dirty -= PAGE_SIZE;
 	if (pga->flag & OBD_BRW_NOCACHE) {
 		pga->flag &= ~OBD_BRW_NOCACHE;
 		atomic_dec(&obd_dirty_transit_pages);
-		cli->cl_dirty_transit -= PAGE_CACHE_SIZE;
+		cli->cl_dirty_transit -= PAGE_SIZE;
@@ -1469,7 +1469,7 @@ static void osc_free_grant(struct client_obd *cli, unsigned int nr_pages,
 	atomic_sub(nr_pages, &obd_dirty_pages);
-	cli->cl_dirty -= nr_pages << PAGE_CACHE_SHIFT;
+	cli->cl_dirty -= nr_pages << PAGE_SHIFT;
 	cli->cl_lost_grant += lost_grant;
 	if (cli->cl_avail_grant < grant && cli->cl_lost_grant >= grant) {
 		/* borrow some grant from truncate to avoid the case that
@@ -1512,11 +1512,11 @@ static int osc_enter_cache_try(struct client_obd *cli,
 	if (rc < 0)
 		return 0;
-	if (cli->cl_dirty + PAGE_CACHE_SIZE <= cli->cl_dirty_max &&
+	if (cli->cl_dirty + PAGE_SIZE <= cli->cl_dirty_max &&
 	    atomic_read(&obd_dirty_pages) + 1 <= obd_max_dirty_pages) {
 		osc_consume_write_grant(cli, &oap->oap_brw_page);
 		if (transient) {
-			cli->cl_dirty_transit += PAGE_CACHE_SIZE;
+			cli->cl_dirty_transit += PAGE_SIZE;
 			atomic_inc(&obd_dirty_transit_pages);
 			oap->oap_brw_flags |= OBD_BRW_NOCACHE;
@@ -1562,7 +1562,7 @@ static int osc_enter_cache(const struct lu_env *env, struct client_obd *cli,
 	 * of queued writes and create a discontiguous rpc stream
 	if (OBD_FAIL_CHECK(OBD_FAIL_OSC_NO_GRANT) ||
-	    cli->cl_dirty_max < PAGE_CACHE_SIZE     ||
+	    cli->cl_dirty_max < PAGE_SIZE     ||
 	    cli->cl_ar.ar_force_sync || loi->loi_ar.ar_force_sync) {
 		rc = -EDQUOT;
 		goto out;
@@ -1632,7 +1632,7 @@ void osc_wake_cache_waiters(struct client_obd *cli)
 		ocw->ocw_rc = -EDQUOT;
 		/* we can't dirty more */
-		if ((cli->cl_dirty + PAGE_CACHE_SIZE > cli->cl_dirty_max) ||
+		if ((cli->cl_dirty + PAGE_SIZE > cli->cl_dirty_max) ||
 		    (atomic_read(&obd_dirty_pages) + 1 >
 		     obd_max_dirty_pages)) {
 			CDEBUG(D_CACHE, "no dirty room: dirty: %ld osc max %ld, sys max %d\n",
diff --git a/drivers/staging/lustre/lustre/osc/osc_page.c b/drivers/staging/lustre/lustre/osc/osc_page.c
index d720b1a..ce9ddd5 100644
--- a/drivers/staging/lustre/lustre/osc/osc_page.c
+++ b/drivers/staging/lustre/lustre/osc/osc_page.c
@@ -410,7 +410,7 @@ int osc_page_init(const struct lu_env *env, struct cl_object *obj,
 	int result;
 	opg->ops_from = 0;
-	opg->ops_to = PAGE_CACHE_SIZE;
+	opg->ops_to = PAGE_SIZE;
 	result = osc_prep_async_page(osc, opg, vmpage,
 				     cl_offset(obj, page->cp_index));
@@ -487,9 +487,9 @@ static atomic_t osc_lru_waiters = ATOMIC_INIT(0);
 /* LRU pages are freed in batch mode. OSC should at least free this
  * number of pages to avoid running out of LRU budget, and..
-static const int lru_shrink_min = 2 << (20 - PAGE_CACHE_SHIFT);  /* 2M */
+static const int lru_shrink_min = 2 << (20 - PAGE_SHIFT);  /* 2M */
 /* free this number at most otherwise it will take too long time to finish. */
-static const int lru_shrink_max = 32 << (20 - PAGE_CACHE_SHIFT); /* 32M */
+static const int lru_shrink_max = 32 << (20 - PAGE_SHIFT); /* 32M */
 /* Check if we can free LRU slots from this OSC. If there exists LRU waiters,
  * we should free slots aggressively. In this way, slots are freed in a steady
diff --git a/drivers/staging/lustre/lustre/osc/osc_request.c b/drivers/staging/lustre/lustre/osc/osc_request.c
index 74805f1..30526eb 100644
--- a/drivers/staging/lustre/lustre/osc/osc_request.c
+++ b/drivers/staging/lustre/lustre/osc/osc_request.c
@@ -826,7 +826,7 @@ static void osc_announce_cached(struct client_obd *cli, struct obdo *oa,
 		oa->o_undirty = 0;
 	} else {
 		long max_in_flight = (cli->cl_max_pages_per_rpc <<
-				      PAGE_CACHE_SHIFT)*
+				      PAGE_SHIFT)*
 				     (cli->cl_max_rpcs_in_flight + 1);
 		oa->o_undirty = max(cli->cl_dirty_max, max_in_flight);
@@ -909,11 +909,11 @@ static void osc_shrink_grant_local(struct client_obd *cli, struct obdo *oa)
 static int osc_shrink_grant(struct client_obd *cli)
 	__u64 target_bytes = (cli->cl_max_rpcs_in_flight + 1) *
-			     (cli->cl_max_pages_per_rpc << PAGE_CACHE_SHIFT);
+			     (cli->cl_max_pages_per_rpc << PAGE_SHIFT);
 	if (cli->cl_avail_grant <= target_bytes)
-		target_bytes = cli->cl_max_pages_per_rpc << PAGE_CACHE_SHIFT;
+		target_bytes = cli->cl_max_pages_per_rpc << PAGE_SHIFT;
 	return osc_shrink_grant_to_target(cli, target_bytes);
@@ -929,8 +929,8 @@ int osc_shrink_grant_to_target(struct client_obd *cli, __u64 target_bytes)
 	 * We don't want to shrink below a single RPC, as that will negatively
 	 * impact block allocation and long-term performance.
-	if (target_bytes < cli->cl_max_pages_per_rpc << PAGE_CACHE_SHIFT)
+	if (target_bytes < cli->cl_max_pages_per_rpc << PAGE_SHIFT)
 	if (target_bytes >= cli->cl_avail_grant) {
@@ -978,7 +978,7 @@ static int osc_should_shrink_grant(struct client_obd *client)
 		 * cli_brw_size(obd->u.cli.cl_import->imp_obd->obd_self_export)
 		 * Keep comment here so that it can be found by searching.
-		int brw_size = client->cl_max_pages_per_rpc << PAGE_CACHE_SHIFT;
+		int brw_size = client->cl_max_pages_per_rpc << PAGE_SHIFT;
 		if (client->cl_import->imp_state == LUSTRE_IMP_FULL &&
 		    client->cl_avail_grant > brw_size)
@@ -1052,7 +1052,7 @@ static void osc_init_grant(struct client_obd *cli, struct obd_connect_data *ocd)
 	/* determine the appropriate chunk size used by osc_extent. */
-	cli->cl_chunkbits = max_t(int, PAGE_CACHE_SHIFT, ocd->ocd_blocksize);
+	cli->cl_chunkbits = max_t(int, PAGE_SHIFT, ocd->ocd_blocksize);
 	CDEBUG(D_CACHE, "%s, setting cl_avail_grant: %ld cl_lost_grant: %ld chunk bits: %d\n",
@@ -1317,9 +1317,9 @@ static int osc_brw_prep_request(int cmd, struct client_obd *cli,
 		LASSERT(pg->count > 0);
 		/* make sure there is no gap in the middle of page array */
 		LASSERTF(page_count == 1 ||
-			 (ergo(i == 0, poff + pg->count == PAGE_CACHE_SIZE) &&
+			 (ergo(i == 0, poff + pg->count == PAGE_SIZE) &&
 			  ergo(i > 0 && i < page_count - 1,
-			       poff == 0 && pg->count == PAGE_CACHE_SIZE)   &&
+			       poff == 0 && pg->count == PAGE_SIZE)   &&
 			  ergo(i == page_count - 1, poff == 0)),
 			 "i: %d/%d pg: %p off: %llu, count: %u\n",
 			 i, page_count, pg, pg->off, pg->count);
@@ -1877,7 +1877,7 @@ int osc_build_rpc(const struct lu_env *env, struct client_obd *cli,
 						oap->oap_count;
 			else
 				LASSERT(oap->oap_page_off + oap->oap_count ==
-					PAGE_CACHE_SIZE);
+					PAGE_SIZE);
@@ -1993,7 +1993,7 @@ int osc_build_rpc(const struct lu_env *env, struct client_obd *cli,
 		tmp->oap_request = ptlrpc_request_addref(req);
-	starting_offset >>= PAGE_CACHE_SHIFT;
+	starting_offset >>= PAGE_SHIFT;
 	if (cmd == OBD_BRW_READ) {
 		cli->cl_r_in_flight++;
 		lprocfs_oh_tally_log2(&cli->cl_read_page_hist, page_count);
@@ -2790,12 +2790,12 @@ out:
 						CFS_PAGE_MASK;
 		if (OBD_OBJECT_EOF - fm_key->fiemap.fm_length <=
-		    fm_key->fiemap.fm_start + PAGE_CACHE_SIZE - 1)
+		    fm_key->fiemap.fm_start + PAGE_SIZE - 1)
 			policy.l_extent.end = OBD_OBJECT_EOF;
 		else
 			policy.l_extent.end = (fm_key->fiemap.fm_start +
 				fm_key->fiemap.fm_length +
-				PAGE_CACHE_SIZE - 1) & CFS_PAGE_MASK;
+				PAGE_SIZE - 1) & CFS_PAGE_MASK;
 		ostid_build_res_name(&fm_key->oa.o_oi, &res_id);
 		mode = ldlm_lock_match(exp->exp_obd->obd_namespace,
diff --git a/drivers/staging/lustre/lustre/ptlrpc/client.c b/drivers/staging/lustre/lustre/ptlrpc/client.c
index 1b7673e..cf3ac8e 100644
--- a/drivers/staging/lustre/lustre/ptlrpc/client.c
+++ b/drivers/staging/lustre/lustre/ptlrpc/client.c
@@ -174,12 +174,12 @@ void __ptlrpc_prep_bulk_page(struct ptlrpc_bulk_desc *desc,
 	LASSERT(page);
 	LASSERT(pageoffset >= 0);
 	LASSERT(len > 0);
-	LASSERT(pageoffset + len <= PAGE_CACHE_SIZE);
+	LASSERT(pageoffset + len <= PAGE_SIZE);
 	desc->bd_nob += len;
 	if (pin)
+		get_page(page);
 	ptlrpc_add_bulk_page(desc, page, pageoffset, len);
@@ -206,7 +206,7 @@ void __ptlrpc_free_bulk(struct ptlrpc_bulk_desc *desc, int unpin)
 	if (unpin) {
 		for (i = 0; i < desc->bd_iov_count; i++)
-			page_cache_release(desc->bd_iov[i].kiov_page);
+			put_page(desc->bd_iov[i].kiov_page);
 	kfree(desc);
diff --git a/drivers/staging/lustre/lustre/ptlrpc/import.c b/drivers/staging/lustre/lustre/ptlrpc/import.c
index b4eddf2..cd94fed 100644
--- a/drivers/staging/lustre/lustre/ptlrpc/import.c
+++ b/drivers/staging/lustre/lustre/ptlrpc/import.c
@@ -1092,7 +1092,7 @@ finish:
 		if (ocd->ocd_connect_flags & OBD_CONNECT_BRW_SIZE)
-				min(ocd->ocd_brw_size >> PAGE_CACHE_SHIFT,
+				min(ocd->ocd_brw_size >> PAGE_SHIFT,
 				    cli->cl_max_pages_per_rpc);
 		else if (imp->imp_connect_op == MDS_CONNECT ||
 			 imp->imp_connect_op == MGS_CONNECT)
diff --git a/drivers/staging/lustre/lustre/ptlrpc/lproc_ptlrpc.c b/drivers/staging/lustre/lustre/ptlrpc/lproc_ptlrpc.c
index cee04ef..c95a91c 100644
--- a/drivers/staging/lustre/lustre/ptlrpc/lproc_ptlrpc.c
+++ b/drivers/staging/lustre/lustre/ptlrpc/lproc_ptlrpc.c
@@ -308,7 +308,7 @@ ptlrpc_lprocfs_req_history_max_seq_write(struct file *file,
 	 * hose a kernel by allowing the request history to grow too
 	 * far.
-	bufpages = (svc->srv_buf_size + PAGE_CACHE_SIZE - 1) >> PAGE_CACHE_SHIFT;
+	bufpages = (svc->srv_buf_size + PAGE_SIZE - 1) >> PAGE_SHIFT;
 	if (val > totalram_pages / (2 * bufpages))
 		return -ERANGE;
@@ -1226,7 +1226,7 @@ int lprocfs_wr_import(struct file *file, const char __user *buffer,
 	const char prefix[] = "connection=";
 	const int prefix_len = sizeof(prefix) - 1;
-	if (count > PAGE_CACHE_SIZE - 1 || count <= prefix_len)
+	if (count > PAGE_SIZE - 1 || count <= prefix_len)
 		return -EINVAL;
 	kbuf = kzalloc(count + 1, GFP_NOFS);
diff --git a/drivers/staging/lustre/lustre/ptlrpc/recover.c b/drivers/staging/lustre/lustre/ptlrpc/recover.c
index 5f27d9c..30d9a16 100644
--- a/drivers/staging/lustre/lustre/ptlrpc/recover.c
+++ b/drivers/staging/lustre/lustre/ptlrpc/recover.c
@@ -195,7 +195,7 @@ int ptlrpc_resend(struct obd_import *imp)
 	list_for_each_entry_safe(req, next, &imp->imp_sending_list, rq_list) {
-		LASSERTF((long)req > PAGE_CACHE_SIZE && req != LP_POISON,
+		LASSERTF((long)req > PAGE_SIZE && req != LP_POISON,
 			 "req %p bad\n", req);
 		LASSERTF(req->rq_type != LI_POISON, "req %p freed\n", req);
 		if (!ptlrpc_no_resend(req))
diff --git a/drivers/staging/lustre/lustre/ptlrpc/sec_bulk.c b/drivers/staging/lustre/lustre/ptlrpc/sec_bulk.c
index 72d5b9b..d3872b8 100644
--- a/drivers/staging/lustre/lustre/ptlrpc/sec_bulk.c
+++ b/drivers/staging/lustre/lustre/ptlrpc/sec_bulk.c
@@ -58,7 +58,7 @@
  * bulk encryption page pools	   *
-#define POINTERS_PER_PAGE	(PAGE_CACHE_SIZE / sizeof(void *))
+#define POINTERS_PER_PAGE	(PAGE_SIZE / sizeof(void *))
 #define PAGES_PER_POOL		(POINTERS_PER_PAGE)
 #define IDLE_IDX_MAX	 (100)
diff --git a/drivers/usb/gadget/function/f_fs.c b/drivers/usb/gadget/function/f_fs.c
index 8cfce10..e21ca2bd 100644
--- a/drivers/usb/gadget/function/f_fs.c
+++ b/drivers/usb/gadget/function/f_fs.c
@@ -1147,8 +1147,8 @@ static int ffs_sb_fill(struct super_block *sb, void *_data, int silent)
 	ffs->sb              = sb;
 	data->ffs_data       = NULL;
 	sb->s_fs_info        = ffs;
-	sb->s_blocksize      = PAGE_CACHE_SIZE;
-	sb->s_blocksize_bits = PAGE_CACHE_SHIFT;
+	sb->s_blocksize      = PAGE_SIZE;
+	sb->s_blocksize_bits = PAGE_SHIFT;
 	sb->s_magic          = FUNCTIONFS_MAGIC;
 	sb->s_op             = &ffs_sb_operations;
 	sb->s_time_gran      = 1;
diff --git a/drivers/usb/gadget/legacy/inode.c b/drivers/usb/gadget/legacy/inode.c
index 5cdaf01..e64479f 100644
--- a/drivers/usb/gadget/legacy/inode.c
+++ b/drivers/usb/gadget/legacy/inode.c
@@ -1954,8 +1954,8 @@ gadgetfs_fill_super (struct super_block *sb, void *opts, int silent)
 		return -ENODEV;
 	/* superblock */
 	sb->s_magic = GADGETFS_MAGIC;
 	sb->s_op = &gadget_fs_operations;
diff --git a/drivers/usb/storage/scsiglue.c b/drivers/usb/storage/scsiglue.c
index dba5136..9090186 100644
--- a/drivers/usb/storage/scsiglue.c
+++ b/drivers/usb/storage/scsiglue.c
@@ -123,7 +123,7 @@ static int slave_configure(struct scsi_device *sdev)
 		unsigned int max_sectors = 64;
 		if (us->fflags & US_FL_MAX_SECTORS_MIN)
-			max_sectors = PAGE_CACHE_SIZE >> 9;
+			max_sectors = PAGE_SIZE >> 9;
 		if (queue_max_hw_sectors(sdev->request_queue) > max_sectors)
 			blk_queue_max_hw_sectors(sdev->request_queue,
 					      max_sectors);
diff --git a/drivers/video/fbdev/pvr2fb.c b/drivers/video/fbdev/pvr2fb.c
index 71a923e..3b1ca44 100644
--- a/drivers/video/fbdev/pvr2fb.c
+++ b/drivers/video/fbdev/pvr2fb.c
@@ -735,7 +735,7 @@ out:
 out_unmap:
 	for (i = 0; i < nr_pages; i++)
-		page_cache_release(pages[i]);
+		put_page(pages[i]);
 	kfree(pages);
diff --git a/fs/9p/vfs_addr.c b/fs/9p/vfs_addr.c
index e9e0437..ac9225e 100644
--- a/fs/9p/vfs_addr.c
+++ b/fs/9p/vfs_addr.c
@@ -153,7 +153,7 @@ static void v9fs_invalidate_page(struct page *page, unsigned int offset,
 	 * If called with zero offset, we should release
 	 * the private state assocated with the page
 		v9fs_fscache_invalidate_page(page);
@@ -166,10 +166,10 @@ static int v9fs_vfs_writepage_locked(struct page *page)
 	struct bio_vec bvec;
 	int err, len;
-	if (page->index == size >> PAGE_CACHE_SHIFT)
-		len = size & ~PAGE_CACHE_MASK;
+	if (page->index == size >> PAGE_SHIFT)
+		len = size & ~PAGE_MASK;
 	else
-		len = PAGE_CACHE_SIZE;
+		len = PAGE_SIZE;
 	bvec.bv_page = page;
 	bvec.bv_offset = 0;
@@ -271,7 +271,7 @@ static int v9fs_write_begin(struct file *filp, struct address_space *mapping,
 	int retval = 0;
 	struct page *page;
 	struct v9fs_inode *v9inode;
 	struct inode *inode = mapping->host;
@@ -288,11 +288,11 @@ start:
 	if (PageUptodate(page))
 		goto out;
-	if (len == PAGE_CACHE_SIZE)
+	if (len == PAGE_SIZE)
 		goto out;
 	retval = v9fs_fid_readpage(v9inode->writeback_fid, page);
-	page_cache_release(page);
+	put_page(page);
 	if (!retval)
 		goto start;
 out:
@@ -313,7 +313,7 @@ static int v9fs_write_end(struct file *filp, struct address_space *mapping,
 		 * zero out the rest of the area
 		zero_user(page, from + copied, len - copied);
 		flush_dcache_page(page);
@@ -331,7 +331,7 @@ static int v9fs_write_end(struct file *filp, struct address_space *mapping,
 	set_page_dirty(page);
 	unlock_page(page);
+	put_page(page);
 	return copied;
diff --git a/fs/9p/vfs_file.c b/fs/9p/vfs_file.c
index eadc894..b84c291 100644
--- a/fs/9p/vfs_file.c
+++ b/fs/9p/vfs_file.c
@@ -421,8 +421,8 @@ v9fs_file_write_iter(struct kiocb *iocb, struct iov_iter *from)
 		struct inode *inode = file_inode(file);
 		loff_t i_size;
 		unsigned long pg_start, pg_end;
-		pg_start = origin >> PAGE_CACHE_SHIFT;
-		pg_end = (origin + retval - 1) >> PAGE_CACHE_SHIFT;
+		pg_start = origin >> PAGE_SHIFT;
+		pg_end = (origin + retval - 1) >> PAGE_SHIFT;
 		if (inode->i_mapping && inode->i_mapping->nrpages)
 			invalidate_inode_pages2_range(inode->i_mapping,
 						      pg_start, pg_end);
diff --git a/fs/9p/vfs_super.c b/fs/9p/vfs_super.c
index bf495ce..de3ed86 100644
--- a/fs/9p/vfs_super.c
+++ b/fs/9p/vfs_super.c
@@ -87,7 +87,7 @@ v9fs_fill_super(struct super_block *sb, struct v9fs_session_info *v9ses,
 		sb->s_op = &v9fs_super_ops;
 	sb->s_bdi = &v9ses->bdi;
 	if (v9ses->cache)
-		sb->s_bdi->ra_pages = (VM_MAX_READAHEAD * 1024)/PAGE_CACHE_SIZE;
+		sb->s_bdi->ra_pages = (VM_MAX_READAHEAD * 1024)/PAGE_SIZE;
 	sb->s_flags |= MS_ACTIVE | MS_DIRSYNC | MS_NOATIME;
 	if (!v9ses->cache)
diff --git a/fs/affs/file.c b/fs/affs/file.c
index 22fc7c8..0cde550 100644
--- a/fs/affs/file.c
+++ b/fs/affs/file.c
@@ -510,9 +510,9 @@ affs_do_readpage_ofs(struct page *page, unsigned to)
 	pr_debug("%s(%lu, %ld, 0, %d)\n", __func__, inode->i_ino,
 		 page->index, to);
-	BUG_ON(to > PAGE_CACHE_SIZE);
+	BUG_ON(to > PAGE_SIZE);
 	bsize = AFFS_SB(sb)->s_data_blksize;
-	tmp = page->index << PAGE_CACHE_SHIFT;
+	tmp = page->index << PAGE_SHIFT;
 	bidx = tmp / bsize;
 	boff = tmp % bsize;
@@ -613,10 +613,10 @@ affs_readpage_ofs(struct file *file, struct page *page)
 	int err;
 	pr_debug("%s(%lu, %ld)\n", __func__, inode->i_ino, page->index);
-	if (((page->index + 1) << PAGE_CACHE_SHIFT) > inode->i_size) {
-		to = inode->i_size & ~PAGE_CACHE_MASK;
-		memset(page_address(page) + to, 0, PAGE_CACHE_SIZE - to);
+	to = PAGE_SIZE;
+	if (((page->index + 1) << PAGE_SHIFT) > inode->i_size) {
+		to = inode->i_size & ~PAGE_MASK;
+		memset(page_address(page) + to, 0, PAGE_SIZE - to);
 	err = affs_do_readpage_ofs(page, to);
@@ -646,7 +646,7 @@ static int affs_write_begin_ofs(struct file *file, struct address_space *mapping
 			return err;
-	index = pos >> PAGE_CACHE_SHIFT;
+	index = pos >> PAGE_SHIFT;
 	if (!page)
 		return -ENOMEM;
@@ -656,10 +656,10 @@ static int affs_write_begin_ofs(struct file *file, struct address_space *mapping
 		return 0;
 	/* XXX: inefficient but safe in the face of short writes */
-	err = affs_do_readpage_ofs(page, PAGE_CACHE_SIZE);
+	err = affs_do_readpage_ofs(page, PAGE_SIZE);
 	if (err) {
 		unlock_page(page);
+		put_page(page);
 	return err;
@@ -677,7 +677,7 @@ static int affs_write_end_ofs(struct file *file, struct address_space *mapping,
 	u32 tmp;
 	int written;
-	from = pos & (PAGE_CACHE_SIZE - 1);
+	from = pos & (PAGE_SIZE - 1);
 	to = pos + len;
 	 * XXX: not sure if this can handle short copies (len < copied), but
@@ -692,7 +692,7 @@ static int affs_write_end_ofs(struct file *file, struct address_space *mapping,
 	bh = NULL;
 	written = 0;
-	tmp = (page->index << PAGE_CACHE_SHIFT) + from;
+	tmp = (page->index << PAGE_SHIFT) + from;
 	bidx = tmp / bsize;
 	boff = tmp % bsize;
 	if (boff) {
@@ -788,13 +788,13 @@ static int affs_write_end_ofs(struct file *file, struct address_space *mapping,
 done:
 	affs_brelse(bh);
 	if (tmp > inode->i_size)
 		inode->i_size = AFFS_I(inode)->mmu_private = tmp;
 err_first_bh:
 	unlock_page(page);
+	put_page(page);
 	return written;
diff --git a/fs/afs/dir.c b/fs/afs/dir.c
index e10e1778..5fda2bc 100644
--- a/fs/afs/dir.c
+++ b/fs/afs/dir.c
@@ -181,7 +181,7 @@ error:
 static inline void afs_dir_put_page(struct page *page)
 	kunmap(page);
+	put_page(page);
diff --git a/fs/afs/file.c b/fs/afs/file.c
index 999bc3c..6344aee 100644
--- a/fs/afs/file.c
+++ b/fs/afs/file.c
@@ -164,7 +164,7 @@ int afs_page_filler(void *data, struct page *page)
 		_debug("cache said ENOBUFS");
 	default:
 	go_on:
-		offset = page->index << PAGE_CACHE_SHIFT;
+		offset = page->index << PAGE_SHIFT;
 		len = min_t(size_t, i_size_read(inode) - offset, PAGE_SIZE);
 		/* read the contents of the file from the server into the
@@ -319,7 +319,7 @@ static void afs_invalidatepage(struct page *page, unsigned int offset,
 	BUG_ON(!PageLocked(page));
 	/* we clean up only if the entire page is being invalidated */
 #ifdef CONFIG_AFS_FSCACHE
 		if (PageFsCache(page)) {
 			struct afs_vnode *vnode = AFS_FS_I(page->mapping->host);
diff --git a/fs/afs/mntpt.c b/fs/afs/mntpt.c
index ccd0b21..81dd075 100644
--- a/fs/afs/mntpt.c
+++ b/fs/afs/mntpt.c
@@ -93,7 +93,7 @@ int afs_mntpt_check_symlink(struct afs_vnode *vnode, struct key *key)
 	kunmap(page);
 out_free:
+	put_page(page);
 out:
 	_leave(" = %d", ret);
 	return ret;
@@ -189,7 +189,7 @@ static struct vfsmount *afs_mntpt_do_automount(struct dentry *mntpt)
 		buf = kmap_atomic(page);
 		memcpy(devname, buf, size);
 		kunmap_atomic(buf);
+		put_page(page);
 		page = NULL;
@@ -211,7 +211,7 @@ static struct vfsmount *afs_mntpt_do_automount(struct dentry *mntpt)
 	return mnt;
 error:
+	put_page(page);
 error_no_page:
 	free_page((unsigned long) options);
 error_no_options:
diff --git a/fs/afs/super.c b/fs/afs/super.c
index 81afefe..fbdb022 100644
--- a/fs/afs/super.c
+++ b/fs/afs/super.c
@@ -315,8 +315,8 @@ static int afs_fill_super(struct super_block *sb,
 	_enter("");
 	/* fill in the superblock */
 	sb->s_magic		= AFS_FS_MAGIC;
 	sb->s_op		= &afs_super_ops;
 	sb->s_bdi		= &as->volume->bdi;
diff --git a/fs/afs/write.c b/fs/afs/write.c
index dfef94f..65de439 100644
--- a/fs/afs/write.c
+++ b/fs/afs/write.c
@@ -93,10 +93,10 @@ static int afs_fill_page(struct afs_vnode *vnode, struct key *key,
 	_enter(",,%llu", (unsigned long long)pos);
 	i_size = i_size_read(&vnode->vfs_inode);
-	if (pos + PAGE_CACHE_SIZE > i_size)
+	if (pos + PAGE_SIZE > i_size)
 		len = i_size - pos;
 	else
+		len = PAGE_SIZE;
 	ret = afs_vnode_fetch_data(vnode, key, pos, len, page);
 	if (ret < 0) {
@@ -123,9 +123,9 @@ int afs_write_begin(struct file *file, struct address_space *mapping,
 	struct afs_vnode *vnode = AFS_FS_I(file_inode(file));
 	struct page *page;
 	struct key *key = file->private_data;
 	unsigned to = from + len;
 	int ret;
 	_enter("{%x:%u},{%lx},%u,%u",
@@ -151,8 +151,8 @@ int afs_write_begin(struct file *file, struct address_space *mapping,
 	*pagep = page;
 	/* page won't leak in error case: it eventually gets cleaned off LRU */
-	if (!PageUptodate(page) && len != PAGE_CACHE_SIZE) {
-		ret = afs_fill_page(vnode, key, index << PAGE_CACHE_SHIFT, page);
+	if (!PageUptodate(page) && len != PAGE_SIZE) {
+		ret = afs_fill_page(vnode, key, index << PAGE_SHIFT, page);
 		if (ret < 0) {
 			kfree(candidate);
 			_leave(" = %d [prep]", ret);
@@ -266,7 +266,7 @@ int afs_write_end(struct file *file, struct address_space *mapping,
 	if (PageDirty(page))
 		_debug("dirtied");
 	unlock_page(page);
+	put_page(page);
 	return copied;
@@ -480,7 +480,7 @@ static int afs_writepages_region(struct address_space *mapping,
 		if (page->index > end) {
 			*_next = index;
+			put_page(page);
 			_leave(" = 0 [%lx]", *_next);
 			return 0;
@@ -494,7 +494,7 @@ static int afs_writepages_region(struct address_space *mapping,
 		if (page->mapping != mapping) {
 			unlock_page(page);
+			put_page(page);
 			continue;
@@ -515,7 +515,7 @@ static int afs_writepages_region(struct address_space *mapping,
 		ret = afs_write_back_from_locked_page(wb, page);
 		unlock_page(page);
+		put_page(page);
 		if (ret < 0) {
 			return ret;
@@ -551,13 +551,13 @@ int afs_writepages(struct address_space *mapping,
 						    &next);
 		mapping->writeback_index = next;
 	} else if (wbc->range_start == 0 && wbc->range_end == LLONG_MAX) {
-		end = (pgoff_t)(LLONG_MAX >> PAGE_CACHE_SHIFT);
+		end = (pgoff_t)(LLONG_MAX >> PAGE_SHIFT);
 		ret = afs_writepages_region(mapping, wbc, 0, end, &next);
 		if (wbc->nr_to_write > 0)
 	} else {
-		start = wbc->range_start >> PAGE_CACHE_SHIFT;
-		end = wbc->range_end >> PAGE_CACHE_SHIFT;
+		start = wbc->range_start >> PAGE_SHIFT;
+		end = wbc->range_end >> PAGE_SHIFT;
 		ret = afs_writepages_region(mapping, wbc, start, end, &next);
diff --git a/fs/binfmt_elf.c b/fs/binfmt_elf.c
index 7d914c6..81381cc 100644
--- a/fs/binfmt_elf.c
+++ b/fs/binfmt_elf.c
@@ -2292,7 +2292,7 @@ static int elf_core_dump(struct coredump_params *cprm)
 				void *kaddr = kmap(page);
 				stop = !dump_emit(cprm, kaddr, PAGE_SIZE);
 				kunmap(page);
+				put_page(page);
 			} else
 				stop = !dump_skip(cprm, PAGE_SIZE);
 			if (stop)
diff --git a/fs/binfmt_elf_fdpic.c b/fs/binfmt_elf_fdpic.c
index b1adb92..083ea2bc 100644
--- a/fs/binfmt_elf_fdpic.c
+++ b/fs/binfmt_elf_fdpic.c
@@ -1533,7 +1533,7 @@ static bool elf_fdpic_dump_segments(struct coredump_params *cprm)
 				res = dump_emit(cprm, kaddr, PAGE_SIZE);
 				kunmap(page);
+				put_page(page);
 			} else {
 				res = dump_skip(cprm, PAGE_SIZE);
diff --git a/fs/block_dev.c b/fs/block_dev.c
index 3172c4e..20a2c02 100644
--- a/fs/block_dev.c
+++ b/fs/block_dev.c
@@ -331,7 +331,7 @@ static int blkdev_write_end(struct file *file, struct address_space *mapping,
 	ret = block_write_end(file, mapping, pos, len, copied, page, fsdata);
 	unlock_page(page);
+	put_page(page);
 	return ret;
@@ -1149,7 +1149,7 @@ void bd_set_size(struct block_device *bdev, loff_t size)
 	inode_lock(bdev->bd_inode);
 	i_size_write(bdev->bd_inode, size);
 	inode_unlock(bdev->bd_inode);
-	while (bsize < PAGE_CACHE_SIZE) {
+	while (bsize < PAGE_SIZE) {
 		if (size & bsize)
 			break;
 		bsize <<= 1;
diff --git a/fs/btrfs/check-integrity.c b/fs/btrfs/check-integrity.c
index e34a71b..866789e 100644
--- a/fs/btrfs/check-integrity.c
+++ b/fs/btrfs/check-integrity.c
@@ -757,7 +757,7 @@ static int btrfsic_process_superblock(struct btrfsic_state *state,
 			BUG_ON(NULL == l);
 			ret = btrfsic_read_block(state, &tmp_next_block_ctx);
-			if (ret < (int)PAGE_CACHE_SIZE) {
+			if (ret < (int)PAGE_SIZE) {
 				printk(KERN_INFO
 				       "btrfsic: read @logical %llu failed!\n",
 				       tmp_next_block_ctx.start);
@@ -1231,15 +1231,15 @@ static void btrfsic_read_from_block_data(
 	size_t offset_in_page;
 	char *kaddr;
 	char *dst = (char *)dstv;
-	size_t start_offset = block_ctx->start & ((u64)PAGE_CACHE_SIZE - 1);
-	unsigned long i = (start_offset + offset) >> PAGE_CACHE_SHIFT;
+	size_t start_offset = block_ctx->start & ((u64)PAGE_SIZE - 1);
+	unsigned long i = (start_offset + offset) >> PAGE_SHIFT;
 	WARN_ON(offset + len > block_ctx->len);
-	offset_in_page = (start_offset + offset) & (PAGE_CACHE_SIZE - 1);
+	offset_in_page = (start_offset + offset) & (PAGE_SIZE - 1);
 	while (len > 0) {
-		cur = min(len, ((size_t)PAGE_CACHE_SIZE - offset_in_page));
-		BUG_ON(i >= DIV_ROUND_UP(block_ctx->len, PAGE_CACHE_SIZE));
+		cur = min(len, ((size_t)PAGE_SIZE - offset_in_page));
+		BUG_ON(i >= DIV_ROUND_UP(block_ctx->len, PAGE_SIZE));
 		kaddr = block_ctx->datav[i];
 		memcpy(dst, kaddr + offset_in_page, cur);
@@ -1605,8 +1605,8 @@ static void btrfsic_release_block_ctx(struct btrfsic_block_data_ctx *block_ctx)
 		BUG_ON(!block_ctx->datav);
 		BUG_ON(!block_ctx->pagev);
-		num_pages = (block_ctx->len + (u64)PAGE_CACHE_SIZE - 1) >>
-			    PAGE_CACHE_SHIFT;
+		num_pages = (block_ctx->len + (u64)PAGE_SIZE - 1) >>
+			    PAGE_SHIFT;
 		while (num_pages > 0) {
 			num_pages--;
 			if (block_ctx->datav[num_pages]) {
@@ -1637,15 +1637,15 @@ static int btrfsic_read_block(struct btrfsic_state *state,
 	BUG_ON(block_ctx->datav);
 	BUG_ON(block_ctx->pagev);
 	BUG_ON(block_ctx->mem_to_free);
-	if (block_ctx->dev_bytenr & ((u64)PAGE_CACHE_SIZE - 1)) {
+	if (block_ctx->dev_bytenr & ((u64)PAGE_SIZE - 1)) {
 		printk(KERN_INFO
 		       "btrfsic: read_block() with unaligned bytenr %llu\n",
 		       block_ctx->dev_bytenr);
 		return -1;
-		    PAGE_CACHE_SHIFT;
+		    PAGE_SHIFT;
 	block_ctx->mem_to_free = kzalloc((sizeof(*block_ctx->datav) +
 					  sizeof(*block_ctx->pagev)) *
 					 num_pages, GFP_NOFS);
@@ -1676,8 +1676,8 @@ static int btrfsic_read_block(struct btrfsic_state *state,
 		for (j = i; j < num_pages; j++) {
 			ret = bio_add_page(bio, block_ctx->pagev[j],
-					   PAGE_CACHE_SIZE, 0);
-			if (PAGE_CACHE_SIZE != ret)
+					   PAGE_SIZE, 0);
+			if (PAGE_SIZE != ret)
 				break;
 		if (j == i) {
@@ -1693,7 +1693,7 @@ static int btrfsic_read_block(struct btrfsic_state *state,
 			return -1;
 		bio_put(bio);
-		dev_bytenr += (j - i) * PAGE_CACHE_SIZE;
+		dev_bytenr += (j - i) * PAGE_SIZE;
 		i = j;
 	for (i = 0; i < num_pages; i++) {
@@ -1769,9 +1769,9 @@ static int btrfsic_test_for_metadata(struct btrfsic_state *state,
 	u32 crc = ~(u32)0;
 	unsigned int i;
-	if (num_pages * PAGE_CACHE_SIZE < state->metablock_size)
+	if (num_pages * PAGE_SIZE < state->metablock_size)
 		return 1; /* not metadata */
-	num_pages = state->metablock_size >> PAGE_CACHE_SHIFT;
+	num_pages = state->metablock_size >> PAGE_SHIFT;
 	h = (struct btrfs_header *)datav[0];
 	if (memcmp(h->fsid, state->root->fs_info->fsid, BTRFS_UUID_SIZE))
@@ -1779,8 +1779,8 @@ static int btrfsic_test_for_metadata(struct btrfsic_state *state,
 		u8 *data = i ? datav[i] : (datav[i] + BTRFS_CSUM_SIZE);
-		size_t sublen = i ? PAGE_CACHE_SIZE :
-				    (PAGE_CACHE_SIZE - BTRFS_CSUM_SIZE);
+		size_t sublen = i ? PAGE_SIZE :
+				    (PAGE_SIZE - BTRFS_CSUM_SIZE);
 		crc = btrfs_crc32c(crc, data, sublen);
@@ -1826,14 +1826,14 @@ again:
 		if (block->is_superblock) {
 			bytenr = btrfs_super_bytenr((struct btrfs_super_block *)
 						    mapped_datav[0]);
 			    BTRFS_SUPER_INFO_SIZE) {
 				printk(KERN_INFO
 				       "btrfsic: cannot work with too short bios!\n");
 				return;
 			is_metadata = 1;
-			BUG_ON(BTRFS_SUPER_INFO_SIZE & (PAGE_CACHE_SIZE - 1));
+			BUG_ON(BTRFS_SUPER_INFO_SIZE & (PAGE_SIZE - 1));
 			processed_len = BTRFS_SUPER_INFO_SIZE;
 			if (state->print_mask &
 			    BTRFSIC_PRINT_MASK_TREE_BEFORE_SB_WRITE) {
@@ -1844,7 +1844,7 @@ again:
 		if (is_metadata) {
 			if (!block->is_superblock) {
 				    state->metablock_size) {
 					printk(KERN_INFO
@@ -1880,7 +1880,7 @@ again:
 			block->logical_bytenr = bytenr;
 		} else {
 			    state->datablock_size) {
 				printk(KERN_INFO
@@ -2013,7 +2013,7 @@ again:
 			block->is_metadata = 1;
-				BUG_ON(PAGE_CACHE_SIZE !=
+				BUG_ON(PAGE_SIZE !=
 				       BTRFS_SUPER_INFO_SIZE);
 				ret = btrfsic_process_written_superblock(
 						state,
@@ -2172,8 +2172,8 @@ again:
 continue_loop:
 	BUG_ON(!processed_len);
 	dev_bytenr += processed_len;
-	mapped_datav += processed_len >> PAGE_CACHE_SHIFT;
-	num_pages -= processed_len >> PAGE_CACHE_SHIFT;
+	mapped_datav += processed_len >> PAGE_SHIFT;
+	num_pages -= processed_len >> PAGE_SHIFT;
 	goto again;
@@ -2954,7 +2954,7 @@ static void __btrfsic_submit_bio(int rw, struct bio *bio)
 			goto leave;
 		cur_bytenr = dev_bytenr;
 		for (i = 0; i < bio->bi_vcnt; i++) {
-			BUG_ON(bio->bi_io_vec[i].bv_len != PAGE_CACHE_SIZE);
+			BUG_ON(bio->bi_io_vec[i].bv_len != PAGE_SIZE);
 			mapped_datav[i] = kmap(bio->bi_io_vec[i].bv_page);
 			if (!mapped_datav[i]) {
 				while (i > 0) {
@@ -3037,16 +3037,16 @@ int btrfsic_mount(struct btrfs_root *root,
 	struct list_head *dev_head = &fs_devices->devices;
 	struct btrfs_device *device;
-	if (root->nodesize & ((u64)PAGE_CACHE_SIZE - 1)) {
+	if (root->nodesize & ((u64)PAGE_SIZE - 1)) {
 		printk(KERN_INFO
 		       "btrfsic: cannot handle nodesize %d not being a multiple of PAGE_CACHE_SIZE %ld!\n",
-		       root->nodesize, PAGE_CACHE_SIZE);
+		       root->nodesize, PAGE_SIZE);
 		return -1;
-	if (root->sectorsize & ((u64)PAGE_CACHE_SIZE - 1)) {
+	if (root->sectorsize & ((u64)PAGE_SIZE - 1)) {
 		printk(KERN_INFO
 		       "btrfsic: cannot handle sectorsize %d not being a multiple of PAGE_CACHE_SIZE %ld!\n",
-		       root->sectorsize, PAGE_CACHE_SIZE);
+		       root->sectorsize, PAGE_SIZE);
 		return -1;
 	state = kzalloc(sizeof(*state), GFP_KERNEL | __GFP_NOWARN | __GFP_REPEAT);
diff --git a/fs/btrfs/compression.c b/fs/btrfs/compression.c
index 3346cd8..ff61a41 100644
--- a/fs/btrfs/compression.c
+++ b/fs/btrfs/compression.c
@@ -119,7 +119,7 @@ static int check_compressed_csum(struct inode *inode,
 		csum = ~(u32)0;
 		kaddr = kmap_atomic(page);
-		csum = btrfs_csum_data(kaddr, csum, PAGE_CACHE_SIZE);
+		csum = btrfs_csum_data(kaddr, csum, PAGE_SIZE);
 		btrfs_csum_final(csum, (char *)&csum);
 		kunmap_atomic(kaddr);
@@ -190,7 +190,7 @@ csum_failed:
 	for (index = 0; index < cb->nr_pages; index++) {
 		page = cb->compressed_pages[index];
 		page->mapping = NULL;
+		put_page(page);
 	/* do io completion on the original bio */
@@ -224,8 +224,8 @@ out:
 static noinline void end_compressed_writeback(struct inode *inode,
 					      const struct compressed_bio *cb)
-	unsigned long index = cb->start >> PAGE_CACHE_SHIFT;
-	unsigned long end_index = (cb->start + cb->len - 1) >> PAGE_CACHE_SHIFT;
+	unsigned long index = cb->start >> PAGE_SHIFT;
+	unsigned long end_index = (cb->start + cb->len - 1) >> PAGE_SHIFT;
 	struct page *pages[16];
 	unsigned long nr_pages = end_index - index + 1;
 	int i;
@@ -247,7 +247,7 @@ static noinline void end_compressed_writeback(struct inode *inode,
 			if (cb->errors)
 				SetPageError(pages[i]);
 			end_page_writeback(pages[i]);
 		nr_pages -= ret;
 		index += ret;
@@ -304,7 +304,7 @@ static void end_compressed_bio_write(struct bio *bio)
+		put_page(page);
 	/* finally free the cb struct */
@@ -341,7 +341,7 @@ int btrfs_submit_compressed_write(struct inode *inode, u64 start,
 	int ret;
 	int skip_sum = BTRFS_I(inode)->flags & BTRFS_INODE_NODATASUM;
-	WARN_ON(start & ((u64)PAGE_CACHE_SIZE - 1));
+	WARN_ON(start & ((u64)PAGE_SIZE - 1));
 	cb = kmalloc(compressed_bio_size(root, compressed_len), GFP_NOFS);
 	if (!cb)
 		return -ENOMEM;
@@ -374,14 +374,14 @@ int btrfs_submit_compressed_write(struct inode *inode, u64 start,
 		page->mapping = inode->i_mapping;
 		if (bio->bi_iter.bi_size)
 			ret = io_tree->ops->merge_bio_hook(WRITE, page, 0,
-							   PAGE_CACHE_SIZE,
+							   PAGE_SIZE,
 							   bio, 0);
 		else
 			ret = 0;
-		if (ret || bio_add_page(bio, page, PAGE_CACHE_SIZE, 0) <
+		if (ret || bio_add_page(bio, page, PAGE_SIZE, 0) <
+		    PAGE_SIZE) {
 			bio_get(bio);
@@ -410,15 +410,15 @@ int btrfs_submit_compressed_write(struct inode *inode, u64 start,
 			BUG_ON(!bio);
 			bio->bi_private = cb;
 			bio->bi_end_io = end_compressed_bio_write;
-			bio_add_page(bio, page, PAGE_CACHE_SIZE, 0);
+			bio_add_page(bio, page, PAGE_SIZE, 0);
-		if (bytes_left < PAGE_CACHE_SIZE) {
+		if (bytes_left < PAGE_SIZE) {
 			btrfs_info(BTRFS_I(inode)->root->fs_info,
 					"bytes left %lu compress len %lu nr %lu",
 			       bytes_left, cb->compressed_len, cb->nr_pages);
-		bytes_left -= PAGE_CACHE_SIZE;
-		first_byte += PAGE_CACHE_SIZE;
+		bytes_left -= PAGE_SIZE;
+		first_byte += PAGE_SIZE;
 		cond_resched();
 	bio_get(bio);
@@ -457,17 +457,17 @@ static noinline int add_ra_bio_pages(struct inode *inode,
 	int misses = 0;
 	page = cb->orig_bio->bi_io_vec[cb->orig_bio->bi_vcnt - 1].bv_page;
-	last_offset = (page_offset(page) + PAGE_CACHE_SIZE);
+	last_offset = (page_offset(page) + PAGE_SIZE);
 	em_tree = &BTRFS_I(inode)->extent_tree;
 	tree = &BTRFS_I(inode)->io_tree;
 	if (isize == 0)
 		return 0;
-	end_index = (i_size_read(inode) - 1) >> PAGE_CACHE_SHIFT;
+	end_index = (i_size_read(inode) - 1) >> PAGE_SHIFT;
 	while (last_offset < compressed_end) {
-		pg_index = last_offset >> PAGE_CACHE_SHIFT;
+		pg_index = last_offset >> PAGE_SHIFT;
 		if (pg_index > end_index)
 			break;
@@ -488,11 +488,11 @@ static noinline int add_ra_bio_pages(struct inode *inode,
 			break;
 		if (add_to_page_cache_lru(page, mapping, pg_index, GFP_NOFS)) {
+			put_page(page);
 			goto next;
-		end = last_offset + PAGE_CACHE_SIZE - 1;
+		end = last_offset + PAGE_SIZE - 1;
 		 * at this point, we have a locked page in the page cache
 		 * for these bytes in the file.  But, we have to make
@@ -502,27 +502,27 @@ static noinline int add_ra_bio_pages(struct inode *inode,
 		lock_extent(tree, last_offset, end);
 		read_lock(&em_tree->lock);
 		em = lookup_extent_mapping(em_tree, last_offset,
-					   PAGE_CACHE_SIZE);
+					   PAGE_SIZE);
 		read_unlock(&em_tree->lock);
 		if (!em || last_offset < em->start ||
-		    (last_offset + PAGE_CACHE_SIZE > extent_map_end(em)) ||
+		    (last_offset + PAGE_SIZE > extent_map_end(em)) ||
 		    (em->block_start >> 9) != cb->orig_bio->bi_iter.bi_sector) {
 			free_extent_map(em);
 			unlock_extent(tree, last_offset, end);
 			unlock_page(page);
+			put_page(page);
 			break;
 		if (page->index == end_index) {
 			char *userpage;
-			size_t zero_offset = isize & (PAGE_CACHE_SIZE - 1);
+			size_t zero_offset = isize & (PAGE_SIZE - 1);
 			if (zero_offset) {
 				int zeros;
-				zeros = PAGE_CACHE_SIZE - zero_offset;
+				zeros = PAGE_SIZE - zero_offset;
 				userpage = kmap_atomic(page);
 				memset(userpage + zero_offset, 0, zeros);
@@ -531,19 +531,19 @@ static noinline int add_ra_bio_pages(struct inode *inode,
 		ret = bio_add_page(cb->orig_bio, page,
+				   PAGE_SIZE, 0);
-		if (ret == PAGE_CACHE_SIZE) {
+		if (ret == PAGE_SIZE) {
 			nr_pages++;
+			put_page(page);
 		} else {
 			unlock_page(page);
+			put_page(page);
 			break;
 next:
-		last_offset += PAGE_CACHE_SIZE;
+		last_offset += PAGE_SIZE;
 	return 0;
@@ -567,7 +567,7 @@ int btrfs_submit_compressed_read(struct inode *inode, struct bio *bio,
 	struct extent_map_tree *em_tree;
 	struct compressed_bio *cb;
 	struct btrfs_root *root = BTRFS_I(inode)->root;
-	unsigned long uncompressed_len = bio->bi_vcnt * PAGE_CACHE_SIZE;
+	unsigned long uncompressed_len = bio->bi_vcnt * PAGE_SIZE;
 	unsigned long compressed_len;
 	unsigned long nr_pages;
 	unsigned long pg_index;
@@ -589,7 +589,7 @@ int btrfs_submit_compressed_read(struct inode *inode, struct bio *bio,
 				   page_offset(bio->bi_io_vec->bv_page),
-				   PAGE_CACHE_SIZE);
+				   PAGE_SIZE);
 	if (!em)
 		return -EIO;
@@ -617,7 +617,7 @@ int btrfs_submit_compressed_read(struct inode *inode, struct bio *bio,
 	cb->compress_type = extent_compress_type(bio_flags);
 	cb->orig_bio = bio;
-	nr_pages = DIV_ROUND_UP(compressed_len, PAGE_CACHE_SIZE);
+	nr_pages = DIV_ROUND_UP(compressed_len, PAGE_SIZE);
 	cb->compressed_pages = kcalloc(nr_pages, sizeof(struct page *),
 				       GFP_NOFS);
 	if (!cb->compressed_pages)
@@ -640,7 +640,7 @@ int btrfs_submit_compressed_read(struct inode *inode, struct bio *bio,
 	add_ra_bio_pages(inode, em_start + em_len, cb);
 	/* include any pages we added in add_ra-bio_pages */
-	uncompressed_len = bio->bi_vcnt * PAGE_CACHE_SIZE;
+	uncompressed_len = bio->bi_vcnt * PAGE_SIZE;
 	cb->len = uncompressed_len;
 	comp_bio = compressed_bio_alloc(bdev, cur_disk_byte, GFP_NOFS);
@@ -653,18 +653,18 @@ int btrfs_submit_compressed_read(struct inode *inode, struct bio *bio,
 	for (pg_index = 0; pg_index < nr_pages; pg_index++) {
 		page = cb->compressed_pages[pg_index];
-		page->index = em_start >> PAGE_CACHE_SHIFT;
+		page->index = em_start >> PAGE_SHIFT;
 		if (comp_bio->bi_iter.bi_size)
 			ret = tree->ops->merge_bio_hook(READ, page, 0,
-							PAGE_CACHE_SIZE,
+							PAGE_SIZE,
 							comp_bio, 0);
 		else
 			ret = 0;
-		if (ret || bio_add_page(comp_bio, page, PAGE_CACHE_SIZE, 0) <
+		if (ret || bio_add_page(comp_bio, page, PAGE_SIZE, 0) <
+		    PAGE_SIZE) {
 			bio_get(comp_bio);
 			ret = btrfs_bio_wq_end_io(root->fs_info, comp_bio,
@@ -702,9 +702,9 @@ int btrfs_submit_compressed_read(struct inode *inode, struct bio *bio,
 			comp_bio->bi_private = cb;
 			comp_bio->bi_end_io = end_compressed_bio_read;
-			bio_add_page(comp_bio, page, PAGE_CACHE_SIZE, 0);
+			bio_add_page(comp_bio, page, PAGE_SIZE, 0);
-		cur_disk_byte += PAGE_CACHE_SIZE;
+		cur_disk_byte += PAGE_SIZE;
 	bio_get(comp_bio);
@@ -1013,8 +1013,8 @@ int btrfs_decompress_buf2page(char *buf, unsigned long buf_start,
 	/* copy bytes from the working buffer into the pages */
 	while (working_bytes > 0) {
-		bytes = min(PAGE_CACHE_SIZE - *pg_offset,
-			    PAGE_CACHE_SIZE - buf_offset);
+		bytes = min(PAGE_SIZE - *pg_offset,
+			    PAGE_SIZE - buf_offset);
 		bytes = min(bytes, working_bytes);
 		kaddr = kmap_atomic(page_out);
 		memcpy(kaddr + *pg_offset, buf + buf_offset, bytes);
@@ -1027,7 +1027,7 @@ int btrfs_decompress_buf2page(char *buf, unsigned long buf_start,
 		current_buf_start += bytes;
 		/* check if we need to pick another page */
-		if (*pg_offset == PAGE_CACHE_SIZE) {
+		if (*pg_offset == PAGE_SIZE) {
 			(*pg_index)++;
 			if (*pg_index >= vcnt)
 				return 0;
diff --git a/fs/btrfs/disk-io.c b/fs/btrfs/disk-io.c
index 4b02591..942af3d 100644
--- a/fs/btrfs/disk-io.c
+++ b/fs/btrfs/disk-io.c
@@ -1055,7 +1055,7 @@ static void btree_invalidatepage(struct page *page, unsigned int offset,
 			   (unsigned long long)page_offset(page));
 		ClearPagePrivate(page);
 		set_page_private(page, 0);
+		put_page(page);
@@ -1757,7 +1757,7 @@ static int setup_bdi(struct btrfs_fs_info *info, struct backing_dev_info *bdi)
 	if (err)
 		return err;
-	bdi->ra_pages = VM_MAX_READAHEAD * 1024 / PAGE_CACHE_SIZE;
+	bdi->ra_pages = VM_MAX_READAHEAD * 1024 / PAGE_SIZE;
 	bdi->congested_fn	= btrfs_congested_fn;
 	bdi->congested_data	= info;
 	bdi->capabilities |= BDI_CAP_CGROUP_WRITEBACK;
@@ -2537,7 +2537,7 @@ int open_ctree(struct super_block *sb,
 		err = ret;
 		goto fail_bdi;
-	fs_info->dirty_metadata_batch = PAGE_CACHE_SIZE *
+	fs_info->dirty_metadata_batch = PAGE_SIZE *
 					(1 + ilog2(nr_cpu_ids));
 	ret = percpu_counter_init(&fs_info->delalloc_bytes, 0, GFP_KERNEL);
@@ -2782,7 +2782,7 @@ int open_ctree(struct super_block *sb,
 	 * flag our filesystem as having big metadata blocks if
 	 * they are bigger than the page size
-	if (btrfs_super_nodesize(disk_super) > PAGE_CACHE_SIZE) {
+	if (btrfs_super_nodesize(disk_super) > PAGE_SIZE) {
 		if (!(features & BTRFS_FEATURE_INCOMPAT_BIG_METADATA))
 			printk(KERN_INFO "BTRFS: flagging fs with big metadata feature\n");
 		features |= BTRFS_FEATURE_INCOMPAT_BIG_METADATA;
@@ -2832,7 +2832,7 @@ int open_ctree(struct super_block *sb,
 	fs_info->bdi.ra_pages *= btrfs_super_num_devices(disk_super);
 	fs_info->bdi.ra_pages = max(fs_info->bdi.ra_pages,
-				    SZ_4M / PAGE_CACHE_SIZE);
+				    SZ_4M / PAGE_SIZE);
 	tree_root->nodesize = nodesize;
 	tree_root->sectorsize = sectorsize;
@@ -4071,9 +4071,9 @@ static int btrfs_check_super_valid(struct btrfs_fs_info *fs_info,
 		ret = -EINVAL;
 	/* Only PAGE SIZE is supported yet */
-	if (sectorsize != PAGE_CACHE_SIZE) {
+	if (sectorsize != PAGE_SIZE) {
 		printk(KERN_ERR "BTRFS: sectorsize %llu not supported yet, only support %lu\n",
-				sectorsize, PAGE_CACHE_SIZE);
+				sectorsize, PAGE_SIZE);
 		ret = -EINVAL;
 	if (!is_power_of_2(nodesize) || nodesize < sectorsize ||
diff --git a/fs/btrfs/extent-tree.c b/fs/btrfs/extent-tree.c
index 53e1297..ce114ba 100644
--- a/fs/btrfs/extent-tree.c
+++ b/fs/btrfs/extent-tree.c
@@ -3452,7 +3452,7 @@ again:
 		num_pages = 1;
 	num_pages *= 16;
-	num_pages *= PAGE_CACHE_SIZE;
+	num_pages *= PAGE_SIZE;
 	ret = btrfs_check_data_free_space(inode, 0, num_pages);
 	if (ret)
@@ -4639,7 +4639,7 @@ static void shrink_delalloc(struct btrfs_root *root, u64 to_reclaim, u64 orig,
 	loops = 0;
 	while (delalloc_bytes && loops < 3) {
 		max_reclaim = min(delalloc_bytes, to_reclaim);
-		nr_pages = max_reclaim >> PAGE_CACHE_SHIFT;
+		nr_pages = max_reclaim >> PAGE_SHIFT;
 		btrfs_writeback_inodes_sb_nr(root, nr_pages, items);
 		 * We need to wait for the async pages to actually start before
diff --git a/fs/btrfs/extent_io.c b/fs/btrfs/extent_io.c
index 76a0c85..93d696d 100644
--- a/fs/btrfs/extent_io.c
+++ b/fs/btrfs/extent_io.c
@@ -1363,23 +1363,23 @@ int try_lock_extent(struct extent_io_tree *tree, u64 start, u64 end)
 void extent_range_clear_dirty_for_io(struct inode *inode, u64 start, u64 end)
-	unsigned long index = start >> PAGE_CACHE_SHIFT;
-	unsigned long end_index = end >> PAGE_CACHE_SHIFT;
+	unsigned long index = start >> PAGE_SHIFT;
+	unsigned long end_index = end >> PAGE_SHIFT;
 	struct page *page;
 	while (index <= end_index) {
 		page = find_get_page(inode->i_mapping, index);
 		BUG_ON(!page); /* Pages should be in the extent_io_tree */
 		clear_page_dirty_for_io(page);
+		put_page(page);
 		index++;
 void extent_range_redirty_for_io(struct inode *inode, u64 start, u64 end)
 	struct page *page;
@@ -1387,7 +1387,7 @@ void extent_range_redirty_for_io(struct inode *inode, u64 start, u64 end)
 		__set_page_dirty_nobuffers(page);
 		account_page_redirty(page);
+		put_page(page);
 		index++;
@@ -1397,15 +1397,15 @@ void extent_range_redirty_for_io(struct inode *inode, u64 start, u64 end)
 static void set_range_writeback(struct extent_io_tree *tree, u64 start, u64 end)
 	struct page *page;
 		page = find_get_page(tree->mapping, index);
 		set_page_writeback(page);
+		put_page(page);
 		index++;
@@ -1556,8 +1556,8 @@ static noinline void __unlock_for_delalloc(struct inode *inode,
 	int ret;
 	int i;
@@ -1571,7 +1571,7 @@ static noinline void __unlock_for_delalloc(struct inode *inode,
 		for (i = 0; i < ret; i++) {
 			if (pages[i] != locked_page)
 				unlock_page(pages[i]);
 		nr_pages -= ret;
 		index += ret;
@@ -1584,9 +1584,9 @@ static noinline int lock_delalloc_pages(struct inode *inode,
 					u64 delalloc_start,
 					u64 delalloc_end)
-	unsigned long index = delalloc_start >> PAGE_CACHE_SHIFT;
+	unsigned long index = delalloc_start >> PAGE_SHIFT;
 	unsigned long start_index = index;
-	unsigned long end_index = delalloc_end >> PAGE_CACHE_SHIFT;
+	unsigned long end_index = delalloc_end >> PAGE_SHIFT;
 	unsigned long pages_locked = 0;
 	unsigned long nrpages;
@@ -1619,11 +1619,11 @@ static noinline int lock_delalloc_pages(struct inode *inode,
 				    pages[i]->mapping != inode->i_mapping) {
 					ret = -EAGAIN;
 					goto done;
 			pages_locked++;
 		nrpages -= ret;
@@ -1636,7 +1636,7 @@ done:
 		__unlock_for_delalloc(inode, locked_page,
 			      delalloc_start,
 			      ((u64)(start_index + pages_locked - 1)) <<
+			      PAGE_SHIFT);
 	return ret;
@@ -1696,7 +1696,7 @@ again:
 		free_extent_state(cached_state);
 		cached_state = NULL;
 		if (!loops) {
-			max_bytes = PAGE_CACHE_SIZE;
+			max_bytes = PAGE_SIZE;
 			loops = 1;
 			goto again;
 		} else {
@@ -1735,8 +1735,8 @@ void extent_clear_unlock_delalloc(struct inode *inode, u64 start, u64 end,
 	struct extent_io_tree *tree = &BTRFS_I(inode)->io_tree;
 	int ret;
 	int i;
@@ -1757,7 +1757,7 @@ void extent_clear_unlock_delalloc(struct inode *inode, u64 start, u64 end,
 				SetPagePrivate2(pages[i]);
 			if (pages[i] == locked_page) {
 				continue;
 			if (page_ops & PAGE_CLEAR_DIRTY)
@@ -1770,7 +1770,7 @@ void extent_clear_unlock_delalloc(struct inode *inode, u64 start, u64 end,
 			if (page_ops & PAGE_UNLOCK)
 		nr_pages -= ret;
 		index += ret;
@@ -1961,7 +1961,7 @@ int test_range_bit(struct extent_io_tree *tree, u64 start, u64 end,
 static void check_page_uptodate(struct extent_io_tree *tree, struct page *page)
 	u64 start = page_offset(page);
-	u64 end = start + PAGE_CACHE_SIZE - 1;
+	u64 end = start + PAGE_SIZE - 1;
 	if (test_range_bit(tree, start, end, EXTENT_UPTODATE, 1, NULL))
 		SetPageUptodate(page);
@@ -2071,11 +2071,11 @@ int repair_eb_io_failure(struct btrfs_root *root, struct extent_buffer *eb,
 		struct page *p = eb->pages[i];
 		ret = repair_io_failure(root->fs_info->btree_inode, start,
-					PAGE_CACHE_SIZE, start, p,
+					PAGE_SIZE, start, p,
 					start - page_offset(p), mirror_num);
 		if (ret)
 			break;
-		start += PAGE_CACHE_SIZE;
+		start += PAGE_SIZE;
 	return ret;
@@ -2466,8 +2466,8 @@ static void end_bio_extent_writepage(struct bio *bio)
 		 * advance bv_offset and adjust bv_len to compensate.
 		 * Print a warning for nonzero offsets, and an error
 		 * if they don't add up to a full page.  */
-		if (bvec->bv_offset || bvec->bv_len != PAGE_CACHE_SIZE) {
-			if (bvec->bv_offset + bvec->bv_len != PAGE_CACHE_SIZE)
+		if (bvec->bv_offset || bvec->bv_len != PAGE_SIZE) {
+			if (bvec->bv_offset + bvec->bv_len != PAGE_SIZE)
 				btrfs_err(BTRFS_I(page->mapping->host)->root->fs_info,
 				   "partial page write in btrfs with offset %u and length %u",
 					bvec->bv_offset, bvec->bv_len);
@@ -2541,8 +2541,8 @@ static void end_bio_extent_readpage(struct bio *bio)
 				   "partial page read in btrfs with offset %u and length %u",
@@ -2598,13 +2598,13 @@ static void end_bio_extent_readpage(struct bio *bio)
 readpage_ok:
 		if (likely(uptodate)) {
 			loff_t i_size = i_size_read(inode);
-			pgoff_t end_index = i_size >> PAGE_CACHE_SHIFT;
+			pgoff_t end_index = i_size >> PAGE_SHIFT;
 			unsigned off;
 			/* Zero out the end if this page straddles i_size */
-			off = i_size & (PAGE_CACHE_SIZE-1);
+			off = i_size & (PAGE_SIZE-1);
 			if (page->index == end_index && off)
-				zero_user_segment(page, off, PAGE_CACHE_SIZE);
+				zero_user_segment(page, off, PAGE_SIZE);
 		} else {
 			ClearPageUptodate(page);
@@ -2768,7 +2768,7 @@ static int submit_extent_page(int rw, struct extent_io_tree *tree,
 	struct bio *bio;
 	int contig = 0;
 	int old_compressed = prev_bio_flags & EXTENT_BIO_COMPRESSED;
-	size_t page_size = min_t(size_t, size, PAGE_CACHE_SIZE);
+	size_t page_size = min_t(size_t, size, PAGE_SIZE);
 	if (bio_ret && *bio_ret) {
 		bio = *bio_ret;
@@ -2821,7 +2821,7 @@ static void attach_extent_buffer_page(struct extent_buffer *eb,
 	if (!PagePrivate(page)) {
 		SetPagePrivate(page);
-		page_cache_get(page);
+		get_page(page);
 		set_page_private(page, (unsigned long)eb);
 	} else {
 		WARN_ON(page->private != (unsigned long)eb);
@@ -2832,7 +2832,7 @@ void set_page_extent_mapped(struct page *page)
+		get_page(page);
 		set_page_private(page, EXTENT_PAGE_PRIVATE);
@@ -2880,7 +2880,7 @@ static int __do_readpage(struct extent_io_tree *tree,
 	struct inode *inode = page->mapping->host;
-	u64 page_end = start + PAGE_CACHE_SIZE - 1;
+	u64 page_end = start + PAGE_SIZE - 1;
 	u64 end;
 	u64 cur = start;
 	u64 extent_offset;
@@ -2909,12 +2909,12 @@ static int __do_readpage(struct extent_io_tree *tree,
-	if (page->index == last_byte >> PAGE_CACHE_SHIFT) {
+	if (page->index == last_byte >> PAGE_SHIFT) {
 		char *userpage;
-		size_t zero_offset = last_byte & (PAGE_CACHE_SIZE - 1);
+		size_t zero_offset = last_byte & (PAGE_SIZE - 1);
 		if (zero_offset) {
-			iosize = PAGE_CACHE_SIZE - zero_offset;
+			iosize = PAGE_SIZE - zero_offset;
 			memset(userpage + zero_offset, 0, iosize);
@@ -2922,14 +2922,14 @@ static int __do_readpage(struct extent_io_tree *tree,
 	while (cur <= end) {
-		unsigned long pnr = (last_byte >> PAGE_CACHE_SHIFT) + 1;
+		unsigned long pnr = (last_byte >> PAGE_SHIFT) + 1;
 		bool force_bio_submit = false;
 		if (cur >= last_byte) {
 			char *userpage;
 			struct extent_state *cached = NULL;
-			iosize = PAGE_CACHE_SIZE - pg_offset;
+			iosize = PAGE_SIZE - pg_offset;
 			memset(userpage + pg_offset, 0, iosize);
@@ -3112,7 +3112,7 @@ static inline void __do_contiguous_readpages(struct extent_io_tree *tree,
 	for (index = 0; index < nr_pages; index++) {
 		__do_readpage(tree, pages[index], get_extent, em_cached, bio,
 			      mirror_num, bio_flags, rw, prev_em_start);
-		page_cache_release(pages[index]);
+		put_page(pages[index]);
@@ -3134,10 +3134,10 @@ static void __extent_readpages(struct extent_io_tree *tree,
 		page_start = page_offset(pages[index]);
 		if (!end) {
 			start = page_start;
-			end = start + PAGE_CACHE_SIZE - 1;
+			end = start + PAGE_SIZE - 1;
 			first_index = index;
 		} else if (end + 1 == page_start) {
-			end += PAGE_CACHE_SIZE;
+			end += PAGE_SIZE;
 		} else {
 			__do_contiguous_readpages(tree, &pages[first_index],
 						  index - first_index, start,
@@ -3145,7 +3145,7 @@ static void __extent_readpages(struct extent_io_tree *tree,
 						  bio, mirror_num, bio_flags,
 						  rw, prev_em_start);
 			start = page_start;
@@ -3167,13 +3167,13 @@ static int __extent_read_full_page(struct extent_io_tree *tree,
 	struct btrfs_ordered_extent *ordered;
 	int ret;
 	while (1) {
 		lock_extent(tree, start, end);
 		ordered = btrfs_lookup_ordered_range(inode, start,
-						PAGE_CACHE_SIZE);
+						PAGE_SIZE);
 		if (!ordered)
 			break;
 		unlock_extent(tree, start, end);
@@ -3227,7 +3227,7 @@ static noinline_for_stack int writepage_delalloc(struct inode *inode,
 			      unsigned long *nr_written)
 	struct extent_io_tree *tree = epd->tree;
-	u64 page_end = delalloc_start + PAGE_CACHE_SIZE - 1;
+	u64 page_end = delalloc_start + PAGE_SIZE - 1;
 	u64 nr_delalloc;
 	u64 delalloc_to_write = 0;
 	u64 delalloc_end = 0;
@@ -3269,8 +3269,8 @@ static noinline_for_stack int writepage_delalloc(struct inode *inode,
 		 * PAGE_CACHE_SIZE
 		delalloc_to_write += (delalloc_end - delalloc_start +
-				      PAGE_CACHE_SIZE) >>
-				      PAGE_CACHE_SHIFT;
+				      PAGE_SIZE) >>
+				      PAGE_SHIFT;
 		delalloc_start = delalloc_end + 1;
 	if (wbc->nr_to_write < delalloc_to_write) {
@@ -3319,7 +3319,7 @@ static noinline_for_stack int __extent_writepage_io(struct inode *inode,
 	u64 end;
 	u64 cur = start;
 	u64 extent_offset;
@@ -3434,7 +3434,7 @@ static noinline_for_stack int __extent_writepage_io(struct inode *inode,
 		if (ret) {
 			SetPageError(page);
 		} else {
-			unsigned long max_nr = (i_size >> PAGE_CACHE_SHIFT) + 1;
+			unsigned long max_nr = (i_size >> PAGE_SHIFT) + 1;
 			set_range_writeback(tree, cur, cur + iosize - 1);
 			if (!PageWriteback(page)) {
@@ -3477,12 +3477,12 @@ static int __extent_writepage(struct page *page, struct writeback_control *wbc,
 	struct extent_page_data *epd = data;
 	int ret;
 	int nr = 0;
 	size_t pg_offset = 0;
-	unsigned long end_index = i_size >> PAGE_CACHE_SHIFT;
+	unsigned long end_index = i_size >> PAGE_SHIFT;
 	int write_flags;
 	unsigned long nr_written = 0;
@@ -3497,10 +3497,10 @@ static int __extent_writepage(struct page *page, struct writeback_control *wbc,
 	ClearPageError(page);
-	pg_offset = i_size & (PAGE_CACHE_SIZE - 1);
+	pg_offset = i_size & (PAGE_SIZE - 1);
 	if (page->index > end_index ||
 	   (page->index == end_index && !pg_offset)) {
-		page->mapping->a_ops->invalidatepage(page, 0, PAGE_CACHE_SIZE);
+		page->mapping->a_ops->invalidatepage(page, 0, PAGE_SIZE);
 		unlock_page(page);
 		return 0;
@@ -3510,7 +3510,7 @@ static int __extent_writepage(struct page *page, struct writeback_control *wbc,
-		       PAGE_CACHE_SIZE - pg_offset);
+		       PAGE_SIZE - pg_offset);
 		kunmap_atomic(userpage);
@@ -3748,7 +3748,7 @@ static noinline_for_stack int write_one_eb(struct extent_buffer *eb,
 		clear_page_dirty_for_io(p);
 		set_page_writeback(p);
 		ret = submit_extent_page(rw, tree, wbc, p, offset >> 9,
-					 PAGE_CACHE_SIZE, 0, bdev, &epd->bio,
+					 PAGE_SIZE, 0, bdev, &epd->bio,
 					 -1, end_bio_extent_buffer_writepage,
 					 0, epd->bio_flags, bio_flags, false);
 		epd->bio_flags = bio_flags;
@@ -3760,7 +3760,7 @@ static noinline_for_stack int write_one_eb(struct extent_buffer *eb,
 			ret = -EIO;
 			break;
-		offset += PAGE_CACHE_SIZE;
+		offset += PAGE_SIZE;
 		update_nr_written(p, wbc, 1);
 		unlock_page(p);
@@ -3804,8 +3804,8 @@ int btree_write_cache_pages(struct address_space *mapping,
 		index = mapping->writeback_index; /* Start from prev offset */
 		end = -1;
 	} else {
-		index = wbc->range_start >> PAGE_CACHE_SHIFT;
+		index = wbc->range_start >> PAGE_SHIFT;
 		scanned = 1;
 	if (wbc->sync_mode == WB_SYNC_ALL)
@@ -3948,8 +3948,8 @@ static int extent_write_cache_pages(struct extent_io_tree *tree,
 		end = -1;
 	} else {
 		scanned = 1;
@@ -4083,8 +4083,8 @@ int extent_write_locked_range(struct extent_io_tree *tree, struct inode *inode,
 	int ret = 0;
 	struct address_space *mapping = inode->i_mapping;
 	struct page *page;
-	unsigned long nr_pages = (end - start + PAGE_CACHE_SIZE) >>
-		PAGE_CACHE_SHIFT;
+	unsigned long nr_pages = (end - start + PAGE_SIZE) >>
+		PAGE_SHIFT;
 	struct extent_page_data epd = {
 		.bio = NULL,
@@ -4102,18 +4102,18 @@ int extent_write_locked_range(struct extent_io_tree *tree, struct inode *inode,
 	while (start <= end) {
-		page = find_get_page(mapping, start >> PAGE_CACHE_SHIFT);
+		page = find_get_page(mapping, start >> PAGE_SHIFT);
 		if (clear_page_dirty_for_io(page))
 			ret = __extent_writepage(page, &wbc_writepages, &epd);
 		else {
 			if (tree->ops && tree->ops->writepage_end_io_hook)
 				tree->ops->writepage_end_io_hook(page, start,
-						 start + PAGE_CACHE_SIZE - 1,
+						 start + PAGE_SIZE - 1,
 						 NULL, 1);
 			unlock_page(page);
+		put_page(page);
 	flush_epd_write_bio(&epd);
@@ -4163,7 +4163,7 @@ int extent_readpages(struct extent_io_tree *tree,
 		list_del(&page->lru);
 					page->index, GFP_NOFS)) {
+			put_page(page);
 			continue;
@@ -4197,7 +4197,7 @@ int extent_invalidatepage(struct extent_io_tree *tree,
 	struct extent_state *cached_state = NULL;
 	size_t blocksize = page->mapping->host->i_sb->s_blocksize;
 	start += ALIGN(offset, blocksize);
@@ -4223,7 +4223,7 @@ static int try_release_extent_state(struct extent_map_tree *map,
 				    struct page *page, gfp_t mask)
 	int ret = 1;
@@ -4262,7 +4262,7 @@ int try_release_extent_mapping(struct extent_map_tree *map,
 	struct extent_map *em;
 	if (gfpflags_allow_blocking(mask) &&
 	    page->mapping->host->i_size > SZ_16M) {
@@ -4587,14 +4587,14 @@ static void btrfs_release_extent_buffer_page(struct extent_buffer *eb)
 			/* One for the page private */
+			put_page(page);
 		if (mapped)
 			spin_unlock(&page->mapping->private_lock);
 		/* One for when we alloced the page */
+		put_page(page);
 	} while (index != 0);
@@ -4779,7 +4779,7 @@ struct extent_buffer *find_extent_buffer(struct btrfs_fs_info *fs_info,
 	rcu_read_lock();
 	eb = radix_tree_lookup(&fs_info->buffer_radix,
-			       start >> PAGE_CACHE_SHIFT);
+			       start >> PAGE_SHIFT);
 	if (eb && atomic_inc_not_zero(&eb->refs)) {
 		rcu_read_unlock();
@@ -4829,7 +4829,7 @@ again:
 		goto free_eb;
 	spin_lock(&fs_info->buffer_lock);
 	ret = radix_tree_insert(&fs_info->buffer_radix,
-				start >> PAGE_CACHE_SHIFT, eb);
+				start >> PAGE_SHIFT, eb);
 	spin_unlock(&fs_info->buffer_lock);
 	radix_tree_preload_end();
 	if (ret == -EEXIST) {
@@ -4862,7 +4862,7 @@ struct extent_buffer *alloc_extent_buffer(struct btrfs_fs_info *fs_info,
 	unsigned long len = fs_info->tree_root->nodesize;
 	unsigned long num_pages = num_extent_pages(start, len);
 	unsigned long i;
 	struct extent_buffer *eb;
 	struct extent_buffer *exists = NULL;
 	struct page *p;
@@ -4896,7 +4896,7 @@ struct extent_buffer *alloc_extent_buffer(struct btrfs_fs_info *fs_info,
 			if (atomic_inc_not_zero(&exists->refs)) {
 				spin_unlock(&mapping->private_lock);
 				unlock_page(p);
-				page_cache_release(p);
+				put_page(p);
 				mark_extent_buffer_accessed(exists, p);
 				goto free_eb;
@@ -4908,7 +4908,7 @@ struct extent_buffer *alloc_extent_buffer(struct btrfs_fs_info *fs_info,
 			ClearPagePrivate(p);
 			WARN_ON(PageDirty(p));
+			put_page(p);
 		attach_extent_buffer_page(eb, p);
@@ -4931,7 +4931,7 @@ again:
@@ -4994,7 +4994,7 @@ static int release_extent_buffer(struct extent_buffer *eb)
 			radix_tree_delete(&fs_info->buffer_radix,
-					  eb->start >> PAGE_CACHE_SHIFT);
+					  eb->start >> PAGE_SHIFT);
 		} else {
 			spin_unlock(&eb->refs_lock);
@@ -5168,8 +5168,8 @@ int read_extent_buffer_pages(struct extent_io_tree *tree,
 	if (start) {
 		WARN_ON(start < eb->start);
-		start_i = (start >> PAGE_CACHE_SHIFT) -
-			(eb->start >> PAGE_CACHE_SHIFT);
+		start_i = (start >> PAGE_SHIFT) -
+			(eb->start >> PAGE_SHIFT);
 	} else {
 		start_i = 0;
@@ -5252,18 +5252,18 @@ void read_extent_buffer(struct extent_buffer *eb, void *dstv,
 	struct page *page;
 	char *kaddr;
-	size_t start_offset = eb->start & ((u64)PAGE_CACHE_SIZE - 1);
-	unsigned long i = (start_offset + start) >> PAGE_CACHE_SHIFT;
+	size_t start_offset = eb->start & ((u64)PAGE_SIZE - 1);
+	unsigned long i = (start_offset + start) >> PAGE_SHIFT;
 	WARN_ON(start > eb->len);
 	WARN_ON(start + len > eb->start + eb->len);
-	offset = (start_offset + start) & (PAGE_CACHE_SIZE - 1);
+	offset = (start_offset + start) & (PAGE_SIZE - 1);
 	while (len > 0) {
 		page = eb->pages[i];
-		cur = min(len, (PAGE_CACHE_SIZE - offset));
+		cur = min(len, (PAGE_SIZE - offset));
 		kaddr = page_address(page);
 		memcpy(dst, kaddr + offset, cur);
@@ -5283,19 +5283,19 @@ int read_extent_buffer_to_user(struct extent_buffer *eb, void __user *dstv,
 	struct page *page;
 	char *kaddr;
 	char __user *dst = (char __user *)dstv;
 	int ret = 0;
 	while (len > 0) {
 		if (copy_to_user(dst, kaddr + offset, cur)) {
 			ret = -EFAULT;
@@ -5316,13 +5316,13 @@ int map_private_extent_buffer(struct extent_buffer *eb, unsigned long start,
 			       unsigned long *map_start,
 			       unsigned long *map_len)
-	size_t offset = start & (PAGE_CACHE_SIZE - 1);
+	size_t offset = start & (PAGE_SIZE - 1);
 	char *kaddr;
 	struct page *p;
 	unsigned long end_i = (start_offset + start + min_len - 1) >>
-		PAGE_CACHE_SHIFT;
+		PAGE_SHIFT;
 	if (i != end_i)
 		return -EINVAL;
@@ -5332,7 +5332,7 @@ int map_private_extent_buffer(struct extent_buffer *eb, unsigned long start,
 		*map_start = 0;
 	} else {
 		offset = 0;
-		*map_start = ((u64)i << PAGE_CACHE_SHIFT) - start_offset;
+		*map_start = ((u64)i << PAGE_SHIFT) - start_offset;
 	if (start + min_len > eb->len) {
@@ -5345,7 +5345,7 @@ int map_private_extent_buffer(struct extent_buffer *eb, unsigned long start,
 	p = eb->pages[i];
 	kaddr = page_address(p);
 	*map = kaddr + offset;
-	*map_len = PAGE_CACHE_SIZE - offset;
+	*map_len = PAGE_SIZE - offset;
 	return 0;
@@ -5358,19 +5358,19 @@ int memcmp_extent_buffer(struct extent_buffer *eb, const void *ptrv,
 	struct page *page;
 	char *kaddr;
 	char *ptr = (char *)ptrv;
 	int ret = 0;
 	while (len > 0) {
 		ret = memcmp(ptr, kaddr + offset, cur);
@@ -5393,19 +5393,19 @@ void write_extent_buffer(struct extent_buffer *eb, const void *srcv,
 	struct page *page;
 	char *kaddr;
 	char *src = (char *)srcv;
 	while (len > 0) {
 		WARN_ON(!PageUptodate(page));
-		cur = min(len, PAGE_CACHE_SIZE - offset);
+		cur = min(len, PAGE_SIZE - offset);
 		memcpy(kaddr + offset, src, cur);
@@ -5423,19 +5423,19 @@ void memset_extent_buffer(struct extent_buffer *eb, char c,
 	size_t offset;
 	struct page *page;
 	char *kaddr;
 	while (len > 0) {
 		memset(kaddr + offset, c, cur);
@@ -5454,19 +5454,19 @@ void copy_extent_buffer(struct extent_buffer *dst, struct extent_buffer *src,
 	size_t offset;
 	struct page *page;
 	char *kaddr;
-	size_t start_offset = dst->start & ((u64)PAGE_CACHE_SIZE - 1);
-	unsigned long i = (start_offset + dst_offset) >> PAGE_CACHE_SHIFT;
+	size_t start_offset = dst->start & ((u64)PAGE_SIZE - 1);
+	unsigned long i = (start_offset + dst_offset) >> PAGE_SHIFT;
 	WARN_ON(src->len != dst_len);
 	offset = (start_offset + dst_offset) &
-		(PAGE_CACHE_SIZE - 1);
+		(PAGE_SIZE - 1);
 	while (len > 0) {
 		page = dst->pages[i];
-		cur = min(len, (unsigned long)(PAGE_CACHE_SIZE - offset));
+		cur = min(len, (unsigned long)(PAGE_SIZE - offset));
 		read_extent_buffer(src, kaddr + offset, src_offset, cur);
@@ -5508,7 +5508,7 @@ static inline void eb_bitmap_offset(struct extent_buffer *eb,
 				    unsigned long *page_index,
 				    size_t *page_offset)
 	size_t byte_offset = BIT_BYTE(nr);
 	size_t offset;
@@ -5519,8 +5519,8 @@ static inline void eb_bitmap_offset(struct extent_buffer *eb,
 	offset = start_offset + start + byte_offset;
-	*page_index = offset >> PAGE_CACHE_SHIFT;
-	*page_offset = offset & (PAGE_CACHE_SIZE - 1);
+	*page_index = offset >> PAGE_SHIFT;
+	*page_offset = offset & (PAGE_SIZE - 1);
@@ -5572,7 +5572,7 @@ void extent_buffer_bitmap_set(struct extent_buffer *eb, unsigned long start,
 		len -= bits_to_set;
 		bits_to_set = BITS_PER_BYTE;
 		mask_to_set = ~0U;
-		if (++offset >= PAGE_CACHE_SIZE && len > 0) {
+		if (++offset >= PAGE_SIZE && len > 0) {
 			offset = 0;
 			page = eb->pages[++i];
@@ -5614,7 +5614,7 @@ void extent_buffer_bitmap_clear(struct extent_buffer *eb, unsigned long start,
 		len -= bits_to_clear;
 		bits_to_clear = BITS_PER_BYTE;
 		mask_to_clear = ~0U;
 			offset = 0;
@@ -5661,7 +5661,7 @@ void memcpy_extent_buffer(struct extent_buffer *dst, unsigned long dst_offset,
 	size_t cur;
 	size_t dst_off_in_page;
 	size_t src_off_in_page;
 	unsigned long dst_i;
 	unsigned long src_i;
@@ -5680,17 +5680,17 @@ void memcpy_extent_buffer(struct extent_buffer *dst, unsigned long dst_offset,
 	while (len > 0) {
 		dst_off_in_page = (start_offset + dst_offset) &
+			(PAGE_SIZE - 1);
 		src_off_in_page = (start_offset + src_offset) &
+			(PAGE_SIZE - 1);
-		dst_i = (start_offset + dst_offset) >> PAGE_CACHE_SHIFT;
-		src_i = (start_offset + src_offset) >> PAGE_CACHE_SHIFT;
+		dst_i = (start_offset + dst_offset) >> PAGE_SHIFT;
+		src_i = (start_offset + src_offset) >> PAGE_SHIFT;
 					       src_off_in_page));
 		cur = min_t(unsigned long, cur,
-			(unsigned long)(PAGE_CACHE_SIZE - dst_off_in_page));
+			(unsigned long)(PAGE_SIZE - dst_off_in_page));
 		copy_pages(dst->pages[dst_i], dst->pages[src_i],
 			   dst_off_in_page, src_off_in_page, cur);
@@ -5709,7 +5709,7 @@ void memmove_extent_buffer(struct extent_buffer *dst, unsigned long dst_offset,
 	unsigned long dst_end = dst_offset + len - 1;
 	unsigned long src_end = src_offset + len - 1;
@@ -5728,13 +5728,13 @@ void memmove_extent_buffer(struct extent_buffer *dst, unsigned long dst_offset,
 		return;
 	while (len > 0) {
-		dst_i = (start_offset + dst_end) >> PAGE_CACHE_SHIFT;
-		src_i = (start_offset + src_end) >> PAGE_CACHE_SHIFT;
+		dst_i = (start_offset + dst_end) >> PAGE_SHIFT;
+		src_i = (start_offset + src_end) >> PAGE_SHIFT;
 		dst_off_in_page = (start_offset + dst_end) &
+			(PAGE_SIZE - 1);
 		src_off_in_page = (start_offset + src_end) &
+			(PAGE_SIZE - 1);
 		cur = min_t(unsigned long, len, src_off_in_page + 1);
 		cur = min(cur, dst_off_in_page + 1);
diff --git a/fs/btrfs/extent_io.h b/fs/btrfs/extent_io.h
index 5dbf92e..b5e0ade 100644
--- a/fs/btrfs/extent_io.h
+++ b/fs/btrfs/extent_io.h
@@ -120,7 +120,7 @@ struct extent_state {
 #define INLINE_EXTENT_BUFFER_PAGES 16
-#define MAX_INLINE_EXTENT_BUFFER_SIZE (INLINE_EXTENT_BUFFER_PAGES * PAGE_CACHE_SIZE)
+#define MAX_INLINE_EXTENT_BUFFER_SIZE (INLINE_EXTENT_BUFFER_PAGES * PAGE_SIZE)
 struct extent_buffer {
 	u64 start;
 	unsigned long len;
@@ -365,8 +365,8 @@ void wait_on_extent_buffer_writeback(struct extent_buffer *eb);
 static inline unsigned long num_extent_pages(u64 start, u64 len)
-	return ((start + len + PAGE_CACHE_SIZE - 1) >> PAGE_CACHE_SHIFT) -
-		(start >> PAGE_CACHE_SHIFT);
+	return ((start + len + PAGE_SIZE - 1) >> PAGE_SHIFT) -
+		(start >> PAGE_SHIFT);
 static inline void extent_buffer_get(struct extent_buffer *eb)
diff --git a/fs/btrfs/file-item.c b/fs/btrfs/file-item.c
index b5baf5b..7a7d6e2 100644
--- a/fs/btrfs/file-item.c
+++ b/fs/btrfs/file-item.c
@@ -32,7 +32,7 @@
 				  size) - 1))
 #define MAX_CSUM_ITEMS(r, size) (min_t(u32, __MAX_CSUM_ITEMS(r, size), \
-				       PAGE_CACHE_SIZE))
+				       PAGE_SIZE))
 #define MAX_ORDERED_SUM_BYTES(r) ((PAGE_SIZE - \
 				   sizeof(struct btrfs_ordered_sum)) / \
@@ -203,7 +203,7 @@ static int __btrfs_lookup_bio_sums(struct btrfs_root *root,
 		csum = (u8 *)dst;
-	if (bio->bi_iter.bi_size > PAGE_CACHE_SIZE * 8)
+	if (bio->bi_iter.bi_size > PAGE_SIZE * 8)
 		path->reada = READA_FORWARD;
 	WARN_ON(bio->bi_vcnt <= 0);
diff --git a/fs/btrfs/file.c b/fs/btrfs/file.c
index 15a09cb..cf31a60 100644
--- a/fs/btrfs/file.c
+++ b/fs/btrfs/file.c
@@ -414,11 +414,11 @@ static noinline int btrfs_copy_from_user(loff_t pos, size_t write_bytes,
 	size_t copied = 0;
 	size_t total_copied = 0;
 	int pg = 0;
-	int offset = pos & (PAGE_CACHE_SIZE - 1);
+	int offset = pos & (PAGE_SIZE - 1);
 	while (write_bytes > 0) {
 		size_t count = min_t(size_t,
-				     PAGE_CACHE_SIZE - offset, write_bytes);
+				     PAGE_SIZE - offset, write_bytes);
 		struct page *page = prepared_pages[pg];
 		 * Copy data from userspace to the current page
@@ -448,7 +448,7 @@ static noinline int btrfs_copy_from_user(loff_t pos, size_t write_bytes,
 		if (unlikely(copied == 0))
 			break;
-		if (copied < PAGE_CACHE_SIZE - offset) {
+		if (copied < PAGE_SIZE - offset) {
 			offset += copied;
 		} else {
 			pg++;
@@ -473,7 +473,7 @@ static void btrfs_drop_pages(struct page **pages, size_t num_pages)
 		ClearPageChecked(pages[i]);
@@ -1297,7 +1297,7 @@ static int prepare_uptodate_page(struct inode *inode,
 	int ret = 0;
-	if (((pos & (PAGE_CACHE_SIZE - 1)) || force_uptodate) &&
+	if (((pos & (PAGE_SIZE - 1)) || force_uptodate) &&
 	    !PageUptodate(page)) {
 		ret = btrfs_readpage(NULL, page);
 		if (ret)
@@ -1323,7 +1323,7 @@ static noinline int prepare_pages(struct inode *inode, struct page **pages,
 				  size_t write_bytes, bool force_uptodate)
 	int i;
-	unsigned long index = pos >> PAGE_CACHE_SHIFT;
+	unsigned long index = pos >> PAGE_SHIFT;
 	gfp_t mask = btrfs_alloc_write_mask(inode->i_mapping);
 	int err = 0;
 	int faili;
@@ -1345,7 +1345,7 @@ again:
 			err = prepare_uptodate_page(inode, pages[i],
 						    pos + write_bytes, false);
 		if (err) {
 			if (err == -EAGAIN) {
 				err = 0;
 				goto again;
@@ -1360,7 +1360,7 @@ again:
 fail:
 	while (faili >= 0) {
 		unlock_page(pages[faili]);
-		page_cache_release(pages[faili]);
+		put_page(pages[faili]);
 		faili--;
 	return err;
@@ -1408,7 +1408,7 @@ lock_and_cleanup_extent_if_need(struct inode *inode, struct page **pages,
 					     cached_state, GFP_NOFS);
 			btrfs_start_ordered_extent(inode, ordered, 1);
 			btrfs_put_ordered_extent(ordered);
@@ -1497,8 +1497,8 @@ static noinline ssize_t __btrfs_buffered_write(struct file *file,
 	bool force_page_uptodate = false;
 	bool need_unlock;
-	nrptrs = min(DIV_ROUND_UP(iov_iter_count(i), PAGE_CACHE_SIZE),
-			PAGE_CACHE_SIZE / (sizeof(struct page *)));
+	nrptrs = min(DIV_ROUND_UP(iov_iter_count(i), PAGE_SIZE),
+			PAGE_SIZE / (sizeof(struct page *)));
 	nrptrs = min(nrptrs, current->nr_dirtied_pause - current->nr_dirtied);
 	nrptrs = max(nrptrs, 8);
 	pages = kmalloc_array(nrptrs, sizeof(struct page *), GFP_KERNEL);
@@ -1506,13 +1506,13 @@ static noinline ssize_t __btrfs_buffered_write(struct file *file,
 		return -ENOMEM;
 	while (iov_iter_count(i) > 0) {
-		size_t offset = pos & (PAGE_CACHE_SIZE - 1);
+		size_t offset = pos & (PAGE_SIZE - 1);
 		size_t sector_offset;
 		size_t write_bytes = min(iov_iter_count(i),
-					 nrptrs * (size_t)PAGE_CACHE_SIZE -
+					 nrptrs * (size_t)PAGE_SIZE -
 					 offset);
 		size_t num_pages = DIV_ROUND_UP(write_bytes + offset,
-						PAGE_CACHE_SIZE);
+						PAGE_SIZE);
 		size_t reserve_bytes;
 		size_t dirty_pages;
 		size_t copied;
@@ -1547,7 +1547,7 @@ static noinline ssize_t __btrfs_buffered_write(struct file *file,
 			 * write_bytes, so scale down.
-						 PAGE_CACHE_SIZE);
+						 PAGE_SIZE);
 			reserve_bytes = round_up(write_bytes + sector_offset,
 					root->sectorsize);
 			goto reserve_metadata;
@@ -1609,7 +1609,7 @@ again:
 		} else {
 			dirty_pages = DIV_ROUND_UP(copied + offset,
-						   PAGE_CACHE_SIZE);
+						   PAGE_SIZE);
@@ -1641,7 +1641,7 @@ again:
 				u64 __pos;
 				__pos = round_down(pos, root->sectorsize) +
-					(dirty_pages << PAGE_CACHE_SHIFT);
+					(dirty_pages << PAGE_SHIFT);
 				btrfs_delalloc_release_space(inode, __pos,
 							     release_bytes);
@@ -1682,7 +1682,7 @@ again:
 		cond_resched();
 		balance_dirty_pages_ratelimited(inode->i_mapping);
-		if (dirty_pages < (root->nodesize >> PAGE_CACHE_SHIFT) + 1)
+		if (dirty_pages < (root->nodesize >> PAGE_SHIFT) + 1)
 			btrfs_btree_balance_dirty(root);
 		pos += copied;
@@ -1738,8 +1738,8 @@ static ssize_t __btrfs_direct_write(struct kiocb *iocb,
 		goto out;
 	written += written_buffered;
 	iocb->ki_pos = pos + written_buffered;
-	invalidate_mapping_pages(file->f_mapping, pos >> PAGE_CACHE_SHIFT,
-				 endbyte >> PAGE_CACHE_SHIFT);
+	invalidate_mapping_pages(file->f_mapping, pos >> PAGE_SHIFT,
+				 endbyte >> PAGE_SHIFT);
 out:
 	return written ? written : err;
diff --git a/fs/btrfs/free-space-cache.c b/fs/btrfs/free-space-cache.c
index 8f835bf..5e6062c 100644
--- a/fs/btrfs/free-space-cache.c
+++ b/fs/btrfs/free-space-cache.c
@@ -29,7 +29,7 @@
 #include "inode-map.h"
 #include "volumes.h"
-#define BITS_PER_BITMAP		(PAGE_CACHE_SIZE * 8)
+#define BITS_PER_BITMAP		(PAGE_SIZE * 8)
 #define MAX_CACHE_BYTES_PER_GIG	SZ_32K
 struct btrfs_trim_range {
@@ -295,7 +295,7 @@ static int readahead_cache(struct inode *inode)
 		return -ENOMEM;
 	file_ra_state_init(ra, inode->i_mapping);
-	last_index = (i_size_read(inode) - 1) >> PAGE_CACHE_SHIFT;
+	last_index = (i_size_read(inode) - 1) >> PAGE_SHIFT;
 	page_cache_sync_readahead(inode->i_mapping, ra, NULL, 0, last_index);
@@ -310,14 +310,14 @@ static int io_ctl_init(struct btrfs_io_ctl *io_ctl, struct inode *inode,
 	int num_pages;
 	int check_crcs = 0;
-	num_pages = DIV_ROUND_UP(i_size_read(inode), PAGE_CACHE_SIZE);
+	num_pages = DIV_ROUND_UP(i_size_read(inode), PAGE_SIZE);
 	if (btrfs_ino(inode) != BTRFS_FREE_INO_OBJECTID)
 		check_crcs = 1;
 	/* Make sure we can fit our crcs into the first page */
 	if (write && check_crcs &&
-	    (num_pages * sizeof(u32)) >= PAGE_CACHE_SIZE)
+	    (num_pages * sizeof(u32)) >= PAGE_SIZE)
 		return -ENOSPC;
 	memset(io_ctl, 0, sizeof(struct btrfs_io_ctl));
@@ -354,9 +354,9 @@ static void io_ctl_map_page(struct btrfs_io_ctl *io_ctl, int clear)
 	io_ctl->page = io_ctl->pages[io_ctl->index++];
 	io_ctl->cur = page_address(io_ctl->page);
 	io_ctl->orig = io_ctl->cur;
-	io_ctl->size = PAGE_CACHE_SIZE;
+	io_ctl->size = PAGE_SIZE;
 	if (clear)
-		memset(io_ctl->cur, 0, PAGE_CACHE_SIZE);
+		memset(io_ctl->cur, 0, PAGE_SIZE);
 static void io_ctl_drop_pages(struct btrfs_io_ctl *io_ctl)
@@ -369,7 +369,7 @@ static void io_ctl_drop_pages(struct btrfs_io_ctl *io_ctl)
 		if (io_ctl->pages[i]) {
 			ClearPageChecked(io_ctl->pages[i]);
 			unlock_page(io_ctl->pages[i]);
-			page_cache_release(io_ctl->pages[i]);
+			put_page(io_ctl->pages[i]);
@@ -475,7 +475,7 @@ static void io_ctl_set_crc(struct btrfs_io_ctl *io_ctl, int index)
 		offset = sizeof(u32) * io_ctl->num_pages;
 	crc = btrfs_csum_data(io_ctl->orig + offset, crc,
-			      PAGE_CACHE_SIZE - offset);
+			      PAGE_SIZE - offset);
 	btrfs_csum_final(crc, (char *)&crc);
 	io_ctl_unmap_page(io_ctl);
 	tmp = page_address(io_ctl->pages[0]);
@@ -503,7 +503,7 @@ static int io_ctl_check_crc(struct btrfs_io_ctl *io_ctl, int index)
 	io_ctl_map_page(io_ctl, 0);
 	if (val != crc) {
 		btrfs_err_rl(io_ctl->root->fs_info,
@@ -561,7 +561,7 @@ static int io_ctl_add_bitmap(struct btrfs_io_ctl *io_ctl, void *bitmap)
-	memcpy(io_ctl->cur, bitmap, PAGE_CACHE_SIZE);
+	memcpy(io_ctl->cur, bitmap, PAGE_SIZE);
 	io_ctl_set_crc(io_ctl, io_ctl->index - 1);
 	if (io_ctl->index < io_ctl->num_pages)
@@ -621,7 +621,7 @@ static int io_ctl_read_bitmap(struct btrfs_io_ctl *io_ctl,
 	if (ret)
 		return ret;
-	memcpy(entry->bitmap, io_ctl->cur, PAGE_CACHE_SIZE);
+	memcpy(entry->bitmap, io_ctl->cur, PAGE_SIZE);
 	return 0;
@@ -775,7 +775,7 @@ static int __load_free_space_cache(struct btrfs_root *root, struct inode *inode,
 		} else {
 			ASSERT(num_bitmaps);
 			num_bitmaps--;
-			e->bitmap = kzalloc(PAGE_CACHE_SIZE, GFP_NOFS);
+			e->bitmap = kzalloc(PAGE_SIZE, GFP_NOFS);
 			if (!e->bitmap) {
 				kmem_cache_free(
 					btrfs_free_space_cachep, e);
@@ -1660,7 +1660,7 @@ static void recalculate_thresholds(struct btrfs_free_space_ctl *ctl)
 	 * sure we don't go over our overall goal of MAX_CACHE_BYTES_PER_GIG as
 	 * we add more bitmaps.
-	bitmap_bytes = (ctl->total_bitmaps + 1) * PAGE_CACHE_SIZE;
+	bitmap_bytes = (ctl->total_bitmaps + 1) * PAGE_SIZE;
 	if (bitmap_bytes >= max_bytes) {
 		ctl->extents_thresh = 0;
@@ -2111,7 +2111,7 @@ new_bitmap:
 		/* allocate the bitmap */
-		info->bitmap = kzalloc(PAGE_CACHE_SIZE, GFP_NOFS);
+		info->bitmap = kzalloc(PAGE_SIZE, GFP_NOFS);
 		spin_lock(&ctl->tree_lock);
 		if (!info->bitmap) {
 			ret = -ENOMEM;
@@ -3580,7 +3580,7 @@ again:
 	if (!map) {
-		map = kzalloc(PAGE_CACHE_SIZE, GFP_NOFS);
+		map = kzalloc(PAGE_SIZE, GFP_NOFS);
 		if (!map) {
 			kmem_cache_free(btrfs_free_space_cachep, info);
 			return -ENOMEM;
diff --git a/fs/btrfs/inode-map.c b/fs/btrfs/inode-map.c
index 1f0ec19..70107f7 100644
--- a/fs/btrfs/inode-map.c
+++ b/fs/btrfs/inode-map.c
@@ -283,7 +283,7 @@ void btrfs_unpin_free_ino(struct btrfs_root *root)
 #define INIT_THRESHOLD	((SZ_32K / 2) / sizeof(struct btrfs_free_space))
-#define INODES_PER_BITMAP (PAGE_CACHE_SIZE * 8)
+#define INODES_PER_BITMAP (PAGE_SIZE * 8)
  * The goal is to keep the memory used by the free_ino tree won't
@@ -317,7 +317,7 @@ static void recalculate_thresholds(struct btrfs_free_space_ctl *ctl)
 	ctl->extents_thresh = (max_bitmaps - ctl->total_bitmaps) *
-				PAGE_CACHE_SIZE / sizeof(*info);
+				PAGE_SIZE / sizeof(*info);
@@ -481,12 +481,12 @@ again:
 	prealloc = sizeof(struct btrfs_free_space) * ctl->free_extents;
-	prealloc = ALIGN(prealloc, PAGE_CACHE_SIZE);
-	prealloc += ctl->total_bitmaps * PAGE_CACHE_SIZE;
+	prealloc = ALIGN(prealloc, PAGE_SIZE);
+	prealloc += ctl->total_bitmaps * PAGE_SIZE;
 	spin_unlock(&ctl->tree_lock);
 	/* Just to make sure we have enough space */
-	prealloc += 8 * PAGE_CACHE_SIZE;
+	prealloc += 8 * PAGE_SIZE;
 	ret = btrfs_delalloc_reserve_space(inode, 0, prealloc);
 	if (ret)
diff --git a/fs/btrfs/inode.c b/fs/btrfs/inode.c
index 41a5688..2aaba58 100644
--- a/fs/btrfs/inode.c
+++ b/fs/btrfs/inode.c
@@ -194,7 +194,7 @@ static int insert_inline_extent(struct btrfs_trans_handle *trans,
 		while (compressed_size > 0) {
 			cpage = compressed_pages[i];
 			cur_size = min_t(unsigned long, compressed_size,
-				       PAGE_CACHE_SIZE);
+				       PAGE_SIZE);
 			kaddr = kmap_atomic(cpage);
 			write_extent_buffer(leaf, kaddr, ptr, cur_size);
@@ -208,13 +208,13 @@ static int insert_inline_extent(struct btrfs_trans_handle *trans,
 						  compress_type);
 	} else {
 		btrfs_set_file_extent_compression(leaf, ei, 0);
-		offset = start & (PAGE_CACHE_SIZE - 1);
+		offset = start & (PAGE_SIZE - 1);
 		write_extent_buffer(leaf, kaddr + offset, ptr, size);
+		put_page(page);
 	btrfs_mark_buffer_dirty(leaf);
 	btrfs_release_path(path);
@@ -322,7 +322,7 @@ out:
 	 * And at reserve time, it's always aligned to page size, so
 	 * just free one page here.
-	btrfs_qgroup_free_data(inode, 0, PAGE_CACHE_SIZE);
+	btrfs_qgroup_free_data(inode, 0, PAGE_SIZE);
 	btrfs_free_path(path);
 	btrfs_end_transaction(trans, root);
 	return ret;
@@ -435,8 +435,8 @@ static noinline void compress_file_range(struct inode *inode,
 	actual_end = min_t(u64, isize, end + 1);
 again:
 	will_compress = 0;
-	nr_pages = (end >> PAGE_CACHE_SHIFT) - (start >> PAGE_CACHE_SHIFT) + 1;
-	nr_pages = min_t(unsigned long, nr_pages, SZ_128K / PAGE_CACHE_SIZE);
+	nr_pages = (end >> PAGE_SHIFT) - (start >> PAGE_SHIFT) + 1;
+	nr_pages = min_t(unsigned long, nr_pages, SZ_128K / PAGE_SIZE);
 	 * we don't want to send crud past the end of i_size through
@@ -514,7 +514,7 @@ again:
 		if (!ret) {
 			unsigned long offset = total_compressed &
+				(PAGE_SIZE - 1);
 			struct page *page = pages[nr_pages_ret - 1];
 			char *kaddr;
@@ -524,7 +524,7 @@ again:
 			if (offset) {
 				memset(kaddr + offset, 0,
 			will_compress = 1;
@@ -580,7 +580,7 @@ cont:
 		 * one last check to make sure the compression is really a
 		 * win, compare the page count read with the blocks on disk
-		total_in = ALIGN(total_in, PAGE_CACHE_SIZE);
+		total_in = ALIGN(total_in, PAGE_SIZE);
 		if (total_compressed >= total_in) {
 			will_compress = 0;
 		} else {
@@ -594,7 +594,7 @@ cont:
 		for (i = 0; i < nr_pages_ret; i++) {
 			WARN_ON(pages[i]->mapping);
-			page_cache_release(pages[i]);
+			put_page(pages[i]);
 		kfree(pages);
 		pages = NULL;
@@ -650,7 +650,7 @@ cleanup_and_bail_uncompressed:
 free_pages_out:
 	kfree(pages);
@@ -664,7 +664,7 @@ static void free_async_extent_pages(struct async_extent *async_extent)
 	for (i = 0; i < async_extent->nr_pages; i++) {
 		WARN_ON(async_extent->pages[i]->mapping);
-		page_cache_release(async_extent->pages[i]);
+		put_page(async_extent->pages[i]);
 	kfree(async_extent->pages);
 	async_extent->nr_pages = 0;
@@ -966,7 +966,7 @@ static noinline int cow_file_range(struct inode *inode,
 				     PAGE_END_WRITEBACK);
 			*nr_written = *nr_written +
-			     (end - start + PAGE_CACHE_SIZE) / PAGE_CACHE_SIZE;
+			     (end - start + PAGE_SIZE) / PAGE_SIZE;
 			*page_started = 1;
 			goto out;
 		} else if (ret < 0) {
@@ -1106,8 +1106,8 @@ static noinline void async_cow_submit(struct btrfs_work *work)
 	async_cow = container_of(work, struct async_cow, work);
 	root = async_cow->root;
-	nr_pages = (async_cow->end - async_cow->start + PAGE_CACHE_SIZE) >>
-		PAGE_CACHE_SHIFT;
+	nr_pages = (async_cow->end - async_cow->start + PAGE_SIZE) >>
+		PAGE_SHIFT;
 	 * atomic_sub_return implies a barrier for waitqueue_active
@@ -1164,8 +1164,8 @@ static int cow_file_range_async(struct inode *inode, struct page *locked_page,
 				async_cow_start, async_cow_submit,
 				async_cow_free);
-		nr_pages = (cur_end - start + PAGE_CACHE_SIZE) >>
-			PAGE_CACHE_SHIFT;
+		nr_pages = (cur_end - start + PAGE_SIZE) >>
+			PAGE_SHIFT;
 		atomic_add(nr_pages, &root->fs_info->async_delalloc_pages);
 		btrfs_queue_work(root->fs_info->delalloc_workers,
@@ -1960,7 +1960,7 @@ static noinline int add_pending_csums(struct btrfs_trans_handle *trans,
 int btrfs_set_extent_delalloc(struct inode *inode, u64 start, u64 end,
 			      struct extent_state **cached_state)
-	WARN_ON((end & (PAGE_CACHE_SIZE - 1)) == 0);
+	WARN_ON((end & (PAGE_SIZE - 1)) == 0);
 	return set_extent_delalloc(&BTRFS_I(inode)->io_tree, start, end,
@@ -1993,7 +1993,7 @@ again:
 	page_start = page_offset(page);
-	page_end = page_offset(page) + PAGE_CACHE_SIZE - 1;
+	page_end = page_offset(page) + PAGE_SIZE - 1;
 	lock_extent_bits(&BTRFS_I(inode)->io_tree, page_start, page_end,
 			 &cached_state);
@@ -2003,7 +2003,7 @@ again:
 		goto out;
 	ordered = btrfs_lookup_ordered_range(inode, page_start,
-					PAGE_CACHE_SIZE);
+					PAGE_SIZE);
 	if (ordered) {
 		unlock_extent_cached(&BTRFS_I(inode)->io_tree, page_start,
 				     page_end, &cached_state, GFP_NOFS);
@@ -2014,7 +2014,7 @@ again:
 	ret = btrfs_delalloc_reserve_space(inode, page_start,
-					   PAGE_CACHE_SIZE);
+					   PAGE_SIZE);
 	if (ret) {
 		mapping_set_error(page->mapping, ret);
 		end_extent_writepage(page, ret, page_start, page_end);
@@ -2030,7 +2030,7 @@ out:
 out_page:
 	unlock_page(page);
-	page_cache_release(page);
+	put_page(page);
 	kfree(fixup);
@@ -2063,7 +2063,7 @@ static int btrfs_writepage_start_hook(struct page *page, u64 start, u64 end)
 		return -EAGAIN;
 	SetPageChecked(page);
+	get_page(page);
 	btrfs_init_work(&fixup->work, btrfs_fixup_helper,
 			btrfs_writepage_fixup_worker, NULL, NULL);
 	fixup->page = page;
@@ -4247,7 +4247,7 @@ static int truncate_inline_extent(struct inode *inode,
 	if (btrfs_file_extent_compression(leaf, fi) != BTRFS_COMPRESS_NONE) {
 		loff_t offset = new_size;
-		loff_t page_end = ALIGN(offset, PAGE_CACHE_SIZE);
+		loff_t page_end = ALIGN(offset, PAGE_SIZE);
 		 * Zero out the remaining of the last page of our inline extent,
@@ -4633,7 +4633,7 @@ int btrfs_truncate_block(struct inode *inode, loff_t from, loff_t len,
 	char *kaddr;
 	u32 blocksize = root->sectorsize;
-	pgoff_t index = from >> PAGE_CACHE_SHIFT;
+	pgoff_t index = from >> PAGE_SHIFT;
 	unsigned offset = from & (blocksize - 1);
 	struct page *page;
 	gfp_t mask = btrfs_alloc_write_mask(mapping);
@@ -4668,7 +4668,7 @@ again:
 		lock_page(page);
 			unlock_page(page);
+			put_page(page);
 			goto again;
 		if (!PageUptodate(page)) {
@@ -4686,7 +4686,7 @@ again:
 		unlock_extent_cached(io_tree, block_start, block_end,
 		unlock_page(page);
+		put_page(page);
 		goto again;
@@ -4728,7 +4728,7 @@ out_unlock:
 		btrfs_delalloc_release_space(inode, block_start,
 					     blocksize);
 	unlock_page(page);
+	put_page(page);
 out:
 	return ret;
@@ -6717,7 +6717,7 @@ static noinline int uncompress_inline(struct btrfs_path *path,
 	read_extent_buffer(leaf, tmp, ptr, inline_size);
-	max_size = min_t(unsigned long, PAGE_CACHE_SIZE, max_size);
+	max_size = min_t(unsigned long, PAGE_SIZE, max_size);
 	ret = btrfs_decompress(compress_type, tmp, page,
 			       extent_offset, inline_size, max_size);
 	kfree(tmp);
@@ -6879,8 +6879,8 @@ next:
 		size = btrfs_file_extent_inline_len(leaf, path->slots[0], item);
 		extent_offset = page_offset(page) + pg_offset - extent_start;
-		copy_size = min_t(u64, PAGE_CACHE_SIZE - pg_offset,
-				size - extent_offset);
+		copy_size = min_t(u64, PAGE_SIZE - pg_offset,
+				  size - extent_offset);
 		em->start = extent_start + extent_offset;
 		em->len = ALIGN(copy_size, root->sectorsize);
 		em->orig_block_len = em->len;
@@ -6899,9 +6899,9 @@ next:
 				map = kmap(page);
 				read_extent_buffer(leaf, map + pg_offset, ptr,
 						   copy_size);
-				if (pg_offset + copy_size < PAGE_CACHE_SIZE) {
+				if (pg_offset + copy_size < PAGE_SIZE) {
 					memset(map + pg_offset + copy_size, 0,
-					       PAGE_CACHE_SIZE - pg_offset -
+					       PAGE_SIZE - pg_offset -
 					       copy_size);
 				kunmap(page);
@@ -7336,12 +7336,12 @@ bool btrfs_page_exists_in_range(struct inode *inode, loff_t start, loff_t end)
 	int start_idx;
 	int end_idx;
-	start_idx = start >> PAGE_CACHE_SHIFT;
+	start_idx = start >> PAGE_SHIFT;
 	 * end is the last byte in the last page.  end == start is legal
-	end_idx = end >> PAGE_CACHE_SHIFT;
+	end_idx = end >> PAGE_SHIFT;
 	rcu_read_lock();
@@ -7382,7 +7382,7 @@ bool btrfs_page_exists_in_range(struct inode *inode, loff_t start, loff_t end)
 		 * include/linux/pagemap.h for details.
 		if (unlikely(page != *pagep)) {
+			put_page(page);
 			page = NULL;
@@ -7390,7 +7390,7 @@ bool btrfs_page_exists_in_range(struct inode *inode, loff_t start, loff_t end)
 	if (page) {
 		if (page->index <= end_idx)
 			found = true;
+		put_page(page);
 	rcu_read_unlock();
@@ -8719,7 +8719,7 @@ static int __btrfs_releasepage(struct page *page, gfp_t gfp_flags)
 	if (ret == 1) {
+		put_page(page);
 	return ret;
@@ -8739,7 +8739,7 @@ static void btrfs_invalidatepage(struct page *page, unsigned int offset,
 	u64 page_start = page_offset(page);
-	u64 page_end = page_start + PAGE_CACHE_SIZE - 1;
+	u64 page_end = page_start + PAGE_SIZE - 1;
 	u64 start;
 	u64 end;
 	int inode_evicting = inode->i_state & I_FREEING;
@@ -8822,7 +8822,7 @@ again:
 	 * 2) Not written to disk
 	 *    This means the reserved space should be freed here.
-	btrfs_qgroup_free_data(inode, page_start, PAGE_CACHE_SIZE);
+	btrfs_qgroup_free_data(inode, page_start, PAGE_SIZE);
 	if (!inode_evicting) {
 		clear_extent_bit(tree, page_start, page_end,
 				 EXTENT_LOCKED | EXTENT_DIRTY |
@@ -8837,7 +8837,7 @@ again:
 	if (PagePrivate(page)) {
+		put_page(page);
@@ -8874,11 +8874,11 @@ int btrfs_page_mkwrite(struct vm_area_struct *vma, struct vm_fault *vmf)
 	u64 page_end;
 	u64 end;
-	reserved_space = PAGE_CACHE_SIZE;
+	reserved_space = PAGE_SIZE;
 	sb_start_pagefault(inode->i_sb);
-	page_end = page_start + PAGE_CACHE_SIZE - 1;
+	page_end = page_start + PAGE_SIZE - 1;
 	end = page_end;
@@ -8934,15 +8934,15 @@ again:
 		goto again;
-	if (page->index == ((size - 1) >> PAGE_CACHE_SHIFT)) {
+	if (page->index == ((size - 1) >> PAGE_SHIFT)) {
 		reserved_space = round_up(size - page_start, root->sectorsize);
-		if (reserved_space < PAGE_CACHE_SIZE) {
+		if (reserved_space < PAGE_SIZE) {
 			end = page_start + reserved_space - 1;
 			spin_lock(&BTRFS_I(inode)->lock);
 			BTRFS_I(inode)->outstanding_extents++;
 			spin_unlock(&BTRFS_I(inode)->lock);
 			btrfs_delalloc_release_space(inode, page_start,
-						PAGE_CACHE_SIZE - reserved_space);
+						PAGE_SIZE - reserved_space);
@@ -8969,14 +8969,14 @@ again:
 	ret = 0;
 	/* page is wholly or partially inside EOF */
-	if (page_start + PAGE_CACHE_SIZE > size)
-		zero_start = size & ~PAGE_CACHE_MASK;
+	if (page_start + PAGE_SIZE > size)
+		zero_start = size & ~PAGE_MASK;
 	else
-		zero_start = PAGE_CACHE_SIZE;
+		zero_start = PAGE_SIZE;
-	if (zero_start != PAGE_CACHE_SIZE) {
+	if (zero_start != PAGE_SIZE) {
 		kaddr = kmap(page);
-		memset(kaddr + zero_start, 0, PAGE_CACHE_SIZE - zero_start);
+		memset(kaddr + zero_start, 0, PAGE_SIZE - zero_start);
 		flush_dcache_page(page);
 		kunmap(page);
diff --git a/fs/btrfs/ioctl.c b/fs/btrfs/ioctl.c
index 053e677..94a0c8a 100644
--- a/fs/btrfs/ioctl.c
+++ b/fs/btrfs/ioctl.c
@@ -898,7 +898,7 @@ static int check_defrag_in_cache(struct inode *inode, u64 offset, u32 thresh)
 	u64 end;
-	em = lookup_extent_mapping(em_tree, offset, PAGE_CACHE_SIZE);
+	em = lookup_extent_mapping(em_tree, offset, PAGE_SIZE);
 	if (em) {
@@ -988,7 +988,7 @@ static struct extent_map *defrag_lookup_extent(struct inode *inode, u64 start)
 	struct extent_map_tree *em_tree = &BTRFS_I(inode)->extent_tree;
 	struct extent_io_tree *io_tree = &BTRFS_I(inode)->io_tree;
-	u64 len = PAGE_CACHE_SIZE;
+	u64 len = PAGE_SIZE;
 	 * hopefully we have this extent in the tree already, try without
@@ -1124,15 +1124,15 @@ static int cluster_pages_for_defrag(struct inode *inode,
 	struct extent_io_tree *tree;
-	file_end = (isize - 1) >> PAGE_CACHE_SHIFT;
+	file_end = (isize - 1) >> PAGE_SHIFT;
 	if (!isize || start_index > file_end)
 		return 0;
 	page_cnt = min_t(u64, (u64)num_pages, (u64)file_end - start_index + 1);
-			start_index << PAGE_CACHE_SHIFT,
-			page_cnt << PAGE_CACHE_SHIFT);
+			start_index << PAGE_SHIFT,
+			page_cnt << PAGE_SHIFT);
 	if (ret)
 		return ret;
 	i_done = 0;
@@ -1148,7 +1148,7 @@ again:
 			break;
 		while (1) {
 			lock_extent_bits(tree, page_start, page_end,
 					 &cached_state);
@@ -1169,7 +1169,7 @@ again:
 			if (page->mapping != inode->i_mapping) {
 				unlock_page(page);
+				put_page(page);
 				goto again;
@@ -1179,7 +1179,7 @@ again:
 			lock_page(page);
 				unlock_page(page);
+				put_page(page);
 				ret = -EIO;
 				break;
@@ -1187,7 +1187,7 @@ again:
 			unlock_page(page);
+			put_page(page);
 			goto again;
@@ -1208,7 +1208,7 @@ again:
 		wait_on_page_writeback(pages[i]);
 	page_start = page_offset(pages[0]);
-	page_end = page_offset(pages[i_done - 1]) + PAGE_CACHE_SIZE;
+	page_end = page_offset(pages[i_done - 1]) + PAGE_SIZE;
 			 page_start, page_end - 1, &cached_state);
@@ -1222,8 +1222,8 @@ again:
-				(page_cnt - i_done) << PAGE_CACHE_SHIFT);
+				(page_cnt - i_done) << PAGE_SHIFT);
@@ -1240,17 +1240,17 @@ again:
 		set_page_extent_mapped(pages[i]);
 		set_page_dirty(pages[i]);
 	return i_done;
 out:
 	for (i = 0; i < i_done; i++) {
 	return ret;
@@ -1273,7 +1273,7 @@ int btrfs_defrag_file(struct inode *inode, struct file *file,
 	int defrag_count = 0;
 	int compress_type = BTRFS_COMPRESS_ZLIB;
 	u32 extent_thresh = range->extent_thresh;
-	unsigned long max_cluster = SZ_256K >> PAGE_CACHE_SHIFT;
+	unsigned long max_cluster = SZ_256K >> PAGE_SHIFT;
 	unsigned long cluster = max_cluster;
 	u64 new_align = ~((u64)SZ_128K - 1);
 	struct page **pages = NULL;
@@ -1317,9 +1317,9 @@ int btrfs_defrag_file(struct inode *inode, struct file *file,
 	/* find the last page to defrag */
 	if (range->start + range->len > range->start) {
 		last_index = min_t(u64, isize - 1,
-			 range->start + range->len - 1) >> PAGE_CACHE_SHIFT;
+			 range->start + range->len - 1) >> PAGE_SHIFT;
 	} else {
-		last_index = (isize - 1) >> PAGE_CACHE_SHIFT;
+		last_index = (isize - 1) >> PAGE_SHIFT;
 	if (newer_than) {
@@ -1331,11 +1331,11 @@ int btrfs_defrag_file(struct inode *inode, struct file *file,
 			 * we always align our defrag to help keep
 			 * the extents in the file evenly spaced
-			i = (newer_off & new_align) >> PAGE_CACHE_SHIFT;
+			i = (newer_off & new_align) >> PAGE_SHIFT;
 		} else
 			goto out_ra;
 	} else {
-		i = range->start >> PAGE_CACHE_SHIFT;
+		i = range->start >> PAGE_SHIFT;
 	if (!max_to_defrag)
 		max_to_defrag = last_index - i + 1;
@@ -1348,7 +1348,7 @@ int btrfs_defrag_file(struct inode *inode, struct file *file,
 		inode->i_mapping->writeback_index = i;
 	while (i <= last_index && defrag_count < max_to_defrag &&
-	       (i < DIV_ROUND_UP(i_size_read(inode), PAGE_CACHE_SIZE))) {
+	       (i < DIV_ROUND_UP(i_size_read(inode), PAGE_SIZE))) {
 		 * make sure we stop running if someone unmounts
 		 * the FS
@@ -1362,7 +1362,7 @@ int btrfs_defrag_file(struct inode *inode, struct file *file,
 			break;
-		if (!should_defrag_range(inode, (u64)i << PAGE_CACHE_SHIFT,
+		if (!should_defrag_range(inode, (u64)i << PAGE_SHIFT,
 					 extent_thresh, &last_len, &skip,
 					 &defrag_end, range->flags &
 					 BTRFS_DEFRAG_RANGE_COMPRESS)) {
@@ -1371,14 +1371,14 @@ int btrfs_defrag_file(struct inode *inode, struct file *file,
 			 * the should_defrag function tells us how much to skip
 			 * bump our counter by the suggested amount
-			next = DIV_ROUND_UP(skip, PAGE_CACHE_SIZE);
+			next = DIV_ROUND_UP(skip, PAGE_SIZE);
 			i = max(i + 1, next);
 			continue;
 		if (!newer_than) {
-			cluster = (PAGE_CACHE_ALIGN(defrag_end) >>
-				   PAGE_CACHE_SHIFT) - i;
+			cluster = (PAGE_ALIGN(defrag_end) >>
+				   PAGE_SHIFT) - i;
 			cluster = min(cluster, max_cluster);
 		} else {
@@ -1412,20 +1412,20 @@ int btrfs_defrag_file(struct inode *inode, struct file *file,
 				i += ret;
 			newer_off = max(newer_off + 1,
-					(u64)i << PAGE_CACHE_SHIFT);
+					(u64)i << PAGE_SHIFT);
 			ret = find_new_extents(root, inode, newer_than,
 					       &newer_off, SZ_64K);
 			if (!ret) {
 				range->start = newer_off;
 			} else {
 				break;
 		} else {
 			if (ret > 0) {
 				i += ret;
-				last_len += ret << PAGE_CACHE_SHIFT;
+				last_len += ret << PAGE_SHIFT;
 			} else {
 				i++;
 				last_len = 0;
@@ -1722,7 +1722,7 @@ static noinline int btrfs_ioctl_snap_create_v2(struct file *file,
 	if (vol_args->flags & BTRFS_SUBVOL_RDONLY)
 		readonly = true;
 	if (vol_args->flags & BTRFS_SUBVOL_QGROUP_INHERIT) {
-		if (vol_args->size > PAGE_CACHE_SIZE) {
+		if (vol_args->size > PAGE_SIZE) {
 			ret = -EINVAL;
 			goto free_args;
@@ -2806,12 +2806,12 @@ static struct page *extent_same_get_page(struct inode *inode, pgoff_t index)
 		lock_page(page);
 			unlock_page(page);
+			put_page(page);
 			return ERR_PTR(-EIO);
 			unlock_page(page);
+			put_page(page);
 			return ERR_PTR(-EAGAIN);
@@ -2823,7 +2823,7 @@ static int gather_extent_pages(struct inode *inode, struct page **pages,
 			       int num_pages, u64 off)
 	int i;
-	pgoff_t index = off >> PAGE_CACHE_SHIFT;
+	pgoff_t index = off >> PAGE_SHIFT;
 	for (i = 0; i < num_pages; i++) {
 again:
@@ -2932,12 +2932,12 @@ static void btrfs_cmp_data_free(struct cmp_pages *cmp)
 		pg = cmp->src_pages[i];
 		if (pg) {
 			unlock_page(pg);
-			page_cache_release(pg);
+			put_page(pg);
 		pg = cmp->dst_pages[i];
 		if (pg) {
 			unlock_page(pg);
+			put_page(pg);
 	kfree(cmp->src_pages);
@@ -2949,7 +2949,7 @@ static int btrfs_cmp_data_prepare(struct inode *src, u64 loff,
 				  u64 len, struct cmp_pages *cmp)
 	int ret;
-	int num_pages = PAGE_CACHE_ALIGN(len) >> PAGE_CACHE_SHIFT;
+	int num_pages = PAGE_ALIGN(len) >> PAGE_SHIFT;
 	struct page **src_pgarr, **dst_pgarr;
@@ -2987,12 +2987,12 @@ static int btrfs_cmp_data(struct inode *src, u64 loff, struct inode *dst,
 	int ret = 0;
 	int i;
 	struct page *src_page, *dst_page;
-	unsigned int cmp_len = PAGE_CACHE_SIZE;
+	unsigned int cmp_len = PAGE_SIZE;
 	void *addr, *dst_addr;
 	i = 0;
 	while (len) {
-		if (len < PAGE_CACHE_SIZE)
+		if (len < PAGE_SIZE)
 			cmp_len = len;
 		BUG_ON(i >= cmp->num_pages);
@@ -3191,7 +3191,7 @@ ssize_t btrfs_dedupe_file_range(struct file *src_file, u64 loff, u64 olen,
 	if (olen > BTRFS_MAX_DEDUPE_LEN)
 		olen = BTRFS_MAX_DEDUPE_LEN;
-	if (WARN_ON_ONCE(bs < PAGE_CACHE_SIZE)) {
+	if (WARN_ON_ONCE(bs < PAGE_SIZE)) {
 		 * Btrfs does not support blocksize < page_size. As a
 		 * result, btrfs_cmp_data() won't correctly handle
@@ -3891,8 +3891,8 @@ static noinline int btrfs_clone_files(struct file *file, struct file *file_src,
 	 * data immediately and not the previous data.
 	truncate_inode_pages_range(&inode->i_data,
-				round_down(destoff, PAGE_CACHE_SIZE),
-				round_up(destoff + len, PAGE_CACHE_SIZE) - 1);
+				round_down(destoff, PAGE_SIZE),
+				round_up(destoff + len, PAGE_SIZE) - 1);
 out_unlock:
 	if (!same_inode)
 		btrfs_double_inode_unlock(src, inode);
@@ -4124,7 +4124,7 @@ static long btrfs_ioctl_space_info(struct btrfs_root *root, void __user *arg)
 	/* we generally have at most 6 or so space infos, one for each raid
 	 * level.  So, a whole page should be more than enough for everyone
-	if (alloc_size > PAGE_CACHE_SIZE)
+	if (alloc_size > PAGE_SIZE)
 		return -ENOMEM;
 	space_args.total_spaces = 0;
diff --git a/fs/btrfs/lzo.c b/fs/btrfs/lzo.c
index a2f0513..1adfbe7 100644
--- a/fs/btrfs/lzo.c
+++ b/fs/btrfs/lzo.c
@@ -55,8 +55,8 @@ static struct list_head *lzo_alloc_workspace(void)
 		return ERR_PTR(-ENOMEM);
 	workspace->mem = vmalloc(LZO1X_MEM_COMPRESS);
-	workspace->buf = vmalloc(lzo1x_worst_compress(PAGE_CACHE_SIZE));
-	workspace->cbuf = vmalloc(lzo1x_worst_compress(PAGE_CACHE_SIZE));
+	workspace->buf = vmalloc(lzo1x_worst_compress(PAGE_SIZE));
+	workspace->cbuf = vmalloc(lzo1x_worst_compress(PAGE_SIZE));
 	if (!workspace->mem || !workspace->buf || !workspace->cbuf)
 		goto fail;
@@ -116,7 +116,7 @@ static int lzo_compress_pages(struct list_head *ws,
 	*total_out = 0;
 	*total_in = 0;
-	in_page = find_get_page(mapping, start >> PAGE_CACHE_SHIFT);
+	in_page = find_get_page(mapping, start >> PAGE_SHIFT);
 	data_in = kmap(in_page);
@@ -133,10 +133,10 @@ static int lzo_compress_pages(struct list_head *ws,
 	tot_out = LZO_LEN;
 	pages[0] = out_page;
 	nr_pages = 1;
-	pg_bytes_left = PAGE_CACHE_SIZE - LZO_LEN;
+	pg_bytes_left = PAGE_SIZE - LZO_LEN;
 	/* compress at most one page of data each time */
-	in_len = min(len, PAGE_CACHE_SIZE);
+	in_len = min(len, PAGE_SIZE);
 	while (tot_in < len) {
 		ret = lzo1x_1_compress(data_in, in_len, workspace->cbuf,
 				       &out_len, workspace->mem);
@@ -201,7 +201,7 @@ static int lzo_compress_pages(struct list_head *ws,
 				cpage_out = kmap(out_page);
 				pages[nr_pages++] = out_page;
-				pg_bytes_left = PAGE_CACHE_SIZE;
+				pg_bytes_left = PAGE_SIZE;
 				out_offset = 0;
@@ -221,12 +221,12 @@ static int lzo_compress_pages(struct list_head *ws,
 		bytes_left = len - tot_in;
 		kunmap(in_page);
-		page_cache_release(in_page);
+		put_page(in_page);
-		in_len = min(bytes_left, PAGE_CACHE_SIZE);
+		in_len = min(bytes_left, PAGE_SIZE);
 	if (tot_out > tot_in)
@@ -248,7 +248,7 @@ out:
 	if (in_page) {
 		kunmap(in_page);
 	return ret;
@@ -266,7 +266,7 @@ static int lzo_decompress_biovec(struct list_head *ws,
 	char *data_in;
 	unsigned long page_in_index = 0;
 	unsigned long page_out_index = 0;
-	unsigned long total_pages_in = DIV_ROUND_UP(srclen, PAGE_CACHE_SIZE);
+	unsigned long total_pages_in = DIV_ROUND_UP(srclen, PAGE_SIZE);
 	unsigned long buf_start;
 	unsigned long buf_offset = 0;
 	unsigned long bytes;
@@ -289,7 +289,7 @@ static int lzo_decompress_biovec(struct list_head *ws,
 	tot_in = LZO_LEN;
 	in_offset = LZO_LEN;
 	tot_len = min_t(size_t, srclen, tot_len);
-	in_page_bytes_left = PAGE_CACHE_SIZE - LZO_LEN;
+	in_page_bytes_left = PAGE_SIZE - LZO_LEN;
 	tot_out = 0;
 	pg_offset = 0;
@@ -345,12 +345,12 @@ cont:
 				data_in = kmap(pages_in[++page_in_index]);
-				in_page_bytes_left = PAGE_CACHE_SIZE;
+				in_page_bytes_left = PAGE_SIZE;
 				in_offset = 0;
-		out_len = lzo1x_worst_compress(PAGE_CACHE_SIZE);
+		out_len = lzo1x_worst_compress(PAGE_SIZE);
 		ret = lzo1x_decompress_safe(buf, in_len, workspace->buf,
 					    &out_len);
 		if (need_unmap)
@@ -399,7 +399,7 @@ static int lzo_decompress(struct list_head *ws, unsigned char *data_in,
 	in_len = read_compress_length(data_in);
 	data_in += LZO_LEN;
-	out_len = PAGE_CACHE_SIZE;
+	out_len = PAGE_SIZE;
 	ret = lzo1x_decompress_safe(data_in, in_len, workspace->buf, &out_len);
 	if (ret != LZO_E_OK) {
 		printk(KERN_WARNING "BTRFS: decompress failed!\n");
diff --git a/fs/btrfs/raid56.c b/fs/btrfs/raid56.c
index 5516136..0b7792e 100644
--- a/fs/btrfs/raid56.c
+++ b/fs/btrfs/raid56.c
@@ -270,7 +270,7 @@ static void cache_rbio_pages(struct btrfs_raid_bio *rbio)
 		s = kmap(rbio->bio_pages[i]);
 		d = kmap(rbio->stripe_pages[i]);
-		memcpy(d, s, PAGE_CACHE_SIZE);
+		memcpy(d, s, PAGE_SIZE);
 		kunmap(rbio->bio_pages[i]);
 		kunmap(rbio->stripe_pages[i]);
@@ -962,7 +962,7 @@ static struct page *page_in_rbio(struct btrfs_raid_bio *rbio,
 static unsigned long rbio_nr_pages(unsigned long stripe_len, int nr_stripes)
-	return DIV_ROUND_UP(stripe_len, PAGE_CACHE_SIZE) * nr_stripes;
+	return DIV_ROUND_UP(stripe_len, PAGE_SIZE) * nr_stripes;
@@ -1078,7 +1078,7 @@ static int rbio_add_io_page(struct btrfs_raid_bio *rbio,
 	u64 disk_start;
 	stripe = &rbio->bbio->stripes[stripe_nr];
-	disk_start = stripe->physical + (page_index << PAGE_CACHE_SHIFT);
+	disk_start = stripe->physical + (page_index << PAGE_SHIFT);
 	/* if the device is missing, just fail this stripe */
 	if (!stripe->dev->bdev)
@@ -1096,8 +1096,8 @@ static int rbio_add_io_page(struct btrfs_raid_bio *rbio,
 		if (last_end == disk_start && stripe->dev->bdev &&
 		    !last->bi_error &&
 		    last->bi_bdev == stripe->dev->bdev) {
-			ret = bio_add_page(last, page, PAGE_CACHE_SIZE, 0);
-			if (ret == PAGE_CACHE_SIZE)
+			ret = bio_add_page(last, page, PAGE_SIZE, 0);
+			if (ret == PAGE_SIZE)
 				return 0;
@@ -1111,7 +1111,7 @@ static int rbio_add_io_page(struct btrfs_raid_bio *rbio,
 	bio->bi_bdev = stripe->dev->bdev;
 	bio->bi_iter.bi_sector = disk_start >> 9;
-	bio_add_page(bio, page, PAGE_CACHE_SIZE, 0);
+	bio_add_page(bio, page, PAGE_SIZE, 0);
 	bio_list_add(bio_list, bio);
 	return 0;
@@ -1154,7 +1154,7 @@ static void index_rbio_pages(struct btrfs_raid_bio *rbio)
 	bio_list_for_each(bio, &rbio->bio_list) {
 		start = (u64)bio->bi_iter.bi_sector << 9;
 		stripe_offset = start - rbio->bbio->raid_map[0];
-		page_index = stripe_offset >> PAGE_CACHE_SHIFT;
+		page_index = stripe_offset >> PAGE_SHIFT;
 		for (i = 0; i < bio->bi_vcnt; i++) {
 			p = bio->bi_io_vec[i].bv_page;
@@ -1253,7 +1253,7 @@ static noinline void finish_rmw(struct btrfs_raid_bio *rbio)
 		} else {
 			/* raid5 */
 			memcpy(pointers[nr_data], pointers[0], PAGE_SIZE);
-			run_xor(pointers + 1, nr_data - 1, PAGE_CACHE_SIZE);
+			run_xor(pointers + 1, nr_data - 1, PAGE_SIZE);
@@ -1914,7 +1914,7 @@ pstripe:
 			/* Copy parity block into failed block to start with */
 			memcpy(pointers[faila],
 			       pointers[rbio->nr_data],
-			       PAGE_CACHE_SIZE);
+			       PAGE_SIZE);
 			/* rearrange the pointer array */
 			p = pointers[faila];
@@ -1923,7 +1923,7 @@ pstripe:
 			pointers[rbio->nr_data - 1] = p;
 			/* xor in the rest */
-			run_xor(pointers, rbio->nr_data - 1, PAGE_CACHE_SIZE);
+			run_xor(pointers, rbio->nr_data - 1, PAGE_SIZE);
 		/* if we're doing this rebuild as part of an rmw, go through
 		 * and set all of our private rbio pages in the
@@ -2250,7 +2250,7 @@ void raid56_add_scrub_pages(struct btrfs_raid_bio *rbio, struct page *page,
 	ASSERT(logical + PAGE_SIZE <= rbio->bbio->raid_map[0] +
 				rbio->stripe_len * rbio->nr_data);
 	stripe_offset = (int)(logical - rbio->bbio->raid_map[0]);
-	index = stripe_offset >> PAGE_CACHE_SHIFT;
+	index = stripe_offset >> PAGE_SHIFT;
 	rbio->bio_pages[index] = page;
@@ -2365,14 +2365,14 @@ static noinline void finish_parity_scrub(struct btrfs_raid_bio *rbio,
 		} else {
 			/* raid5 */
 		/* Check scrubbing pairty and repair it */
 		p = rbio_stripe_page(rbio, rbio->scrubp, pagenr);
 		parity = kmap(p);
-		if (memcmp(parity, pointers[rbio->scrubp], PAGE_CACHE_SIZE))
-			memcpy(parity, pointers[rbio->scrubp], PAGE_CACHE_SIZE);
+		if (memcmp(parity, pointers[rbio->scrubp], PAGE_SIZE))
+			memcpy(parity, pointers[rbio->scrubp], PAGE_SIZE);
 		else
 			/* Parity is right, needn't writeback */
 			bitmap_clear(rbio->dbitmap, pagenr, 1);
diff --git a/fs/btrfs/reada.c b/fs/btrfs/reada.c
index b8929149..298631ea 100644
--- a/fs/btrfs/reada.c
+++ b/fs/btrfs/reada.c
@@ -226,7 +226,7 @@ int btree_readahead_hook(struct btrfs_fs_info *fs_info,
 	/* find extent */
 	spin_lock(&fs_info->reada_lock);
 	re = radix_tree_lookup(&fs_info->reada_tree,
 	if (re)
 		re->refcnt++;
 	spin_unlock(&fs_info->reada_lock);
@@ -257,7 +257,7 @@ static struct reada_zone *reada_find_zone(struct btrfs_fs_info *fs_info,
 	zone = NULL;
 	ret = radix_tree_gang_lookup(&dev->reada_zones, (void **)&zone,
-				     logical >> PAGE_CACHE_SHIFT, 1);
+				     logical >> PAGE_SHIFT, 1);
 	if (ret == 1 && logical >= zone->start && logical <= zone->end) {
 		kref_get(&zone->refcnt);
@@ -294,13 +294,13 @@ static struct reada_zone *reada_find_zone(struct btrfs_fs_info *fs_info,
 	ret = radix_tree_insert(&dev->reada_zones,
-				(unsigned long)(zone->end >> PAGE_CACHE_SHIFT),
+				(unsigned long)(zone->end >> PAGE_SHIFT),
 				zone);
 		kfree(zone);
 		else
@@ -326,7 +326,7 @@ static struct reada_extent *reada_find_extent(struct btrfs_root *root,
 	u64 length;
 	int real_stripes;
 	int nzones = 0;
-	unsigned long index = logical >> PAGE_CACHE_SHIFT;
+	unsigned long index = logical >> PAGE_SHIFT;
 	int dev_replace_is_ongoing;
 	int have_zone = 0;
@@ -495,7 +495,7 @@ static void reada_extent_put(struct btrfs_fs_info *fs_info,
 			     struct reada_extent *re)
 	int i;
-	unsigned long index = re->logical >> PAGE_CACHE_SHIFT;
+	unsigned long index = re->logical >> PAGE_SHIFT;
 	if (--re->refcnt) {
@@ -538,7 +538,7 @@ static void reada_zone_release(struct kref *kref)
 	struct reada_zone *zone = container_of(kref, struct reada_zone, refcnt);
 	radix_tree_delete(&zone->device->reada_zones,
-			  zone->end >> PAGE_CACHE_SHIFT);
+			  zone->end >> PAGE_SHIFT);
 	kfree(zone);
@@ -587,7 +587,7 @@ static int reada_add_block(struct reada_control *rc, u64 logical,
 static void reada_peer_zones_set_lock(struct reada_zone *zone, int lock)
 	int i;
-	unsigned long index = zone->end >> PAGE_CACHE_SHIFT;
+	unsigned long index = zone->end >> PAGE_SHIFT;
 	for (i = 0; i < zone->ndevs; ++i) {
 		struct reada_zone *peer;
@@ -622,7 +622,7 @@ static int reada_pick_zone(struct btrfs_device *dev)
 					     (void **)&zone, index, 1);
 		if (ret == 0)
 			break;
-		index = (zone->end >> PAGE_CACHE_SHIFT) + 1;
+		index = (zone->end >> PAGE_SHIFT) + 1;
 		if (zone->locked) {
 			if (zone->elems > top_locked_elems) {
 				top_locked_elems = zone->elems;
@@ -673,7 +673,7 @@ static int reada_start_machine_dev(struct btrfs_fs_info *fs_info,
 	 * plugging to speed things up
 	ret = radix_tree_gang_lookup(&dev->reada_extents, (void **)&re,
-				     dev->reada_next >> PAGE_CACHE_SHIFT, 1);
+				     dev->reada_next >> PAGE_SHIFT, 1);
 	if (ret == 0 || re->logical > dev->reada_curr_zone->end) {
 		ret = reada_pick_zone(dev);
 		if (!ret) {
@@ -682,7 +682,7 @@ static int reada_start_machine_dev(struct btrfs_fs_info *fs_info,
 		re = NULL;
 	if (ret == 0) {
@@ -838,7 +838,7 @@ static void dump_devs(struct btrfs_fs_info *fs_info, int all)
 				printk(KERN_CONT " curr off %llu",
 					device->reada_next - zone->start);
 			printk(KERN_CONT "\n");
 		cnt = 0;
 		index = 0;
@@ -864,7 +864,7 @@ static void dump_devs(struct btrfs_fs_info *fs_info, int all)
-			index = (re->logical >> PAGE_CACHE_SHIFT) + 1;
+			index = (re->logical >> PAGE_SHIFT) + 1;
 			if (++cnt > 15)
 				break;
@@ -880,7 +880,7 @@ static void dump_devs(struct btrfs_fs_info *fs_info, int all)
 		if (ret == 0)
 			break;
 		if (!re->scheduled) {
 			continue;
 		printk(KERN_DEBUG
@@ -897,7 +897,7 @@ static void dump_devs(struct btrfs_fs_info *fs_info, int all)
diff --git a/fs/btrfs/relocation.c b/fs/btrfs/relocation.c
index 2bd0011..3c93968 100644
--- a/fs/btrfs/relocation.c
+++ b/fs/btrfs/relocation.c
@@ -3129,10 +3129,10 @@ static int relocate_file_extent_cluster(struct inode *inode,
 	if (ret)
 		goto out;
-	index = (cluster->start - offset) >> PAGE_CACHE_SHIFT;
-	last_index = (cluster->end - offset) >> PAGE_CACHE_SHIFT;
+	index = (cluster->start - offset) >> PAGE_SHIFT;
+	last_index = (cluster->end - offset) >> PAGE_SHIFT;
 	while (index <= last_index) {
-		ret = btrfs_delalloc_reserve_metadata(inode, PAGE_CACHE_SIZE);
+		ret = btrfs_delalloc_reserve_metadata(inode, PAGE_SIZE);
 		if (ret)
 			goto out;
@@ -3145,7 +3145,7 @@ static int relocate_file_extent_cluster(struct inode *inode,
 						   mask);
 			if (!page) {
 				btrfs_delalloc_release_metadata(inode,
-							PAGE_CACHE_SIZE);
+							PAGE_SIZE);
 				ret = -ENOMEM;
 				goto out;
@@ -3162,16 +3162,16 @@ static int relocate_file_extent_cluster(struct inode *inode,
 			lock_page(page);
 				unlock_page(page);
+				put_page(page);
-							PAGE_CACHE_SIZE);
+							PAGE_SIZE);
 				ret = -EIO;
 				goto out;
 		lock_extent(&BTRFS_I(inode)->io_tree, page_start, page_end);
@@ -3191,7 +3191,7 @@ static int relocate_file_extent_cluster(struct inode *inode,
 		unlock_extent(&BTRFS_I(inode)->io_tree,
 		unlock_page(page);
+		put_page(page);
 		index++;
diff --git a/fs/btrfs/scrub.c b/fs/btrfs/scrub.c
index 39dbdcb..4678f03 100644
--- a/fs/btrfs/scrub.c
+++ b/fs/btrfs/scrub.c
@@ -703,7 +703,7 @@ static int scrub_fixup_readpage(u64 inum, u64 offset, u64 root, void *fixup_ctx)
 	if (IS_ERR(inode))
 		return PTR_ERR(inode);
-	index = offset >> PAGE_CACHE_SHIFT;
+	index = offset >> PAGE_SHIFT;
 	page = find_or_create_page(inode->i_mapping, index, GFP_NOFS);
 	if (!page) {
@@ -1636,7 +1636,7 @@ static int scrub_write_page_to_dev_replace(struct scrub_block *sblock,
 	if (spage->io_error) {
 		void *mapped_buffer = kmap_atomic(spage->page);
-		memset(mapped_buffer, 0, PAGE_CACHE_SIZE);
+		memset(mapped_buffer, 0, PAGE_SIZE);
 		flush_dcache_page(spage->page);
 		kunmap_atomic(mapped_buffer);
@@ -4294,8 +4294,8 @@ static int copy_nocow_pages_for_inode(u64 inum, u64 offset, u64 root,
 		goto out;
-	while (len >= PAGE_CACHE_SIZE) {
+	while (len >= PAGE_SIZE) {
 again:
 		if (!page) {
@@ -4326,7 +4326,7 @@ again:
 				unlock_page(page);
+				put_page(page);
 				goto again;
@@ -4348,15 +4348,15 @@ again:
 			ret = err;
 next_page:
 		unlock_page(page);
+		put_page(page);
 		if (ret)
 			break;
-		physical_for_dev_replace += PAGE_CACHE_SIZE;
-		nocow_ctx_logical += PAGE_CACHE_SIZE;
-		len -= PAGE_CACHE_SIZE;
+		physical_for_dev_replace += PAGE_SIZE;
+		nocow_ctx_logical += PAGE_SIZE;
+		len -= PAGE_SIZE;
 	ret = COPY_COMPLETE;
 out:
@@ -4390,8 +4390,8 @@ static int write_page_nocow(struct scrub_ctx *sctx,
 	bio->bi_iter.bi_size = 0;
 	bio->bi_iter.bi_sector = physical_for_dev_replace >> 9;
 	bio->bi_bdev = dev->bdev;
-	ret = bio_add_page(bio, page, PAGE_CACHE_SIZE, 0);
-	if (ret != PAGE_CACHE_SIZE) {
+	ret = bio_add_page(bio, page, PAGE_SIZE, 0);
+	if (ret != PAGE_SIZE) {
 leave_with_eio:
 		bio_put(bio);
 		btrfs_dev_stat_inc_and_print(dev, BTRFS_DEV_STAT_WRITE_ERRS);
diff --git a/fs/btrfs/send.c b/fs/btrfs/send.c
index 19b7bf4..8d358c5 100644
--- a/fs/btrfs/send.c
+++ b/fs/btrfs/send.c
@@ -4449,9 +4449,9 @@ static ssize_t fill_read_buf(struct send_ctx *sctx, u64 offset, u32 len)
 	struct page *page;
 	char *addr;
 	struct btrfs_key key;
-	pgoff_t index = offset >> PAGE_CACHE_SHIFT;
+	pgoff_t index = offset >> PAGE_SHIFT;
 	pgoff_t last_index;
-	unsigned pg_offset = offset & ~PAGE_CACHE_MASK;
+	unsigned pg_offset = offset & ~PAGE_MASK;
 	ssize_t ret = 0;
 	key.objectid = sctx->cur_ino;
@@ -4471,7 +4471,7 @@ static ssize_t fill_read_buf(struct send_ctx *sctx, u64 offset, u32 len)
 	if (len == 0)
 		goto out;
-	last_index = (offset + len - 1) >> PAGE_CACHE_SHIFT;
+	last_index = (offset + len - 1) >> PAGE_SHIFT;
 	/* initial readahead */
 	memset(&sctx->ra, 0, sizeof(struct file_ra_state));
@@ -4481,7 +4481,7 @@ static ssize_t fill_read_buf(struct send_ctx *sctx, u64 offset, u32 len)
 		unsigned cur_len = min_t(unsigned, len,
 		page = find_or_create_page(inode->i_mapping, index, GFP_KERNEL);
 		if (!page) {
 			ret = -ENOMEM;
@@ -4493,7 +4493,7 @@ static ssize_t fill_read_buf(struct send_ctx *sctx, u64 offset, u32 len)
 			lock_page(page);
 				unlock_page(page);
+				put_page(page);
 				ret = -EIO;
 				break;
@@ -4503,7 +4503,7 @@ static ssize_t fill_read_buf(struct send_ctx *sctx, u64 offset, u32 len)
 		memcpy(sctx->read_buf + ret, addr + pg_offset, cur_len);
 		kunmap(page);
 		unlock_page(page);
+		put_page(page);
 		index++;
 		pg_offset = 0;
 		len -= cur_len;
@@ -4804,7 +4804,7 @@ static int clone_range(struct send_ctx *sctx,
 		type = btrfs_file_extent_type(leaf, ei);
 		if (type == BTRFS_FILE_EXTENT_INLINE) {
 			ext_len = btrfs_file_extent_inline_len(leaf, slot, ei);
-			ext_len = PAGE_CACHE_ALIGN(ext_len);
+			ext_len = PAGE_ALIGN(ext_len);
 		} else {
 			ext_len = btrfs_file_extent_num_bytes(leaf, ei);
@@ -4886,7 +4886,7 @@ static int send_write_or_clone(struct send_ctx *sctx,
 		 * but there may be items after this page.  Make
 		 * sure to send the whole thing
-		len = PAGE_CACHE_ALIGN(len);
+		len = PAGE_ALIGN(len);
 	} else {
 		len = btrfs_file_extent_num_bytes(path->nodes[0], ei);
diff --git a/fs/btrfs/tests/extent-io-tests.c b/fs/btrfs/tests/extent-io-tests.c
index 669b582..ac3a06d 100644
--- a/fs/btrfs/tests/extent-io-tests.c
+++ b/fs/btrfs/tests/extent-io-tests.c
@@ -32,8 +32,8 @@ static noinline int process_page_range(struct inode *inode, u64 start, u64 end,
 	int ret;
 	struct page *pages[16];
-	unsigned long index = start >> PAGE_CACHE_SHIFT;
-	unsigned long end_index = end >> PAGE_CACHE_SHIFT;
+	unsigned long index = start >> PAGE_SHIFT;
+	unsigned long end_index = end >> PAGE_SHIFT;
 	unsigned long nr_pages = end_index - index + 1;
 	int i;
 	int count = 0;
@@ -49,9 +49,9 @@ static noinline int process_page_range(struct inode *inode, u64 start, u64 end,
 				count++;
 			if (flags & PROCESS_UNLOCK && PageLocked(pages[i]))
 				unlock_page(pages[i]);
 			if (flags & PROCESS_RELEASE)
 		nr_pages -= ret;
 		index += ret;
@@ -93,7 +93,7 @@ static int test_find_delalloc(void)
 	 * everything to make sure our pages don't get evicted and screw up our
 	 * test.
-	for (index = 0; index < (total_dirty >> PAGE_CACHE_SHIFT); index++) {
+	for (index = 0; index < (total_dirty >> PAGE_SHIFT); index++) {
 		if (!page) {
 			test_msg("Failed to allocate test page\n");
@@ -104,7 +104,7 @@ static int test_find_delalloc(void)
 		if (index) {
 			unlock_page(page);
 		} else {
-			page_cache_get(page);
+			get_page(page);
 			locked_page = page;
@@ -129,7 +129,7 @@ static int test_find_delalloc(void)
 	unlock_extent(&tmp, start, end);
 	unlock_page(locked_page);
-	page_cache_release(locked_page);
+	put_page(locked_page);
 	 * Test this scenario
@@ -139,7 +139,7 @@ static int test_find_delalloc(void)
 	test_start = SZ_64M;
 	locked_page = find_lock_page(inode->i_mapping,
-				     test_start >> PAGE_CACHE_SHIFT);
+				     test_start >> PAGE_SHIFT);
 	if (!locked_page) {
 		test_msg("Couldn't find the locked page\n");
 		goto out_bits;
@@ -165,7 +165,7 @@ static int test_find_delalloc(void)
 	/* locked_page was unlocked above */
@@ -174,7 +174,7 @@ static int test_find_delalloc(void)
 	test_start = max_bytes + 4096;
 	locked_page = find_lock_page(inode->i_mapping, test_start >>
-				     PAGE_CACHE_SHIFT);
+				     PAGE_SHIFT);
 	if (!locked_page) {
 		test_msg("Could'nt find the locked page\n");
 		goto out_bits;
@@ -225,13 +225,13 @@ static int test_find_delalloc(void)
 	 * range we want to find.
 	page = find_get_page(inode->i_mapping,
-			     (max_bytes + SZ_1M) >> PAGE_CACHE_SHIFT);
+			     (max_bytes + SZ_1M) >> PAGE_SHIFT);
 	if (!page) {
 		test_msg("Couldn't find our page\n");
 		goto out_bits;
 	ClearPageDirty(page);
+	put_page(page);
 	/* We unlocked it in the previous test */
@@ -249,9 +249,9 @@ static int test_find_delalloc(void)
 		test_msg("Didn't find our range\n");
 		goto out_bits;
-	if (start != test_start && end != test_start + PAGE_CACHE_SIZE - 1) {
+	if (start != test_start && end != test_start + PAGE_SIZE - 1) {
 		test_msg("Expected start %Lu end %Lu, got start %Lu end %Lu\n",
-			 test_start, test_start + PAGE_CACHE_SIZE - 1, start,
+			 test_start, test_start + PAGE_SIZE - 1, start,
 			 end);
 		goto out_bits;
@@ -265,7 +265,7 @@ out_bits:
 	clear_extent_bits(&tmp, 0, total_dirty - 1, (unsigned)-1, GFP_KERNEL);
 out:
 	if (locked_page)
 	process_page_range(inode, 0, total_dirty - 1,
 			   PROCESS_UNLOCK | PROCESS_RELEASE);
 	iput(inode);
@@ -298,9 +298,9 @@ static int __test_eb_bitmaps(unsigned long *bitmap, struct extent_buffer *eb,
 		return -EINVAL;
-	bitmap_set(bitmap, (PAGE_CACHE_SIZE - sizeof(long) / 2) * BITS_PER_BYTE,
+	bitmap_set(bitmap, (PAGE_SIZE - sizeof(long) / 2) * BITS_PER_BYTE,
 		   sizeof(long) * BITS_PER_BYTE);
-	extent_buffer_bitmap_set(eb, PAGE_CACHE_SIZE - sizeof(long) / 2, 0,
+	extent_buffer_bitmap_set(eb, PAGE_SIZE - sizeof(long) / 2, 0,
 	if (memcmp_extent_buffer(eb, bitmap, 0, len) != 0) {
 		test_msg("Setting straddling pages failed\n");
@@ -309,10 +309,10 @@ static int __test_eb_bitmaps(unsigned long *bitmap, struct extent_buffer *eb,
 	bitmap_set(bitmap, 0, len * BITS_PER_BYTE);
 	bitmap_clear(bitmap,
-		     (PAGE_CACHE_SIZE - sizeof(long) / 2) * BITS_PER_BYTE,
+		     (PAGE_SIZE - sizeof(long) / 2) * BITS_PER_BYTE,
 	extent_buffer_bitmap_set(eb, 0, 0, len * BITS_PER_BYTE);
-	extent_buffer_bitmap_clear(eb, PAGE_CACHE_SIZE - sizeof(long) / 2, 0,
+	extent_buffer_bitmap_clear(eb, PAGE_SIZE - sizeof(long) / 2, 0,
 		test_msg("Clearing straddling pages failed\n");
@@ -353,7 +353,7 @@ static int __test_eb_bitmaps(unsigned long *bitmap, struct extent_buffer *eb,
 static int test_eb_bitmaps(void)
-	unsigned long len = PAGE_CACHE_SIZE * 4;
+	unsigned long len = PAGE_SIZE * 4;
 	unsigned long *bitmap;
 	int ret;
@@ -379,7 +379,7 @@ static int test_eb_bitmaps(void)
 	/* Do it over again with an extent buffer which isn't page-aligned. */
 	free_extent_buffer(eb);
-	eb = __alloc_dummy_extent_buffer(NULL, PAGE_CACHE_SIZE / 2, len);
+	eb = __alloc_dummy_extent_buffer(NULL, PAGE_SIZE / 2, len);
 	if (!eb) {
 		test_msg("Couldn't allocate test extent buffer\n");
 		kfree(bitmap);
diff --git a/fs/btrfs/tests/free-space-tests.c b/fs/btrfs/tests/free-space-tests.c
index c9ad97b..5142475 100644
--- a/fs/btrfs/tests/free-space-tests.c
+++ b/fs/btrfs/tests/free-space-tests.c
@@ -22,7 +22,7 @@
 #include "../disk-io.h"
 #include "../free-space-cache.h"
  * This test just does basic sanity checking, making sure we can add an exten
diff --git a/fs/btrfs/volumes.c b/fs/btrfs/volumes.c
index e2b54d5..bd0f45f 100644
--- a/fs/btrfs/volumes.c
+++ b/fs/btrfs/volumes.c
@@ -1025,16 +1025,16 @@ int btrfs_scan_one_device(const char *path, fmode_t flags, void *holder,
 	/* make sure our super fits in the device */
-	if (bytenr + PAGE_CACHE_SIZE >= i_size_read(bdev->bd_inode))
+	if (bytenr + PAGE_SIZE >= i_size_read(bdev->bd_inode))
 		goto error_bdev_put;
 	/* make sure our super fits in the page */
-	if (sizeof(*disk_super) > PAGE_CACHE_SIZE)
+	if (sizeof(*disk_super) > PAGE_SIZE)
 	/* make sure our super doesn't straddle pages on disk */
-	index = bytenr >> PAGE_CACHE_SHIFT;
-	if ((bytenr + sizeof(*disk_super) - 1) >> PAGE_CACHE_SHIFT != index)
+	index = bytenr >> PAGE_SHIFT;
+	if ((bytenr + sizeof(*disk_super) - 1) >> PAGE_SHIFT != index)
 	/* pull in the page with our super */
@@ -1047,7 +1047,7 @@ int btrfs_scan_one_device(const char *path, fmode_t flags, void *holder,
 	p = kmap(page);
 	/* align our pointer to the offset of the super block */
-	disk_super = p + (bytenr & ~PAGE_CACHE_MASK);
+	disk_super = p + (bytenr & ~PAGE_MASK);
 	if (btrfs_super_bytenr(disk_super) != bytenr ||
 	    btrfs_super_magic(disk_super) != BTRFS_MAGIC)
@@ -1075,7 +1075,7 @@ int btrfs_scan_one_device(const char *path, fmode_t flags, void *holder,
 error_unmap:
 	kunmap(page);
+	put_page(page);
 error_bdev_put:
 	blkdev_put(bdev, flags);
@@ -6527,7 +6527,7 @@ int btrfs_read_sys_array(struct btrfs_root *root)
 	 * but sb spans only this function. Add an explicit SetPageUptodate call
 	 * to silence the warning eg. on PowerPC 64.
-	if (PAGE_CACHE_SIZE > BTRFS_SUPER_INFO_SIZE)
+	if (PAGE_SIZE > BTRFS_SUPER_INFO_SIZE)
 		SetPageUptodate(sb->pages[0]);
 	write_extent_buffer(sb, super_copy, 0, BTRFS_SUPER_INFO_SIZE);
diff --git a/fs/btrfs/zlib.c b/fs/btrfs/zlib.c
index 82990b8..88d274e 100644
--- a/fs/btrfs/zlib.c
+++ b/fs/btrfs/zlib.c
@@ -59,7 +59,7 @@ static struct list_head *zlib_alloc_workspace(void)
 	workspacesize = max(zlib_deflate_workspacesize(MAX_WBITS, MAX_MEM_LEVEL),
 			zlib_inflate_workspacesize());
 	workspace->strm.workspace = vmalloc(workspacesize);
-	workspace->buf = kmalloc(PAGE_CACHE_SIZE, GFP_NOFS);
+	workspace->buf = kmalloc(PAGE_SIZE, GFP_NOFS);
 	if (!workspace->strm.workspace || !workspace->buf)
 		goto fail;
@@ -103,7 +103,7 @@ static int zlib_compress_pages(struct list_head *ws,
 	workspace->strm.total_in = 0;
 	workspace->strm.total_out = 0;
 	out_page = alloc_page(GFP_NOFS | __GFP_HIGHMEM);
@@ -117,8 +117,8 @@ static int zlib_compress_pages(struct list_head *ws,
 	workspace->strm.next_in = data_in;
 	workspace->strm.next_out = cpage_out;
-	workspace->strm.avail_out = PAGE_CACHE_SIZE;
-	workspace->strm.avail_in = min(len, PAGE_CACHE_SIZE);
+	workspace->strm.avail_out = PAGE_SIZE;
+	workspace->strm.avail_in = min(len, PAGE_SIZE);
 	while (workspace->strm.total_in < len) {
 		ret = zlib_deflate(&workspace->strm, Z_SYNC_FLUSH);
@@ -156,7 +156,7 @@ static int zlib_compress_pages(struct list_head *ws,
 			pages[nr_pages] = out_page;
 			nr_pages++;
 		/* we're all done */
@@ -170,14 +170,14 @@ static int zlib_compress_pages(struct list_head *ws,
 			bytes_left = len - workspace->strm.total_in;
 			kunmap(in_page);
-			start += PAGE_CACHE_SIZE;
+			start += PAGE_SIZE;
-						start >> PAGE_CACHE_SHIFT);
+						start >> PAGE_SHIFT);
 			workspace->strm.avail_in = min(bytes_left,
-							   PAGE_CACHE_SIZE);
+							   PAGE_SIZE);
@@ -205,7 +205,7 @@ out:
 	if (in_page) {
 		kunmap(in_page);
 	return ret;
@@ -223,18 +223,18 @@ static int zlib_decompress_biovec(struct list_head *ws, struct page **pages_in,
 	size_t total_out = 0;
 	unsigned long pg_offset;
 	data_in = kmap(pages_in[page_in_index]);
-	workspace->strm.avail_in = min_t(size_t, srclen, PAGE_CACHE_SIZE);
+	workspace->strm.avail_in = min_t(size_t, srclen, PAGE_SIZE);
 	workspace->strm.next_out = workspace->buf;
 	pg_offset = 0;
 	/* If it's deflate, and it's got no preset dictionary, then
@@ -274,7 +274,7 @@ static int zlib_decompress_biovec(struct list_head *ws, struct page **pages_in,
 		if (workspace->strm.avail_in == 0) {
 			unsigned long tmp;
@@ -288,7 +288,7 @@ static int zlib_decompress_biovec(struct list_head *ws, struct page **pages_in,
 			tmp = srclen - workspace->strm.total_in;
 			workspace->strm.avail_in = min(tmp,
-							   PAGE_CACHE_SIZE);
+							   PAGE_SIZE);
 	if (ret != Z_STREAM_END)
@@ -325,7 +325,7 @@ static int zlib_decompress(struct list_head *ws, unsigned char *data_in,
 	   we can tell zlib to skip the adler32 check. */
@@ -368,8 +368,8 @@ static int zlib_decompress(struct list_head *ws, unsigned char *data_in,
 		else
 			buf_offset = 0;
-		bytes = min(PAGE_CACHE_SIZE - pg_offset,
-			    PAGE_CACHE_SIZE - buf_offset);
+		bytes = min(PAGE_SIZE - pg_offset,
+			    PAGE_SIZE - buf_offset);
 		bytes = min(bytes, bytes_left);
 		kaddr = kmap_atomic(dest_page);
@@ -380,7 +380,7 @@ static int zlib_decompress(struct list_head *ws, unsigned char *data_in,
 		bytes_left -= bytes;
 next:
 	if (ret != Z_STREAM_END && bytes_left != 0)
diff --git a/fs/buffer.c b/fs/buffer.c
index 33be296..af0d9a8 100644
--- a/fs/buffer.c
+++ b/fs/buffer.c
@@ -129,7 +129,7 @@ __clear_page_buffers(struct page *page)
 	ClearPagePrivate(page);
 	set_page_private(page, 0);
+	put_page(page);
 static void buffer_io_error(struct buffer_head *bh, char *msg)
@@ -207,7 +207,7 @@ __find_get_block_slow(struct block_device *bdev, sector_t block)
 	struct page *page;
 	int all_mapped = 1;
-	index = block >> (PAGE_CACHE_SHIFT - bd_inode->i_blkbits);
+	index = block >> (PAGE_SHIFT - bd_inode->i_blkbits);
 	page = find_get_page_flags(bd_mapping, index, FGP_ACCESSED);
 	if (!page)
 		goto out;
@@ -245,7 +245,7 @@ __find_get_block_slow(struct block_device *bdev, sector_t block)
 out_unlock:
 	spin_unlock(&bd_mapping->private_lock);
+	put_page(page);
 out:
 	return ret;
@@ -1040,7 +1040,7 @@ done:
 	ret = (block < end_block) ? 1 : -ENXIO;
 failed:
 	unlock_page(page);
+	put_page(page);
 	return ret;
@@ -1533,7 +1533,7 @@ void block_invalidatepage(struct page *page, unsigned int offset,
 	 * Check for overflow
-	BUG_ON(stop > PAGE_CACHE_SIZE || stop < length);
+	BUG_ON(stop > PAGE_SIZE || stop < length);
 	head = page_buffers(page);
 	bh = head;
@@ -1716,7 +1716,7 @@ static int __block_write_full_page(struct inode *inode, struct page *page,
 	blocksize = bh->b_size;
 	bbits = block_size_bits(blocksize);
-	block = (sector_t)page->index << (PAGE_CACHE_SHIFT - bbits);
+	block = (sector_t)page->index << (PAGE_SHIFT - bbits);
 	last_block = (i_size_read(inode) - 1) >> bbits;
@@ -1894,7 +1894,7 @@ EXPORT_SYMBOL(page_zero_new_buffers);
 int __block_write_begin(struct page *page, loff_t pos, unsigned len,
 		get_block_t *get_block)
-	unsigned from = pos & (PAGE_CACHE_SIZE - 1);
+	unsigned from = pos & (PAGE_SIZE - 1);
 	unsigned to = from + len;
 	struct inode *inode = page->mapping->host;
 	unsigned block_start, block_end;
@@ -1904,15 +1904,15 @@ int __block_write_begin(struct page *page, loff_t pos, unsigned len,
 	struct buffer_head *bh, *head, *wait[2], **wait_bh=wait;
 	BUG_ON(!PageLocked(page));
-	BUG_ON(from > PAGE_CACHE_SIZE);
-	BUG_ON(to > PAGE_CACHE_SIZE);
+	BUG_ON(from > PAGE_SIZE);
+	BUG_ON(to > PAGE_SIZE);
 	BUG_ON(from > to);
 	head = create_page_buffers(page, inode, 0);
 	blocksize = head->b_size;
 	for(bh = head, block_start = 0; bh != head || !block_start;
 	    block++, block_start=block_end, bh = bh->b_this_page) {
@@ -2020,7 +2020,7 @@ static int __block_commit_write(struct inode *inode, struct page *page,
 int block_write_begin(struct address_space *mapping, loff_t pos, unsigned len,
 		unsigned flags, struct page **pagep, get_block_t *get_block)
-	pgoff_t index = pos >> PAGE_CACHE_SHIFT;
+	pgoff_t index = pos >> PAGE_SHIFT;
 	struct page *page;
 	int status;
@@ -2031,7 +2031,7 @@ int block_write_begin(struct address_space *mapping, loff_t pos, unsigned len,
 	status = __block_write_begin(page, pos, len, get_block);
 	if (unlikely(status)) {
 		unlock_page(page);
+		put_page(page);
 		page = NULL;
@@ -2047,7 +2047,7 @@ int block_write_end(struct file *file, struct address_space *mapping,
 	struct inode *inode = mapping->host;
 	unsigned start;
-	start = pos & (PAGE_CACHE_SIZE - 1);
+	start = pos & (PAGE_SIZE - 1);
 	if (unlikely(copied < len)) {
@@ -2099,7 +2099,7 @@ int generic_write_end(struct file *file, struct address_space *mapping,
 	unlock_page(page);
+	put_page(page);
 	if (old_size < pos)
 		pagecache_isize_extended(inode, old_size, pos);
@@ -2136,9 +2136,9 @@ int block_is_partially_uptodate(struct page *page, unsigned long from,
-	to = min_t(unsigned, PAGE_CACHE_SIZE - from, count);
+	to = min_t(unsigned, PAGE_SIZE - from, count);
 	to = from + to;
-	if (from < blocksize && to > PAGE_CACHE_SIZE - blocksize)
+	if (from < blocksize && to > PAGE_SIZE - blocksize)
 		return 0;
 	bh = head;
@@ -2181,7 +2181,7 @@ int block_read_full_page(struct page *page, get_block_t *get_block)
-	iblock = (sector_t)page->index << (PAGE_CACHE_SHIFT - bbits);
+	iblock = (sector_t)page->index << (PAGE_SHIFT - bbits);
 	lblock = (i_size_read(inode)+blocksize-1) >> bbits;
 	bh = head;
 	nr = 0;
@@ -2295,16 +2295,16 @@ static int cont_expand_zero(struct file *file, struct address_space *mapping,
 	unsigned zerofrom, offset, len;
 	int err = 0;
-	index = pos >> PAGE_CACHE_SHIFT;
-	offset = pos & ~PAGE_CACHE_MASK;
+	index = pos >> PAGE_SHIFT;
+	offset = pos & ~PAGE_MASK;
-	while (index > (curidx = (curpos = *bytes)>>PAGE_CACHE_SHIFT)) {
-		zerofrom = curpos & ~PAGE_CACHE_MASK;
+	while (index > (curidx = (curpos = *bytes)>>PAGE_SHIFT)) {
+		zerofrom = curpos & ~PAGE_MASK;
 		if (zerofrom & (blocksize-1)) {
 			*bytes |= (blocksize-1);
 			(*bytes)++;
-		len = PAGE_CACHE_SIZE - zerofrom;
+		len = PAGE_SIZE - zerofrom;
 		err = pagecache_write_begin(file, mapping, curpos, len,
 						AOP_FLAG_UNINTERRUPTIBLE,
@@ -2329,7 +2329,7 @@ static int cont_expand_zero(struct file *file, struct address_space *mapping,
 	/* page covers the boundary, find the boundary offset */
 	if (index == curidx) {
 		/* if we will expand the thing last block will be filled */
 		if (offset <= zerofrom) {
 			goto out;
@@ -2375,7 +2375,7 @@ int cont_write_begin(struct file *file, struct address_space *mapping,
 	if (err)
 		return err;
-	zerofrom = *bytes & ~PAGE_CACHE_MASK;
+	zerofrom = *bytes & ~PAGE_MASK;
 	if (pos+len > *bytes && zerofrom & (blocksize-1)) {
 		(*bytes)++;
@@ -2430,10 +2430,10 @@ int block_page_mkwrite(struct vm_area_struct *vma, struct vm_fault *vmf,
-	if (((page->index + 1) << PAGE_CACHE_SHIFT) > size)
-		end = size & ~PAGE_CACHE_MASK;
+	if (((page->index + 1) << PAGE_SHIFT) > size)
+		end = size & ~PAGE_MASK;
 	else
-		end = PAGE_CACHE_SIZE;
+		end = PAGE_SIZE;
 	ret = __block_write_begin(page, 0, end, get_block);
 	if (!ret)
@@ -2508,8 +2508,8 @@ int nobh_write_begin(struct address_space *mapping,
 	int ret = 0;
 	int is_mapped_to_disk = 1;
-	from = pos & (PAGE_CACHE_SIZE - 1);
+	from = pos & (PAGE_SIZE - 1);
 	to = from + len;
 	page = grab_cache_page_write_begin(mapping, index, flags);
@@ -2543,7 +2543,7 @@ int nobh_write_begin(struct address_space *mapping,
 		goto out_release;
-	block_in_file = (sector_t)page->index << (PAGE_CACHE_SHIFT - blkbits);
+	block_in_file = (sector_t)page->index << (PAGE_SHIFT - blkbits);
 	 * We loop across all blocks in the page, whether or not they are
@@ -2551,7 +2551,7 @@ int nobh_write_begin(struct address_space *mapping,
 	 * page is fully mapped-to-disk.
 	for (block_start = 0, block_in_page = 0, bh = head;
-		  block_start < PAGE_CACHE_SIZE;
+		  block_start < PAGE_SIZE;
 		  block_in_page++, block_start += blocksize, bh = bh->b_this_page) {
 		int create;
@@ -2623,7 +2623,7 @@ failed:
 out_release:
 	unlock_page(page);
+	put_page(page);
 	*pagep = NULL;
 	return ret;
@@ -2653,7 +2653,7 @@ int nobh_write_end(struct file *file, struct address_space *mapping,
 	unlock_page(page);
+	put_page(page);
 	while (head) {
 		bh = head;
@@ -2675,7 +2675,7 @@ int nobh_writepage(struct page *page, get_block_t *get_block,
 	struct inode * const inode = page->mapping->host;
 	loff_t i_size = i_size_read(inode);
-	const pgoff_t end_index = i_size >> PAGE_CACHE_SHIFT;
+	const pgoff_t end_index = i_size >> PAGE_SHIFT;
 	unsigned offset;
 	int ret;
@@ -2684,7 +2684,7 @@ int nobh_writepage(struct page *page, get_block_t *get_block,
 		goto out;
 	/* Is the page fully outside i_size? (truncate in progress) */
-	offset = i_size & (PAGE_CACHE_SIZE-1);
+	offset = i_size & (PAGE_SIZE-1);
 	if (page->index >= end_index+1 || !offset) {
 		 * The page may have dirty, unmapped buffers.  For example,
@@ -2707,7 +2707,7 @@ int nobh_writepage(struct page *page, get_block_t *get_block,
 	 * the  page size, the remaining memory is zeroed when mapped, and
 	 * writes to that region are not written out to the file."
-	zero_user_segment(page, offset, PAGE_CACHE_SIZE);
+	zero_user_segment(page, offset, PAGE_SIZE);
 out:
 	ret = mpage_writepage(page, get_block, wbc);
 	if (ret == -EAGAIN)
@@ -2720,8 +2720,8 @@ EXPORT_SYMBOL(nobh_writepage);
 int nobh_truncate_page(struct address_space *mapping,
 			loff_t from, get_block_t *get_block)
-	unsigned offset = from & (PAGE_CACHE_SIZE-1);
+	unsigned offset = from & (PAGE_SIZE-1);
 	unsigned blocksize;
 	sector_t iblock;
 	unsigned length, pos;
@@ -2738,7 +2738,7 @@ int nobh_truncate_page(struct address_space *mapping,
 		return 0;
 	length = blocksize - length;
-	iblock = (sector_t)index << (PAGE_CACHE_SHIFT - inode->i_blkbits);
+	iblock = (sector_t)index << (PAGE_SHIFT - inode->i_blkbits);
 	page = grab_cache_page(mapping, index);
 	err = -ENOMEM;
@@ -2748,7 +2748,7 @@ int nobh_truncate_page(struct address_space *mapping,
 	if (page_has_buffers(page)) {
 has_buffers:
 		unlock_page(page);
+		put_page(page);
 		return block_truncate_page(mapping, from, get_block);
@@ -2772,7 +2772,7 @@ has_buffers:
 		err = mapping->a_ops->readpage(NULL, page);
 		if (err) {
+			put_page(page);
 			goto out;
 		lock_page(page);
@@ -2789,7 +2789,7 @@ has_buffers:
 unlock:
 	unlock_page(page);
+	put_page(page);
 out:
 	return err;
@@ -2798,8 +2798,8 @@ EXPORT_SYMBOL(nobh_truncate_page);
 int block_truncate_page(struct address_space *mapping,
 	unsigned blocksize;
 	sector_t iblock;
@@ -2816,7 +2816,7 @@ int block_truncate_page(struct address_space *mapping,
 		return 0;
 	err = -ENOMEM;
@@ -2865,7 +2865,7 @@ int block_truncate_page(struct address_space *mapping,
 unlock:
 	unlock_page(page);
+	put_page(page);
 out:
 	return err;
@@ -2879,7 +2879,7 @@ int block_write_full_page(struct page *page, get_block_t *get_block,
 	unsigned offset;
 	/* Is the page fully inside i_size? */
@@ -2888,14 +2888,14 @@ int block_write_full_page(struct page *page, get_block_t *get_block,
 					       end_buffer_async_write);
 		 * they may have been added in ext3_writepage().  Make them
 		 * freeable here, so the page does not leak.
-		do_invalidatepage(page, 0, PAGE_CACHE_SIZE);
+		do_invalidatepage(page, 0, PAGE_SIZE);
 		unlock_page(page);
 		return 0; /* don't care */
@@ -2907,7 +2907,7 @@ int block_write_full_page(struct page *page, get_block_t *get_block,
 	return __block_write_full_page(inode, page, get_block, wbc,
diff --git a/fs/cachefiles/rdwr.c b/fs/cachefiles/rdwr.c
index c0f3da3..afbdc41 100644
--- a/fs/cachefiles/rdwr.c
+++ b/fs/cachefiles/rdwr.c
@@ -194,10 +194,10 @@ static void cachefiles_read_copier(struct fscache_operation *_op)
 			error = -EIO;
-		page_cache_release(monitor->back_page);
+		put_page(monitor->back_page);
 		fscache_end_io(op, monitor->netfs_page, error);
-		page_cache_release(monitor->netfs_page);
+		put_page(monitor->netfs_page);
 		fscache_retrieval_complete(op, 1);
 		fscache_put_retrieval(op);
 		kfree(monitor);
@@ -288,8 +288,8 @@ monitor_backing_page:
 	_debug("- monitor add");
 	/* install the monitor */
-	page_cache_get(monitor->netfs_page);
-	page_cache_get(backpage);
+	get_page(monitor->netfs_page);
+	get_page(backpage);
 	monitor->back_page = backpage;
 	monitor->monitor.private = backpage;
 	add_page_wait_queue(backpage, &monitor->monitor);
@@ -310,7 +310,7 @@ backing_page_already_present:
 	_debug("- present");
 	if (newpage) {
-		page_cache_release(newpage);
+		put_page(newpage);
 		newpage = NULL;
@@ -342,7 +342,7 @@ success:
 out:
 	if (backpage)
-		page_cache_release(backpage);
+		put_page(backpage);
 	if (monitor) {
 		fscache_put_retrieval(monitor->op);
 		kfree(monitor);
@@ -363,7 +363,7 @@ io_error:
 	goto out;
 nomem_page:
 nomem_monitor:
 	kfree(monitor);
@@ -530,7 +530,7 @@ static int cachefiles_read_backing_file(struct cachefiles_object *object,
 					    netpage->index, cachefiles_gfp);
 		if (ret < 0) {
 			if (ret == -EEXIST) {
-				page_cache_release(netpage);
+				put_page(netpage);
 				continue;
@@ -538,10 +538,10 @@ static int cachefiles_read_backing_file(struct cachefiles_object *object,
 		/* install a monitor */
-		page_cache_get(netpage);
+		get_page(netpage);
 		monitor->netfs_page = netpage;
@@ -555,10 +555,10 @@ static int cachefiles_read_backing_file(struct cachefiles_object *object,
 			unlock_page(backpage);
 		backpage = NULL;
 		netpage = NULL;
 		continue;
@@ -603,7 +603,7 @@ static int cachefiles_read_backing_file(struct cachefiles_object *object,
 		if (ret < 0) {
 				continue;
@@ -612,14 +612,14 @@ static int cachefiles_read_backing_file(struct cachefiles_object *object,
 		copy_highpage(netpage, backpage);
 		backpage = NULL;
 		fscache_mark_page_cached(op, netpage);
 		/* the netpage is unlocked and marked up to date here */
 		fscache_end_io(op, netpage, 0);
 		netpage = NULL;
 		continue;
@@ -632,11 +632,11 @@ static int cachefiles_read_backing_file(struct cachefiles_object *object,
 out:
 	/* tidy up */
 	if (newpage)
 	if (netpage)
 	if (backpage)
 	if (monitor) {
 		kfree(monitor);
@@ -644,7 +644,7 @@ out:
 	list_for_each_entry_safe(netpage, _n, list, lru) {
 		list_del(&netpage->lru);
diff --git a/fs/ceph/addr.c b/fs/ceph/addr.c
index fc5cae2..4801571 100644
--- a/fs/ceph/addr.c
+++ b/fs/ceph/addr.c
@@ -143,7 +143,7 @@ static void ceph_invalidatepage(struct page *page, unsigned int offset,
 	ci = ceph_inode(inode);
-	if (offset != 0 || length != PAGE_CACHE_SIZE) {
+	if (offset != 0 || length != PAGE_SIZE) {
 		dout("%p invalidatepage %p idx %lu partial dirty page %u~%u\n",
 		     inode, page, page->index, offset, length);
 		return;
@@ -197,10 +197,10 @@ static int readpage_nounlock(struct file *filp, struct page *page)
 		&ceph_inode_to_client(inode)->client->osdc;
 	int err = 0;
 	u64 off = page_offset(page);
 	if (off >= i_size_read(inode)) {
-		zero_user_segment(page, 0, PAGE_CACHE_SIZE);
+		zero_user_segment(page, 0, PAGE_SIZE);
 		SetPageUptodate(page);
 		return 0;
@@ -212,7 +212,7 @@ static int readpage_nounlock(struct file *filp, struct page *page)
 		if (off == 0)
 			return -EINVAL;
 		return 0;
@@ -234,9 +234,9 @@ static int readpage_nounlock(struct file *filp, struct page *page)
 		ceph_fscache_readpage_cancel(inode, page);
 		goto out;
-	if (err < PAGE_CACHE_SIZE)
+	if (err < PAGE_SIZE)
 		/* zero fill remainder of page */
-		zero_user_segment(page, err, PAGE_CACHE_SIZE);
+		zero_user_segment(page, err, PAGE_SIZE);
 	else
@@ -278,10 +278,10 @@ static void finish_read(struct ceph_osd_request *req, struct ceph_msg *msg)
 		if (rc < 0 && rc != -ENOENT)
 			goto unlock;
-		if (bytes < (int)PAGE_CACHE_SIZE) {
+		if (bytes < (int)PAGE_SIZE) {
 			/* zero (remainder of) page */
 			int s = bytes < 0 ? 0 : bytes;
-			zero_user_segment(page, s, PAGE_CACHE_SIZE);
+			zero_user_segment(page, s, PAGE_SIZE);
  		dout("finish_read %p uptodate %p idx %lu\n", inode, page,
 		     page->index);
@@ -290,8 +290,8 @@ static void finish_read(struct ceph_osd_request *req, struct ceph_msg *msg)
 		ceph_readpage_to_fscache(inode, page);
 unlock:
 		unlock_page(page);
-		bytes -= PAGE_CACHE_SIZE;
+		put_page(page);
+		bytes -= PAGE_SIZE;
 	kfree(osd_data->pages);
@@ -336,7 +336,7 @@ static int start_read(struct inode *inode, struct list_head *page_list, int max)
 		if (max && nr_pages == max)
 			break;
-	len = nr_pages << PAGE_CACHE_SHIFT;
+	len = nr_pages << PAGE_SHIFT;
 	dout("start_read %p nr_pages %d is %lld~%lld\n", inode, nr_pages,
 	     off, len);
 	vino = ceph_vino(inode);
@@ -364,7 +364,7 @@ static int start_read(struct inode *inode, struct list_head *page_list, int max)
 		if (add_to_page_cache_lru(page, &inode->i_data, page->index,
 					  GFP_KERNEL)) {
 			ceph_fscache_uncache_page(inode, page);
+			put_page(page);
 			dout("start_read %p add_to_page_cache failed %p\n",
 			     inode, page);
 			nr_pages = i;
@@ -415,8 +415,8 @@ static int ceph_readpages(struct file *file, struct address_space *mapping,
 	if (rc == 0)
 		goto out;
-	if (fsc->mount_options->rsize >= PAGE_CACHE_SIZE)
-		max = (fsc->mount_options->rsize + PAGE_CACHE_SIZE - 1)
+	if (fsc->mount_options->rsize >= PAGE_SIZE)
+		max = (fsc->mount_options->rsize + PAGE_SIZE - 1)
 			>> PAGE_SHIFT;
 	dout("readpages %p file %p nr_pages %d max %d\n", inode,
@@ -484,7 +484,7 @@ static int writepage_nounlock(struct page *page, struct writeback_control *wbc)
 	long writeback_stat;
 	u64 truncate_size;
 	u32 truncate_seq;
-	int err = 0, len = PAGE_CACHE_SIZE;
+	int err = 0, len = PAGE_SIZE;
 	dout("writepage %p idx %lu\n", page, page->index);
@@ -725,9 +725,9 @@ static int ceph_writepages_start(struct address_space *mapping,
 	if (fsc->mount_options->wsize && fsc->mount_options->wsize < wsize)
 		wsize = fsc->mount_options->wsize;
-	if (wsize < PAGE_CACHE_SIZE)
-		wsize = PAGE_CACHE_SIZE;
-	max_pages_ever = wsize >> PAGE_CACHE_SHIFT;
+	if (wsize < PAGE_SIZE)
+		wsize = PAGE_SIZE;
+	max_pages_ever = wsize >> PAGE_SHIFT;
 	pagevec_init(&pvec, 0);
@@ -737,8 +737,8 @@ static int ceph_writepages_start(struct address_space *mapping,
 		end = -1;
 		dout(" cyclic, start at %lu\n", start);
 	} else {
-		start = wbc->range_start >> PAGE_CACHE_SHIFT;
-		end = wbc->range_end >> PAGE_CACHE_SHIFT;
+		start = wbc->range_start >> PAGE_SHIFT;
+		end = wbc->range_end >> PAGE_SHIFT;
 		if (wbc->range_start == 0 && wbc->range_end == LLONG_MAX)
 			range_whole = 1;
 		should_loop = 0;
@@ -887,7 +887,7 @@ get_more_pages:
 				num_ops = 1 + do_sync;
 				strip_unit_end = page->index +
-					((len - 1) >> PAGE_CACHE_SHIFT);
+					((len - 1) >> PAGE_SHIFT);
 				BUG_ON(pages);
 				max_pages = calc_pages_for(0, (u64)len);
@@ -901,7 +901,7 @@ get_more_pages:
 				len = 0;
 			} else if (page->index !=
-				   (offset + len) >> PAGE_CACHE_SHIFT) {
+				   (offset + len) >> PAGE_SHIFT) {
 				if (num_ops >= (pool ?  CEPH_OSD_SLAB_OPS :
 							CEPH_OSD_MAX_OPS)) {
 					redirty_page_for_writepage(wbc, page);
@@ -929,7 +929,7 @@ get_more_pages:
 			pages[locked_pages] = page;
 			locked_pages++;
-			len += PAGE_CACHE_SIZE;
+			len += PAGE_SIZE;
 		/* did we get anything? */
@@ -981,7 +981,7 @@ new_request:
 			BUG_ON(IS_ERR(req));
 		BUG_ON(len < page_offset(pages[locked_pages - 1]) +
-			     PAGE_CACHE_SIZE - offset);
+			     PAGE_SIZE - offset);
 		req->r_callback = writepages_finish;
 		req->r_inode = inode;
@@ -1011,7 +1011,7 @@ new_request:
 			set_page_writeback(pages[i]);
+			len += PAGE_SIZE;
 		if (snap_size != -1) {
@@ -1020,7 +1020,7 @@ new_request:
 			/* writepages_finish() clears writeback pages
 			 * according to the data length, so make sure
 			 * data length covers all locked pages */
-			u64 min_len = len + 1 - PAGE_CACHE_SIZE;
+			u64 min_len = len + 1 - PAGE_SIZE;
 			len = min(len, (u64)i_size_read(inode) - offset);
 			len = max(len, min_len);
@@ -1135,8 +1135,8 @@ static int ceph_update_writeable_page(struct file *file,
 	struct inode *inode = file_inode(file);
 	struct ceph_inode_info *ci = ceph_inode(inode);
-	loff_t page_off = pos & PAGE_CACHE_MASK;
-	int pos_in_page = pos & ~PAGE_CACHE_MASK;
+	loff_t page_off = pos & PAGE_MASK;
+	int pos_in_page = pos & ~PAGE_MASK;
 	int end_in_page = pos_in_page + len;
 	loff_t i_size;
 	int r;
@@ -1191,7 +1191,7 @@ retry_locked:
 	/* full page? */
-	if (pos_in_page == 0 && len == PAGE_CACHE_SIZE)
+	if (pos_in_page == 0 && len == PAGE_SIZE)
 		return 0;
 	/* past end of file? */
@@ -1199,12 +1199,12 @@ retry_locked:
 	if (page_off >= i_size ||
 	    (pos_in_page == 0 && (pos+len) >= i_size &&
-	     end_in_page - pos_in_page != PAGE_CACHE_SIZE)) {
+	     end_in_page - pos_in_page != PAGE_SIZE)) {
 		dout(" zeroing %p 0 - %d and %d - %d\n",
-		     page, pos_in_page, end_in_page, (int)PAGE_CACHE_SIZE);
+		     page, pos_in_page, end_in_page, (int)PAGE_SIZE);
 		zero_user_segments(page,
 				   0, pos_in_page,
-				   end_in_page, PAGE_CACHE_SIZE);
+				   end_in_page, PAGE_SIZE);
 		return 0;
@@ -1228,7 +1228,7 @@ static int ceph_write_begin(struct file *file, struct address_space *mapping,
 	struct page *page;
 	int r;
 	do {
@@ -1242,7 +1242,7 @@ static int ceph_write_begin(struct file *file, struct address_space *mapping,
 		r = ceph_update_writeable_page(file, pos, len, page);
 		if (r < 0)
+			put_page(page);
 		else
 			*pagep = page;
 	} while (r == -EAGAIN);
@@ -1259,7 +1259,7 @@ static int ceph_write_end(struct file *file, struct address_space *mapping,
 			  struct page *page, void *fsdata)
 	int check_cap = 0;
 	dout("write_end file %p inode %p page %p %d~%d (%d)\n", file,
@@ -1279,7 +1279,7 @@ static int ceph_write_end(struct file *file, struct address_space *mapping,
 	set_page_dirty(page);
 	unlock_page(page);
+	put_page(page);
 	if (check_cap)
 		ceph_check_caps(ceph_inode(inode), CHECK_CAPS_AUTHONLY, NULL);
@@ -1322,11 +1322,11 @@ static int ceph_filemap_fault(struct vm_area_struct *vma, struct vm_fault *vmf)
 	struct ceph_file_info *fi = vma->vm_file->private_data;
 	struct page *pinned_page = NULL;
-	loff_t off = vmf->pgoff << PAGE_CACHE_SHIFT;
+	loff_t off = vmf->pgoff << PAGE_SHIFT;
 	int want, got, ret;
 	dout("filemap_fault %p %llx.%llx %llu~%zd trying to get caps\n",
-	     inode, ceph_vinop(inode), off, (size_t)PAGE_CACHE_SIZE);
+	     inode, ceph_vinop(inode), off, (size_t)PAGE_SIZE);
 	if (fi->fmode & CEPH_FILE_MODE_LAZY)
 		want = CEPH_CAP_FILE_CACHE | CEPH_CAP_FILE_LAZYIO;
 	else
@@ -1343,7 +1343,7 @@ static int ceph_filemap_fault(struct vm_area_struct *vma, struct vm_fault *vmf)
 	dout("filemap_fault %p %llu~%zd got cap refs on %s\n",
-	     inode, off, (size_t)PAGE_CACHE_SIZE, ceph_cap_string(got));
+	     inode, off, (size_t)PAGE_SIZE, ceph_cap_string(got));
 	if ((got & (CEPH_CAP_FILE_CACHE | CEPH_CAP_FILE_LAZYIO)) ||
 	    ci->i_inline_version == CEPH_INLINE_NONE)
@@ -1352,16 +1352,16 @@ static int ceph_filemap_fault(struct vm_area_struct *vma, struct vm_fault *vmf)
 		ret = -EAGAIN;
 	dout("filemap_fault %p %llu~%zd dropping cap refs on %s ret %d\n",
-	     inode, off, (size_t)PAGE_CACHE_SIZE, ceph_cap_string(got), ret);
+	     inode, off, (size_t)PAGE_SIZE, ceph_cap_string(got), ret);
 	if (pinned_page)
-		page_cache_release(pinned_page);
+		put_page(pinned_page);
 	ceph_put_cap_refs(ci, got);
 	if (ret != -EAGAIN)
 		return ret;
 	/* read inline data */
-	if (off >= PAGE_CACHE_SIZE) {
+	if (off >= PAGE_SIZE) {
 		/* does not support inline data > PAGE_SIZE */
 		ret = VM_FAULT_SIGBUS;
 	} else {
@@ -1378,12 +1378,12 @@ static int ceph_filemap_fault(struct vm_area_struct *vma, struct vm_fault *vmf)
 					 CEPH_STAT_CAP_INLINE_DATA, true);
 		if (ret1 < 0 || off >= i_size_read(inode)) {
 			unlock_page(page);
+			put_page(page);
 			goto out;
-		if (ret1 < PAGE_CACHE_SIZE)
-			zero_user_segment(page, ret1, PAGE_CACHE_SIZE);
+		if (ret1 < PAGE_SIZE)
+			zero_user_segment(page, ret1, PAGE_SIZE);
 		else
@@ -1392,7 +1392,7 @@ static int ceph_filemap_fault(struct vm_area_struct *vma, struct vm_fault *vmf)
 out:
 	dout("filemap_fault %p %llu~%zd read inline data ret %d\n",
-	     inode, off, (size_t)PAGE_CACHE_SIZE, ret);
+	     inode, off, (size_t)PAGE_SIZE, ret);
 	return ret;
@@ -1430,10 +1430,10 @@ static int ceph_page_mkwrite(struct vm_area_struct *vma, struct vm_fault *vmf)
-	if (off + PAGE_CACHE_SIZE <= size)
-		len = PAGE_CACHE_SIZE;
+	if (off + PAGE_SIZE <= size)
+		len = PAGE_SIZE;
 	else
-		len = size & ~PAGE_CACHE_MASK;
+		len = size & ~PAGE_MASK;
 	dout("page_mkwrite %p %llx.%llx %llu~%zd getting caps i_size %llu\n",
 	     inode, ceph_vinop(inode), off, len, size);
@@ -1519,7 +1519,7 @@ void ceph_fill_inline_data(struct inode *inode, struct page *locked_page,
 			return;
 		if (PageUptodate(page)) {
 			unlock_page(page);
-			page_cache_release(page);
+			put_page(page);
 			return;
@@ -1534,14 +1534,14 @@ void ceph_fill_inline_data(struct inode *inode, struct page *locked_page,
 	if (page != locked_page) {
-			zero_user_segment(page, len, PAGE_CACHE_SIZE);
+			zero_user_segment(page, len, PAGE_SIZE);
 		else
 		unlock_page(page);
+		put_page(page);
@@ -1578,7 +1578,7 @@ int ceph_uninline_data(struct file *filp, struct page *locked_page)
 				from_pagecache = true;
 				lock_page(page);
 			} else {
+				put_page(page);
 				page = NULL;
@@ -1586,8 +1586,8 @@ int ceph_uninline_data(struct file *filp, struct page *locked_page)
 	if (page) {
 		len = i_size_read(inode);
-		if (len > PAGE_CACHE_SIZE)
+		if (len > PAGE_SIZE)
+			len = PAGE_SIZE;
 	} else {
 		page = __page_cache_alloc(GFP_NOFS);
 		if (!page) {
@@ -1670,7 +1670,7 @@ out:
 	if (page && page != locked_page) {
 		if (from_pagecache) {
 			unlock_page(page);
+			put_page(page);
 		} else
 			__free_pages(page, 0);
diff --git a/fs/ceph/caps.c b/fs/ceph/caps.c
index de17bb2..cfaeef1 100644
--- a/fs/ceph/caps.c
+++ b/fs/ceph/caps.c
@@ -2510,7 +2510,7 @@ int ceph_get_caps(struct ceph_inode_info *ci, int need, int want,
 					*pinned_page = page;
 					break;
+				put_page(page);
 			 * drop cap refs first because getattr while
diff --git a/fs/ceph/dir.c b/fs/ceph/dir.c
index fadc243..4fb2bbc 100644
--- a/fs/ceph/dir.c
+++ b/fs/ceph/dir.c
@@ -129,7 +129,7 @@ static int __dcache_readdir(struct file *file,  struct dir_context *ctx,
 	struct inode *dir = d_inode(parent);
 	struct dentry *dentry, *last = NULL;
 	struct ceph_dentry_info *di;
-	unsigned nsize = PAGE_CACHE_SIZE / sizeof(struct dentry *);
+	unsigned nsize = PAGE_SIZE / sizeof(struct dentry *);
 	int err = 0;
 	loff_t ptr_pos = 0;
 	struct ceph_readdir_cache_control cache_ctl = {};
@@ -154,7 +154,7 @@ static int __dcache_readdir(struct file *file,  struct dir_context *ctx,
 		err = -EAGAIN;
-		pgoff = ptr_pos >> PAGE_CACHE_SHIFT;
+		pgoff = ptr_pos >> PAGE_SHIFT;
 		if (!cache_ctl.page || pgoff != page_index(cache_ctl.page)) {
 			ceph_readdir_cache_release(&cache_ctl);
 			cache_ctl.page = find_lock_page(&dir->i_data, pgoff);
diff --git a/fs/ceph/file.c b/fs/ceph/file.c
index ef38f01..a79f926 100644
--- a/fs/ceph/file.c
+++ b/fs/ceph/file.c
@@ -466,7 +466,7 @@ more:
 			ret += zlen;
-		didpages = (page_align + ret) >> PAGE_CACHE_SHIFT;
+		didpages = (page_align + ret) >> PAGE_SHIFT;
 		pos += ret;
 		read = pos - off;
 		left -= ret;
@@ -806,8 +806,8 @@ ceph_direct_read_write(struct kiocb *iocb, struct iov_iter *iter,
 	if (write) {
 		ret = invalidate_inode_pages2_range(inode->i_mapping,
-					pos >> PAGE_CACHE_SHIFT,
-					(pos + count) >> PAGE_CACHE_SHIFT);
+					pos >> PAGE_SHIFT,
+					(pos + count) >> PAGE_SHIFT);
 		if (ret < 0)
 			dout("invalidate_inode_pages2_range returned %d\n", ret);
@@ -872,7 +872,7 @@ ceph_direct_read_write(struct kiocb *iocb, struct iov_iter *iter,
 			 * may block.
 			truncate_inode_pages_range(inode->i_mapping, pos,
-					(pos+len) | (PAGE_CACHE_SIZE - 1));
+					(pos+len) | (PAGE_SIZE - 1));
 			osd_req_op_init(req, 1, CEPH_OSD_OP_STARTSYNC, 0);
@@ -1006,8 +1006,8 @@ ceph_sync_write(struct kiocb *iocb, struct iov_iter *from, loff_t pos,
 		return ret;
 	if (ret < 0)
@@ -1036,7 +1036,7 @@ ceph_sync_write(struct kiocb *iocb, struct iov_iter *from, loff_t pos,
 		 * write from beginning of first page,
 		 * regardless of io alignment
-		num_pages = (len + PAGE_CACHE_SIZE - 1) >> PAGE_CACHE_SHIFT;
+		num_pages = (len + PAGE_SIZE - 1) >> PAGE_SHIFT;
 		pages = ceph_alloc_page_vector(num_pages, GFP_KERNEL);
 		if (IS_ERR(pages)) {
@@ -1159,7 +1159,7 @@ again:
 	dout("aio_read %p %llx.%llx dropping cap refs on %s = %d\n",
 	     inode, ceph_vinop(inode), ceph_cap_string(got), (int)ret);
 	if (pinned_page) {
 		pinned_page = NULL;
@@ -1188,10 +1188,10 @@ again:
 		if (retry_op == READ_INLINE) {
 			BUG_ON(ret > 0 || read > 0);
 			if (iocb->ki_pos < i_size &&
-			    iocb->ki_pos < PAGE_CACHE_SIZE) {
+			    iocb->ki_pos < PAGE_SIZE) {
 				loff_t end = min_t(loff_t, i_size,
 						   iocb->ki_pos + len);
-				end = min_t(loff_t, end, PAGE_CACHE_SIZE);
+				end = min_t(loff_t, end, PAGE_SIZE);
 				if (statret < end)
 					zero_user_segment(page, statret, end);
 				ret = copy_page_to_iter(page,
@@ -1463,21 +1463,21 @@ static inline void ceph_zero_partial_page(
 	struct inode *inode, loff_t offset, unsigned size)
 	struct page *page;
 	page = find_lock_page(inode->i_mapping, index);
 	if (page) {
 		wait_on_page_writeback(page);
-		zero_user(page, offset & (PAGE_CACHE_SIZE - 1), size);
+		zero_user(page, offset & (PAGE_SIZE - 1), size);
 		unlock_page(page);
+		put_page(page);
 static void ceph_zero_pagecache_range(struct inode *inode, loff_t offset,
 				      loff_t length)
-	loff_t nearly = round_up(offset, PAGE_CACHE_SIZE);
+	loff_t nearly = round_up(offset, PAGE_SIZE);
 	if (offset < nearly) {
 		loff_t size = nearly - offset;
 		if (length < size)
@@ -1486,8 +1486,8 @@ static void ceph_zero_pagecache_range(struct inode *inode, loff_t offset,
 		offset += size;
 		length -= size;
-	if (length >= PAGE_CACHE_SIZE) {
-		loff_t size = round_down(length, PAGE_CACHE_SIZE);
+	if (length >= PAGE_SIZE) {
+		loff_t size = round_down(length, PAGE_SIZE);
 		truncate_pagecache_range(inode, offset, offset + size - 1);
 		offset += size;
 		length -= size;
diff --git a/fs/ceph/inode.c b/fs/ceph/inode.c
index ed58b16..edfade0 100644
--- a/fs/ceph/inode.c
+++ b/fs/ceph/inode.c
@@ -1338,7 +1338,7 @@ void ceph_readdir_cache_release(struct ceph_readdir_cache_control *ctl)
 	if (ctl->page) {
 		kunmap(ctl->page);
-		page_cache_release(ctl->page);
+		put_page(ctl->page);
 		ctl->page = NULL;
@@ -1348,7 +1348,7 @@ static int fill_readdir_cache(struct inode *dir, struct dentry *dn,
 			      struct ceph_mds_request *req)
 	struct ceph_inode_info *ci = ceph_inode(dir);
-	unsigned nsize = PAGE_CACHE_SIZE / sizeof(struct dentry*);
+	unsigned nsize = PAGE_SIZE / sizeof(struct dentry*);
 	unsigned idx = ctl->index % nsize;
 	pgoff_t pgoff = ctl->index / nsize;
@@ -1367,7 +1367,7 @@ static int fill_readdir_cache(struct inode *dir, struct dentry *dn,
 		unlock_page(ctl->page);
 		ctl->dentries = kmap(ctl->page);
 		if (idx == 0)
-			memset(ctl->dentries, 0, PAGE_CACHE_SIZE);
+			memset(ctl->dentries, 0, PAGE_SIZE);
 	if (req->r_dir_release_cnt == atomic64_read(&ci->i_release_count) &&
diff --git a/fs/ceph/mds_client.c b/fs/ceph/mds_client.c
index 44852c3..541ead4 100644
--- a/fs/ceph/mds_client.c
+++ b/fs/ceph/mds_client.c
@@ -1610,7 +1610,7 @@ again:
 	while (!list_empty(&tmp_list)) {
 		if (!msg) {
 			msg = ceph_msg_new(CEPH_MSG_CLIENT_CAPRELEASE,
-					PAGE_CACHE_SIZE, GFP_NOFS, false);
+					PAGE_SIZE, GFP_NOFS, false);
 			if (!msg)
 				goto out_err;
 			head = msg->front.iov_base;
diff --git a/fs/ceph/mds_client.h b/fs/ceph/mds_client.h
index 37712cc..ee69a53 100644
--- a/fs/ceph/mds_client.h
+++ b/fs/ceph/mds_client.h
@@ -97,7 +97,7 @@ struct ceph_mds_reply_info_parsed {
  * cap releases are batched and sent to the MDS en masse.
-#define CEPH_CAPS_PER_RELEASE ((PAGE_CACHE_SIZE -			\
+#define CEPH_CAPS_PER_RELEASE ((PAGE_SIZE -			\
 				sizeof(struct ceph_mds_cap_release)) /	\
 			       sizeof(struct ceph_mds_cap_item))
diff --git a/fs/ceph/super.c b/fs/ceph/super.c
index c973043..f12d5e2 100644
--- a/fs/ceph/super.c
+++ b/fs/ceph/super.c
@@ -560,7 +560,7 @@ static struct ceph_fs_client *create_fs_client(struct ceph_mount_options *fsopt,
 	/* set up mempools */
 	err = -ENOMEM;
-	page_count = fsc->mount_options->wsize >> PAGE_CACHE_SHIFT;
+	page_count = fsc->mount_options->wsize >> PAGE_SHIFT;
 	size = sizeof (struct page *) * (page_count ? page_count : 1);
 	fsc->wb_pagevec_pool = mempool_create_kmalloc_pool(10, size);
 	if (!fsc->wb_pagevec_pool)
@@ -912,13 +912,13 @@ static int ceph_register_bdi(struct super_block *sb,
 	int err;
 	/* set ra_pages based on rasize mount option? */
-	if (fsc->mount_options->rasize >= PAGE_CACHE_SIZE)
+	if (fsc->mount_options->rasize >= PAGE_SIZE)
 		fsc->backing_dev_info.ra_pages =
-			(fsc->mount_options->rasize + PAGE_CACHE_SIZE - 1)
+			(fsc->mount_options->rasize + PAGE_SIZE - 1)
 			>> PAGE_SHIFT;
 	else
-			VM_MAX_READAHEAD * 1024 / PAGE_CACHE_SIZE;
+			VM_MAX_READAHEAD * 1024 / PAGE_SIZE;
 	err = bdi_register(&fsc->backing_dev_info, NULL, "ceph-%ld",
 			   atomic_long_inc_return(&bdi_seq));
diff --git a/fs/cifs/cifsfs.c b/fs/cifs/cifsfs.c
index 1d86fc6..8920156 100644
--- a/fs/cifs/cifsfs.c
+++ b/fs/cifs/cifsfs.c
@@ -962,7 +962,7 @@ static int cifs_clone_file_range(struct file *src_file, loff_t off,
 	cifs_dbg(FYI, "about to flush pages\n");
 	/* should we flush first and last page first */
 	truncate_inode_pages_range(&target_inode->i_data, destoff,
-				   PAGE_CACHE_ALIGN(destoff + len)-1);
+				   PAGE_ALIGN(destoff + len)-1);
 	if (target_tcon->ses->server->ops->duplicate_extents)
 		rc = target_tcon->ses->server->ops->duplicate_extents(xid,
diff --git a/fs/cifs/cifssmb.c b/fs/cifs/cifssmb.c
index 76fcb50..a894bf8 100644
--- a/fs/cifs/cifssmb.c
+++ b/fs/cifs/cifssmb.c
@@ -1929,17 +1929,17 @@ cifs_writev_requeue(struct cifs_writedata *wdata)
 		wsize = server->ops->wp_retry_size(inode);
 		if (wsize < rest_len) {
-			nr_pages = wsize / PAGE_CACHE_SIZE;
+			nr_pages = wsize / PAGE_SIZE;
 			if (!nr_pages) {
 				rc = -ENOTSUPP;
 				break;
-			cur_len = nr_pages * PAGE_CACHE_SIZE;
-			tailsz = PAGE_CACHE_SIZE;
+			cur_len = nr_pages * PAGE_SIZE;
+			tailsz = PAGE_SIZE;
 		} else {
-			nr_pages = DIV_ROUND_UP(rest_len, PAGE_CACHE_SIZE);
+			nr_pages = DIV_ROUND_UP(rest_len, PAGE_SIZE);
 			cur_len = rest_len;
-			tailsz = rest_len - (nr_pages - 1) * PAGE_CACHE_SIZE;
+			tailsz = rest_len - (nr_pages - 1) * PAGE_SIZE;
 		wdata2 = cifs_writedata_alloc(nr_pages, cifs_writev_complete);
@@ -1957,7 +1957,7 @@ cifs_writev_requeue(struct cifs_writedata *wdata)
 		wdata2->sync_mode = wdata->sync_mode;
 		wdata2->nr_pages = nr_pages;
 		wdata2->offset = page_offset(wdata2->pages[0]);
-		wdata2->pagesz = PAGE_CACHE_SIZE;
+		wdata2->pagesz = PAGE_SIZE;
 		wdata2->tailsz = tailsz;
 		wdata2->bytes = cur_len;
@@ -1975,7 +1975,7 @@ cifs_writev_requeue(struct cifs_writedata *wdata)
 			if (rc != 0 && rc != -EAGAIN) {
 				SetPageError(wdata2->pages[j]);
 				end_page_writeback(wdata2->pages[j]);
-				page_cache_release(wdata2->pages[j]);
+				put_page(wdata2->pages[j]);
@@ -2018,7 +2018,7 @@ cifs_writev_complete(struct work_struct *work)
 		else if (wdata->result < 0)
 			SetPageError(page);
 		end_page_writeback(page);
+		put_page(page);
 	if (wdata->result != -EAGAIN)
 		mapping_set_error(inode->i_mapping, wdata->result);
diff --git a/fs/cifs/connect.c b/fs/cifs/connect.c
index a763cd3..6f62ac8 100644
--- a/fs/cifs/connect.c
+++ b/fs/cifs/connect.c
@@ -3630,7 +3630,7 @@ try_mount_again:
 	cifs_sb->rsize = server->ops->negotiate_rsize(tcon, volume_info);
 	/* tune readahead according to rsize */
-	cifs_sb->bdi.ra_pages = cifs_sb->rsize / PAGE_CACHE_SIZE;
+	cifs_sb->bdi.ra_pages = cifs_sb->rsize / PAGE_SIZE;
 remote_path_check:
 #ifdef CONFIG_CIFS_DFS_UPCALL
diff --git a/fs/cifs/file.c b/fs/cifs/file.c
index ff882ae..5ce540d 100644
--- a/fs/cifs/file.c
+++ b/fs/cifs/file.c
@@ -1833,7 +1833,7 @@ refind_writable:
 static int cifs_partialpagewrite(struct page *page, unsigned from, unsigned to)
 	struct address_space *mapping = page->mapping;
-	loff_t offset = (loff_t)page->index << PAGE_CACHE_SHIFT;
+	loff_t offset = (loff_t)page->index << PAGE_SHIFT;
 	char *write_data;
 	int rc = -EFAULT;
 	int bytes_written = 0;
@@ -1849,7 +1849,7 @@ static int cifs_partialpagewrite(struct page *page, unsigned from, unsigned to)
 	write_data = kmap(page);
 	write_data += from;
-	if ((to > PAGE_CACHE_SIZE) || (from > to)) {
+	if ((to > PAGE_SIZE) || (from > to)) {
 		kunmap(page);
 		return -EIO;
@@ -1991,7 +1991,7 @@ wdata_prepare_pages(struct cifs_writedata *wdata, unsigned int found_pages,
 	/* put any pages we aren't going to use */
 	for (i = nr_pages; i < found_pages; i++) {
-		page_cache_release(wdata->pages[i]);
+		put_page(wdata->pages[i]);
 		wdata->pages[i] = NULL;
@@ -2009,11 +2009,11 @@ wdata_send_pages(struct cifs_writedata *wdata, unsigned int nr_pages,
 	wdata->sync_mode = wbc->sync_mode;
 	wdata->nr_pages = nr_pages;
 	wdata->offset = page_offset(wdata->pages[0]);
-	wdata->pagesz = PAGE_CACHE_SIZE;
+	wdata->pagesz = PAGE_SIZE;
 	wdata->tailsz = min(i_size_read(mapping->host) -
 			page_offset(wdata->pages[nr_pages - 1]),
-			(loff_t)PAGE_CACHE_SIZE);
-	wdata->bytes = ((nr_pages - 1) * PAGE_CACHE_SIZE) + wdata->tailsz;
+			(loff_t)PAGE_SIZE);
+	wdata->bytes = ((nr_pages - 1) * PAGE_SIZE) + wdata->tailsz;
 	if (wdata->cfile != NULL)
 		cifsFileInfo_put(wdata->cfile);
@@ -2047,15 +2047,15 @@ static int cifs_writepages(struct address_space *mapping,
 	 * If wsize is smaller than the page cache size, default to writing
 	 * one page at a time via cifs_writepage
-	if (cifs_sb->wsize < PAGE_CACHE_SIZE)
+	if (cifs_sb->wsize < PAGE_SIZE)
 		return generic_writepages(mapping, wbc);
 	if (wbc->range_cyclic) {
 		index = mapping->writeback_index; /* Start from prev offset */
 		end = -1;
 	} else {
-		index = wbc->range_start >> PAGE_CACHE_SHIFT;
+		index = wbc->range_start >> PAGE_SHIFT;
 			range_whole = true;
 		scanned = true;
@@ -2071,7 +2071,7 @@ retry:
 		if (rc)
 			break;
-		tofind = min((wsize / PAGE_CACHE_SIZE) - 1, end - index) + 1;
+		tofind = min((wsize / PAGE_SIZE) - 1, end - index) + 1;
 		wdata = wdata_alloc_and_fillpages(tofind, mapping, end, &index,
 						  &found_pages);
@@ -2111,7 +2111,7 @@ retry:
 				else
 					SetPageError(wdata->pages[i]);
 				end_page_writeback(wdata->pages[i]);
 			if (rc != -EAGAIN)
 				mapping_set_error(mapping, rc);
@@ -2154,7 +2154,7 @@ cifs_writepage_locked(struct page *page, struct writeback_control *wbc)
 	xid = get_xid();
 /* BB add check for wbc flags */
+	get_page(page);
 	if (!PageUptodate(page))
 		cifs_dbg(FYI, "ppw - page not up to date\n");
@@ -2170,7 +2170,7 @@ cifs_writepage_locked(struct page *page, struct writeback_control *wbc)
 	set_page_writeback(page);
 retry_write:
-	rc = cifs_partialpagewrite(page, 0, PAGE_CACHE_SIZE);
+	rc = cifs_partialpagewrite(page, 0, PAGE_SIZE);
 	if (rc == -EAGAIN && wbc->sync_mode == WB_SYNC_ALL)
 		goto retry_write;
 	else if (rc == -EAGAIN)
@@ -2180,7 +2180,7 @@ retry_write:
 	else
+	put_page(page);
 	free_xid(xid);
 	return rc;
@@ -2214,12 +2214,12 @@ static int cifs_write_end(struct file *file, struct address_space *mapping,
 		if (copied == len)
 		ClearPageChecked(page);
-	} else if (!PageUptodate(page) && copied == PAGE_CACHE_SIZE)
+	} else if (!PageUptodate(page) && copied == PAGE_SIZE)
 	if (!PageUptodate(page)) {
 		char *page_data;
-		unsigned offset = pos & (PAGE_CACHE_SIZE - 1);
+		unsigned offset = pos & (PAGE_SIZE - 1);
 		unsigned int xid;
 		xid = get_xid();
@@ -2248,7 +2248,7 @@ static int cifs_write_end(struct file *file, struct address_space *mapping,
 	unlock_page(page);
+	put_page(page);
 	return rc;
@@ -3286,9 +3286,9 @@ cifs_readv_complete(struct work_struct *work)
 		    (rdata->result == -EAGAIN && got_bytes))
 			cifs_readpage_to_fscache(rdata->mapping->host, page);
-		got_bytes -= min_t(unsigned int, PAGE_CACHE_SIZE, got_bytes);
+		got_bytes -= min_t(unsigned int, PAGE_SIZE, got_bytes);
+		put_page(page);
 		rdata->pages[i] = NULL;
 	kref_put(&rdata->refcount, cifs_readdata_release);
@@ -3307,21 +3307,21 @@ cifs_readpages_read_into_pages(struct TCP_Server_Info *server,
 	/* determine the eof that the server (probably) has */
 	eof = CIFS_I(rdata->mapping->host)->server_eof;
-	eof_index = eof ? (eof - 1) >> PAGE_CACHE_SHIFT : 0;
+	eof_index = eof ? (eof - 1) >> PAGE_SHIFT : 0;
 	cifs_dbg(FYI, "eof=%llu eof_index=%lu\n", eof, eof_index);
 	rdata->got_bytes = 0;
-	rdata->tailsz = PAGE_CACHE_SIZE;
+	rdata->tailsz = PAGE_SIZE;
 	for (i = 0; i < nr_pages; i++) {
 		struct page *page = rdata->pages[i];
-		if (len >= PAGE_CACHE_SIZE) {
+		if (len >= PAGE_SIZE) {
 			/* enough data to fill the page */
 			iov.iov_base = kmap(page);
-			iov.iov_len = PAGE_CACHE_SIZE;
+			iov.iov_len = PAGE_SIZE;
 			cifs_dbg(FYI, "%u: idx=%lu iov_base=%p iov_len=%zu\n",
 				 i, page->index, iov.iov_base, iov.iov_len);
+			len -= PAGE_SIZE;
 		} else if (len > 0) {
 			/* enough for partial page, fill and zero the rest */
@@ -3329,7 +3329,7 @@ cifs_readpages_read_into_pages(struct TCP_Server_Info *server,
 			memset(iov.iov_base + len,
-				'\0', PAGE_CACHE_SIZE - len);
+				'\0', PAGE_SIZE - len);
 			rdata->tailsz = len;
 			len = 0;
 		} else if (page->index > eof_index) {
@@ -3341,12 +3341,12 @@ cifs_readpages_read_into_pages(struct TCP_Server_Info *server,
 			 * to prevent the VFS from repeatedly attempting to
 			 * fill them until the writes are flushed.
-			zero_user(page, 0, PAGE_CACHE_SIZE);
+			zero_user(page, 0, PAGE_SIZE);
 			lru_cache_add_file(page);
 			flush_dcache_page(page);
 			unlock_page(page);
+			put_page(page);
 			rdata->nr_pages--;
 			continue;
@@ -3354,7 +3354,7 @@ cifs_readpages_read_into_pages(struct TCP_Server_Info *server,
 			/* no need to hold page hostage */
 			unlock_page(page);
+			put_page(page);
 			rdata->nr_pages--;
 			continue;
@@ -3402,8 +3402,8 @@ readpages_get_pages(struct address_space *mapping, struct list_head *page_list,
 	/* move first page to the tmplist */
-	*offset = (loff_t)page->index << PAGE_CACHE_SHIFT;
-	*bytes = PAGE_CACHE_SIZE;
+	*offset = (loff_t)page->index << PAGE_SHIFT;
+	*bytes = PAGE_SIZE;
 	*nr_pages = 1;
 	list_move_tail(&page->lru, tmplist);
@@ -3415,7 +3415,7 @@ readpages_get_pages(struct address_space *mapping, struct list_head *page_list,
 			break;
 		/* would this page push the read over the rsize? */
-		if (*bytes + PAGE_CACHE_SIZE > rsize)
+		if (*bytes + PAGE_SIZE > rsize)
 			break;
 		__SetPageLocked(page);
@@ -3424,7 +3424,7 @@ readpages_get_pages(struct address_space *mapping, struct list_head *page_list,
 			break;
-		(*bytes) += PAGE_CACHE_SIZE;
+		(*bytes) += PAGE_SIZE;
 		expected_index++;
 		(*nr_pages)++;
@@ -3493,7 +3493,7 @@ static int cifs_readpages(struct file *file, struct address_space *mapping,
 		 * reach this point however since we set ra_pages to 0 when the
 		 * rsize is smaller than a cache page.
-		if (unlikely(rsize < PAGE_CACHE_SIZE)) {
+		if (unlikely(rsize < PAGE_SIZE)) {
 			add_credits_and_wake_if(server, credits, 0);
 			return 0;
@@ -3512,7 +3512,7 @@ static int cifs_readpages(struct file *file, struct address_space *mapping,
 				list_del(&page->lru);
 				unlock_page(page);
+				put_page(page);
 			rc = -ENOMEM;
@@ -3524,7 +3524,7 @@ static int cifs_readpages(struct file *file, struct address_space *mapping,
 		rdata->offset = offset;
 		rdata->bytes = bytes;
 		rdata->pid = pid;
-		rdata->pagesz = PAGE_CACHE_SIZE;
+		rdata->pagesz = PAGE_SIZE;
 		rdata->read_into_pages = cifs_readpages_read_into_pages;
 		rdata->credits = credits;
@@ -3542,7 +3542,7 @@ static int cifs_readpages(struct file *file, struct address_space *mapping,
 				unlock_page(page);
+				put_page(page);
 			/* Fallback to the readpage in error/reconnect cases */
@@ -3577,7 +3577,7 @@ static int cifs_readpage_worker(struct file *file, struct page *page,
 	read_data = kmap(page);
 	/* for reads over a certain size could initiate async read ahead */
-	rc = cifs_read(file, read_data, PAGE_CACHE_SIZE, poffset);
+	rc = cifs_read(file, read_data, PAGE_SIZE, poffset);
 	if (rc < 0)
 		goto io_error;
@@ -3587,8 +3587,8 @@ static int cifs_readpage_worker(struct file *file, struct page *page,
 	file_inode(file)->i_atime =
 		current_fs_time(file_inode(file)->i_sb);
-	if (PAGE_CACHE_SIZE > rc)
-		memset(read_data + rc, 0, PAGE_CACHE_SIZE - rc);
+	if (PAGE_SIZE > rc)
+		memset(read_data + rc, 0, PAGE_SIZE - rc);
@@ -3608,7 +3608,7 @@ read_complete:
 static int cifs_readpage(struct file *file, struct page *page)
 	int rc = -EACCES;
 	unsigned int xid;
@@ -3679,8 +3679,8 @@ static int cifs_write_begin(struct file *file, struct address_space *mapping,
 			struct page **pagep, void **fsdata)
 	int oncethru = 0;
-	loff_t offset = pos & (PAGE_CACHE_SIZE - 1);
+	loff_t offset = pos & (PAGE_SIZE - 1);
 	loff_t page_start = pos & PAGE_MASK;
 	loff_t i_size;
 	struct page *page;
@@ -3703,7 +3703,7 @@ start:
 	 * the server. If the write is short, we'll end up doing a sync write
 	 * instead.
-	if (len == PAGE_CACHE_SIZE)
+	if (len == PAGE_SIZE)
 		goto out;
@@ -3718,7 +3718,7 @@ start:
 		    (offset == 0 && (pos + len) >= i_size)) {
 			zero_user_segments(page, 0, offset,
 					   offset + len,
-					   PAGE_CACHE_SIZE);
+					   PAGE_SIZE);
 			 * PageChecked means that the parts of the page
 			 * to which we're not writing are considered up
@@ -3737,7 +3737,7 @@ start:
 		 * do a sync write instead since PG_uptodate isn't set.
 		cifs_readpage_worker(file, page, &page_start);
+		put_page(page);
 		oncethru = 1;
 		goto start;
 	} else {
@@ -3764,7 +3764,7 @@ static void cifs_invalidate_page(struct page *page, unsigned int offset,
 	struct cifsInodeInfo *cifsi = CIFS_I(page->mapping->host);
-	if (offset == 0 && length == PAGE_CACHE_SIZE)
+	if (offset == 0 && length == PAGE_SIZE)
 		cifs_fscache_invalidate_page(page, &cifsi->vfs_inode);
@@ -3772,7 +3772,7 @@ static int cifs_launder_page(struct page *page)
 	int rc = 0;
 	loff_t range_start = page_offset(page);
-	loff_t range_end = range_start + (loff_t)(PAGE_CACHE_SIZE - 1);
+	loff_t range_end = range_start + (loff_t)(PAGE_SIZE - 1);
 	struct writeback_control wbc = {
 		.sync_mode = WB_SYNC_ALL,
 		.nr_to_write = 0,
diff --git a/fs/cifs/inode.c b/fs/cifs/inode.c
index aeb26db..5f9ad5c 100644
--- a/fs/cifs/inode.c
+++ b/fs/cifs/inode.c
@@ -59,7 +59,7 @@ static void cifs_set_ops(struct inode *inode)
 		/* check if server can support readpages */
 		if (cifs_sb_master_tcon(cifs_sb)->ses->server->maxBuf <
-				PAGE_CACHE_SIZE + MAX_CIFS_HDR_SIZE)
+				PAGE_SIZE + MAX_CIFS_HDR_SIZE)
 			inode->i_data.a_ops = &cifs_addr_ops_smallbuf;
 		else
 			inode->i_data.a_ops = &cifs_addr_ops;
@@ -2019,8 +2019,8 @@ int cifs_getattr(struct vfsmount *mnt, struct dentry *dentry,
 static int cifs_truncate_page(struct address_space *mapping, loff_t from)
-	pgoff_t index = from >> PAGE_CACHE_SHIFT;
-	unsigned offset = from & (PAGE_CACHE_SIZE - 1);
+	pgoff_t index = from >> PAGE_SHIFT;
+	unsigned offset = from & (PAGE_SIZE - 1);
 	struct page *page;
 	int rc = 0;
@@ -2028,9 +2028,9 @@ static int cifs_truncate_page(struct address_space *mapping, loff_t from)
 	if (!page)
 		return -ENOMEM;
 	unlock_page(page);
+	put_page(page);
 	return rc;
diff --git a/fs/configfs/mount.c b/fs/configfs/mount.c
index a8f3b58..cfd9132 100644
--- a/fs/configfs/mount.c
+++ b/fs/configfs/mount.c
@@ -71,8 +71,8 @@ static int configfs_fill_super(struct super_block *sb, void *data, int silent)
 	struct inode *inode;
 	struct dentry *root;
-	sb->s_blocksize = PAGE_CACHE_SIZE;
-	sb->s_blocksize_bits = PAGE_CACHE_SHIFT;
+	sb->s_blocksize = PAGE_SIZE;
+	sb->s_blocksize_bits = PAGE_SHIFT;
 	sb->s_magic = CONFIGFS_MAGIC;
 	sb->s_op = &configfs_ops;
 	sb->s_time_gran = 1;
diff --git a/fs/cramfs/inode.c b/fs/cramfs/inode.c
index b862bc2..2096654 100644
--- a/fs/cramfs/inode.c
+++ b/fs/cramfs/inode.c
@@ -152,7 +152,7 @@ static struct inode *get_cramfs_inode(struct super_block *sb,
 #define BLKS_PER_BUF_SHIFT	(2)
 #define BLKS_PER_BUF		(1 << BLKS_PER_BUF_SHIFT)
-#define BUFFER_SIZE		(BLKS_PER_BUF*PAGE_CACHE_SIZE)
+#define BUFFER_SIZE		(BLKS_PER_BUF*PAGE_SIZE)
 static unsigned char read_buffers[READ_BUFFERS][BUFFER_SIZE];
 static unsigned buffer_blocknr[READ_BUFFERS];
@@ -173,8 +173,8 @@ static void *cramfs_read(struct super_block *sb, unsigned int offset, unsigned i
 	if (!len)
 		return NULL;
-	blocknr = offset >> PAGE_CACHE_SHIFT;
-	offset &= PAGE_CACHE_SIZE - 1;
+	blocknr = offset >> PAGE_SHIFT;
+	offset &= PAGE_SIZE - 1;
 	/* Check if an existing buffer already has the data.. */
 	for (i = 0; i < READ_BUFFERS; i++) {
@@ -184,14 +184,14 @@ static void *cramfs_read(struct super_block *sb, unsigned int offset, unsigned i
 			continue;
 		if (blocknr < buffer_blocknr[i])
 			continue;
-		blk_offset = (blocknr - buffer_blocknr[i]) << PAGE_CACHE_SHIFT;
+		blk_offset = (blocknr - buffer_blocknr[i]) << PAGE_SHIFT;
 		blk_offset += offset;
 		if (blk_offset + len > BUFFER_SIZE)
 			continue;
 		return read_buffers[i] + blk_offset;
-	devsize = mapping->host->i_size >> PAGE_CACHE_SHIFT;
+	devsize = mapping->host->i_size >> PAGE_SHIFT;
 	/* Ok, read in BLKS_PER_BUF pages completely first. */
 	for (i = 0; i < BLKS_PER_BUF; i++) {
@@ -213,7 +213,7 @@ static void *cramfs_read(struct super_block *sb, unsigned int offset, unsigned i
 			wait_on_page_locked(page);
 				/* asynchronous error */
+				put_page(page);
 				pages[i] = NULL;
@@ -229,12 +229,12 @@ static void *cramfs_read(struct super_block *sb, unsigned int offset, unsigned i
 		struct page *page = pages[i];
 		if (page) {
-			memcpy(data, kmap(page), PAGE_CACHE_SIZE);
+			memcpy(data, kmap(page), PAGE_SIZE);
 			kunmap(page);
+			put_page(page);
 		} else
-			memset(data, 0, PAGE_CACHE_SIZE);
-		data += PAGE_CACHE_SIZE;
+			memset(data, 0, PAGE_SIZE);
+		data += PAGE_SIZE;
 	return read_buffers[buffer] + offset;
@@ -353,7 +353,7 @@ static int cramfs_statfs(struct dentry *dentry, struct kstatfs *buf)
 	u64 id = huge_encode_dev(sb->s_bdev->bd_dev);
 	buf->f_type = CRAMFS_MAGIC;
-	buf->f_bsize = PAGE_CACHE_SIZE;
+	buf->f_bsize = PAGE_SIZE;
 	buf->f_blocks = CRAMFS_SB(sb)->blocks;
 	buf->f_bfree = 0;
 	buf->f_bavail = 0;
@@ -496,7 +496,7 @@ static int cramfs_readpage(struct file *file, struct page *page)
 	int bytes_filled;
 	void *pgdata;
-	maxblock = (inode->i_size + PAGE_CACHE_SIZE - 1) >> PAGE_CACHE_SHIFT;
+	maxblock = (inode->i_size + PAGE_SIZE - 1) >> PAGE_SHIFT;
 	bytes_filled = 0;
 	pgdata = kmap(page);
@@ -516,14 +516,14 @@ static int cramfs_readpage(struct file *file, struct page *page)
 		if (compr_len == 0)
 			; /* hole */
-		else if (unlikely(compr_len > (PAGE_CACHE_SIZE << 1))) {
+		else if (unlikely(compr_len > (PAGE_SIZE << 1))) {
 			pr_err("bad compressed blocksize %u\n",
 				compr_len);
 			goto err;
 		} else {
 			mutex_lock(&read_mutex);
 			bytes_filled = cramfs_uncompress_block(pgdata,
-				 PAGE_CACHE_SIZE,
+				 PAGE_SIZE,
 				 cramfs_read(sb, start_offset, compr_len),
 				 compr_len);
 			mutex_unlock(&read_mutex);
@@ -532,7 +532,7 @@ static int cramfs_readpage(struct file *file, struct page *page)
-	memset(pgdata + bytes_filled, 0, PAGE_CACHE_SIZE - bytes_filled);
+	memset(pgdata + bytes_filled, 0, PAGE_SIZE - bytes_filled);
 	kunmap(page);
diff --git a/fs/crypto/crypto.c b/fs/crypto/crypto.c
index 06cd1a2..7f58045 100644
--- a/fs/crypto/crypto.c
+++ b/fs/crypto/crypto.c
@@ -175,10 +175,10 @@ static int do_page_crypto(struct inode *inode,
 			FS_XTS_TWEAK_SIZE - sizeof(index));
 	sg_init_table(&dst, 1);
-	sg_set_page(&dst, dest_page, PAGE_CACHE_SIZE, 0);
+	sg_set_page(&dst, dest_page, PAGE_SIZE, 0);
 	sg_init_table(&src, 1);
-	sg_set_page(&src, src_page, PAGE_CACHE_SIZE, 0);
-	skcipher_request_set_crypt(req, &src, &dst, PAGE_CACHE_SIZE,
+	sg_set_page(&src, src_page, PAGE_SIZE, 0);
+	skcipher_request_set_crypt(req, &src, &dst, PAGE_SIZE,
 					xts_tweak);
 	if (rw == FS_DECRYPT)
 		res = crypto_skcipher_decrypt(req);
@@ -287,7 +287,7 @@ int fscrypt_zeroout_range(struct inode *inode, pgoff_t lblk,
 	struct bio *bio;
 	int ret, err = 0;
-	BUG_ON(inode->i_sb->s_blocksize != PAGE_CACHE_SIZE);
+	BUG_ON(inode->i_sb->s_blocksize != PAGE_SIZE);
 	ctx = fscrypt_get_ctx(inode);
 	if (IS_ERR(ctx))
diff --git a/fs/dax.c b/fs/dax.c
index 90322eb..1f95416 100644
--- a/fs/dax.c
+++ b/fs/dax.c
@@ -323,7 +323,7 @@ static int dax_load_hole(struct address_space *mapping, struct page *page,
 	size = (i_size_read(inode) + PAGE_SIZE - 1) >> PAGE_SHIFT;
 	if (vmf->pgoff >= size) {
 		unlock_page(page);
+		put_page(page);
 		return VM_FAULT_SIGBUS;
@@ -351,7 +351,7 @@ static int copy_user_bh(struct page *to, struct inode *inode,
 #define NO_SECTOR -1
-#define DAX_PMD_INDEX(page_index) (page_index & (PMD_MASK >> PAGE_CACHE_SHIFT))
+#define DAX_PMD_INDEX(page_index) (page_index & (PMD_MASK >> PAGE_SHIFT))
 static int dax_radix_entry(struct address_space *mapping, pgoff_t index,
 		sector_t sector, bool pmd_entry, bool dirty)
@@ -506,8 +506,8 @@ int dax_writeback_mapping_range(struct address_space *mapping,
 	if (!mapping->nrexceptional || wbc->sync_mode != WB_SYNC_ALL)
 		return 0;
-	start_index = wbc->range_start >> PAGE_CACHE_SHIFT;
-	end_index = wbc->range_end >> PAGE_CACHE_SHIFT;
+	start_index = wbc->range_start >> PAGE_SHIFT;
+	end_index = wbc->range_end >> PAGE_SHIFT;
 	pmd_index = DAX_PMD_INDEX(start_index);
 	rcu_read_lock();
@@ -642,12 +642,12 @@ int __dax_fault(struct vm_area_struct *vma, struct vm_fault *vmf,
 	page = find_get_page(mapping, vmf->pgoff);
 	if (page) {
 		if (!lock_page_or_retry(page, vma->vm_mm, vmf->flags)) {
+			put_page(page);
 			return VM_FAULT_RETRY;
 		if (unlikely(page->mapping != mapping)) {
 			unlock_page(page);
+			put_page(page);
 			goto repeat;
@@ -711,10 +711,10 @@ int __dax_fault(struct vm_area_struct *vma, struct vm_fault *vmf,
 	if (page) {
 		unmap_mapping_range(mapping, vmf->pgoff << PAGE_SHIFT,
-							PAGE_CACHE_SIZE, 0);
+							PAGE_SIZE, 0);
 		delete_from_page_cache(page);
 		unlock_page(page);
+		put_page(page);
 		page = NULL;
@@ -747,7 +747,7 @@ int __dax_fault(struct vm_area_struct *vma, struct vm_fault *vmf,
  unlock_page:
 	if (page) {
 		unlock_page(page);
+		put_page(page);
 	goto out;
@@ -1104,18 +1104,18 @@ int dax_zero_page_range(struct inode *inode, loff_t from, unsigned length,
 							get_block_t get_block)
 	struct buffer_head bh;
 	int err;
 	/* Block boundary? Nothing to do */
 	if (!length)
 		return 0;
-	BUG_ON((offset + length) > PAGE_CACHE_SIZE);
+	BUG_ON((offset + length) > PAGE_SIZE);
 	memset(&bh, 0, sizeof(bh));
 	bh.b_bdev = inode->i_sb->s_bdev;
-	bh.b_size = PAGE_CACHE_SIZE;
+	bh.b_size = PAGE_SIZE;
 	err = get_block(inode, index, &bh, 0);
 	if (err < 0)
 		return err;
@@ -1123,7 +1123,7 @@ int dax_zero_page_range(struct inode *inode, loff_t from, unsigned length,
 		struct block_device *bdev = bh.b_bdev;
 		struct blk_dax_ctl dax = {
 			.sector = to_sector(&bh, inode),
-			.size = PAGE_CACHE_SIZE,
+			.size = PAGE_SIZE,
 		if (dax_map_atomic(bdev, &dax) < 0)
@@ -1154,7 +1154,7 @@ EXPORT_SYMBOL_GPL(dax_zero_page_range);
 int dax_truncate_page(struct inode *inode, loff_t from, get_block_t get_block)
-	unsigned length = PAGE_CACHE_ALIGN(from) - from;
+	unsigned length = PAGE_ALIGN(from) - from;
 	return dax_zero_page_range(inode, from, length, get_block);
 EXPORT_SYMBOL_GPL(dax_truncate_page);
diff --git a/fs/direct-io.c b/fs/direct-io.c
index 476f1ec..4720377 100644
--- a/fs/direct-io.c
+++ b/fs/direct-io.c
@@ -172,7 +172,7 @@ static inline int dio_refill_pages(struct dio *dio, struct dio_submit *sdio)
 		if (dio->page_errors == 0)
 			dio->page_errors = ret;
-		page_cache_get(page);
+		get_page(page);
 		dio->pages[0] = page;
 		sdio->head = 0;
 		sdio->tail = 1;
@@ -424,7 +424,7 @@ static inline void dio_bio_submit(struct dio *dio, struct dio_submit *sdio)
 static inline void dio_cleanup(struct dio *dio, struct dio_submit *sdio)
 	while (sdio->head < sdio->tail)
-		page_cache_release(dio->pages[sdio->head++]);
+		put_page(dio->pages[sdio->head++]);
@@ -487,7 +487,7 @@ static int dio_bio_complete(struct dio *dio, struct bio *bio)
 			if (dio->rw == READ && !PageCompound(page) &&
 					dio->should_dirty)
 				set_page_dirty_lock(page);
+			put_page(page);
 		err = bio->bi_error;
 		bio_put(bio);
@@ -696,7 +696,7 @@ static inline int dio_bio_add_page(struct dio_submit *sdio)
 		if ((sdio->cur_page_len + sdio->cur_page_offset) == PAGE_SIZE)
 			sdio->pages_in_io--;
-		page_cache_get(sdio->cur_page);
+		get_page(sdio->cur_page);
 		sdio->final_block_in_bio = sdio->cur_page_block +
 			(sdio->cur_page_len >> sdio->blkbits);
 		ret = 0;
@@ -810,13 +810,13 @@ submit_page_section(struct dio *dio, struct dio_submit *sdio, struct page *page,
 	if (sdio->cur_page) {
 		ret = dio_send_cur_page(dio, sdio, map_bh);
-		page_cache_release(sdio->cur_page);
+		put_page(sdio->cur_page);
 		sdio->cur_page = NULL;
 		if (ret)
 			return ret;
-	page_cache_get(page);		/* It is in dio */
+	get_page(page);		/* It is in dio */
 	sdio->cur_page = page;
 	sdio->cur_page_offset = offset;
 	sdio->cur_page_len = len;
@@ -830,7 +830,7 @@ out:
 	if (sdio->boundary) {
 		dio_bio_submit(dio, sdio);
 	return ret;
@@ -947,7 +947,7 @@ static int do_direct_IO(struct dio *dio, struct dio_submit *sdio,
 				ret = get_more_blocks(dio, sdio, map_bh);
 				if (ret) {
+					put_page(page);
 					goto out;
 				if (!buffer_mapped(map_bh))
@@ -988,7 +988,7 @@ do_holes:
 				/* AKPM: eargh, -ENOTBLK is a hack */
 				if (dio->rw & WRITE) {
+					put_page(page);
 					return -ENOTBLK;
@@ -1001,7 +1001,7 @@ do_holes:
 				if (sdio->block_in_file >=
 						i_size_aligned >> blkbits) {
 					/* We hit eof */
+					put_page(page);
 					goto out;
 				zero_user(page, from, 1 << blkbits);
@@ -1041,7 +1041,7 @@ do_holes:
 						  sdio->next_block_for_io,
 						  map_bh);
 			if (ret) {
+				put_page(page);
 				goto out;
 			sdio->next_block_for_io += this_chunk_blocks;
@@ -1057,7 +1057,7 @@ next_block:
 		/* Drop the ref which was taken in get_user_pages() */
+		put_page(page);
 out:
 	return ret;
@@ -1281,7 +1281,7 @@ do_blockdev_direct_IO(struct kiocb *iocb, struct inode *inode,
 		ret2 = dio_send_cur_page(dio, &sdio, &map_bh);
 		if (retval == 0)
 			retval = ret2;
-		page_cache_release(sdio.cur_page);
+		put_page(sdio.cur_page);
 		sdio.cur_page = NULL;
 	if (sdio.bio)
diff --git a/fs/dlm/lowcomms.c b/fs/dlm/lowcomms.c
index 00640e7..1ab012a 100644
--- a/fs/dlm/lowcomms.c
+++ b/fs/dlm/lowcomms.c
@@ -640,7 +640,7 @@ static int receive_from_sock(struct connection *con)
 		con->rx_page = alloc_page(GFP_ATOMIC);
 		if (con->rx_page == NULL)
 			goto out_resched;
-		cbuf_init(&con->cb, PAGE_CACHE_SIZE);
+		cbuf_init(&con->cb, PAGE_SIZE);
@@ -657,7 +657,7 @@ static int receive_from_sock(struct connection *con)
 	 * buffer and the start of the currently used section (cb.base)
 	if (cbuf_data(&con->cb) >= con->cb.base) {
-		iov[0].iov_len = PAGE_CACHE_SIZE - cbuf_data(&con->cb);
+		iov[0].iov_len = PAGE_SIZE - cbuf_data(&con->cb);
 		iov[1].iov_len = con->cb.base;
 		iov[1].iov_base = page_address(con->rx_page);
 		nvec = 2;
@@ -675,7 +675,7 @@ static int receive_from_sock(struct connection *con)
 	ret = dlm_process_incoming_buffer(con->nodeid,
 					  page_address(con->rx_page),
 					  con->cb.base, con->cb.len,
-					  PAGE_CACHE_SIZE);
+					  PAGE_SIZE);
 	if (ret == -EBADMSG) {
 		log_print("lowcomms: addr=%p, base=%u, len=%u, read=%d",
 			  page_address(con->rx_page), con->cb.base,
@@ -1416,7 +1416,7 @@ void *dlm_lowcomms_get_buffer(int nodeid, int len, gfp_t allocation, char **ppc)
 	spin_lock(&con->writequeue_lock);
 	e = list_entry(con->writequeue.prev, struct writequeue_entry, list);
 	if ((&e->list == &con->writequeue) ||
-	    (PAGE_CACHE_SIZE - e->end < len)) {
+	    (PAGE_SIZE - e->end < len)) {
 		e = NULL;
 	} else {
 		offset = e->end;
diff --git a/fs/ecryptfs/crypto.c b/fs/ecryptfs/crypto.c
index 64026e5..d09cb4c 100644
--- a/fs/ecryptfs/crypto.c
+++ b/fs/ecryptfs/crypto.c
@@ -286,7 +286,7 @@ int virt_to_scatterlist(const void *addr, int size, struct scatterlist *sg,
 		pg = virt_to_page(addr);
 		offset = offset_in_page(addr);
 		sg_set_page(&sg[i], pg, 0, offset);
-		remainder_of_page = PAGE_CACHE_SIZE - offset;
+		remainder_of_page = PAGE_SIZE - offset;
 		if (size >= remainder_of_page) {
 			sg[i].length = remainder_of_page;
 			addr += remainder_of_page;
@@ -400,7 +400,7 @@ static loff_t lower_offset_for_page(struct ecryptfs_crypt_stat *crypt_stat,
 				    struct page *page)
 	return ecryptfs_lower_header_size(crypt_stat) +
-	       ((loff_t)page->index << PAGE_CACHE_SHIFT);
+	       ((loff_t)page->index << PAGE_SHIFT);
@@ -428,7 +428,7 @@ static int crypt_extent(struct ecryptfs_crypt_stat *crypt_stat,
 	size_t extent_size = crypt_stat->extent_size;
 	int rc;
-	extent_base = (((loff_t)page_index) * (PAGE_CACHE_SIZE / extent_size));
+	extent_base = (((loff_t)page_index) * (PAGE_SIZE / extent_size));
 	rc = ecryptfs_derive_iv(extent_iv, crypt_stat,
 				(extent_base + extent_offset));
 	if (rc) {
@@ -498,7 +498,7 @@ int ecryptfs_encrypt_page(struct page *page)
 	for (extent_offset = 0;
-	     extent_offset < (PAGE_CACHE_SIZE / crypt_stat->extent_size);
+	     extent_offset < (PAGE_SIZE / crypt_stat->extent_size);
 	     extent_offset++) {
 		rc = crypt_extent(crypt_stat, enc_extent_page, page,
 				  extent_offset, ENCRYPT);
@@ -512,7 +512,7 @@ int ecryptfs_encrypt_page(struct page *page)
 	lower_offset = lower_offset_for_page(crypt_stat, page);
 	enc_extent_virt = kmap(enc_extent_page);
 	rc = ecryptfs_write_lower(ecryptfs_inode, enc_extent_virt, lower_offset,
-				  PAGE_CACHE_SIZE);
+				  PAGE_SIZE);
 	kunmap(enc_extent_page);
 	if (rc < 0) {
 		ecryptfs_printk(KERN_ERR,
@@ -560,7 +560,7 @@ int ecryptfs_decrypt_page(struct page *page)
 	page_virt = kmap(page);
-	rc = ecryptfs_read_lower(page_virt, lower_offset, PAGE_CACHE_SIZE,
+	rc = ecryptfs_read_lower(page_virt, lower_offset, PAGE_SIZE,
 				 ecryptfs_inode);
 	kunmap(page);
 	if (rc < 0) {
@@ -571,7 +571,7 @@ int ecryptfs_decrypt_page(struct page *page)
 	     extent_offset++) {
 		rc = crypt_extent(crypt_stat, page, page,
 				  extent_offset, DECRYPT);
@@ -659,11 +659,11 @@ void ecryptfs_set_default_sizes(struct ecryptfs_crypt_stat *crypt_stat)
 	if (crypt_stat->flags & ECRYPTFS_METADATA_IN_XATTR)
 		crypt_stat->metadata_size = ECRYPTFS_MINIMUM_HEADER_EXTENT_SIZE;
 	else {
-		if (PAGE_CACHE_SIZE <= ECRYPTFS_MINIMUM_HEADER_EXTENT_SIZE)
+		if (PAGE_SIZE <= ECRYPTFS_MINIMUM_HEADER_EXTENT_SIZE)
 		else
-			crypt_stat->metadata_size = PAGE_CACHE_SIZE;
+			crypt_stat->metadata_size = PAGE_SIZE;
@@ -1442,7 +1442,7 @@ int ecryptfs_read_metadata(struct dentry *ecryptfs_dentry)
 						ECRYPTFS_VALIDATE_HEADER_SIZE);
 	if (rc) {
 		/* metadata is not in the file header, so try xattrs */
-		memset(page_virt, 0, PAGE_CACHE_SIZE);
+		memset(page_virt, 0, PAGE_SIZE);
 		rc = ecryptfs_read_xattr_region(page_virt, ecryptfs_inode);
 		if (rc) {
 			printk(KERN_DEBUG "Valid eCryptfs headers not found in "
@@ -1475,7 +1475,7 @@ int ecryptfs_read_metadata(struct dentry *ecryptfs_dentry)
 out:
 	if (page_virt) {
 		kmem_cache_free(ecryptfs_header_cache, page_virt);
 	return rc;
diff --git a/fs/ecryptfs/inode.c b/fs/ecryptfs/inode.c
index 121114e..2a988f3 100644
--- a/fs/ecryptfs/inode.c
+++ b/fs/ecryptfs/inode.c
@@ -765,8 +765,8 @@ static int truncate_upper(struct dentry *dentry, struct iattr *ia,
 		 * in which ia->ia_size is located. Fill in the end of
 		 * that page from (ia->ia_size & ~PAGE_CACHE_MASK) to
 		 * PAGE_CACHE_SIZE with zeros. */
-		size_t num_zeros = (PAGE_CACHE_SIZE
-				    - (ia->ia_size & ~PAGE_CACHE_MASK));
+		size_t num_zeros = (PAGE_SIZE
+				    - (ia->ia_size & ~PAGE_MASK));
 		if (!(crypt_stat->flags & ECRYPTFS_ENCRYPTED)) {
 			truncate_setsize(inode, ia->ia_size);
diff --git a/fs/ecryptfs/keystore.c b/fs/ecryptfs/keystore.c
index 9893d15..3cf1546 100644
--- a/fs/ecryptfs/keystore.c
+++ b/fs/ecryptfs/keystore.c
@@ -1798,7 +1798,7 @@ int ecryptfs_parse_packet_set(struct ecryptfs_crypt_stat *crypt_stat,
 	 * added the our &auth_tok_list */
 	next_packet_is_auth_tok_packet = 1;
 	while (next_packet_is_auth_tok_packet) {
-		size_t max_packet_size = ((PAGE_CACHE_SIZE - 8) - i);
+		size_t max_packet_size = ((PAGE_SIZE - 8) - i);
 		switch (src[i]) {
 		case ECRYPTFS_TAG_3_PACKET_TYPE:
diff --git a/fs/ecryptfs/main.c b/fs/ecryptfs/main.c
index 8b0b4a7..1698132 100644
--- a/fs/ecryptfs/main.c
+++ b/fs/ecryptfs/main.c
@@ -695,12 +695,12 @@ static struct ecryptfs_cache_info {
 		.cache = &ecryptfs_header_cache,
 		.name = "ecryptfs_headers",
 		.cache = &ecryptfs_xattr_cache,
 		.name = "ecryptfs_xattr_cache",
 		.cache = &ecryptfs_key_record_cache,
@@ -818,7 +818,7 @@ static int __init ecryptfs_init(void)
 	int rc;
-	if (ECRYPTFS_DEFAULT_EXTENT_SIZE > PAGE_CACHE_SIZE) {
+	if (ECRYPTFS_DEFAULT_EXTENT_SIZE > PAGE_SIZE) {
 		rc = -EINVAL;
 		ecryptfs_printk(KERN_ERR, "The eCryptfs extent size is "
 				"larger than the host's page size, and so "
@@ -826,7 +826,7 @@ static int __init ecryptfs_init(void)
 				"default eCryptfs extent size is [%u] bytes; "
 				"the page size is [%lu] bytes.\n",
 				ECRYPTFS_DEFAULT_EXTENT_SIZE,
-				(unsigned long)PAGE_CACHE_SIZE);
+				(unsigned long)PAGE_SIZE);
 		goto out;
 	rc = ecryptfs_init_kmem_caches();
diff --git a/fs/ecryptfs/mmap.c b/fs/ecryptfs/mmap.c
index 1f58652..e6b1d80 100644
--- a/fs/ecryptfs/mmap.c
+++ b/fs/ecryptfs/mmap.c
@@ -122,7 +122,7 @@ ecryptfs_copy_up_encrypted_with_header(struct page *page,
 	loff_t extent_num_in_page = 0;
-	loff_t num_extents_per_page = (PAGE_CACHE_SIZE
+	loff_t num_extents_per_page = (PAGE_SIZE
 	int rc = 0;
@@ -138,7 +138,7 @@ ecryptfs_copy_up_encrypted_with_header(struct page *page,
 			char *page_virt;
 			page_virt = kmap_atomic(page);
 			/* TODO: Support more than one header extent */
 			if (view_extent_num == 0) {
 				size_t written;
@@ -164,8 +164,8 @@ ecryptfs_copy_up_encrypted_with_header(struct page *page,
 				 - crypt_stat->metadata_size);
 			rc = ecryptfs_read_lower_page_segment(
-				page, (lower_offset >> PAGE_CACHE_SHIFT),
-				(lower_offset & ~PAGE_CACHE_MASK),
+				page, (lower_offset >> PAGE_SHIFT),
+				(lower_offset & ~PAGE_MASK),
 				crypt_stat->extent_size, page->mapping->host);
 			if (rc) {
 				printk(KERN_ERR "%s: Error attempting to read "
@@ -198,7 +198,7 @@ static int ecryptfs_readpage(struct file *file, struct page *page)
 	if (!crypt_stat || !(crypt_stat->flags & ECRYPTFS_ENCRYPTED)) {
 		rc = ecryptfs_read_lower_page_segment(page, page->index, 0,
-						      PAGE_CACHE_SIZE,
+						      PAGE_SIZE,
 	} else if (crypt_stat->flags & ECRYPTFS_VIEW_AS_ENCRYPTED) {
 		if (crypt_stat->flags & ECRYPTFS_METADATA_IN_XATTR) {
@@ -215,7 +215,7 @@ static int ecryptfs_readpage(struct file *file, struct page *page)
 		} else {
-				page, page->index, 0, PAGE_CACHE_SIZE,
+				page, page->index, 0, PAGE_SIZE,
 			if (rc) {
 				printk(KERN_ERR "Error reading page; rc = "
@@ -250,12 +250,12 @@ static int fill_zeros_to_end_of_page(struct page *page, unsigned int to)
 	struct inode *inode = page->mapping->host;
 	int end_byte_in_page;
-	if ((i_size_read(inode) / PAGE_CACHE_SIZE) != page->index)
+	if ((i_size_read(inode) / PAGE_SIZE) != page->index)
 		goto out;
-	end_byte_in_page = i_size_read(inode) % PAGE_CACHE_SIZE;
+	end_byte_in_page = i_size_read(inode) % PAGE_SIZE;
 	if (to > end_byte_in_page)
 		end_byte_in_page = to;
-	zero_user_segment(page, end_byte_in_page, PAGE_CACHE_SIZE);
+	zero_user_segment(page, end_byte_in_page, PAGE_SIZE);
 out:
 	return 0;
@@ -279,7 +279,7 @@ static int ecryptfs_write_begin(struct file *file,
 			loff_t pos, unsigned len, unsigned flags,
-	pgoff_t index = pos >> PAGE_CACHE_SHIFT;
+	pgoff_t index = pos >> PAGE_SHIFT;
 	struct page *page;
 	loff_t prev_page_end_size;
 	int rc = 0;
@@ -289,14 +289,14 @@ static int ecryptfs_write_begin(struct file *file,
 		return -ENOMEM;
 	*pagep = page;
-	prev_page_end_size = ((loff_t)index << PAGE_CACHE_SHIFT);
+	prev_page_end_size = ((loff_t)index << PAGE_SHIFT);
 		struct ecryptfs_crypt_stat *crypt_stat =
 			&ecryptfs_inode_to_private(mapping->host)->crypt_stat;
-				page, index, 0, PAGE_CACHE_SIZE, mapping->host);
+				page, index, 0, PAGE_SIZE, mapping->host);
 			if (rc) {
 				       "lower page segment; rc = [%d]\n",
@@ -322,7 +322,7 @@ static int ecryptfs_write_begin(struct file *file,
 			} else {
 					mapping->host);
 				if (rc) {
 					printk(KERN_ERR "%s: Error reading "
@@ -336,9 +336,9 @@ static int ecryptfs_write_begin(struct file *file,
 		} else {
 			if (prev_page_end_size
 			    >= i_size_read(page->mapping->host)) {
-			} else if (len < PAGE_CACHE_SIZE) {
+			} else if (len < PAGE_SIZE) {
 				rc = ecryptfs_decrypt_page(page);
 				if (rc) {
 					printk(KERN_ERR "%s: Error decrypting "
@@ -371,11 +371,11 @@ static int ecryptfs_write_begin(struct file *file,
 	 * of page?  Zero it out. */
 	if ((i_size_read(mapping->host) == prev_page_end_size)
 	    && (pos != 0))
 out:
 	if (unlikely(rc)) {
 		unlock_page(page);
+		put_page(page);
 		*pagep = NULL;
 	return rc;
@@ -437,7 +437,7 @@ static int ecryptfs_write_inode_size_to_xattr(struct inode *ecryptfs_inode)
 	inode_lock(lower_inode);
 	size = lower_inode->i_op->getxattr(lower_dentry, ECRYPTFS_XATTR_NAME,
-					   xattr_virt, PAGE_CACHE_SIZE);
+					   xattr_virt, PAGE_SIZE);
 	if (size < 0)
 		size = 8;
 	put_unaligned_be64(i_size_read(ecryptfs_inode), xattr_virt);
@@ -479,8 +479,8 @@ static int ecryptfs_write_end(struct file *file,
 			loff_t pos, unsigned len, unsigned copied,
-	unsigned from = pos & (PAGE_CACHE_SIZE - 1);
+	unsigned from = pos & (PAGE_SIZE - 1);
 	unsigned to = from + copied;
 	struct inode *ecryptfs_inode = mapping->host;
@@ -500,7 +500,7 @@ static int ecryptfs_write_end(struct file *file,
 		goto out;
-		if (copied < PAGE_CACHE_SIZE) {
+		if (copied < PAGE_SIZE) {
 			rc = 0;
 			goto out;
@@ -533,7 +533,7 @@ static int ecryptfs_write_end(struct file *file,
 		rc = copied;
 out:
 	unlock_page(page);
+	put_page(page);
 	return rc;
diff --git a/fs/ecryptfs/read_write.c b/fs/ecryptfs/read_write.c
index 09fe622..158a3a3 100644
--- a/fs/ecryptfs/read_write.c
+++ b/fs/ecryptfs/read_write.c
@@ -74,7 +74,7 @@ int ecryptfs_write_lower_page_segment(struct inode *ecryptfs_inode,
 	loff_t offset;
 	int rc;
-	offset = ((((loff_t)page_for_lower->index) << PAGE_CACHE_SHIFT)
+	offset = ((((loff_t)page_for_lower->index) << PAGE_SHIFT)
 		  + offset_in_page);
 	virt = kmap(page_for_lower);
 	rc = ecryptfs_write_lower(ecryptfs_inode, virt, offset, size);
@@ -123,9 +123,9 @@ int ecryptfs_write(struct inode *ecryptfs_inode, char *data, loff_t offset,
 	else
 		pos = offset;
 	while (pos < (offset + size)) {
-		pgoff_t ecryptfs_page_idx = (pos >> PAGE_CACHE_SHIFT);
-		size_t start_offset_in_page = (pos & ~PAGE_CACHE_MASK);
-		size_t num_bytes = (PAGE_CACHE_SIZE - start_offset_in_page);
+		pgoff_t ecryptfs_page_idx = (pos >> PAGE_SHIFT);
+		size_t start_offset_in_page = (pos & ~PAGE_MASK);
+		size_t num_bytes = (PAGE_SIZE - start_offset_in_page);
 		loff_t total_remaining_bytes = ((offset + size) - pos);
 		if (fatal_signal_pending(current)) {
@@ -165,7 +165,7 @@ int ecryptfs_write(struct inode *ecryptfs_inode, char *data, loff_t offset,
 			 * Fill in zero values to the end of the page */
 			memset(((char *)ecryptfs_page_virt
 				+ start_offset_in_page), 0,
-				PAGE_CACHE_SIZE - start_offset_in_page);
+				PAGE_SIZE - start_offset_in_page);
 		/* pos >= offset, we are now writing the data request */
@@ -186,7 +186,7 @@ int ecryptfs_write(struct inode *ecryptfs_inode, char *data, loff_t offset,
 						ecryptfs_page,
 						start_offset_in_page,
 						data_offset);
-		page_cache_release(ecryptfs_page);
+		put_page(ecryptfs_page);
 		if (rc) {
 			printk(KERN_ERR "%s: Error encrypting "
 			       "page; rc = [%d]\n", __func__, rc);
@@ -262,7 +262,7 @@ int ecryptfs_read_lower_page_segment(struct page *page_for_ecryptfs,
 	loff_t offset;
 	int rc;
-	offset = ((((loff_t)page_index) << PAGE_CACHE_SHIFT) + offset_in_page);
+	offset = ((((loff_t)page_index) << PAGE_SHIFT) + offset_in_page);
 	virt = kmap(page_for_ecryptfs);
 	rc = ecryptfs_read_lower(virt, offset, size, ecryptfs_inode);
 	if (rc > 0)
diff --git a/fs/efivarfs/super.c b/fs/efivarfs/super.c
index dd029d1..553c5d2 100644
--- a/fs/efivarfs/super.c
+++ b/fs/efivarfs/super.c
@@ -197,8 +197,8 @@ static int efivarfs_fill_super(struct super_block *sb, void *data, int silent)
 	efivarfs_sb = sb;
 	sb->s_maxbytes          = MAX_LFS_FILESIZE;
 	sb->s_magic             = EFIVARFS_MAGIC;
 	sb->s_op                = &efivarfs_ops;
 	sb->s_d_op		= &efivarfs_d_ops;
diff --git a/fs/exofs/dir.c b/fs/exofs/dir.c
index e5bb2ab..547b93c 100644
--- a/fs/exofs/dir.c
+++ b/fs/exofs/dir.c
@@ -41,16 +41,16 @@ static inline unsigned exofs_chunk_size(struct inode *inode)
 static inline void exofs_put_page(struct page *page)
 	kunmap(page);
+	put_page(page);
 static unsigned exofs_last_byte(struct inode *inode, unsigned long page_nr)
 	loff_t last_byte = inode->i_size;
-	last_byte -= page_nr << PAGE_CACHE_SHIFT;
-	if (last_byte > PAGE_CACHE_SIZE)
-		last_byte = PAGE_CACHE_SIZE;
+	last_byte -= page_nr << PAGE_SHIFT;
+	if (last_byte > PAGE_SIZE)
+		last_byte = PAGE_SIZE;
 	return last_byte;
@@ -85,13 +85,13 @@ static void exofs_check_page(struct page *page)
 	unsigned chunk_size = exofs_chunk_size(dir);
 	char *kaddr = page_address(page);
 	unsigned offs, rec_len;
-	unsigned limit = PAGE_CACHE_SIZE;
+	unsigned limit = PAGE_SIZE;
 	struct exofs_dir_entry *p;
 	char *error;
 	/* if the page is the last one in the directory */
-	if ((dir->i_size >> PAGE_CACHE_SHIFT) == page->index) {
-		limit = dir->i_size & ~PAGE_CACHE_MASK;
+	if ((dir->i_size >> PAGE_SHIFT) == page->index) {
+		limit = dir->i_size & ~PAGE_MASK;
 		if (limit & (chunk_size - 1))
 			goto Ebadsize;
 		if (!limit)
@@ -138,7 +138,7 @@ bad_entry:
 	EXOFS_ERR(
 		"ERROR [exofs_check_page]: bad entry in directory(0x%lx): %s - "
 		"offset=%lu, inode=0x%llu, rec_len=%d, name_len=%d\n",
-		dir->i_ino, error, (page->index<<PAGE_CACHE_SHIFT)+offs,
+		dir->i_ino, error, (page->index<<PAGE_SHIFT)+offs,
 		_LLU(le64_to_cpu(p->inode_no)),
 		rec_len, p->name_len);
 	goto fail;
@@ -147,7 +147,7 @@ Eend:
 	EXOFS_ERR("ERROR [exofs_check_page]: "
 		"entry in directory(0x%lx) spans the page boundary"
 		"offset=%lu, inode=0x%llx\n",
-		dir->i_ino, (page->index<<PAGE_CACHE_SHIFT)+offs,
+		dir->i_ino, (page->index<<PAGE_SHIFT)+offs,
 		_LLU(le64_to_cpu(p->inode_no)));
 fail:
 	SetPageChecked(page);
@@ -237,8 +237,8 @@ exofs_readdir(struct file *file, struct dir_context *ctx)
 	loff_t pos = ctx->pos;
-	unsigned int offset = pos & ~PAGE_CACHE_MASK;
-	unsigned long n = pos >> PAGE_CACHE_SHIFT;
+	unsigned int offset = pos & ~PAGE_MASK;
+	unsigned long n = pos >> PAGE_SHIFT;
 	unsigned long npages = dir_pages(inode);
 	unsigned chunk_mask = ~(exofs_chunk_size(inode)-1);
 	int need_revalidate = (file->f_version != inode->i_version);
@@ -254,7 +254,7 @@ exofs_readdir(struct file *file, struct dir_context *ctx)
 		if (IS_ERR(page)) {
 			EXOFS_ERR("ERROR: bad page in directory(0x%lx)\n",
 				  inode->i_ino);
-			ctx->pos += PAGE_CACHE_SIZE - offset;
+			ctx->pos += PAGE_SIZE - offset;
 			return PTR_ERR(page);
@@ -262,7 +262,7 @@ exofs_readdir(struct file *file, struct dir_context *ctx)
 			if (offset) {
 				offset = exofs_validate_entry(kaddr, offset,
 								chunk_mask);
-				ctx->pos = (n<<PAGE_CACHE_SHIFT) + offset;
+				ctx->pos = (n<<PAGE_SHIFT) + offset;
 			file->f_version = inode->i_version;
 			need_revalidate = 0;
@@ -449,7 +449,7 @@ int exofs_add_link(struct dentry *dentry, struct inode *inode)
 		dir_end = kaddr + exofs_last_byte(dir, n);
 		de = (struct exofs_dir_entry *)kaddr;
-		kaddr += PAGE_CACHE_SIZE - reclen;
+		kaddr += PAGE_SIZE - reclen;
 		while ((char *)de <= kaddr) {
 			if ((char *)de == dir_end) {
 				name_len = 0;
@@ -602,7 +602,7 @@ int exofs_make_empty(struct inode *inode, struct inode *parent)
 	kunmap_atomic(kaddr);
 	err = exofs_commit_chunk(page, 0, chunk_size);
 fail:
+	put_page(page);
 	return err;
diff --git a/fs/exofs/inode.c b/fs/exofs/inode.c
index 9eaf595..49e1bd0 100644
--- a/fs/exofs/inode.c
+++ b/fs/exofs/inode.c
@@ -317,7 +317,7 @@ static int read_exec(struct page_collect *pcol)
 	if (!pcol->ios) {
 		int ret = ore_get_rw_state(&pcol->sbi->layout, &oi->oc, true,
-					     pcol->pg_first << PAGE_CACHE_SHIFT,
+					     pcol->pg_first << PAGE_SHIFT,
 					     pcol->length, &pcol->ios);
 		if (ret)
@@ -383,7 +383,7 @@ static int readpage_strip(void *data, struct page *page)
 	struct inode *inode = pcol->inode;
 	struct exofs_i_info *oi = exofs_i(inode);
 	loff_t i_size = i_size_read(inode);
-	pgoff_t end_index = i_size >> PAGE_CACHE_SHIFT;
+	pgoff_t end_index = i_size >> PAGE_SHIFT;
 	size_t len;
 	int ret;
@@ -397,9 +397,9 @@ static int readpage_strip(void *data, struct page *page)
 	pcol->that_locked_page = page;
 	if (page->index < end_index)
+		len = PAGE_SIZE;
 	else if (page->index == end_index)
-		len = i_size & ~PAGE_CACHE_MASK;
+		len = i_size & ~PAGE_MASK;
 	else
 		len = 0;
@@ -442,8 +442,8 @@ try_again:
 			goto fail;
-	if (len != PAGE_CACHE_SIZE)
-		zero_user(page, len, PAGE_CACHE_SIZE - len);
+	if (len != PAGE_SIZE)
+		zero_user(page, len, PAGE_SIZE - len);
 	EXOFS_DBGMSG2("    readpage_strip(0x%lx, 0x%lx) len=0x%zx\n",
 		     inode->i_ino, page->index, len);
@@ -609,7 +609,7 @@ static void __r4w_put_page(void *priv, struct page *page)
 	if ((pcol->that_locked_page != page) && (ZERO_PAGE(0) != page)) {
 		EXOFS_DBGMSG2("index=0x%lx\n", page->index);
+		put_page(page);
 		return;
 	EXOFS_DBGMSG2("that_locked_page index=0x%lx\n",
@@ -633,7 +633,7 @@ static int write_exec(struct page_collect *pcol)
 	BUG_ON(pcol->ios);
 	ret = ore_get_rw_state(&pcol->sbi->layout, &oi->oc, false,
 	if (unlikely(ret))
 		goto err;
@@ -696,7 +696,7 @@ static int writepage_strip(struct page *page,
 	size_t len;
 	int ret;
@@ -708,9 +708,9 @@ static int writepage_strip(struct page *page,
 		/* in this case, the page is within the limits of the file */
+		len = PAGE_SIZE;
 	else {
 		if (page->index > end_index || !len) {
 			/* in this case, the page is outside the limits
@@ -790,10 +790,10 @@ static int exofs_writepages(struct address_space *mapping,
 	long start, end, expected_pages;
 	int ret;
 	end = (wbc->range_end == LLONG_MAX) ?
 			start + mapping->nrpages :
-			wbc->range_end >> PAGE_CACHE_SHIFT;
+			wbc->range_end >> PAGE_SHIFT;
 	if (start || end)
 		expected_pages = end - start + 1;
@@ -881,15 +881,15 @@ int exofs_write_begin(struct file *file, struct address_space *mapping,
 	 /* read modify write */
-	if (!PageUptodate(page) && (len != PAGE_CACHE_SIZE)) {
+	if (!PageUptodate(page) && (len != PAGE_SIZE)) {
 		loff_t i_size = i_size_read(mapping->host);
 		size_t rlen;
-			rlen = PAGE_CACHE_SIZE;
+			rlen = PAGE_SIZE;
-			rlen = i_size & ~PAGE_CACHE_MASK;
+			rlen = i_size & ~PAGE_MASK;
 		else
 			rlen = 0;
diff --git a/fs/exofs/namei.c b/fs/exofs/namei.c
index c20d77d..622a686 100644
--- a/fs/exofs/namei.c
+++ b/fs/exofs/namei.c
@@ -292,11 +292,11 @@ static int exofs_rename(struct inode *old_dir, struct dentry *old_dentry,
 out_dir:
 	if (dir_de) {
 		kunmap(dir_page);
-		page_cache_release(dir_page);
+		put_page(dir_page);
 out_old:
 	kunmap(old_page);
-	page_cache_release(old_page);
+	put_page(old_page);
 out:
 	return err;
diff --git a/fs/ext2/dir.c b/fs/ext2/dir.c
index 0c6638b..1b45694 100644
--- a/fs/ext2/dir.c
+++ b/fs/ext2/dir.c
@@ -67,7 +67,7 @@ static inline unsigned ext2_chunk_size(struct inode *inode)
 static inline void ext2_put_page(struct page *page)
 	kunmap(page);
+	put_page(page);
@@ -79,9 +79,9 @@ ext2_last_byte(struct inode *inode, unsigned long page_nr)
 	unsigned last_byte = inode->i_size;
 	return last_byte;
@@ -118,12 +118,12 @@ static void ext2_check_page(struct page *page, int quiet)
 	u32 max_inumber = le32_to_cpu(EXT2_SB(sb)->s_es->s_inodes_count);
 	ext2_dirent *p;
 	char *error;
 			goto Ebadsize;
 		if (!limit)
@@ -176,7 +176,7 @@ bad_entry:
 	if (!quiet)
 		ext2_error(sb, __func__, "bad entry in directory #%lu: : %s - "
 			"offset=%lu, inode=%lu, rec_len=%d, name_len=%d",
 			(unsigned long) le32_to_cpu(p->inode),
 	goto fail;
@@ -186,7 +186,7 @@ Eend:
 		ext2_error(sb, "ext2_check_page",
 			"entry in directory #%lu spans the page boundary"
 			"offset=%lu, inode=%lu",
 			(unsigned long) le32_to_cpu(p->inode));
 fail:
@@ -287,8 +287,8 @@ ext2_readdir(struct file *file, struct dir_context *ctx)
 	struct super_block *sb = inode->i_sb;
 	unsigned chunk_mask = ~(ext2_chunk_size(inode)-1);
 	unsigned char *types = NULL;
@@ -309,14 +309,14 @@ ext2_readdir(struct file *file, struct dir_context *ctx)
 				   "bad page in #%lu",
 				   inode->i_ino);
 		if (unlikely(need_revalidate)) {
 			if (offset) {
 				offset = ext2_validate_entry(kaddr, offset, chunk_mask);
@@ -406,7 +406,7 @@ struct ext2_dir_entry_2 *ext2_find_entry (struct inode * dir,
 		if (++n >= npages)
 			n = 0;
 		/* next page is past the blocks we've got */
-		if (unlikely(n > (dir->i_blocks >> (PAGE_CACHE_SHIFT - 9)))) {
+		if (unlikely(n > (dir->i_blocks >> (PAGE_SHIFT - 9)))) {
 			ext2_error(dir->i_sb, __func__,
 				"dir %lu size %lld exceeds block count %llu",
 				dir->i_ino, dir->i_size,
@@ -511,7 +511,7 @@ int ext2_add_link (struct dentry *dentry, struct inode *inode)
 		dir_end = kaddr + ext2_last_byte(dir, n);
 		de = (ext2_dirent *)kaddr;
 				/* We hit i_size */
@@ -655,7 +655,7 @@ int ext2_make_empty(struct inode *inode, struct inode *parent)
 	err = ext2_commit_chunk(page, 0, chunk_size);
 fail:
+	put_page(page);
 	return err;
diff --git a/fs/ext2/namei.c b/fs/ext2/namei.c
index 7a2be8f..d348439 100644
--- a/fs/ext2/namei.c
+++ b/fs/ext2/namei.c
@@ -398,7 +398,7 @@ static int ext2_rename (struct inode * old_dir, struct dentry * old_dentry,
 			ext2_set_link(old_inode, dir_de, dir_page, new_dir, 0);
 		else {
 			kunmap(dir_page);
 		inode_dec_link_count(old_dir);
@@ -408,11 +408,11 @@ static int ext2_rename (struct inode * old_dir, struct dentry * old_dentry,
 out_dir:
 	if (dir_de) {
 		kunmap(dir_page);
 out_old:
 	kunmap(old_page);
 out:
 	return err;
diff --git a/fs/ext4/crypto.c b/fs/ext4/crypto.c
index edc053a..2580ef3 100644
--- a/fs/ext4/crypto.c
+++ b/fs/ext4/crypto.c
@@ -283,10 +283,10 @@ static int ext4_page_crypto(struct inode *inode,
 	       EXT4_XTS_TWEAK_SIZE - sizeof(index));
 				   xts_tweak);
 	if (rw == EXT4_DECRYPT)
@@ -396,7 +396,7 @@ int ext4_encrypted_zeroout(struct inode *inode, ext4_lblk_t lblk,
 		 (unsigned long) inode->i_ino, lblk, len);
 #endif
 	ctx = ext4_get_crypto_ctx(inode);
 	if (IS_ERR(ctx))
diff --git a/fs/ext4/dir.c b/fs/ext4/dir.c
index 50ba27c..561d730 100644
--- a/fs/ext4/dir.c
+++ b/fs/ext4/dir.c
@@ -155,13 +155,13 @@ static int ext4_readdir(struct file *file, struct dir_context *ctx)
 		err = ext4_map_blocks(NULL, inode, &map, 0);
 		if (err > 0) {
 			pgoff_t index = map.m_pblk >>
-					(PAGE_CACHE_SHIFT - inode->i_blkbits);
+					(PAGE_SHIFT - inode->i_blkbits);
 			if (!ra_has_index(&file->f_ra, index))
 				page_cache_sync_readahead(
 					sb->s_bdev->bd_inode->i_mapping,
 					&file->f_ra, file,
 					index, 1);
-			file->f_ra.prev_pos = (loff_t)index << PAGE_CACHE_SHIFT;
+			file->f_ra.prev_pos = (loff_t)index << PAGE_SHIFT;
 			bh = ext4_bread(NULL, inode, map.m_lblk, 0);
 			if (IS_ERR(bh)) {
 				err = PTR_ERR(bh);
diff --git a/fs/ext4/file.c b/fs/ext4/file.c
index 6659e21..0caece3 100644
--- a/fs/ext4/file.c
+++ b/fs/ext4/file.c
@@ -428,8 +428,8 @@ static int ext4_find_unwritten_pgoff(struct inode *inode,
 	lastoff = startoff;
 	endoff = (loff_t)end_blk << blkbits;
-	index = startoff >> PAGE_CACHE_SHIFT;
-	end = endoff >> PAGE_CACHE_SHIFT;
+	index = startoff >> PAGE_SHIFT;
+	end = endoff >> PAGE_SHIFT;
 	pagevec_init(&pvec, 0);
 	do {
diff --git a/fs/ext4/inline.c b/fs/ext4/inline.c
index 7cbdd375..7bc6c85 100644
--- a/fs/ext4/inline.c
+++ b/fs/ext4/inline.c
@@ -482,7 +482,7 @@ static int ext4_read_inline_page(struct inode *inode, struct page *page)
 	ret = ext4_read_inline_data(inode, kaddr, len, &iloc);
 	SetPageUptodate(page);
 	brelse(iloc.bh);
@@ -507,7 +507,7 @@ int ext4_readpage_inline(struct inode *inode, struct page *page)
 	if (!page->index)
 		ret = ext4_read_inline_page(inode, page);
 	else if (!PageUptodate(page)) {
-		zero_user_segment(page, 0, PAGE_CACHE_SIZE);
+		zero_user_segment(page, 0, PAGE_SIZE);
@@ -595,7 +595,7 @@ retry:
 	if (ret) {
 		unlock_page(page);
+		put_page(page);
 		page = NULL;
 		ext4_orphan_add(handle, inode);
 		up_write(&EXT4_I(inode)->xattr_sem);
@@ -621,7 +621,7 @@ retry:
 out:
 	if (page) {
 		unlock_page(page);
+		put_page(page);
 	if (sem_held)
@@ -690,7 +690,7 @@ int ext4_try_to_write_inline_data(struct address_space *mapping,
 	if (!ext4_has_inline_data(inode)) {
 		ret = 0;
 		unlock_page(page);
+		put_page(page);
 		goto out_up_read;
@@ -815,7 +815,7 @@ static int ext4_da_convert_inline_data_to_extent(struct address_space *mapping,
 	if (ret) {
 		up_read(&EXT4_I(inode)->xattr_sem);
 		unlock_page(page);
+		put_page(page);
 		ext4_truncate_failed_write(inode);
 		return ret;
@@ -829,7 +829,7 @@ out:
 	if (page) {
 		unlock_page(page);
+		put_page(page);
 	return ret;
@@ -919,7 +919,7 @@ retry_journal:
 out_release_page:
 	unlock_page(page);
+	put_page(page);
 out_journal:
 	ext4_journal_stop(handle);
 out:
@@ -947,7 +947,7 @@ int ext4_da_write_inline_data_end(struct inode *inode, loff_t pos,
 		i_size_changed = 1;
 	unlock_page(page);
+	put_page(page);
 	 * Don't mark the inode dirty under page lock. First, it unnecessarily
diff --git a/fs/ext4/inode.c b/fs/ext4/inode.c
index dab84a2..8a43c68 100644
--- a/fs/ext4/inode.c
+++ b/fs/ext4/inode.c
@@ -1057,7 +1057,7 @@ int do_journal_get_write_access(handle_t *handle,
 static int ext4_block_write_begin(struct page *page, loff_t pos, unsigned len,
 				  get_block_t *get_block)
 	unsigned to = from + len;
 	unsigned block_start, block_end;
@@ -1069,15 +1069,15 @@ static int ext4_block_write_begin(struct page *page, loff_t pos, unsigned len,
 	bool decrypt = false;
 	BUG_ON(!PageLocked(page));
-	BUG_ON(from > PAGE_CACHE_SIZE);
-	BUG_ON(to > PAGE_CACHE_SIZE);
+	BUG_ON(from > PAGE_SIZE);
+	BUG_ON(to > PAGE_SIZE);
 	BUG_ON(from > to);
 	if (!page_has_buffers(page))
 		create_empty_buffers(page, blocksize, 0);
 	head = page_buffers(page);
 	bbits = ilog2(blocksize);
-	block = (sector_t)page->index << (PAGE_CACHE_SHIFT - bbits);
+	block = (sector_t)page->index << (PAGE_SHIFT - bbits);
 	for (bh = head, block_start = 0; bh != head || !block_start;
 	    block++, block_start = block_end, bh = bh->b_this_page) {
@@ -1159,8 +1159,8 @@ static int ext4_write_begin(struct file *file, struct address_space *mapping,
 	 * we allocate blocks but write fails for some reason
 	needed_blocks = ext4_writepage_trans_blocks(inode) + 1;
-	index = pos >> PAGE_CACHE_SHIFT;
-	from = pos & (PAGE_CACHE_SIZE - 1);
+	index = pos >> PAGE_SHIFT;
+	from = pos & (PAGE_SIZE - 1);
 	to = from + len;
 	if (ext4_test_inode_state(inode, EXT4_STATE_MAY_INLINE_DATA)) {
@@ -1188,7 +1188,7 @@ retry_grab:
 retry_journal:
 	handle = ext4_journal_start(inode, EXT4_HT_WRITE_PAGE, needed_blocks);
 	if (IS_ERR(handle)) {
+		put_page(page);
 		return PTR_ERR(handle);
@@ -1196,7 +1196,7 @@ retry_journal:
 	if (page->mapping != mapping) {
 		/* The page got truncated from under us */
 		unlock_page(page);
+		put_page(page);
 		goto retry_grab;
@@ -1252,7 +1252,7 @@ retry_journal:
 		if (ret == -ENOSPC &&
 		    ext4_should_retry_alloc(inode->i_sb, &retries))
 			goto retry_journal;
+		put_page(page);
 		return ret;
 	*pagep = page;
@@ -1295,7 +1295,7 @@ static int ext4_write_end(struct file *file,
 		ret = ext4_jbd2_file_inode(handle, inode);
 		if (ret) {
 			unlock_page(page);
+			put_page(page);
 			goto errout;
@@ -1315,7 +1315,7 @@ static int ext4_write_end(struct file *file,
 	i_size_changed = ext4_update_inode_size(inode, pos + copied);
 	unlock_page(page);
-	page_cache_release(page);
+	put_page(page);
 	if (old_size < pos)
 		pagecache_isize_extended(inode, old_size, pos);
@@ -1399,7 +1399,7 @@ static int ext4_journalled_write_end(struct file *file,
 	int size_changed = 0;
 	trace_ext4_journalled_write_end(inode, pos, len, copied);
 	to = from + len;
 	BUG_ON(!ext4_handle_valid(handle));
@@ -1423,7 +1423,7 @@ static int ext4_journalled_write_end(struct file *file,
 	ext4_set_inode_state(inode, EXT4_STATE_JDATA);
 	EXT4_I(inode)->i_datasync_tid = handle->h_transaction->t_tid;
 	unlock_page(page);
+	put_page(page);
 	if (old_size < pos)
@@ -1537,7 +1537,7 @@ static void ext4_da_page_release_reservation(struct page *page,
 	int num_clusters;
 	ext4_fsblk_t lblk;
-	BUG_ON(stop > PAGE_CACHE_SIZE || stop < length);
+	BUG_ON(stop > PAGE_SIZE || stop < length);
 	bh = head;
@@ -1553,7 +1553,7 @@ static void ext4_da_page_release_reservation(struct page *page,
 			clear_buffer_delay(bh);
 		} else if (contiguous_blks) {
 			lblk = page->index <<
 			lblk += (curr_off >> inode->i_blkbits) -
 				contiguous_blks;
 			ext4_es_remove_extent(inode, lblk, contiguous_blks);
@@ -1563,7 +1563,7 @@ static void ext4_da_page_release_reservation(struct page *page,
 	} while ((bh = bh->b_this_page) != head);
-		lblk = page->index << (PAGE_CACHE_SHIFT - inode->i_blkbits);
+		lblk = page->index << (PAGE_SHIFT - inode->i_blkbits);
 		lblk += (curr_off >> inode->i_blkbits) - contiguous_blks;
@@ -1572,7 +1572,7 @@ static void ext4_da_page_release_reservation(struct page *page,
 	 * need to release the reserved space for that cluster. */
 	num_clusters = EXT4_NUM_B2C(sbi, to_release);
 	while (num_clusters > 0) {
-		lblk = (page->index << (PAGE_CACHE_SHIFT - inode->i_blkbits)) +
+		lblk = (page->index << (PAGE_SHIFT - inode->i_blkbits)) +
 			((num_clusters - 1) << sbi->s_cluster_bits);
 		if (sbi->s_cluster_ratio == 1 ||
 		    !ext4_find_delalloc_cluster(inode, lblk))
@@ -1619,8 +1619,8 @@ static void mpage_release_unused_pages(struct mpage_da_data *mpd,
 	end   = mpd->next_page - 1;
 	if (invalidate) {
 		ext4_lblk_t start, last;
-		start = index << (PAGE_CACHE_SHIFT - inode->i_blkbits);
-		last = end << (PAGE_CACHE_SHIFT - inode->i_blkbits);
+		start = index << (PAGE_SHIFT - inode->i_blkbits);
+		last = end << (PAGE_SHIFT - inode->i_blkbits);
 		ext4_es_remove_extent(inode, start, last - start + 1);
@@ -1636,7 +1636,7 @@ static void mpage_release_unused_pages(struct mpage_da_data *mpd,
 			BUG_ON(PageWriteback(page));
 			if (invalidate) {
-				block_invalidatepage(page, 0, PAGE_CACHE_SIZE);
+				block_invalidatepage(page, 0, PAGE_SIZE);
 				ClearPageUptodate(page);
 			unlock_page(page);
@@ -2007,10 +2007,10 @@ static int ext4_writepage(struct page *page,
 	trace_ext4_writepage(page);
-	if (page->index == size >> PAGE_CACHE_SHIFT)
-		len = size & ~PAGE_CACHE_MASK;
+	if (page->index == size >> PAGE_SHIFT)
+		len = size & ~PAGE_MASK;
 	else
-		len = PAGE_CACHE_SIZE;
+		len = PAGE_SIZE;
 	page_bufs = page_buffers(page);
@@ -2034,7 +2034,7 @@ static int ext4_writepage(struct page *page,
 				   ext4_bh_delay_or_unwritten)) {
 		redirty_page_for_writepage(wbc, page);
 		if ((current->flags & PF_MEMALLOC) ||
-		    (inode->i_sb->s_blocksize == PAGE_CACHE_SIZE)) {
+		    (inode->i_sb->s_blocksize == PAGE_SIZE)) {
 			 * For memory cleaning there's no point in writing only
 			 * some buffers. So just bail out. Warn if we came here
@@ -2076,10 +2076,10 @@ static int mpage_submit_page(struct mpage_da_data *mpd, struct page *page)
 	int err;
 	BUG_ON(page->index != mpd->first_page);
 	else
+		len = PAGE_SIZE;
 	clear_page_dirty_for_io(page);
 	err = ext4_bio_write_page(&mpd->io_submit, page, len, mpd->wbc, false);
 	if (!err)
@@ -2213,7 +2213,7 @@ static int mpage_map_and_submit_buffers(struct mpage_da_data *mpd)
 	int nr_pages, i;
 	struct inode *inode = mpd->inode;
 	struct buffer_head *head, *bh;
-	int bpp_bits = PAGE_CACHE_SHIFT - inode->i_blkbits;
+	int bpp_bits = PAGE_SHIFT - inode->i_blkbits;
 	pgoff_t start, end;
 	ext4_lblk_t lblk;
 	sector_t pblock;
@@ -2274,7 +2274,7 @@ static int mpage_map_and_submit_buffers(struct mpage_da_data *mpd)
 			 * supports blocksize < pagesize as we will try to
 			 * convert potentially unmapped parts of inode.
-			mpd->io_submit.io_end->size += PAGE_CACHE_SIZE;
+			mpd->io_submit.io_end->size += PAGE_SIZE;
 			/* Page fully mapped - let IO run! */
 			err = mpage_submit_page(mpd, page);
 			if (err < 0) {
@@ -2426,7 +2426,7 @@ update_disksize:
 	 * Update on-disk size after IO is submitted.  Races with
 	 * truncate are avoided by checking i_size under i_data_sem.
-	disksize = ((loff_t)mpd->first_page) << PAGE_CACHE_SHIFT;
+	disksize = ((loff_t)mpd->first_page) << PAGE_SHIFT;
 	if (disksize > EXT4_I(inode)->i_disksize) {
 		int err2;
 		loff_t i_size;
@@ -2562,7 +2562,7 @@ static int mpage_prepare_extent_to_map(struct mpage_da_data *mpd)
 			mpd->next_page = page->index + 1;
 			/* Add all dirty buffers to mpd */
 			lblk = ((ext4_lblk_t)page->index) <<
-				(PAGE_CACHE_SHIFT - blkbits);
+				(PAGE_SHIFT - blkbits);
 			err = mpage_process_page_bufs(mpd, head, head, lblk);
 			if (err <= 0)
@@ -2647,7 +2647,7 @@ static int ext4_writepages(struct address_space *mapping,
 		 * We may need to convert up to one extent per block in
 		 * the page and we may dirty the inode.
-		rsv_blocks = 1 + (PAGE_CACHE_SIZE >> inode->i_blkbits);
+		rsv_blocks = 1 + (PAGE_SIZE >> inode->i_blkbits);
@@ -2678,8 +2678,8 @@ static int ext4_writepages(struct address_space *mapping,
 		mpd.first_page = writeback_index;
 		mpd.last_page = -1;
 	} else {
-		mpd.first_page = wbc->range_start >> PAGE_CACHE_SHIFT;
-		mpd.last_page = wbc->range_end >> PAGE_CACHE_SHIFT;
+		mpd.first_page = wbc->range_start >> PAGE_SHIFT;
+		mpd.last_page = wbc->range_end >> PAGE_SHIFT;
 	mpd.inode = inode;
@@ -2838,7 +2838,7 @@ static int ext4_da_write_begin(struct file *file, struct address_space *mapping,
 	struct inode *inode = mapping->host;
 	handle_t *handle;
 	if (ext4_nonda_switch(inode->i_sb)) {
 		*fsdata = (void *)FALL_BACK_TO_NONDELALLOC;
@@ -2881,7 +2881,7 @@ retry_journal:
 				ext4_da_write_credits(inode, pos, len));
+		put_page(page);
@@ -2889,7 +2889,7 @@ retry_journal:
 		unlock_page(page);
+		put_page(page);
 		goto retry_grab;
@@ -2917,7 +2917,7 @@ retry_journal:
 			goto retry_journal;
+		put_page(page);
 		return ret;
@@ -2965,7 +2965,7 @@ static int ext4_da_write_end(struct file *file,
 				      len, copied, page, fsdata);
 	trace_ext4_da_write_end(inode, pos, len, copied);
-	start = pos & (PAGE_CACHE_SIZE - 1);
+	start = pos & (PAGE_SIZE - 1);
 	end = start + copied - 1;
@@ -3187,7 +3187,7 @@ static int __ext4_journalled_invalidatepage(struct page *page,
 	 * If it's a full truncate we just forget about the pending dirtying
 	return jbd2_journal_invalidatepage(journal, page, offset, length);
@@ -3556,8 +3556,8 @@ void ext4_set_aops(struct inode *inode)
 static int __ext4_block_zero_page_range(handle_t *handle,
 		struct address_space *mapping, loff_t from, loff_t length)
-	ext4_fsblk_t index = from >> PAGE_CACHE_SHIFT;
-	unsigned offset = from & (PAGE_CACHE_SIZE-1);
+	ext4_fsblk_t index = from >> PAGE_SHIFT;
+	unsigned offset = from & (PAGE_SIZE-1);
 	unsigned blocksize, pos;
 	ext4_lblk_t iblock;
@@ -3565,14 +3565,14 @@ static int __ext4_block_zero_page_range(handle_t *handle,
 	struct page *page;
 	int err = 0;
-	page = find_or_create_page(mapping, from >> PAGE_CACHE_SHIFT,
+	page = find_or_create_page(mapping, from >> PAGE_SHIFT,
 				   mapping_gfp_constraint(mapping, ~__GFP_FS));
 	if (!page)
 		return -ENOMEM;
 	blocksize = inode->i_sb->s_blocksize;
-	iblock = index << (PAGE_CACHE_SHIFT - inode->i_sb->s_blocksize_bits);
+	iblock = index << (PAGE_SHIFT - inode->i_sb->s_blocksize_bits);
@@ -3614,7 +3614,7 @@ static int __ext4_block_zero_page_range(handle_t *handle,
 		    ext4_encrypted_inode(inode)) {
 			/* We expect the key to be set. */
 			BUG_ON(!ext4_has_encryption_key(inode));
-			BUG_ON(blocksize != PAGE_CACHE_SIZE);
+			BUG_ON(blocksize != PAGE_SIZE);
 			WARN_ON_ONCE(ext4_decrypt(page));
@@ -3638,7 +3638,7 @@ static int __ext4_block_zero_page_range(handle_t *handle,
 unlock:
 	unlock_page(page);
+	put_page(page);
 	return err;
@@ -3653,7 +3653,7 @@ static int ext4_block_zero_page_range(handle_t *handle,
 	unsigned blocksize = inode->i_sb->s_blocksize;
 	unsigned max = blocksize - (offset & (blocksize - 1));
@@ -3678,7 +3678,7 @@ static int ext4_block_zero_page_range(handle_t *handle,
 static int ext4_block_truncate_page(handle_t *handle,
 	unsigned length;
 	unsigned blocksize;
@@ -3816,7 +3816,7 @@ int ext4_punch_hole(struct inode *inode, loff_t offset, loff_t length)
 	if (offset + length > inode->i_size) {
 		length = inode->i_size +
-		   PAGE_CACHE_SIZE - (inode->i_size & (PAGE_CACHE_SIZE - 1)) -
+		   PAGE_SIZE - (inode->i_size & (PAGE_SIZE - 1)) -
 		   offset;
@@ -4891,23 +4891,23 @@ static void ext4_wait_for_tail_page_commit(struct inode *inode)
 	tid_t commit_tid = 0;
 	int ret;
-	offset = inode->i_size & (PAGE_CACHE_SIZE - 1);
+	offset = inode->i_size & (PAGE_SIZE - 1);
 	 * All buffers in the last page remain valid? Then there's nothing to
 	 * do. We do the check mainly to optimize the common PAGE_CACHE_SIZE ==
 	 * blocksize case
-	if (offset > PAGE_CACHE_SIZE - (1 << inode->i_blkbits))
+	if (offset > PAGE_SIZE - (1 << inode->i_blkbits))
 		return;
 	while (1) {
 		page = find_lock_page(inode->i_mapping,
-				      inode->i_size >> PAGE_CACHE_SHIFT);
+				      inode->i_size >> PAGE_SHIFT);
 		if (!page)
 			return;
 		ret = __ext4_journalled_invalidatepage(page, offset,
-						PAGE_CACHE_SIZE - offset);
+						PAGE_SIZE - offset);
 		unlock_page(page);
+		put_page(page);
 		if (ret != -EBUSY)
 			return;
 		commit_tid = 0;
@@ -5546,10 +5546,10 @@ int ext4_page_mkwrite(struct vm_area_struct *vma, struct vm_fault *vmf)
 		goto out;
 	else
+		len = PAGE_SIZE;
 	 * Return if we have all the buffers mapped. This avoids the need to do
 	 * journal_start/journal_stop which can block and take a long time
@@ -5580,7 +5580,7 @@ retry_alloc:
 	ret = block_page_mkwrite(vma, vmf, get_block);
 	if (!ret && ext4_should_journal_data(inode)) {
 		if (ext4_walk_page_buffers(handle, page_buffers(page), 0,
-			  PAGE_CACHE_SIZE, NULL, do_journal_get_write_access)) {
+			  PAGE_SIZE, NULL, do_journal_get_write_access)) {
 			unlock_page(page);
 			ret = VM_FAULT_SIGBUS;
diff --git a/fs/ext4/mballoc.c b/fs/ext4/mballoc.c
index 50e05df..c121747 100644
--- a/fs/ext4/mballoc.c
+++ b/fs/ext4/mballoc.c
@@ -839,7 +839,7 @@ static int ext4_mb_init_cache(struct page *page, char *incore, gfp_t gfp)
 	sb = inode->i_sb;
 	ngroups = ext4_get_groups_count(sb);
 	blocksize = 1 << inode->i_blkbits;
-	blocks_per_page = PAGE_CACHE_SIZE / blocksize;
+	blocks_per_page = PAGE_SIZE / blocksize;
 	groups_per_page = blocks_per_page >> 1;
 	if (groups_per_page == 0)
@@ -993,7 +993,7 @@ static int ext4_mb_get_buddy_page_lock(struct super_block *sb,
 	e4b->bd_buddy_page = NULL;
 	e4b->bd_bitmap_page = NULL;
-	blocks_per_page = PAGE_CACHE_SIZE / sb->s_blocksize;
+	blocks_per_page = PAGE_SIZE / sb->s_blocksize;
 	 * the buddy cache inode stores the block bitmap
 	 * and buddy information in consecutive blocks.
@@ -1028,11 +1028,11 @@ static void ext4_mb_put_buddy_page_lock(struct ext4_buddy *e4b)
 	if (e4b->bd_bitmap_page) {
 		unlock_page(e4b->bd_bitmap_page);
-		page_cache_release(e4b->bd_bitmap_page);
+		put_page(e4b->bd_bitmap_page);
 	if (e4b->bd_buddy_page) {
 		unlock_page(e4b->bd_buddy_page);
-		page_cache_release(e4b->bd_buddy_page);
+		put_page(e4b->bd_buddy_page);
@@ -1125,7 +1125,7 @@ ext4_mb_load_buddy_gfp(struct super_block *sb, ext4_group_t group,
 	might_sleep();
 	mb_debug(1, "load group %u\n", group);
 	grp = ext4_get_group_info(sb, group);
 	e4b->bd_blkbits = sb->s_blocksize_bits;
@@ -1167,7 +1167,7 @@ ext4_mb_load_buddy_gfp(struct super_block *sb, ext4_group_t group,
 			 * is yet to initialize the same. So
 			 * wait for it to initialize.
+			put_page(page);
 		page = find_or_create_page(inode->i_mapping, pnum, gfp);
 		if (page) {
 			BUG_ON(page->mapping != inode->i_mapping);
@@ -1203,7 +1203,7 @@ ext4_mb_load_buddy_gfp(struct super_block *sb, ext4_group_t group,
 	page = find_get_page_flags(inode->i_mapping, pnum, FGP_ACCESSED);
 	if (page == NULL || !PageUptodate(page)) {
 		if (page)
+			put_page(page);
 		if (page) {
@@ -1238,11 +1238,11 @@ ext4_mb_load_buddy_gfp(struct super_block *sb, ext4_group_t group,
 err:
 	if (page)
+		put_page(page);
 	e4b->bd_buddy = NULL;
 	e4b->bd_bitmap = NULL;
 	return ret;
@@ -1257,9 +1257,9 @@ static int ext4_mb_load_buddy(struct super_block *sb, ext4_group_t group,
 static void ext4_mb_unload_buddy(struct ext4_buddy *e4b)
@@ -2833,8 +2833,8 @@ static void ext4_free_data_callback(struct super_block *sb,
 		/* No more items in the per group rb tree
 		 * balance refcounts from ext4_mb_free_metadata()
-		page_cache_release(e4b.bd_buddy_page);
-		page_cache_release(e4b.bd_bitmap_page);
+		put_page(e4b.bd_buddy_page);
+		put_page(e4b.bd_bitmap_page);
 	ext4_unlock_group(sb, entry->efd_group);
 	kmem_cache_free(ext4_free_data_cachep, entry);
@@ -4385,9 +4385,9 @@ static int ext4_mb_release_context(struct ext4_allocation_context *ac)
 		ext4_mb_put_pa(ac, ac->ac_sb, pa);
 	if (ac->ac_bitmap_page)
-		page_cache_release(ac->ac_bitmap_page);
+		put_page(ac->ac_bitmap_page);
 	if (ac->ac_buddy_page)
-		page_cache_release(ac->ac_buddy_page);
+		put_page(ac->ac_buddy_page);
 	if (ac->ac_flags & EXT4_MB_HINT_GROUP_ALLOC)
 		mutex_unlock(&ac->ac_lg->lg_mutex);
 	ext4_mb_collect_stats(ac);
@@ -4599,8 +4599,8 @@ ext4_mb_free_metadata(handle_t *handle, struct ext4_buddy *e4b,
 		 * otherwise we'll refresh it from
 		 * on-disk bitmap and lose not-yet-available
 		 * blocks */
-		page_cache_get(e4b->bd_buddy_page);
-		page_cache_get(e4b->bd_bitmap_page);
+		get_page(e4b->bd_buddy_page);
+		get_page(e4b->bd_bitmap_page);
 	while (*n) {
 		parent = *n;
diff --git a/fs/ext4/move_extent.c b/fs/ext4/move_extent.c
index 4098acc..675b67e 100644
--- a/fs/ext4/move_extent.c
+++ b/fs/ext4/move_extent.c
@@ -156,7 +156,7 @@ mext_page_double_lock(struct inode *inode1, struct inode *inode2,
 	page[1] = grab_cache_page_write_begin(mapping[1], index2, fl);
 	if (!page[1]) {
 		unlock_page(page[0]);
-		page_cache_release(page[0]);
+		put_page(page[0]);
 		return -ENOMEM;
@@ -192,7 +192,7 @@ mext_page_mkuptodate(struct page *page, unsigned from, unsigned to)
-	block = (sector_t)page->index << (PAGE_CACHE_SHIFT - inode->i_blkbits);
+	block = (sector_t)page->index << (PAGE_SHIFT - inode->i_blkbits);
 		block_end = block_start + blocksize;
@@ -268,7 +268,7 @@ move_extent_per_page(struct file *o_filp, struct inode *donor_inode,
 	int i, err2, jblocks, retries = 0;
 	int replaced_count = 0;
 	int from = data_offset_in_page << orig_inode->i_blkbits;
-	int blocks_per_page = PAGE_CACHE_SIZE >> orig_inode->i_blkbits;
+	int blocks_per_page = PAGE_SIZE >> orig_inode->i_blkbits;
 	struct super_block *sb = orig_inode->i_sb;
 	struct buffer_head *bh = NULL;
@@ -404,9 +404,9 @@ data_copy:
 unlock_pages:
 	unlock_page(pagep[0]);
-	page_cache_release(pagep[0]);
+	put_page(pagep[0]);
 	unlock_page(pagep[1]);
-	page_cache_release(pagep[1]);
+	put_page(pagep[1]);
 stop_journal:
 	if (*err == -ENOSPC &&
@@ -554,7 +554,7 @@ ext4_move_extents(struct file *o_filp, struct file *d_filp, __u64 orig_blk,
 	struct inode *orig_inode = file_inode(o_filp);
 	struct inode *donor_inode = file_inode(d_filp);
 	struct ext4_ext_path *path = NULL;
 	ext4_lblk_t o_end, o_start = orig_blk;
 	ext4_lblk_t d_start = donor_blk;
 	int ret;
@@ -648,9 +648,9 @@ ext4_move_extents(struct file *o_filp, struct file *d_filp, __u64 orig_blk,
 		if (o_end - o_start < cur_len)
 			cur_len = o_end - o_start;
-		orig_page_index = o_start >> (PAGE_CACHE_SHIFT -
+		orig_page_index = o_start >> (PAGE_SHIFT -
 					       orig_inode->i_blkbits);
-		donor_page_index = d_start >> (PAGE_CACHE_SHIFT -
+		donor_page_index = d_start >> (PAGE_SHIFT -
 					       donor_inode->i_blkbits);
 		offset_in_page = o_start % blocks_per_page;
 		if (cur_len > blocks_per_page- offset_in_page)
diff --git a/fs/ext4/page-io.c b/fs/ext4/page-io.c
index d77d15f..93ad0ac 100644
--- a/fs/ext4/page-io.c
+++ b/fs/ext4/page-io.c
@@ -432,8 +432,8 @@ int ext4_bio_write_page(struct ext4_io_submit *io,
 	 * the page size, the remaining memory is zeroed when mapped, and
 	 * writes to that region are not written out to the file."
-	if (len < PAGE_CACHE_SIZE)
-		zero_user_segment(page, len, PAGE_CACHE_SIZE);
+	if (len < PAGE_SIZE)
+		zero_user_segment(page, len, PAGE_SIZE);
 	 * In the first loop we prepare and mark buffers to submit. We have to
 	 * mark all buffers in the page before submitting so that
diff --git a/fs/ext4/readpage.c b/fs/ext4/readpage.c
index 5dc5e95..ea27aa1 100644
--- a/fs/ext4/readpage.c
+++ b/fs/ext4/readpage.c
@@ -140,7 +140,7 @@ int ext4_mpage_readpages(struct address_space *mapping,
 	const unsigned blkbits = inode->i_blkbits;
-	const unsigned blocks_per_page = PAGE_CACHE_SIZE >> blkbits;
+	const unsigned blocks_per_page = PAGE_SIZE >> blkbits;
 	const unsigned blocksize = 1 << blkbits;
 	sector_t block_in_file;
 	sector_t last_block;
@@ -173,7 +173,7 @@ int ext4_mpage_readpages(struct address_space *mapping,
 		if (page_has_buffers(page))
 			goto confused;
-		block_in_file = (sector_t)page->index << (PAGE_CACHE_SHIFT - blkbits);
+		block_in_file = (sector_t)page->index << (PAGE_SHIFT - blkbits);
 		last_block = block_in_file + nr_pages * blocks_per_page;
 		last_block_in_file = (i_size_read(inode) + blocksize - 1) >> blkbits;
 		if (last_block > last_block_in_file)
@@ -217,7 +217,7 @@ int ext4_mpage_readpages(struct address_space *mapping,
 				set_error_page:
 					SetPageError(page);
-							  PAGE_CACHE_SIZE);
+							  PAGE_SIZE);
 					unlock_page(page);
 					goto next_page;
@@ -250,7 +250,7 @@ int ext4_mpage_readpages(struct address_space *mapping,
 		if (first_hole != blocks_per_page) {
 			zero_user_segment(page, first_hole << blkbits,
-					  PAGE_CACHE_SIZE);
+					  PAGE_SIZE);
 			if (first_hole == 0) {
 				unlock_page(page);
@@ -319,7 +319,7 @@ int ext4_mpage_readpages(struct address_space *mapping,
 			unlock_page(page);
 	next_page:
 		if (pages)
+			put_page(page);
 	BUG_ON(pages && !list_empty(pages));
 	if (bio)
diff --git a/fs/ext4/super.c b/fs/ext4/super.c
index 5392975..0bb74aa 100644
--- a/fs/ext4/super.c
+++ b/fs/ext4/super.c
@@ -1784,7 +1784,7 @@ static int parse_options(char *options, struct super_block *sb,
 		int blocksize =
 			BLOCK_SIZE << le32_to_cpu(sbi->s_es->s_log_block_size);
-		if (blocksize < PAGE_CACHE_SIZE) {
+		if (blocksize < PAGE_SIZE) {
 			ext4_msg(sb, KERN_ERR, "can't mount with "
 				 "dioread_nolock if block size != PAGE_SIZE");
 			return 0;
@@ -3808,7 +3808,7 @@ no_journal:
 	if ((DUMMY_ENCRYPTION_ENABLED(sbi) || ext4_has_feature_encrypt(sb)) &&
-	    (blocksize != PAGE_CACHE_SIZE)) {
+	    (blocksize != PAGE_SIZE)) {
 			 "Unsupported blocksize for fs encryption");
 		goto failed_mount_wq;
diff --git a/fs/ext4/symlink.c b/fs/ext4/symlink.c
index 6f7ee30..75ed5c2 100644
--- a/fs/ext4/symlink.c
+++ b/fs/ext4/symlink.c
@@ -80,12 +80,12 @@ static const char *ext4_encrypted_get_link(struct dentry *dentry,
 	if (res <= plen)
 		paddr[res] = '\0';
 	if (cpage)
-		page_cache_release(cpage);
+		put_page(cpage);
 	set_delayed_call(done, kfree_link, paddr);
 	return paddr;
 errout:
 	if (cpage)
+		put_page(cpage);
 	kfree(paddr);
 	return ERR_PTR(res);
diff --git a/fs/f2fs/data.c b/fs/f2fs/data.c
index e5c762b..53fec08 100644
--- a/fs/f2fs/data.c
+++ b/fs/f2fs/data.c
@@ -223,7 +223,7 @@ int f2fs_submit_page_bio(struct f2fs_io_info *fio)
 	/* Allocate a new bio */
 	bio = __bio_alloc(fio->sbi, fio->new_blkaddr, 1, is_read_io(fio->rw));
-	if (bio_add_page(bio, page, PAGE_CACHE_SIZE, 0) < PAGE_CACHE_SIZE) {
+	if (bio_add_page(bio, page, PAGE_SIZE, 0) < PAGE_SIZE) {
 		bio_put(bio);
 		return -EFAULT;
@@ -265,8 +265,8 @@ alloc_new:
 	bio_page = fio->encrypted_page ? fio->encrypted_page : fio->page;
-	if (bio_add_page(io->bio, bio_page, PAGE_CACHE_SIZE, 0) <
-							PAGE_CACHE_SIZE) {
+	if (bio_add_page(io->bio, bio_page, PAGE_SIZE, 0) <
+							PAGE_SIZE) {
 		__submit_merged_bio(io);
 		goto alloc_new;
@@ -406,7 +406,7 @@ got_it:
 	 * see, f2fs_add_link -> get_new_data_page -> init_inode_metadata.
 	if (dn.data_blkaddr == NEW_ADDR) {
 		unlock_page(page);
 		return page;
@@ -517,7 +517,7 @@ struct page *get_new_data_page(struct inode *inode,
 		goto got_it;
 	} else {
 		f2fs_put_page(page, 1);
@@ -530,8 +530,8 @@ struct page *get_new_data_page(struct inode *inode,
 got_it:
 	if (new_i_size && i_size_read(inode) <
-				((loff_t)(index + 1) << PAGE_CACHE_SHIFT)) {
-		i_size_write(inode, ((loff_t)(index + 1) << PAGE_CACHE_SHIFT));
+				((loff_t)(index + 1) << PAGE_SHIFT)) {
+		i_size_write(inode, ((loff_t)(index + 1) << PAGE_SHIFT));
 		/* Only the directory inode sets new_i_size */
 		set_inode_flag(F2FS_I(inode), FI_UPDATE_DIR);
@@ -570,9 +570,9 @@ alloc:
 	/* update i_size */
 	fofs = start_bidx_of_node(ofs_of_node(dn->node_page), dn->inode) +
 							dn->ofs_in_node;
-	if (i_size_read(dn->inode) < ((loff_t)(fofs + 1) << PAGE_CACHE_SHIFT))
+	if (i_size_read(dn->inode) < ((loff_t)(fofs + 1) << PAGE_SHIFT))
 		i_size_write(dn->inode,
-				((loff_t)(fofs + 1) << PAGE_CACHE_SHIFT));
+				((loff_t)(fofs + 1) << PAGE_SHIFT));
 	return 0;
@@ -971,7 +971,7 @@ got_it:
 				goto confused;
 		} else {
 			unlock_page(page);
 			goto next_page;
@@ -1021,7 +1021,7 @@ submit_and_realloc:
 		goto next_page;
 set_error_page:
 		SetPageError(page);
 		unlock_page(page);
 		goto next_page;
 confused:
@@ -1032,7 +1032,7 @@ confused:
 		unlock_page(page);
 next_page:
 		if (pages)
+			put_page(page);
 	if (bio)
@@ -1136,7 +1136,7 @@ static int f2fs_write_data_page(struct page *page,
 	struct f2fs_sb_info *sbi = F2FS_I_SB(inode);
 	const pgoff_t end_index = ((unsigned long long) i_size)
-							>> PAGE_CACHE_SHIFT;
+							>> PAGE_SHIFT;
 	unsigned offset = 0;
 	bool need_balance_fs = false;
 	int err = 0;
@@ -1157,11 +1157,11 @@ static int f2fs_write_data_page(struct page *page,
 	 * If the offset is out-of-range of file size,
 	 * this page does not have to be written to disk.
-	offset = i_size & (PAGE_CACHE_SIZE - 1);
+	offset = i_size & (PAGE_SIZE - 1);
 	if ((page->index >= end_index + 1) || !offset)
 		goto out;
-	zero_user_segment(page, offset, PAGE_CACHE_SIZE);
+	zero_user_segment(page, offset, PAGE_SIZE);
 write:
 	if (unlikely(is_sbi_flag_set(sbi, SBI_POR_DOING)))
 		goto redirty_out;
@@ -1267,8 +1267,8 @@ next:
 			cycled = 0;
 		end = -1;
 	} else {
-		index = wbc->range_start >> PAGE_CACHE_SHIFT;
-		end = wbc->range_end >> PAGE_CACHE_SHIFT;
+		index = wbc->range_start >> PAGE_SHIFT;
+		end = wbc->range_end >> PAGE_SHIFT;
 		if (wbc->range_start == 0 && wbc->range_end == LLONG_MAX)
 			range_whole = 1;
 		cycled = 1; /* ignore range_cyclic tests */
@@ -1448,11 +1448,11 @@ static int prepare_write_begin(struct f2fs_sb_info *sbi,
 	 * the block addresses when there is no need to fill the page.
 	if (!f2fs_has_inline_data(inode) && !f2fs_encrypted_inode(inode) &&
-					len == PAGE_CACHE_SIZE)
+					len == PAGE_SIZE)
 		return 0;
 	if (f2fs_has_inline_data(inode) ||
-			(pos & PAGE_CACHE_MASK) >= i_size_read(inode)) {
+			(pos & PAGE_MASK) >= i_size_read(inode)) {
 		f2fs_lock_op(sbi);
 		locked = true;
@@ -1513,7 +1513,7 @@ static int f2fs_write_begin(struct file *file, struct address_space *mapping,
 	struct page *page = NULL;
-	pgoff_t index = ((unsigned long long) pos) >> PAGE_CACHE_SHIFT;
+	pgoff_t index = ((unsigned long long) pos) >> PAGE_SHIFT;
 	bool need_balance = false;
 	block_t blkaddr = NULL_ADDR;
 	int err = 0;
@@ -1561,22 +1561,22 @@ repeat:
 	if (f2fs_encrypted_inode(inode) && S_ISREG(inode->i_mode))
 		f2fs_wait_on_encrypted_page_writeback(sbi, blkaddr);
-	if (len == PAGE_CACHE_SIZE)
+	if (len == PAGE_SIZE)
 		goto out_update;
 	if (PageUptodate(page))
 		goto out_clear;
-	if ((pos & PAGE_CACHE_MASK) >= i_size_read(inode)) {
-		unsigned start = pos & (PAGE_CACHE_SIZE - 1);
+	if ((pos & PAGE_MASK) >= i_size_read(inode)) {
+		unsigned start = pos & (PAGE_SIZE - 1);
 		unsigned end = start + len;
 		/* Reading beyond i_size is simple: memset to zero */
-		zero_user_segments(page, 0, start, end, PAGE_CACHE_SIZE);
+		zero_user_segments(page, 0, start, end, PAGE_SIZE);
 		goto out_update;
 	if (blkaddr == NEW_ADDR) {
 	} else {
 		struct f2fs_io_info fio = {
 			.sbi = sbi,
@@ -1688,7 +1688,7 @@ void f2fs_invalidate_page(struct page *page, unsigned int offset,
 	if (inode->i_ino >= F2FS_ROOT_INO(sbi) &&
-		(offset % PAGE_CACHE_SIZE || length != PAGE_CACHE_SIZE))
+		(offset % PAGE_SIZE || length != PAGE_SIZE))
 		return;
 	if (PageDirty(page)) {
diff --git a/fs/f2fs/debug.c b/fs/f2fs/debug.c
index 4fb6ef8..f4a61a5 100644
--- a/fs/f2fs/debug.c
+++ b/fs/f2fs/debug.c
@@ -164,7 +164,7 @@ static void update_mem_info(struct f2fs_sb_info *sbi)
 	/* build curseg */
 	si->base_mem += sizeof(struct curseg_info) * NR_CURSEG_TYPE;
-	si->base_mem += PAGE_CACHE_SIZE * NR_CURSEG_TYPE;
+	si->base_mem += PAGE_SIZE * NR_CURSEG_TYPE;
 	/* build dirty segmap */
 	si->base_mem += sizeof(struct dirty_seglist_info);
@@ -201,9 +201,9 @@ get_cache:
 	si->page_mem = 0;
 	npages = NODE_MAPPING(sbi)->nrpages;
-	si->page_mem += (unsigned long long)npages << PAGE_CACHE_SHIFT;
+	si->page_mem += (unsigned long long)npages << PAGE_SHIFT;
 	npages = META_MAPPING(sbi)->nrpages;
 static int stat_show(struct seq_file *s, void *v)
diff --git a/fs/f2fs/dir.c b/fs/f2fs/dir.c
index 80641ad..af81957 100644
--- a/fs/f2fs/dir.c
+++ b/fs/f2fs/dir.c
@@ -17,8 +17,8 @@
 static unsigned long dir_blocks(struct inode *inode)
-	return ((unsigned long long) (i_size_read(inode) + PAGE_CACHE_SIZE - 1))
+	return ((unsigned long long) (i_size_read(inode) + PAGE_SIZE - 1))
+							>> PAGE_SHIFT;
 static unsigned int dir_buckets(unsigned int level, int dir_level)
diff --git a/fs/f2fs/f2fs.h b/fs/f2fs/f2fs.h
index bbe2cd1..7a4558d 100644
--- a/fs/f2fs/f2fs.h
+++ b/fs/f2fs/f2fs.h
@@ -1294,7 +1294,7 @@ static inline void f2fs_put_page(struct page *page, int unlock)
 		f2fs_bug_on(F2FS_P_SB(page), !PageLocked(page));
 		unlock_page(page);
+	put_page(page);
 static inline void f2fs_put_dnode(struct dnode_of_data *dn)
diff --git a/fs/f2fs/file.c b/fs/f2fs/file.c
index b41c357..443e077 100644
--- a/fs/f2fs/file.c
+++ b/fs/f2fs/file.c
@@ -74,11 +74,11 @@ static int f2fs_vm_page_mkwrite(struct vm_area_struct *vma,
 		goto mapped;
 	/* page is wholly or partially inside EOF */
-	if (((loff_t)(page->index + 1) << PAGE_CACHE_SHIFT) >
+	if (((loff_t)(page->index + 1) << PAGE_SHIFT) >
 		unsigned offset;
-		offset = i_size_read(inode) & ~PAGE_CACHE_MASK;
+		offset = i_size_read(inode) & ~PAGE_MASK;
 	set_page_dirty(page);
@@ -346,11 +346,11 @@ static loff_t f2fs_seek_block(struct file *file, loff_t offset, int whence)
 		goto found;
-	pgofs = (pgoff_t)(offset >> PAGE_CACHE_SHIFT);
+	pgofs = (pgoff_t)(offset >> PAGE_SHIFT);
 	dirty = __get_first_dirty_index(inode->i_mapping, pgofs, whence);
-	for (; data_ofs < isize; data_ofs = (loff_t)pgofs << PAGE_CACHE_SHIFT) {
+	for (; data_ofs < isize; data_ofs = (loff_t)pgofs << PAGE_SHIFT) {
 		set_new_dnode(&dn, inode, NULL, NULL, 0);
 		err = get_dnode_of_data(&dn, pgofs, LOOKUP_NODE_RA);
 		if (err && err != -ENOENT) {
@@ -370,7 +370,7 @@ static loff_t f2fs_seek_block(struct file *file, loff_t offset, int whence)
 		/* find data/hole in dnode block */
 		for (; dn.ofs_in_node < end_offset;
 				dn.ofs_in_node++, pgofs++,
-				data_ofs = (loff_t)pgofs << PAGE_CACHE_SHIFT) {
+				data_ofs = (loff_t)pgofs << PAGE_SHIFT) {
 			block_t blkaddr;
 			blkaddr = datablock_addr(dn.node_page, dn.ofs_in_node);
@@ -508,8 +508,8 @@ void truncate_data_blocks(struct dnode_of_data *dn)
 static int truncate_partial_data_page(struct inode *inode, u64 from,
 								bool cache_only)
-	unsigned offset = from & (PAGE_CACHE_SIZE - 1);
-	pgoff_t index = from >> PAGE_CACHE_SHIFT;
+	unsigned offset = from & (PAGE_SIZE - 1);
+	pgoff_t index = from >> PAGE_SHIFT;
 	struct address_space *mapping = inode->i_mapping;
 	struct page *page;
@@ -529,7 +529,7 @@ static int truncate_partial_data_page(struct inode *inode, u64 from,
 		return 0;
 truncate_out:
 	f2fs_wait_on_page_writeback(page, DATA, true);
-	zero_user(page, offset, PAGE_CACHE_SIZE - offset);
+	zero_user(page, offset, PAGE_SIZE - offset);
 	if (!cache_only || !f2fs_encrypted_inode(inode) ||
 					!S_ISREG(inode->i_mode))
@@ -799,11 +799,11 @@ static int punch_hole(struct inode *inode, loff_t offset, loff_t len)
 	if (ret)
 		return ret;
-	pg_start = ((unsigned long long) offset) >> PAGE_CACHE_SHIFT;
-	pg_end = ((unsigned long long) offset + len) >> PAGE_CACHE_SHIFT;
+	pg_start = ((unsigned long long) offset) >> PAGE_SHIFT;
+	pg_end = ((unsigned long long) offset + len) >> PAGE_SHIFT;
-	off_start = offset & (PAGE_CACHE_SIZE - 1);
-	off_end = (offset + len) & (PAGE_CACHE_SIZE - 1);
+	off_start = offset & (PAGE_SIZE - 1);
+	off_end = (offset + len) & (PAGE_SIZE - 1);
 	if (pg_start == pg_end) {
 		ret = fill_zero(inode, pg_start, off_start,
@@ -813,7 +813,7 @@ static int punch_hole(struct inode *inode, loff_t offset, loff_t len)
 	} else {
 		if (off_start) {
 			ret = fill_zero(inode, pg_start++, off_start,
-						PAGE_CACHE_SIZE - off_start);
+						PAGE_SIZE - off_start);
 			if (ret)
 				return ret;
@@ -830,8 +830,8 @@ static int punch_hole(struct inode *inode, loff_t offset, loff_t len)
 			f2fs_balance_fs(sbi, true);
-			blk_start = (loff_t)pg_start << PAGE_CACHE_SHIFT;
-			blk_end = (loff_t)pg_end << PAGE_CACHE_SHIFT;
+			blk_start = (loff_t)pg_start << PAGE_SHIFT;
+			blk_end = (loff_t)pg_end << PAGE_SHIFT;
 			truncate_inode_pages_range(mapping, blk_start,
 					blk_end - 1);
@@ -954,8 +954,8 @@ static int f2fs_collapse_range(struct inode *inode, loff_t offset, loff_t len)
 	if (ret)
 		return ret;
-	pg_start = offset >> PAGE_CACHE_SHIFT;
-	pg_end = (offset + len) >> PAGE_CACHE_SHIFT;
+	pg_start = offset >> PAGE_SHIFT;
+	pg_end = (offset + len) >> PAGE_SHIFT;
 	/* write out all dirty pages from offset */
 	ret = filemap_write_and_wait_range(inode->i_mapping, offset, LLONG_MAX);
@@ -1006,11 +1006,11 @@ static int f2fs_zero_range(struct inode *inode, loff_t offset, loff_t len,
 	truncate_pagecache_range(inode, offset, offset + len - 1);
@@ -1024,12 +1024,12 @@ static int f2fs_zero_range(struct inode *inode, loff_t offset, loff_t len,
 	} else {
 		if (off_start) {
 			if (ret)
 				return ret;
 			new_size = max_t(loff_t, new_size,
-					(loff_t)pg_start << PAGE_CACHE_SHIFT);
+					(loff_t)pg_start << PAGE_SHIFT);
 		for (index = pg_start; index < pg_end; index++) {
@@ -1060,7 +1060,7 @@ static int f2fs_zero_range(struct inode *inode, loff_t offset, loff_t len,
 			f2fs_unlock_op(sbi);
-				(loff_t)(index + 1) << PAGE_CACHE_SHIFT);
+				(loff_t)(index + 1) << PAGE_SHIFT);
 		if (off_end) {
@@ -1117,8 +1117,8 @@ static int f2fs_insert_range(struct inode *inode, loff_t offset, loff_t len)
 	truncate_pagecache(inode, offset);
 	delta = pg_end - pg_start;
 	nrpages = (i_size_read(inode) + PAGE_SIZE - 1) / PAGE_SIZE;
@@ -1158,11 +1158,11 @@ static int expand_inode_data(struct inode *inode, loff_t offset,
 	f2fs_lock_op(sbi);
@@ -1180,12 +1180,12 @@ noalloc:
 			new_size = offset + len;
 		else if (index == pg_start && off_start)
-			new_size = (loff_t)(index + 1) << PAGE_CACHE_SHIFT;
+			new_size = (loff_t)(index + 1) << PAGE_SHIFT;
 		else if (index == pg_end)
-			new_size = ((loff_t)index << PAGE_CACHE_SHIFT) +
+			new_size = ((loff_t)index << PAGE_SHIFT) +
 								off_end;
 		else
-			new_size += PAGE_CACHE_SIZE;
+			new_size += PAGE_SIZE;
 	if (!(mode & FALLOC_FL_KEEP_SIZE) &&
@@ -1652,8 +1652,8 @@ static int f2fs_defragment_range(struct f2fs_sb_info *sbi,
 	if (need_inplace_update(inode))
 		return -EINVAL;
-	pg_start = range->start >> PAGE_CACHE_SHIFT;
-	pg_end = (range->start + range->len) >> PAGE_CACHE_SHIFT;
+	pg_start = range->start >> PAGE_SHIFT;
+	pg_end = (range->start + range->len) >> PAGE_SHIFT;
@@ -1770,7 +1770,7 @@ clear_out:
 out:
 	inode_unlock(inode);
 	if (!err)
-		range->len = (u64)total << PAGE_CACHE_SHIFT;
+		range->len = (u64)total << PAGE_SHIFT;
 	return err;
diff --git a/fs/f2fs/inline.c b/fs/f2fs/inline.c
index 358214e..a2fbe6f 100644
--- a/fs/f2fs/inline.c
+++ b/fs/f2fs/inline.c
@@ -51,7 +51,7 @@ void read_inline_data(struct page *page, struct page *ipage)
 	f2fs_bug_on(F2FS_P_SB(page), page->index);
-	zero_user_segment(page, MAX_INLINE_DATA, PAGE_CACHE_SIZE);
+	zero_user_segment(page, MAX_INLINE_DATA, PAGE_SIZE);
 	/* Copy the whole inline data block */
 	src_addr = inline_data_addr(ipage);
@@ -93,7 +93,7 @@ int f2fs_read_inline_data(struct inode *inode, struct page *page)
 	if (page->index)
 	else
 		read_inline_data(page, ipage);
@@ -375,7 +375,7 @@ static int f2fs_convert_inline_dir(struct inode *dir, struct page *ipage,
 		goto out;
 	dentry_blk = kmap_atomic(page);
@@ -405,8 +405,8 @@ static int f2fs_convert_inline_dir(struct inode *dir, struct page *ipage,
 	stat_dec_inline_dir(dir);
 	clear_inode_flag(F2FS_I(dir), FI_INLINE_DENTRY);
-	if (i_size_read(dir) < PAGE_CACHE_SIZE) {
-		i_size_write(dir, PAGE_CACHE_SIZE);
+	if (i_size_read(dir) < PAGE_SIZE) {
+		i_size_write(dir, PAGE_SIZE);
 		set_inode_flag(F2FS_I(dir), FI_UPDATE_DIR);
diff --git a/fs/f2fs/namei.c b/fs/f2fs/namei.c
index 7876f10..c1d9e9d 100644
--- a/fs/f2fs/namei.c
+++ b/fs/f2fs/namei.c
@@ -1051,12 +1051,12 @@ static const char *f2fs_encrypted_get_link(struct dentry *dentry,
 	/* Null-terminate the name */
 	paddr[res] = '\0';
+	put_page(cpage);
 	return paddr;
 errout:
 	fscrypt_fname_free_buffer(&pstr);
+	put_page(cpage);
diff --git a/fs/f2fs/node.c b/fs/f2fs/node.c
index 118321b..1a33de9 100644
--- a/fs/f2fs/node.c
+++ b/fs/f2fs/node.c
@@ -46,11 +46,11 @@ bool available_free_memory(struct f2fs_sb_info *sbi, int type)
 	if (type == FREE_NIDS) {
 		mem_size = (nm_i->fcnt * sizeof(struct free_nid)) >>
-							PAGE_CACHE_SHIFT;
+							PAGE_SHIFT;
 		res = mem_size < ((avail_ram * nm_i->ram_thresh / 100) >> 2);
 	} else if (type == NAT_ENTRIES) {
 		mem_size = (nm_i->nat_cnt * sizeof(struct nat_entry)) >>
-							PAGE_CACHE_SHIFT;
+							PAGE_SHIFT;
 	} else if (type == DIRTY_DENTS) {
 		if (sbi->sb->s_bdi->wb.dirty_exceeded)
@@ -62,13 +62,13 @@ bool available_free_memory(struct f2fs_sb_info *sbi, int type)
 		for (i = 0; i <= UPDATE_INO; i++)
 			mem_size += (sbi->im[i].ino_num *
-				sizeof(struct ino_entry)) >> PAGE_CACHE_SHIFT;
+				sizeof(struct ino_entry)) >> PAGE_SHIFT;
 		res = mem_size < ((avail_ram * nm_i->ram_thresh / 100) >> 1);
 	} else if (type == EXTENT_CACHE) {
 		mem_size = (atomic_read(&sbi->total_ext_tree) *
 				sizeof(struct extent_tree) +
 				atomic_read(&sbi->total_ext_node) *
-				sizeof(struct extent_node)) >> PAGE_CACHE_SHIFT;
+				sizeof(struct extent_node)) >> PAGE_SHIFT;
 	} else {
 		if (!sbi->sb->s_bdi->wb.dirty_exceeded)
@@ -121,7 +121,7 @@ static struct page *get_next_nat_page(struct f2fs_sb_info *sbi, nid_t nid)
 	src_addr = page_address(src_page);
 	dst_addr = page_address(dst_page);
-	memcpy(dst_addr, src_addr, PAGE_CACHE_SIZE);
+	memcpy(dst_addr, src_addr, PAGE_SIZE);
 	set_page_dirty(dst_page);
 	f2fs_put_page(src_page, 1);
diff --git a/fs/f2fs/recovery.c b/fs/f2fs/recovery.c
index 0b30cd2..011942f 100644
--- a/fs/f2fs/recovery.c
+++ b/fs/f2fs/recovery.c
@@ -591,7 +591,7 @@ out:
 	/* truncate meta pages to be used by the recovery */
 	truncate_inode_pages_range(META_MAPPING(sbi),
-			(loff_t)MAIN_BLKADDR(sbi) << PAGE_CACHE_SHIFT, -1);
+			(loff_t)MAIN_BLKADDR(sbi) << PAGE_SHIFT, -1);
 	if (err) {
 		truncate_inode_pages_final(NODE_MAPPING(sbi));
diff --git a/fs/f2fs/segment.c b/fs/f2fs/segment.c
index 6f16b39..540669d 100644
--- a/fs/f2fs/segment.c
+++ b/fs/f2fs/segment.c
@@ -885,12 +885,12 @@ int npages_for_summary_flush(struct f2fs_sb_info *sbi, bool for_ra)
-	sum_in_page = (PAGE_CACHE_SIZE - 2 * SUM_JOURNAL_SIZE -
+	sum_in_page = (PAGE_SIZE - 2 * SUM_JOURNAL_SIZE -
 			SUM_FOOTER_SIZE) / SUMMARY_SIZE;
 	if (valid_sum_count <= sum_in_page)
 		return 1;
 	else if ((valid_sum_count - sum_in_page) <=
-		(PAGE_CACHE_SIZE - SUM_FOOTER_SIZE) / SUMMARY_SIZE)
+		(PAGE_SIZE - SUM_FOOTER_SIZE) / SUMMARY_SIZE)
 		return 2;
 	return 3;
@@ -909,9 +909,9 @@ void update_meta_page(struct f2fs_sb_info *sbi, void *src, block_t blk_addr)
 	void *dst = page_address(page);
 	if (src)
-		memcpy(dst, src, PAGE_CACHE_SIZE);
+		memcpy(dst, src, PAGE_SIZE);
 	else
-		memset(dst, 0, PAGE_CACHE_SIZE);
+		memset(dst, 0, PAGE_SIZE);
@@ -1596,7 +1596,7 @@ static int read_compacted_summaries(struct f2fs_sb_info *sbi)
 			s = (struct f2fs_summary *)(kaddr + offset);
 			seg_i->sum_blk->entries[j] = *s;
 			offset += SUMMARY_SIZE;
-			if (offset + SUMMARY_SIZE <= PAGE_CACHE_SIZE -
+			if (offset + SUMMARY_SIZE <= PAGE_SIZE -
 						SUM_FOOTER_SIZE)
 				continue;
@@ -1757,7 +1757,7 @@ static void write_compacted_summaries(struct f2fs_sb_info *sbi, block_t blkaddr)
 			*summary = seg_i->sum_blk->entries[j];
 			written_size += SUMMARY_SIZE;
-			if (written_size + SUMMARY_SIZE <= PAGE_CACHE_SIZE -
+			if (written_size + SUMMARY_SIZE <= PAGE_SIZE -
 							SUM_FOOTER_SIZE)
 				continue;
@@ -1844,7 +1844,7 @@ static struct page *get_next_sit_page(struct f2fs_sb_info *sbi,
@@ -2171,7 +2171,7 @@ static int build_curseg(struct f2fs_sb_info *sbi)
 	for (i = 0; i < NR_CURSEG_TYPE; i++) {
 		mutex_init(&array[i].curseg_mutex);
-		array[i].sum_blk = kzalloc(PAGE_CACHE_SIZE, GFP_KERNEL);
+		array[i].sum_blk = kzalloc(PAGE_SIZE, GFP_KERNEL);
 		if (!array[i].sum_blk)
 			return -ENOMEM;
 		init_rwsem(&array[i].journal_rwsem);
diff --git a/fs/f2fs/super.c b/fs/f2fs/super.c
index 15bb81f..53b766c 100644
--- a/fs/f2fs/super.c
+++ b/fs/f2fs/super.c
@@ -1070,10 +1070,10 @@ static int sanity_check_raw_super(struct super_block *sb,
 	/* Currently, support only 4KB page cache size */
-	if (F2FS_BLKSIZE != PAGE_CACHE_SIZE) {
+	if (F2FS_BLKSIZE != PAGE_SIZE) {
 		f2fs_msg(sb, KERN_INFO,
 			"Invalid page_cache_size (%lu), supports only 4KB\n",
-			PAGE_CACHE_SIZE);
+			PAGE_SIZE);
 		return 1;
diff --git a/fs/freevxfs/vxfs_immed.c b/fs/freevxfs/vxfs_immed.c
index cb84f0f..bfc780c 100644
--- a/fs/freevxfs/vxfs_immed.c
+++ b/fs/freevxfs/vxfs_immed.c
@@ -66,11 +66,11 @@ static int
 vxfs_immed_readpage(struct file *fp, struct page *pp)
 	struct vxfs_inode_info	*vip = VXFS_INO(pp->mapping->host);
-	u_int64_t	offset = (u_int64_t)pp->index << PAGE_CACHE_SHIFT;
+	u_int64_t	offset = (u_int64_t)pp->index << PAGE_SHIFT;
 	caddr_t		kaddr;
 	kaddr = kmap(pp);
-	memcpy(kaddr, vip->vii_immed.vi_immed + offset, PAGE_CACHE_SIZE);
+	memcpy(kaddr, vip->vii_immed.vi_immed + offset, PAGE_SIZE);
 	kunmap(pp);
 	flush_dcache_page(pp);
diff --git a/fs/freevxfs/vxfs_lookup.c b/fs/freevxfs/vxfs_lookup.c
index 1cff72d..a49e0cf 100644
--- a/fs/freevxfs/vxfs_lookup.c
+++ b/fs/freevxfs/vxfs_lookup.c
@@ -45,7 +45,7 @@
  * Number of VxFS blocks per page.
-#define VXFS_BLOCK_PER_PAGE(sbp)  ((PAGE_CACHE_SIZE / (sbp)->s_blocksize))
+#define VXFS_BLOCK_PER_PAGE(sbp)  ((PAGE_SIZE / (sbp)->s_blocksize))
 static struct dentry *	vxfs_lookup(struct inode *, struct dentry *, unsigned int);
@@ -175,7 +175,7 @@ vxfs_inode_by_name(struct inode *dip, struct dentry *dp)
 	if (de) {
 		ino = de->d_ino;
 		kunmap(pp);
-		page_cache_release(pp);
+		put_page(pp);
 	return (ino);
@@ -255,8 +255,8 @@ vxfs_readdir(struct file *fp, struct dir_context *ctx)
 	nblocks = dir_blocks(ip);
 	pblocks = VXFS_BLOCK_PER_PAGE(sbp);
-	page = pos >> PAGE_CACHE_SHIFT;
-	offset = pos & ~PAGE_CACHE_MASK;
+	page = pos >> PAGE_SHIFT;
+	offset = pos & ~PAGE_MASK;
 	block = (u_long)(pos >> sbp->s_blocksize_bits) % pblocks;
 	for (; page < npages; page++, block = 0) {
@@ -289,7 +289,7 @@ vxfs_readdir(struct file *fp, struct dir_context *ctx)
 					continue;
 				offset = (char *)de - kaddr;
-				ctx->pos = ((page << PAGE_CACHE_SHIFT) | offset) + 2;
+				ctx->pos = ((page << PAGE_SHIFT) | offset) + 2;
 				if (!dir_emit(ctx, de->d_name, de->d_namelen,
 					de->d_ino, DT_UNKNOWN)) {
 					vxfs_put_page(pp);
@@ -301,6 +301,6 @@ vxfs_readdir(struct file *fp, struct dir_context *ctx)
 		vxfs_put_page(pp);
 		offset = 0;
 	return 0;
diff --git a/fs/freevxfs/vxfs_subr.c b/fs/freevxfs/vxfs_subr.c
index 5d318c4..e806694 100644
--- a/fs/freevxfs/vxfs_subr.c
+++ b/fs/freevxfs/vxfs_subr.c
@@ -50,7 +50,7 @@ inline void
 vxfs_put_page(struct page *pp)
 	kunmap(pp);
+	put_page(pp);
diff --git a/fs/fs-writeback.c b/fs/fs-writeback.c
index fee81e8..592cea5 100644
--- a/fs/fs-writeback.c
+++ b/fs/fs-writeback.c
@@ -33,7 +33,7 @@
  * 4MB minimal write chunk size
-#define MIN_WRITEBACK_PAGES	(4096UL >> (PAGE_CACHE_SHIFT - 10))
+#define MIN_WRITEBACK_PAGES	(4096UL >> (PAGE_SHIFT - 10))
 struct wb_completion {
 	atomic_t		cnt;
diff --git a/fs/fscache/page.c b/fs/fscache/page.c
index 6b35fc4..3078b67 100644
--- a/fs/fscache/page.c
+++ b/fs/fscache/page.c
@@ -113,7 +113,7 @@ try_again:
 	wake_up_bit(&cookie->flags, 0);
 	if (xpage)
-		page_cache_release(xpage);
+		put_page(xpage);
 	__fscache_uncache_page(cookie, page);
 	return true;
@@ -164,7 +164,7 @@ static void fscache_end_page_write(struct fscache_object *object,
 	spin_unlock(&object->lock);
 	if (xpage)
+		put_page(xpage);
@@ -884,7 +884,7 @@ void fscache_invalidate_writes(struct fscache_cookie *cookie)
 		spin_unlock(&cookie->stores_lock);
 		for (i = n - 1; i >= 0; i--)
-			page_cache_release(results[i]);
+			put_page(results[i]);
 	_leave("");
@@ -982,7 +982,7 @@ int __fscache_write_page(struct fscache_cookie *cookie,
 	radix_tree_tag_set(&cookie->stores, page->index,
 			   FSCACHE_COOKIE_PENDING_TAG);
-	page_cache_get(page);
+	get_page(page);
 	/* we only want one writer at a time, but we do need to queue new
 	 * writers after exclusive ops */
@@ -1026,7 +1026,7 @@ submit_failed:
 	radix_tree_delete(&cookie->stores, page->index);
 	wake_cookie = __fscache_unuse_cookie(cookie);
+	put_page(page);
 	ret = -ENOBUFS;
 	goto nobufs;
diff --git a/fs/fuse/dev.c b/fs/fuse/dev.c
index ebb5e37..cbece12 100644
--- a/fs/fuse/dev.c
+++ b/fs/fuse/dev.c
@@ -897,7 +897,7 @@ static int fuse_try_move_page(struct fuse_copy_state *cs, struct page **pagep)
 		return err;
-	page_cache_get(newpage);
+	get_page(newpage);
 	if (!(buf->flags & PIPE_BUF_FLAG_LRU))
 		lru_cache_add_file(newpage);
@@ -912,12 +912,12 @@ static int fuse_try_move_page(struct fuse_copy_state *cs, struct page **pagep)
 	if (err) {
 		unlock_page(newpage);
-		page_cache_release(newpage);
+		put_page(newpage);
 		return err;
 	unlock_page(oldpage);
-	page_cache_release(oldpage);
+	put_page(oldpage);
 	cs->len = 0;
 	return 0;
@@ -951,7 +951,7 @@ static int fuse_ref_page(struct fuse_copy_state *cs, struct page *page,
 	fuse_copy_finish(cs);
 	buf = cs->pipebufs;
+	get_page(page);
 	buf->page = page;
 	buf->offset = offset;
 	buf->len = count;
@@ -1435,7 +1435,7 @@ out_unlock:
 out:
 	for (; page_nr < cs.nr_segs; page_nr++)
-		page_cache_release(bufs[page_nr].page);
+		put_page(bufs[page_nr].page);
 	kfree(bufs);
 	return ret;
@@ -1632,8 +1632,8 @@ static int fuse_notify_store(struct fuse_conn *fc, unsigned int size,
 		goto out_up_killsb;
-	index = outarg.offset >> PAGE_CACHE_SHIFT;
-	offset = outarg.offset & ~PAGE_CACHE_MASK;
+	index = outarg.offset >> PAGE_SHIFT;
+	offset = outarg.offset & ~PAGE_MASK;
 	file_size = i_size_read(inode);
 	end = outarg.offset + outarg.size;
 	if (end > file_size) {
@@ -1652,13 +1652,13 @@ static int fuse_notify_store(struct fuse_conn *fc, unsigned int size,
 		if (!page)
 			goto out_iput;
-		this_num = min_t(unsigned, num, PAGE_CACHE_SIZE - offset);
+		this_num = min_t(unsigned, num, PAGE_SIZE - offset);
 		err = fuse_copy_page(cs, &page, offset, this_num, 0);
 		if (!err && offset == 0 &&
-		    (this_num == PAGE_CACHE_SIZE || file_size == end))
+		    (this_num == PAGE_SIZE || file_size == end))
 		unlock_page(page);
+		put_page(page);
 		if (err)
 			goto out_iput;
@@ -1697,7 +1697,7 @@ static int fuse_retrieve(struct fuse_conn *fc, struct inode *inode,
 	size_t total_len = 0;
 	int num_pages;
-	offset = outarg->offset & ~PAGE_CACHE_MASK;
+	offset = outarg->offset & ~PAGE_MASK;
 	num = outarg->size;
@@ -1720,7 +1720,7 @@ static int fuse_retrieve(struct fuse_conn *fc, struct inode *inode,
 	req->page_descs[0].offset = offset;
 	req->end = fuse_retrieve_end;
-	index = outarg->offset >> PAGE_CACHE_SHIFT;
+	index = outarg->offset >> PAGE_SHIFT;
 	while (num && req->num_pages < num_pages) {
 		struct page *page;
@@ -1730,7 +1730,7 @@ static int fuse_retrieve(struct fuse_conn *fc, struct inode *inode,
 		if (!page)
 			break;
 		req->pages[req->num_pages] = page;
 		req->page_descs[req->num_pages].length = this_num;
 		req->num_pages++;
diff --git a/fs/fuse/file.c b/fs/fuse/file.c
index 9dde38f..719924d 100644
--- a/fs/fuse/file.c
+++ b/fs/fuse/file.c
@@ -348,7 +348,7 @@ static bool fuse_range_is_writeback(struct inode *inode, pgoff_t idx_from,
 		pgoff_t curr_index;
 		BUG_ON(req->inode != inode);
-		curr_index = req->misc.write.in.offset >> PAGE_CACHE_SHIFT;
+		curr_index = req->misc.write.in.offset >> PAGE_SHIFT;
 		if (idx_from < curr_index + req->num_pages &&
 		    curr_index <= idx_to) {
 			found = true;
@@ -683,11 +683,11 @@ static void fuse_short_read(struct fuse_req *req, struct inode *inode,
 		 * present there.
 		int i;
-		int start_idx = num_read >> PAGE_CACHE_SHIFT;
-		size_t off = num_read & (PAGE_CACHE_SIZE - 1);
+		int start_idx = num_read >> PAGE_SHIFT;
+		size_t off = num_read & (PAGE_SIZE - 1);
 		for (i = start_idx; i < req->num_pages; i++) {
-			zero_user_segment(req->pages[i], off, PAGE_CACHE_SIZE);
+			zero_user_segment(req->pages[i], off, PAGE_SIZE);
 			off = 0;
 	} else {
@@ -704,7 +704,7 @@ static int fuse_do_readpage(struct file *file, struct page *page)
 	struct fuse_req *req;
 	size_t num_read;
 	loff_t pos = page_offset(page);
-	size_t count = PAGE_CACHE_SIZE;
+	size_t count = PAGE_SIZE;
 	u64 attr_ver;
 	int err;
@@ -789,7 +789,7 @@ static void fuse_readpages_end(struct fuse_conn *fc, struct fuse_req *req)
 		else
 			SetPageError(page);
 		unlock_page(page);
+		put_page(page);
 	if (req->ff)
 		fuse_file_put(req->ff, false);
@@ -800,7 +800,7 @@ static void fuse_send_readpages(struct fuse_req *req, struct file *file)
 	struct fuse_file *ff = file->private_data;
 	struct fuse_conn *fc = ff->fc;
 	loff_t pos = page_offset(req->pages[0]);
-	size_t count = req->num_pages << PAGE_CACHE_SHIFT;
+	size_t count = req->num_pages << PAGE_SHIFT;
 	req->out.argpages = 1;
 	req->out.page_zeroing = 1;
@@ -836,7 +836,7 @@ static int fuse_readpages_fill(void *_data, struct page *page)
 	if (req->num_pages &&
 	    (req->num_pages == FUSE_MAX_PAGES_PER_REQ ||
-	     (req->num_pages + 1) * PAGE_CACHE_SIZE > fc->max_read ||
+	     (req->num_pages + 1) * PAGE_SIZE > fc->max_read ||
 	     req->pages[req->num_pages - 1]->index + 1 != page->index)) {
 		int nr_alloc = min_t(unsigned, data->nr_pages,
 				     FUSE_MAX_PAGES_PER_REQ);
@@ -858,7 +858,7 @@ static int fuse_readpages_fill(void *_data, struct page *page)
 		return -EIO;
+	get_page(page);
 	req->page_descs[req->num_pages].length = PAGE_SIZE;
 	req->num_pages++;
@@ -1003,17 +1003,17 @@ static size_t fuse_send_write_pages(struct fuse_req *req, struct file *file,
 	for (i = 0; i < req->num_pages; i++) {
 		struct page *page = req->pages[i];
-		if (!req->out.h.error && !offset && count >= PAGE_CACHE_SIZE)
+		if (!req->out.h.error && !offset && count >= PAGE_SIZE)
-		if (count > PAGE_CACHE_SIZE - offset)
-			count -= PAGE_CACHE_SIZE - offset;
+		if (count > PAGE_SIZE - offset)
+			count -= PAGE_SIZE - offset;
 		else
 			count = 0;
 		offset = 0;
 		unlock_page(page);
+		put_page(page);
 	return res;
@@ -1024,7 +1024,7 @@ static ssize_t fuse_fill_write_pages(struct fuse_req *req,
 			       struct iov_iter *ii, loff_t pos)
 	struct fuse_conn *fc = get_fuse_conn(mapping->host);
-	unsigned offset = pos & (PAGE_CACHE_SIZE - 1);
+	unsigned offset = pos & (PAGE_SIZE - 1);
 	size_t count = 0;
 	int err;
@@ -1034,8 +1034,8 @@ static ssize_t fuse_fill_write_pages(struct fuse_req *req,
 	do {
 		size_t tmp;
 		struct page *page;
-		pgoff_t index = pos >> PAGE_CACHE_SHIFT;
-		size_t bytes = min_t(size_t, PAGE_CACHE_SIZE - offset,
+		pgoff_t index = pos >> PAGE_SHIFT;
+		size_t bytes = min_t(size_t, PAGE_SIZE - offset,
 				     iov_iter_count(ii));
 		bytes = min_t(size_t, bytes, fc->max_write - count);
@@ -1059,7 +1059,7 @@ static ssize_t fuse_fill_write_pages(struct fuse_req *req,
 		iov_iter_advance(ii, tmp);
 		if (!tmp) {
 			unlock_page(page);
+			put_page(page);
 			bytes = min(bytes, iov_iter_single_seg_count(ii));
 			goto again;
@@ -1072,7 +1072,7 @@ static ssize_t fuse_fill_write_pages(struct fuse_req *req,
 		count += tmp;
 		pos += tmp;
 		offset += tmp;
-		if (offset == PAGE_CACHE_SIZE)
+		if (offset == PAGE_SIZE)
 			offset = 0;
 		if (!fc->big_writes)
@@ -1086,8 +1086,8 @@ static ssize_t fuse_fill_write_pages(struct fuse_req *req,
 static inline unsigned fuse_wr_pages(loff_t pos, size_t len)
 	return min_t(unsigned,
-		     ((pos + len - 1) >> PAGE_CACHE_SHIFT) -
-		     (pos >> PAGE_CACHE_SHIFT) + 1,
+		     ((pos + len - 1) >> PAGE_SHIFT) -
+		     (pos >> PAGE_SHIFT) + 1,
@@ -1205,8 +1205,8 @@ static ssize_t fuse_file_write_iter(struct kiocb *iocb, struct iov_iter *from)
 			goto out;
 		invalidate_mapping_pages(file->f_mapping,
-					 pos >> PAGE_CACHE_SHIFT,
-					 endbyte >> PAGE_CACHE_SHIFT);
+					 pos >> PAGE_SHIFT,
+					 endbyte >> PAGE_SHIFT);
 		written += written_buffered;
 		iocb->ki_pos = pos + written_buffered;
@@ -1315,8 +1315,8 @@ ssize_t fuse_direct_io(struct fuse_io_priv *io, struct iov_iter *iter,
 	size_t nmax = write ? fc->max_write : fc->max_read;
 	loff_t pos = *ppos;
 	size_t count = iov_iter_count(iter);
-	pgoff_t idx_from = pos >> PAGE_CACHE_SHIFT;
-	pgoff_t idx_to = (pos + count - 1) >> PAGE_CACHE_SHIFT;
+	pgoff_t idx_from = pos >> PAGE_SHIFT;
+	pgoff_t idx_to = (pos + count - 1) >> PAGE_SHIFT;
 	ssize_t res = 0;
 	int err = 0;
@@ -1466,7 +1466,7 @@ __acquires(fc->lock)
 	struct fuse_inode *fi = get_fuse_inode(req->inode);
 	struct fuse_write_in *inarg = &req->misc.write.in;
-	__u64 data_size = req->num_pages * PAGE_CACHE_SIZE;
+	__u64 data_size = req->num_pages * PAGE_SIZE;
 	if (!fc->connected)
 		goto out_free;
@@ -1727,7 +1727,7 @@ static bool fuse_writepage_in_flight(struct fuse_req *new_req,
 	list_del(&new_req->writepages_entry);
 	list_for_each_entry(old_req, &fi->writepages, writepages_entry) {
 		BUG_ON(old_req->inode != new_req->inode);
-		curr_index = old_req->misc.write.in.offset >> PAGE_CACHE_SHIFT;
+		curr_index = old_req->misc.write.in.offset >> PAGE_SHIFT;
 		if (curr_index <= page->index &&
 		    page->index < curr_index + old_req->num_pages) {
 			found = true;
@@ -1742,7 +1742,7 @@ static bool fuse_writepage_in_flight(struct fuse_req *new_req,
 	new_req->num_pages = 1;
 	for (tmp = old_req; tmp != NULL; tmp = tmp->misc.write.next) {
 		BUG_ON(tmp->inode != new_req->inode);
-		curr_index = tmp->misc.write.in.offset >> PAGE_CACHE_SHIFT;
+		curr_index = tmp->misc.write.in.offset >> PAGE_SHIFT;
 		if (tmp->num_pages == 1 &&
 		    curr_index == page->index) {
 			old_req = tmp;
@@ -1799,7 +1799,7 @@ static int fuse_writepages_fill(struct page *page,
 	if (req && req->num_pages &&
 	    (is_writeback || req->num_pages == FUSE_MAX_PAGES_PER_REQ ||
-	     (req->num_pages + 1) * PAGE_CACHE_SIZE > fc->max_write ||
+	     (req->num_pages + 1) * PAGE_SIZE > fc->max_write ||
 	     data->orig_pages[req->num_pages - 1]->index + 1 != page->index)) {
 		fuse_writepages_send(data);
 		data->req = NULL;
@@ -1924,7 +1924,7 @@ static int fuse_write_begin(struct file *file, struct address_space *mapping,
 		loff_t pos, unsigned len, unsigned flags,
 		struct page **pagep, void **fsdata)
 	struct fuse_conn *fc = get_fuse_conn(file_inode(file));
 	struct page *page;
 	loff_t fsize;
@@ -1938,15 +1938,15 @@ static int fuse_write_begin(struct file *file, struct address_space *mapping,
 	fuse_wait_on_page_writeback(mapping->host, page->index);
-	if (PageUptodate(page) || len == PAGE_CACHE_SIZE)
+	if (PageUptodate(page) || len == PAGE_SIZE)
 		goto success;
 	 * Check if the start this page comes after the end of file, in which
 	 * case the readpage can be optimized away.
 	fsize = i_size_read(mapping->host);
-	if (fsize <= (pos & PAGE_CACHE_MASK)) {
-		size_t off = pos & ~PAGE_CACHE_MASK;
+	if (fsize <= (pos & PAGE_MASK)) {
+		size_t off = pos & ~PAGE_MASK;
 		if (off)
 			zero_user_segment(page, 0, off);
 		goto success;
@@ -1960,7 +1960,7 @@ success:
 cleanup:
 	unlock_page(page);
+	put_page(page);
 error:
 	return err;
@@ -1973,16 +1973,16 @@ static int fuse_write_end(struct file *file, struct address_space *mapping,
 		/* Zero any unwritten bytes at the end of the page */
-		size_t endoff = (pos + copied) & ~PAGE_CACHE_MASK;
+		size_t endoff = (pos + copied) & ~PAGE_MASK;
 		if (endoff)
-			zero_user_segment(page, endoff, PAGE_CACHE_SIZE);
+			zero_user_segment(page, endoff, PAGE_SIZE);
 	fuse_write_update_size(inode, pos + copied);
 	unlock_page(page);
+	put_page(page);
 	return copied;
diff --git a/fs/fuse/inode.c b/fs/fuse/inode.c
index 4d69d5c..1ce6766 100644
--- a/fs/fuse/inode.c
+++ b/fs/fuse/inode.c
@@ -339,11 +339,11 @@ int fuse_reverse_inval_inode(struct super_block *sb, u64 nodeid,
 	fuse_invalidate_attr(inode);
 	if (offset >= 0) {
 		if (len <= 0)
 			pg_end = -1;
 		else
-			pg_end = (offset + len - 1) >> PAGE_CACHE_SHIFT;
+			pg_end = (offset + len - 1) >> PAGE_SHIFT;
 		invalidate_inode_pages2_range(inode->i_mapping,
 					      pg_start, pg_end);
@@ -864,7 +864,7 @@ static void process_init_reply(struct fuse_conn *fc, struct fuse_req *req)
 		process_init_limits(fc, arg);
 		if (arg->minor >= 6) {
-			ra_pages = arg->max_readahead / PAGE_CACHE_SIZE;
+			ra_pages = arg->max_readahead / PAGE_SIZE;
 			if (arg->flags & FUSE_ASYNC_READ)
 				fc->async_read = 1;
 			if (!(arg->flags & FUSE_POSIX_LOCKS))
@@ -901,7 +901,7 @@ static void process_init_reply(struct fuse_conn *fc, struct fuse_req *req)
 			if (arg->time_gran && arg->time_gran <= 1000000000)
 				fc->sb->s_time_gran = arg->time_gran;
 		} else {
-			ra_pages = fc->max_read / PAGE_CACHE_SIZE;
+			ra_pages = fc->max_read / PAGE_SIZE;
 			fc->no_lock = 1;
 			fc->no_flock = 1;
@@ -922,7 +922,7 @@ static void fuse_send_init(struct fuse_conn *fc, struct fuse_req *req)
 	arg->major = FUSE_KERNEL_VERSION;
 	arg->minor = FUSE_KERNEL_MINOR_VERSION;
-	arg->max_readahead = fc->bdi.ra_pages * PAGE_CACHE_SIZE;
+	arg->max_readahead = fc->bdi.ra_pages * PAGE_SIZE;
 	arg->flags |= FUSE_ASYNC_READ | FUSE_POSIX_LOCKS | FUSE_ATOMIC_O_TRUNC |
 		FUSE_EXPORT_SUPPORT | FUSE_BIG_WRITES | FUSE_DONT_MASK |
 		FUSE_SPLICE_WRITE | FUSE_SPLICE_MOVE | FUSE_SPLICE_READ |
@@ -955,7 +955,7 @@ static int fuse_bdi_init(struct fuse_conn *fc, struct super_block *sb)
 	int err;
 	fc->bdi.name = "fuse";
-	fc->bdi.ra_pages = (VM_MAX_READAHEAD * 1024) / PAGE_CACHE_SIZE;
+	fc->bdi.ra_pages = (VM_MAX_READAHEAD * 1024) / PAGE_SIZE;
 	/* fuse does it's own writeback accounting */
 	fc->bdi.capabilities = BDI_CAP_NO_ACCT_WB | BDI_CAP_STRICTLIMIT;
@@ -1053,8 +1053,8 @@ static int fuse_fill_super(struct super_block *sb, void *data, int silent)
 			goto err;
 #endif
 	} else {
-		sb->s_blocksize = PAGE_CACHE_SIZE;
-		sb->s_blocksize_bits = PAGE_CACHE_SHIFT;
+		sb->s_blocksize = PAGE_SIZE;
+		sb->s_blocksize_bits = PAGE_SHIFT;
 	sb->s_magic = FUSE_SUPER_MAGIC;
 	sb->s_op = &fuse_super_operations;
diff --git a/fs/gfs2/aops.c b/fs/gfs2/aops.c
index aa016e4..1bbbee9 100644
--- a/fs/gfs2/aops.c
+++ b/fs/gfs2/aops.c
@@ -101,7 +101,7 @@ static int gfs2_writepage_common(struct page *page,
 	struct gfs2_inode *ip = GFS2_I(inode);
 	struct gfs2_sbd *sdp = GFS2_SB(inode);
 	loff_t i_size = i_size_read(inode);
-	pgoff_t end_index = i_size >> PAGE_CACHE_SHIFT;
+	pgoff_t end_index = i_size >> PAGE_SHIFT;
 	unsigned offset;
 	if (gfs2_assert_withdraw(sdp, gfs2_glock_is_held_excl(ip->i_gl)))
@@ -109,9 +109,9 @@ static int gfs2_writepage_common(struct page *page,
 	if (current->journal_info)
 		goto redirty;
 	/* Is the page fully outside i_size? (truncate in progress) */
-	offset = i_size & (PAGE_CACHE_SIZE-1);
+	offset = i_size & (PAGE_SIZE-1);
 	if (page->index > end_index || (page->index == end_index && !offset)) {
-		page->mapping->a_ops->invalidatepage(page, 0, PAGE_CACHE_SIZE);
+		page->mapping->a_ops->invalidatepage(page, 0, PAGE_SIZE);
 		goto out;
 	return 1;
@@ -238,7 +238,7 @@ static int gfs2_write_jdata_pagevec(struct address_space *mapping,
-	unsigned nrblocks = nr_pages * (PAGE_CACHE_SIZE/inode->i_sb->s_blocksize);
+	unsigned nrblocks = nr_pages * (PAGE_SIZE/inode->i_sb->s_blocksize);
 	int i;
 	int ret;
@@ -366,8 +366,8 @@ static int gfs2_write_cache_jdata(struct address_space *mapping,
 			cycled = 0;
 		end = -1;
 	} else {
 			range_whole = 1;
@@ -458,7 +458,7 @@ static int stuffed_readpage(struct gfs2_inode *ip, struct page *page)
 	 * so we need to supply one here. It doesn't happen often.
 	if (unlikely(page->index)) {
-		zero_user(page, 0, PAGE_CACHE_SIZE);
+		zero_user(page, 0, PAGE_SIZE);
 		return 0;
@@ -471,7 +471,7 @@ static int stuffed_readpage(struct gfs2_inode *ip, struct page *page)
 	if (dsize > (dibh->b_size - sizeof(struct gfs2_dinode)))
 		dsize = (dibh->b_size - sizeof(struct gfs2_dinode));
 	memcpy(kaddr, dibh->b_data + sizeof(struct gfs2_dinode), dsize);
-	memset(kaddr + dsize, 0, PAGE_CACHE_SIZE - dsize);
+	memset(kaddr + dsize, 0, PAGE_SIZE - dsize);
 	kunmap_atomic(kaddr);
 	flush_dcache_page(page);
 	brelse(dibh);
@@ -560,8 +560,8 @@ int gfs2_internal_read(struct gfs2_inode *ip, char *buf, loff_t *pos,
                        unsigned size)
 	struct address_space *mapping = ip->i_inode.i_mapping;
-	unsigned long index = *pos / PAGE_CACHE_SIZE;
-	unsigned offset = *pos & (PAGE_CACHE_SIZE - 1);
+	unsigned long index = *pos / PAGE_SIZE;
+	unsigned offset = *pos & (PAGE_SIZE - 1);
 	unsigned copied = 0;
 	unsigned amt;
 	struct page *page;
@@ -569,15 +569,15 @@ int gfs2_internal_read(struct gfs2_inode *ip, char *buf, loff_t *pos,
 	do {
 		amt = size - copied;
-		if (offset + size > PAGE_CACHE_SIZE)
-			amt = PAGE_CACHE_SIZE - offset;
+		if (offset + size > PAGE_SIZE)
+			amt = PAGE_SIZE - offset;
 		page = read_cache_page(mapping, index, __gfs2_readpage, NULL);
 		if (IS_ERR(page))
 			return PTR_ERR(page);
 		p = kmap_atomic(page);
 		memcpy(buf + copied, p + offset, amt);
 		kunmap_atomic(p);
+		put_page(page);
 		copied += amt;
 		index++;
 		offset = 0;
@@ -651,8 +651,8 @@ static int gfs2_write_begin(struct file *file, struct address_space *mapping,
 	unsigned requested = 0;
 	int alloc_required;
 	int error = 0;
-	unsigned from = pos & (PAGE_CACHE_SIZE - 1);
+	unsigned from = pos & (PAGE_SIZE - 1);
 	struct page *page;
 	gfs2_holder_init(ip->i_gl, LM_ST_EXCLUSIVE, 0, &ip->i_gh);
@@ -697,7 +697,7 @@ static int gfs2_write_begin(struct file *file, struct address_space *mapping,
 		rblocks += gfs2_rg_blocks(ip, requested);
 	error = gfs2_trans_begin(sdp, rblocks,
-				 PAGE_CACHE_SIZE/sdp->sd_sb.sb_bsize);
+				 PAGE_SIZE/sdp->sd_sb.sb_bsize);
 	if (error)
 		goto out_trans_fail;
@@ -727,7 +727,7 @@ out:
 		return 0;
 	unlock_page(page);
+	put_page(page);
 	gfs2_trans_end(sdp);
 	if (pos + len > ip->i_inode.i_size)
@@ -827,7 +827,7 @@ static int gfs2_stuffed_write_end(struct inode *inode, struct buffer_head *dibh,
 	if (!PageUptodate(page))
 		SetPageUptodate(page);
 	unlock_page(page);
+	put_page(page);
 	if (copied) {
 		if (inode->i_size < to)
@@ -877,7 +877,7 @@ static int gfs2_write_end(struct file *file, struct address_space *mapping,
 	struct gfs2_inode *m_ip = GFS2_I(sdp->sd_statfs_inode);
 	struct buffer_head *dibh;
-	unsigned int from = pos & (PAGE_CACHE_SIZE - 1);
+	unsigned int from = pos & (PAGE_SIZE - 1);
 	unsigned int to = from + len;
 	int ret;
 	struct gfs2_trans *tr = current->journal_info;
@@ -888,7 +888,7 @@ static int gfs2_write_end(struct file *file, struct address_space *mapping,
 	ret = gfs2_meta_inode_buffer(ip, &dibh);
 	if (unlikely(ret)) {
 		unlock_page(page);
+		put_page(page);
 		goto failed;
@@ -992,7 +992,7 @@ static void gfs2_invalidatepage(struct page *page, unsigned int offset,
 	struct gfs2_sbd *sdp = GFS2_SB(page->mapping->host);
 	unsigned int stop = offset + length;
-	int partial_page = (offset || length < PAGE_CACHE_SIZE);
+	int partial_page = (offset || length < PAGE_SIZE);
 	struct buffer_head *bh, *head;
 	unsigned long pos = 0;
@@ -1082,7 +1082,7 @@ static ssize_t gfs2_direct_IO(struct kiocb *iocb, struct iov_iter *iter,
 	 * the first place, mapping->nr_pages will always be zero.
 	if (mapping->nrpages) {
-		loff_t lstart = offset & ~(PAGE_CACHE_SIZE - 1);
+		loff_t lstart = offset & ~(PAGE_SIZE - 1);
 		loff_t len = iov_iter_count(iter);
 		loff_t end = PAGE_ALIGN(offset + len) - 1;
diff --git a/fs/gfs2/bmap.c b/fs/gfs2/bmap.c
index 0860f0b..24ce1cd 100644
--- a/fs/gfs2/bmap.c
+++ b/fs/gfs2/bmap.c
@@ -75,7 +75,7 @@ static int gfs2_unstuffer_page(struct gfs2_inode *ip, struct buffer_head *dibh,
 			dsize = dibh->b_size - sizeof(struct gfs2_dinode);
 		kunmap(page);
@@ -98,7 +98,7 @@ static int gfs2_unstuffer_page(struct gfs2_inode *ip, struct buffer_head *dibh,
 	if (release) {
 		unlock_page(page);
+		put_page(page);
 	return 0;
@@ -932,8 +932,8 @@ static int gfs2_block_truncate_page(struct address_space *mapping, loff_t from)
-	unsigned long index = from >> PAGE_CACHE_SHIFT;
+	unsigned long index = from >> PAGE_SHIFT;
 	unsigned blocksize, iblock, length, pos;
 	struct buffer_head *bh;
 	struct page *page;
@@ -945,7 +945,7 @@ static int gfs2_block_truncate_page(struct address_space *mapping, loff_t from)
 	length = blocksize - (offset & (blocksize - 1));
 	if (!page_has_buffers(page))
 		create_empty_buffers(page, blocksize, 0);
@@ -989,7 +989,7 @@ static int gfs2_block_truncate_page(struct address_space *mapping, loff_t from)
 	mark_buffer_dirty(bh);
 unlock:
 	unlock_page(page);
+	put_page(page);
 	return err;
diff --git a/fs/gfs2/file.c b/fs/gfs2/file.c
index c9384f9..208efc7 100644
--- a/fs/gfs2/file.c
+++ b/fs/gfs2/file.c
@@ -354,8 +354,8 @@ static int gfs2_allocate_page_backing(struct page *page)
 	struct inode *inode = page->mapping->host;
 	struct buffer_head bh;
-	unsigned long size = PAGE_CACHE_SIZE;
-	u64 lblock = page->index << (PAGE_CACHE_SHIFT - inode->i_blkbits);
+	unsigned long size = PAGE_SIZE;
+	u64 lblock = page->index << (PAGE_SHIFT - inode->i_blkbits);
 	do {
 		bh.b_state = 0;
@@ -386,7 +386,7 @@ static int gfs2_page_mkwrite(struct vm_area_struct *vma, struct vm_fault *vmf)
 	struct gfs2_alloc_parms ap = { .aflags = 0, };
 	unsigned long last_index;
-	u64 pos = page->index << PAGE_CACHE_SHIFT;
+	u64 pos = page->index << PAGE_SHIFT;
 	unsigned int data_blocks, ind_blocks, rblocks;
 	struct gfs2_holder gh;
 	loff_t size;
@@ -401,7 +401,7 @@ static int gfs2_page_mkwrite(struct vm_area_struct *vma, struct vm_fault *vmf)
 	if (ret)
 		goto out;
-	gfs2_size_hint(vma->vm_file, pos, PAGE_CACHE_SIZE);
+	gfs2_size_hint(vma->vm_file, pos, PAGE_SIZE);
 	gfs2_holder_init(ip->i_gl, LM_ST_EXCLUSIVE, 0, &gh);
 	ret = gfs2_glock_nq(&gh);
@@ -411,7 +411,7 @@ static int gfs2_page_mkwrite(struct vm_area_struct *vma, struct vm_fault *vmf)
 	set_bit(GLF_DIRTY, &ip->i_gl->gl_flags);
 	set_bit(GIF_SW_PAGED, &ip->i_flags);
-	if (!gfs2_write_alloc_required(ip, pos, PAGE_CACHE_SIZE)) {
+	if (!gfs2_write_alloc_required(ip, pos, PAGE_SIZE)) {
 		lock_page(page);
 		if (!PageUptodate(page) || page->mapping != inode->i_mapping) {
 			ret = -EAGAIN;
@@ -424,7 +424,7 @@ static int gfs2_page_mkwrite(struct vm_area_struct *vma, struct vm_fault *vmf)
 	if (ret)
 		goto out_unlock;
-	gfs2_write_calc_reserv(ip, PAGE_CACHE_SIZE, &data_blocks, &ind_blocks);
+	gfs2_write_calc_reserv(ip, PAGE_SIZE, &data_blocks, &ind_blocks);
 	ap.target = data_blocks + ind_blocks;
 	ret = gfs2_quota_lock_check(ip, &ap);
 	if (ret)
@@ -447,7 +447,7 @@ static int gfs2_page_mkwrite(struct vm_area_struct *vma, struct vm_fault *vmf)
 	lock_page(page);
 	ret = -EINVAL;
-	last_index = (size - 1) >> PAGE_CACHE_SHIFT;
+	last_index = (size - 1) >> PAGE_SHIFT;
 	/* Check page index against inode size */
 	if (size == 0 || (page->index > last_index))
 		goto out_trans_end;
@@ -873,7 +873,7 @@ static long __gfs2_fallocate(struct file *file, int mode, loff_t offset, loff_t
 			rblocks += data_blocks ? data_blocks : 1;
 		if (error)
diff --git a/fs/gfs2/meta_io.c b/fs/gfs2/meta_io.c
index e137d96..0448524 100644
--- a/fs/gfs2/meta_io.c
+++ b/fs/gfs2/meta_io.c
@@ -124,7 +124,7 @@ struct buffer_head *gfs2_getbuf(struct gfs2_glock *gl, u64 blkno, int create)
 	if (mapping == NULL)
 		mapping = &sdp->sd_aspace;
-	shift = PAGE_CACHE_SHIFT - sdp->sd_sb.sb_bsize_shift;
+	shift = PAGE_SHIFT - sdp->sd_sb.sb_bsize_shift;
 	index = blkno >> shift;             /* convert block to page */
 	bufnum = blkno - (index << shift);  /* block buf index within page */
@@ -154,7 +154,7 @@ struct buffer_head *gfs2_getbuf(struct gfs2_glock *gl, u64 blkno, int create)
 		map_bh(bh, sdp->sd_vfs, blkno);
 	unlock_page(page);
-	page_cache_release(page);
+	put_page(page);
 	return bh;
diff --git a/fs/gfs2/quota.c b/fs/gfs2/quota.c
index a398913..ce7d69a 100644
--- a/fs/gfs2/quota.c
+++ b/fs/gfs2/quota.c
@@ -701,7 +701,7 @@ static int gfs2_write_buf_to_page(struct gfs2_inode *ip, unsigned long index,
 	unsigned to_write = bytes, pg_off = off;
 	int done = 0;
-	blk = index << (PAGE_CACHE_SHIFT - sdp->sd_sb.sb_bsize_shift);
+	blk = index << (PAGE_SHIFT - sdp->sd_sb.sb_bsize_shift);
 	boff = off % bsize;
 	page = find_or_create_page(mapping, index, GFP_NOFS);
@@ -753,13 +753,13 @@ static int gfs2_write_buf_to_page(struct gfs2_inode *ip, unsigned long index,
 	unlock_page(page);
+	put_page(page);
 	return 0;
 unlock_out:
 	unlock_page(page);
+	put_page(page);
 	return -EIO;
@@ -773,13 +773,13 @@ static int gfs2_write_disk_quota(struct gfs2_inode *ip, struct gfs2_quota *qp,
 	nbytes = sizeof(struct gfs2_quota);
-	pg_beg = loc >> PAGE_CACHE_SHIFT;
-	pg_off = loc % PAGE_CACHE_SIZE;
+	pg_beg = loc >> PAGE_SHIFT;
+	pg_off = loc % PAGE_SIZE;
 	/* If the quota straddles a page boundary, split the write in two */
-	if ((pg_off + nbytes) > PAGE_CACHE_SIZE) {
+	if ((pg_off + nbytes) > PAGE_SIZE) {
 		pg_oflow = 1;
-		overflow = (pg_off + nbytes) - PAGE_CACHE_SIZE;
+		overflow = (pg_off + nbytes) - PAGE_SIZE;
 	ptr = qp;
diff --git a/fs/gfs2/rgrp.c b/fs/gfs2/rgrp.c
index 07c0265..99a0bda 100644
--- a/fs/gfs2/rgrp.c
+++ b/fs/gfs2/rgrp.c
@@ -918,9 +918,8 @@ static int read_rindex_entry(struct gfs2_inode *ip)
 		goto fail;
 	rgd->rd_gl->gl_object = rgd;
-	rgd->rd_gl->gl_vm.start = (rgd->rd_addr * bsize) & PAGE_CACHE_MASK;
-	rgd->rd_gl->gl_vm.end = PAGE_CACHE_ALIGN((rgd->rd_addr +
-						  rgd->rd_length) * bsize) - 1;
+	rgd->rd_gl->gl_vm.start = (rgd->rd_addr * bsize) & PAGE_MASK;
+	rgd->rd_gl->gl_vm.end = PAGE_ALIGN((rgd->rd_addr + rgd->rd_length) * bsize) - 1;
 	rgd->rd_rgl = (struct gfs2_rgrp_lvb *)rgd->rd_gl->gl_lksb.sb_lvbptr;
 	rgd->rd_flags &= ~(GFS2_RDF_UPTODATE | GFS2_RDF_PREFERRED);
 	if (rgd->rd_data > sdp->sd_max_rg_data)
diff --git a/fs/hfs/bnode.c b/fs/hfs/bnode.c
index 221719e..d77d844 100644
--- a/fs/hfs/bnode.c
+++ b/fs/hfs/bnode.c
@@ -278,14 +278,14 @@ static struct hfs_bnode *__hfs_bnode_create(struct hfs_btree *tree, u32 cnid)
 	mapping = tree->inode->i_mapping;
 	off = (loff_t)cnid * tree->node_size;
-	block = off >> PAGE_CACHE_SHIFT;
-	node->page_offset = off & ~PAGE_CACHE_MASK;
+	block = off >> PAGE_SHIFT;
+	node->page_offset = off & ~PAGE_MASK;
 	for (i = 0; i < tree->pages_per_bnode; i++) {
 		page = read_mapping_page(mapping, block++, NULL);
 		if (IS_ERR(page))
 			goto fail;
 		if (PageError(page)) {
+			put_page(page);
 			goto fail;
 		node->page[i] = page;
@@ -401,7 +401,7 @@ void hfs_bnode_free(struct hfs_bnode *node)
 	for (i = 0; i < node->tree->pages_per_bnode; i++)
 		if (node->page[i])
-			page_cache_release(node->page[i]);
+			put_page(node->page[i]);
 	kfree(node);
@@ -429,11 +429,11 @@ struct hfs_bnode *hfs_bnode_create(struct hfs_btree *tree, u32 num)
 	pagep = node->page;
 	memset(kmap(*pagep) + node->page_offset, 0,
-	       min((int)PAGE_CACHE_SIZE, (int)tree->node_size));
+	       min((int)PAGE_SIZE, (int)tree->node_size));
 	set_page_dirty(*pagep);
 	kunmap(*pagep);
 	for (i = 1; i < tree->pages_per_bnode; i++) {
-		memset(kmap(*++pagep), 0, PAGE_CACHE_SIZE);
+		memset(kmap(*++pagep), 0, PAGE_SIZE);
 		kunmap(*pagep);
diff --git a/fs/hfs/btree.c b/fs/hfs/btree.c
index 1ab19e6..37cdd95 100644
--- a/fs/hfs/btree.c
+++ b/fs/hfs/btree.c
@@ -116,14 +116,14 @@ struct hfs_btree *hfs_btree_open(struct super_block *sb, u32 id, btree_keycmp ke
 	tree->node_size_shift = ffs(size) - 1;
-	tree->pages_per_bnode = (tree->node_size + PAGE_CACHE_SIZE - 1) >> PAGE_CACHE_SHIFT;
+	tree->pages_per_bnode = (tree->node_size + PAGE_SIZE - 1) >> PAGE_SHIFT;
 	kunmap(page);
+	put_page(page);
 	return tree;
 fail_page:
+	put_page(page);
 free_inode:
 	tree->inode->i_mapping->a_ops = &hfs_aops;
 	iput(tree->inode);
@@ -257,9 +257,9 @@ struct hfs_bnode *hfs_bmap_alloc(struct hfs_btree *tree)
 	off = off16;
 	off += node->page_offset;
-	pagep = node->page + (off >> PAGE_CACHE_SHIFT);
+	pagep = node->page + (off >> PAGE_SHIFT);
 	data = kmap(*pagep);
-	off &= ~PAGE_CACHE_MASK;
+	off &= ~PAGE_MASK;
 	idx = 0;
 	for (;;) {
@@ -279,7 +279,7 @@ struct hfs_bnode *hfs_bmap_alloc(struct hfs_btree *tree)
-			if (++off >= PAGE_CACHE_SIZE) {
+			if (++off >= PAGE_SIZE) {
 				kunmap(*pagep);
 				data = kmap(*++pagep);
 				off = 0;
@@ -302,9 +302,9 @@ struct hfs_bnode *hfs_bmap_alloc(struct hfs_btree *tree)
 		len = hfs_brec_lenoff(node, 0, &off16);
 		off = off16;
@@ -348,9 +348,9 @@ void hfs_bmap_free(struct hfs_bnode *node)
 		len = hfs_brec_lenoff(node, 0, &off);
 	off += node->page_offset + nidx / 8;
-	page = node->page[off >> PAGE_CACHE_SHIFT];
+	page = node->page[off >> PAGE_SHIFT];
 	data = kmap(page);
 	m = 1 << (~nidx & 7);
 	byte = data[off];
 	if (!(byte & m)) {
diff --git a/fs/hfs/inode.c b/fs/hfs/inode.c
index 6686bf3..cb1e5fa 100644
--- a/fs/hfs/inode.c
+++ b/fs/hfs/inode.c
@@ -91,8 +91,8 @@ static int hfs_releasepage(struct page *page, gfp_t mask)
 	if (!tree)
 		return 0;
-	if (tree->node_size >= PAGE_CACHE_SIZE) {
-		nidx = page->index >> (tree->node_size_shift - PAGE_CACHE_SHIFT);
+	if (tree->node_size >= PAGE_SIZE) {
+		nidx = page->index >> (tree->node_size_shift - PAGE_SHIFT);
 		spin_lock(&tree->hash_lock);
 		node = hfs_bnode_findhash(tree, nidx);
 		if (!node)
@@ -105,8 +105,8 @@ static int hfs_releasepage(struct page *page, gfp_t mask)
 		spin_unlock(&tree->hash_lock);
 	} else {
-		nidx = page->index << (PAGE_CACHE_SHIFT - tree->node_size_shift);
-		i = 1 << (PAGE_CACHE_SHIFT - tree->node_size_shift);
+		nidx = page->index << (PAGE_SHIFT - tree->node_size_shift);
+		i = 1 << (PAGE_SHIFT - tree->node_size_shift);
 		do {
 			node = hfs_bnode_findhash(tree, nidx++);
diff --git a/fs/hfsplus/bitmap.c b/fs/hfsplus/bitmap.c
index d2954451..c0ae274 100644
--- a/fs/hfsplus/bitmap.c
+++ b/fs/hfsplus/bitmap.c
@@ -13,7 +13,7 @@
 #include "hfsplus_fs.h"
 #include "hfsplus_raw.h"
-#define PAGE_CACHE_BITS	(PAGE_CACHE_SIZE * 8)
+#define PAGE_CACHE_BITS	(PAGE_SIZE * 8)
 int hfsplus_block_allocate(struct super_block *sb, u32 size,
 		u32 offset, u32 *max)
diff --git a/fs/hfsplus/bnode.c b/fs/hfsplus/bnode.c
index 6392466..ce014ce 100644
--- a/fs/hfsplus/bnode.c
+++ b/fs/hfsplus/bnode.c
@@ -24,16 +24,16 @@ void hfs_bnode_read(struct hfs_bnode *node, void *buf, int off, int len)
 	int l;
-	l = min_t(int, len, PAGE_CACHE_SIZE - off);
+	l = min_t(int, len, PAGE_SIZE - off);
 	memcpy(buf, kmap(*pagep) + off, l);
 	kunmap(*pagep);
 	while ((len -= l) != 0) {
 		buf += l;
-		l = min_t(int, len, PAGE_CACHE_SIZE);
+		l = min_t(int, len, PAGE_SIZE);
 		memcpy(buf, kmap(*++pagep), l);
 		kunmap(*pagep);
@@ -77,17 +77,17 @@ void hfs_bnode_write(struct hfs_bnode *node, void *buf, int off, int len)
 	int l;
 	memcpy(kmap(*pagep) + off, buf, l);
 	kunmap(*pagep);
 		buf += l;
 		memcpy(kmap(*++pagep), buf, l);
 		kunmap(*pagep);
@@ -107,16 +107,16 @@ void hfs_bnode_clear(struct hfs_bnode *node, int off, int len)
 	int l;
 	memset(kmap(*pagep) + off, 0, l);
 	kunmap(*pagep);
 		memset(kmap(*++pagep), 0, l);
 		kunmap(*pagep);
@@ -136,20 +136,20 @@ void hfs_bnode_copy(struct hfs_bnode *dst_node, int dst,
 	tree = src_node->tree;
 	src += src_node->page_offset;
 	dst += dst_node->page_offset;
-	src_page = src_node->page + (src >> PAGE_CACHE_SHIFT);
-	src &= ~PAGE_CACHE_MASK;
-	dst_page = dst_node->page + (dst >> PAGE_CACHE_SHIFT);
-	dst &= ~PAGE_CACHE_MASK;
+	src_page = src_node->page + (src >> PAGE_SHIFT);
+	src &= ~PAGE_MASK;
+	dst_page = dst_node->page + (dst >> PAGE_SHIFT);
+	dst &= ~PAGE_MASK;
 	if (src == dst) {
-		l = min_t(int, len, PAGE_CACHE_SIZE - src);
+		l = min_t(int, len, PAGE_SIZE - src);
 		memcpy(kmap(*dst_page) + src, kmap(*src_page) + src, l);
 		kunmap(*src_page);
 		set_page_dirty(*dst_page);
 		kunmap(*dst_page);
 			memcpy(kmap(*++dst_page), kmap(*++src_page), l);
 			kunmap(*src_page);
@@ -161,12 +161,12 @@ void hfs_bnode_copy(struct hfs_bnode *dst_node, int dst,
 		do {
 			src_ptr = kmap(*src_page) + src;
 			dst_ptr = kmap(*dst_page) + dst;
-			if (PAGE_CACHE_SIZE - src < PAGE_CACHE_SIZE - dst) {
-				l = PAGE_CACHE_SIZE - src;
+			if (PAGE_SIZE - src < PAGE_SIZE - dst) {
+				l = PAGE_SIZE - src;
 				src = 0;
 				dst += l;
 			} else {
-				l = PAGE_CACHE_SIZE - dst;
+				l = PAGE_SIZE - dst;
 				src += l;
 				dst = 0;
@@ -195,11 +195,11 @@ void hfs_bnode_move(struct hfs_bnode *node, int dst, int src, int len)
 	dst += node->page_offset;
 	if (dst > src) {
 		src += len - 1;
-		src_page = node->page + (src >> PAGE_CACHE_SHIFT);
-		src = (src & ~PAGE_CACHE_MASK) + 1;
+		src_page = node->page + (src >> PAGE_SHIFT);
+		src = (src & ~PAGE_MASK) + 1;
 		dst += len - 1;
-		dst_page = node->page + (dst >> PAGE_CACHE_SHIFT);
-		dst = (dst & ~PAGE_CACHE_MASK) + 1;
+		dst_page = node->page + (dst >> PAGE_SHIFT);
+		dst = (dst & ~PAGE_MASK) + 1;
 		if (src == dst) {
 			while (src < len) {
@@ -208,7 +208,7 @@ void hfs_bnode_move(struct hfs_bnode *node, int dst, int src, int len)
 				kunmap(*dst_page);
 				len -= src;
-				src = PAGE_CACHE_SIZE;
+				src = PAGE_SIZE;
 				src_page--;
 				dst_page--;
@@ -226,32 +226,32 @@ void hfs_bnode_move(struct hfs_bnode *node, int dst, int src, int len)
 				if (src < dst) {
 					l = src;
+					src = PAGE_SIZE;
 					dst -= l;
 				} else {
 					l = dst;
 					src -= l;
-					dst = PAGE_CACHE_SIZE;
+					dst = PAGE_SIZE;
 				l = min(len, l);
 				memmove(dst_ptr - l, src_ptr - l, l);
 				kunmap(*src_page);
 				kunmap(*dst_page);
-				if (dst == PAGE_CACHE_SIZE)
+				if (dst == PAGE_SIZE)
 					dst_page--;
 				else
 					src_page--;
 			} while ((len -= l));
 	} else {
 		if (src == dst) {
 			memmove(kmap(*dst_page) + src,
 			kunmap(*src_page);
@@ -259,7 +259,7 @@ void hfs_bnode_move(struct hfs_bnode *node, int dst, int src, int len)
 			kunmap(*dst_page);
 				memmove(kmap(*++dst_page),
 				kunmap(*src_page);
@@ -272,13 +272,13 @@ void hfs_bnode_move(struct hfs_bnode *node, int dst, int src, int len)
 			do {
-						PAGE_CACHE_SIZE - dst) {
+						PAGE_SIZE - dst) {
 					src = 0;
 					dst += l;
 				} else {
 					src += l;
 					dst = 0;
@@ -444,14 +444,14 @@ static struct hfs_bnode *__hfs_bnode_create(struct hfs_btree *tree, u32 cnid)
 	off = (loff_t)cnid << tree->node_size_shift;
 	for (i = 0; i < tree->pages_per_bnode; block++, i++) {
 		page = read_mapping_page(mapping, block, NULL);
 		if (IS_ERR(page))
 			goto fail;
+			put_page(page);
 			goto fail;
@@ -569,7 +569,7 @@ void hfs_bnode_free(struct hfs_bnode *node)
 		if (node->page[i])
 	kfree(node);
@@ -597,11 +597,11 @@ struct hfs_bnode *hfs_bnode_create(struct hfs_btree *tree, u32 num)
 	pagep = node->page;
-	       min_t(int, PAGE_CACHE_SIZE, tree->node_size));
+	       min_t(int, PAGE_SIZE, tree->node_size));
 	kunmap(*pagep);
 		kunmap(*pagep);
diff --git a/fs/hfsplus/btree.c b/fs/hfsplus/btree.c
index 3345c75..d9d1a36 100644
--- a/fs/hfsplus/btree.c
+++ b/fs/hfsplus/btree.c
@@ -236,15 +236,15 @@ struct hfs_btree *hfs_btree_open(struct super_block *sb, u32 id)
-		(tree->node_size + PAGE_CACHE_SIZE - 1) >>
-		PAGE_CACHE_SHIFT;
+		(tree->node_size + PAGE_SIZE - 1) >>
+		PAGE_SHIFT;
 	kunmap(page);
+	put_page(page);
 	return tree;
  fail_page:
+	put_page(page);
  free_inode:
 	tree->inode->i_mapping->a_ops = &hfsplus_aops;
 	iput(tree->inode);
@@ -380,9 +380,9 @@ struct hfs_bnode *hfs_bmap_alloc(struct hfs_btree *tree)
 	off = off16;
 	idx = 0;
 	for (;;) {
@@ -403,7 +403,7 @@ struct hfs_bnode *hfs_bmap_alloc(struct hfs_btree *tree)
 				kunmap(*pagep);
 				off = 0;
@@ -426,9 +426,9 @@ struct hfs_bnode *hfs_bmap_alloc(struct hfs_btree *tree)
 		off = off16;
@@ -475,9 +475,9 @@ void hfs_bmap_free(struct hfs_bnode *node)
 	data = kmap(page);
 	byte = data[off];
 	if (!(byte & m)) {
diff --git a/fs/hfsplus/inode.c b/fs/hfsplus/inode.c
index 1a6394c..b28f398 100644
--- a/fs/hfsplus/inode.c
+++ b/fs/hfsplus/inode.c
@@ -87,9 +87,9 @@ static int hfsplus_releasepage(struct page *page, gfp_t mask)
 	if (!tree)
 		return 0;
-			(tree->node_size_shift - PAGE_CACHE_SHIFT);
+			(tree->node_size_shift - PAGE_SHIFT);
 		if (!node)
@@ -103,8 +103,8 @@ static int hfsplus_releasepage(struct page *page, gfp_t mask)
 	} else {
-			(PAGE_CACHE_SHIFT - tree->node_size_shift);
+			(PAGE_SHIFT - tree->node_size_shift);
 		do {
diff --git a/fs/hfsplus/super.c b/fs/hfsplus/super.c
index 5d54490..c359113 100644
--- a/fs/hfsplus/super.c
+++ b/fs/hfsplus/super.c
@@ -438,7 +438,7 @@ static int hfsplus_fill_super(struct super_block *sb, void *data, int silent)
 	err = -EFBIG;
 	last_fs_block = sbi->total_blocks - 1;
 	last_fs_page = (last_fs_block << sbi->alloc_blksz_shift) >>
-			PAGE_CACHE_SHIFT;
+			PAGE_SHIFT;
 	if ((last_fs_block > (sector_t)(~0ULL) >> (sbi->alloc_blksz_shift - 9)) ||
 	    (last_fs_page > (pgoff_t)(~0ULL))) {
diff --git a/fs/hfsplus/xattr.c b/fs/hfsplus/xattr.c
index ab01530..70e445f 100644
--- a/fs/hfsplus/xattr.c
+++ b/fs/hfsplus/xattr.c
@@ -220,7 +220,7 @@ check_attr_tree_state_again:
 	index = 0;
 	written = 0;
-	for (; written < node_size; index++, written += PAGE_CACHE_SIZE) {
+	for (; written < node_size; index++, written += PAGE_SIZE) {
 		void *kaddr;
 		page = read_mapping_page(mapping, index, NULL);
@@ -231,11 +231,11 @@ check_attr_tree_state_again:
 		kaddr = kmap_atomic(page);
 		memcpy(kaddr, buf + written,
-			min_t(size_t, PAGE_CACHE_SIZE, node_size - written));
+			min_t(size_t, PAGE_SIZE, node_size - written));
+		put_page(page);
 	hfsplus_mark_inode_dirty(attr_file, HFSPLUS_I_ATTR_DIRTY);
diff --git a/fs/hostfs/hostfs_kern.c b/fs/hostfs/hostfs_kern.c
index d1abbee..7016653 100644
--- a/fs/hostfs/hostfs_kern.c
+++ b/fs/hostfs/hostfs_kern.c
@@ -410,12 +410,12 @@ static int hostfs_writepage(struct page *page, struct writeback_control *wbc)
 	struct inode *inode = mapping->host;
 	char *buffer;
 	loff_t base = page_offset(page);
-	int count = PAGE_CACHE_SIZE;
-	int end_index = inode->i_size >> PAGE_CACHE_SHIFT;
+	int count = PAGE_SIZE;
+	int end_index = inode->i_size >> PAGE_SHIFT;
 	int err;
 	if (page->index >= end_index)
-		count = inode->i_size & (PAGE_CACHE_SIZE-1);
+		count = inode->i_size & (PAGE_SIZE-1);
 	buffer = kmap(page);
@@ -447,7 +447,7 @@ static int hostfs_readpage(struct file *file, struct page *page)
 	bytes_read = read_file(FILE_HOSTFS_I(file)->fd, &start, buffer,
-			PAGE_CACHE_SIZE);
+			PAGE_SIZE);
 	if (bytes_read < 0) {
 		ClearPageUptodate(page);
 		SetPageError(page);
@@ -455,7 +455,7 @@ static int hostfs_readpage(struct file *file, struct page *page)
 		goto out;
-	memset(buffer + bytes_read, 0, PAGE_CACHE_SIZE - bytes_read);
+	memset(buffer + bytes_read, 0, PAGE_SIZE - bytes_read);
 	ClearPageError(page);
@@ -471,7 +471,7 @@ static int hostfs_write_begin(struct file *file, struct address_space *mapping,
 	*pagep = grab_cache_page_write_begin(mapping, index, flags);
 	if (!*pagep)
@@ -485,14 +485,14 @@ static int hostfs_write_end(struct file *file, struct address_space *mapping,
 	void *buffer;
 	int err;
 	err = write_file(FILE_HOSTFS_I(file)->fd, &pos, buffer + from, copied);
 	kunmap(page);
-	if (!PageUptodate(page) && err == PAGE_CACHE_SIZE)
+	if (!PageUptodate(page) && err == PAGE_SIZE)
@@ -502,7 +502,7 @@ static int hostfs_write_end(struct file *file, struct address_space *mapping,
 	if (err > 0 && (pos > inode->i_size))
 		inode->i_size = pos;
 	unlock_page(page);
+	put_page(page);
 	return err;
diff --git a/fs/hugetlbfs/inode.c b/fs/hugetlbfs/inode.c
index e1f465a..afb7c7f 100644
--- a/fs/hugetlbfs/inode.c
+++ b/fs/hugetlbfs/inode.c
@@ -213,12 +213,12 @@ hugetlbfs_read_actor(struct page *page, unsigned long offset,
 	int i, chunksize;
 	/* Find which 4k chunk and offset with in that chunk */
-	i = offset >> PAGE_CACHE_SHIFT;
-	offset = offset & ~PAGE_CACHE_MASK;
+	i = offset >> PAGE_SHIFT;
+	offset = offset & ~PAGE_MASK;
 	while (size) {
 		size_t n;
-		chunksize = PAGE_CACHE_SIZE;
+		chunksize = PAGE_SIZE;
 		if (offset)
 			chunksize -= offset;
 		if (chunksize > size)
@@ -285,7 +285,7 @@ static ssize_t hugetlbfs_read_iter(struct kiocb *iocb, struct iov_iter *to)
 			 * We have the page, copy it to user space buffer.
 			copied = hugetlbfs_read_actor(page, offset, to, nr);
+			put_page(page);
 		offset += copied;
 		retval += copied;
diff --git a/fs/isofs/compress.c b/fs/isofs/compress.c
index f311bf0..2e4e834 100644
--- a/fs/isofs/compress.c
+++ b/fs/isofs/compress.c
@@ -26,7 +26,7 @@
 #include "zisofs.h"
 /* This should probably be global. */
-static char zisofs_sink_page[PAGE_CACHE_SIZE];
+static char zisofs_sink_page[PAGE_SIZE];
  * This contains the zlib memory allocation and the mutex for the
@@ -70,11 +70,11 @@ static loff_t zisofs_uncompress_block(struct inode *inode, loff_t block_start,
 		for ( i = 0 ; i < pcount ; i++ ) {
 			if (!pages[i])
 				continue;
-			memset(page_address(pages[i]), 0, PAGE_CACHE_SIZE);
+			memset(page_address(pages[i]), 0, PAGE_SIZE);
 			flush_dcache_page(pages[i]);
 			SetPageUptodate(pages[i]);
-		return ((loff_t)pcount) << PAGE_CACHE_SHIFT;
+		return ((loff_t)pcount) << PAGE_SHIFT;
 	/* Because zlib is not thread-safe, do all the I/O at the top. */
@@ -121,11 +121,11 @@ static loff_t zisofs_uncompress_block(struct inode *inode, loff_t block_start,
 			if (pages[curpage]) {
 				stream.next_out = page_address(pages[curpage])
 						+ poffset;
-				stream.avail_out = PAGE_CACHE_SIZE - poffset;
+				stream.avail_out = PAGE_SIZE - poffset;
 				poffset = 0;
 			} else {
 				stream.next_out = (void *)&zisofs_sink_page;
-				stream.avail_out = PAGE_CACHE_SIZE;
+				stream.avail_out = PAGE_SIZE;
 		if (!stream.avail_in) {
@@ -220,14 +220,14 @@ static int zisofs_fill_pages(struct inode *inode, int full_page, int pcount,
 	 * pages with the data we have anyway...
 	start_off = page_offset(pages[full_page]);
-	end_off = min_t(loff_t, start_off + PAGE_CACHE_SIZE, inode->i_size);
+	end_off = min_t(loff_t, start_off + PAGE_SIZE, inode->i_size);
 	cstart_block = start_off >> zisofs_block_shift;
 	cend_block = (end_off + (1 << zisofs_block_shift) - 1)
 			>> zisofs_block_shift;
-	WARN_ON(start_off - (full_page << PAGE_CACHE_SHIFT) !=
-		((cstart_block << zisofs_block_shift) & PAGE_CACHE_MASK));
+	WARN_ON(start_off - (full_page << PAGE_SHIFT) !=
+		((cstart_block << zisofs_block_shift) & PAGE_MASK));
 	/* Find the pointer to this specific chunk */
 	/* Note: we're not using isonum_731() here because the data is known aligned */
@@ -260,10 +260,10 @@ static int zisofs_fill_pages(struct inode *inode, int full_page, int pcount,
 		ret = zisofs_uncompress_block(inode, block_start, block_end,
 					      pcount, pages, poffset, &err);
 		poffset += ret;
-		pages += poffset >> PAGE_CACHE_SHIFT;
-		pcount -= poffset >> PAGE_CACHE_SHIFT;
-		full_page -= poffset >> PAGE_CACHE_SHIFT;
-		poffset &= ~PAGE_CACHE_MASK;
+		pages += poffset >> PAGE_SHIFT;
+		pcount -= poffset >> PAGE_SHIFT;
+		full_page -= poffset >> PAGE_SHIFT;
+		poffset &= ~PAGE_MASK;
 		if (err) {
 			brelse(bh);
@@ -282,7 +282,7 @@ static int zisofs_fill_pages(struct inode *inode, int full_page, int pcount,
 	if (poffset && *pages) {
 		memset(page_address(*pages) + poffset, 0,
-		       PAGE_CACHE_SIZE - poffset);
+		       PAGE_SIZE - poffset);
 		flush_dcache_page(*pages);
 		SetPageUptodate(*pages);
@@ -302,12 +302,12 @@ static int zisofs_readpage(struct file *file, struct page *page)
 	int i, pcount, full_page;
 	unsigned int zisofs_block_shift = ISOFS_I(inode)->i_format_parm[1];
 	unsigned int zisofs_pages_per_cblock =
-		PAGE_CACHE_SHIFT <= zisofs_block_shift ?
-		(1 << (zisofs_block_shift - PAGE_CACHE_SHIFT)) : 0;
+		PAGE_SHIFT <= zisofs_block_shift ?
+		(1 << (zisofs_block_shift - PAGE_SHIFT)) : 0;
 	struct page *pages[max_t(unsigned, zisofs_pages_per_cblock, 1)];
 	pgoff_t index = page->index, end_index;
-	end_index = (inode->i_size + PAGE_CACHE_SIZE - 1) >> PAGE_CACHE_SHIFT;
+	end_index = (inode->i_size + PAGE_SIZE - 1) >> PAGE_SHIFT;
 	 * If this page is wholly outside i_size we just return zero;
 	 * do_generic_file_read() will handle this for us
@@ -318,7 +318,7 @@ static int zisofs_readpage(struct file *file, struct page *page)
 		return 0;
-	if (PAGE_CACHE_SHIFT <= zisofs_block_shift) {
+	if (PAGE_SHIFT <= zisofs_block_shift) {
 		/* We have already been given one page, this is the one
 		   we must do. */
 		full_page = index & (zisofs_pages_per_cblock - 1);
@@ -351,7 +351,7 @@ static int zisofs_readpage(struct file *file, struct page *page)
 			kunmap(pages[i]);
 			unlock_page(pages[i]);
 			if (i != full_page)
-				page_cache_release(pages[i]);
+				put_page(pages[i]);
diff --git a/fs/isofs/inode.c b/fs/isofs/inode.c
index bcd2d41..131dedc 100644
--- a/fs/isofs/inode.c
+++ b/fs/isofs/inode.c
@@ -1021,7 +1021,7 @@ int isofs_get_blocks(struct inode *inode, sector_t iblock,
 		 * the page with useless information without generating any
 		 * I/O errors.
-		if (b_off > ((inode->i_size + PAGE_CACHE_SIZE - 1) >> ISOFS_BUFFER_BITS(inode))) {
+		if (b_off > ((inode->i_size + PAGE_SIZE - 1) >> ISOFS_BUFFER_BITS(inode))) {
 			printk(KERN_DEBUG "%s: block >= EOF (%lu, %llu)\n",
 				__func__, b_off,
 				(unsigned long long)inode->i_size);
diff --git a/fs/jbd2/commit.c b/fs/jbd2/commit.c
index 517f2de..2ad98d6 100644
--- a/fs/jbd2/commit.c
+++ b/fs/jbd2/commit.c
@@ -81,11 +81,11 @@ static void release_buffer_page(struct buffer_head *bh)
 	if (!trylock_page(page))
 		goto nope;
+	get_page(page);
 	__brelse(bh);
 	try_to_free_buffers(page);
 	unlock_page(page);
+	put_page(page);
 	return;
 nope:
diff --git a/fs/jbd2/journal.c b/fs/jbd2/journal.c
index de73a95..435f0b2 100644
--- a/fs/jbd2/journal.c
+++ b/fs/jbd2/journal.c
@@ -2221,7 +2221,7 @@ void jbd2_journal_ack_err(journal_t *journal)
 int jbd2_journal_blocks_per_page(struct inode *inode)
-	return 1 << (PAGE_CACHE_SHIFT - inode->i_sb->s_blocksize_bits);
+	return 1 << (PAGE_SHIFT - inode->i_sb->s_blocksize_bits);
diff --git a/fs/jbd2/transaction.c b/fs/jbd2/transaction.c
index 01e4652d..67c1038 100644
--- a/fs/jbd2/transaction.c
+++ b/fs/jbd2/transaction.c
@@ -2263,7 +2263,7 @@ int jbd2_journal_invalidatepage(journal_t *journal,
 	struct buffer_head *head, *bh, *next;
 	unsigned int curr_off = 0;
 	int may_free = 1;
 	int ret = 0;
@@ -2272,7 +2272,7 @@ int jbd2_journal_invalidatepage(journal_t *journal,
 		return 0;
-	BUG_ON(stop > PAGE_CACHE_SIZE || stop < length);
+	BUG_ON(stop > PAGE_SIZE || stop < length);
 	/* We will potentially be playing with lists other than just the
 	 * data lists (especially for journaled data mode), so be
diff --git a/fs/jffs2/debug.c b/fs/jffs2/debug.c
index 1090eb6..9d26b1b9 100644
--- a/fs/jffs2/debug.c
+++ b/fs/jffs2/debug.c
@@ -95,15 +95,15 @@ __jffs2_dbg_fragtree_paranoia_check_nolock(struct jffs2_inode_info *f)
 			   rather than mucking around with actually reading the node
 			   and checking the compression type, which is the real way
 			   to tell a hole node. */
-			if (frag->ofs & (PAGE_CACHE_SIZE-1) && frag_prev(frag)
-					&& frag_prev(frag)->size < PAGE_CACHE_SIZE && frag_prev(frag)->node) {
+			if (frag->ofs & (PAGE_SIZE-1) && frag_prev(frag)
+					&& frag_prev(frag)->size < PAGE_SIZE && frag_prev(frag)->node) {
 				JFFS2_ERROR("REF_PRISTINE node at 0x%08x had a previous non-hole frag in the same page. Tell dwmw2.\n",
 					ref_offset(fn->raw));
 				bitched = 1;
-			if ((frag->ofs+frag->size) & (PAGE_CACHE_SIZE-1) && frag_next(frag)
-					&& frag_next(frag)->size < PAGE_CACHE_SIZE && frag_next(frag)->node) {
+			if ((frag->ofs+frag->size) & (PAGE_SIZE-1) && frag_next(frag)
+					&& frag_next(frag)->size < PAGE_SIZE && frag_next(frag)->node) {
 				JFFS2_ERROR("REF_PRISTINE node at 0x%08x (%08x-%08x) had a following non-hole frag in the same page. Tell dwmw2.\n",
 				       ref_offset(fn->raw), frag->ofs, frag->ofs+frag->size);
 				bitched = 1;
diff --git a/fs/jffs2/file.c b/fs/jffs2/file.c
index cad86ba..0e62dec 100644
--- a/fs/jffs2/file.c
+++ b/fs/jffs2/file.c
@@ -87,14 +87,15 @@ static int jffs2_do_readpage_nolock (struct inode *inode, struct page *pg)
 	int ret;
 	jffs2_dbg(2, "%s(): ino #%lu, page at offset 0x%lx\n",
-		  __func__, inode->i_ino, pg->index << PAGE_CACHE_SHIFT);
+		  __func__, inode->i_ino, pg->index << PAGE_SHIFT);
 	BUG_ON(!PageLocked(pg));
 	pg_buf = kmap(pg);
 	/* FIXME: Can kmap fail? */
-	ret = jffs2_read_inode_range(c, f, pg_buf, pg->index << PAGE_CACHE_SHIFT, PAGE_CACHE_SIZE);
+	ret = jffs2_read_inode_range(c, f, pg_buf, pg->index << PAGE_SHIFT,
+				     PAGE_SIZE);
 	if (ret) {
 		ClearPageUptodate(pg);
@@ -137,8 +138,8 @@ static int jffs2_write_begin(struct file *filp, struct address_space *mapping,
 	struct page *pg;
 	struct jffs2_inode_info *f = JFFS2_INODE_INFO(inode);
-	uint32_t pageofs = index << PAGE_CACHE_SHIFT;
+	uint32_t pageofs = index << PAGE_SHIFT;
 	int ret = 0;
 	pg = grab_cache_page_write_begin(mapping, index, flags);
@@ -230,7 +231,7 @@ static int jffs2_write_begin(struct file *filp, struct address_space *mapping,
 out_page:
 	unlock_page(pg);
-	page_cache_release(pg);
+	put_page(pg);
 	return ret;
@@ -245,14 +246,14 @@ static int jffs2_write_end(struct file *filp, struct address_space *mapping,
 	struct jffs2_sb_info *c = JFFS2_SB_INFO(inode->i_sb);
 	struct jffs2_raw_inode *ri;
-	unsigned start = pos & (PAGE_CACHE_SIZE - 1);
+	unsigned start = pos & (PAGE_SIZE - 1);
 	unsigned end = start + copied;
 	unsigned aligned_start = start & ~3;
 	int ret = 0;
 	uint32_t writtenlen = 0;
 	jffs2_dbg(1, "%s(): ino #%lu, page at 0x%lx, range %d-%d, flags %lx\n",
-		  __func__, inode->i_ino, pg->index << PAGE_CACHE_SHIFT,
+		  __func__, inode->i_ino, pg->index << PAGE_SHIFT,
 		  start, end, pg->flags);
 	/* We need to avoid deadlock with page_cache_read() in
@@ -261,7 +262,7 @@ static int jffs2_write_end(struct file *filp, struct address_space *mapping,
 	   to re-lock it. */
 	BUG_ON(!PageUptodate(pg));
-	if (end == PAGE_CACHE_SIZE) {
+	if (end == PAGE_SIZE) {
 		/* When writing out the end of a page, write out the
 		   _whole_ page. This helps to reduce the number of
 		   nodes in files which have many short writes, like
@@ -275,7 +276,7 @@ static int jffs2_write_end(struct file *filp, struct address_space *mapping,
 		jffs2_dbg(1, "%s(): Allocation of raw inode failed\n",
 			  __func__);
 		unlock_page(pg);
+		put_page(pg);
 		return -ENOMEM;
@@ -292,7 +293,7 @@ static int jffs2_write_end(struct file *filp, struct address_space *mapping,
 	kmap(pg);
 	ret = jffs2_write_inode_range(c, f, ri, page_address(pg) + aligned_start,
-				      (pg->index << PAGE_CACHE_SHIFT) + aligned_start,
+				      (pg->index << PAGE_SHIFT) + aligned_start,
 				      end - aligned_start, &writtenlen);
 	kunmap(pg);
@@ -329,6 +330,6 @@ static int jffs2_write_end(struct file *filp, struct address_space *mapping,
 	jffs2_dbg(1, "%s() returning %d\n",
 		  __func__, writtenlen > 0 ? writtenlen : ret);
 	unlock_page(pg);
+	put_page(pg);
 	return writtenlen > 0 ? writtenlen : ret;
diff --git a/fs/jffs2/fs.c b/fs/jffs2/fs.c
index bead25a..ae2ebb2 100644
--- a/fs/jffs2/fs.c
+++ b/fs/jffs2/fs.c
@@ -586,8 +586,8 @@ int jffs2_do_fill_super(struct super_block *sb, void *data, int silent)
 		goto out_root;
 	sb->s_maxbytes = 0xFFFFFFFF;
 	sb->s_magic = JFFS2_SUPER_MAGIC;
 	if (!(sb->s_flags & MS_RDONLY))
 		jffs2_start_garbage_collect_thread(c);
@@ -685,7 +685,7 @@ unsigned char *jffs2_gc_fetch_page(struct jffs2_sb_info *c,
 	struct inode *inode = OFNI_EDONI_2SFFJ(f);
 	struct page *pg;
-	pg = read_cache_page(inode->i_mapping, offset >> PAGE_CACHE_SHIFT,
+	pg = read_cache_page(inode->i_mapping, offset >> PAGE_SHIFT,
 			     (void *)jffs2_do_readpage_unlock, inode);
 	if (IS_ERR(pg))
 		return (void *)pg;
@@ -701,7 +701,7 @@ void jffs2_gc_release_page(struct jffs2_sb_info *c,
 	struct page *pg = (void *)*priv;
 	kunmap(pg);
+	put_page(pg);
 static int jffs2_flash_setup(struct jffs2_sb_info *c) {
diff --git a/fs/jffs2/gc.c b/fs/jffs2/gc.c
index 7e553f2..9ed0f26 100644
--- a/fs/jffs2/gc.c
+++ b/fs/jffs2/gc.c
@@ -552,7 +552,7 @@ static int jffs2_garbage_collect_live(struct jffs2_sb_info *c,  struct jffs2_era
 				goto upnout;
 		/* We found a datanode. Do the GC */
-		if((start >> PAGE_CACHE_SHIFT) < ((end-1) >> PAGE_CACHE_SHIFT)) {
+		if((start >> PAGE_SHIFT) < ((end-1) >> PAGE_SHIFT)) {
 			/* It crosses a page boundary. Therefore, it must be a hole. */
 			ret = jffs2_garbage_collect_hole(c, jeb, f, fn, start, end);
 		} else {
@@ -1192,8 +1192,8 @@ static int jffs2_garbage_collect_dnode(struct jffs2_sb_info *c, struct jffs2_era
 		struct jffs2_node_frag *frag;
 		uint32_t min, max;
-		min = start & ~(PAGE_CACHE_SIZE-1);
-		max = min + PAGE_CACHE_SIZE;
+		min = start & ~(PAGE_SIZE-1);
+		max = min + PAGE_SIZE;
 		frag = jffs2_lookup_node_frag(&f->fragtree, start);
@@ -1351,7 +1351,7 @@ static int jffs2_garbage_collect_dnode(struct jffs2_sb_info *c, struct jffs2_era
 		cdatalen = min_t(uint32_t, alloclen - sizeof(ri), end - offset);
 		datalen = end - offset;
-		writebuf = pg_ptr + (offset & (PAGE_CACHE_SIZE -1));
+		writebuf = pg_ptr + (offset & (PAGE_SIZE -1));
 		comprtype = jffs2_compress(c, f, writebuf, &comprbuf, &datalen, &cdatalen);
diff --git a/fs/jffs2/nodelist.c b/fs/jffs2/nodelist.c
index 9a5449b..b86c78d 100644
--- a/fs/jffs2/nodelist.c
+++ b/fs/jffs2/nodelist.c
@@ -90,7 +90,7 @@ uint32_t jffs2_truncate_fragtree(struct jffs2_sb_info *c, struct rb_root *list,
 	/* If the last fragment starts at the RAM page boundary, it is
 	 * REF_PRISTINE irrespective of its size. */
-	if (frag->node && (frag->ofs & (PAGE_CACHE_SIZE - 1)) == 0) {
+	if (frag->node && (frag->ofs & (PAGE_SIZE - 1)) == 0) {
 		dbg_fragtree2("marking the last fragment 0x%08x-0x%08x REF_PRISTINE.\n",
 			frag->ofs, frag->ofs + frag->size);
 		frag->node->raw->flash_offset = ref_offset(frag->node->raw) | REF_PRISTINE;
@@ -237,7 +237,7 @@ static int jffs2_add_frag_to_fragtree(struct jffs2_sb_info *c, struct rb_root *r
 		   If so, both 'this' and the new node get marked REF_NORMAL so
 		   the GC can take a look.
-		if (lastend && (lastend-1) >> PAGE_CACHE_SHIFT == newfrag->ofs >> PAGE_CACHE_SHIFT) {
+		if (lastend && (lastend-1) >> PAGE_SHIFT == newfrag->ofs >> PAGE_SHIFT) {
 			if (this->node)
 				mark_ref_normal(this->node->raw);
 			mark_ref_normal(newfrag->node->raw);
@@ -382,7 +382,7 @@ int jffs2_add_full_dnode_to_inode(struct jffs2_sb_info *c, struct jffs2_inode_in
 	/* If we now share a page with other nodes, mark either previous
 	   or next node REF_NORMAL, as appropriate.  */
-	if (newfrag->ofs & (PAGE_CACHE_SIZE-1)) {
+	if (newfrag->ofs & (PAGE_SIZE-1)) {
 		struct jffs2_node_frag *prev = frag_prev(newfrag);
 		mark_ref_normal(fn->raw);
@@ -391,7 +391,7 @@ int jffs2_add_full_dnode_to_inode(struct jffs2_sb_info *c, struct jffs2_inode_in
 			mark_ref_normal(prev->node->raw);
-	if ((newfrag->ofs+newfrag->size) & (PAGE_CACHE_SIZE-1)) {
+	if ((newfrag->ofs+newfrag->size) & (PAGE_SIZE-1)) {
 		struct jffs2_node_frag *next = frag_next(newfrag);
 		if (next) {
diff --git a/fs/jffs2/write.c b/fs/jffs2/write.c
index b634de4c..7fb187a 100644
--- a/fs/jffs2/write.c
+++ b/fs/jffs2/write.c
@@ -172,8 +172,8 @@ struct jffs2_full_dnode *jffs2_write_dnode(struct jffs2_sb_info *c, struct jffs2
 	   beginning of a page and runs to the end of the file, or if
 	   it's a hole node, mark it REF_PRISTINE, else REF_NORMAL.
-	if ((je32_to_cpu(ri->dsize) >= PAGE_CACHE_SIZE) ||
-	    ( ((je32_to_cpu(ri->offset)&(PAGE_CACHE_SIZE-1))==0) &&
+	if ((je32_to_cpu(ri->dsize) >= PAGE_SIZE) ||
+	    ( ((je32_to_cpu(ri->offset)&(PAGE_SIZE-1))==0) &&
 	      (je32_to_cpu(ri->dsize)+je32_to_cpu(ri->offset) ==  je32_to_cpu(ri->isize)))) {
 		flash_ofs |= REF_PRISTINE;
 	} else {
@@ -366,7 +366,8 @@ int jffs2_write_inode_range(struct jffs2_sb_info *c, struct jffs2_inode_info *f,
 			break;
 		mutex_lock(&f->sem);
-		datalen = min_t(uint32_t, writelen, PAGE_CACHE_SIZE - (offset & (PAGE_CACHE_SIZE-1)));
+		datalen = min_t(uint32_t, writelen,
+				PAGE_SIZE - (offset & (PAGE_SIZE-1)));
 		cdatalen = min_t(uint32_t, alloclen - sizeof(*ri), datalen);
 		comprtype = jffs2_compress(c, f, buf, &comprbuf, &datalen, &cdatalen);
diff --git a/fs/jfs/jfs_metapage.c b/fs/jfs/jfs_metapage.c
index a3eb316..b60e015 100644
--- a/fs/jfs/jfs_metapage.c
+++ b/fs/jfs/jfs_metapage.c
@@ -80,7 +80,7 @@ static inline void lock_metapage(struct metapage *mp)
 static struct kmem_cache *metapage_cache;
 static mempool_t *metapage_mempool;
-#define MPS_PER_PAGE (PAGE_CACHE_SIZE >> L2PSIZE)
+#define MPS_PER_PAGE (PAGE_SIZE >> L2PSIZE)
 #if MPS_PER_PAGE > 1
@@ -316,7 +316,7 @@ static void last_write_complete(struct page *page)
 	struct metapage *mp;
 	unsigned int offset;
-	for (offset = 0; offset < PAGE_CACHE_SIZE; offset += PSIZE) {
+	for (offset = 0; offset < PAGE_SIZE; offset += PSIZE) {
 		mp = page_to_mp(page, offset);
 		if (mp && test_bit(META_io, &mp->flag)) {
 			if (mp->lsn)
@@ -366,12 +366,12 @@ static int metapage_writepage(struct page *page, struct writeback_control *wbc)
 	int bad_blocks = 0;
 	page_start = (sector_t)page->index <<
-		     (PAGE_CACHE_SHIFT - inode->i_blkbits);
+		     (PAGE_SHIFT - inode->i_blkbits);
 	BUG_ON(!PageLocked(page));
 	BUG_ON(PageWriteback(page));
 	set_page_writeback(page);
 		if (!mp || !test_bit(META_dirty, &mp->flag))
@@ -416,7 +416,7 @@ static int metapage_writepage(struct page *page, struct writeback_control *wbc)
 			bio = NULL;
 		} else
 			inc_io(page);
-		xlen = (PAGE_CACHE_SIZE - offset) >> inode->i_blkbits;
+		xlen = (PAGE_SIZE - offset) >> inode->i_blkbits;
 		pblock = metapage_get_blocks(inode, lblock, &xlen);
 		if (!pblock) {
 			printk(KERN_ERR "JFS: metapage_get_blocks failed\n");
@@ -485,7 +485,7 @@ static int metapage_readpage(struct file *fp, struct page *page)
 	struct bio *bio = NULL;
 	int block_offset;
-	int blocks_per_page = PAGE_CACHE_SIZE >> inode->i_blkbits;
+	int blocks_per_page = PAGE_SIZE >> inode->i_blkbits;
 	sector_t page_start;	/* address of page in fs blocks */
 	sector_t pblock;
 	int xlen;
@@ -494,7 +494,7 @@ static int metapage_readpage(struct file *fp, struct page *page)
 	block_offset = 0;
 	while (block_offset < blocks_per_page) {
@@ -542,7 +542,7 @@ static int metapage_releasepage(struct page *page, gfp_t gfp_mask)
 	int ret = 1;
 	int offset;
 		if (!mp)
@@ -568,7 +568,7 @@ static int metapage_releasepage(struct page *page, gfp_t gfp_mask)
 static void metapage_invalidatepage(struct page *page, unsigned int offset,
 				    unsigned int length)
-	BUG_ON(offset || length < PAGE_CACHE_SIZE);
+	BUG_ON(offset || length < PAGE_SIZE);
@@ -599,10 +599,10 @@ struct metapage *__get_metapage(struct inode *inode, unsigned long lblock,
 		 inode->i_ino, lblock, absolute);
 	l2bsize = inode->i_blkbits;
-	l2BlocksPerPage = PAGE_CACHE_SHIFT - l2bsize;
+	l2BlocksPerPage = PAGE_SHIFT - l2bsize;
 	page_index = lblock >> l2BlocksPerPage;
 	page_offset = (lblock - (page_index << l2BlocksPerPage)) << l2bsize;
-	if ((page_offset + size) > PAGE_CACHE_SIZE) {
+	if ((page_offset + size) > PAGE_SIZE) {
 		jfs_err("MetaData crosses page boundary!!");
 		jfs_err("lblock = %lx, size  = %d", lblock, size);
 		dump_stack();
@@ -621,7 +621,7 @@ struct metapage *__get_metapage(struct inode *inode, unsigned long lblock,
 		mapping = inode->i_mapping;
-	if (new && (PSIZE == PAGE_CACHE_SIZE)) {
+	if (new && (PSIZE == PAGE_SIZE)) {
 		page = grab_cache_page(mapping, page_index);
 		if (!page) {
 			jfs_err("grab_cache_page failed!");
@@ -693,7 +693,7 @@ unlock:
 void grab_metapage(struct metapage * mp)
 	jfs_info("grab_metapage: mp = 0x%p", mp);
-	page_cache_get(mp->page);
+	get_page(mp->page);
 	lock_page(mp->page);
 	mp->count++;
 	lock_metapage(mp);
@@ -706,12 +706,12 @@ void force_metapage(struct metapage *mp)
 	jfs_info("force_metapage: mp = 0x%p", mp);
 	set_bit(META_forcewrite, &mp->flag);
 	clear_bit(META_sync, &mp->flag);
+	get_page(page);
 	lock_page(page);
 	set_page_dirty(page);
 	write_one_page(page, 1);
 	clear_bit(META_forcewrite, &mp->flag);
+	put_page(page);
 void hold_metapage(struct metapage *mp)
@@ -726,7 +726,7 @@ void put_metapage(struct metapage *mp)
 		unlock_page(mp->page);
 		return;
 	mp->count++;
 	lock_metapage(mp);
@@ -746,7 +746,7 @@ void release_metapage(struct metapage * mp)
 	assert(mp->count);
 	if (--mp->count || mp->nohomeok) {
 		unlock_page(page);
+		put_page(page);
 		return;
@@ -764,13 +764,13 @@ void release_metapage(struct metapage * mp)
 	drop_metapage(page, mp);
 	unlock_page(page);
+	put_page(page);
 void __invalidate_metapages(struct inode *ip, s64 addr, int len)
 	sector_t lblock;
-	int l2BlocksPerPage = PAGE_CACHE_SHIFT - ip->i_blkbits;
+	int l2BlocksPerPage = PAGE_SHIFT - ip->i_blkbits;
 	int BlocksPerPage = 1 << l2BlocksPerPage;
 	/* All callers are interested in block device's mapping */
@@ -788,7 +788,7 @@ void __invalidate_metapages(struct inode *ip, s64 addr, int len)
 		page = find_lock_page(mapping, lblock >> l2BlocksPerPage);
 		if (!page)
 			continue;
 			if (!mp)
 				continue;
@@ -803,7 +803,7 @@ void __invalidate_metapages(struct inode *ip, s64 addr, int len)
 				remove_from_logsync(mp);
 		unlock_page(page);
+		put_page(page);
diff --git a/fs/jfs/jfs_metapage.h b/fs/jfs/jfs_metapage.h
index 337e9e5..a869fb4 100644
--- a/fs/jfs/jfs_metapage.h
+++ b/fs/jfs/jfs_metapage.h
@@ -106,7 +106,7 @@ static inline void metapage_nohomeok(struct metapage *mp)
 	lock_page(page);
 	if (!mp->nohomeok++) {
 		mark_metapage_dirty(mp);
+		get_page(page);
 		wait_on_page_writeback(page);
 	unlock_page(page);
@@ -128,7 +128,7 @@ static inline void metapage_wait_for_io(struct metapage *mp)
 static inline void _metapage_homeok(struct metapage *mp)
 	if (!--mp->nohomeok)
-		page_cache_release(mp->page);
+		put_page(mp->page);
 static inline void metapage_homeok(struct metapage *mp)
diff --git a/fs/jfs/super.c b/fs/jfs/super.c
index 4f5d85b..78d5991 100644
--- a/fs/jfs/super.c
+++ b/fs/jfs/super.c
@@ -596,7 +596,7 @@ static int jfs_fill_super(struct super_block *sb, void *data, int silent)
 	 * Page cache is indexed by long.
 	 * I would use MAX_LFS_FILESIZE, but it's only half as big
-	sb->s_maxbytes = min(((u64) PAGE_CACHE_SIZE << 32) - 1,
+	sb->s_maxbytes = min(((u64) PAGE_SIZE << 32) - 1,
 			     (u64)sb->s_maxbytes);
 #endif
 	sb->s_time_gran = 1;
diff --git a/fs/kernfs/mount.c b/fs/kernfs/mount.c
index b67dbcc..f73541f 100644
--- a/fs/kernfs/mount.c
+++ b/fs/kernfs/mount.c
@@ -138,8 +138,8 @@ static int kernfs_fill_super(struct super_block *sb, unsigned long magic)
 	struct dentry *root;
 	info->sb = sb;
 	sb->s_magic = magic;
 	sb->s_op = &kernfs_sops;
diff --git a/fs/libfs.c b/fs/libfs.c
index 0ca80b2..f3fa82c 100644
--- a/fs/libfs.c
+++ b/fs/libfs.c
@@ -25,7 +25,7 @@ int simple_getattr(struct vfsmount *mnt, struct dentry *dentry,
 	struct inode *inode = d_inode(dentry);
 	generic_fillattr(inode, stat);
-	stat->blocks = inode->i_mapping->nrpages << (PAGE_CACHE_SHIFT - 9);
+	stat->blocks = inode->i_mapping->nrpages << (PAGE_SHIFT - 9);
 	return 0;
 EXPORT_SYMBOL(simple_getattr);
@@ -33,7 +33,7 @@ EXPORT_SYMBOL(simple_getattr);
 int simple_statfs(struct dentry *dentry, struct kstatfs *buf)
 	buf->f_type = dentry->d_sb->s_magic;
-	buf->f_bsize = PAGE_CACHE_SIZE;
+	buf->f_bsize = PAGE_SIZE;
 	buf->f_namelen = NAME_MAX;
 	return 0;
@@ -395,7 +395,7 @@ int simple_write_begin(struct file *file, struct address_space *mapping,
 	struct page *page;
 	pgoff_t index;
-	index = pos >> PAGE_CACHE_SHIFT;
+	index = pos >> PAGE_SHIFT;
 	page = grab_cache_page_write_begin(mapping, index, flags);
 	if (!page)
@@ -403,10 +403,10 @@ int simple_write_begin(struct file *file, struct address_space *mapping,
 	*pagep = page;
-	if (!PageUptodate(page) && (len != PAGE_CACHE_SIZE)) {
+	if (!PageUptodate(page) && (len != PAGE_SIZE)) {
-		zero_user_segments(page, 0, from, from + len, PAGE_CACHE_SIZE);
+		zero_user_segments(page, 0, from, from + len, PAGE_SIZE);
 	return 0;
@@ -442,7 +442,7 @@ int simple_write_end(struct file *file, struct address_space *mapping,
 	/* zero the stale part of the page if we did a short copy */
 	if (copied < len) {
 		zero_user(page, from + copied, len - copied);
@@ -458,7 +458,7 @@ int simple_write_end(struct file *file, struct address_space *mapping,
 	unlock_page(page);
+	put_page(page);
 	return copied;
@@ -477,8 +477,8 @@ int simple_fill_super(struct super_block *s, unsigned long magic,
 	struct dentry *dentry;
 	int i;
-	s->s_blocksize = PAGE_CACHE_SIZE;
-	s->s_blocksize_bits = PAGE_CACHE_SHIFT;
+	s->s_blocksize = PAGE_SIZE;
+	s->s_blocksize_bits = PAGE_SHIFT;
 	s->s_magic = magic;
 	s->s_op = &simple_super_operations;
 	s->s_time_gran = 1;
@@ -994,12 +994,12 @@ int generic_check_addressable(unsigned blocksize_bits, u64 num_blocks)
 	u64 last_fs_block = num_blocks - 1;
 	u64 last_fs_page =
-		last_fs_block >> (PAGE_CACHE_SHIFT - blocksize_bits);
+		last_fs_block >> (PAGE_SHIFT - blocksize_bits);
 	if (unlikely(num_blocks == 0))
 		return 0;
-	if ((blocksize_bits < 9) || (blocksize_bits > PAGE_CACHE_SHIFT))
+	if ((blocksize_bits < 9) || (blocksize_bits > PAGE_SHIFT))
 		return -EINVAL;
 	if ((last_fs_block > (sector_t)(~0ULL) >> (blocksize_bits - 9)) ||
diff --git a/fs/logfs/dev_bdev.c b/fs/logfs/dev_bdev.c
index a709d80..cc26f8f 100644
--- a/fs/logfs/dev_bdev.c
+++ b/fs/logfs/dev_bdev.c
@@ -64,7 +64,7 @@ static void writeseg_end_io(struct bio *bio)
 	bio_for_each_segment_all(bvec, bio, i) {
 		end_page_writeback(bvec->bv_page);
-		page_cache_release(bvec->bv_page);
+		put_page(bvec->bv_page);
 	bio_put(bio);
 	if (atomic_dec_and_test(&super->s_pending_writes))
diff --git a/fs/logfs/dev_mtd.c b/fs/logfs/dev_mtd.c
index 9c50144..b76a62b 100644
--- a/fs/logfs/dev_mtd.c
+++ b/fs/logfs/dev_mtd.c
@@ -46,9 +46,9 @@ static int loffs_mtd_write(struct super_block *sb, loff_t ofs, size_t len,
 	BUG_ON((ofs >= mtd->size) || (len > mtd->size - ofs));
 	BUG_ON(ofs != (ofs >> super->s_writeshift) << super->s_writeshift);
-	BUG_ON(len > PAGE_CACHE_SIZE);
-	page_start = ofs & PAGE_CACHE_MASK;
-	page_end = PAGE_CACHE_ALIGN(ofs + len) - 1;
+	BUG_ON(len > PAGE_SIZE);
+	page_start = ofs & PAGE_MASK;
+	page_end = PAGE_ALIGN(ofs + len) - 1;
 	ret = mtd_write(mtd, ofs, len, &retlen, buf);
 	if (ret || (retlen != len))
 		return -EIO;
@@ -82,7 +82,7 @@ static int logfs_mtd_erase_mapping(struct super_block *sb, loff_t ofs,
 		if (!page)
 			continue;
 		memset(page_address(page), 0xFF, PAGE_SIZE);
+		put_page(page);
 	return 0;
@@ -195,7 +195,7 @@ static int __logfs_mtd_writeseg(struct super_block *sb, u64 ofs, pgoff_t index,
 		err = loffs_mtd_write(sb, page->index << PAGE_SHIFT, PAGE_SIZE,
 					page_address(page));
 		unlock_page(page);
+		put_page(page);
 		if (err)
 			return err;
diff --git a/fs/logfs/dir.c b/fs/logfs/dir.c
index 542468e..ddbed2b 100644
--- a/fs/logfs/dir.c
+++ b/fs/logfs/dir.c
@@ -183,7 +183,7 @@ static struct page *logfs_get_dd_page(struct inode *dir, struct dentry *dentry)
 		if (name->len != be16_to_cpu(dd->namelen) ||
 				memcmp(name->name, dd->name, name->len)) {
 			kunmap_atomic(dd);
+			put_page(page);
 			continue;
@@ -238,7 +238,7 @@ static int logfs_unlink(struct inode *dir, struct dentry *dentry)
 	index = page->index;
+	put_page(page);
 	mutex_lock(&super->s_dirop_mutex);
 	logfs_add_transaction(dir, ta);
@@ -316,7 +316,7 @@ static int logfs_readdir(struct file *file, struct dir_context *ctx)
 				be16_to_cpu(dd->namelen),
 				be64_to_cpu(dd->ino), dd->type);
 		kunmap(page);
+		put_page(page);
 		if (full)
 			break;
@@ -349,7 +349,7 @@ static struct dentry *logfs_lookup(struct inode *dir, struct dentry *dentry,
 	dd = kmap_atomic(page);
 	ino = be64_to_cpu(dd->ino);
 	kunmap_atomic(dd);
+	put_page(page);
 	inode = logfs_iget(dir->i_sb, ino);
 	if (IS_ERR(inode))
@@ -392,7 +392,7 @@ static int logfs_write_dir(struct inode *dir, struct dentry *dentry,
 		err = logfs_write_buf(dir, page, WF_LOCK);
 		unlock_page(page);
+		put_page(page);
 		if (!err)
 			grow_dir(dir, index);
 		return err;
@@ -561,7 +561,7 @@ static int logfs_get_dd(struct inode *dir, struct dentry *dentry,
 	map = kmap_atomic(page);
 	memcpy(dd, map, sizeof(*dd));
 	kunmap_atomic(map);
+	put_page(page);
 	return 0;
diff --git a/fs/logfs/file.c b/fs/logfs/file.c
index 61eaeb1..f01ddfb 100644
--- a/fs/logfs/file.c
+++ b/fs/logfs/file.c
@@ -15,21 +15,21 @@ static int logfs_write_begin(struct file *file, struct address_space *mapping,
 	struct page *page;
 	if (!page)
 		return -ENOMEM;
 	*pagep = page;
-	if ((len == PAGE_CACHE_SIZE) || PageUptodate(page))
+	if ((len == PAGE_SIZE) || PageUptodate(page))
 		return 0;
-	if ((pos & PAGE_CACHE_MASK) >= i_size_read(inode)) {
+	if ((pos & PAGE_MASK) >= i_size_read(inode)) {
 		unsigned end = start + len;
 		/* Reading beyond i_size is simple: memset to zero */
-		zero_user_segments(page, 0, start, end, PAGE_CACHE_SIZE);
+		zero_user_segments(page, 0, start, end, PAGE_SIZE);
 		return 0;
 	return logfs_readpage_nolock(page);
@@ -41,11 +41,11 @@ static int logfs_write_end(struct file *file, struct address_space *mapping,
 	pgoff_t index = page->index;
 	int ret = 0;
-	BUG_ON(PAGE_CACHE_SIZE != inode->i_sb->s_blocksize);
+	BUG_ON(PAGE_SIZE != inode->i_sb->s_blocksize);
 	BUG_ON(page->index > I3_BLOCKS);
 	if (copied < len) {
@@ -61,8 +61,8 @@ static int logfs_write_end(struct file *file, struct address_space *mapping,
 	if (copied == 0)
 		goto out; /* FIXME: do we need to update inode? */
-	if (i_size_read(inode) < (index << PAGE_CACHE_SHIFT) + end) {
-		i_size_write(inode, (index << PAGE_CACHE_SHIFT) + end);
+	if (i_size_read(inode) < (index << PAGE_SHIFT) + end) {
+		i_size_write(inode, (index << PAGE_SHIFT) + end);
 		mark_inode_dirty_sync(inode);
@@ -75,7 +75,7 @@ static int logfs_write_end(struct file *file, struct address_space *mapping,
 out:
 	unlock_page(page);
+	put_page(page);
 	return ret ? ret : copied;
@@ -118,7 +118,7 @@ static int logfs_writepage(struct page *page, struct writeback_control *wbc)
 	unsigned offset;
 	u64 bix;
 	level_t level;
@@ -142,7 +142,7 @@ static int logfs_writepage(struct page *page, struct writeback_control *wbc)
 		return __logfs_writepage(page);
 	if (bix > end_index || offset == 0) {
 		unlock_page(page);
 		return 0; /* don't care */
@@ -155,7 +155,7 @@ static int logfs_writepage(struct page *page, struct writeback_control *wbc)
 	 * the  page size, the remaining memory is zeroed when mapped, and
 	 * writes to that region are not written out to the file."
-	zero_user_segment(page, offset, PAGE_CACHE_SIZE);
+	zero_user_segment(page, offset, PAGE_SIZE);
diff --git a/fs/logfs/readwrite.c b/fs/logfs/readwrite.c
index 20973c9..3fb8c6d 100644
--- a/fs/logfs/readwrite.c
+++ b/fs/logfs/readwrite.c
@@ -281,7 +281,7 @@ static struct page *logfs_get_read_page(struct inode *inode, u64 bix,
 static void logfs_put_read_page(struct page *page)
 	unlock_page(page);
+	put_page(page);
 static void logfs_lock_write_page(struct page *page)
@@ -323,7 +323,7 @@ repeat:
 			return NULL;
 		err = add_to_page_cache_lru(page, mapping, index, GFP_NOFS);
 		if (unlikely(err)) {
+			put_page(page);
 			if (err == -EEXIST)
 				goto repeat;
 			return NULL;
@@ -342,7 +342,7 @@ static void logfs_unlock_write_page(struct page *page)
 static void logfs_put_write_page(struct page *page)
 	logfs_unlock_write_page(page);
+	put_page(page);
 static struct page *logfs_get_page(struct inode *inode, u64 bix, level_t level,
@@ -562,7 +562,7 @@ static void indirect_free_block(struct super_block *sb,
 	if (PagePrivate(page)) {
 		ClearPagePrivate(page);
+		put_page(page);
 		set_page_private(page, 0);
 	__free_block(sb, block);
@@ -655,7 +655,7 @@ static void alloc_data_block(struct inode *inode, struct page *page)
 	block->page = page;
 	SetPagePrivate(page);
-	page_cache_get(page);
+	get_page(page);
 	set_page_private(page, (unsigned long) block);
 	block->ops = &indirect_block_ops;
@@ -709,7 +709,7 @@ static u64 block_get_pointer(struct page *page, int index)
 static int logfs_read_empty(struct page *page)
-	zero_user_segment(page, 0, PAGE_CACHE_SIZE);
+	zero_user_segment(page, 0, PAGE_SIZE);
 	return 0;
@@ -1660,7 +1660,7 @@ static int truncate_data_block(struct inode *inode, struct page *page,
 	if (err)
 		return err;
-	zero_user_segment(page, size - pageofs, PAGE_CACHE_SIZE);
+	zero_user_segment(page, size - pageofs, PAGE_SIZE);
 	return logfs_segment_write(inode, page, shadow);
@@ -1919,7 +1919,7 @@ static void move_page_to_inode(struct inode *inode, struct page *page)
 	block->page = NULL;
+		put_page(page);
@@ -1940,7 +1940,7 @@ static void move_inode_to_page(struct page *page, struct inode *inode)
 	if (!PagePrivate(page)) {
+		get_page(page);
@@ -1971,7 +1971,7 @@ int logfs_read_inode(struct inode *inode)
 	logfs_disk_to_inode(di, inode);
 	kunmap_atomic(di);
 	move_page_to_inode(inode, page);
+	put_page(page);
 	return 0;
diff --git a/fs/logfs/segment.c b/fs/logfs/segment.c
index d270e4b..1efd605 100644
--- a/fs/logfs/segment.c
+++ b/fs/logfs/segment.c
@@ -90,9 +90,9 @@ int __logfs_buf_write(struct logfs_area *area, u64 ofs, void *buf, size_t len,
+			get_page(page);
+		put_page(page);
 		buf += copylen;
 		len -= copylen;
@@ -117,9 +117,9 @@ static void pad_partial_page(struct logfs_area *area)
 		memset(page_address(page) + offset, 0xff, len);
+			get_page(page);
+		put_page(page);
@@ -129,20 +129,20 @@ static void pad_full_pages(struct logfs_area *area)
 	struct logfs_super *super = logfs_super(sb);
 	u64 ofs = dev_ofs(sb, area->a_segno, area->a_used_bytes);
 	u32 len = super->s_segsize - area->a_used_bytes;
-	pgoff_t index = PAGE_CACHE_ALIGN(ofs) >> PAGE_CACHE_SHIFT;
-	pgoff_t no_indizes = len >> PAGE_CACHE_SHIFT;
+	pgoff_t index = PAGE_ALIGN(ofs) >> PAGE_SHIFT;
+	pgoff_t no_indizes = len >> PAGE_SHIFT;
 	struct page *page;
 	while (no_indizes) {
 		page = get_mapping_page(sb, index, 0);
 		BUG_ON(!page); /* FIXME: reserve a pool */
-		memset(page_address(page), 0xff, PAGE_CACHE_SIZE);
+		memset(page_address(page), 0xff, PAGE_SIZE);
+			get_page(page);
+		put_page(page);
 		index++;
 		no_indizes--;
@@ -411,7 +411,7 @@ int wbuf_read(struct super_block *sb, u64 ofs, size_t len, void *buf)
 		if (IS_ERR(page))
 		memcpy(buf, page_address(page) + offset, copylen);
+		put_page(page);
 		buf += copylen;
 		len -= copylen;
@@ -499,7 +499,7 @@ static void move_btree_to_page(struct inode *inode, struct page *page,
+		get_page(page);
@@ -554,7 +554,7 @@ void move_page_to_btree(struct page *page)
+		put_page(page);
 	block->ops = &btree_block_ops;
@@ -723,9 +723,9 @@ void freeseg(struct super_block *sb, u32 segno)
 			continue;
+			put_page(page);
+		put_page(page);
diff --git a/fs/logfs/super.c b/fs/logfs/super.c
index 5436029..5751082 100644
--- a/fs/logfs/super.c
+++ b/fs/logfs/super.c
@@ -48,7 +48,7 @@ void emergency_read_end(struct page *page)
 	if (page == emergency_page)
 		mutex_unlock(&emergency_mutex);
 	else
+		put_page(page);
 static void dump_segfile(struct super_block *sb)
@@ -206,7 +206,7 @@ static int write_one_sb(struct super_block *sb,
 	logfs_set_segment_erased(sb, segno, ec, 0);
 	logfs_write_ds(sb, ds, segno, ec);
 	err = super->s_devops->write_sb(sb, page);
+	put_page(page);
 	return err;
@@ -366,24 +366,24 @@ static struct page *find_super_block(struct super_block *sb)
 		return NULL;
 	last = super->s_devops->find_last_sb(sb, &super->s_sb_ofs[1]);
 	if (!last || IS_ERR(last)) {
-		page_cache_release(first);
+		put_page(first);
 		return NULL;
 	if (!logfs_check_ds(page_address(first))) {
-		page_cache_release(last);
+		put_page(last);
 		return first;
 	/* First one didn't work, try the second superblock */
 	if (!logfs_check_ds(page_address(last))) {
+		put_page(first);
 		return last;
 	/* Neither worked, sorry folks */
+	put_page(first);
+	put_page(last);
 	return NULL;
@@ -425,7 +425,7 @@ static int __logfs_read_sb(struct super_block *sb)
 	super->s_data_levels = ds->ds_data_levels;
 	super->s_total_levels = super->s_ifile_levels + super->s_iblock_levels
 		+ super->s_data_levels;
+	put_page(page);
 	return 0;
diff --git a/fs/minix/dir.c b/fs/minix/dir.c
index d19ac25..33957c0 100644
--- a/fs/minix/dir.c
+++ b/fs/minix/dir.c
@@ -28,7 +28,7 @@ const struct file_operations minix_dir_operations = {
 static inline void dir_put_page(struct page *page)
 	kunmap(page);
+	put_page(page);
@@ -38,10 +38,10 @@ static inline void dir_put_page(struct page *page)
 static unsigned
 minix_last_byte(struct inode *inode, unsigned long page_nr)
-	unsigned last_byte = PAGE_CACHE_SIZE;
+	unsigned last_byte = PAGE_SIZE;
-	if (page_nr == (inode->i_size >> PAGE_CACHE_SHIFT))
-		last_byte = inode->i_size & (PAGE_CACHE_SIZE - 1);
+	if (page_nr == (inode->i_size >> PAGE_SHIFT))
+		last_byte = inode->i_size & (PAGE_SIZE - 1);
 	return last_byte;
@@ -92,8 +92,8 @@ static int minix_readdir(struct file *file, struct dir_context *ctx)
 	if (pos >= inode->i_size)
 		return 0;
-	offset = pos & ~PAGE_CACHE_MASK;
-	n = pos >> PAGE_CACHE_SHIFT;
+	offset = pos & ~PAGE_MASK;
+	n = pos >> PAGE_SHIFT;
 	for ( ; n < npages; n++, offset = 0) {
 		char *p, *kaddr, *limit;
@@ -229,7 +229,7 @@ int minix_add_link(struct dentry *dentry, struct inode *inode)
 		lock_page(page);
 		kaddr = (char*)page_address(page);
 		dir_end = kaddr + minix_last_byte(dir, n);
-		limit = kaddr + PAGE_CACHE_SIZE - sbi->s_dirsize;
+		limit = kaddr + PAGE_SIZE - sbi->s_dirsize;
 		for (p = kaddr; p <= limit; p = minix_next_entry(p, sbi)) {
 			de = (minix_dirent *)p;
 			de3 = (minix3_dirent *)p;
@@ -327,7 +327,7 @@ int minix_make_empty(struct inode *inode, struct inode *dir)
-	memset(kaddr, 0, PAGE_CACHE_SIZE);
+	memset(kaddr, 0, PAGE_SIZE);
 	if (sbi->s_version == MINIX_V3) {
 		minix3_dirent *de3 = (minix3_dirent *)kaddr;
@@ -350,7 +350,7 @@ int minix_make_empty(struct inode *inode, struct inode *dir)
 	err = dir_commit_chunk(page, 0, 2 * sbi->s_dirsize);
 fail:
+	put_page(page);
 	return err;
diff --git a/fs/minix/namei.c b/fs/minix/namei.c
index a795a11..2887d1d 100644
--- a/fs/minix/namei.c
+++ b/fs/minix/namei.c
@@ -243,11 +243,11 @@ static int minix_rename(struct inode * old_dir, struct dentry *old_dentry,
 out_dir:
 	if (dir_de) {
 		kunmap(dir_page);
-		page_cache_release(dir_page);
+		put_page(dir_page);
 out_old:
 	kunmap(old_page);
-	page_cache_release(old_page);
+	put_page(old_page);
 out:
 	return err;
diff --git a/fs/mpage.c b/fs/mpage.c
index 6bd9fd9..e7083bf 100644
--- a/fs/mpage.c
+++ b/fs/mpage.c
@@ -107,7 +107,7 @@ map_buffer_to_page(struct page *page, struct buffer_head *bh, int page_block)
 		 * don't make any buffers if there is only one buffer on
 		 * the page and the page just needs to be set up to date
-		if (inode->i_blkbits == PAGE_CACHE_SHIFT &&
+		if (inode->i_blkbits == PAGE_SHIFT &&
 		    buffer_uptodate(bh)) {
 			return;
@@ -145,7 +145,7 @@ do_mpage_readpage(struct bio *bio, struct page *page, unsigned nr_pages,
 	const unsigned blkbits = inode->i_blkbits;
-	const unsigned blocks_per_page = PAGE_CACHE_SIZE >> blkbits;
+	const unsigned blocks_per_page = PAGE_SIZE >> blkbits;
 	const unsigned blocksize = 1 << blkbits;
 	sector_t block_in_file;
 	sector_t last_block;
@@ -162,7 +162,7 @@ do_mpage_readpage(struct bio *bio, struct page *page, unsigned nr_pages,
 	if (page_has_buffers(page))
 		goto confused;
-	block_in_file = (sector_t)page->index << (PAGE_CACHE_SHIFT - blkbits);
+	block_in_file = (sector_t)page->index << (PAGE_SHIFT - blkbits);
 	last_block = block_in_file + nr_pages * blocks_per_page;
 	last_block_in_file = (i_size_read(inode) + blocksize - 1) >> blkbits;
 	if (last_block > last_block_in_file)
@@ -249,7 +249,7 @@ do_mpage_readpage(struct bio *bio, struct page *page, unsigned nr_pages,
 	if (first_hole != blocks_per_page) {
-		zero_user_segment(page, first_hole << blkbits, PAGE_CACHE_SIZE);
+		zero_user_segment(page, first_hole << blkbits, PAGE_SIZE);
 		if (first_hole == 0) {
 			unlock_page(page);
@@ -380,7 +380,7 @@ mpage_readpages(struct address_space *mapping, struct list_head *pages,
 					&first_logical_block,
 					get_block, gfp);
+		put_page(page);
 	BUG_ON(!list_empty(pages));
 	if (bio)
@@ -472,7 +472,7 @@ static int __mpage_writepage(struct page *page, struct writeback_control *wbc,
 	unsigned long end_index;
 	sector_t blocks[MAX_BUF_PER_PAGE];
@@ -542,7 +542,7 @@ static int __mpage_writepage(struct page *page, struct writeback_control *wbc,
 	 * The page has no buffers: map it to disk
 	BUG_ON(!PageUptodate(page));
 	last_block = (i_size - 1) >> blkbits;
 	map_bh.b_page = page;
 	for (page_block = 0; page_block < blocks_per_page; ) {
@@ -574,7 +574,7 @@ static int __mpage_writepage(struct page *page, struct writeback_control *wbc,
 	first_unmapped = page_block;
 page_is_mapped:
-	end_index = i_size >> PAGE_CACHE_SHIFT;
+	end_index = i_size >> PAGE_SHIFT;
 	if (page->index >= end_index) {
 		 * The page straddles i_size.  It must be zeroed out on each
@@ -584,11 +584,11 @@ page_is_mapped:
 		 * is zeroed when mapped, and writes to that region are not
 		 * written out to the file."
-		unsigned offset = i_size & (PAGE_CACHE_SIZE - 1);
+		unsigned offset = i_size & (PAGE_SIZE - 1);
 		if (page->index > end_index || !offset)
 			goto confused;
diff --git a/fs/ncpfs/dir.c b/fs/ncpfs/dir.c
index b7f8eae..bfdad00 100644
--- a/fs/ncpfs/dir.c
+++ b/fs/ncpfs/dir.c
@@ -510,7 +510,7 @@ static int ncp_readdir(struct file *file, struct dir_context *ctx)
 			kunmap(ctl.page);
 			SetPageUptodate(ctl.page);
 			unlock_page(ctl.page);
-			page_cache_release(ctl.page);
+			put_page(ctl.page);
 			ctl.page = NULL;
 		ctl.idx  = 0;
@@ -520,7 +520,7 @@ invalid_cache:
 	if (ctl.page) {
 		kunmap(ctl.page);
 		ctl.page = NULL;
 	ctl.cache = cache;
@@ -554,14 +554,14 @@ finished:
 		kunmap(ctl.page);
 	if (page) {
 		cache->head = ctl.head;
 		kunmap(page);
 		SetPageUptodate(page);
 		unlock_page(page);
+		put_page(page);
 out:
 	return result;
@@ -649,7 +649,7 @@ ncp_fill_cache(struct file *file, struct dir_context *ctx,
 			kunmap(ctl.page);
 		ctl.cache = NULL;
 		ctl.idx  -= NCP_DIRCACHE_SIZE;
diff --git a/fs/ncpfs/ncplib_kernel.h b/fs/ncpfs/ncplib_kernel.h
index 5233fbc..17cfb74 100644
--- a/fs/ncpfs/ncplib_kernel.h
+++ b/fs/ncpfs/ncplib_kernel.h
@@ -191,7 +191,7 @@ struct ncp_cache_head {
 	int		eof;
-#define NCP_DIRCACHE_SIZE	((int)(PAGE_CACHE_SIZE/sizeof(struct dentry *)))
+#define NCP_DIRCACHE_SIZE	((int)(PAGE_SIZE/sizeof(struct dentry *)))
 union ncp_dir_cache {
 	struct ncp_cache_head	head;
 	struct dentry		*dentry[NCP_DIRCACHE_SIZE];
diff --git a/fs/nfs/blocklayout/blocklayout.c b/fs/nfs/blocklayout/blocklayout.c
index 02e4d87..17a42e4 100644
--- a/fs/nfs/blocklayout/blocklayout.c
+++ b/fs/nfs/blocklayout/blocklayout.c
@@ -231,7 +231,7 @@ bl_read_pagelist(struct nfs_pgio_header *header)
 	size_t bytes_left = header->args.count;
 	unsigned int pg_offset = header->args.pgbase, pg_len;
 	struct page **pages = header->args.pages;
-	int pg_index = header->args.pgbase >> PAGE_CACHE_SHIFT;
+	int pg_index = header->args.pgbase >> PAGE_SHIFT;
 	const bool is_dio = (header->dreq != NULL);
 	struct blk_plug plug;
 	int i;
@@ -263,13 +263,13 @@ bl_read_pagelist(struct nfs_pgio_header *header)
 		if (is_dio) {
-			if (pg_offset + bytes_left > PAGE_CACHE_SIZE)
-				pg_len = PAGE_CACHE_SIZE - pg_offset;
+			if (pg_offset + bytes_left > PAGE_SIZE)
+				pg_len = PAGE_SIZE - pg_offset;
 			else
 				pg_len = bytes_left;
 		} else {
 			BUG_ON(pg_offset != 0);
-			pg_len = PAGE_CACHE_SIZE;
+			pg_len = PAGE_SIZE;
 		if (is_hole(&be)) {
@@ -339,9 +339,9 @@ static void bl_write_cleanup(struct work_struct *work)
 	if (likely(!hdr->pnfs_error)) {
 		struct pnfs_block_layout *bl = BLK_LSEG2EXT(hdr->lseg);
-		u64 start = hdr->args.offset & (loff_t)PAGE_CACHE_MASK;
+		u64 start = hdr->args.offset & (loff_t)PAGE_MASK;
 		u64 end = (hdr->args.offset + hdr->args.count +
-			PAGE_CACHE_SIZE - 1) & (loff_t)PAGE_CACHE_MASK;
+			PAGE_SIZE - 1) & (loff_t)PAGE_MASK;
 		ext_tree_mark_written(bl, start >> SECTOR_SHIFT,
 					(end - start) >> SECTOR_SHIFT);
@@ -373,7 +373,7 @@ bl_write_pagelist(struct nfs_pgio_header *header, int sync)
 	loff_t offset = header->args.offset;
 	size_t count = header->args.count;
 	unsigned int pg_len;
 	int i;
@@ -392,7 +392,7 @@ bl_write_pagelist(struct nfs_pgio_header *header, int sync)
 	blk_start_plug(&plug);
 	/* we always write out the whole page */
-	offset = offset & (loff_t)PAGE_CACHE_MASK;
+	offset = offset & (loff_t)PAGE_MASK;
 	isect = offset >> SECTOR_SHIFT;
 	for (i = pg_index; i < header->page_array.npages; i++) {
@@ -408,7 +408,7 @@ bl_write_pagelist(struct nfs_pgio_header *header, int sync)
 			extent_length = be.be_length - (isect - be.be_f_offset);
 		bio = do_add_page_to_bio(bio, header->page_array.npages - i,
 					 WRITE, isect, pages[i], &map, &be,
 					 bl_end_io_write, par,
@@ -820,7 +820,7 @@ static u64 pnfs_num_cont_bytes(struct inode *inode, pgoff_t idx)
 	pgoff_t end;
 	/* Optimize common case that writes from 0 to end of file */
-	end = DIV_ROUND_UP(i_size_read(inode), PAGE_CACHE_SIZE);
+	end = DIV_ROUND_UP(i_size_read(inode), PAGE_SIZE);
 	if (end != inode->i_mapping->nrpages) {
 		rcu_read_lock();
 		end = page_cache_next_hole(mapping, idx + 1, ULONG_MAX);
@@ -828,9 +828,9 @@ static u64 pnfs_num_cont_bytes(struct inode *inode, pgoff_t idx)
 	if (!end)
-		return i_size_read(inode) - (idx << PAGE_CACHE_SHIFT);
+		return i_size_read(inode) - (idx << PAGE_SHIFT);
 	else
-		return (end - idx) << PAGE_CACHE_SHIFT;
+		return (end - idx) << PAGE_SHIFT;
 static void
diff --git a/fs/nfs/blocklayout/blocklayout.h b/fs/nfs/blocklayout/blocklayout.h
index bc21205..18e6fd0 100644
--- a/fs/nfs/blocklayout/blocklayout.h
+++ b/fs/nfs/blocklayout/blocklayout.h
@@ -40,8 +40,8 @@
 #include "../pnfs.h"
 #include "../netns.h"
-#define PAGE_CACHE_SECTORS (PAGE_CACHE_SIZE >> SECTOR_SHIFT)
-#define PAGE_CACHE_SECTOR_SHIFT (PAGE_CACHE_SHIFT - SECTOR_SHIFT)
+#define PAGE_CACHE_SECTORS (PAGE_SIZE >> SECTOR_SHIFT)
+#define PAGE_CACHE_SECTOR_SHIFT (PAGE_SHIFT - SECTOR_SHIFT)
 #define SECTOR_SIZE (1 << SECTOR_SHIFT)
 struct pnfs_block_dev;
diff --git a/fs/nfs/client.c b/fs/nfs/client.c
index d6d5d2a..0c96528 100644
--- a/fs/nfs/client.c
+++ b/fs/nfs/client.c
@@ -736,7 +736,7 @@ static void nfs_server_set_fsinfo(struct nfs_server *server,
 		server->rsize = max_rpc_payload;
 	if (server->rsize > NFS_MAX_FILE_IO_SIZE)
 		server->rsize = NFS_MAX_FILE_IO_SIZE;
-	server->rpages = (server->rsize + PAGE_CACHE_SIZE - 1) >> PAGE_CACHE_SHIFT;
+	server->rpages = (server->rsize + PAGE_SIZE - 1) >> PAGE_SHIFT;
 	server->backing_dev_info.name = "nfs";
 	server->backing_dev_info.ra_pages = server->rpages * NFS_MAX_READAHEAD;
@@ -745,13 +745,13 @@ static void nfs_server_set_fsinfo(struct nfs_server *server,
 		server->wsize = max_rpc_payload;
 	if (server->wsize > NFS_MAX_FILE_IO_SIZE)
 		server->wsize = NFS_MAX_FILE_IO_SIZE;
-	server->wpages = (server->wsize + PAGE_CACHE_SIZE - 1) >> PAGE_CACHE_SHIFT;
+	server->wpages = (server->wsize + PAGE_SIZE - 1) >> PAGE_SHIFT;
 	server->wtmult = nfs_block_bits(fsinfo->wtmult, NULL);
 	server->dtsize = nfs_block_size(fsinfo->dtpref, NULL);
-	if (server->dtsize > PAGE_CACHE_SIZE * NFS_MAX_READDIR_PAGES)
-		server->dtsize = PAGE_CACHE_SIZE * NFS_MAX_READDIR_PAGES;
+	if (server->dtsize > PAGE_SIZE * NFS_MAX_READDIR_PAGES)
+		server->dtsize = PAGE_SIZE * NFS_MAX_READDIR_PAGES;
 	if (server->dtsize > server->rsize)
 		server->dtsize = server->rsize;
diff --git a/fs/nfs/dir.c b/fs/nfs/dir.c
index 4bfa7d8..adef506 100644
--- a/fs/nfs/dir.c
+++ b/fs/nfs/dir.c
@@ -707,7 +707,7 @@ void cache_page_release(nfs_readdir_descriptor_t *desc)
 	if (!desc->page->mapping)
 		nfs_readdir_clear_array(desc->page);
-	page_cache_release(desc->page);
+	put_page(desc->page);
 	desc->page = NULL;
@@ -1923,7 +1923,7 @@ int nfs_symlink(struct inode *dir, struct dentry *dentry, const char *symname)
 		 * add_to_page_cache_lru() grabs an extra page refcount.
 		 * Drop it here to avoid leaking this page later.
-		page_cache_release(page);
+		put_page(page);
 	} else
 		__free_page(page);
diff --git a/fs/nfs/direct.c b/fs/nfs/direct.c
index 7a0cfd3..c93826e 100644
--- a/fs/nfs/direct.c
+++ b/fs/nfs/direct.c
@@ -269,7 +269,7 @@ static void nfs_direct_release_pages(struct page **pages, unsigned int npages)
 	unsigned int i;
 	for (i = 0; i < npages; i++)
 void nfs_init_cinfo_from_dreq(struct nfs_commit_info *cinfo,
@@ -1003,7 +1003,7 @@ ssize_t nfs_file_direct_write(struct kiocb *iocb, struct iov_iter *iter)
 		      iov_iter_count(iter));
 	pos = iocb->ki_pos;
-	end = (pos + iov_iter_count(iter) - 1) >> PAGE_CACHE_SHIFT;
+	end = (pos + iov_iter_count(iter) - 1) >> PAGE_SHIFT;
 	inode_lock(inode);
@@ -1013,7 +1013,7 @@ ssize_t nfs_file_direct_write(struct kiocb *iocb, struct iov_iter *iter)
 	if (mapping->nrpages) {
 		result = invalidate_inode_pages2_range(mapping,
-					pos >> PAGE_CACHE_SHIFT, end);
+					pos >> PAGE_SHIFT, end);
 		if (result)
 			goto out_unlock;
@@ -1042,7 +1042,7 @@ ssize_t nfs_file_direct_write(struct kiocb *iocb, struct iov_iter *iter)
 	inode_unlock(inode);
diff --git a/fs/nfs/file.c b/fs/nfs/file.c
index 89bf093..be01095 100644
--- a/fs/nfs/file.c
+++ b/fs/nfs/file.c
@@ -320,7 +320,7 @@ static int nfs_want_read_modify_write(struct file *file, struct page *page,
 			loff_t pos, unsigned len)
 	unsigned int pglen = nfs_page_length(page);
-	unsigned int offset = pos & (PAGE_CACHE_SIZE - 1);
+	unsigned int offset = pos & (PAGE_SIZE - 1);
 	unsigned int end = offset + len;
 	if (pnfs_ld_read_whole_page(file->f_mapping->host)) {
@@ -351,7 +351,7 @@ static int nfs_write_begin(struct file *file, struct address_space *mapping,
 			struct page **pagep, void **fsdata)
 	int ret;
-	pgoff_t index = pos >> PAGE_CACHE_SHIFT;
+	pgoff_t index = pos >> PAGE_SHIFT;
 	struct page *page;
 	int once_thru = 0;
@@ -380,12 +380,12 @@ start:
 	ret = nfs_flush_incompatible(file, page);
 	if (ret) {
 		unlock_page(page);
+		put_page(page);
 	} else if (!once_thru &&
 		   nfs_want_read_modify_write(file, page, pos, len)) {
 		once_thru = 1;
 		ret = nfs_readpage(file, page);
+		put_page(page);
 		if (!ret)
 			goto start;
@@ -396,7 +396,7 @@ static int nfs_write_end(struct file *file, struct address_space *mapping,
 			loff_t pos, unsigned len, unsigned copied,
 			struct page *page, void *fsdata)
-	unsigned offset = pos & (PAGE_CACHE_SIZE - 1);
+	unsigned offset = pos & (PAGE_SIZE - 1);
 	struct nfs_open_context *ctx = nfs_file_open_context(file);
 	int status;
@@ -413,20 +413,20 @@ static int nfs_write_end(struct file *file, struct address_space *mapping,
 		if (pglen == 0) {
 			zero_user_segments(page, 0, offset,
-					end, PAGE_CACHE_SIZE);
+					end, PAGE_SIZE);
 		} else if (end >= pglen) {
-			zero_user_segment(page, end, PAGE_CACHE_SIZE);
+			zero_user_segment(page, end, PAGE_SIZE);
 			if (offset == 0)
 		} else
-			zero_user_segment(page, pglen, PAGE_CACHE_SIZE);
+			zero_user_segment(page, pglen, PAGE_SIZE);
 	status = nfs_updatepage(file, page, offset, copied);
 	unlock_page(page);
+	put_page(page);
 	if (status < 0)
 		return status;
@@ -454,7 +454,7 @@ static void nfs_invalidate_page(struct page *page, unsigned int offset,
 	dfprintk(PAGECACHE, "NFS: invalidate_page(%p, %u, %u)\n",
 		 page, offset, length);
-	if (offset != 0 || length < PAGE_CACHE_SIZE)
+	if (offset != 0 || length < PAGE_SIZE)
 		return;
 	/* Cancel any unstarted writes on this page */
 	nfs_wb_page_cancel(page_file_mapping(page)->host, page);
diff --git a/fs/nfs/internal.h b/fs/nfs/internal.h
index 565f813..f1d1d2c 100644
--- a/fs/nfs/internal.h
+++ b/fs/nfs/internal.h
@@ -638,11 +638,11 @@ unsigned int nfs_page_length(struct page *page)
 	if (i_size > 0) {
 		pgoff_t page_index = page_file_index(page);
-		pgoff_t end_index = (i_size - 1) >> PAGE_CACHE_SHIFT;
+		pgoff_t end_index = (i_size - 1) >> PAGE_SHIFT;
 		if (page_index < end_index)
-			return PAGE_CACHE_SIZE;
+			return PAGE_SIZE;
 		if (page_index == end_index)
-			return ((i_size - 1) & ~PAGE_CACHE_MASK) + 1;
+			return ((i_size - 1) & ~PAGE_MASK) + 1;
 	return 0;
diff --git a/fs/nfs/nfs4xdr.c b/fs/nfs/nfs4xdr.c
index 4e44412..88474a4 100644
--- a/fs/nfs/nfs4xdr.c
+++ b/fs/nfs/nfs4xdr.c
@@ -5001,7 +5001,7 @@ static int decode_space_limit(struct xdr_stream *xdr,
 		blocksize = be32_to_cpup(p);
 		maxsize = (uint64_t)nblocks * (uint64_t)blocksize;
-	maxsize >>= PAGE_CACHE_SHIFT;
+	maxsize >>= PAGE_SHIFT;
 	*pagemod_limit = min_t(u64, maxsize, ULONG_MAX);
 	return 0;
 out_overflow:
diff --git a/fs/nfs/objlayout/objio_osd.c b/fs/nfs/objlayout/objio_osd.c
index 9aebffb..049c1b1 100644
--- a/fs/nfs/objlayout/objio_osd.c
+++ b/fs/nfs/objlayout/objio_osd.c
@@ -486,7 +486,7 @@ static void __r4w_put_page(void *priv, struct page *page)
 	dprintk("%s: index=0x%lx\n", __func__,
 		(page == ZERO_PAGE(0)) ? -1UL : page->index);
 	if (ZERO_PAGE(0) != page)
+		put_page(page);
 	return;
diff --git a/fs/nfs/pagelist.c b/fs/nfs/pagelist.c
index 8ce4f61..1f6db42 100644
--- a/fs/nfs/pagelist.c
+++ b/fs/nfs/pagelist.c
@@ -342,7 +342,7 @@ nfs_create_request(struct nfs_open_context *ctx, struct page *page,
 	 * update_nfs_request below if the region is not locked. */
 	req->wb_page    = page;
 	req->wb_index	= page_file_index(page);
+	get_page(page);
 	req->wb_offset  = offset;
 	req->wb_pgbase	= offset;
 	req->wb_bytes   = count;
@@ -392,7 +392,7 @@ static void nfs_clear_request(struct nfs_page *req)
 	struct nfs_lock_context *l_ctx = req->wb_lock_context;
 	if (page != NULL) {
+		put_page(page);
 		req->wb_page = NULL;
 	if (l_ctx != NULL) {
@@ -904,7 +904,7 @@ static bool nfs_can_coalesce_requests(struct nfs_page *prev,
 				return false;
 		} else {
 			if (req->wb_pgbase != 0 ||
-			    prev->wb_pgbase + prev->wb_bytes != PAGE_CACHE_SIZE)
+			    prev->wb_pgbase + prev->wb_bytes != PAGE_SIZE)
 				return false;
diff --git a/fs/nfs/pnfs.c b/fs/nfs/pnfs.c
index 2fa483e..89a5ef4 100644
--- a/fs/nfs/pnfs.c
+++ b/fs/nfs/pnfs.c
@@ -841,7 +841,7 @@ send_layoutget(struct pnfs_layout_hdr *lo,
 		i_size = i_size_read(ino);
-		lgp->args.minlength = PAGE_CACHE_SIZE;
+		lgp->args.minlength = PAGE_SIZE;
 		if (lgp->args.minlength > range->length)
 			lgp->args.minlength = range->length;
 		if (range->iomode == IOMODE_READ) {
@@ -1618,13 +1618,13 @@ lookup_again:
 		spin_unlock(&clp->cl_lock);
-	pg_offset = arg.offset & ~PAGE_CACHE_MASK;
+	pg_offset = arg.offset & ~PAGE_MASK;
 	if (pg_offset) {
 		arg.offset -= pg_offset;
 		arg.length += pg_offset;
 	if (arg.length != NFS4_MAX_UINT64)
-		arg.length = PAGE_CACHE_ALIGN(arg.length);
+		arg.length = PAGE_ALIGN(arg.length);
 	lseg = send_layoutget(lo, ctx, &arg, gfp_flags);
 	atomic_dec(&lo->plh_outstanding);
diff --git a/fs/nfs/read.c b/fs/nfs/read.c
index eb31e23..6776d7a 100644
--- a/fs/nfs/read.c
+++ b/fs/nfs/read.c
@@ -46,7 +46,7 @@ static void nfs_readhdr_free(struct nfs_pgio_header *rhdr)
 static
 int nfs_return_empty_page(struct page *page)
-	zero_user(page, 0, PAGE_CACHE_SIZE);
+	zero_user(page, 0, PAGE_SIZE);
 	unlock_page(page);
 	return 0;
@@ -118,8 +118,8 @@ int nfs_readpage_async(struct nfs_open_context *ctx, struct inode *inode,
 		unlock_page(page);
 		return PTR_ERR(new);
-	if (len < PAGE_CACHE_SIZE)
-		zero_user_segment(page, len, PAGE_CACHE_SIZE);
+	if (len < PAGE_SIZE)
+		zero_user_segment(page, len, PAGE_SIZE);
 	nfs_pageio_init_read(&pgio, inode, false,
 			     &nfs_async_read_completion_ops);
@@ -295,7 +295,7 @@ int nfs_readpage(struct file *file, struct page *page)
 	int		error;
 	dprintk("NFS: nfs_readpage (%p %ld@%lu)\n",
-		page, PAGE_CACHE_SIZE, page_file_index(page));
+		page, PAGE_SIZE, page_file_index(page));
 	nfs_inc_stats(inode, NFSIOS_VFSREADPAGE);
 	nfs_add_stats(inode, NFSIOS_READPAGES, 1);
@@ -361,8 +361,8 @@ readpage_async_filler(void *data, struct page *page)
 	if (IS_ERR(new))
 		goto out_error;
 	if (!nfs_pageio_add_request(desc->pgio, new)) {
 		nfs_list_remove_request(new);
 		nfs_readpage_release(new);
@@ -424,8 +424,8 @@ int nfs_readpages(struct file *filp, struct address_space *mapping,
 	pgm = &pgio.pg_mirrors[0];
 	NFS_I(inode)->read_io += pgm->pg_bytes_written;
-	npages = (pgm->pg_bytes_written + PAGE_CACHE_SIZE - 1) >>
-		 PAGE_CACHE_SHIFT;
+	npages = (pgm->pg_bytes_written + PAGE_SIZE - 1) >>
+		 PAGE_SHIFT;
 	nfs_add_stats(inode, NFSIOS_READPAGES, npages);
 read_complete:
 	put_nfs_open_context(desc.ctx);
diff --git a/fs/nfs/write.c b/fs/nfs/write.c
index 5754835..5f4fd53 100644
--- a/fs/nfs/write.c
+++ b/fs/nfs/write.c
@@ -150,7 +150,7 @@ static void nfs_grow_file(struct page *page, unsigned int offset, unsigned int c
 	spin_lock(&inode->i_lock);
 	i_size = i_size_read(inode);
-	end_index = (i_size - 1) >> PAGE_CACHE_SHIFT;
+	end_index = (i_size - 1) >> PAGE_SHIFT;
 	if (i_size > 0 && page_file_index(page) < end_index)
 		goto out;
 	end = page_file_offset(page) + ((loff_t)offset+count);
@@ -1942,7 +1942,7 @@ int nfs_wb_page_cancel(struct inode *inode, struct page *page)
 int nfs_wb_single_page(struct inode *inode, struct page *page, bool launder)
 	loff_t range_start = page_file_offset(page);
-	loff_t range_end = range_start + (loff_t)(PAGE_CACHE_SIZE - 1);
+	loff_t range_end = range_start + (loff_t)(PAGE_SIZE - 1);
 	struct writeback_control wbc = {
 		.sync_mode = WB_SYNC_ALL,
 		.nr_to_write = 0,
diff --git a/fs/nilfs2/bmap.c b/fs/nilfs2/bmap.c
index 27f75bc..a9fb363 100644
--- a/fs/nilfs2/bmap.c
+++ b/fs/nilfs2/bmap.c
@@ -458,7 +458,7 @@ __u64 nilfs_bmap_data_get_key(const struct nilfs_bmap *bmap,
 	struct buffer_head *pbh;
 	__u64 key;
-	key = page_index(bh->b_page) << (PAGE_CACHE_SHIFT -
+	key = page_index(bh->b_page) << (PAGE_SHIFT -
 					 bmap->b_inode->i_blkbits);
 	for (pbh = page_buffers(bh->b_page); pbh != bh; pbh = pbh->b_this_page)
 		key++;
diff --git a/fs/nilfs2/btnode.c b/fs/nilfs2/btnode.c
index a35ae35..e0c9daf 100644
--- a/fs/nilfs2/btnode.c
+++ b/fs/nilfs2/btnode.c
@@ -62,7 +62,7 @@ nilfs_btnode_create_block(struct address_space *btnc, __u64 blocknr)
 	set_buffer_uptodate(bh);
 	unlock_page(bh->b_page);
-	page_cache_release(bh->b_page);
+	put_page(bh->b_page);
 	return bh;
@@ -128,7 +128,7 @@ found:
 out_locked:
 	unlock_page(page);
+	put_page(page);
 	return err;
@@ -146,7 +146,7 @@ void nilfs_btnode_delete(struct buffer_head *bh)
 	pgoff_t index = page_index(page);
 	int still_dirty;
+	get_page(page);
 	lock_page(page);
@@ -154,7 +154,7 @@ void nilfs_btnode_delete(struct buffer_head *bh)
 	still_dirty = PageDirty(page);
 	mapping = page->mapping;
 	unlock_page(page);
+	put_page(page);
 	if (!still_dirty && mapping)
 		invalidate_inode_pages2_range(mapping, index, index);
@@ -181,7 +181,7 @@ int nilfs_btnode_prepare_change_key(struct address_space *btnc,
 	obh = ctxt->bh;
 	ctxt->newbh = NULL;
-	if (inode->i_blkbits == PAGE_CACHE_SHIFT) {
+	if (inode->i_blkbits == PAGE_SHIFT) {
 		lock_page(obh->b_page);
 		 * We cannot call radix_tree_preload for the kernels older
diff --git a/fs/nilfs2/dir.c b/fs/nilfs2/dir.c
index 6b8b92b..e08f064 100644
--- a/fs/nilfs2/dir.c
+++ b/fs/nilfs2/dir.c
@@ -58,7 +58,7 @@ static inline unsigned nilfs_chunk_size(struct inode *inode)
 static inline void nilfs_put_page(struct page *page)
 	kunmap(page);
+	put_page(page);
@@ -69,9 +69,9 @@ static unsigned nilfs_last_byte(struct inode *inode, unsigned long page_nr)
 	unsigned last_byte = inode->i_size;
-	last_byte -= page_nr << PAGE_CACHE_SHIFT;
-	if (last_byte > PAGE_CACHE_SIZE)
-		last_byte = PAGE_CACHE_SIZE;
+	last_byte -= page_nr << PAGE_SHIFT;
+	if (last_byte > PAGE_SIZE)
+		last_byte = PAGE_SIZE;
 	return last_byte;
@@ -109,12 +109,12 @@ static void nilfs_check_page(struct page *page)
 	unsigned chunk_size = nilfs_chunk_size(dir);
 	char *kaddr = page_address(page);
 	unsigned offs, rec_len;
-	unsigned limit = PAGE_CACHE_SIZE;
+	unsigned limit = PAGE_SIZE;
 	struct nilfs_dir_entry *p;
 	char *error;
-	if ((dir->i_size >> PAGE_CACHE_SHIFT) == page->index) {
-		limit = dir->i_size & ~PAGE_CACHE_MASK;
+	if ((dir->i_size >> PAGE_SHIFT) == page->index) {
+		limit = dir->i_size & ~PAGE_MASK;
 		if (limit & (chunk_size - 1))
 			goto Ebadsize;
 		if (!limit)
@@ -161,7 +161,7 @@ Espan:
 bad_entry:
 	nilfs_error(sb, "nilfs_check_page", "bad entry in directory #%lu: %s - "
 		    "offset=%lu, inode=%lu, rec_len=%d, name_len=%d",
-		    dir->i_ino, error, (page->index<<PAGE_CACHE_SHIFT)+offs,
+		    dir->i_ino, error, (page->index<<PAGE_SHIFT)+offs,
 		    (unsigned long) le64_to_cpu(p->inode),
 		    rec_len, p->name_len);
 	goto fail;
@@ -170,7 +170,7 @@ Eend:
 		    "entry in directory #%lu spans the page boundary"
 		    "offset=%lu, inode=%lu",
-		    dir->i_ino, (page->index<<PAGE_CACHE_SHIFT)+offs,
+		    dir->i_ino, (page->index<<PAGE_SHIFT)+offs,
 		    (unsigned long) le64_to_cpu(p->inode));
 fail:
 	SetPageChecked(page);
@@ -256,8 +256,8 @@ static int nilfs_readdir(struct file *file, struct dir_context *ctx)
 	loff_t pos = ctx->pos;
 	struct inode *inode = file_inode(file);
 	struct super_block *sb = inode->i_sb;
-	unsigned int offset = pos & ~PAGE_CACHE_MASK;
-	unsigned long n = pos >> PAGE_CACHE_SHIFT;
+	unsigned int offset = pos & ~PAGE_MASK;
+	unsigned long n = pos >> PAGE_SHIFT;
 	unsigned long npages = dir_pages(inode);
 /*	unsigned chunk_mask = ~(nilfs_chunk_size(inode)-1); */
@@ -272,7 +272,7 @@ static int nilfs_readdir(struct file *file, struct dir_context *ctx)
 		if (IS_ERR(page)) {
 			nilfs_error(sb, __func__, "bad page in #%lu",
 				    inode->i_ino);
-			ctx->pos += PAGE_CACHE_SIZE - offset;
+			ctx->pos += PAGE_SIZE - offset;
 			return -EIO;
@@ -361,7 +361,7 @@ nilfs_find_entry(struct inode *dir, const struct qstr *qstr,
 		if (++n >= npages)
 			n = 0;
 		/* next page is past the blocks we've got */
-		if (unlikely(n > (dir->i_blocks >> (PAGE_CACHE_SHIFT - 9)))) {
+		if (unlikely(n > (dir->i_blocks >> (PAGE_SHIFT - 9)))) {
 			nilfs_error(dir->i_sb, __func__,
 			       "dir %lu size %lld exceeds block count %llu",
 			       dir->i_ino, dir->i_size,
@@ -401,7 +401,7 @@ ino_t nilfs_inode_by_name(struct inode *dir, const struct qstr *qstr)
 	if (de) {
 		res = le64_to_cpu(de->inode);
 		kunmap(page);
+		put_page(page);
 	return res;
@@ -460,7 +460,7 @@ int nilfs_add_link(struct dentry *dentry, struct inode *inode)
 		dir_end = kaddr + nilfs_last_byte(dir, n);
 		de = (struct nilfs_dir_entry *)kaddr;
-		kaddr += PAGE_CACHE_SIZE - reclen;
+		kaddr += PAGE_SIZE - reclen;
 		while ((char *)de <= kaddr) {
 			if ((char *)de == dir_end) {
 				/* We hit i_size */
@@ -603,7 +603,7 @@ int nilfs_make_empty(struct inode *inode, struct inode *parent)
 	kunmap_atomic(kaddr);
 	nilfs_commit_chunk(page, mapping, 0, chunk_size);
 fail:
+	put_page(page);
 	return err;
diff --git a/fs/nilfs2/gcinode.c b/fs/nilfs2/gcinode.c
index 748ca23..0224b78 100644
--- a/fs/nilfs2/gcinode.c
+++ b/fs/nilfs2/gcinode.c
@@ -115,7 +115,7 @@ int nilfs_gccache_submit_read_data(struct inode *inode, sector_t blkoff,
  failed:
 	return err;
diff --git a/fs/nilfs2/inode.c b/fs/nilfs2/inode.c
index 21a1e2e..5346313 100644
--- a/fs/nilfs2/inode.c
+++ b/fs/nilfs2/inode.c
@@ -249,7 +249,7 @@ static int nilfs_set_page_dirty(struct page *page)
 		if (nr_dirty)
 			nilfs_set_file_dirty(inode, nr_dirty);
 	} else if (ret) {
-		unsigned nr_dirty = 1 << (PAGE_CACHE_SHIFT - inode->i_blkbits);
+		unsigned nr_dirty = 1 << (PAGE_SHIFT - inode->i_blkbits);
@@ -291,7 +291,7 @@ static int nilfs_write_end(struct file *file, struct address_space *mapping,
 	struct inode *inode = mapping->host;
 	unsigned nr_dirty;
 	int err;
diff --git a/fs/nilfs2/mdt.c b/fs/nilfs2/mdt.c
index 1125f40..f6982b9 100644
--- a/fs/nilfs2/mdt.c
+++ b/fs/nilfs2/mdt.c
@@ -110,7 +110,7 @@ static int nilfs_mdt_create_block(struct inode *inode, unsigned long block,
  failed_bh:
 	brelse(bh);
  failed_unlock:
@@ -170,7 +170,7 @@ nilfs_mdt_submit_block(struct inode *inode, unsigned long blkoff,
  failed_bh:
 	brelse(bh);
  failed:
 	return ret;
@@ -363,7 +363,7 @@ int nilfs_mdt_delete_block(struct inode *inode, unsigned long block)
 int nilfs_mdt_forget_block(struct inode *inode, unsigned long block)
 	pgoff_t index = (pgoff_t)block >>
 	struct page *page;
 	unsigned long first_block;
 	int ret = 0;
@@ -376,7 +376,7 @@ int nilfs_mdt_forget_block(struct inode *inode, unsigned long block)
 	first_block = (unsigned long)index <<
 	if (page_has_buffers(page)) {
 		struct buffer_head *bh;
@@ -385,7 +385,7 @@ int nilfs_mdt_forget_block(struct inode *inode, unsigned long block)
 	unlock_page(page);
+	put_page(page);
 	if (still_dirty ||
 	    invalidate_inode_pages2_range(inode->i_mapping, index, index) != 0)
@@ -578,7 +578,7 @@ int nilfs_mdt_freeze_buffer(struct inode *inode, struct buffer_head *bh)
 	unlock_page(page);
+	put_page(page);
 	return 0;
@@ -597,7 +597,7 @@ nilfs_mdt_get_frozen_buffer(struct inode *inode, struct buffer_head *bh)
 			bh_frozen = nilfs_page_get_nth_block(page, n);
 		unlock_page(page);
+		put_page(page);
 	return bh_frozen;
diff --git a/fs/nilfs2/namei.c b/fs/nilfs2/namei.c
index 7ccdb96..151bc19 100644
--- a/fs/nilfs2/namei.c
+++ b/fs/nilfs2/namei.c
@@ -431,11 +431,11 @@ static int nilfs_rename(struct inode *old_dir, struct dentry *old_dentry,
 out_dir:
 	if (dir_de) {
 		kunmap(dir_page);
 out_old:
 	kunmap(old_page);
 out:
 	nilfs_transaction_abort(old_dir->i_sb);
 	return err;
diff --git a/fs/nilfs2/page.c b/fs/nilfs2/page.c
index c20df77..4893915 100644
--- a/fs/nilfs2/page.c
+++ b/fs/nilfs2/page.c
@@ -50,7 +50,7 @@ __nilfs_get_page_block(struct page *page, unsigned long block, pgoff_t index,
 	if (!page_has_buffers(page))
 		create_empty_buffers(page, 1 << blkbits, b_state);
-	first_block = (unsigned long)index << (PAGE_CACHE_SHIFT - blkbits);
+	first_block = (unsigned long)index << (PAGE_SHIFT - blkbits);
 	bh = nilfs_page_get_nth_block(page, block - first_block);
 	touch_buffer(bh);
@@ -64,7 +64,7 @@ struct buffer_head *nilfs_grab_buffer(struct inode *inode,
 				      unsigned long b_state)
 	int blkbits = inode->i_blkbits;
-	pgoff_t index = blkoff >> (PAGE_CACHE_SHIFT - blkbits);
+	pgoff_t index = blkoff >> (PAGE_SHIFT - blkbits);
 	struct page *page;
@@ -75,7 +75,7 @@ struct buffer_head *nilfs_grab_buffer(struct inode *inode,
 	bh = __nilfs_get_page_block(page, blkoff, index, blkbits, b_state);
 	if (unlikely(!bh)) {
 		unlock_page(page);
+		put_page(page);
 		return NULL;
 	return bh;
@@ -288,7 +288,7 @@ repeat:
 		__set_page_dirty_nobuffers(dpage);
 		unlock_page(dpage);
-		page_cache_release(dpage);
+		put_page(dpage);
 		unlock_page(page);
 	pagevec_release(&pvec);
@@ -333,7 +333,7 @@ repeat:
 			WARN_ON(PageDirty(dpage));
 			nilfs_copy_page(dpage, page, 0);
 			unlock_page(dpage);
+			put_page(dpage);
 		} else {
 			struct page *page2;
@@ -350,7 +350,7 @@ repeat:
 			if (unlikely(err < 0)) {
 				WARN_ON(err == -EEXIST);
 				page->mapping = NULL;
-				page_cache_release(page); /* for cache */
+				put_page(page); /* for cache */
 			} else {
 				page->mapping = dmap;
 				dmap->nrpages++;
@@ -523,8 +523,8 @@ unsigned long nilfs_find_uncommitted_extent(struct inode *inode,
 	if (inode->i_mapping->nrpages == 0)
 		return 0;
-	index = start_blk >> (PAGE_CACHE_SHIFT - inode->i_blkbits);
-	nblocks_in_page = 1U << (PAGE_CACHE_SHIFT - inode->i_blkbits);
+	index = start_blk >> (PAGE_SHIFT - inode->i_blkbits);
+	nblocks_in_page = 1U << (PAGE_SHIFT - inode->i_blkbits);
 	pagevec_init(&pvec, 0);
@@ -537,7 +537,7 @@ repeat:
 	if (length > 0 && pvec.pages[0]->index > index)
 		goto out;
-	b = pvec.pages[0]->index << (PAGE_CACHE_SHIFT - inode->i_blkbits);
+	b = pvec.pages[0]->index << (PAGE_SHIFT - inode->i_blkbits);
 	i = 0;
 	do {
 		page = pvec.pages[i];
diff --git a/fs/nilfs2/recovery.c b/fs/nilfs2/recovery.c
index 9b4f205..5afa77f 100644
--- a/fs/nilfs2/recovery.c
+++ b/fs/nilfs2/recovery.c
@@ -544,14 +544,14 @@ static int nilfs_recover_dsync_blocks(struct the_nilfs *nilfs,
 				blocksize, page, NULL);
 		unlock_page(page);
+		put_page(page);
 		(*nr_salvaged_blocks)++;
 		goto next;
  failed_page:
 		unlock_page(page);
+		put_page(page);
  failed_inode:
 		printk(KERN_WARNING
diff --git a/fs/nilfs2/segment.c b/fs/nilfs2/segment.c
index 3b65ada..4317f72 100644
--- a/fs/nilfs2/segment.c
+++ b/fs/nilfs2/segment.c
@@ -2070,7 +2070,7 @@ static int nilfs_segctor_do_construct(struct nilfs_sc_info *sci, int mode)
 			goto failed_to_write;
 		if (nilfs_sc_cstage_get(sci) == NILFS_ST_DONE ||
-		    nilfs->ns_blocksize_bits != PAGE_CACHE_SHIFT) {
+		    nilfs->ns_blocksize_bits != PAGE_SHIFT) {
 			 * At this point, we avoid double buffering
 			 * for blocksize < pagesize because page dirty
diff --git a/fs/ntfs/aops.c b/fs/ntfs/aops.c
index 7521e11..a474e7e 100644
--- a/fs/ntfs/aops.c
+++ b/fs/ntfs/aops.c
@@ -74,7 +74,7 @@ static void ntfs_end_buffer_async_read(struct buffer_head *bh, int uptodate)
-		file_ofs = ((s64)page->index << PAGE_CACHE_SHIFT) +
+		file_ofs = ((s64)page->index << PAGE_SHIFT) +
 				bh_offset(bh);
 		read_lock_irqsave(&ni->size_lock, flags);
 		init_size = ni->initialized_size;
@@ -142,7 +142,7 @@ static void ntfs_end_buffer_async_read(struct buffer_head *bh, int uptodate)
 		u32 rec_size;
 		rec_size = ni->itype.index.block_size;
-		recs = PAGE_CACHE_SIZE / rec_size;
+		recs = PAGE_SIZE / rec_size;
 		/* Should have been verified before we got here... */
 		BUG_ON(!recs);
 		local_irq_save(flags);
@@ -229,7 +229,7 @@ static int ntfs_read_block(struct page *page)
 	 * fully truncated, truncate will throw it away as soon as we unlock
 	 * it so no need to worry what we do with it.
-	iblock = (s64)page->index << (PAGE_CACHE_SHIFT - blocksize_bits);
+	iblock = (s64)page->index << (PAGE_SHIFT - blocksize_bits);
 	lblock = (ni->allocated_size + blocksize - 1) >> blocksize_bits;
@@ -412,9 +412,9 @@ retry_readpage:
 	vi = page->mapping->host;
 	i_size = i_size_read(vi);
 	/* Is the page fully outside i_size? (truncate in progress) */
-	if (unlikely(page->index >= (i_size + PAGE_CACHE_SIZE - 1) >>
-			PAGE_CACHE_SHIFT)) {
+	if (unlikely(page->index >= (i_size + PAGE_SIZE - 1) >>
+			PAGE_SHIFT)) {
 		ntfs_debug("Read outside i_size - truncated?");
 		goto done;
@@ -463,7 +463,7 @@ retry_readpage:
 	 * ok to ignore the compressed flag here.
 	if (unlikely(page->index > 0)) {
 		goto done;
 	if (!NInoAttr(ni))
@@ -509,7 +509,7 @@ retry_readpage:
 			le16_to_cpu(ctx->attr->data.resident.value_offset),
 			attr_len);
 	/* Zero the remainder of the page. */
-	memset(addr + attr_len, 0, PAGE_CACHE_SIZE - attr_len);
+	memset(addr + attr_len, 0, PAGE_SIZE - attr_len);
 	flush_dcache_page(page);
 	kunmap_atomic(addr);
 put_unm_err_out:
@@ -599,7 +599,7 @@ static int ntfs_write_block(struct page *page, struct writeback_control *wbc)
 	/* NOTE: Different naming scheme to ntfs_read_block()! */
 	/* The first block in the page. */
-	block = (s64)page->index << (PAGE_CACHE_SHIFT - blocksize_bits);
+	block = (s64)page->index << (PAGE_SHIFT - blocksize_bits);
@@ -925,7 +925,7 @@ static int ntfs_write_mst_block(struct page *page,
 	ntfs_volume *vol = ni->vol;
 	u8 *kaddr;
 	unsigned int rec_size = ni->itype.index.block_size;
-	ntfs_inode *locked_nis[PAGE_CACHE_SIZE / rec_size];
+	ntfs_inode *locked_nis[PAGE_SIZE / rec_size];
 	struct buffer_head *bh, *head, *tbh, *rec_start_bh;
 	struct buffer_head *bhs[MAX_BUF_PER_PAGE];
 	runlist_element *rl;
@@ -949,7 +949,7 @@ static int ntfs_write_mst_block(struct page *page,
 			(NInoAttr(ni) && ni->type == AT_INDEX_ALLOCATION)));
 	bh_size = vol->sb->s_blocksize;
 	bh_size_bits = vol->sb->s_blocksize_bits;
-	max_bhs = PAGE_CACHE_SIZE / bh_size;
+	max_bhs = PAGE_SIZE / bh_size;
 	BUG_ON(!max_bhs);
 	BUG_ON(max_bhs > MAX_BUF_PER_PAGE);
@@ -961,13 +961,13 @@ static int ntfs_write_mst_block(struct page *page,
 	BUG_ON(!bh);
 	rec_size_bits = ni->itype.index.block_size_bits;
-	BUG_ON(!(PAGE_CACHE_SIZE >> rec_size_bits));
+	BUG_ON(!(PAGE_SIZE >> rec_size_bits));
 	bhs_per_rec = rec_size >> bh_size_bits;
 	BUG_ON(!bhs_per_rec);
 	rec_block = block = (sector_t)page->index <<
-			(PAGE_CACHE_SHIFT - bh_size_bits);
+			(PAGE_SHIFT - bh_size_bits);
 	/* The first out of bounds block for the data size. */
 	dblock = (i_size_read(vi) + bh_size - 1) >> bh_size_bits;
@@ -1133,7 +1133,7 @@ lock_retry_remap:
 			unsigned long mft_no;
 			/* Get the mft record number. */
-			mft_no = (((s64)page->index << PAGE_CACHE_SHIFT) + ofs)
+			mft_no = (((s64)page->index << PAGE_SHIFT) + ofs)
 					>> rec_size_bits;
 			/* Check whether to write this mft record. */
 			tni = NULL;
@@ -1249,7 +1249,7 @@ do_mirror:
 				continue;
 			ofs = bh_offset(tbh);
 					>> rec_size_bits;
 			if (mft_no < vol->mftmirr_size)
 				ntfs_sync_mft_mirror(vol, mft_no,
@@ -1300,7 +1300,7 @@ done:
 		 * Set page error if there is only one ntfs record in the page.
 		 * Otherwise we would loose per-record granularity.
-		if (ni->itype.index.block_size == PAGE_CACHE_SIZE)
+		if (ni->itype.index.block_size == PAGE_SIZE)
 			SetPageError(page);
 		NVolSetErrors(vol);
@@ -1308,7 +1308,7 @@ done:
 		ntfs_debug("Page still contains one or more dirty ntfs "
 				"records.  Redirtying the page starting at "
 				"record 0x%lx.", page->index <<
-				(PAGE_CACHE_SHIFT - rec_size_bits));
+				(PAGE_SHIFT - rec_size_bits));
 		redirty_page_for_writepage(wbc, page);
 		unlock_page(page);
 	} else {
@@ -1365,13 +1365,13 @@ retry_writepage:
+			PAGE_SHIFT)) {
 		 * The page may have dirty, unmapped buffers.  Make them
 		 * freeable here, so the page does not leak.
-		block_invalidatepage(page, 0, PAGE_CACHE_SIZE);
+		block_invalidatepage(page, 0, PAGE_SIZE);
 		unlock_page(page);
 		ntfs_debug("Write outside i_size - truncated?");
 		return 0;
@@ -1414,10 +1414,10 @@ retry_writepage:
 	/* NInoNonResident() == NInoIndexAllocPresent() */
 	if (NInoNonResident(ni)) {
 		/* We have to zero every time due to mmap-at-end-of-file. */
-		if (page->index >= (i_size >> PAGE_CACHE_SHIFT)) {
+		if (page->index >= (i_size >> PAGE_SHIFT)) {
 			/* The page straddles i_size. */
-			unsigned int ofs = i_size & ~PAGE_CACHE_MASK;
-			zero_user_segment(page, ofs, PAGE_CACHE_SIZE);
+			unsigned int ofs = i_size & ~PAGE_MASK;
+			zero_user_segment(page, ofs, PAGE_SIZE);
 		/* Handle mst protected attributes. */
 		if (NInoMstProtected(ni))
@@ -1500,7 +1500,7 @@ retry_writepage:
 			addr, attr_len);
 	/* Zero out of bounds area in the page cache page. */
 	flush_dcache_mft_record_page(ctx->ntfs_ino);
diff --git a/fs/ntfs/aops.h b/fs/ntfs/aops.h
index caecc58..37cd7e4 100644
--- a/fs/ntfs/aops.h
+++ b/fs/ntfs/aops.h
@@ -40,7 +40,7 @@
 static inline void ntfs_unmap_page(struct page *page)
 	kunmap(page);
+	put_page(page);
diff --git a/fs/ntfs/attrib.c b/fs/ntfs/attrib.c
index 250ed5b..44a39a0 100644
--- a/fs/ntfs/attrib.c
+++ b/fs/ntfs/attrib.c
@@ -152,7 +152,7 @@ int ntfs_map_runlist_nolock(ntfs_inode *ni, VCN vcn, ntfs_attr_search_ctx *ctx)
 			if (old_ctx.base_ntfs_ino && old_ctx.ntfs_ino !=
 					old_ctx.base_ntfs_ino) {
 				put_this_page = old_ctx.ntfs_ino->page;
-				page_cache_get(put_this_page);
+				get_page(put_this_page);
 			 * Reinitialize the search context so we can lookup the
@@ -275,7 +275,7 @@ retry_map:
 		 * the pieces anyway.
 		if (put_this_page)
-			page_cache_release(put_this_page);
+			put_page(put_this_page);
 	return err;
@@ -1660,7 +1660,7 @@ int ntfs_attr_make_non_resident(ntfs_inode *ni, const u32 data_size)
 		memcpy(kaddr, (u8*)a +
 				le16_to_cpu(a->data.resident.value_offset),
 				attr_size);
-		memset(kaddr + attr_size, 0, PAGE_CACHE_SIZE - attr_size);
+		memset(kaddr + attr_size, 0, PAGE_SIZE - attr_size);
@@ -1748,7 +1748,7 @@ int ntfs_attr_make_non_resident(ntfs_inode *ni, const u32 data_size)
 	if (page) {
 		unlock_page(page);
+		put_page(page);
 	ntfs_debug("Done.");
 	return 0;
@@ -1835,7 +1835,7 @@ rl_err_out:
 		ntfs_free(rl);
 page_err_out:
 		unlock_page(page);
+		put_page(page);
 	if (err == -EINVAL)
 		err = -EIO;
@@ -2513,17 +2513,17 @@ int ntfs_attr_set(ntfs_inode *ni, const s64 ofs, const s64 cnt, const u8 val)
 	BUG_ON(NInoEncrypted(ni));
 	mapping = VFS_I(ni)->i_mapping;
 	/* Work out the starting index and page offset. */
-	idx = ofs >> PAGE_CACHE_SHIFT;
-	start_ofs = ofs & ~PAGE_CACHE_MASK;
+	idx = ofs >> PAGE_SHIFT;
+	start_ofs = ofs & ~PAGE_MASK;
 	/* Work out the ending index and page offset. */
 	end = ofs + cnt;
-	end_ofs = end & ~PAGE_CACHE_MASK;
+	end_ofs = end & ~PAGE_MASK;
 	/* If the end is outside the inode size return -ESPIPE. */
 	if (unlikely(end > i_size_read(VFS_I(ni)))) {
 		ntfs_error(vol->sb, "Request exceeds end of attribute.");
 		return -ESPIPE;
-	end >>= PAGE_CACHE_SHIFT;
+	end >>= PAGE_SHIFT;
 	/* If there is a first partial page, need to do it the slow way. */
 	if (start_ofs) {
 		page = read_mapping_page(mapping, idx, NULL);
@@ -2536,7 +2536,7 @@ int ntfs_attr_set(ntfs_inode *ni, const s64 ofs, const s64 cnt, const u8 val)
 		 * If the last page is the same as the first page, need to
 		 * limit the write to the end offset.
-		size = PAGE_CACHE_SIZE;
+		size = PAGE_SIZE;
 		if (idx == end)
 			size = end_ofs;
 		kaddr = kmap_atomic(page);
@@ -2544,7 +2544,7 @@ int ntfs_attr_set(ntfs_inode *ni, const s64 ofs, const s64 cnt, const u8 val)
+		put_page(page);
 		balance_dirty_pages_ratelimited(mapping);
 		cond_resched();
 		if (idx == end)
@@ -2561,7 +2561,7 @@ int ntfs_attr_set(ntfs_inode *ni, const s64 ofs, const s64 cnt, const u8 val)
 			return -ENOMEM;
-		memset(kaddr, val, PAGE_CACHE_SIZE);
+		memset(kaddr, val, PAGE_SIZE);
@@ -2585,7 +2585,7 @@ int ntfs_attr_set(ntfs_inode *ni, const s64 ofs, const s64 cnt, const u8 val)
 		/* Finally unlock and release the page. */
 		unlock_page(page);
+		put_page(page);
 		cond_resched();
@@ -2602,7 +2602,7 @@ int ntfs_attr_set(ntfs_inode *ni, const s64 ofs, const s64 cnt, const u8 val)
+		put_page(page);
 		cond_resched();
diff --git a/fs/ntfs/bitmap.c b/fs/ntfs/bitmap.c
index 0809cf8..ec130c5 100644
--- a/fs/ntfs/bitmap.c
+++ b/fs/ntfs/bitmap.c
@@ -67,8 +67,8 @@ int __ntfs_bitmap_set_bits_in_run(struct inode *vi, const s64 start_bit,
 	 * Calculate the indices for the pages containing the first and last
 	 * bits, i.e. @start_bit and @start_bit + @cnt - 1, respectively.
-	index = start_bit >> (3 + PAGE_CACHE_SHIFT);
-	end_index = (start_bit + cnt - 1) >> (3 + PAGE_CACHE_SHIFT);
+	index = start_bit >> (3 + PAGE_SHIFT);
+	end_index = (start_bit + cnt - 1) >> (3 + PAGE_SHIFT);
 	/* Get the page containing the first bit (@start_bit). */
 	mapping = vi->i_mapping;
@@ -82,7 +82,7 @@ int __ntfs_bitmap_set_bits_in_run(struct inode *vi, const s64 start_bit,
 	/* Set @pos to the position of the byte containing @start_bit. */
-	pos = (start_bit >> 3) & ~PAGE_CACHE_MASK;
+	pos = (start_bit >> 3) & ~PAGE_MASK;
 	/* Calculate the position of @start_bit in the first byte. */
 	bit = start_bit & 7;
@@ -108,7 +108,7 @@ int __ntfs_bitmap_set_bits_in_run(struct inode *vi, const s64 start_bit,
 	 * Depending on @value, modify all remaining whole bytes in the page up
 	 * to @cnt.
-	len = min_t(s64, cnt >> 3, PAGE_CACHE_SIZE - pos);
+	len = min_t(s64, cnt >> 3, PAGE_SIZE - pos);
 	memset(kaddr + pos, value ? 0xff : 0, len);
 	cnt -= len << 3;
@@ -132,7 +132,7 @@ int __ntfs_bitmap_set_bits_in_run(struct inode *vi, const s64 start_bit,
 		 * page up to @cnt.
-		len = min_t(s64, cnt >> 3, PAGE_CACHE_SIZE);
+		len = min_t(s64, cnt >> 3, PAGE_SIZE);
 		memset(kaddr, value ? 0xff : 0, len);
 		cnt -= len << 3;
diff --git a/fs/ntfs/compress.c b/fs/ntfs/compress.c
index f82498c..b6074a5 100644
--- a/fs/ntfs/compress.c
+++ b/fs/ntfs/compress.c
@@ -104,7 +104,7 @@ static void zero_partial_compressed_page(struct page *page,
 	unsigned int kp_ofs;
 	ntfs_debug("Zeroing page region outside initialized size.");
-	if (((s64)page->index << PAGE_CACHE_SHIFT) >= initialized_size) {
+	if (((s64)page->index << PAGE_SHIFT) >= initialized_size) {
 		 * FIXME: Using clear_page() will become wrong when we get
 		 * PAGE_CACHE_SIZE != PAGE_SIZE but for now there is no problem.
@@ -112,8 +112,8 @@ static void zero_partial_compressed_page(struct page *page,
 		clear_page(kp);
 		return;
-	kp_ofs = initialized_size & ~PAGE_CACHE_MASK;
-	memset(kp + kp_ofs, 0, PAGE_CACHE_SIZE - kp_ofs);
+	kp_ofs = initialized_size & ~PAGE_MASK;
+	memset(kp + kp_ofs, 0, PAGE_SIZE - kp_ofs);
 	return;
@@ -123,7 +123,7 @@ static void zero_partial_compressed_page(struct page *page,
 static inline void handle_bounds_compressed_page(struct page *page,
 		const loff_t i_size, const s64 initialized_size)
-	if ((page->index >= (initialized_size >> PAGE_CACHE_SHIFT)) &&
+	if ((page->index >= (initialized_size >> PAGE_SHIFT)) &&
 			(initialized_size < i_size))
 		zero_partial_compressed_page(page, initialized_size);
 	return;
@@ -241,7 +241,7 @@ return_error:
 				if (di == xpage)
 					*xpage_done = 1;
 				else
-					page_cache_release(dp);
+					put_page(dp);
 				dest_pages[di] = NULL;
@@ -274,7 +274,7 @@ return_error:
 		cb = cb_sb_end;
 		/* Advance destination position to next sub-block. */
-		*dest_ofs = (*dest_ofs + NTFS_SB_SIZE) & ~PAGE_CACHE_MASK;
+		*dest_ofs = (*dest_ofs + NTFS_SB_SIZE) & ~PAGE_MASK;
 		if (!*dest_ofs && (++*dest_index > dest_max_index))
 			goto return_overflow;
 		goto do_next_sb;
@@ -301,7 +301,7 @@ return_error:
 		*dest_ofs += NTFS_SB_SIZE;
-		if (!(*dest_ofs &= ~PAGE_CACHE_MASK)) {
+		if (!(*dest_ofs &= ~PAGE_MASK)) {
 finalize_page:
 			 * First stage: add current page index to array of
@@ -335,7 +335,7 @@ do_next_tag:
 			*dest_ofs += nr_bytes;
 		/* We have finished the current sub-block. */
 			goto finalize_page;
 		goto do_next_sb;
@@ -498,13 +498,13 @@ int ntfs_read_compressed_block(struct page *page)
 	VCN vcn;
 	LCN lcn;
 	/* The first wanted vcn (minimum alignment is PAGE_CACHE_SIZE). */
-	VCN start_vcn = (((s64)index << PAGE_CACHE_SHIFT) & ~cb_size_mask) >>
+	VCN start_vcn = (((s64)index << PAGE_SHIFT) & ~cb_size_mask) >>
 			vol->cluster_size_bits;
 	 * The first vcn after the last wanted vcn (minimum alignment is again
 	 * PAGE_CACHE_SIZE.
-	VCN end_vcn = ((((s64)(index + 1UL) << PAGE_CACHE_SHIFT) + cb_size - 1)
+	VCN end_vcn = ((((s64)(index + 1UL) << PAGE_SHIFT) + cb_size - 1)
 			& ~cb_size_mask) >> vol->cluster_size_bits;
 	/* Number of compression blocks (cbs) in the wanted vcn range. */
 	unsigned int nr_cbs = (end_vcn - start_vcn) << vol->cluster_size_bits
@@ -515,7 +515,7 @@ int ntfs_read_compressed_block(struct page *page)
 	 * guarantees of start_vcn and end_vcn, no need to round up here.
 	unsigned int nr_pages = (end_vcn - start_vcn) <<
-			vol->cluster_size_bits >> PAGE_CACHE_SHIFT;
+			vol->cluster_size_bits >> PAGE_SHIFT;
 	unsigned int xpage, max_page, cur_page, cur_ofs, i;
 	unsigned int cb_clusters, cb_max_ofs;
 	int block, max_block, cb_max_page, bhs_size, nr_bhs, err = 0;
@@ -549,7 +549,7 @@ int ntfs_read_compressed_block(struct page *page)
 	 * We have already been given one page, this is the one we must do.
 	 * Once again, the alignment guarantees keep it simple.
-	offset = start_vcn << vol->cluster_size_bits >> PAGE_CACHE_SHIFT;
+	offset = start_vcn << vol->cluster_size_bits >> PAGE_SHIFT;
 	xpage = index - offset;
 	pages[xpage] = page;
@@ -560,13 +560,13 @@ int ntfs_read_compressed_block(struct page *page)
 	i_size = i_size_read(VFS_I(ni));
 	initialized_size = ni->initialized_size;
 	read_unlock_irqrestore(&ni->size_lock, flags);
-	max_page = ((i_size + PAGE_CACHE_SIZE - 1) >> PAGE_CACHE_SHIFT) -
+	max_page = ((i_size + PAGE_SIZE - 1) >> PAGE_SHIFT) -
 			offset;
 	if (xpage >= max_page) {
 		kfree(bhs);
 		kfree(pages);
 		ntfs_debug("Compressed read outside i_size - truncated?");
 		unlock_page(page);
@@ -591,7 +591,7 @@ int ntfs_read_compressed_block(struct page *page)
 				continue;
 			unlock_page(page);
+			put_page(page);
 			pages[i] = NULL;
@@ -735,9 +735,9 @@ lock_retry_remap:
 	ntfs_debug("Successfully read the compression block.");
 	/* The last page and maximum offset within it for the current cb. */
-	cb_max_page = (cur_page << PAGE_CACHE_SHIFT) + cur_ofs + cb_size;
-	cb_max_ofs = cb_max_page & ~PAGE_CACHE_MASK;
-	cb_max_page >>= PAGE_CACHE_SHIFT;
+	cb_max_page = (cur_page << PAGE_SHIFT) + cur_ofs + cb_size;
+	cb_max_ofs = cb_max_page & ~PAGE_MASK;
+	cb_max_page >>= PAGE_SHIFT;
 	/* Catch end of file inside a compression block. */
 	if (cb_max_page > max_page)
@@ -762,7 +762,7 @@ lock_retry_remap:
 					clear_page(page_address(page));
 				else
 					memset(page_address(page) + cur_ofs, 0,
-							PAGE_CACHE_SIZE -
+							PAGE_SIZE -
 							cur_ofs);
 				kunmap(page);
@@ -771,10 +771,10 @@ lock_retry_remap:
 				if (cur_page == xpage)
 					xpage_done = 1;
 				else
+					put_page(page);
 				pages[cur_page] = NULL;
-			cb_pos += PAGE_CACHE_SIZE - cur_ofs;
+			cb_pos += PAGE_SIZE - cur_ofs;
 			cur_ofs = 0;
 			if (cb_pos >= cb_end)
 				break;
@@ -816,8 +816,8 @@ lock_retry_remap:
 			page = pages[cur_page];
 			if (page)
 				memcpy(page_address(page) + cur_ofs, cb_pos,
-						PAGE_CACHE_SIZE - cur_ofs);
+						PAGE_SIZE - cur_ofs);
 			cur_ofs = 0;
 				break;
@@ -850,10 +850,10 @@ lock_retry_remap:
 				if (cur2_page == xpage)
 					xpage_done = 1;
 				else
+					put_page(page);
 				pages[cur2_page] = NULL;
-			cb_pos2 += PAGE_CACHE_SIZE - cur_ofs2;
+			cb_pos2 += PAGE_SIZE - cur_ofs2;
 			cur_ofs2 = 0;
 			if (cb_pos2 >= cb_end)
 				break;
@@ -884,7 +884,7 @@ lock_retry_remap:
 					kunmap(page);
 					unlock_page(page);
 					if (prev_cur_page != xpage)
+						put_page(page);
 					pages[prev_cur_page] = NULL;
@@ -914,7 +914,7 @@ lock_retry_remap:
 			kunmap(page);
 			unlock_page(page);
 			if (cur_page != xpage)
+				put_page(page);
@@ -961,7 +961,7 @@ err_out:
 			kunmap(page);
 			unlock_page(page);
 			if (i != xpage)
+				put_page(page);
 	kfree(pages);
diff --git a/fs/ntfs/dir.c b/fs/ntfs/dir.c
index b2eff58..3cdce16 100644
--- a/fs/ntfs/dir.c
+++ b/fs/ntfs/dir.c
@@ -319,7 +319,7 @@ descend_into_child_node:
 	 * disk if necessary.
 	page = ntfs_map_page(ia_mapping, vcn <<
-			dir_ni->itype.index.vcn_size_bits >> PAGE_CACHE_SHIFT);
+			dir_ni->itype.index.vcn_size_bits >> PAGE_SHIFT);
 	if (IS_ERR(page)) {
 		ntfs_error(sb, "Failed to map directory index page, error %ld.",
 				-PTR_ERR(page));
@@ -331,9 +331,9 @@ descend_into_child_node:
 fast_descend_into_child_node:
 	/* Get to the index allocation block. */
 	ia = (INDEX_ALLOCATION*)(kaddr + ((vcn <<
-			dir_ni->itype.index.vcn_size_bits) & ~PAGE_CACHE_MASK));
+			dir_ni->itype.index.vcn_size_bits) & ~PAGE_MASK));
 	/* Bounds checks. */
-	if ((u8*)ia < kaddr || (u8*)ia > kaddr + PAGE_CACHE_SIZE) {
+	if ((u8*)ia < kaddr || (u8*)ia > kaddr + PAGE_SIZE) {
 		ntfs_error(sb, "Out of bounds check failed. Corrupt directory "
 				"inode 0x%lx or driver bug.", dir_ni->mft_no);
 		goto unm_err_out;
@@ -366,7 +366,7 @@ fast_descend_into_child_node:
 		goto unm_err_out;
 	index_end = (u8*)ia + dir_ni->itype.index.block_size;
-	if (index_end > kaddr + PAGE_CACHE_SIZE) {
+	if (index_end > kaddr + PAGE_SIZE) {
 		ntfs_error(sb, "Index buffer (VCN 0x%llx) of directory inode "
 				"0x%lx crosses page boundary. Impossible! "
 				"Cannot access! This is probably a bug in the "
@@ -559,9 +559,9 @@ found_it2:
 			/* If vcn is in the same page cache page as old_vcn we
 			 * recycle the mapped page. */
 			if (old_vcn << vol->cluster_size_bits >>
-					PAGE_CACHE_SHIFT == vcn <<
+					PAGE_SHIFT == vcn <<
-					PAGE_CACHE_SHIFT)
+					PAGE_SHIFT)
 				goto fast_descend_into_child_node;
 			unlock_page(page);
 			ntfs_unmap_page(page);
@@ -1246,15 +1246,15 @@ skip_index_root:
 		goto iput_err_out;
 	/* Get the starting bit position in the current bitmap page. */
-	cur_bmp_pos = bmp_pos & ((PAGE_CACHE_SIZE * 8) - 1);
-	bmp_pos &= ~(u64)((PAGE_CACHE_SIZE * 8) - 1);
+	cur_bmp_pos = bmp_pos & ((PAGE_SIZE * 8) - 1);
+	bmp_pos &= ~(u64)((PAGE_SIZE * 8) - 1);
 get_next_bmp_page:
 	ntfs_debug("Reading bitmap with page index 0x%llx, bit ofs 0x%llx",
-			(unsigned long long)bmp_pos >> (3 + PAGE_CACHE_SHIFT),
+			(unsigned long long)bmp_pos >> (3 + PAGE_SHIFT),
 			(unsigned long long)bmp_pos &
-			(unsigned long long)((PAGE_CACHE_SIZE * 8) - 1));
+			(unsigned long long)((PAGE_SIZE * 8) - 1));
 	bmp_page = ntfs_map_page(bmp_mapping,
-			bmp_pos >> (3 + PAGE_CACHE_SHIFT));
+			bmp_pos >> (3 + PAGE_SHIFT));
 	if (IS_ERR(bmp_page)) {
 		ntfs_error(sb, "Reading index bitmap failed.");
 		err = PTR_ERR(bmp_page);
@@ -1270,9 +1270,9 @@ find_next_index_buffer:
 		 * If we have reached the end of the bitmap page, get the next
 		 * page, and put away the old one.
-		if (unlikely((cur_bmp_pos >> 3) >= PAGE_CACHE_SIZE)) {
+		if (unlikely((cur_bmp_pos >> 3) >= PAGE_SIZE)) {
 			ntfs_unmap_page(bmp_page);
-			bmp_pos += PAGE_CACHE_SIZE * 8;
+			bmp_pos += PAGE_SIZE * 8;
 			cur_bmp_pos = 0;
 			goto get_next_bmp_page;
@@ -1285,8 +1285,8 @@ find_next_index_buffer:
 	ntfs_debug("Handling index buffer 0x%llx.",
 			(unsigned long long)bmp_pos + cur_bmp_pos);
 	/* If the current index buffer is in the same page we reuse the page. */
-	if ((prev_ia_pos & (s64)PAGE_CACHE_MASK) !=
-			(ia_pos & (s64)PAGE_CACHE_MASK)) {
+	if ((prev_ia_pos & (s64)PAGE_MASK) !=
+			(ia_pos & (s64)PAGE_MASK)) {
 		prev_ia_pos = ia_pos;
 		if (likely(ia_page != NULL)) {
 			unlock_page(ia_page);
@@ -1296,7 +1296,7 @@ find_next_index_buffer:
 		 * Map the page cache page containing the current ia_pos,
 		 * reading it from disk if necessary.
-		ia_page = ntfs_map_page(ia_mapping, ia_pos >> PAGE_CACHE_SHIFT);
+		ia_page = ntfs_map_page(ia_mapping, ia_pos >> PAGE_SHIFT);
 		if (IS_ERR(ia_page)) {
 			ntfs_error(sb, "Reading index allocation data failed.");
 			err = PTR_ERR(ia_page);
@@ -1307,10 +1307,10 @@ find_next_index_buffer:
 		kaddr = (u8*)page_address(ia_page);
 	/* Get the current index buffer. */
-	ia = (INDEX_ALLOCATION*)(kaddr + (ia_pos & ~PAGE_CACHE_MASK &
-			~(s64)(ndir->itype.index.block_size - 1)));
+	ia = (INDEX_ALLOCATION*)(kaddr + (ia_pos & ~PAGE_MASK &
+					  ~(s64)(ndir->itype.index.block_size - 1)));
-	if (unlikely((u8*)ia < kaddr || (u8*)ia > kaddr + PAGE_CACHE_SIZE)) {
+	if (unlikely((u8*)ia < kaddr || (u8*)ia > kaddr + PAGE_SIZE)) {
 				"inode 0x%lx or driver bug.", vdir->i_ino);
 		goto err_out;
@@ -1348,7 +1348,7 @@ find_next_index_buffer:
 		goto err_out;
 	index_end = (u8*)ia + ndir->itype.index.block_size;
-	if (unlikely(index_end > kaddr + PAGE_CACHE_SIZE)) {
+	if (unlikely(index_end > kaddr + PAGE_SIZE)) {
diff --git a/fs/ntfs/file.c b/fs/ntfs/file.c
index bed4d42..2dae608 100644
--- a/fs/ntfs/file.c
+++ b/fs/ntfs/file.c
@@ -220,8 +220,8 @@ do_non_resident_extend:
 		m = NULL;
-	index = old_init_size >> PAGE_CACHE_SHIFT;
-	end_index = (new_init_size + PAGE_CACHE_SIZE - 1) >> PAGE_CACHE_SHIFT;
+	index = old_init_size >> PAGE_SHIFT;
+	end_index = (new_init_size + PAGE_SIZE - 1) >> PAGE_SHIFT;
 	do {
 		 * Read the page.  If the page is not present, this will zero
@@ -233,7 +233,7 @@ do_non_resident_extend:
 			goto init_err_out;
 		if (unlikely(PageError(page))) {
+			put_page(page);
 			err = -EIO;
 			goto init_err_out;
@@ -242,13 +242,13 @@ do_non_resident_extend:
 		 * enough to make ntfs_writepage() work.
 		write_lock_irqsave(&ni->size_lock, flags);
-		ni->initialized_size = (s64)(index + 1) << PAGE_CACHE_SHIFT;
+		ni->initialized_size = (s64)(index + 1) << PAGE_SHIFT;
 		if (ni->initialized_size > new_init_size)
 			ni->initialized_size = new_init_size;
 		write_unlock_irqrestore(&ni->size_lock, flags);
 		/* Set the page dirty so it gets written out. */
 		set_page_dirty(page);
+		put_page(page);
 		 * Play nice with the vm and the rest of the system.  This is
 		 * very much needed as we can potentially be modifying the
@@ -543,7 +543,7 @@ out:
 err_out:
 	while (nr > 0) {
 		unlock_page(pages[--nr]);
-		page_cache_release(pages[nr]);
+		put_page(pages[nr]);
 	goto out;
@@ -653,7 +653,7 @@ static int ntfs_prepare_pages_for_non_resident_write(struct page **pages,
 	u = 0;
 do_next_page:
 	page = pages[u];
-	bh_pos = (s64)page->index << PAGE_CACHE_SHIFT;
+	bh_pos = (s64)page->index << PAGE_SHIFT;
 	bh = head = page_buffers(page);
 	do {
 		VCN cdelta;
@@ -810,11 +810,11 @@ map_buffer_cached:
 				if (bh_pos < pos) {
-					pofs = bh_pos & ~PAGE_CACHE_MASK;
+					pofs = bh_pos & ~PAGE_MASK;
 					memset(kaddr + pofs, 0, pos - bh_pos);
 				if (bh_end > end) {
-					pofs = end & ~PAGE_CACHE_MASK;
+					pofs = end & ~PAGE_MASK;
 					memset(kaddr + pofs, 0, bh_end - end);
@@ -942,7 +942,7 @@ rl_not_mapped_enoent:
 		 * unmapped.  This can only happen when the cluster size is
 		 * less than the page cache size.
-		if (unlikely(vol->cluster_size < PAGE_CACHE_SIZE)) {
+		if (unlikely(vol->cluster_size < PAGE_SIZE)) {
 			bh_cend = (bh_end + vol->cluster_size - 1) >>
 			if ((bh_cend <= cpos || bh_cpos >= cend)) {
@@ -1208,7 +1208,7 @@ rl_not_mapped_enoent:
 		wait_on_buffer(bh);
 		if (likely(buffer_uptodate(bh))) {
 			page = bh->b_page;
-			bh_pos = ((s64)page->index << PAGE_CACHE_SHIFT) +
+			bh_pos = ((s64)page->index << PAGE_SHIFT) +
 					bh_offset(bh);
 			 * If the buffer overflows the initialized size, need
@@ -1350,7 +1350,7 @@ rl_not_mapped_enoent:
 		do {
 			if (u == nr_pages &&
-					((s64)page->index << PAGE_CACHE_SHIFT) +
+					((s64)page->index << PAGE_SHIFT) +
 					bh_offset(bh) >= end)
 				break;
 			if (!buffer_new(bh))
@@ -1422,7 +1422,7 @@ static inline int ntfs_commit_pages_after_non_resident_write(
 		bool partial;
 		page = pages[u];
 		partial = false;
 		do {
@@ -1639,7 +1639,7 @@ static int ntfs_commit_pages_after_write(struct page **pages,
 		if (end < attr_len)
 			memcpy(kaddr + end, kattr + end, attr_len - end);
 		/* Zero the region outside the end of the attribute value. */
-		memset(kaddr + attr_len, 0, PAGE_CACHE_SIZE - attr_len);
+		memset(kaddr + attr_len, 0, PAGE_SIZE - attr_len);
@@ -1706,7 +1706,7 @@ static size_t ntfs_copy_from_user_iter(struct page **pages, unsigned nr_pages,
 	unsigned len, copied;
 	do {
-		len = PAGE_CACHE_SIZE - ofs;
+		len = PAGE_SIZE - ofs;
 		if (len > bytes)
 			len = bytes;
 		copied = iov_iter_copy_from_user_atomic(*pages, &data, ofs,
@@ -1724,14 +1724,14 @@ out:
 	return total;
 err:
 	/* Zero the rest of the target like __copy_from_user(). */
-	len = PAGE_CACHE_SIZE - copied;
+	len = PAGE_SIZE - copied;
 	do {
 		if (len > bytes)
 			len = bytes;
 		zero_user(*pages, copied, len);
 		bytes -= len;
 		copied = 0;
-		len = PAGE_CACHE_SIZE;
+		len = PAGE_SIZE;
 	} while (++pages < last_page);
 	goto out;
@@ -1787,8 +1787,8 @@ static ssize_t ntfs_perform_write(struct file *file, struct iov_iter *i,
 	 * attributes.
 	nr_pages = 1;
-	if (vol->cluster_size > PAGE_CACHE_SIZE && NInoNonResident(ni))
-		nr_pages = vol->cluster_size >> PAGE_CACHE_SHIFT;
+	if (vol->cluster_size > PAGE_SIZE && NInoNonResident(ni))
+		nr_pages = vol->cluster_size >> PAGE_SHIFT;
 	last_vcn = -1;
 	do {
 		VCN vcn;
@@ -1796,9 +1796,9 @@ static ssize_t ntfs_perform_write(struct file *file, struct iov_iter *i,
 		unsigned ofs, do_pages, u;
 		size_t copied;
-		start_idx = idx = pos >> PAGE_CACHE_SHIFT;
-		ofs = pos & ~PAGE_CACHE_MASK;
-		bytes = PAGE_CACHE_SIZE - ofs;
+		start_idx = idx = pos >> PAGE_SHIFT;
+		ofs = pos & ~PAGE_MASK;
+		bytes = PAGE_SIZE - ofs;
 		do_pages = 1;
 		if (nr_pages > 1) {
 			vcn = pos >> vol->cluster_size_bits;
@@ -1832,7 +1832,7 @@ static ssize_t ntfs_perform_write(struct file *file, struct iov_iter *i,
 				if (lcn == LCN_HOLE) {
 					start_idx = (pos & ~(s64)
 							vol->cluster_size_mask)
-							>> PAGE_CACHE_SHIFT;
+							>> PAGE_SHIFT;
 					bytes = vol->cluster_size - (pos &
 							vol->cluster_size_mask);
 					do_pages = nr_pages;
@@ -1871,12 +1871,12 @@ again:
 			if (unlikely(status)) {
 				do {
 					unlock_page(pages[--do_pages]);
-					page_cache_release(pages[do_pages]);
+					put_page(pages[do_pages]);
 				} while (do_pages);
 				break;
-		u = (pos >> PAGE_CACHE_SHIFT) - pages[0]->index;
+		u = (pos >> PAGE_SHIFT) - pages[0]->index;
 		copied = ntfs_copy_from_user_iter(pages + u, do_pages - u, ofs,
 					i, bytes);
 		ntfs_flush_dcache_pages(pages + u, do_pages - u);
@@ -1889,7 +1889,7 @@ again:
 		do {
 		} while (do_pages);
 		if (unlikely(status < 0))
 			break;
@@ -1921,7 +1921,7 @@ again:
 	} while (iov_iter_count(i));
 	if (cached_page)
-		page_cache_release(cached_page);
+		put_page(cached_page);
 	ntfs_debug("Done.  Returning %s (written 0x%lx, status %li).",
 			written ? "written" : "status", (unsigned long)written,
 			(long)status);
diff --git a/fs/ntfs/index.c b/fs/ntfs/index.c
index 096c135..02a83a4 100644
--- a/fs/ntfs/index.c
+++ b/fs/ntfs/index.c
@@ -276,7 +276,7 @@ descend_into_child_node:
-			idx_ni->itype.index.vcn_size_bits >> PAGE_CACHE_SHIFT);
+			idx_ni->itype.index.vcn_size_bits >> PAGE_SHIFT);
 	if (IS_ERR(page)) {
 		ntfs_error(sb, "Failed to map index page, error %ld.",
 				-PTR_ERR(page));
@@ -288,9 +288,9 @@ descend_into_child_node:
-			idx_ni->itype.index.vcn_size_bits) & ~PAGE_CACHE_MASK));
+			idx_ni->itype.index.vcn_size_bits) & ~PAGE_MASK));
 		ntfs_error(sb, "Out of bounds check failed.  Corrupt inode "
 				"0x%lx or driver bug.", idx_ni->mft_no);
 		goto unm_err_out;
@@ -323,7 +323,7 @@ fast_descend_into_child_node:
 		goto unm_err_out;
 	index_end = (u8*)ia + idx_ni->itype.index.block_size;
 		ntfs_error(sb, "Index buffer (VCN 0x%llx) of inode 0x%lx "
 				"crosses page boundary.  Impossible!  Cannot "
 				"access!  This is probably a bug in the "
@@ -427,9 +427,9 @@ ia_done:
 		 * the mapped page.
-				PAGE_CACHE_SHIFT)
+				PAGE_SHIFT)
 		unlock_page(page);
diff --git a/fs/ntfs/inode.c b/fs/ntfs/inode.c
index d284f07..3eda6d4 100644
--- a/fs/ntfs/inode.c
+++ b/fs/ntfs/inode.c
@@ -868,12 +868,12 @@ skip_attr_list_load:
 					ni->itype.index.block_size);
 			goto unm_err_out;
-		if (ni->itype.index.block_size > PAGE_CACHE_SIZE) {
+		if (ni->itype.index.block_size > PAGE_SIZE) {
 			ntfs_error(vi->i_sb, "Index block size (%u) > "
 					"PAGE_CACHE_SIZE (%ld) is not "
 					"supported.  Sorry.",
 					ni->itype.index.block_size,
-					PAGE_CACHE_SIZE);
+					PAGE_SIZE);
 			err = -EOPNOTSUPP;
 			goto unm_err_out;
@@ -1585,10 +1585,10 @@ static int ntfs_read_locked_index_inode(struct inode *base_vi, struct inode *vi)
 				"two.", ni->itype.index.block_size);
 		goto unm_err_out;
 		ntfs_error(vi->i_sb, "Index block size (%u) > PAGE_CACHE_SIZE "
 				"(%ld) is not supported.  Sorry.",
-				ni->itype.index.block_size, PAGE_CACHE_SIZE);
+				ni->itype.index.block_size, PAGE_SIZE);
 		err = -EOPNOTSUPP;
 		goto unm_err_out;
diff --git a/fs/ntfs/lcnalloc.c b/fs/ntfs/lcnalloc.c
index 1711b71..27a24a4 100644
--- a/fs/ntfs/lcnalloc.c
+++ b/fs/ntfs/lcnalloc.c
@@ -283,15 +283,15 @@ runlist_element *ntfs_cluster_alloc(ntfs_volume *vol, const VCN start_vcn,
 		page = ntfs_map_page(mapping, last_read_pos >>
-				PAGE_CACHE_SHIFT);
+				PAGE_SHIFT);
 		if (IS_ERR(page)) {
 			err = PTR_ERR(page);
 			ntfs_error(vol->sb, "Failed to map page.");
 			goto out;
-		buf_size = last_read_pos & ~PAGE_CACHE_MASK;
+		buf_size = last_read_pos & ~PAGE_MASK;
 		buf = page_address(page) + buf_size;
-		buf_size = PAGE_CACHE_SIZE - buf_size;
+		buf_size = PAGE_SIZE - buf_size;
 		if (unlikely(last_read_pos + buf_size > i_size))
 			buf_size = i_size - last_read_pos;
 		buf_size <<= 3;
diff --git a/fs/ntfs/logfile.c b/fs/ntfs/logfile.c
index c71de29..9d71213 100644
--- a/fs/ntfs/logfile.c
+++ b/fs/ntfs/logfile.c
@@ -381,7 +381,7 @@ static int ntfs_check_and_load_restart_page(struct inode *vi,
 	 * completely inside @rp, just copy it from there.  Otherwise map all
 	 * the required pages and copy the data from them.
-	size = PAGE_CACHE_SIZE - (pos & ~PAGE_CACHE_MASK);
+	size = PAGE_SIZE - (pos & ~PAGE_MASK);
 	if (size >= le32_to_cpu(rp->system_page_size)) {
 		memcpy(trp, rp, le32_to_cpu(rp->system_page_size));
 	} else {
@@ -394,8 +394,8 @@ static int ntfs_check_and_load_restart_page(struct inode *vi,
 		/* Copy the remaining data one page at a time. */
 		have_read = size;
 		to_read = le32_to_cpu(rp->system_page_size) - size;
-		idx = (pos + size) >> PAGE_CACHE_SHIFT;
-		BUG_ON((pos + size) & ~PAGE_CACHE_MASK);
+		idx = (pos + size) >> PAGE_SHIFT;
+		BUG_ON((pos + size) & ~PAGE_MASK);
 		do {
 			page = ntfs_map_page(vi->i_mapping, idx);
 			if (IS_ERR(page)) {
@@ -406,7 +406,7 @@ static int ntfs_check_and_load_restart_page(struct inode *vi,
 					err = -EIO;
 				goto err_out;
-			size = min_t(int, to_read, PAGE_CACHE_SIZE);
+			size = min_t(int, to_read, PAGE_SIZE);
 			memcpy((u8*)trp + have_read, page_address(page), size);
 			have_read += size;
@@ -509,11 +509,11 @@ bool ntfs_check_logfile(struct inode *log_vi, RESTART_PAGE_HEADER **rp)
 	 * log page size if the page cache size is between the default log page
 	 * size and twice that.
-	if (PAGE_CACHE_SIZE >= DefaultLogPageSize && PAGE_CACHE_SIZE <=
+	if (PAGE_SIZE >= DefaultLogPageSize && PAGE_SIZE <=
 			DefaultLogPageSize * 2)
 		log_page_size = DefaultLogPageSize;
 	else
-		log_page_size = PAGE_CACHE_SIZE;
+		log_page_size = PAGE_SIZE;
 	log_page_mask = log_page_size - 1;
 	 * Use ntfs_ffs() instead of ffs() to enable the compiler to
@@ -539,7 +539,7 @@ bool ntfs_check_logfile(struct inode *log_vi, RESTART_PAGE_HEADER **rp)
 	 * to be empty.
 	for (pos = 0; pos < size; pos <<= 1) {
-		pgoff_t idx = pos >> PAGE_CACHE_SHIFT;
+		pgoff_t idx = pos >> PAGE_SHIFT;
 		if (!page || page->index != idx) {
 			if (page)
@@ -550,7 +550,7 @@ bool ntfs_check_logfile(struct inode *log_vi, RESTART_PAGE_HEADER **rp)
 				goto err_out;
-		kaddr = (u8*)page_address(page) + (pos & ~PAGE_CACHE_MASK);
+		kaddr = (u8*)page_address(page) + (pos & ~PAGE_MASK);
 		 * A non-empty block means the logfile is not empty while an
 		 * empty block after a non-empty block has been encountered
diff --git a/fs/ntfs/mft.c b/fs/ntfs/mft.c
index 3014a36..37b2501 100644
--- a/fs/ntfs/mft.c
+++ b/fs/ntfs/mft.c
@@ -61,16 +61,16 @@ static inline MFT_RECORD *map_mft_record_page(ntfs_inode *ni)
 	 * here if the volume was that big...
 	index = (u64)ni->mft_no << vol->mft_record_size_bits >>
-			PAGE_CACHE_SHIFT;
-	ofs = (ni->mft_no << vol->mft_record_size_bits) & ~PAGE_CACHE_MASK;
+			PAGE_SHIFT;
+	ofs = (ni->mft_no << vol->mft_record_size_bits) & ~PAGE_MASK;
 	i_size = i_size_read(mft_vi);
 	/* The maximum valid index into the page cache for $MFT's data. */
 	/* If the wanted index is out of bounds the mft record doesn't exist. */
 	if (unlikely(index >= end_index)) {
-		if (index > end_index || (i_size & ~PAGE_CACHE_MASK) < ofs +
+		if (index > end_index || (i_size & ~PAGE_MASK) < ofs +
 				vol->mft_record_size) {
 			page = ERR_PTR(-ENOENT);
 			ntfs_error(vol->sb, "Attempt to read mft record 0x%lx, "
@@ -487,7 +487,7 @@ int ntfs_sync_mft_mirror(ntfs_volume *vol, const unsigned long mft_no,
 	/* Get the page containing the mirror copy of the mft record @m. */
 	page = ntfs_map_page(vol->mftmirr_ino->i_mapping, mft_no >>
-			(PAGE_CACHE_SHIFT - vol->mft_record_size_bits));
+			(PAGE_SHIFT - vol->mft_record_size_bits));
 	if (IS_ERR(page)) {
 		ntfs_error(vol->sb, "Failed to map mft mirror page.");
@@ -497,7 +497,7 @@ int ntfs_sync_mft_mirror(ntfs_volume *vol, const unsigned long mft_no,
 	ClearPageUptodate(page);
 	/* Offset of the mft mirror record inside the page. */
-	page_ofs = (mft_no << vol->mft_record_size_bits) & ~PAGE_CACHE_MASK;
+	page_ofs = (mft_no << vol->mft_record_size_bits) & ~PAGE_MASK;
 	/* The address in the page of the mirror copy of the mft record @m. */
 	kmirr = page_address(page) + page_ofs;
 	/* Copy the mst protected mft record to the mirror. */
@@ -1178,8 +1178,8 @@ static int ntfs_mft_bitmap_find_and_alloc_free_rec_nolock(ntfs_volume *vol,
 	for (; pass <= 2;) {
 		/* Cap size to pass_end. */
 		ofs = data_pos >> 3;
-		page_ofs = ofs & ~PAGE_CACHE_MASK;
-		size = PAGE_CACHE_SIZE - page_ofs;
+		page_ofs = ofs & ~PAGE_MASK;
+		size = PAGE_SIZE - page_ofs;
 		ll = ((pass_end + 7) >> 3) - ofs;
 		if (size > ll)
 			size = ll;
@@ -1190,7 +1190,7 @@ static int ntfs_mft_bitmap_find_and_alloc_free_rec_nolock(ntfs_volume *vol,
 		if (size) {
 			page = ntfs_map_page(mftbmp_mapping,
-					ofs >> PAGE_CACHE_SHIFT);
+					ofs >> PAGE_SHIFT);
 			if (IS_ERR(page)) {
 				ntfs_error(vol->sb, "Failed to read mft "
 						"bitmap, aborting.");
@@ -1328,13 +1328,13 @@ static int ntfs_mft_bitmap_extend_allocation_nolock(ntfs_volume *vol)
 	ll = lcn >> 3;
 	page = ntfs_map_page(vol->lcnbmp_ino->i_mapping,
-			ll >> PAGE_CACHE_SHIFT);
+			ll >> PAGE_SHIFT);
 	if (IS_ERR(page)) {
 		up_write(&mftbmp_ni->runlist.lock);
 		ntfs_error(vol->sb, "Failed to read from lcn bitmap.");
 		return PTR_ERR(page);
-	b = (u8*)page_address(page) + (ll & ~PAGE_CACHE_MASK);
+	b = (u8*)page_address(page) + (ll & ~PAGE_MASK);
 	tb = 1 << (lcn & 7ull);
 	down_write(&vol->lcnbmp_lock);
 	if (*b != 0xff && !(*b & tb)) {
@@ -2103,14 +2103,14 @@ static int ntfs_mft_record_format(const ntfs_volume *vol, const s64 mft_no)
 	 * The index into the page cache and the offset within the page cache
 	 * page of the wanted mft record.
-	index = mft_no << vol->mft_record_size_bits >> PAGE_CACHE_SHIFT;
-	ofs = (mft_no << vol->mft_record_size_bits) & ~PAGE_CACHE_MASK;
+	index = mft_no << vol->mft_record_size_bits >> PAGE_SHIFT;
+	ofs = (mft_no << vol->mft_record_size_bits) & ~PAGE_MASK;
-	end_index = i_size >> PAGE_CACHE_SHIFT;
+	end_index = i_size >> PAGE_SHIFT;
 		if (unlikely(index > end_index || ofs + vol->mft_record_size >=
-				(i_size & ~PAGE_CACHE_MASK))) {
+				(i_size & ~PAGE_MASK))) {
 			ntfs_error(vol->sb, "Tried to format non-existing mft "
 					"record 0x%llx.", (long long)mft_no);
 			return -ENOENT;
@@ -2515,8 +2515,8 @@ mft_rec_already_initialized:
 	 * We now have allocated and initialized the mft record.  Calculate the
 	 * index of and the offset within the page cache page the record is in.
-	index = bit << vol->mft_record_size_bits >> PAGE_CACHE_SHIFT;
-	ofs = (bit << vol->mft_record_size_bits) & ~PAGE_CACHE_MASK;
+	index = bit << vol->mft_record_size_bits >> PAGE_SHIFT;
+	ofs = (bit << vol->mft_record_size_bits) & ~PAGE_MASK;
 	/* Read, map, and pin the page containing the mft record. */
 	page = ntfs_map_page(vol->mft_ino->i_mapping, index);
 	if (IS_ERR(page)) {
diff --git a/fs/ntfs/ntfs.h b/fs/ntfs/ntfs.h
index c581e26..12de47b 100644
--- a/fs/ntfs/ntfs.h
+++ b/fs/ntfs/ntfs.h
@@ -43,7 +43,7 @@ typedef enum {
 	NTFS_MAX_NAME_LEN	= 255,
 	NTFS_MAX_ATTR_NAME_LEN	= 255,
 	NTFS_MAX_CLUSTER_SIZE	= 64 * 1024,	/* 64kiB */
-	NTFS_MAX_PAGES_PER_CLUSTER = NTFS_MAX_CLUSTER_SIZE / PAGE_CACHE_SIZE,
+	NTFS_MAX_PAGES_PER_CLUSTER = NTFS_MAX_CLUSTER_SIZE / PAGE_SIZE,
 } NTFS_CONSTANTS;
 /* Global variables. */
diff --git a/fs/ntfs/super.c b/fs/ntfs/super.c
index 1b38abd..ab2b093 100644
--- a/fs/ntfs/super.c
+++ b/fs/ntfs/super.c
@@ -826,11 +826,11 @@ static bool parse_ntfs_boot_sector(ntfs_volume *vol, const NTFS_BOOT_SECTOR *b)
 	 * We cannot support mft record sizes above the PAGE_CACHE_SIZE since
 	 * we store $MFT/$DATA, the table of mft records in the page cache.
-	if (vol->mft_record_size > PAGE_CACHE_SIZE) {
+	if (vol->mft_record_size > PAGE_SIZE) {
 		ntfs_error(vol->sb, "Mft record size (%i) exceeds the "
 				"PAGE_CACHE_SIZE on your system (%lu).  "
 				"This is not supported.  Sorry.",
-				vol->mft_record_size, PAGE_CACHE_SIZE);
+				vol->mft_record_size, PAGE_SIZE);
 		return false;
 	/* We cannot support mft record sizes below the sector size. */
@@ -1096,7 +1096,7 @@ static bool check_mft_mirror(ntfs_volume *vol)
 	ntfs_debug("Entering.");
 	/* Compare contents of $MFT and $MFTMirr. */
-	mrecs_per_page = PAGE_CACHE_SIZE / vol->mft_record_size;
+	mrecs_per_page = PAGE_SIZE / vol->mft_record_size;
 	BUG_ON(!mrecs_per_page);
 	BUG_ON(!vol->mftmirr_size);
 	mft_page = mirr_page = NULL;
@@ -1615,20 +1615,20 @@ static bool load_and_init_attrdef(ntfs_volume *vol)
 	if (!vol->attrdef)
 		goto iput_failed;
 	index = 0;
-	max_index = i_size >> PAGE_CACHE_SHIFT;
+	max_index = i_size >> PAGE_SHIFT;
+	size = PAGE_SIZE;
 	while (index < max_index) {
 		/* Read the attrdef table and copy it into the linear buffer. */
 read_partial_attrdef_page:
 		page = ntfs_map_page(ino->i_mapping, index);
 		if (IS_ERR(page))
 			goto free_iput_failed;
-		memcpy((u8*)vol->attrdef + (index++ << PAGE_CACHE_SHIFT),
+		memcpy((u8*)vol->attrdef + (index++ << PAGE_SHIFT),
-	if (size == PAGE_CACHE_SIZE) {
-		size = i_size & ~PAGE_CACHE_MASK;
+	if (size == PAGE_SIZE) {
+		size = i_size & ~PAGE_MASK;
 		if (size)
 			goto read_partial_attrdef_page;
@@ -1684,20 +1684,20 @@ static bool load_and_init_upcase(ntfs_volume *vol)
 	if (!vol->upcase)
 		goto iput_upcase_failed;
 	index = 0;
+	size = PAGE_SIZE;
 		/* Read the upcase table and copy it into the linear buffer. */
 read_partial_upcase_page:
 		if (IS_ERR(page))
-		memcpy((char*)vol->upcase + (index++ << PAGE_CACHE_SHIFT),
+		memcpy((char*)vol->upcase + (index++ << PAGE_SHIFT),
 		if (size)
 			goto read_partial_upcase_page;
@@ -2474,11 +2474,11 @@ static s64 get_nr_free_clusters(ntfs_volume *vol)
 	 * multiples of PAGE_CACHE_SIZE, rounding up so that if we have one
 	 * full and one partial page max_index = 2.
-	max_index = (((vol->nr_clusters + 7) >> 3) + PAGE_CACHE_SIZE - 1) >>
-			PAGE_CACHE_SHIFT;
+	max_index = (((vol->nr_clusters + 7) >> 3) + PAGE_SIZE - 1) >>
+			PAGE_SHIFT;
 	/* Use multiples of 4 bytes, thus max_size is PAGE_CACHE_SIZE / 4. */
 	ntfs_debug("Reading $Bitmap, max_index = 0x%lx, max_size = 0x%lx.",
-			max_index, PAGE_CACHE_SIZE / 4);
+			max_index, PAGE_SIZE / 4);
 	for (index = 0; index < max_index; index++) {
 		unsigned long *kaddr;
@@ -2491,7 +2491,7 @@ static s64 get_nr_free_clusters(ntfs_volume *vol)
 		if (IS_ERR(page)) {
 			ntfs_debug("read_mapping_page() error. Skipping "
 					"page (index 0x%lx).", index);
-			nr_free -= PAGE_CACHE_SIZE * 8;
+			nr_free -= PAGE_SIZE * 8;
 			continue;
@@ -2503,9 +2503,9 @@ static s64 get_nr_free_clusters(ntfs_volume *vol)
 		 * ntfs_readpage().
 		nr_free -= bitmap_weight(kaddr,
-					PAGE_CACHE_SIZE * BITS_PER_BYTE);
+					PAGE_SIZE * BITS_PER_BYTE);
+		put_page(page);
 	ntfs_debug("Finished reading $Bitmap, last index = 0x%lx.", index - 1);
@@ -2549,7 +2549,7 @@ static unsigned long __get_nr_free_mft_records(ntfs_volume *vol,
 	ntfs_debug("Reading $MFT/$BITMAP, max_index = 0x%lx, max_size = "
-			"0x%lx.", max_index, PAGE_CACHE_SIZE / 4);
+			"0x%lx.", max_index, PAGE_SIZE / 4);
@@ -2562,7 +2562,7 @@ static unsigned long __get_nr_free_mft_records(ntfs_volume *vol,
 		if (IS_ERR(page)) {
 			continue;
@@ -2574,9 +2574,9 @@ static unsigned long __get_nr_free_mft_records(ntfs_volume *vol,
 		 * ntfs_readpage().
+		put_page(page);
 	ntfs_debug("Finished reading $MFT/$BITMAP, last index = 0x%lx.",
 			index - 1);
@@ -2618,17 +2618,17 @@ static int ntfs_statfs(struct dentry *dentry, struct kstatfs *sfs)
 	/* Type of filesystem. */
 	sfs->f_type   = NTFS_SB_MAGIC;
 	/* Optimal transfer block size. */
-	sfs->f_bsize  = PAGE_CACHE_SIZE;
+	sfs->f_bsize  = PAGE_SIZE;
 	 * Total data blocks in filesystem in units of f_bsize and since
 	 * inodes are also stored in data blocs ($MFT is a file) this is just
 	 * the total clusters.
 	sfs->f_blocks = vol->nr_clusters << vol->cluster_size_bits >>
-				PAGE_CACHE_SHIFT;
+				PAGE_SHIFT;
 	/* Free data blocks in filesystem in units of f_bsize. */
 	size	      = get_nr_free_clusters(vol) << vol->cluster_size_bits >>
-				PAGE_CACHE_SHIFT;
+				PAGE_SHIFT;
 	if (size < 0LL)
 		size = 0LL;
 	/* Free blocks avail to non-superuser, same as above on NTFS. */
@@ -2643,7 +2643,7 @@ static int ntfs_statfs(struct dentry *dentry, struct kstatfs *sfs)
 	 * have one full and one partial page max_index = 2.
 	max_index = ((((mft_ni->initialized_size >> vol->mft_record_size_bits)
-			+ 7) >> 3) + PAGE_CACHE_SIZE - 1) >> PAGE_CACHE_SHIFT;
+			+ 7) >> 3) + PAGE_SIZE - 1) >> PAGE_SHIFT;
 	read_unlock_irqrestore(&mft_ni->size_lock, flags);
 	/* Number of inodes in filesystem (at this point in time). */
 	sfs->f_files = size;
@@ -2766,14 +2766,14 @@ static int ntfs_fill_super(struct super_block *sb, void *opt, const int silent)
 		goto err_out_now;
 	/* We support sector sizes up to the PAGE_CACHE_SIZE. */
-	if (bdev_logical_block_size(sb->s_bdev) > PAGE_CACHE_SIZE) {
+	if (bdev_logical_block_size(sb->s_bdev) > PAGE_SIZE) {
 		if (!silent)
 			ntfs_error(sb, "Device has unsupported sector size "
 					"(%i).  The maximum supported sector "
 					"size on this architecture is %lu "
 					"bytes.",
 					bdev_logical_block_size(sb->s_bdev),
-					PAGE_CACHE_SIZE);
+					PAGE_SIZE);
 		goto err_out_now;
diff --git a/fs/ocfs2/alloc.c b/fs/ocfs2/alloc.c
index 70907d6..e361d1a 100644
--- a/fs/ocfs2/alloc.c
+++ b/fs/ocfs2/alloc.c
@@ -6671,7 +6671,7 @@ static void ocfs2_zero_cluster_pages(struct inode *inode, loff_t start,
 	int i;
 	struct page *page;
-	unsigned int from, to = PAGE_CACHE_SIZE;
+	unsigned int from, to = PAGE_SIZE;
 	BUG_ON(!ocfs2_sparse_alloc(OCFS2_SB(sb)));
@@ -6679,21 +6679,21 @@ static void ocfs2_zero_cluster_pages(struct inode *inode, loff_t start,
 	if (numpages == 0)
 		goto out;
-	to = PAGE_CACHE_SIZE;
+	to = PAGE_SIZE;
 	for(i = 0; i < numpages; i++) {
 		page = pages[i];
-		from = start & (PAGE_CACHE_SIZE - 1);
-		if ((end >> PAGE_CACHE_SHIFT) == page->index)
-			to = end & (PAGE_CACHE_SIZE - 1);
+		from = start & (PAGE_SIZE - 1);
+		if ((end >> PAGE_SHIFT) == page->index)
+			to = end & (PAGE_SIZE - 1);
-		BUG_ON(from > PAGE_CACHE_SIZE);
-		BUG_ON(to > PAGE_CACHE_SIZE);
+		BUG_ON(from > PAGE_SIZE);
+		BUG_ON(to > PAGE_SIZE);
 		ocfs2_map_and_dirty_page(inode, handle, from, to, page, 1,
 					 &phys);
-		start = (page->index + 1) << PAGE_CACHE_SHIFT;
+		start = (page->index + 1) << PAGE_SHIFT;
 out:
 	if (pages)
@@ -6712,7 +6712,7 @@ int ocfs2_grab_pages(struct inode *inode, loff_t start, loff_t end,
 	numpages = 0;
 	last_page_bytes = PAGE_ALIGN(end);
-	index = start >> PAGE_CACHE_SHIFT;
+	index = start >> PAGE_SHIFT;
 	do {
 		pages[numpages] = find_or_create_page(mapping, index, GFP_NOFS);
 		if (!pages[numpages]) {
@@ -6723,7 +6723,7 @@ int ocfs2_grab_pages(struct inode *inode, loff_t start, loff_t end,
 		numpages++;
 		index++;
-	} while (index < (last_page_bytes >> PAGE_CACHE_SHIFT));
+	} while (index < (last_page_bytes >> PAGE_SHIFT));
 out:
 	if (ret != 0) {
@@ -6950,8 +6950,8 @@ int ocfs2_convert_inline_data_to_extents(struct inode *inode,
 		 * to do that now.
 		if (!ocfs2_sparse_alloc(osb) &&
-		    PAGE_CACHE_SIZE < osb->s_clustersize)
-			end = PAGE_CACHE_SIZE;
+		    PAGE_SIZE < osb->s_clustersize)
+			end = PAGE_SIZE;
 		ret = ocfs2_grab_eof_pages(inode, 0, end, pages, &num_pages);
 		if (ret) {
@@ -6971,8 +6971,8 @@ int ocfs2_convert_inline_data_to_extents(struct inode *inode,
 			goto out_unlock;
-		page_end = PAGE_CACHE_SIZE;
-		if (PAGE_CACHE_SIZE > osb->s_clustersize)
+		page_end = PAGE_SIZE;
+		if (PAGE_SIZE > osb->s_clustersize)
 			page_end = osb->s_clustersize;
 		for (i = 0; i < num_pages; i++)
diff --git a/fs/ocfs2/aops.c b/fs/ocfs2/aops.c
index 1581240..ce5dc4f 100644
--- a/fs/ocfs2/aops.c
+++ b/fs/ocfs2/aops.c
@@ -234,7 +234,7 @@ int ocfs2_read_inline_data(struct inode *inode, struct page *page,
-	if (size > PAGE_CACHE_SIZE ||
+	if (size > PAGE_SIZE ||
 	    size > ocfs2_max_inline_data_with_xattr(inode->i_sb, di)) {
 		ocfs2_error(inode->i_sb,
 			    "Inode %llu has with inline data has bad size: %Lu\n",
@@ -247,7 +247,7 @@ int ocfs2_read_inline_data(struct inode *inode, struct page *page,
 	if (size)
 		memcpy(kaddr, di->id2.i_data.id_data, size);
 	/* Clear the remaining part of the page */
-	memset(kaddr + size, 0, PAGE_CACHE_SIZE - size);
+	memset(kaddr + size, 0, PAGE_SIZE - size);
@@ -282,7 +282,7 @@ static int ocfs2_readpage(struct file *file, struct page *page)
 	struct inode *inode = page->mapping->host;
 	struct ocfs2_inode_info *oi = OCFS2_I(inode);
-	loff_t start = (loff_t)page->index << PAGE_CACHE_SHIFT;
+	loff_t start = (loff_t)page->index << PAGE_SHIFT;
 	int ret, unlock = 1;
 	trace_ocfs2_readpage((unsigned long long)oi->ip_blkno,
@@ -385,7 +385,7 @@ static int ocfs2_readpages(struct file *filp, struct address_space *mapping,
 	 * drop out in that case as it's not worth handling here.
 	last = list_entry(pages->prev, struct page, lru);
-	start = (loff_t)last->index << PAGE_CACHE_SHIFT;
+	start = (loff_t)last->index << PAGE_SHIFT;
 	if (start >= i_size_read(inode))
 		goto out_unlock;
@@ -511,12 +511,12 @@ static void ocfs2_figure_cluster_boundaries(struct ocfs2_super *osb,
 					    unsigned int *start,
 					    unsigned int *end)
-	unsigned int cluster_start = 0, cluster_end = PAGE_CACHE_SIZE;
+	unsigned int cluster_start = 0, cluster_end = PAGE_SIZE;
-	if (unlikely(PAGE_CACHE_SHIFT > osb->s_clustersize_bits)) {
+	if (unlikely(PAGE_SHIFT > osb->s_clustersize_bits)) {
 		unsigned int cpp;
-		cpp = 1 << (PAGE_CACHE_SHIFT - osb->s_clustersize_bits);
+		cpp = 1 << (PAGE_SHIFT - osb->s_clustersize_bits);
 		cluster_start = cpos % cpp;
 		cluster_start = cluster_start << osb->s_clustersize_bits;
@@ -687,10 +687,10 @@ next_bh:
 #if (PAGE_CACHE_SIZE >= OCFS2_MAX_CLUSTERSIZE)
 #define OCFS2_MAX_CTXT_PAGES	1
 #else
-#define OCFS2_MAX_CTXT_PAGES	(OCFS2_MAX_CLUSTERSIZE / PAGE_CACHE_SIZE)
+#define OCFS2_MAX_CTXT_PAGES	(OCFS2_MAX_CLUSTERSIZE / PAGE_SIZE)
 #endif
-#define OCFS2_MAX_CLUSTERS_PER_PAGE	(PAGE_CACHE_SIZE / OCFS2_MIN_CLUSTERSIZE)
+#define OCFS2_MAX_CLUSTERS_PER_PAGE	(PAGE_SIZE / OCFS2_MIN_CLUSTERSIZE)
 struct ocfs2_unwritten_extent {
 	struct list_head	ue_node;
@@ -785,7 +785,7 @@ void ocfs2_unlock_and_free_pages(struct page **pages, int num_pages)
 		if (pages[i]) {
 			unlock_page(pages[i]);
 			mark_page_accessed(pages[i]);
-			page_cache_release(pages[i]);
+			put_page(pages[i]);
@@ -808,7 +808,7 @@ static void ocfs2_unlock_pages(struct ocfs2_write_ctxt *wc)
 		mark_page_accessed(wc->w_target_page);
-		page_cache_release(wc->w_target_page);
+		put_page(wc->w_target_page);
 	ocfs2_unlock_and_free_pages(wc->w_pages, wc->w_num_pages);
@@ -857,7 +857,7 @@ static int ocfs2_alloc_write_ctxt(struct ocfs2_write_ctxt **wcp,
 	wc->w_di_bh = di_bh;
 	wc->w_type = type;
 		wc->w_large_pages = 1;
 	else
 		wc->w_large_pages = 0;
@@ -920,7 +920,7 @@ static void ocfs2_write_failure(struct inode *inode,
 				loff_t user_pos, unsigned user_len)
 	int i;
-	unsigned from = user_pos & (PAGE_CACHE_SIZE - 1),
+	unsigned from = user_pos & (PAGE_SIZE - 1),
 		to = user_pos + user_len;
 	struct page *tmppage;
@@ -960,7 +960,7 @@ static int ocfs2_prepare_page_for_write(struct inode *inode, u64 *p_blkno,
 			(page_offset(page) <= user_pos));
 	if (page == wc->w_target_page) {
-		map_from = user_pos & (PAGE_CACHE_SIZE - 1);
+		map_from = user_pos & (PAGE_SIZE - 1);
 		map_to = map_from + user_len;
 		if (new)
@@ -1034,7 +1034,7 @@ static int ocfs2_grab_pages_for_write(struct address_space *mapping,
 	loff_t last_byte;
-	target_index = user_pos >> PAGE_CACHE_SHIFT;
+	target_index = user_pos >> PAGE_SHIFT;
 	 * Figure out how many pages we'll be manipulating here. For
@@ -1053,14 +1053,14 @@ static int ocfs2_grab_pages_for_write(struct address_space *mapping,
 		last_byte = max(user_pos + user_len, i_size_read(inode));
 		BUG_ON(last_byte < 1);
-		end_index = ((last_byte - 1) >> PAGE_CACHE_SHIFT) + 1;
+		end_index = ((last_byte - 1) >> PAGE_SHIFT) + 1;
 		if ((start + wc->w_num_pages) > end_index)
 			wc->w_num_pages = end_index - start;
 	} else {
 		wc->w_num_pages = 1;
 		start = target_index;
-	end_index = (user_pos + user_len - 1) >> PAGE_CACHE_SHIFT;
+	end_index = (user_pos + user_len - 1) >> PAGE_SHIFT;
 	for(i = 0; i < wc->w_num_pages; i++) {
 		index = start + i;
@@ -1082,7 +1082,7 @@ static int ocfs2_grab_pages_for_write(struct address_space *mapping,
 				goto out;
-			page_cache_get(mmap_page);
+			get_page(mmap_page);
 			wc->w_pages[i] = mmap_page;
 			wc->w_target_locked = true;
 		} else if (index >= target_index && index <= end_index &&
@@ -1272,7 +1272,7 @@ static void ocfs2_set_target_boundaries(struct ocfs2_super *osb,
 	struct ocfs2_write_cluster_desc *desc;
-	wc->w_target_from = pos & (PAGE_CACHE_SIZE - 1);
+	wc->w_target_from = pos & (PAGE_SIZE - 1);
 	wc->w_target_to = wc->w_target_from + len;
 	if (alloc == 0)
@@ -1309,7 +1309,7 @@ static void ocfs2_set_target_boundaries(struct ocfs2_super *osb,
 							&wc->w_target_to);
 	} else {
 		wc->w_target_from = 0;
-		wc->w_target_to = PAGE_CACHE_SIZE;
+		wc->w_target_to = PAGE_SIZE;
@@ -1981,7 +1981,7 @@ int ocfs2_write_end_nolock(struct address_space *mapping,
 			   struct page *page, void *fsdata)
 	int i, ret;
-	unsigned from, to, start = pos & (PAGE_CACHE_SIZE - 1);
+	unsigned from, to, start = pos & (PAGE_SIZE - 1);
 	struct ocfs2_super *osb = OCFS2_SB(inode->i_sb);
 	struct ocfs2_write_ctxt *wc = fsdata;
@@ -2027,8 +2027,8 @@ int ocfs2_write_end_nolock(struct address_space *mapping,
 			from = wc->w_target_from;
 			to = wc->w_target_to;
-			BUG_ON(from > PAGE_CACHE_SIZE ||
-			       to > PAGE_CACHE_SIZE ||
+			BUG_ON(from > PAGE_SIZE ||
+			       to > PAGE_SIZE ||
 			       to < from);
 		} else {
@@ -2037,7 +2037,7 @@ int ocfs2_write_end_nolock(struct address_space *mapping,
 			 * to flush their entire range.
 			from = 0;
+			to = PAGE_SIZE;
 		if (page_has_buffers(tmppage)) {
diff --git a/fs/ocfs2/cluster/heartbeat.c b/fs/ocfs2/cluster/heartbeat.c
index bd15929..1934abb 100644
--- a/fs/ocfs2/cluster/heartbeat.c
+++ b/fs/ocfs2/cluster/heartbeat.c
@@ -417,13 +417,13 @@ static struct bio *o2hb_setup_one_bio(struct o2hb_region *reg,
 	bio->bi_private = wc;
 	bio->bi_end_io = o2hb_bio_end_io;
-	vec_start = (cs << bits) % PAGE_CACHE_SIZE;
+	vec_start = (cs << bits) % PAGE_SIZE;
 	while(cs < max_slots) {
 		current_page = cs / spp;
 		page = reg->hr_slot_data[current_page];
-		vec_len = min(PAGE_CACHE_SIZE - vec_start,
-			      (max_slots-cs) * (PAGE_CACHE_SIZE/spp) );
+		vec_len = min(PAGE_SIZE - vec_start,
+			      (max_slots-cs) * (PAGE_SIZE/spp) );
 		mlog(ML_HB_BIO, "page %d, vec_len = %u, vec_start = %u\n",
 		     current_page, vec_len, vec_start);
@@ -431,7 +431,7 @@ static struct bio *o2hb_setup_one_bio(struct o2hb_region *reg,
 		len = bio_add_page(bio, page, vec_len, vec_start);
 		if (len != vec_len) break;
-		cs += vec_len / (PAGE_CACHE_SIZE/spp);
+		cs += vec_len / (PAGE_SIZE/spp);
 		vec_start = 0;
@@ -1576,7 +1576,7 @@ static ssize_t o2hb_region_dev_show(struct config_item *item, char *page)
 static void o2hb_init_region_params(struct o2hb_region *reg)
-	reg->hr_slots_per_page = PAGE_CACHE_SIZE >> reg->hr_block_bits;
+	reg->hr_slots_per_page = PAGE_SIZE >> reg->hr_block_bits;
 	reg->hr_timeout_ms = O2HB_REGION_TIMEOUT_MS;
 	mlog(ML_HEARTBEAT, "hr_start_block = %llu, hr_blocks = %u\n",
diff --git a/fs/ocfs2/dlmfs/dlmfs.c b/fs/ocfs2/dlmfs/dlmfs.c
index 03768bb..47b3b2d 100644
--- a/fs/ocfs2/dlmfs/dlmfs.c
+++ b/fs/ocfs2/dlmfs/dlmfs.c
@@ -571,8 +571,8 @@ static int dlmfs_fill_super(struct super_block * sb,
 			    int silent)
 	sb->s_maxbytes = MAX_LFS_FILESIZE;
-	sb->s_blocksize = PAGE_CACHE_SIZE;
-	sb->s_blocksize_bits = PAGE_CACHE_SHIFT;
+	sb->s_blocksize = PAGE_SIZE;
+	sb->s_blocksize_bits = PAGE_SHIFT;
 	sb->s_magic = DLMFS_MAGIC;
 	sb->s_op = &dlmfs_ops;
 	sb->s_root = d_make_root(dlmfs_get_root_inode(sb));
diff --git a/fs/ocfs2/file.c b/fs/ocfs2/file.c
index c18ab45..5308841 100644
--- a/fs/ocfs2/file.c
+++ b/fs/ocfs2/file.c
@@ -770,14 +770,14 @@ static int ocfs2_write_zero_page(struct inode *inode, u64 abs_from,
 	struct address_space *mapping = inode->i_mapping;
 	struct page *page;
-	unsigned long index = abs_from >> PAGE_CACHE_SHIFT;
+	unsigned long index = abs_from >> PAGE_SHIFT;
 	handle_t *handle;
 	int ret = 0;
 	unsigned zero_from, zero_to, block_start, block_end;
 	struct ocfs2_dinode *di = (struct ocfs2_dinode *)di_bh->b_data;
 	BUG_ON(abs_from >= abs_to);
-	BUG_ON(abs_to > (((u64)index + 1) << PAGE_CACHE_SHIFT));
+	BUG_ON(abs_to > (((u64)index + 1) << PAGE_SHIFT));
 	BUG_ON(abs_from & (inode->i_blkbits - 1));
 	handle = ocfs2_zero_start_ordered_transaction(inode, di_bh);
@@ -794,10 +794,10 @@ static int ocfs2_write_zero_page(struct inode *inode, u64 abs_from,
 	/* Get the offsets within the page that we want to zero */
-	zero_from = abs_from & (PAGE_CACHE_SIZE - 1);
-	zero_to = abs_to & (PAGE_CACHE_SIZE - 1);
+	zero_from = abs_from & (PAGE_SIZE - 1);
+	zero_to = abs_to & (PAGE_SIZE - 1);
 	if (!zero_to)
-		zero_to = PAGE_CACHE_SIZE;
+		zero_to = PAGE_SIZE;
 	trace_ocfs2_write_zero_page(
 			(unsigned long long)OCFS2_I(inode)->ip_blkno,
@@ -851,7 +851,7 @@ static int ocfs2_write_zero_page(struct inode *inode, u64 abs_from,
 out_unlock:
 	unlock_page(page);
+	put_page(page);
 out_commit_trans:
 	if (handle)
 		ocfs2_commit_trans(OCFS2_SB(inode->i_sb), handle);
@@ -959,7 +959,7 @@ static int ocfs2_zero_extend_range(struct inode *inode, u64 range_start,
 	BUG_ON(range_start >= range_end);
 	while (zero_pos < range_end) {
-		next_pos = (zero_pos & PAGE_CACHE_MASK) + PAGE_CACHE_SIZE;
+		next_pos = (zero_pos & PAGE_MASK) + PAGE_SIZE;
 		if (next_pos > range_end)
 			next_pos = range_end;
 		rc = ocfs2_write_zero_page(inode, zero_pos, next_pos, di_bh);
diff --git a/fs/ocfs2/mmap.c b/fs/ocfs2/mmap.c
index 9ea081f..71545ad 100644
--- a/fs/ocfs2/mmap.c
+++ b/fs/ocfs2/mmap.c
@@ -65,13 +65,13 @@ static int __ocfs2_page_mkwrite(struct file *file, struct buffer_head *di_bh,
 	struct inode *inode = file_inode(file);
 	loff_t pos = page_offset(page);
-	unsigned int len = PAGE_CACHE_SIZE;
+	unsigned int len = PAGE_SIZE;
 	pgoff_t last_index;
 	struct page *locked_page = NULL;
 	void *fsdata;
 	loff_t size = i_size_read(inode);
-	last_index = (size - 1) >> PAGE_CACHE_SHIFT;
+	last_index = (size - 1) >> PAGE_SHIFT;
 	 * There are cases that lead to the page no longer bebongs to the
@@ -102,7 +102,7 @@ static int __ocfs2_page_mkwrite(struct file *file, struct buffer_head *di_bh,
 	 * because the "write" would invalidate their data.
 	if (page->index == last_index)
-		len = ((size - 1) & ~PAGE_CACHE_MASK) + 1;
+		len = ((size - 1) & ~PAGE_MASK) + 1;
 	ret = ocfs2_write_begin_nolock(mapping, pos, len, OCFS2_WRITE_MMAP,
 				       &locked_page, &fsdata, di_bh, page);
diff --git a/fs/ocfs2/ocfs2.h b/fs/ocfs2/ocfs2.h
index 6cf6538..e63af7d 100644
--- a/fs/ocfs2/ocfs2.h
+++ b/fs/ocfs2/ocfs2.h
@@ -822,10 +822,10 @@ static inline unsigned int ocfs2_page_index_to_clusters(struct super_block *sb,
 	u32 clusters = pg_index;
 	unsigned int cbits = OCFS2_SB(sb)->s_clustersize_bits;
-	if (unlikely(PAGE_CACHE_SHIFT > cbits))
-		clusters = pg_index << (PAGE_CACHE_SHIFT - cbits);
-	else if (PAGE_CACHE_SHIFT < cbits)
-		clusters = pg_index >> (cbits - PAGE_CACHE_SHIFT);
+	if (unlikely(PAGE_SHIFT > cbits))
+		clusters = pg_index << (PAGE_SHIFT - cbits);
+	else if (PAGE_SHIFT < cbits)
+		clusters = pg_index >> (cbits - PAGE_SHIFT);
 	return clusters;
@@ -839,10 +839,10 @@ static inline pgoff_t ocfs2_align_clusters_to_page_index(struct super_block *sb,
         pgoff_t index = clusters;
-	if (PAGE_CACHE_SHIFT > cbits) {
-		index = (pgoff_t)clusters >> (PAGE_CACHE_SHIFT - cbits);
-	} else if (PAGE_CACHE_SHIFT < cbits) {
-		index = (pgoff_t)clusters << (cbits - PAGE_CACHE_SHIFT);
+	if (PAGE_SHIFT > cbits) {
+		index = (pgoff_t)clusters >> (PAGE_SHIFT - cbits);
+	} else if (PAGE_SHIFT < cbits) {
+		index = (pgoff_t)clusters << (cbits - PAGE_SHIFT);
 	return index;
@@ -853,8 +853,8 @@ static inline unsigned int ocfs2_pages_per_cluster(struct super_block *sb)
 	unsigned int pages_per_cluster = 1;
-	if (PAGE_CACHE_SHIFT < cbits)
-		pages_per_cluster = 1 << (cbits - PAGE_CACHE_SHIFT);
+	if (PAGE_SHIFT < cbits)
+		pages_per_cluster = 1 << (cbits - PAGE_SHIFT);
 	return pages_per_cluster;
diff --git a/fs/ocfs2/refcounttree.c b/fs/ocfs2/refcounttree.c
index 3eff031..881242c 100644
--- a/fs/ocfs2/refcounttree.c
+++ b/fs/ocfs2/refcounttree.c
@@ -2937,16 +2937,16 @@ int ocfs2_duplicate_clusters_by_page(handle_t *handle,
 		end = i_size_read(inode);
 	while (offset < end) {
-		page_index = offset >> PAGE_CACHE_SHIFT;
-		map_end = ((loff_t)page_index + 1) << PAGE_CACHE_SHIFT;
+		page_index = offset >> PAGE_SHIFT;
+		map_end = ((loff_t)page_index + 1) << PAGE_SHIFT;
 		if (map_end > end)
 			map_end = end;
 		/* from, to is the offset within the page. */
-		from = offset & (PAGE_CACHE_SIZE - 1);
-		if (map_end & (PAGE_CACHE_SIZE - 1))
-			to = map_end & (PAGE_CACHE_SIZE - 1);
+		from = offset & (PAGE_SIZE - 1);
+		to = PAGE_SIZE;
+		if (map_end & (PAGE_SIZE - 1))
+			to = map_end & (PAGE_SIZE - 1);
 		page = find_or_create_page(mapping, page_index, GFP_NOFS);
 		if (!page) {
@@ -2959,7 +2959,7 @@ int ocfs2_duplicate_clusters_by_page(handle_t *handle,
 		 * In case PAGE_CACHE_SIZE <= CLUSTER_SIZE, This page
 		 * can't be dirtied before we CoW it out.
-		if (PAGE_CACHE_SIZE <= OCFS2_SB(sb)->s_clustersize)
+		if (PAGE_SIZE <= OCFS2_SB(sb)->s_clustersize)
 			BUG_ON(PageDirty(page));
 		if (!PageUptodate(page)) {
@@ -2987,7 +2987,7 @@ int ocfs2_duplicate_clusters_by_page(handle_t *handle,
 		mark_page_accessed(page);
 unlock:
 		unlock_page(page);
+		put_page(page);
 		page = NULL;
 		offset = map_end;
 		if (ret)
@@ -3165,8 +3165,8 @@ int ocfs2_cow_sync_writeback(struct super_block *sb,
 		if (map_end > end)
 			map_end = end;
@@ -3182,7 +3182,7 @@ int ocfs2_cow_sync_writeback(struct super_block *sb,
 		unlock_page(page);
+		put_page(page);
 		page = NULL;
 		offset = map_end;
 		if (ret)
diff --git a/fs/ocfs2/super.c b/fs/ocfs2/super.c
index 7db631e..d7cae33 100644
--- a/fs/ocfs2/super.c
+++ b/fs/ocfs2/super.c
@@ -605,8 +605,8 @@ static unsigned long long ocfs2_max_file_offset(unsigned int bbits,
 	 * We might be limited by page cache size.
-	if (bytes > PAGE_CACHE_SIZE) {
-		bytes = PAGE_CACHE_SIZE;
+	if (bytes > PAGE_SIZE) {
+		bytes = PAGE_SIZE;
 		trim = 1;
 		 * Shift by 31 here so that we don't get larger than
diff --git a/fs/orangefs/inode.c b/fs/orangefs/inode.c
index 2382e26..0166faa 100644
--- a/fs/orangefs/inode.c
+++ b/fs/orangefs/inode.c
@@ -18,8 +18,8 @@ static int read_one_page(struct page *page)
 	int max_block;
 	ssize_t bytes_read = 0;
-	const __u32 blocksize = PAGE_CACHE_SIZE;	/* inode->i_blksize */
-	const __u32 blockbits = PAGE_CACHE_SHIFT;	/* inode->i_blkbits */
+	const __u32 blocksize = PAGE_SIZE;	/* inode->i_blksize */
+	const __u32 blockbits = PAGE_SHIFT;	/* inode->i_blkbits */
 	struct iov_iter to;
 	struct bio_vec bv = {.bv_page = page, .bv_len = PAGE_SIZE};
@@ -86,7 +86,7 @@ static int orangefs_readpages(struct file *file,
 				"failure adding page to cache, read_one_page returned: %d\n",
 				ret);
 	      } else {
-			page_cache_release(page);
+			put_page(page);
 	BUG_ON(!list_empty(pages));
@@ -328,7 +328,7 @@ static int orangefs_init_iops(struct inode *inode)
 	case S_IFREG:
 		inode->i_op = &orangefs_file_inode_operations;
 		inode->i_fop = &orangefs_file_operations;
-		inode->i_blkbits = PAGE_CACHE_SHIFT;
+		inode->i_blkbits = PAGE_SHIFT;
 		break;
 	case S_IFLNK:
 		inode->i_op = &orangefs_symlink_inode_operations;
@@ -456,7 +456,7 @@ struct inode *orangefs_new_inode(struct super_block *sb, struct inode *dir,
 	inode->i_uid = current_fsuid();
 	inode->i_gid = current_fsgid();
 	inode->i_atime = inode->i_mtime = inode->i_ctime = CURRENT_TIME;
-	inode->i_size = PAGE_CACHE_SIZE;
+	inode->i_size = PAGE_SIZE;
 	inode->i_rdev = dev;
 	error = insert_inode_locked4(inode, hash, orangefs_test_inode, ref);
diff --git a/fs/orangefs/orangefs-bufmap.c b/fs/orangefs/orangefs-bufmap.c
index 1f8acc9..75375e9 100644
--- a/fs/orangefs/orangefs-bufmap.c
+++ b/fs/orangefs/orangefs-bufmap.c
@@ -170,7 +170,7 @@ orangefs_bufmap_unmap(struct orangefs_bufmap *bufmap)
 	int i;
 	for (i = 0; i < bufmap->page_count; i++)
-		page_cache_release(bufmap->page_array[i]);
+		put_page(bufmap->page_array[i]);
 static void
@@ -299,7 +299,7 @@ orangefs_bufmap_map(struct orangefs_bufmap *bufmap,
 		for (i = 0; i < ret; i++) {
 			SetPageError(bufmap->page_array[i]);
 		return -ENOMEM;
diff --git a/fs/orangefs/orangefs-utils.c b/fs/orangefs/orangefs-utils.c
index 40f5163..8277aba 100644
--- a/fs/orangefs/orangefs-utils.c
+++ b/fs/orangefs/orangefs-utils.c
@@ -303,7 +303,7 @@ int orangefs_inode_getattr(struct inode *inode, int new, int size)
 		break;
 	case S_IFDIR:
 		orangefs_inode->blksize = (1 << inode->i_blkbits);
 		spin_lock(&inode->i_lock);
 		inode_set_bytes(inode, inode->i_size);
diff --git a/fs/pipe.c b/fs/pipe.c
index ab8dad3..0d3f516 100644
--- a/fs/pipe.c
+++ b/fs/pipe.c
@@ -134,7 +134,7 @@ static void anon_pipe_buf_release(struct pipe_inode_info *pipe,
 	if (page_count(page) == 1 && !pipe->tmp_page)
 		pipe->tmp_page = page;
 	else
+		put_page(page);
@@ -180,7 +180,7 @@ EXPORT_SYMBOL(generic_pipe_buf_steal);
 void generic_pipe_buf_get(struct pipe_inode_info *pipe, struct pipe_buffer *buf)
-	page_cache_get(buf->page);
+	get_page(buf->page);
 EXPORT_SYMBOL(generic_pipe_buf_get);
@@ -211,7 +211,7 @@ EXPORT_SYMBOL(generic_pipe_buf_confirm);
 void generic_pipe_buf_release(struct pipe_inode_info *pipe,
-	page_cache_release(buf->page);
+	put_page(buf->page);
 EXPORT_SYMBOL(generic_pipe_buf_release);
diff --git a/fs/proc/task_mmu.c b/fs/proc/task_mmu.c
index 9df4316..229cb54 100644
--- a/fs/proc/task_mmu.c
+++ b/fs/proc/task_mmu.c
@@ -553,7 +553,7 @@ static void smaps_pte_entry(pte_t *pte, unsigned long addr,
 		if (radix_tree_exceptional_entry(page))
 			mss->swap += PAGE_SIZE;
 		else
+			put_page(page);
 		return;
diff --git a/fs/proc/vmcore.c b/fs/proc/vmcore.c
index 55bb57e..8afe10c 100644
--- a/fs/proc/vmcore.c
+++ b/fs/proc/vmcore.c
@@ -279,12 +279,12 @@ static int mmap_vmcore_fault(struct vm_area_struct *vma, struct vm_fault *vmf)
 	if (!page)
 		return VM_FAULT_OOM;
-		offset = (loff_t) index << PAGE_CACHE_SHIFT;
+		offset = (loff_t) index << PAGE_SHIFT;
 		buf = __va((page_to_pfn(page) << PAGE_SHIFT));
 		rc = __read_vmcore(buf, PAGE_SIZE, &offset, 0);
 		if (rc < 0) {
 			unlock_page(page);
+			put_page(page);
 			return (rc == -ENOMEM) ? VM_FAULT_OOM : VM_FAULT_SIGBUS;
 		SetPageUptodate(page);
diff --git a/fs/pstore/inode.c b/fs/pstore/inode.c
index dc645b6..45d6110 100644
--- a/fs/pstore/inode.c
+++ b/fs/pstore/inode.c
@@ -420,8 +420,8 @@ static int pstore_fill_super(struct super_block *sb, void *data, int silent)
 	pstore_sb = sb;
 	sb->s_magic		= PSTOREFS_MAGIC;
 	sb->s_op		= &pstore_ops;
 	sb->s_time_gran		= 1;
diff --git a/fs/qnx6/dir.c b/fs/qnx6/dir.c
index e1f3727..144ceda 100644
--- a/fs/qnx6/dir.c
+++ b/fs/qnx6/dir.c
@@ -35,9 +35,9 @@ static struct page *qnx6_get_page(struct inode *dir, unsigned long n)
 static unsigned last_entry(struct inode *inode, unsigned long page_nr)
 	unsigned long last_byte = inode->i_size;
-	last_byte -= page_nr << PAGE_CACHE_SHIFT;
-	if (last_byte > PAGE_CACHE_SIZE)
-		last_byte = PAGE_CACHE_SIZE;
+	last_byte -= page_nr << PAGE_SHIFT;
+	if (last_byte > PAGE_SIZE)
+		last_byte = PAGE_SIZE;
 	return last_byte / QNX6_DIR_ENTRY_SIZE;
@@ -47,9 +47,9 @@ static struct qnx6_long_filename *qnx6_longname(struct super_block *sb,
 	struct qnx6_sb_info *sbi = QNX6_SB(sb);
 	u32 s = fs32_to_cpu(sbi, de->de_long_inode); /* in block units */
-	u32 n = s >> (PAGE_CACHE_SHIFT - sb->s_blocksize_bits); /* in pages */
+	u32 n = s >> (PAGE_SHIFT - sb->s_blocksize_bits); /* in pages */
 	/* within page */
-	u32 offs = (s << sb->s_blocksize_bits) & ~PAGE_CACHE_MASK;
+	u32 offs = (s << sb->s_blocksize_bits) & ~PAGE_MASK;
 	struct address_space *mapping = sbi->longfile->i_mapping;
 	struct page *page = read_mapping_page(mapping, n, NULL);
 	if (IS_ERR(page))
@@ -115,8 +115,8 @@ static int qnx6_readdir(struct file *file, struct dir_context *ctx)
 	struct qnx6_sb_info *sbi = QNX6_SB(s);
 	loff_t pos = ctx->pos & ~(QNX6_DIR_ENTRY_SIZE - 1);
 	unsigned long npages = dir_pages(inode);
-	unsigned long n = pos >> PAGE_CACHE_SHIFT;
-	unsigned start = (pos & ~PAGE_CACHE_MASK) / QNX6_DIR_ENTRY_SIZE;
+	unsigned long n = pos >> PAGE_SHIFT;
+	unsigned start = (pos & ~PAGE_MASK) / QNX6_DIR_ENTRY_SIZE;
 	bool done = false;
 	ctx->pos = pos;
@@ -131,7 +131,7 @@ static int qnx6_readdir(struct file *file, struct dir_context *ctx)
 		if (IS_ERR(page)) {
 			pr_err("%s(): read failed\n", __func__);
-			ctx->pos = (n + 1) << PAGE_CACHE_SHIFT;
+			ctx->pos = (n + 1) << PAGE_SHIFT;
 		de = ((struct qnx6_dir_entry *)page_address(page)) + start;
diff --git a/fs/qnx6/inode.c b/fs/qnx6/inode.c
index 47bb1de..1192422 100644
--- a/fs/qnx6/inode.c
+++ b/fs/qnx6/inode.c
@@ -542,8 +542,8 @@ struct inode *qnx6_iget(struct super_block *sb, unsigned ino)
 		iget_failed(inode);
 		return ERR_PTR(-EIO);
-	n = (ino - 1) >> (PAGE_CACHE_SHIFT - QNX6_INODE_SIZE_BITS);
-	offs = (ino - 1) & (~PAGE_CACHE_MASK >> QNX6_INODE_SIZE_BITS);
+	n = (ino - 1) >> (PAGE_SHIFT - QNX6_INODE_SIZE_BITS);
+	offs = (ino - 1) & (~PAGE_MASK >> QNX6_INODE_SIZE_BITS);
 	mapping = sbi->inodes->i_mapping;
 	if (IS_ERR(page)) {
diff --git a/fs/qnx6/qnx6.h b/fs/qnx6/qnx6.h
index d3fb2b6..f23b5c4 100644
--- a/fs/qnx6/qnx6.h
+++ b/fs/qnx6/qnx6.h
@@ -128,7 +128,7 @@ extern struct qnx6_super_block *qnx6_mmi_fill_super(struct super_block *s,
 static inline void qnx6_put_page(struct page *page)
 	kunmap(page);
+	put_page(page);
 extern unsigned qnx6_find_entry(int len, struct inode *dir, const char *name,
diff --git a/fs/ramfs/inode.c b/fs/ramfs/inode.c
index 38981b0..1ab6e6c 100644
--- a/fs/ramfs/inode.c
+++ b/fs/ramfs/inode.c
@@ -223,8 +223,8 @@ int ramfs_fill_super(struct super_block *sb, void *data, int silent)
 		return err;
 	sb->s_magic		= RAMFS_MAGIC;
 	sb->s_op		= &ramfs_ops;
diff --git a/fs/reiserfs/file.c b/fs/reiserfs/file.c
index 9424a4b..3897737 100644
--- a/fs/reiserfs/file.c
+++ b/fs/reiserfs/file.c
@@ -180,11 +180,11 @@ int reiserfs_commit_page(struct inode *inode, struct page *page,
 	int partial = 0;
 	unsigned blocksize;
 	struct buffer_head *bh, *head;
-	unsigned long i_size_index = inode->i_size >> PAGE_CACHE_SHIFT;
+	unsigned long i_size_index = inode->i_size >> PAGE_SHIFT;
 	int new;
 	int logit = reiserfs_file_data_log(inode);
 	struct super_block *s = inode->i_sb;
-	int bh_per_page = PAGE_CACHE_SIZE / s->s_blocksize;
+	int bh_per_page = PAGE_SIZE / s->s_blocksize;
 	struct reiserfs_transaction_handle th;
 	int ret = 0;
diff --git a/fs/reiserfs/inode.c b/fs/reiserfs/inode.c
index ae9e5b3..d5c2e9c 100644
--- a/fs/reiserfs/inode.c
+++ b/fs/reiserfs/inode.c
@@ -386,7 +386,7 @@ static int _get_block_create_0(struct inode *inode, sector_t block,
 		goto finished;
 	/* read file tail into part of page */
-	offset = (cpu_key_k_offset(&key) - 1) & (PAGE_CACHE_SIZE - 1);
+	offset = (cpu_key_k_offset(&key) - 1) & (PAGE_SIZE - 1);
 	copy_item_head(&tmp_ih, ih);
@@ -587,10 +587,10 @@ static int convert_tail_for_hole(struct inode *inode,
 		return -EIO;
 	/* always try to read until the end of the block */
-	tail_start = tail_offset & (PAGE_CACHE_SIZE - 1);
+	tail_start = tail_offset & (PAGE_SIZE - 1);
 	tail_end = (tail_start | (bh_result->b_size - 1)) + 1;
-	index = tail_offset >> PAGE_CACHE_SHIFT;
+	index = tail_offset >> PAGE_SHIFT;
 	 * hole_page can be zero in case of direct_io, we are sure
 	 * that we cannot get here if we write with O_DIRECT into tail page
@@ -629,7 +629,7 @@ static int convert_tail_for_hole(struct inode *inode,
 unlock:
 	if (tail_page != hole_page) {
 		unlock_page(tail_page);
-		page_cache_release(tail_page);
+		put_page(tail_page);
 out:
 	return retval;
@@ -2189,11 +2189,11 @@ static int grab_tail_page(struct inode *inode,
 	 * we want the page with the last byte in the file,
 	 * not the page that will hold the next byte for appending
-	unsigned long index = (inode->i_size - 1) >> PAGE_CACHE_SHIFT;
+	unsigned long index = (inode->i_size - 1) >> PAGE_SHIFT;
 	unsigned long pos = 0;
 	unsigned long start = 0;
 	unsigned long blocksize = inode->i_sb->s_blocksize;
-	unsigned long offset = (inode->i_size) & (PAGE_CACHE_SIZE - 1);
+	unsigned long offset = (inode->i_size) & (PAGE_SIZE - 1);
 	struct buffer_head *bh;
 	struct buffer_head *head;
 	struct page *page;
@@ -2251,7 +2251,7 @@ out:
 unlock:
 	unlock_page(page);
+	put_page(page);
 	return error;
@@ -2265,7 +2265,7 @@ int reiserfs_truncate_file(struct inode *inode, int update_timestamps)
 	/* we want the offset for the first byte after the end of the file */
-	unsigned long offset = inode->i_size & (PAGE_CACHE_SIZE - 1);
+	unsigned long offset = inode->i_size & (PAGE_SIZE - 1);
 	unsigned blocksize = inode->i_sb->s_blocksize;
 	unsigned length;
 	struct page *page = NULL;
@@ -2345,7 +2345,7 @@ int reiserfs_truncate_file(struct inode *inode, int update_timestamps)
 		unlock_page(page);
+		put_page(page);
 	reiserfs_write_unlock(inode->i_sb);
@@ -2354,7 +2354,7 @@ int reiserfs_truncate_file(struct inode *inode, int update_timestamps)
 out:
 	if (page) {
 		unlock_page(page);
+		put_page(page);
@@ -2426,7 +2426,7 @@ research:
 	} else if (is_direct_le_ih(ih)) {
 		char *p;
 		p = page_address(bh_result->b_page);
-		p += (byte_offset - 1) & (PAGE_CACHE_SIZE - 1);
+		p += (byte_offset - 1) & (PAGE_SIZE - 1);
 		copy_size = ih_item_len(ih) - pos_in_item;
 		fs_gen = get_generation(inode->i_sb);
@@ -2525,7 +2525,7 @@ static int reiserfs_write_full_page(struct page *page,
 				    struct writeback_control *wbc)
-	unsigned long end_index = inode->i_size >> PAGE_CACHE_SHIFT;
+	unsigned long end_index = inode->i_size >> PAGE_SHIFT;
 	int error = 0;
 	unsigned long block;
 	sector_t last_block;
@@ -2535,7 +2535,7 @@ static int reiserfs_write_full_page(struct page *page,
 	int checked = PageChecked(page);
 	th.t_trans_id = 0;
 	/* no logging allowed when nonblocking or from PF_MEMALLOC */
@@ -2564,16 +2564,16 @@ static int reiserfs_write_full_page(struct page *page,
 	if (page->index >= end_index) {
 		unsigned last_offset;
-		last_offset = inode->i_size & (PAGE_CACHE_SIZE - 1);
+		last_offset = inode->i_size & (PAGE_SIZE - 1);
 		/* no file contents in this page */
 		if (page->index >= end_index + 1 || !last_offset) {
 			unlock_page(page);
 			return 0;
-		zero_user_segment(page, last_offset, PAGE_CACHE_SIZE);
+		zero_user_segment(page, last_offset, PAGE_SIZE);
 	bh = head;
-	block = page->index << (PAGE_CACHE_SHIFT - s->s_blocksize_bits);
+	block = page->index << (PAGE_SHIFT - s->s_blocksize_bits);
 	last_block = (i_size_read(inode) - 1) >> inode->i_blkbits;
 	/* first map all the buffers, logging any direct items we find */
 	do {
@@ -2774,7 +2774,7 @@ static int reiserfs_write_begin(struct file *file,
 		*fsdata = (void *)(unsigned long)flags;
-	index = pos >> PAGE_CACHE_SHIFT;
+	index = pos >> PAGE_SHIFT;
 	page = grab_cache_page_write_begin(mapping, index, flags);
 	if (!page)
 		return -ENOMEM;
@@ -2822,7 +2822,7 @@ static int reiserfs_write_begin(struct file *file,
 	if (ret) {
 		unlock_page(page);
+		put_page(page);
 		/* Truncate allocated blocks */
 		reiserfs_truncate_failed_write(inode);
@@ -2909,7 +2909,7 @@ static int reiserfs_write_end(struct file *file, struct address_space *mapping,
 	else
 		th = NULL;
-	start = pos & (PAGE_CACHE_SIZE - 1);
+	start = pos & (PAGE_SIZE - 1);
 	if (unlikely(copied < len)) {
 			copied = 0;
@@ -2974,7 +2974,7 @@ out:
 	if (locked)
 	unlock_page(page);
+	put_page(page);
 	if (pos + len > inode->i_size)
@@ -2996,7 +2996,7 @@ int reiserfs_commit_write(struct file *f, struct page *page,
 			  unsigned from, unsigned to)
-	loff_t pos = ((loff_t) page->index << PAGE_CACHE_SHIFT) + to;
+	loff_t pos = ((loff_t) page->index << PAGE_SHIFT) + to;
 	int ret = 0;
 	int update_sd = 0;
 	struct reiserfs_transaction_handle *th = NULL;
@@ -3181,7 +3181,7 @@ static void reiserfs_invalidatepage(struct page *page, unsigned int offset,
 	unsigned int curr_off = 0;
 	unsigned int stop = offset + length;
-	int partial_page = (offset || length < PAGE_CACHE_SIZE);
+	int partial_page = (offset || length < PAGE_SIZE);
 	int ret = 1;
 	BUG_ON(!PageLocked(page));
diff --git a/fs/reiserfs/ioctl.c b/fs/reiserfs/ioctl.c
index 036a1fc..57045f4 100644
--- a/fs/reiserfs/ioctl.c
+++ b/fs/reiserfs/ioctl.c
@@ -203,7 +203,7 @@ int reiserfs_unpack(struct inode *inode, struct file *filp)
 	 * __reiserfs_write_begin on that page.  This will force a
 	 * reiserfs_get_block to unpack the tail for us.
-	index = inode->i_size >> PAGE_CACHE_SHIFT;
+	index = inode->i_size >> PAGE_SHIFT;
 	page = grab_cache_page(mapping, index);
 	retval = -ENOMEM;
@@ -221,7 +221,7 @@ int reiserfs_unpack(struct inode *inode, struct file *filp)
 out_unlock:
 	unlock_page(page);
+	put_page(page);
 out:
 	inode_unlock(inode);
diff --git a/fs/reiserfs/journal.c b/fs/reiserfs/journal.c
index 44c2bdc..8c64872 100644
--- a/fs/reiserfs/journal.c
+++ b/fs/reiserfs/journal.c
@@ -605,12 +605,12 @@ static void release_buffer_page(struct buffer_head *bh)
 	struct page *page = bh->b_page;
 	if (!page->mapping && trylock_page(page)) {
-		page_cache_get(page);
+		get_page(page);
 		put_bh(bh);
 		if (!page->mapping)
 			try_to_free_buffers(page);
 		unlock_page(page);
+		put_page(page);
 	} else {
 		put_bh(bh);
diff --git a/fs/reiserfs/stree.c b/fs/reiserfs/stree.c
index 24cbe01..5feacd6 100644
--- a/fs/reiserfs/stree.c
+++ b/fs/reiserfs/stree.c
@@ -1342,7 +1342,7 @@ int reiserfs_delete_item(struct reiserfs_transaction_handle *th,
 		data = kmap_atomic(un_bh->b_page);
-		off = ((le_ih_k_offset(&s_ih) - 1) & (PAGE_CACHE_SIZE - 1));
+		off = ((le_ih_k_offset(&s_ih) - 1) & (PAGE_SIZE - 1));
 		memcpy(data + off,
 		       ih_item_body(PATH_PLAST_BUFFER(path), &s_ih),
 		       ret_value);
@@ -1511,7 +1511,7 @@ static void unmap_buffers(struct page *page, loff_t pos)
 	if (page) {
 		if (page_has_buffers(page)) {
-			tail_index = pos & (PAGE_CACHE_SIZE - 1);
+			tail_index = pos & (PAGE_SIZE - 1);
 			cur_index = 0;
 			bh = head;
diff --git a/fs/reiserfs/tail_conversion.c b/fs/reiserfs/tail_conversion.c
index f41e19b..2d5489b 100644
--- a/fs/reiserfs/tail_conversion.c
+++ b/fs/reiserfs/tail_conversion.c
@@ -151,7 +151,7 @@ int direct2indirect(struct reiserfs_transaction_handle *th, struct inode *inode,
 	if (up_to_date_bh) {
 		unsigned pgoff =
-		    (tail_offset + total_tail - 1) & (PAGE_CACHE_SIZE - 1);
+		    (tail_offset + total_tail - 1) & (PAGE_SIZE - 1);
 		char *kaddr = kmap_atomic(up_to_date_bh->b_page);
 		memset(kaddr + pgoff, 0, blk_size - total_tail);
 		kunmap_atomic(kaddr);
@@ -271,7 +271,7 @@ int indirect2direct(struct reiserfs_transaction_handle *th,
 	 * the page was locked and this part of the page was up to date when
 	 * indirect2direct was called, so we know the bytes are still valid
-	tail = tail + (pos & (PAGE_CACHE_SIZE - 1));
+	tail = tail + (pos & (PAGE_SIZE - 1));
 	PATH_LAST_POSITION(path)++;
diff --git a/fs/reiserfs/xattr.c b/fs/reiserfs/xattr.c
index 57e0b23..28f5f8b 100644
--- a/fs/reiserfs/xattr.c
+++ b/fs/reiserfs/xattr.c
@@ -415,7 +415,7 @@ out:
 static inline void reiserfs_put_page(struct page *page)
 	kunmap(page);
+	put_page(page);
 static struct page *reiserfs_get_page(struct inode *dir, size_t n)
@@ -427,7 +427,7 @@ static struct page *reiserfs_get_page(struct inode *dir, size_t n)
 	 * and an unlink/rmdir has just occurred - GFP_NOFS avoids this
 	mapping_set_gfp_mask(mapping, GFP_NOFS);
-	page = read_mapping_page(mapping, n >> PAGE_CACHE_SHIFT, NULL);
+	page = read_mapping_page(mapping, n >> PAGE_SHIFT, NULL);
 	if (!IS_ERR(page)) {
 		kmap(page);
 		if (PageError(page))
@@ -526,10 +526,10 @@ reiserfs_xattr_set_handle(struct reiserfs_transaction_handle *th,
 	while (buffer_pos < buffer_size || buffer_pos == 0) {
 		size_t chunk;
 		size_t skip = 0;
-		size_t page_offset = (file_pos & (PAGE_CACHE_SIZE - 1));
+		size_t page_offset = (file_pos & (PAGE_SIZE - 1));
-		if (buffer_size - buffer_pos > PAGE_CACHE_SIZE)
-			chunk = PAGE_CACHE_SIZE;
+		if (buffer_size - buffer_pos > PAGE_SIZE)
+			chunk = PAGE_SIZE;
 		else
 			chunk = buffer_size - buffer_pos;
@@ -546,8 +546,8 @@ reiserfs_xattr_set_handle(struct reiserfs_transaction_handle *th,
 			struct reiserfs_xattr_header *rxh;
 			skip = file_pos = sizeof(struct reiserfs_xattr_header);
-			if (chunk + skip > PAGE_CACHE_SIZE)
-				chunk = PAGE_CACHE_SIZE - skip;
+			if (chunk + skip > PAGE_SIZE)
+				chunk = PAGE_SIZE - skip;
 			rxh = (struct reiserfs_xattr_header *)data;
 			rxh->h_magic = cpu_to_le32(REISERFS_XATTR_MAGIC);
 			rxh->h_hash = cpu_to_le32(xahash);
@@ -675,8 +675,8 @@ reiserfs_xattr_get(struct inode *inode, const char *name, void *buffer,
 		char *data;
 		size_t skip = 0;
-		if (isize - file_pos > PAGE_CACHE_SIZE)
+		if (isize - file_pos > PAGE_SIZE)
 		else
 			chunk = isize - file_pos;
diff --git a/fs/splice.c b/fs/splice.c
index 9947b5c..b018eb4 100644
--- a/fs/splice.c
+++ b/fs/splice.c
@@ -88,7 +88,7 @@ out_unlock:
 static void page_cache_pipe_buf_release(struct pipe_inode_info *pipe,
 	buf->flags &= ~PIPE_BUF_FLAG_LRU;
@@ -268,7 +268,7 @@ EXPORT_SYMBOL_GPL(splice_to_pipe);
 void spd_release_page(struct splice_pipe_desc *spd, unsigned int i)
-	page_cache_release(spd->pages[i]);
+	put_page(spd->pages[i]);
@@ -328,9 +328,9 @@ __generic_file_splice_read(struct file *in, loff_t *ppos,
 	if (splice_grow_spd(pipe, &spd))
 		return -ENOMEM;
-	index = *ppos >> PAGE_CACHE_SHIFT;
-	loff = *ppos & ~PAGE_CACHE_MASK;
-	req_pages = (len + loff + PAGE_CACHE_SIZE - 1) >> PAGE_CACHE_SHIFT;
+	index = *ppos >> PAGE_SHIFT;
+	loff = *ppos & ~PAGE_MASK;
+	req_pages = (len + loff + PAGE_SIZE - 1) >> PAGE_SHIFT;
 	nr_pages = min(req_pages, spd.nr_pages_max);
@@ -365,7 +365,7 @@ __generic_file_splice_read(struct file *in, loff_t *ppos,
 			error = add_to_page_cache_lru(page, mapping, index,
 				   mapping_gfp_constraint(mapping, GFP_KERNEL));
 			if (unlikely(error)) {
+				put_page(page);
 				if (error == -EEXIST)
 					continue;
 				break;
@@ -385,7 +385,7 @@ __generic_file_splice_read(struct file *in, loff_t *ppos,
 	 * Now loop over the map and see if we need to start IO on any
 	 * pages, fill in the partial map, etc.
 	nr_pages = spd.nr_pages;
 	spd.nr_pages = 0;
 	for (page_nr = 0; page_nr < nr_pages; page_nr++) {
@@ -397,7 +397,7 @@ __generic_file_splice_read(struct file *in, loff_t *ppos,
 		 * this_len is the max we'll use from this page
-		this_len = min_t(unsigned long, len, PAGE_CACHE_SIZE - loff);
+		this_len = min_t(unsigned long, len, PAGE_SIZE - loff);
 		page = spd.pages[page_nr];
 		if (PageReadahead(page))
@@ -426,7 +426,7 @@ retry_lookup:
 					error = -ENOMEM;
 					break;
-				page_cache_release(spd.pages[page_nr]);
+				put_page(spd.pages[page_nr]);
 				spd.pages[page_nr] = page;
@@ -456,7 +456,7 @@ fill_it:
 		 * i_size must be checked after PageUptodate.
 		isize = i_size_read(mapping->host);
-		end_index = (isize - 1) >> PAGE_CACHE_SHIFT;
+		end_index = (isize - 1) >> PAGE_SHIFT;
 		if (unlikely(!isize || index > end_index))
 			break;
@@ -470,7 +470,7 @@ fill_it:
 			 * max good bytes in this page
-			plen = ((isize - 1) & ~PAGE_CACHE_MASK) + 1;
+			plen = ((isize - 1) & ~PAGE_MASK) + 1;
 			if (plen <= loff)
 				break;
@@ -494,8 +494,8 @@ fill_it:
 	 * we got, 'nr_pages' is how many pages are in the map.
 	while (page_nr < nr_pages)
-		page_cache_release(spd.pages[page_nr++]);
-	in->f_ra.prev_pos = (loff_t)index << PAGE_CACHE_SHIFT;
+		put_page(spd.pages[page_nr++]);
+	in->f_ra.prev_pos = (loff_t)index << PAGE_SHIFT;
 	if (spd.nr_pages)
 		error = splice_to_pipe(pipe, &spd);
@@ -636,8 +636,8 @@ ssize_t default_file_splice_read(struct file *in, loff_t *ppos,
 			goto shrink_ret;
-	offset = *ppos & ~PAGE_CACHE_MASK;
-	nr_pages = (len + offset + PAGE_CACHE_SIZE - 1) >> PAGE_CACHE_SHIFT;
+	offset = *ppos & ~PAGE_MASK;
+	nr_pages = (len + offset + PAGE_SIZE - 1) >> PAGE_SHIFT;
 	for (i = 0; i < nr_pages && i < spd.nr_pages_max && len; i++) {
 		struct page *page;
@@ -647,7 +647,7 @@ ssize_t default_file_splice_read(struct file *in, loff_t *ppos,
 		if (!page)
 			goto err;
-		this_len = min_t(size_t, len, PAGE_CACHE_SIZE - offset);
+		this_len = min_t(size_t, len, PAGE_SIZE - offset);
 		vec[i].iov_base = (void __user *) page_address(page);
 		vec[i].iov_len = this_len;
 		spd.pages[i] = page;
diff --git a/fs/squashfs/block.c b/fs/squashfs/block.c
index 0cea9b9..2c26184 100644
--- a/fs/squashfs/block.c
+++ b/fs/squashfs/block.c
@@ -181,11 +181,11 @@ int squashfs_read_data(struct super_block *sb, u64 index, int length,
 			in = min(bytes, msblk->devblksize - offset);
 			bytes -= in;
 			while (in) {
-				if (pg_offset == PAGE_CACHE_SIZE) {
+				if (pg_offset == PAGE_SIZE) {
 					data = squashfs_next_page(output);
 					pg_offset = 0;
-				avail = min_t(int, in, PAGE_CACHE_SIZE -
+				avail = min_t(int, in, PAGE_SIZE -
 						pg_offset);
 				memcpy(data + pg_offset, bh[k]->b_data + offset,
 						avail);
diff --git a/fs/squashfs/cache.c b/fs/squashfs/cache.c
index 1cb70a0..27e501a 100644
--- a/fs/squashfs/cache.c
+++ b/fs/squashfs/cache.c
@@ -255,7 +255,7 @@ struct squashfs_cache *squashfs_cache_init(char *name, int entries,
 	cache->unused = entries;
 	cache->entries = entries;
 	cache->block_size = block_size;
-	cache->pages = block_size >> PAGE_CACHE_SHIFT;
+	cache->pages = block_size >> PAGE_SHIFT;
 	cache->pages = cache->pages ? cache->pages : 1;
 	cache->name = name;
 	cache->num_waiters = 0;
@@ -275,7 +275,7 @@ struct squashfs_cache *squashfs_cache_init(char *name, int entries,
 		for (j = 0; j < cache->pages; j++) {
-			entry->data[j] = kmalloc(PAGE_CACHE_SIZE, GFP_KERNEL);
+			entry->data[j] = kmalloc(PAGE_SIZE, GFP_KERNEL);
 			if (entry->data[j] == NULL) {
 				ERROR("Failed to allocate %s buffer\n", name);
 				goto cleanup;
@@ -314,10 +314,10 @@ int squashfs_copy_data(void *buffer, struct squashfs_cache_entry *entry,
 		return min(length, entry->length - offset);
 	while (offset < entry->length) {
-		void *buff = entry->data[offset / PAGE_CACHE_SIZE]
-				+ (offset % PAGE_CACHE_SIZE);
+		void *buff = entry->data[offset / PAGE_SIZE]
+				+ (offset % PAGE_SIZE);
 		int bytes = min_t(int, entry->length - offset,
-				PAGE_CACHE_SIZE - (offset % PAGE_CACHE_SIZE));
+				PAGE_SIZE - (offset % PAGE_SIZE));
 		if (bytes >= remaining) {
 			memcpy(buffer, buff, remaining);
@@ -415,7 +415,7 @@ struct squashfs_cache_entry *squashfs_get_datablock(struct super_block *sb,
 void *squashfs_read_table(struct super_block *sb, u64 block, int length)
-	int pages = (length + PAGE_CACHE_SIZE - 1) >> PAGE_CACHE_SHIFT;
+	int pages = (length + PAGE_SIZE - 1) >> PAGE_SHIFT;
 	int i, res;
 	void *table, *buffer, **data;
 	struct squashfs_page_actor *actor;
@@ -436,7 +436,7 @@ void *squashfs_read_table(struct super_block *sb, u64 block, int length)
 		goto failed2;
-	for (i = 0; i < pages; i++, buffer += PAGE_CACHE_SIZE)
+	for (i = 0; i < pages; i++, buffer += PAGE_SIZE)
 		data[i] = buffer;
 	res = squashfs_read_data(sb, block, length |
diff --git a/fs/squashfs/decompressor.c b/fs/squashfs/decompressor.c
index e9034bf..d2bc136 100644
--- a/fs/squashfs/decompressor.c
+++ b/fs/squashfs/decompressor.c
@@ -102,7 +102,7 @@ static void *get_comp_opts(struct super_block *sb, unsigned short flags)
 	 * Read decompressor specific options from file system if present
 	if (SQUASHFS_COMP_OPTS(flags)) {
-		buffer = kmalloc(PAGE_CACHE_SIZE, GFP_KERNEL);
+		buffer = kmalloc(PAGE_SIZE, GFP_KERNEL);
 		if (buffer == NULL) {
 			comp_opts = ERR_PTR(-ENOMEM);
 			goto out;
diff --git a/fs/squashfs/file.c b/fs/squashfs/file.c
index e5c9689..437de9e 100644
--- a/fs/squashfs/file.c
+++ b/fs/squashfs/file.c
@@ -175,7 +175,7 @@ static long long read_indexes(struct super_block *sb, int n,
 	int err, i;
 	long long block = 0;
-	__le32 *blist = kmalloc(PAGE_CACHE_SIZE, GFP_KERNEL);
+	__le32 *blist = kmalloc(PAGE_SIZE, GFP_KERNEL);
 	if (blist == NULL) {
 		ERROR("read_indexes: Failed to allocate block_list\n");
@@ -183,7 +183,7 @@ static long long read_indexes(struct super_block *sb, int n,
 	while (n) {
-		int blocks = min_t(int, n, PAGE_CACHE_SIZE >> 2);
+		int blocks = min_t(int, n, PAGE_SIZE >> 2);
 		err = squashfs_read_metadata(sb, blist, start_block,
 				offset, blocks << 2);
@@ -377,7 +377,7 @@ void squashfs_copy_cache(struct page *page, struct squashfs_cache_entry *buffer,
 	struct squashfs_sb_info *msblk = inode->i_sb->s_fs_info;
 	void *pageaddr;
-	int i, mask = (1 << (msblk->block_log - PAGE_CACHE_SHIFT)) - 1;
+	int i, mask = (1 << (msblk->block_log - PAGE_SHIFT)) - 1;
 	int start_index = page->index & ~mask, end_index = start_index | mask;
@@ -387,9 +387,9 @@ void squashfs_copy_cache(struct page *page, struct squashfs_cache_entry *buffer,
 	 * been called to fill.
 	for (i = start_index; i <= end_index && bytes > 0; i++,
-			bytes -= PAGE_CACHE_SIZE, offset += PAGE_CACHE_SIZE) {
+			bytes -= PAGE_SIZE, offset += PAGE_SIZE) {
 		struct page *push_page;
-		int avail = buffer ? min_t(int, bytes, PAGE_CACHE_SIZE) : 0;
+		int avail = buffer ? min_t(int, bytes, PAGE_SIZE) : 0;
 		TRACE("bytes %d, i %d, available_bytes %d\n", bytes, i, avail);
@@ -404,14 +404,14 @@ void squashfs_copy_cache(struct page *page, struct squashfs_cache_entry *buffer,
 		pageaddr = kmap_atomic(push_page);
 		squashfs_copy_data(pageaddr, buffer, offset, avail);
-		memset(pageaddr + avail, 0, PAGE_CACHE_SIZE - avail);
+		memset(pageaddr + avail, 0, PAGE_SIZE - avail);
 		kunmap_atomic(pageaddr);
 		flush_dcache_page(push_page);
 		SetPageUptodate(push_page);
 skip_page:
 		unlock_page(push_page);
 		if (i != page->index)
-			page_cache_release(push_page);
+			put_page(push_page);
@@ -454,7 +454,7 @@ static int squashfs_readpage(struct file *file, struct page *page)
-	int index = page->index >> (msblk->block_log - PAGE_CACHE_SHIFT);
+	int index = page->index >> (msblk->block_log - PAGE_SHIFT);
 	int file_end = i_size_read(inode) >> msblk->block_log;
 	int res;
 	void *pageaddr;
@@ -462,8 +462,8 @@ static int squashfs_readpage(struct file *file, struct page *page)
 	TRACE("Entered squashfs_readpage, page index %lx, start block %llx\n",
 				page->index, squashfs_i(inode)->start);
-	if (page->index >= ((i_size_read(inode) + PAGE_CACHE_SIZE - 1) >>
+	if (page->index >= ((i_size_read(inode) + PAGE_SIZE - 1) >>
+					PAGE_SHIFT))
 		goto out;
 	if (index < file_end || squashfs_i(inode)->fragment_block ==
@@ -487,7 +487,7 @@ error_out:
 	SetPageError(page);
 out:
 	pageaddr = kmap_atomic(page);
-	memset(pageaddr, 0, PAGE_CACHE_SIZE);
+	memset(pageaddr, 0, PAGE_SIZE);
 	flush_dcache_page(page);
 	if (!PageError(page))
diff --git a/fs/squashfs/file_direct.c b/fs/squashfs/file_direct.c
index 43e7a7e..cb485d8 100644
--- a/fs/squashfs/file_direct.c
+++ b/fs/squashfs/file_direct.c
@@ -30,8 +30,8 @@ int squashfs_readpage_block(struct page *target_page, u64 block, int bsize)
 	struct inode *inode = target_page->mapping->host;
-	int file_end = (i_size_read(inode) - 1) >> PAGE_CACHE_SHIFT;
-	int mask = (1 << (msblk->block_log - PAGE_CACHE_SHIFT)) - 1;
+	int file_end = (i_size_read(inode) - 1) >> PAGE_SHIFT;
+	int mask = (1 << (msblk->block_log - PAGE_SHIFT)) - 1;
 	int start_index = target_page->index & ~mask;
 	int end_index = start_index | mask;
 	int i, n, pages, missing_pages, bytes, res = -ENOMEM;
@@ -68,7 +68,7 @@ int squashfs_readpage_block(struct page *target_page, u64 block, int bsize)
 		if (PageUptodate(page[i])) {
 			unlock_page(page[i]);
-			page_cache_release(page[i]);
+			put_page(page[i]);
 			page[i] = NULL;
 			missing_pages++;
@@ -96,10 +96,10 @@ int squashfs_readpage_block(struct page *target_page, u64 block, int bsize)
 		goto mark_errored;
 	/* Last page may have trailing bytes not filled */
-	bytes = res % PAGE_CACHE_SIZE;
+	bytes = res % PAGE_SIZE;
 	if (bytes) {
 		pageaddr = kmap_atomic(page[pages - 1]);
-		memset(pageaddr + bytes, 0, PAGE_CACHE_SIZE - bytes);
+		memset(pageaddr + bytes, 0, PAGE_SIZE - bytes);
@@ -109,7 +109,7 @@ int squashfs_readpage_block(struct page *target_page, u64 block, int bsize)
 		SetPageUptodate(page[i]);
 		if (page[i] != target_page)
 	kfree(actor);
@@ -127,7 +127,7 @@ mark_errored:
 		flush_dcache_page(page[i]);
 		SetPageError(page[i]);
 out:
@@ -153,21 +153,21 @@ static int squashfs_read_cache(struct page *target_page, u64 block, int bsize,
 	for (n = 0; n < pages && bytes > 0; n++,
-		int avail = min_t(int, bytes, PAGE_CACHE_SIZE);
+		int avail = min_t(int, bytes, PAGE_SIZE);
 		if (page[n] == NULL)
 			continue;
 		pageaddr = kmap_atomic(page[n]);
 		flush_dcache_page(page[n]);
 		SetPageUptodate(page[n]);
 		unlock_page(page[n]);
 		if (page[n] != target_page)
-			page_cache_release(page[n]);
+			put_page(page[n]);
 out:
diff --git a/fs/squashfs/lz4_wrapper.c b/fs/squashfs/lz4_wrapper.c
index c31e2bc..ff4468b 100644
--- a/fs/squashfs/lz4_wrapper.c
+++ b/fs/squashfs/lz4_wrapper.c
@@ -117,13 +117,13 @@ static int lz4_uncompress(struct squashfs_sb_info *msblk, void *strm,
 	data = squashfs_first_page(output);
 	buff = stream->output;
 	while (data) {
-		if (bytes <= PAGE_CACHE_SIZE) {
+		if (bytes <= PAGE_SIZE) {
 			memcpy(data, buff, bytes);
 			break;
-		memcpy(data, buff, PAGE_CACHE_SIZE);
-		buff += PAGE_CACHE_SIZE;
-		bytes -= PAGE_CACHE_SIZE;
+		memcpy(data, buff, PAGE_SIZE);
+		buff += PAGE_SIZE;
+		bytes -= PAGE_SIZE;
 	squashfs_finish_page(output);
diff --git a/fs/squashfs/lzo_wrapper.c b/fs/squashfs/lzo_wrapper.c
index 244b9fb..934c17e 100644
--- a/fs/squashfs/lzo_wrapper.c
+++ b/fs/squashfs/lzo_wrapper.c
@@ -102,13 +102,13 @@ static int lzo_uncompress(struct squashfs_sb_info *msblk, void *strm,
 	while (data) {
 			break;
 		} else {
diff --git a/fs/squashfs/page_actor.c b/fs/squashfs/page_actor.c
index 5a1c11f..9b7b1b6 100644
--- a/fs/squashfs/page_actor.c
+++ b/fs/squashfs/page_actor.c
@@ -48,7 +48,7 @@ struct squashfs_page_actor *squashfs_page_actor_init(void **buffer,
 	if (actor == NULL)
 		return NULL;
-	actor->length = length ? : pages * PAGE_CACHE_SIZE;
+	actor->length = length ? : pages * PAGE_SIZE;
 	actor->buffer = buffer;
 	actor->pages = pages;
 	actor->next_page = 0;
@@ -88,7 +88,7 @@ struct squashfs_page_actor *squashfs_page_actor_init_special(struct page **page,
 	if (actor == NULL)
 		return NULL;
 	actor->page = page;
diff --git a/fs/squashfs/page_actor.h b/fs/squashfs/page_actor.h
index 26dd820..98537ea 100644
--- a/fs/squashfs/page_actor.h
+++ b/fs/squashfs/page_actor.h
@@ -24,7 +24,7 @@ static inline struct squashfs_page_actor *squashfs_page_actor_init(void **page,
 	if (actor == NULL)
 		return NULL;
 	actor->page = page;
diff --git a/fs/squashfs/super.c b/fs/squashfs/super.c
index 5e79bfa..cf01e15 100644
--- a/fs/squashfs/super.c
+++ b/fs/squashfs/super.c
@@ -152,7 +152,7 @@ static int squashfs_fill_super(struct super_block *sb, void *data, int silent)
 	 * Check the system page size is not larger than the filesystem
 	 * block size (by default 128K).  This is currently not supported.
-	if (PAGE_CACHE_SIZE > msblk->block_size) {
+	if (PAGE_SIZE > msblk->block_size) {
 		ERROR("Page size > filesystem block size (%d).  This is "
 			"currently not supported!\n", msblk->block_size);
 		goto failed_mount;
diff --git a/fs/squashfs/symlink.c b/fs/squashfs/symlink.c
index dbcc2f5..d688ef4 100644
--- a/fs/squashfs/symlink.c
+++ b/fs/squashfs/symlink.c
@@ -48,10 +48,10 @@ static int squashfs_symlink_readpage(struct file *file, struct page *page)
 	struct super_block *sb = inode->i_sb;
 	struct squashfs_sb_info *msblk = sb->s_fs_info;
-	int index = page->index << PAGE_CACHE_SHIFT;
+	int index = page->index << PAGE_SHIFT;
 	u64 block = squashfs_i(inode)->start;
 	int offset = squashfs_i(inode)->offset;
-	int length = min_t(int, i_size_read(inode) - index, PAGE_CACHE_SIZE);
+	int length = min_t(int, i_size_read(inode) - index, PAGE_SIZE);
 	int bytes, copied;
 	void *pageaddr;
 	struct squashfs_cache_entry *entry;
@@ -94,7 +94,7 @@ static int squashfs_symlink_readpage(struct file *file, struct page *page)
 		copied = squashfs_copy_data(pageaddr + bytes, entry, offset,
 								length - bytes);
 		if (copied == length - bytes)
-			memset(pageaddr + length, 0, PAGE_CACHE_SIZE - length);
+			memset(pageaddr + length, 0, PAGE_SIZE - length);
 		else
 			block = entry->next_index;
diff --git a/fs/squashfs/xz_wrapper.c b/fs/squashfs/xz_wrapper.c
index c609624..6bfaef7 100644
--- a/fs/squashfs/xz_wrapper.c
+++ b/fs/squashfs/xz_wrapper.c
@@ -141,7 +141,7 @@ static int squashfs_xz_uncompress(struct squashfs_sb_info *msblk, void *strm,
 	stream->buf.in_pos = 0;
 	stream->buf.in_size = 0;
 	stream->buf.out_pos = 0;
-	stream->buf.out_size = PAGE_CACHE_SIZE;
+	stream->buf.out_size = PAGE_SIZE;
 	stream->buf.out = squashfs_first_page(output);
 	do {
@@ -158,7 +158,7 @@ static int squashfs_xz_uncompress(struct squashfs_sb_info *msblk, void *strm,
 			stream->buf.out = squashfs_next_page(output);
 			if (stream->buf.out != NULL) {
-				total += PAGE_CACHE_SIZE;
+				total += PAGE_SIZE;
diff --git a/fs/squashfs/zlib_wrapper.c b/fs/squashfs/zlib_wrapper.c
index 8727cab..2ec24d1 100644
--- a/fs/squashfs/zlib_wrapper.c
+++ b/fs/squashfs/zlib_wrapper.c
@@ -69,7 +69,7 @@ static int zlib_uncompress(struct squashfs_sb_info *msblk, void *strm,
 	int zlib_err, zlib_init = 0, k = 0;
 	z_stream *stream = strm;
-	stream->avail_out = PAGE_CACHE_SIZE;
+	stream->avail_out = PAGE_SIZE;
 	stream->next_out = squashfs_first_page(output);
 	stream->avail_in = 0;
@@ -85,7 +85,7 @@ static int zlib_uncompress(struct squashfs_sb_info *msblk, void *strm,
 		if (stream->avail_out == 0) {
 			stream->next_out = squashfs_next_page(output);
 			if (stream->next_out != NULL)
 		if (!zlib_init) {
diff --git a/fs/sync.c b/fs/sync.c
index dd5d171..2a54c1f 100644
--- a/fs/sync.c
+++ b/fs/sync.c
@@ -302,7 +302,7 @@ SYSCALL_DEFINE4(sync_file_range, int, fd, loff_t, offset, loff_t, nbytes,
 		goto out;
 	if (sizeof(pgoff_t) == 4) {
-		if (offset >= (0x100000000ULL << PAGE_CACHE_SHIFT)) {
+		if (offset >= (0x100000000ULL << PAGE_SHIFT)) {
 			 * The range starts outside a 32 bit machine's
 			 * pagecache addressing capabilities.  Let it "succeed"
@@ -310,7 +310,7 @@ SYSCALL_DEFINE4(sync_file_range, int, fd, loff_t, offset, loff_t, nbytes,
 			ret = 0;
 			goto out;
-		if (endbyte >= (0x100000000ULL << PAGE_CACHE_SHIFT)) {
+		if (endbyte >= (0x100000000ULL << PAGE_SHIFT)) {
 			 * Out to EOF
diff --git a/fs/sysv/dir.c b/fs/sysv/dir.c
index 63c1bcb..c0f0a3e 100644
--- a/fs/sysv/dir.c
+++ b/fs/sysv/dir.c
@@ -30,7 +30,7 @@ const struct file_operations sysv_dir_operations = {
 static inline void dir_put_page(struct page *page)
 	kunmap(page);
+	put_page(page);
 static int dir_commit_chunk(struct page *page, loff_t pos, unsigned len)
@@ -73,8 +73,8 @@ static int sysv_readdir(struct file *file, struct dir_context *ctx)
 	if (pos >= inode->i_size)
 		return 0;
-	offset = pos & ~PAGE_CACHE_MASK;
-	n = pos >> PAGE_CACHE_SHIFT;
+	offset = pos & ~PAGE_MASK;
+	n = pos >> PAGE_SHIFT;
 	for ( ; n < npages; n++, offset = 0) {
 		char *kaddr, *limit;
@@ -85,7 +85,7 @@ static int sysv_readdir(struct file *file, struct dir_context *ctx)
 			continue;
 		kaddr = (char *)page_address(page);
 		de = (struct sysv_dir_entry *)(kaddr+offset);
-		limit = kaddr + PAGE_CACHE_SIZE - SYSV_DIRSIZE;
+		limit = kaddr + PAGE_SIZE - SYSV_DIRSIZE;
 		for ( ;(char*)de <= limit; de++, ctx->pos += sizeof(*de)) {
 			char *name = de->name;
@@ -146,7 +146,7 @@ struct sysv_dir_entry *sysv_find_entry(struct dentry *dentry, struct page **res_
 			kaddr = (char*)page_address(page);
 			de = (struct sysv_dir_entry *) kaddr;
-			kaddr += PAGE_CACHE_SIZE - SYSV_DIRSIZE;
+			kaddr += PAGE_SIZE - SYSV_DIRSIZE;
 			for ( ; (char *) de <= kaddr ; de++) {
 				if (!de->inode)
 					continue;
@@ -190,7 +190,7 @@ int sysv_add_link(struct dentry *dentry, struct inode *inode)
 			goto out;
 		de = (struct sysv_dir_entry *)kaddr;
 		while ((char *)de <= kaddr) {
 			if (!de->inode)
 				goto got_it;
@@ -261,7 +261,7 @@ int sysv_make_empty(struct inode *inode, struct inode *dir)
 	kmap(page);
 	base = (char*)page_address(page);
-	memset(base, 0, PAGE_CACHE_SIZE);
+	memset(base, 0, PAGE_SIZE);
 	de = (struct sysv_dir_entry *) base;
 	de->inode = cpu_to_fs16(SYSV_SB(inode->i_sb), inode->i_ino);
@@ -273,7 +273,7 @@ int sysv_make_empty(struct inode *inode, struct inode *dir)
 	kunmap(page);
 	err = dir_commit_chunk(page, 0, 2 * SYSV_DIRSIZE);
 fail:
+	put_page(page);
 	return err;
@@ -296,7 +296,7 @@ int sysv_empty_dir(struct inode * inode)
-		kaddr += PAGE_CACHE_SIZE-SYSV_DIRSIZE;
+		kaddr += PAGE_SIZE-SYSV_DIRSIZE;
 		for ( ;(char *)de <= kaddr; de++) {
 			if (!de->inode)
diff --git a/fs/sysv/namei.c b/fs/sysv/namei.c
index 11e83ed..90b60c0 100644
--- a/fs/sysv/namei.c
+++ b/fs/sysv/namei.c
@@ -264,11 +264,11 @@ static int sysv_rename(struct inode * old_dir, struct dentry * old_dentry,
 out_dir:
 	if (dir_de) {
 		kunmap(dir_page);
-		page_cache_release(dir_page);
+		put_page(dir_page);
 out_old:
 	kunmap(old_page);
-	page_cache_release(old_page);
+	put_page(old_page);
 out:
 	return err;
diff --git a/fs/ubifs/file.c b/fs/ubifs/file.c
index 065c88f..1a9c664 100644
--- a/fs/ubifs/file.c
+++ b/fs/ubifs/file.c
@@ -121,7 +121,7 @@ static int do_readpage(struct page *page)
 	if (block >= beyond) {
 		/* Reading beyond inode */
 		SetPageChecked(page);
-		memset(addr, 0, PAGE_CACHE_SIZE);
+		memset(addr, 0, PAGE_SIZE);
 		goto out;
@@ -223,7 +223,7 @@ static int write_begin_slow(struct address_space *mapping,
 	struct inode *inode = mapping->host;
 	struct ubifs_info *c = inode->i_sb->s_fs_info;
-	pgoff_t index = pos >> PAGE_CACHE_SHIFT;
+	pgoff_t index = pos >> PAGE_SHIFT;
 	struct ubifs_budget_req req = { .new_page = 1 };
 	int uninitialized_var(err), appending = !!(pos + len > inode->i_size);
 	struct page *page;
@@ -254,13 +254,13 @@ static int write_begin_slow(struct address_space *mapping,
-		if (!(pos & ~PAGE_CACHE_MASK) && len == PAGE_CACHE_SIZE)
+		if (!(pos & ~PAGE_MASK) && len == PAGE_SIZE)
 		else {
 			err = do_readpage(page);
 			if (err) {
 				unlock_page(page);
+				put_page(page);
 				ubifs_release_budget(c, &req);
 				return err;
@@ -428,7 +428,7 @@ static int ubifs_write_begin(struct file *file, struct address_space *mapping,
 	struct ubifs_inode *ui = ubifs_inode(inode);
 	int skipped_read = 0;
 	struct page *page;
@@ -446,7 +446,7 @@ static int ubifs_write_begin(struct file *file, struct address_space *mapping,
 		/* The page is not loaded from the flash */
-		if (!(pos & ~PAGE_CACHE_MASK) && len == PAGE_CACHE_SIZE) {
+		if (!(pos & ~PAGE_MASK) && len == PAGE_SIZE) {
 			 * We change whole page so no need to load it. But we
 			 * do not know whether this page exists on the media or
@@ -462,7 +462,7 @@ static int ubifs_write_begin(struct file *file, struct address_space *mapping,
 			if (err) {
 				unlock_page(page);
+				put_page(page);
 				return err;
@@ -494,7 +494,7 @@ static int ubifs_write_begin(struct file *file, struct address_space *mapping,
 			mutex_unlock(&ui->ui_mutex);
 		unlock_page(page);
+		put_page(page);
 		return write_begin_slow(mapping, pos, len, pagep, flags);
@@ -549,7 +549,7 @@ static int ubifs_write_end(struct file *file, struct address_space *mapping,
 	dbg_gen("ino %lu, pos %llu, pg %lu, len %u, copied %d, i_size %lld",
 		inode->i_ino, pos, page->index, len, copied, inode->i_size);
-	if (unlikely(copied < len && len == PAGE_CACHE_SIZE)) {
+	if (unlikely(copied < len && len == PAGE_SIZE)) {
 		 * VFS copied less data to the page that it intended and
 		 * declared in its '->write_begin()' call via the @len
@@ -593,7 +593,7 @@ static int ubifs_write_end(struct file *file, struct address_space *mapping,
 out:
 	unlock_page(page);
+	put_page(page);
 	return copied;
@@ -621,10 +621,10 @@ static int populate_page(struct ubifs_info *c, struct page *page,
 	addr = zaddr = kmap(page);
-	end_index = (i_size - 1) >> PAGE_CACHE_SHIFT;
+	end_index = (i_size - 1) >> PAGE_SHIFT;
 	if (!i_size || page->index > end_index) {
 		hole = 1;
 		goto out_hole;
@@ -673,7 +673,7 @@ static int populate_page(struct ubifs_info *c, struct page *page,
 	if (end_index == page->index) {
-		int len = i_size & (PAGE_CACHE_SIZE - 1);
+		int len = i_size & (PAGE_SIZE - 1);
 		if (len && len < read)
 			memset(zaddr + len, 0, read - len);
@@ -773,7 +773,7 @@ static int ubifs_do_bulk_read(struct ubifs_info *c, struct bu_info *bu,
 	isize = i_size_read(inode);
 	if (isize == 0)
 		goto out_free;
-	end_index = ((isize - 1) >> PAGE_CACHE_SHIFT);
+	end_index = ((isize - 1) >> PAGE_SHIFT);
 	for (page_idx = 1; page_idx < page_cnt; page_idx++) {
 		pgoff_t page_offset = offset + page_idx;
@@ -788,7 +788,7 @@ static int ubifs_do_bulk_read(struct ubifs_info *c, struct bu_info *bu,
 			err = populate_page(c, page, bu, &n);
 		unlock_page(page);
+		put_page(page);
 		if (err)
 			break;
@@ -905,7 +905,7 @@ static int do_writepage(struct page *page, int len)
 #ifdef UBIFS_DEBUG
 	spin_lock(&ui->ui_lock);
-	ubifs_assert(page->index <= ui->synced_i_size >> PAGE_CACHE_SHIFT);
+	ubifs_assert(page->index <= ui->synced_i_size >> PAGE_SHIFT);
 	spin_unlock(&ui->ui_lock);
 #endif
@@ -1001,8 +1001,8 @@ static int ubifs_writepage(struct page *page, struct writeback_control *wbc)
 	loff_t i_size =  i_size_read(inode), synced_i_size;
-	pgoff_t end_index = i_size >> PAGE_CACHE_SHIFT;
-	int err, len = i_size & (PAGE_CACHE_SIZE - 1);
+	pgoff_t end_index = i_size >> PAGE_SHIFT;
+	int err, len = i_size & (PAGE_SIZE - 1);
 	void *kaddr;
 	dbg_gen("ino %lu, pg %lu, pg flags %#lx",
@@ -1021,7 +1021,7 @@ static int ubifs_writepage(struct page *page, struct writeback_control *wbc)
 	/* Is the page fully inside @i_size? */
 	if (page->index < end_index) {
-		if (page->index >= synced_i_size >> PAGE_CACHE_SHIFT) {
+		if (page->index >= synced_i_size >> PAGE_SHIFT) {
 			err = inode->i_sb->s_op->write_inode(inode, NULL);
 			if (err)
 				goto out_unlock;
@@ -1034,7 +1034,7 @@ static int ubifs_writepage(struct page *page, struct writeback_control *wbc)
 			 * with this.
-		return do_writepage(page, PAGE_CACHE_SIZE);
+		return do_writepage(page, PAGE_SIZE);
@@ -1045,7 +1045,7 @@ static int ubifs_writepage(struct page *page, struct writeback_control *wbc)
 	 * writes to that region are not written out to the file."
 	kaddr = kmap_atomic(page);
-	memset(kaddr + len, 0, PAGE_CACHE_SIZE - len);
+	memset(kaddr + len, 0, PAGE_SIZE - len);
@@ -1138,7 +1138,7 @@ static int do_truncation(struct ubifs_info *c, struct inode *inode,
 	truncate_setsize(inode, new_size);
 	if (offset) {
-		pgoff_t index = new_size >> PAGE_CACHE_SHIFT;
+		pgoff_t index = new_size >> PAGE_SHIFT;
 		struct page *page;
 		page = find_lock_page(inode->i_mapping, index);
@@ -1157,9 +1157,9 @@ static int do_truncation(struct ubifs_info *c, struct inode *inode,
 				clear_page_dirty_for_io(page);
 				if (UBIFS_BLOCKS_PER_PAGE_SHIFT)
 					offset = new_size &
-						 (PAGE_CACHE_SIZE - 1);
+						 (PAGE_SIZE - 1);
 				err = do_writepage(page, offset);
+				put_page(page);
 				if (err)
 					goto out_budg;
@@ -1173,7 +1173,7 @@ static int do_truncation(struct ubifs_info *c, struct inode *inode,
 				 * having to read it.
 				unlock_page(page);
+				put_page(page);
@@ -1285,7 +1285,7 @@ static void ubifs_invalidatepage(struct page *page, unsigned int offset,
 	ubifs_assert(PagePrivate(page));
-	if (offset || length < PAGE_CACHE_SIZE)
+	if (offset || length < PAGE_SIZE)
 		/* Partial page remains dirty */
 		return;
diff --git a/fs/ubifs/super.c b/fs/ubifs/super.c
index a233ba9..20daea9 100644
--- a/fs/ubifs/super.c
+++ b/fs/ubifs/super.c
@@ -2240,9 +2240,9 @@ static int __init ubifs_init(void)
 	 * We require that PAGE_CACHE_SIZE is greater-than-or-equal-to
 	 * UBIFS_BLOCK_SIZE. It is assumed that both are powers of 2.
-	if (PAGE_CACHE_SIZE < UBIFS_BLOCK_SIZE) {
+	if (PAGE_SIZE < UBIFS_BLOCK_SIZE) {
 		pr_err("UBIFS error (pid %d): VFS page cache size is %u bytes, but UBIFS requires at least 4096 bytes",
-		       current->pid, (unsigned int)PAGE_CACHE_SIZE);
+		       current->pid, (unsigned int)PAGE_SIZE);
 		return -EINVAL;
diff --git a/fs/ubifs/ubifs.h b/fs/ubifs/ubifs.h
index c2a57e1..4cd7e56 100644
--- a/fs/ubifs/ubifs.h
+++ b/fs/ubifs/ubifs.h
@@ -46,8 +46,8 @@
 #define UBIFS_SUPER_MAGIC 0x24051905
 /* Number of UBIFS blocks per VFS page */
-#define UBIFS_BLOCKS_PER_PAGE (PAGE_CACHE_SIZE / UBIFS_BLOCK_SIZE)
-#define UBIFS_BLOCKS_PER_PAGE_SHIFT (PAGE_CACHE_SHIFT - UBIFS_BLOCK_SHIFT)
+#define UBIFS_BLOCKS_PER_PAGE (PAGE_SIZE / UBIFS_BLOCK_SIZE)
+#define UBIFS_BLOCKS_PER_PAGE_SHIFT (PAGE_SHIFT - UBIFS_BLOCK_SHIFT)
 /* "File system end of life" sequence number watermark */
 #define SQNUM_WARN_WATERMARK 0xFFFFFFFF00000000ULL
diff --git a/fs/udf/file.c b/fs/udf/file.c
index 1af9896..877ba1c 100644
--- a/fs/udf/file.c
+++ b/fs/udf/file.c
@@ -46,7 +46,7 @@ static void __udf_adinicb_readpage(struct page *page)
 	kaddr = kmap(page);
 	memcpy(kaddr, iinfo->i_ext.i_data + iinfo->i_lenEAttr, inode->i_size);
-	memset(kaddr + inode->i_size, 0, PAGE_CACHE_SIZE - inode->i_size);
+	memset(kaddr + inode->i_size, 0, PAGE_SIZE - inode->i_size);
 	kunmap(page);
@@ -87,14 +87,14 @@ static int udf_adinicb_write_begin(struct file *file,
 	struct page *page;
-	if (WARN_ON_ONCE(pos >= PAGE_CACHE_SIZE))
+	if (WARN_ON_ONCE(pos >= PAGE_SIZE))
 		return -EIO;
 	page = grab_cache_page_write_begin(mapping, 0, flags);
 	if (!page)
 		return -ENOMEM;
 	*pagep = page;
-	if (!PageUptodate(page) && len != PAGE_CACHE_SIZE)
+	if (!PageUptodate(page) && len != PAGE_SIZE)
 		__udf_adinicb_readpage(page);
 	return 0;
diff --git a/fs/udf/inode.c b/fs/udf/inode.c
index 166d3ed..2dc461e 100644
--- a/fs/udf/inode.c
+++ b/fs/udf/inode.c
@@ -287,7 +287,7 @@ int udf_expand_file_adinicb(struct inode *inode)
 		kaddr = kmap(page);
 		memset(kaddr + iinfo->i_lenAlloc, 0x00,
-		       PAGE_CACHE_SIZE - iinfo->i_lenAlloc);
+		       PAGE_SIZE - iinfo->i_lenAlloc);
 			iinfo->i_lenAlloc);
@@ -319,7 +319,7 @@ int udf_expand_file_adinicb(struct inode *inode)
 		inode->i_data.a_ops = &udf_adinicb_aops;
 		up_write(&iinfo->i_data_sem);
+	put_page(page);
 	mark_inode_dirty(inode);
 	return err;
diff --git a/fs/ufs/balloc.c b/fs/ufs/balloc.c
index dc5fae6..0447b94 100644
--- a/fs/ufs/balloc.c
+++ b/fs/ufs/balloc.c
@@ -237,7 +237,7 @@ static void ufs_change_blocknr(struct inode *inode, sector_t beg,
 			       sector_t newb, struct page *locked_page)
 	const unsigned blks_per_page =
-		1 << (PAGE_CACHE_SHIFT - inode->i_blkbits);
+		1 << (PAGE_SHIFT - inode->i_blkbits);
 	const unsigned mask = blks_per_page - 1;
 	struct address_space * const mapping = inode->i_mapping;
 	pgoff_t index, cur_index, last_index;
@@ -255,9 +255,9 @@ static void ufs_change_blocknr(struct inode *inode, sector_t beg,
 	cur_index = locked_page->index;
 	end = count + beg;
-	last_index = end >> (PAGE_CACHE_SHIFT - inode->i_blkbits);
+	last_index = end >> (PAGE_SHIFT - inode->i_blkbits);
 	for (i = beg; i < end; i = (i | mask) + 1) {
-		index = i >> (PAGE_CACHE_SHIFT - inode->i_blkbits);
+		index = i >> (PAGE_SHIFT - inode->i_blkbits);
 		if (likely(cur_index != index)) {
 			page = ufs_get_locked_page(mapping, index);
diff --git a/fs/ufs/dir.c b/fs/ufs/dir.c
index 74f2e80..0b14572 100644
--- a/fs/ufs/dir.c
+++ b/fs/ufs/dir.c
@@ -62,7 +62,7 @@ static int ufs_commit_chunk(struct page *page, loff_t pos, unsigned len)
 static inline void ufs_put_page(struct page *page)
 	kunmap(page);
+	put_page(page);
 ino_t ufs_inode_by_name(struct inode *dir, const struct qstr *qstr)
@@ -111,13 +111,13 @@ static void ufs_check_page(struct page *page)
 	struct super_block *sb = dir->i_sb;
 	char *kaddr = page_address(page);
 	unsigned offs, rec_len;
-	unsigned limit = PAGE_CACHE_SIZE;
+	unsigned limit = PAGE_SIZE;
 	const unsigned chunk_mask = UFS_SB(sb)->s_uspi->s_dirblksize - 1;
 	struct ufs_dir_entry *p;
 	char *error;
-	if ((dir->i_size >> PAGE_CACHE_SHIFT) == page->index) {
-		limit = dir->i_size & ~PAGE_CACHE_MASK;
+	if ((dir->i_size >> PAGE_SHIFT) == page->index) {
+		limit = dir->i_size & ~PAGE_MASK;
 		if (limit & chunk_mask)
 			goto Ebadsize;
 		if (!limit)
@@ -170,7 +170,7 @@ Einumber:
 bad_entry:
 	ufs_error (sb, "ufs_check_page", "bad entry in directory #%lu: %s - "
 		   "offset=%lu, rec_len=%d, name_len=%d",
-		   dir->i_ino, error, (page->index<<PAGE_CACHE_SHIFT)+offs,
+		   dir->i_ino, error, (page->index<<PAGE_SHIFT)+offs,
 		   rec_len, ufs_get_de_namlen(sb, p));
 	goto fail;
 Eend:
@@ -178,7 +178,7 @@ Eend:
 	ufs_error(sb, __func__,
 		   "entry in directory #%lu spans the page boundary"
 		   "offset=%lu",
-		   dir->i_ino, (page->index<<PAGE_CACHE_SHIFT)+offs);
+		   dir->i_ino, (page->index<<PAGE_SHIFT)+offs);
 fail:
 	SetPageError(page);
@@ -211,9 +211,9 @@ ufs_last_byte(struct inode *inode, unsigned long page_nr)
 	unsigned last_byte = inode->i_size;
 	return last_byte;
@@ -341,7 +341,7 @@ int ufs_add_link(struct dentry *dentry, struct inode *inode)
 		dir_end = kaddr + ufs_last_byte(dir, n);
 		de = (struct ufs_dir_entry *)kaddr;
-		kaddr += PAGE_CACHE_SIZE - reclen;
+		kaddr += PAGE_SIZE - reclen;
 			if ((char *)de == dir_end) {
 				/* We hit i_size */
@@ -432,8 +432,8 @@ ufs_readdir(struct file *file, struct dir_context *ctx)
 	loff_t pos = ctx->pos;
-	unsigned int offset = pos & ~PAGE_CACHE_MASK;
+	unsigned int offset = pos & ~PAGE_MASK;
 	unsigned chunk_mask = ~(UFS_SB(sb)->s_uspi->s_dirblksize - 1);
 	int need_revalidate = file->f_version != inode->i_version;
@@ -454,14 +454,14 @@ ufs_readdir(struct file *file, struct dir_context *ctx)
 				  "bad page in #%lu",
 				  inode->i_ino);
-			ctx->pos += PAGE_CACHE_SIZE - offset;
+			ctx->pos += PAGE_SIZE - offset;
 			return -EIO;
 		if (unlikely(need_revalidate)) {
 			if (offset) {
 				offset = ufs_validate_entry(sb, kaddr, offset, chunk_mask);
-				ctx->pos = (n<<PAGE_CACHE_SHIFT) + offset;
+				ctx->pos = (n<<PAGE_SHIFT) + offset;
 			file->f_version = inode->i_version;
 			need_revalidate = 0;
@@ -574,7 +574,7 @@ int ufs_make_empty(struct inode * inode, struct inode *dir)
 	kmap(page);
 	de = (struct ufs_dir_entry *) base;
@@ -594,7 +594,7 @@ int ufs_make_empty(struct inode * inode, struct inode *dir)
 	err = ufs_commit_chunk(page, 0, chunk_size);
 fail:
+	put_page(page);
 	return err;
diff --git a/fs/ufs/inode.c b/fs/ufs/inode.c
index d897e16..9f49431 100644
--- a/fs/ufs/inode.c
+++ b/fs/ufs/inode.c
@@ -1051,13 +1051,13 @@ static int ufs_alloc_lastblock(struct inode *inode, loff_t size)
 	lastfrag--;
 	lastpage = ufs_get_locked_page(mapping, lastfrag >>
-				       (PAGE_CACHE_SHIFT - inode->i_blkbits));
+				       (PAGE_SHIFT - inode->i_blkbits));
        if (IS_ERR(lastpage)) {
                err = -EIO;
                goto out;
-       end = lastfrag & ((1 << (PAGE_CACHE_SHIFT - inode->i_blkbits)) - 1);
+       end = lastfrag & ((1 << (PAGE_SHIFT - inode->i_blkbits)) - 1);
        bh = page_buffers(lastpage);
        for (i = 0; i < end; ++i)
                bh = bh->b_this_page;
diff --git a/fs/ufs/namei.c b/fs/ufs/namei.c
index acf4a3b..a1559f7 100644
--- a/fs/ufs/namei.c
+++ b/fs/ufs/namei.c
@@ -305,7 +305,7 @@ static int ufs_rename(struct inode *old_dir, struct dentry *old_dentry,
 			ufs_set_link(old_inode, dir_de, dir_page, new_dir, 0);
 		else {
 			kunmap(dir_page);
 		inode_dec_link_count(old_dir);
@@ -315,11 +315,11 @@ static int ufs_rename(struct inode *old_dir, struct dentry *old_dentry,
 out_dir:
 	if (dir_de) {
 		kunmap(dir_page);
 out_old:
 	kunmap(old_page);
 out:
 	return err;
diff --git a/fs/ufs/util.c b/fs/ufs/util.c
index b6c2f94..a409e3e 100644
--- a/fs/ufs/util.c
+++ b/fs/ufs/util.c
@@ -261,14 +261,14 @@ struct page *ufs_get_locked_page(struct address_space *mapping,
 		if (unlikely(page->mapping == NULL)) {
 			/* Truncate got there first */
 			unlock_page(page);
+			put_page(page);
 			page = NULL;
 			goto out;
 		if (!PageUptodate(page) || PageError(page)) {
 			unlock_page(page);
+			put_page(page);
 			printk(KERN_ERR "ufs_change_blocknr: "
 			       "can not read page: ino %lu, index: %lu\n",
diff --git a/fs/ufs/util.h b/fs/ufs/util.h
index 9541759..b7fbf53 100644
--- a/fs/ufs/util.h
+++ b/fs/ufs/util.h
@@ -283,7 +283,7 @@ extern struct page *ufs_get_locked_page(struct address_space *mapping,
 static inline void ufs_put_locked_page(struct page *page)
        unlock_page(page);
+       put_page(page);
diff --git a/fs/xfs/libxfs/xfs_bmap.c b/fs/xfs/libxfs/xfs_bmap.c
index 041b694..ce41d7f 100644
--- a/fs/xfs/libxfs/xfs_bmap.c
+++ b/fs/xfs/libxfs/xfs_bmap.c
@@ -3742,11 +3742,11 @@ xfs_bmap_btalloc(
 		args.prod = align;
 		if ((args.mod = (xfs_extlen_t)do_mod(ap->offset, args.prod)))
 			args.mod = (xfs_extlen_t)(args.prod - args.mod);
-	} else if (mp->m_sb.sb_blocksize >= PAGE_CACHE_SIZE) {
+	} else if (mp->m_sb.sb_blocksize >= PAGE_SIZE) {
 		args.prod = 1;
 		args.mod = 0;
 	} else {
-		args.prod = PAGE_CACHE_SIZE >> mp->m_sb.sb_blocklog;
+		args.prod = PAGE_SIZE >> mp->m_sb.sb_blocklog;
 		if ((args.mod = (xfs_extlen_t)(do_mod(ap->offset, args.prod))))
diff --git a/fs/xfs/xfs_aops.c b/fs/xfs/xfs_aops.c
index d445a64..5b8ae03 100644
--- a/fs/xfs/xfs_aops.c
+++ b/fs/xfs/xfs_aops.c
@@ -704,7 +704,7 @@ next_buffer:
 	xfs_iunlock(ip, XFS_ILOCK_EXCL);
 out_invalidate:
-	xfs_vm_invalidatepage(page, 0, PAGE_CACHE_SIZE);
+	xfs_vm_invalidatepage(page, 0, PAGE_SIZE);
 	return;
@@ -925,9 +925,9 @@ xfs_do_writepage(
 	offset = i_size_read(inode);
-	end_index = offset >> PAGE_CACHE_SHIFT;
+	end_index = offset >> PAGE_SHIFT;
-		end_offset = (xfs_off_t)(page->index + 1) << PAGE_CACHE_SHIFT;
+		end_offset = (xfs_off_t)(page->index + 1) << PAGE_SHIFT;
 	else {
 		 * Check whether the page to write out is beyond or straddles
@@ -940,7 +940,7 @@ xfs_do_writepage(
 		 * |				    |      Straddles     |
-		unsigned offset_into_page = offset & (PAGE_CACHE_SIZE - 1);
+		unsigned offset_into_page = offset & (PAGE_SIZE - 1);
 		 * Skip the page if it is fully outside i_size, e.g. due to a
@@ -971,7 +971,7 @@ xfs_do_writepage(
 		 * memory is zeroed when mapped, and writes to that region are
 		 * not written out to the file."
-		zero_user_segment(page, offset_into_page, PAGE_CACHE_SIZE);
+		zero_user_segment(page, offset_into_page, PAGE_SIZE);
 		/* Adjust the end_offset to the end of file */
 		end_offset = offset;
@@ -1475,7 +1475,7 @@ xfs_vm_write_failed(
 	loff_t			block_offset;
 	loff_t			block_start;
 	loff_t			block_end;
-	loff_t			from = pos & (PAGE_CACHE_SIZE - 1);
+	loff_t			from = pos & (PAGE_SIZE - 1);
 	loff_t			to = from + len;
 	struct xfs_mount	*mp = XFS_I(inode)->i_mount;
@@ -1491,7 +1491,7 @@ xfs_vm_write_failed(
 	 * start of the page by using shifts rather than masks the mismatch
 	 * problem.
-	block_offset = (pos >> PAGE_CACHE_SHIFT) << PAGE_CACHE_SHIFT;
+	block_offset = (pos >> PAGE_SHIFT) << PAGE_SHIFT;
 	ASSERT(block_offset + from == pos);
@@ -1558,7 +1558,7 @@ xfs_vm_write_begin(
 	struct page		**pagep,
 	void			**fsdata)
 	struct page		*page;
 	int			status;
 	struct xfs_mount	*mp = XFS_I(mapping->host)->i_mount;
@@ -1592,7 +1592,7 @@ xfs_vm_write_begin(
 			truncate_pagecache_range(inode, start, pos + len);
+		put_page(page);
 		page = NULL;
diff --git a/fs/xfs/xfs_bmap_util.c b/fs/xfs/xfs_bmap_util.c
index a32c1dc..3b63098 100644
--- a/fs/xfs/xfs_bmap_util.c
+++ b/fs/xfs/xfs_bmap_util.c
@@ -1237,7 +1237,7 @@ xfs_free_file_space(
 	/* wait for the completion of any pending DIOs */
 	inode_dio_wait(VFS_I(ip));
-	rounding = max_t(xfs_off_t, 1 << mp->m_sb.sb_blocklog, PAGE_CACHE_SIZE);
+	rounding = max_t(xfs_off_t, 1 << mp->m_sb.sb_blocklog, PAGE_SIZE);
 	ioffset = round_down(offset, rounding);
 	iendoffset = round_up(offset + len, rounding) - 1;
 	error = filemap_write_and_wait_range(VFS_I(ip)->i_mapping, ioffset,
@@ -1466,7 +1466,7 @@ xfs_shift_file_space(
 	if (error)
 		return error;
 	error = invalidate_inode_pages2_range(VFS_I(ip)->i_mapping,
-					offset >> PAGE_CACHE_SHIFT, -1);
+					offset >> PAGE_SHIFT, -1);
 	if (error)
 		return error;
diff --git a/fs/xfs/xfs_file.c b/fs/xfs/xfs_file.c
index ac0fd32..569938a 100644
--- a/fs/xfs/xfs_file.c
+++ b/fs/xfs/xfs_file.c
@@ -106,8 +106,8 @@ xfs_iozero(
 		unsigned offset, bytes;
 		void *fsdata;
-		offset = (pos & (PAGE_CACHE_SIZE -1)); /* Within page */
-		bytes = PAGE_CACHE_SIZE - offset;
+		offset = (pos & (PAGE_SIZE -1)); /* Within page */
+		bytes = PAGE_SIZE - offset;
 		if (bytes > count)
 			bytes = count;
@@ -799,8 +799,8 @@ xfs_file_dio_aio_write(
 	/* see generic_file_direct_write() for why this is necessary */
 	if (mapping->nrpages) {
 		invalidate_inode_pages2_range(mapping,
-					      pos >> PAGE_CACHE_SHIFT,
-					      end >> PAGE_CACHE_SHIFT);
+					      pos >> PAGE_SHIFT,
+					      end >> PAGE_SHIFT);
 	if (ret > 0) {
@@ -1207,9 +1207,9 @@ xfs_find_get_desired_pgoff(
 	pagevec_init(&pvec, 0);
-	index = startoff >> PAGE_CACHE_SHIFT;
+	index = startoff >> PAGE_SHIFT;
 	endoff = XFS_FSB_TO_B(mp, map->br_startoff + map->br_blockcount);
-	end = endoff >> PAGE_CACHE_SHIFT;
+	end = endoff >> PAGE_SHIFT;
 	do {
 		int		want;
 		unsigned	nr_pages;
diff --git a/fs/xfs/xfs_linux.h b/fs/xfs/xfs_linux.h
index ec0e239..a8192dc 100644
--- a/fs/xfs/xfs_linux.h
+++ b/fs/xfs/xfs_linux.h
@@ -135,7 +135,7 @@ typedef __u32			xfs_nlink_t;
  * Size of block device i/o is parameterized here.
  * Currently the system supports page-sized i/o.
-#define	BLKDEV_IOSHIFT		PAGE_CACHE_SHIFT
+#define	BLKDEV_IOSHIFT		PAGE_SHIFT
 #define	BLKDEV_IOSIZE		(1<<BLKDEV_IOSHIFT)
 /* number of BB's per block device block */
 #define	BLKDEV_BB		BTOBB(BLKDEV_IOSIZE)
diff --git a/fs/xfs/xfs_mount.c b/fs/xfs/xfs_mount.c
index 536a0ee..cfd4210 100644
--- a/fs/xfs/xfs_mount.c
+++ b/fs/xfs/xfs_mount.c
@@ -171,7 +171,7 @@ xfs_sb_validate_fsb_count(
 	ASSERT(sbp->sb_blocklog >= BBSHIFT);
 	/* Limited by ULONG_MAX of page cache index */
-	if (nblocks >> (PAGE_CACHE_SHIFT - sbp->sb_blocklog) > ULONG_MAX)
+	if (nblocks >> (PAGE_SHIFT - sbp->sb_blocklog) > ULONG_MAX)
 		return -EFBIG;
 	return 0;
diff --git a/fs/xfs/xfs_mount.h b/fs/xfs/xfs_mount.h
index bac6b34..eafe257 100644
--- a/fs/xfs/xfs_mount.h
+++ b/fs/xfs/xfs_mount.h
@@ -231,12 +231,12 @@ static inline unsigned long
 xfs_preferred_iosize(xfs_mount_t *mp)
 	if (mp->m_flags & XFS_MOUNT_COMPAT_IOSIZE)
-		return PAGE_CACHE_SIZE;
+		return PAGE_SIZE;
 	return (mp->m_swidth ?
 		(mp->m_swidth << mp->m_sb.sb_blocklog) :
 		((mp->m_flags & XFS_MOUNT_DFLT_IOSIZE) ?
 			(1 << (int)MAX(mp->m_readio_log, mp->m_writeio_log)) :
-			PAGE_CACHE_SIZE));
+			PAGE_SIZE));
 #define XFS_LAST_UNMOUNT_WAS_CLEAN(mp)	\
diff --git a/fs/xfs/xfs_pnfs.c b/fs/xfs/xfs_pnfs.c
index ade236e..51ddaf2 100644
--- a/fs/xfs/xfs_pnfs.c
+++ b/fs/xfs/xfs_pnfs.c
@@ -293,8 +293,8 @@ xfs_fs_commit_blocks(
 		 * Make sure reads through the pagecache see the new data.
 		error = invalidate_inode_pages2_range(inode->i_mapping,
-					start >> PAGE_CACHE_SHIFT,
-					(end - 1) >> PAGE_CACHE_SHIFT);
+					start >> PAGE_SHIFT,
+					(end - 1) >> PAGE_SHIFT);
 		WARN_ON_ONCE(error);
 		error = xfs_iomap_write_unwritten(ip, start, length);
diff --git a/fs/xfs/xfs_super.c b/fs/xfs/xfs_super.c
index d760934..6082f54 100644
--- a/fs/xfs/xfs_super.c
+++ b/fs/xfs/xfs_super.c
@@ -570,10 +570,10 @@ xfs_max_file_offset(
 #if BITS_PER_LONG == 32
 # if defined(CONFIG_LBDAF)
 	ASSERT(sizeof(sector_t) == 8);
-	pagefactor = PAGE_CACHE_SIZE;
+	pagefactor = PAGE_SIZE;
 	bitshift = BITS_PER_LONG;
 # else
-	pagefactor = PAGE_CACHE_SIZE >> (PAGE_CACHE_SHIFT - blockshift);
+	pagefactor = PAGE_SIZE >> (PAGE_SHIFT - blockshift);
 # endif
 #endif
diff --git a/include/linux/bio.h b/include/linux/bio.h
index 88bc64f..6b7481f 100644
--- a/include/linux/bio.h
+++ b/include/linux/bio.h
@@ -41,7 +41,7 @@
 #endif
 #define BIO_MAX_PAGES		256
-#define BIO_MAX_SIZE		(BIO_MAX_PAGES << PAGE_CACHE_SHIFT)
+#define BIO_MAX_SIZE		(BIO_MAX_PAGES << PAGE_SHIFT)
 #define BIO_MAX_SECTORS		(BIO_MAX_SIZE >> 9)
diff --git a/include/linux/blkdev.h b/include/linux/blkdev.h
index 7e5d7e0..669e419 100644
--- a/include/linux/blkdev.h
+++ b/include/linux/blkdev.h
@@ -1372,7 +1372,7 @@ unsigned char *read_dev_sector(struct block_device *, sector_t, Sector *);
 static inline void put_dev_sector(Sector p)
-	page_cache_release(p.v);
+	put_page(p.v);
 static inline bool __bvec_gap_to_prev(struct request_queue *q,
diff --git a/include/linux/buffer_head.h b/include/linux/buffer_head.h
index c67f052..d48daa3 100644
--- a/include/linux/buffer_head.h
+++ b/include/linux/buffer_head.h
@@ -43,7 +43,7 @@ enum bh_state_bits {
-#define MAX_BUF_PER_PAGE (PAGE_CACHE_SIZE / 512)
+#define MAX_BUF_PER_PAGE (PAGE_SIZE / 512)
 struct page;
 struct buffer_head;
@@ -263,7 +263,7 @@ void buffer_init(void);
 static inline void attach_page_buffers(struct page *page,
 		struct buffer_head *head)
+	get_page(page);
 	SetPagePrivate(page);
 	set_page_private(page, (unsigned long)head);
diff --git a/include/linux/ceph/libceph.h b/include/linux/ceph/libceph.h
index e7975e4..db92a8d 100644
--- a/include/linux/ceph/libceph.h
+++ b/include/linux/ceph/libceph.h
@@ -176,8 +176,8 @@ extern void ceph_put_snap_context(struct ceph_snap_context *sc);
 static inline int calc_pages_for(u64 off, u64 len)
-	return ((off+len+PAGE_CACHE_SIZE-1) >> PAGE_CACHE_SHIFT) -
-		(off >> PAGE_CACHE_SHIFT);
+	return ((off+len+PAGE_SIZE-1) >> PAGE_SHIFT) -
+		(off >> PAGE_SHIFT);
 extern struct kmem_cache *ceph_inode_cachep;
diff --git a/include/linux/f2fs_fs.h b/include/linux/f2fs_fs.h
index 9eb215a..b90e9bd 100644
--- a/include/linux/f2fs_fs.h
+++ b/include/linux/f2fs_fs.h
@@ -262,7 +262,7 @@ struct f2fs_node {
  * For NAT entries
-#define NAT_ENTRY_PER_BLOCK (PAGE_CACHE_SIZE / sizeof(struct f2fs_nat_entry))
+#define NAT_ENTRY_PER_BLOCK (PAGE_SIZE / sizeof(struct f2fs_nat_entry))
 struct f2fs_nat_entry {
 	__u8 version;		/* latest version of cached nat entry */
@@ -282,7 +282,7 @@ struct f2fs_nat_block {
  * Not allow to change this.
 #define SIT_VBLOCK_MAP_SIZE 64
-#define SIT_ENTRY_PER_BLOCK (PAGE_CACHE_SIZE / sizeof(struct f2fs_sit_entry))
+#define SIT_ENTRY_PER_BLOCK (PAGE_SIZE / sizeof(struct f2fs_sit_entry))
  * Note that f2fs_sit_entry->vblocks has the following bit-field information.
diff --git a/include/linux/fs.h b/include/linux/fs.h
index 14a9719..304991a 100644
--- a/include/linux/fs.h
+++ b/include/linux/fs.h
@@ -929,7 +929,7 @@ static inline struct file *get_file(struct file *f)
 /* Page cache limit. The filesystems should put that into their s_maxbytes
    limits, otherwise bad things can happen in VM. */
 #if BITS_PER_LONG==32
-#define MAX_LFS_FILESIZE	(((loff_t)PAGE_CACHE_SIZE << (BITS_PER_LONG-1))-1)
+#define MAX_LFS_FILESIZE	(((loff_t)PAGE_SIZE << (BITS_PER_LONG-1))-1)
 #elif BITS_PER_LONG==64
 #define MAX_LFS_FILESIZE 	((loff_t)0x7fffffffffffffffLL)
 #endif
@@ -2067,7 +2067,7 @@ extern int generic_update_time(struct inode *, struct timespec *, int);
 /* /sys/fs */
 extern struct kobject *fs_kobj;
-#define MAX_RW_COUNT (INT_MAX & PAGE_CACHE_MASK)
+#define MAX_RW_COUNT (INT_MAX & PAGE_MASK)
 #ifdef CONFIG_MANDATORY_FILE_LOCKING
 extern int locks_mandatory_locked(struct file *);
diff --git a/include/linux/nfs_page.h b/include/linux/nfs_page.h
index f2f650f..efada23 100644
--- a/include/linux/nfs_page.h
+++ b/include/linux/nfs_page.h
@@ -184,7 +184,7 @@ nfs_list_entry(struct list_head *head)
 static inline
 loff_t req_offset(struct nfs_page *req)
-	return (((loff_t)req->wb_index) << PAGE_CACHE_SHIFT) + req->wb_offset;
+	return (((loff_t)req->wb_index) << PAGE_SHIFT) + req->wb_offset;
 #endif /* _LINUX_NFS_PAGE_H */
diff --git a/include/linux/pagemap.h b/include/linux/pagemap.h
index 1ebd65c..f396ccb 100644
--- a/include/linux/pagemap.h
+++ b/include/linux/pagemap.h
@@ -390,13 +390,13 @@ static inline pgoff_t page_to_pgoff(struct page *page)
 		return page->index << compound_order(page);
 	if (likely(!PageTransTail(page)))
-		return page->index << (PAGE_CACHE_SHIFT - PAGE_SHIFT);
+		return page->index;
 	 *  We don't initialize ->index for tail pages: calculate based on
 	 *  head page
-	pgoff = compound_head(page)->index << (PAGE_CACHE_SHIFT - PAGE_SHIFT);
+	pgoff = compound_head(page)->index;
 	pgoff += page - compound_head(page);
 	return pgoff;
@@ -406,12 +406,12 @@ static inline pgoff_t page_to_pgoff(struct page *page)
 static inline loff_t page_offset(struct page *page)
-	return ((loff_t)page->index) << PAGE_CACHE_SHIFT;
+	return ((loff_t)page->index) << PAGE_SHIFT;
 static inline loff_t page_file_offset(struct page *page)
-	return ((loff_t)page_file_index(page)) << PAGE_CACHE_SHIFT;
+	return ((loff_t)page_file_index(page)) << PAGE_SHIFT;
 extern pgoff_t linear_hugepage_index(struct vm_area_struct *vma,
@@ -425,7 +425,7 @@ static inline pgoff_t linear_page_index(struct vm_area_struct *vma,
 		return linear_hugepage_index(vma, address);
 	pgoff = (address - vma->vm_start) >> PAGE_SHIFT;
 	pgoff += vma->vm_pgoff;
-	return pgoff >> (PAGE_CACHE_SHIFT - PAGE_SHIFT);
+	return pgoff;
 extern void __lock_page(struct page *page);
@@ -671,8 +671,8 @@ static inline int add_to_page_cache(struct page *page,
 static inline unsigned long dir_pages(struct inode *inode)
-	return (unsigned long)(inode->i_size + PAGE_CACHE_SIZE - 1) >>
-			       PAGE_CACHE_SHIFT;
+	return (unsigned long)(inode->i_size + PAGE_SIZE - 1) >>
+			       PAGE_SHIFT;
 #endif /* _LINUX_PAGEMAP_H */
diff --git a/include/linux/swap.h b/include/linux/swap.h
index d18b65c..3d980ea 100644
--- a/include/linux/swap.h
+++ b/include/linux/swap.h
@@ -435,7 +435,7 @@ struct backing_dev_info;
 /* only sparc can not include linux/pagemap.h in this file
  * so leave page_cache_release and release_pages undeclared... */
 #define free_page_and_swap_cache(page) \
-	page_cache_release(page)
+	put_page(page)
 #define free_pages_and_swap_cache(pages, nr) \
 	release_pages((pages), (nr), false);
diff --git a/ipc/mqueue.c b/ipc/mqueue.c
index 781c139..ade739f 100644
--- a/ipc/mqueue.c
+++ b/ipc/mqueue.c
@@ -307,8 +307,8 @@ static int mqueue_fill_super(struct super_block *sb, void *data, int silent)
 	struct inode *inode;
 	struct ipc_namespace *ns = data;
-	sb->s_blocksize = PAGE_CACHE_SIZE;
-	sb->s_blocksize_bits = PAGE_CACHE_SHIFT;
+	sb->s_blocksize = PAGE_SIZE;
+	sb->s_blocksize_bits = PAGE_SHIFT;
 	sb->s_magic = MQUEUE_MAGIC;
 	sb->s_op = &mqueue_super_ops;
diff --git a/kernel/events/uprobes.c b/kernel/events/uprobes.c
index 220fc17..7edc95e 100644
--- a/kernel/events/uprobes.c
+++ b/kernel/events/uprobes.c
@@ -321,7 +321,7 @@ retry:
 	copy_to_page(new_page, vaddr, &opcode, UPROBE_SWBP_INSN_SIZE);
 	ret = __replace_page(vma, vaddr, old_page, new_page);
-	page_cache_release(new_page);
+	put_page(new_page);
 put_old:
 	put_page(old_page);
@@ -539,14 +539,14 @@ static int __copy_insn(struct address_space *mapping, struct file *filp,
 	 * see uprobe_register().
 	if (mapping->a_ops->readpage)
-		page = read_mapping_page(mapping, offset >> PAGE_CACHE_SHIFT, filp);
+		page = read_mapping_page(mapping, offset >> PAGE_SHIFT, filp);
 	else
-		page = shmem_read_mapping_page(mapping, offset >> PAGE_CACHE_SHIFT);
+		page = shmem_read_mapping_page(mapping, offset >> PAGE_SHIFT);
 	if (IS_ERR(page))
 		return PTR_ERR(page);
 	copy_from_page(page, offset, insn, nbytes);
-	page_cache_release(page);
+	put_page(page);
 	return 0;
diff --git a/mm/fadvise.c b/mm/fadvise.c
index b8a5bc6..b8024fa 100644
--- a/mm/fadvise.c
+++ b/mm/fadvise.c
@@ -97,8 +97,8 @@ SYSCALL_DEFINE4(fadvise64_64, int, fd, loff_t, offset, loff_t, len, int, advice)
 		break;
 	case POSIX_FADV_WILLNEED:
 		/* First and last PARTIAL page! */
-		start_index = offset >> PAGE_CACHE_SHIFT;
-		end_index = endbyte >> PAGE_CACHE_SHIFT;
+		start_index = offset >> PAGE_SHIFT;
+		end_index = endbyte >> PAGE_SHIFT;
 		/* Careful about overflow on the "+1" */
 		nrpages = end_index - start_index + 1;
@@ -124,8 +124,8 @@ SYSCALL_DEFINE4(fadvise64_64, int, fd, loff_t, offset, loff_t, len, int, advice)
 		 * preserved on the expectation that it is better to preserve
 		 * needed memory than to discard unneeded memory.
-		start_index = (offset+(PAGE_CACHE_SIZE-1)) >> PAGE_CACHE_SHIFT;
-		end_index = (endbyte >> PAGE_CACHE_SHIFT);
+		start_index = (offset+(PAGE_SIZE-1)) >> PAGE_SHIFT;
+		end_index = (endbyte >> PAGE_SHIFT);
 		if (end_index >= start_index) {
 			unsigned long count = invalidate_mapping_pages(mapping,
diff --git a/mm/filemap.c b/mm/filemap.c
index a8c69c8..f2479af 100644
--- a/mm/filemap.c
+++ b/mm/filemap.c
@@ -265,7 +265,7 @@ void delete_from_page_cache(struct page *page)
 	if (freepage)
 		freepage(page);
+	put_page(page);
 EXPORT_SYMBOL(delete_from_page_cache);
@@ -352,8 +352,8 @@ EXPORT_SYMBOL(filemap_flush);
 static int __filemap_fdatawait_range(struct address_space *mapping,
 				     loff_t start_byte, loff_t end_byte)
-	pgoff_t index = start_byte >> PAGE_CACHE_SHIFT;
-	pgoff_t end = end_byte >> PAGE_CACHE_SHIFT;
+	pgoff_t index = start_byte >> PAGE_SHIFT;
+	pgoff_t end = end_byte >> PAGE_SHIFT;
 	struct pagevec pvec;
 	int nr_pages;
 	int ret = 0;
@@ -550,7 +550,7 @@ int replace_page_cache_page(struct page *old, struct page *new, gfp_t gfp_mask)
 		pgoff_t offset = old->index;
 		freepage = mapping->a_ops->freepage;
-		page_cache_get(new);
+		get_page(new);
 		new->mapping = mapping;
 		new->index = offset;
@@ -572,7 +572,7 @@ int replace_page_cache_page(struct page *old, struct page *new, gfp_t gfp_mask)
 		radix_tree_preload_end();
 		if (freepage)
 			freepage(old);
-		page_cache_release(old);
+		put_page(old);
 	return error;
@@ -651,7 +651,7 @@ static int __add_to_page_cache_locked(struct page *page,
 		return error;
+	get_page(page);
 	page->mapping = mapping;
 	page->index = offset;
@@ -675,7 +675,7 @@ err_insert:
 	spin_unlock_irq(&mapping->tree_lock);
 	if (!huge)
 		mem_cgroup_cancel_charge(page, memcg, false);
+	put_page(page);
 	return error;
@@ -1083,7 +1083,7 @@ repeat:
 		 * include/linux/pagemap.h for details.
 		if (unlikely(page != *pagep)) {
+			put_page(page);
 			goto repeat;
@@ -1121,7 +1121,7 @@ repeat:
 		/* Has the page been truncated? */
 		if (unlikely(page->mapping != mapping)) {
 			unlock_page(page);
+			put_page(page);
 			goto repeat;
 		VM_BUG_ON_PAGE(page->index != offset, page);
@@ -1168,7 +1168,7 @@ repeat:
 	if (fgp_flags & FGP_LOCK) {
 		if (fgp_flags & FGP_NOWAIT) {
 			if (!trylock_page(page)) {
+				put_page(page);
 				return NULL;
 		} else {
@@ -1178,7 +1178,7 @@ repeat:
 			unlock_page(page);
+			put_page(page);
 			goto repeat;
@@ -1209,7 +1209,7 @@ no_page:
 		err = add_to_page_cache_lru(page, mapping, offset,
 				gfp_mask & GFP_RECLAIM_MASK);
 		if (unlikely(err)) {
+			put_page(page);
 			page = NULL;
 			if (err == -EEXIST)
 				goto repeat;
@@ -1278,7 +1278,7 @@ repeat:
 		/* Has the page moved? */
 		if (unlikely(page != *slot)) {
+			put_page(page);
 			goto repeat;
 export:
@@ -1343,7 +1343,7 @@ repeat:
+			put_page(page);
 			goto repeat;
@@ -1405,7 +1405,7 @@ repeat:
+			put_page(page);
 			goto repeat;
@@ -1415,7 +1415,7 @@ repeat:
 		 * negatives, which is just confusing to the caller.
 		if (page->mapping == NULL || page->index != iter.index) {
+			put_page(page);
 			break;
@@ -1482,7 +1482,7 @@ repeat:
+			put_page(page);
 			goto repeat;
@@ -1549,7 +1549,7 @@ repeat:
+			put_page(page);
 			goto repeat;
 export:
@@ -1610,11 +1610,11 @@ static ssize_t do_generic_file_read(struct file *filp, loff_t *ppos,
 	unsigned int prev_offset;
 	int error = 0;
-	prev_index = ra->prev_pos >> PAGE_CACHE_SHIFT;
-	prev_offset = ra->prev_pos & (PAGE_CACHE_SIZE-1);
-	last_index = (*ppos + iter->count + PAGE_CACHE_SIZE-1) >> PAGE_CACHE_SHIFT;
+	prev_index = ra->prev_pos >> PAGE_SHIFT;
+	prev_offset = ra->prev_pos & (PAGE_SIZE-1);
+	last_index = (*ppos + iter->count + PAGE_SIZE-1) >> PAGE_SHIFT;
 	for (;;) {
 		struct page *page;
@@ -1648,7 +1648,7 @@ find_page:
 			if (PageUptodate(page))
 				goto page_ok;
-			if (inode->i_blkbits == PAGE_CACHE_SHIFT ||
+			if (inode->i_blkbits == PAGE_SHIFT ||
 					!mapping->a_ops->is_partially_uptodate)
 				goto page_not_up_to_date;
@@ -1672,18 +1672,18 @@ page_ok:
 		if (unlikely(!isize || index > end_index)) {
+			put_page(page);
 			goto out;
 		/* nr is the maximum number of bytes to copy from this page */
-		nr = PAGE_CACHE_SIZE;
+		nr = PAGE_SIZE;
 		if (index == end_index) {
-			nr = ((isize - 1) & ~PAGE_CACHE_MASK) + 1;
+			nr = ((isize - 1) & ~PAGE_MASK) + 1;
 			if (nr <= offset) {
+				put_page(page);
 				goto out;
@@ -1711,11 +1711,11 @@ page_ok:
 		ret = copy_page_to_iter(page, offset, nr, iter);
 		offset += ret;
-		index += offset >> PAGE_CACHE_SHIFT;
-		offset &= ~PAGE_CACHE_MASK;
+		index += offset >> PAGE_SHIFT;
+		offset &= ~PAGE_MASK;
 		prev_offset = offset;
+		put_page(page);
 		written += ret;
 		if (!iov_iter_count(iter))
 			goto out;
@@ -1735,7 +1735,7 @@ page_not_up_to_date_locked:
 		/* Did it get truncated before we got the lock? */
 		if (!page->mapping) {
 			unlock_page(page);
+			put_page(page);
 			continue;
@@ -1757,7 +1757,7 @@ readpage:
 			if (error == AOP_TRUNCATED_PAGE) {
+				put_page(page);
 				error = 0;
 				goto find_page;
@@ -1774,7 +1774,7 @@ readpage:
 					 * invalidate_mapping_pages got it
 					unlock_page(page);
+					put_page(page);
 					goto find_page;
 				unlock_page(page);
@@ -1789,7 +1789,7 @@ readpage:
 readpage_error:
 		/* UHHUH! A synchronous read error occurred. Report it */
+		put_page(page);
 		goto out;
 no_cached_page:
@@ -1805,7 +1805,7 @@ no_cached_page:
 		if (error) {
+			put_page(page);
 			if (error == -EEXIST) {
 				error = 0;
 				goto find_page;
@@ -1817,10 +1817,10 @@ no_cached_page:
 out:
 	ra->prev_pos = prev_index;
-	ra->prev_pos <<= PAGE_CACHE_SHIFT;
+	ra->prev_pos <<= PAGE_SHIFT;
 	ra->prev_pos |= prev_offset;
-	*ppos = ((loff_t)index << PAGE_CACHE_SHIFT) + offset;
+	*ppos = ((loff_t)index << PAGE_SHIFT) + offset;
 	file_accessed(filp);
 	return written ? written : error;
@@ -1912,7 +1912,7 @@ static int page_cache_read(struct file *file, pgoff_t offset, gfp_t gfp_mask)
 		else if (ret == -EEXIST)
 			ret = 0; /* losing race to add is OK */
+		put_page(page);
 	} while (ret == AOP_TRUNCATED_PAGE);
@@ -2022,8 +2022,8 @@ int filemap_fault(struct vm_area_struct *vma, struct vm_fault *vmf)
 	loff_t size;
 	int ret = 0;
-	size = round_up(i_size_read(inode), PAGE_CACHE_SIZE);
-	if (offset >= size >> PAGE_CACHE_SHIFT)
+	size = round_up(i_size_read(inode), PAGE_SIZE);
+	if (offset >= size >> PAGE_SHIFT)
 		return VM_FAULT_SIGBUS;
@@ -2049,7 +2049,7 @@ retry_find:
 	if (!lock_page_or_retry(page, vma->vm_mm, vmf->flags)) {
+		put_page(page);
 		return ret | VM_FAULT_RETRY;
@@ -2072,10 +2072,10 @@ retry_find:
 	 * Found the page and have a reference on it.
 	 * We must recheck i_size under page lock.
-	if (unlikely(offset >= size >> PAGE_CACHE_SHIFT)) {
+	if (unlikely(offset >= size >> PAGE_SHIFT)) {
 		unlock_page(page);
+		put_page(page);
@@ -2120,7 +2120,7 @@ page_not_uptodate:
 		if (!PageUptodate(page))
 			error = -EIO;
+	put_page(page);
 	if (!error || error == AOP_TRUNCATED_PAGE)
 		goto retry_find;
@@ -2164,7 +2164,7 @@ repeat:
+			put_page(page);
 			goto repeat;
@@ -2178,8 +2178,8 @@ repeat:
 		if (page->mapping != mapping || !PageUptodate(page))
 			goto unlock;
-		size = round_up(i_size_read(mapping->host), PAGE_CACHE_SIZE);
-		if (page->index >= size >> PAGE_CACHE_SHIFT)
+		size = round_up(i_size_read(mapping->host), PAGE_SIZE);
+		if (page->index >= size >> PAGE_SHIFT)
 			goto unlock;
 		pte = vmf->pte + page->index - vmf->pgoff;
@@ -2195,7 +2195,7 @@ repeat:
 unlock:
 		unlock_page(page);
 skip:
+		put_page(page);
 next:
 		if (iter.index == vmf->max_pgoff)
 			break;
@@ -2278,7 +2278,7 @@ static struct page *wait_on_page_read(struct page *page)
 		wait_on_page_locked(page);
 		if (!PageUptodate(page)) {
+			put_page(page);
 			page = ERR_PTR(-EIO);
@@ -2301,7 +2301,7 @@ repeat:
 			return ERR_PTR(-ENOMEM);
 		err = add_to_page_cache_lru(page, mapping, index, gfp);
+			put_page(page);
 			if (err == -EEXIST)
 				goto repeat;
 			/* Presumably ENOMEM for radix tree node */
@@ -2311,7 +2311,7 @@ repeat:
 filler:
 		err = filler(data, page);
 		if (err < 0) {
+			put_page(page);
 			return ERR_PTR(err);
@@ -2364,7 +2364,7 @@ filler:
 	/* Case c or d, restart the operation */
 		unlock_page(page);
+		put_page(page);
 		goto repeat;
@@ -2511,7 +2511,7 @@ generic_file_direct_write(struct kiocb *iocb, struct iov_iter *from, loff_t pos)
 	struct iov_iter data;
 	write_len = iov_iter_count(from);
-	end = (pos + write_len - 1) >> PAGE_CACHE_SHIFT;
+	end = (pos + write_len - 1) >> PAGE_SHIFT;
 	written = filemap_write_and_wait_range(mapping, pos, pos + write_len - 1);
 	if (written)
@@ -2525,7 +2525,7 @@ generic_file_direct_write(struct kiocb *iocb, struct iov_iter *from, loff_t pos)
 		written = invalidate_inode_pages2_range(mapping,
-					pos >> PAGE_CACHE_SHIFT, end);
+					pos >> PAGE_SHIFT, end);
 		 * If a page can not be invalidated, return 0 to fall back
 		 * to buffered write.
@@ -2550,7 +2550,7 @@ generic_file_direct_write(struct kiocb *iocb, struct iov_iter *from, loff_t pos)
 	if (written > 0) {
@@ -2611,8 +2611,8 @@ ssize_t generic_perform_write(struct file *file,
 		size_t copied;		/* Bytes copied from user */
 		void *fsdata;
-		offset = (pos & (PAGE_CACHE_SIZE - 1));
-		bytes = min_t(unsigned long, PAGE_CACHE_SIZE - offset,
+		offset = (pos & (PAGE_SIZE - 1));
+		bytes = min_t(unsigned long, PAGE_SIZE - offset,
 						iov_iter_count(i));
 again:
@@ -2665,7 +2665,7 @@ again:
 			 * because not all segments in the iov can be copied at
 			 * once without a pagefault.
 						iov_iter_single_seg_count(i));
 			goto again;
@@ -2752,8 +2752,8 @@ ssize_t __generic_file_write_iter(struct kiocb *iocb, struct iov_iter *from)
 			iocb->ki_pos = endbyte + 1;
 			written += status;
-						 endbyte >> PAGE_CACHE_SHIFT);
+						 endbyte >> PAGE_SHIFT);
 		} else {
 			 * We don't know how much we wrote, so just return
diff --git a/mm/hugetlb.c b/mm/hugetlb.c
index 06058ea..19d0d08 100644
--- a/mm/hugetlb.c
+++ b/mm/hugetlb.c
@@ -3346,7 +3346,7 @@ retry_avoidcopy:
 			old_page != pagecache_page)
 		outside_reserve = 1;
-	page_cache_get(old_page);
+	get_page(old_page);
 	 * Drop page table lock as buddy allocator may be called. It will
@@ -3364,7 +3364,7 @@ retry_avoidcopy:
 		 * may get SIGKILLed if it later faults.
 		if (outside_reserve) {
 			BUG_ON(huge_pte_none(pte));
 			unmap_ref_private(mm, vma, old_page, address);
@@ -3425,9 +3425,9 @@ retry_avoidcopy:
 	spin_unlock(ptl);
 	mmu_notifier_invalidate_range_end(mm, mmun_start, mmun_end);
 out_release_all:
 out_release_old:
 	spin_lock(ptl); /* Caller expects lock to be held */
 	return ret;
diff --git a/mm/madvise.c b/mm/madvise.c
index a011473..07427d3 100644
--- a/mm/madvise.c
+++ b/mm/madvise.c
@@ -170,7 +170,7 @@ static int swapin_walk_pmd_entry(pmd_t *pmd, unsigned long start,
 		page = read_swap_cache_async(entry, GFP_HIGHUSER_MOVABLE,
 								vma, index);
 		if (page)
+			put_page(page);
 	return 0;
@@ -204,14 +204,14 @@ static void force_shm_swapin_readahead(struct vm_area_struct *vma,
 		page = find_get_entry(mapping, index);
 		if (!radix_tree_exceptional_entry(page)) {
 			if (page)
+				put_page(page);
 			continue;
 		swap = radix_to_swp_entry(page);
 		page = read_swap_cache_async(swap, GFP_HIGHUSER_MOVABLE,
 								NULL, 0);
 		if (page)
+			put_page(page);
 	lru_add_drain();	/* Push any new pages onto the LRU now */
diff --git a/mm/memory-failure.c b/mm/memory-failure.c
index 5a544c6..78f5f26 100644
--- a/mm/memory-failure.c
+++ b/mm/memory-failure.c
@@ -538,7 +538,7 @@ static int delete_from_lru_cache(struct page *p)
 		 * drop the page count elevated by isolate_lru_page()
-		page_cache_release(p);
+		put_page(p);
 		return 0;
 	return -EIO;
diff --git a/mm/memory.c b/mm/memory.c
index 098f00d..07a4204 100644
--- a/mm/memory.c
+++ b/mm/memory.c
@@ -2054,7 +2054,7 @@ static inline int wp_page_reuse(struct mm_struct *mm,
 		VM_BUG_ON_PAGE(PageAnon(page), page);
 		mapping = page->mapping;
 		unlock_page(page);
+		put_page(page);
 		if ((dirtied || page_mkwrite) && mapping) {
@@ -2188,7 +2188,7 @@ static int wp_page_copy(struct mm_struct *mm, struct vm_area_struct *vma,
 	if (new_page)
 	pte_unmap_unlock(page_table, ptl);
@@ -2203,14 +2203,14 @@ static int wp_page_copy(struct mm_struct *mm, struct vm_area_struct *vma,
 				munlock_vma_page(old_page);
 			unlock_page(old_page);
 	return page_copied ? VM_FAULT_WRITE : 0;
 oom_free_new:
 oom:
 	if (old_page)
 	return VM_FAULT_OOM;
@@ -2258,7 +2258,7 @@ static int wp_page_shared(struct mm_struct *mm, struct vm_area_struct *vma,
 	int page_mkwrite = 0;
 	if (vma->vm_ops && vma->vm_ops->page_mkwrite) {
 		int tmp;
@@ -2267,7 +2267,7 @@ static int wp_page_shared(struct mm_struct *mm, struct vm_area_struct *vma,
 		tmp = do_page_mkwrite(vma, old_page, address);
 		if (unlikely(!tmp || (tmp &
 				      (VM_FAULT_ERROR | VM_FAULT_NOPAGE)))) {
 			return tmp;
@@ -2281,7 +2281,7 @@ static int wp_page_shared(struct mm_struct *mm, struct vm_area_struct *vma,
 		if (!pte_same(*page_table, orig_pte)) {
 			return 0;
 		page_mkwrite = 1;
@@ -2341,7 +2341,7 @@ static int do_wp_page(struct mm_struct *mm, struct vm_area_struct *vma,
 	if (PageAnon(old_page) && !PageKsm(old_page)) {
 		if (!trylock_page(old_page)) {
 			page_table = pte_offset_map_lock(mm, pmd, address,
@@ -2349,10 +2349,10 @@ static int do_wp_page(struct mm_struct *mm, struct vm_area_struct *vma,
 				return 0;
 		if (reuse_swap_page(old_page)) {
@@ -2375,7 +2375,7 @@ static int do_wp_page(struct mm_struct *mm, struct vm_area_struct *vma,
 	 * Ok, we need to copy. Oh, well..
 	return wp_page_copy(mm, vma, address, page_table, pmd,
@@ -2619,7 +2619,7 @@ static int do_swap_page(struct mm_struct *mm, struct vm_area_struct *vma,
 		 * parallel locked swapcache.
 		unlock_page(swapcache);
-		page_cache_release(swapcache);
+		put_page(swapcache);
 	if (flags & FAULT_FLAG_WRITE) {
@@ -2641,10 +2641,10 @@ out_nomap:
 out_page:
 	unlock_page(page);
 out_release:
+	put_page(page);
 	if (page != swapcache) {
 	return ret;
@@ -2752,7 +2752,7 @@ static int do_anonymous_page(struct mm_struct *mm, struct vm_area_struct *vma,
 	if (userfaultfd_missing(vma)) {
+		put_page(page);
 		return handle_userfault(vma, address, flags,
 					VM_UFFD_MISSING);
@@ -2771,10 +2771,10 @@ unlock:
 	return 0;
 release:
+	put_page(page);
 	goto unlock;
 oom_free_page:
+	put_page(page);
 oom:
@@ -2807,7 +2807,7 @@ static int __do_fault(struct vm_area_struct *vma, unsigned long address,
 	if (unlikely(PageHWPoison(vmf.page))) {
 		if (ret & VM_FAULT_LOCKED)
 			unlock_page(vmf.page);
-		page_cache_release(vmf.page);
+		put_page(vmf.page);
 		return VM_FAULT_HWPOISON;
@@ -2996,7 +2996,7 @@ static int do_read_fault(struct mm_struct *mm, struct vm_area_struct *vma,
 	if (unlikely(!pte_same(*pte, orig_pte))) {
 		pte_unmap_unlock(pte, ptl);
 		unlock_page(fault_page);
-		page_cache_release(fault_page);
+		put_page(fault_page);
 		return ret;
 	do_set_pte(vma, address, fault_page, pte, false, false);
@@ -3024,7 +3024,7 @@ static int do_cow_fault(struct mm_struct *mm, struct vm_area_struct *vma,
 	if (mem_cgroup_try_charge(new_page, mm, GFP_KERNEL, &memcg, false)) {
@@ -3041,7 +3041,7 @@ static int do_cow_fault(struct mm_struct *mm, struct vm_area_struct *vma,
 		if (fault_page) {
 		} else {
 			 * The fault handler has no page to lock, so it holds
@@ -3057,7 +3057,7 @@ static int do_cow_fault(struct mm_struct *mm, struct vm_area_struct *vma,
 	if (fault_page) {
 	} else {
@@ -3068,7 +3068,7 @@ static int do_cow_fault(struct mm_struct *mm, struct vm_area_struct *vma,
 	return ret;
 uncharge_out:
 	mem_cgroup_cancel_charge(new_page, memcg, false);
 	return ret;
@@ -3096,7 +3096,7 @@ static int do_shared_fault(struct mm_struct *mm, struct vm_area_struct *vma,
 		tmp = do_page_mkwrite(vma, fault_page, address);
 				(tmp & (VM_FAULT_ERROR | VM_FAULT_NOPAGE)))) {
 			return tmp;
@@ -3105,7 +3105,7 @@ static int do_shared_fault(struct mm_struct *mm, struct vm_area_struct *vma,
 		return ret;
 	do_set_pte(vma, address, fault_page, pte, true, false);
@@ -3736,7 +3736,7 @@ static int __access_remote_vm(struct task_struct *tsk, struct mm_struct *mm,
 						    buf, maddr + offset, bytes);
 			kunmap(page);
+			put_page(page);
 		len -= bytes;
 		buf += bytes;
diff --git a/mm/mincore.c b/mm/mincore.c
index 563f320..0eed23d 100644
--- a/mm/mincore.c
+++ b/mm/mincore.c
@@ -75,7 +75,7 @@ static unsigned char mincore_page(struct address_space *mapping, pgoff_t pgoff)
 #endif
 	if (page) {
 		present = PageUptodate(page);
+		put_page(page);
 	return present;
@@ -226,7 +226,7 @@ SYSCALL_DEFINE3(mincore, unsigned long, start, size_t, len,
 	unsigned char *tmp;
 	/* Check the start address: needs to be page-aligned.. */
- 	if (start & ~PAGE_CACHE_MASK)
+	if (start & ~PAGE_MASK)
 		return -EINVAL;
 	/* ..and we need to be passed a valid user-space range */
diff --git a/mm/nommu.c b/mm/nommu.c
index de8b6b6..102e257 100644
--- a/mm/nommu.c
+++ b/mm/nommu.c
@@ -141,7 +141,7 @@ long __get_user_pages(struct task_struct *tsk, struct mm_struct *mm,
 		if (pages) {
 			pages[i] = virt_to_page(start);
 			if (pages[i])
-				page_cache_get(pages[i]);
+				get_page(pages[i]);
 		if (vmas)
 			vmas[i] = vma;
diff --git a/mm/page-writeback.c b/mm/page-writeback.c
index 11ff8f7..999792d 100644
--- a/mm/page-writeback.c
+++ b/mm/page-writeback.c
@@ -2176,8 +2176,8 @@ int write_cache_pages(struct address_space *mapping,
 			cycled = 0;
 		end = -1;
 	} else {
-		index = wbc->range_start >> PAGE_CACHE_SHIFT;
-		end = wbc->range_end >> PAGE_CACHE_SHIFT;
+		index = wbc->range_start >> PAGE_SHIFT;
+		end = wbc->range_end >> PAGE_SHIFT;
 		if (wbc->range_start == 0 && wbc->range_end == LLONG_MAX)
 			range_whole = 1;
 		cycled = 1; /* ignore range_cyclic tests */
@@ -2382,14 +2382,14 @@ int write_one_page(struct page *page, int wait)
 		wait_on_page_writeback(page);
 	if (clear_page_dirty_for_io(page)) {
-		page_cache_get(page);
+		get_page(page);
 		ret = mapping->a_ops->writepage(page, &wbc);
 		if (ret == 0 && wait) {
 			if (PageError(page))
 				ret = -EIO;
+		put_page(page);
 	} else {
 		unlock_page(page);
@@ -2431,7 +2431,7 @@ void account_page_dirtied(struct page *page, struct address_space *mapping)
 		__inc_zone_page_state(page, NR_DIRTIED);
 		__inc_wb_stat(wb, WB_RECLAIMABLE);
 		__inc_wb_stat(wb, WB_DIRTIED);
-		task_io_account_write(PAGE_CACHE_SIZE);
+		task_io_account_write(PAGE_SIZE);
 		current->nr_dirtied++;
 		this_cpu_inc(bdp_ratelimits);
@@ -2450,7 +2450,7 @@ void account_page_cleaned(struct page *page, struct address_space *mapping,
 		mem_cgroup_dec_page_stat(page, MEM_CGROUP_STAT_DIRTY);
 		dec_zone_page_state(page, NR_FILE_DIRTY);
 		dec_wb_stat(wb, WB_RECLAIMABLE);
-		task_io_account_cancelled_write(PAGE_CACHE_SIZE);
+		task_io_account_cancelled_write(PAGE_SIZE);
diff --git a/mm/page_io.c b/mm/page_io.c
index 18aac78..cd92e3d 100644
--- a/mm/page_io.c
+++ b/mm/page_io.c
@@ -252,7 +252,7 @@ out:
 static sector_t swap_page_sector(struct page *page)
-	return (sector_t)__page_file_index(page) << (PAGE_CACHE_SHIFT - 9);
+	return (sector_t)__page_file_index(page) << (PAGE_SHIFT - 9);
 int __swap_writepage(struct page *page, struct writeback_control *wbc,
diff --git a/mm/readahead.c b/mm/readahead.c
index 20e58e8..40be3ae 100644
--- a/mm/readahead.c
+++ b/mm/readahead.c
@@ -47,11 +47,11 @@ static void read_cache_pages_invalidate_page(struct address_space *mapping,
 			BUG();
-		do_invalidatepage(page, 0, PAGE_CACHE_SIZE);
+		do_invalidatepage(page, 0, PAGE_SIZE);
 		page->mapping = NULL;
 		unlock_page(page);
+	put_page(page);
@@ -93,14 +93,14 @@ int read_cache_pages(struct address_space *mapping, struct list_head *pages,
 			read_cache_pages_invalidate_page(mapping, page);
 			continue;
+		put_page(page);
 		ret = filler(data, page);
 		if (unlikely(ret)) {
 			read_cache_pages_invalidate_pages(mapping, pages);
 			break;
-		task_io_account_read(PAGE_CACHE_SIZE);
+		task_io_account_read(PAGE_SIZE);
 	return ret;
@@ -130,7 +130,7 @@ static int read_pages(struct address_space *mapping, struct file *filp,
 				mapping_gfp_constraint(mapping, GFP_KERNEL))) {
 			mapping->a_ops->readpage(filp, page);
+		put_page(page);
 	ret = 0;
@@ -163,7 +163,7 @@ int __do_page_cache_readahead(struct address_space *mapping, struct file *filp,
 	if (isize == 0)
 		goto out;
 	 * Preallocate as many pages as we will need.
@@ -216,7 +216,7 @@ int force_page_cache_readahead(struct address_space *mapping, struct file *filp,
 	while (nr_to_read) {
 		int err;
-		unsigned long this_chunk = (2 * 1024 * 1024) / PAGE_CACHE_SIZE;
+		unsigned long this_chunk = (2 * 1024 * 1024) / PAGE_SIZE;
 		if (this_chunk > nr_to_read)
 			this_chunk = nr_to_read;
@@ -425,7 +425,7 @@ ondemand_readahead(struct address_space *mapping,
 	 * trivial case: (offset - prev_offset) == 1
 	 * unaligned reads: (offset - prev_offset) == 0
-	prev_offset = (unsigned long long)ra->prev_pos >> PAGE_CACHE_SHIFT;
+	prev_offset = (unsigned long long)ra->prev_pos >> PAGE_SHIFT;
 	if (offset - prev_offset <= 1UL)
 		goto initial_readahead;
@@ -558,8 +558,8 @@ SYSCALL_DEFINE3(readahead, int, fd, loff_t, offset, size_t, count)
 	if (f.file) {
 		if (f.file->f_mode & FMODE_READ) {
 			struct address_space *mapping = f.file->f_mapping;
-			pgoff_t start = offset >> PAGE_CACHE_SHIFT;
-			pgoff_t end = (offset + count - 1) >> PAGE_CACHE_SHIFT;
+			pgoff_t start = offset >> PAGE_SHIFT;
+			pgoff_t end = (offset + count - 1) >> PAGE_SHIFT;
 			unsigned long len = end - start + 1;
 			ret = do_readahead(mapping, f.file, start, len);
diff --git a/mm/rmap.c b/mm/rmap.c
index c399a0d..525b92f 100644
--- a/mm/rmap.c
+++ b/mm/rmap.c
@@ -1555,7 +1555,7 @@ static int try_to_unmap_one(struct page *page, struct vm_area_struct *vma,
 discard:
 	page_remove_rmap(page, PageHuge(page));
+	put_page(page);
 out_unmap:
diff --git a/mm/shmem.c b/mm/shmem.c
index 9428c51..719bd6b 100644
--- a/mm/shmem.c
+++ b/mm/shmem.c
@@ -75,8 +75,8 @@ static struct vfsmount *shm_mnt;
 #include "internal.h"
-#define BLOCKS_PER_PAGE  (PAGE_CACHE_SIZE/512)
-#define VM_ACCT(size)    (PAGE_CACHE_ALIGN(size) >> PAGE_SHIFT)
+#define BLOCKS_PER_PAGE  (PAGE_SIZE/512)
+#define VM_ACCT(size)    (PAGE_ALIGN(size) >> PAGE_SHIFT)
 /* Pretend that each entry is of this size in directory's i_size */
 #define BOGO_DIRENT_SIZE 20
@@ -176,13 +176,13 @@ static inline int shmem_reacct_size(unsigned long flags,
 static inline int shmem_acct_block(unsigned long flags)
 	return (flags & VM_NORESERVE) ?
-		security_vm_enough_memory_mm(current->mm, VM_ACCT(PAGE_CACHE_SIZE)) : 0;
+		security_vm_enough_memory_mm(current->mm, VM_ACCT(PAGE_SIZE)) : 0;
 static inline void shmem_unacct_blocks(unsigned long flags, long pages)
 	if (flags & VM_NORESERVE)
-		vm_unacct_memory(pages * VM_ACCT(PAGE_CACHE_SIZE));
+		vm_unacct_memory(pages * VM_ACCT(PAGE_SIZE));
 static const struct super_operations shmem_ops;
@@ -300,7 +300,7 @@ static int shmem_add_to_page_cache(struct page *page,
 	VM_BUG_ON_PAGE(!PageLocked(page), page);
 	VM_BUG_ON_PAGE(!PageSwapBacked(page), page);
+	get_page(page);
 	page->index = index;
@@ -318,7 +318,7 @@ static int shmem_add_to_page_cache(struct page *page,
 	} else {
+		put_page(page);
 	return error;
@@ -338,7 +338,7 @@ static void shmem_delete_from_page_cache(struct page *page, void *radswap)
 	__dec_zone_page_state(page, NR_FILE_PAGES);
 	__dec_zone_page_state(page, NR_SHMEM);
+	put_page(page);
 	BUG_ON(error);
@@ -474,10 +474,10 @@ static void shmem_undo_range(struct inode *inode, loff_t lstart, loff_t lend,
 	struct address_space *mapping = inode->i_mapping;
 	struct shmem_inode_info *info = SHMEM_I(inode);
-	pgoff_t start = (lstart + PAGE_CACHE_SIZE - 1) >> PAGE_CACHE_SHIFT;
-	pgoff_t end = (lend + 1) >> PAGE_CACHE_SHIFT;
-	unsigned int partial_start = lstart & (PAGE_CACHE_SIZE - 1);
-	unsigned int partial_end = (lend + 1) & (PAGE_CACHE_SIZE - 1);
+	pgoff_t start = (lstart + PAGE_SIZE - 1) >> PAGE_SHIFT;
+	pgoff_t end = (lend + 1) >> PAGE_SHIFT;
+	unsigned int partial_start = lstart & (PAGE_SIZE - 1);
+	unsigned int partial_end = (lend + 1) & (PAGE_SIZE - 1);
 	pgoff_t indices[PAGEVEC_SIZE];
 	long nr_swaps_freed = 0;
@@ -530,7 +530,7 @@ static void shmem_undo_range(struct inode *inode, loff_t lstart, loff_t lend,
 		struct page *page = NULL;
 		shmem_getpage(inode, start - 1, &page, SGP_READ, NULL);
 		if (page) {
-			unsigned int top = PAGE_CACHE_SIZE;
+			unsigned int top = PAGE_SIZE;
 			if (start > end) {
 				top = partial_end;
 				partial_end = 0;
@@ -538,7 +538,7 @@ static void shmem_undo_range(struct inode *inode, loff_t lstart, loff_t lend,
 			zero_user_segment(page, partial_start, top);
 			set_page_dirty(page);
 			unlock_page(page);
+			put_page(page);
 	if (partial_end) {
@@ -548,7 +548,7 @@ static void shmem_undo_range(struct inode *inode, loff_t lstart, loff_t lend,
 			zero_user_segment(page, 0, partial_end);
 			unlock_page(page);
+			put_page(page);
 	if (start >= end)
@@ -833,7 +833,7 @@ int shmem_unuse(swp_entry_t swap, struct page *page)
 		mem_cgroup_commit_charge(page, memcg, true, false);
 out:
 	unlock_page(page);
+	put_page(page);
 	return error;
@@ -1080,7 +1080,7 @@ static int shmem_replace_page(struct page **pagep, gfp_t gfp,
 	if (!newpage)
 		return -ENOMEM;
-	page_cache_get(newpage);
+	get_page(newpage);
 	copy_highpage(newpage, oldpage);
 	flush_dcache_page(newpage);
@@ -1120,8 +1120,8 @@ static int shmem_replace_page(struct page **pagep, gfp_t gfp,
 	set_page_private(oldpage, 0);
 	unlock_page(oldpage);
-	page_cache_release(oldpage);
+	put_page(oldpage);
 	return error;
@@ -1145,7 +1145,7 @@ static int shmem_getpage_gfp(struct inode *inode, pgoff_t index,
 	int once = 0;
 	int alloced = 0;
-	if (index > (MAX_LFS_FILESIZE >> PAGE_CACHE_SHIFT))
+	if (index > (MAX_LFS_FILESIZE >> PAGE_SHIFT))
 		return -EFBIG;
 repeat:
 	swap.val = 0;
@@ -1156,7 +1156,7 @@ repeat:
 	if (sgp != SGP_WRITE && sgp != SGP_FALLOC &&
-	    ((loff_t)index << PAGE_CACHE_SHIFT) >= i_size_read(inode)) {
+	    ((loff_t)index << PAGE_SHIFT) >= i_size_read(inode)) {
 		error = -EINVAL;
 		goto unlock;
@@ -1169,7 +1169,7 @@ repeat:
 		if (sgp != SGP_READ)
 			goto clear;
 		unlock_page(page);
+		put_page(page);
 		page = NULL;
 	if (page || (sgp == SGP_READ && !swap.val)) {
@@ -1327,7 +1327,7 @@ clear:
 	/* Perhaps the file has been truncated since we checked */
 		if (alloced) {
 			ClearPageDirty(page);
 			delete_from_page_cache(page);
@@ -1355,7 +1355,7 @@ failed:
 unlock:
 	if (page) {
 		unlock_page(page);
+		put_page(page);
 	if (error == -ENOSPC && !once++) {
@@ -1577,7 +1577,7 @@ shmem_write_begin(struct file *file, struct address_space *mapping,
 	/* i_mutex is held by caller */
 	if (unlikely(info->seals)) {
@@ -1601,16 +1601,16 @@ shmem_write_end(struct file *file, struct address_space *mapping,
 		i_size_write(inode, pos + copied);
-		if (copied < PAGE_CACHE_SIZE) {
-			unsigned from = pos & (PAGE_CACHE_SIZE - 1);
+		if (copied < PAGE_SIZE) {
+			unsigned from = pos & (PAGE_SIZE - 1);
 			zero_user_segments(page, 0, from,
-					from + copied, PAGE_CACHE_SIZE);
+					from + copied, PAGE_SIZE);
 		SetPageUptodate(page);
 	unlock_page(page);
+	put_page(page);
 	return copied;
@@ -1635,8 +1635,8 @@ static ssize_t shmem_file_read_iter(struct kiocb *iocb, struct iov_iter *to)
 	if (!iter_is_iovec(to))
 		sgp = SGP_DIRTY;
-	index = *ppos >> PAGE_CACHE_SHIFT;
-	offset = *ppos & ~PAGE_CACHE_MASK;
+	index = *ppos >> PAGE_SHIFT;
+	offset = *ppos & ~PAGE_MASK;
 	for (;;) {
@@ -1644,11 +1644,11 @@ static ssize_t shmem_file_read_iter(struct kiocb *iocb, struct iov_iter *to)
 		unsigned long nr, ret;
 		loff_t i_size = i_size_read(inode);
-		end_index = i_size >> PAGE_CACHE_SHIFT;
+		end_index = i_size >> PAGE_SHIFT;
 		if (index > end_index)
 			break;
-			nr = i_size & ~PAGE_CACHE_MASK;
+			nr = i_size & ~PAGE_MASK;
 			if (nr <= offset)
 				break;
@@ -1666,14 +1666,14 @@ static ssize_t shmem_file_read_iter(struct kiocb *iocb, struct iov_iter *to)
 		 * We must evaluate after, since reads (unlike writes)
 		 * are called without i_mutex protection against truncate
+		nr = PAGE_SIZE;
 			if (nr <= offset) {
 				if (page)
+					put_page(page);
 				break;
@@ -1694,7 +1694,7 @@ static ssize_t shmem_file_read_iter(struct kiocb *iocb, struct iov_iter *to)
 				mark_page_accessed(page);
 		} else {
 			page = ZERO_PAGE(0);
+			get_page(page);
@@ -1704,10 +1704,10 @@ static ssize_t shmem_file_read_iter(struct kiocb *iocb, struct iov_iter *to)
 		ret = copy_page_to_iter(page, offset, nr, to);
 		retval += ret;
 		offset += ret;
+		put_page(page);
 		if (!iov_iter_count(to))
 			break;
 		if (ret < nr) {
@@ -1717,7 +1717,7 @@ static ssize_t shmem_file_read_iter(struct kiocb *iocb, struct iov_iter *to)
 		cond_resched();
-	*ppos = ((loff_t) index << PAGE_CACHE_SHIFT) + offset;
+	*ppos = ((loff_t) index << PAGE_SHIFT) + offset;
 	file_accessed(file);
 	return retval ? retval : error;
@@ -1755,9 +1755,9 @@ static ssize_t shmem_file_splice_read(struct file *in, loff_t *ppos,
 	if (splice_grow_spd(pipe, &spd))
 		return -ENOMEM;
-	loff = *ppos & ~PAGE_CACHE_MASK;
-	req_pages = (len + loff + PAGE_CACHE_SIZE - 1) >> PAGE_CACHE_SHIFT;
+	loff = *ppos & ~PAGE_MASK;
+	req_pages = (len + loff + PAGE_SIZE - 1) >> PAGE_SHIFT;
 	nr_pages = min(req_pages, spd.nr_pages_max);
 	spd.nr_pages = find_get_pages_contig(mapping, index,
@@ -1774,7 +1774,7 @@ static ssize_t shmem_file_splice_read(struct file *in, loff_t *ppos,
 		index++;
 	nr_pages = spd.nr_pages;
 	spd.nr_pages = 0;
@@ -1784,7 +1784,7 @@ static ssize_t shmem_file_splice_read(struct file *in, loff_t *ppos,
 		if (!len)
 			break;
-		this_len = min_t(unsigned long, len, PAGE_CACHE_SIZE - loff);
+		this_len = min_t(unsigned long, len, PAGE_SIZE - loff);
 		page = spd.pages[page_nr];
 		if (!PageUptodate(page) || page->mapping != mapping) {
@@ -1793,19 +1793,19 @@ static ssize_t shmem_file_splice_read(struct file *in, loff_t *ppos,
 			if (error)
 				break;
 			unlock_page(page);
-			page_cache_release(spd.pages[page_nr]);
+			put_page(spd.pages[page_nr]);
 			spd.pages[page_nr] = page;
-		end_index = (isize - 1) >> PAGE_CACHE_SHIFT;
+		end_index = (isize - 1) >> PAGE_SHIFT;
 			break;
 		if (end_index == index) {
 			unsigned int plen;
-			plen = ((isize - 1) & ~PAGE_CACHE_MASK) + 1;
+			plen = ((isize - 1) & ~PAGE_MASK) + 1;
 			if (plen <= loff)
 				break;
@@ -1822,7 +1822,7 @@ static ssize_t shmem_file_splice_read(struct file *in, loff_t *ppos,
 	while (page_nr < nr_pages)
-		page_cache_release(spd.pages[page_nr++]);
+		put_page(spd.pages[page_nr++]);
 	if (spd.nr_pages)
 		error = splice_to_pipe(pipe, &spd);
@@ -1904,10 +1904,10 @@ static loff_t shmem_file_llseek(struct file *file, loff_t offset, int whence)
 	else if (offset >= inode->i_size)
 		offset = -ENXIO;
 	else {
-		start = offset >> PAGE_CACHE_SHIFT;
-		end = (inode->i_size + PAGE_CACHE_SIZE - 1) >> PAGE_CACHE_SHIFT;
+		start = offset >> PAGE_SHIFT;
+		end = (inode->i_size + PAGE_SIZE - 1) >> PAGE_SHIFT;
 		new_offset = shmem_seek_hole_data(mapping, start, end, whence);
-		new_offset <<= PAGE_CACHE_SHIFT;
+		new_offset <<= PAGE_SHIFT;
 		if (new_offset > offset) {
 			if (new_offset < inode->i_size)
 				offset = new_offset;
@@ -2203,8 +2203,8 @@ static long shmem_fallocate(struct file *file, int mode, loff_t offset,
 		goto out;
-	end = (offset + len + PAGE_CACHE_SIZE - 1) >> PAGE_CACHE_SHIFT;
+	end = (offset + len + PAGE_SIZE - 1) >> PAGE_SHIFT;
 	/* Try to avoid a swapstorm if len is impossible to satisfy */
 	if (sbinfo->max_blocks && end - start > sbinfo->max_blocks) {
 		error = -ENOSPC;
@@ -2237,8 +2237,8 @@ static long shmem_fallocate(struct file *file, int mode, loff_t offset,
 		if (error) {
 			/* Remove the !PageUptodate pages we added */
 			shmem_undo_range(inode,
-				(loff_t)start << PAGE_CACHE_SHIFT,
-				(loff_t)index << PAGE_CACHE_SHIFT, true);
+				(loff_t)start << PAGE_SHIFT,
+				(loff_t)index << PAGE_SHIFT, true);
 			goto undone;
@@ -2259,7 +2259,7 @@ static long shmem_fallocate(struct file *file, int mode, loff_t offset,
 		unlock_page(page);
+		put_page(page);
 		cond_resched();
@@ -2280,7 +2280,7 @@ static int shmem_statfs(struct dentry *dentry, struct kstatfs *buf)
 	struct shmem_sb_info *sbinfo = SHMEM_SB(dentry->d_sb);
 	buf->f_type = TMPFS_MAGIC;
-	buf->f_bsize = PAGE_CACHE_SIZE;
+	buf->f_bsize = PAGE_SIZE;
 	buf->f_namelen = NAME_MAX;
 	if (sbinfo->max_blocks) {
 		buf->f_blocks = sbinfo->max_blocks;
@@ -2523,7 +2523,7 @@ static int shmem_symlink(struct inode *dir, struct dentry *dentry, const char *s
 	struct shmem_inode_info *info;
 	len = strlen(symname) + 1;
-	if (len > PAGE_CACHE_SIZE)
+	if (len > PAGE_SIZE)
 		return -ENAMETOOLONG;
 	inode = shmem_get_inode(dir->i_sb, dir, S_IFLNK|S_IRWXUGO, 0, VM_NORESERVE);
@@ -2562,7 +2562,7 @@ static int shmem_symlink(struct inode *dir, struct dentry *dentry, const char *s
 		unlock_page(page);
+		put_page(page);
 	dir->i_size += BOGO_DIRENT_SIZE;
 	dir->i_ctime = dir->i_mtime = CURRENT_TIME;
@@ -2835,7 +2835,7 @@ static int shmem_parse_options(char *options, struct shmem_sb_info *sbinfo,
 			if (*rest)
 				goto bad_val;
 			sbinfo->max_blocks =
-				DIV_ROUND_UP(size, PAGE_CACHE_SIZE);
+				DIV_ROUND_UP(size, PAGE_SIZE);
 		} else if (!strcmp(this_char,"nr_blocks")) {
 			sbinfo->max_blocks = memparse(value, &rest);
 			if (*rest)
@@ -2940,7 +2940,7 @@ static int shmem_show_options(struct seq_file *seq, struct dentry *root)
 	if (sbinfo->max_blocks != shmem_default_max_blocks())
 		seq_printf(seq, ",size=%luk",
-			sbinfo->max_blocks << (PAGE_CACHE_SHIFT - 10));
+			sbinfo->max_blocks << (PAGE_SHIFT - 10));
 	if (sbinfo->max_inodes != shmem_default_max_inodes())
 		seq_printf(seq, ",nr_inodes=%lu", sbinfo->max_inodes);
 	if (sbinfo->mode != (S_IRWXUGO | S_ISVTX))
@@ -3082,8 +3082,8 @@ int shmem_fill_super(struct super_block *sb, void *data, int silent)
 	sbinfo->free_inodes = sbinfo->max_inodes;
 	sb->s_maxbytes = MAX_LFS_FILESIZE;
 	sb->s_magic = TMPFS_MAGIC;
 	sb->s_op = &shmem_ops;
 	sb->s_time_gran = 1;
diff --git a/mm/swap.c b/mm/swap.c
index 09fe5e9..ea641e2 100644
--- a/mm/swap.c
+++ b/mm/swap.c
@@ -114,7 +114,7 @@ void put_pages_list(struct list_head *pages)
 		victim = list_entry(pages->prev, struct page, lru);
 		list_del(&victim->lru);
-		page_cache_release(victim);
+		put_page(victim);
 EXPORT_SYMBOL(put_pages_list);
@@ -142,7 +142,7 @@ int get_kernel_pages(const struct kvec *kiov, int nr_segs, int write,
 			return seg;
 		pages[seg] = kmap_to_page(kiov[seg].iov_base);
-		page_cache_get(pages[seg]);
+		get_page(pages[seg]);
 	return seg;
@@ -236,7 +236,7 @@ void rotate_reclaimable_page(struct page *page)
 		struct pagevec *pvec;
 		unsigned long flags;
+		get_page(page);
 		local_irq_save(flags);
 		pvec = this_cpu_ptr(&lru_rotate_pvecs);
 		if (!pagevec_add(pvec, page))
@@ -294,7 +294,7 @@ void activate_page(struct page *page)
 	if (PageLRU(page) && !PageActive(page) && !PageUnevictable(page)) {
 		struct pagevec *pvec = &get_cpu_var(activate_page_pvecs);
+		get_page(page);
 			pagevec_lru_move_fn(pvec, __activate_page, NULL);
 		put_cpu_var(activate_page_pvecs);
@@ -389,7 +389,7 @@ static void __lru_cache_add(struct page *page)
 	struct pagevec *pvec = &get_cpu_var(lru_add_pvec);
+	get_page(page);
 	if (!pagevec_space(pvec))
 		__pagevec_lru_add(pvec);
 	pagevec_add(pvec, page);
@@ -646,7 +646,7 @@ void deactivate_page(struct page *page)
 	if (PageLRU(page) && PageActive(page) && !PageUnevictable(page)) {
 		struct pagevec *pvec = &get_cpu_var(lru_deactivate_pvecs);
+		get_page(page);
 			pagevec_lru_move_fn(pvec, lru_deactivate_fn, NULL);
 		put_cpu_var(lru_deactivate_pvecs);
diff --git a/mm/swap_state.c b/mm/swap_state.c
index 69cb246..366ce35 100644
--- a/mm/swap_state.c
+++ b/mm/swap_state.c
@@ -85,7 +85,7 @@ int __add_to_swap_cache(struct page *page, swp_entry_t entry)
 	VM_BUG_ON_PAGE(PageSwapCache(page), page);
+	get_page(page);
 	SetPageSwapCache(page);
 	set_page_private(page, entry.val);
@@ -109,7 +109,7 @@ int __add_to_swap_cache(struct page *page, swp_entry_t entry)
 		VM_BUG_ON(error == -EEXIST);
 		set_page_private(page, 0UL);
 		ClearPageSwapCache(page);
+		put_page(page);
 	return error;
@@ -226,7 +226,7 @@ void delete_from_swap_cache(struct page *page)
 	spin_unlock_irq(&address_space->tree_lock);
 	swapcache_free(entry);
+	put_page(page);
@@ -252,7 +252,7 @@ static inline void free_swap_cache(struct page *page)
 void free_page_and_swap_cache(struct page *page)
 	free_swap_cache(page);
+	put_page(page);
@@ -380,7 +380,7 @@ struct page *__read_swap_cache_async(swp_entry_t entry, gfp_t gfp_mask,
 	} while (err != -ENOMEM);
 	if (new_page)
 	return found_page;
@@ -495,7 +495,7 @@ struct page *swapin_readahead(swp_entry_t entry, gfp_t gfp_mask,
 			continue;
 		if (offset != entry_offset)
 			SetPageReadahead(page);
+		put_page(page);
 	blk_finish_plug(&plug);
diff --git a/mm/swapfile.c b/mm/swapfile.c
index 560ad38..83874ec 100644
--- a/mm/swapfile.c
+++ b/mm/swapfile.c
@@ -119,7 +119,7 @@ __try_to_reclaim_swap(struct swap_info_struct *si, unsigned long offset)
 		ret = try_to_free_swap(page);
 		unlock_page(page);
+	put_page(page);
 	return ret;
@@ -1000,7 +1000,7 @@ int free_swap_and_cache(swp_entry_t entry)
 			page = find_get_page(swap_address_space(entry),
 						entry.val);
 			if (page && !trylock_page(page)) {
+				put_page(page);
 				page = NULL;
@@ -1017,7 +1017,7 @@ int free_swap_and_cache(swp_entry_t entry)
 			SetPageDirty(page);
 		unlock_page(page);
+		put_page(page);
 	return p != NULL;
@@ -1518,7 +1518,7 @@ int try_to_unuse(unsigned int type, bool frontswap,
 		if (retval) {
 			unlock_page(page);
+			put_page(page);
 			break;
@@ -1570,7 +1570,7 @@ int try_to_unuse(unsigned int type, bool frontswap,
 		SetPageDirty(page);
 		unlock_page(page);
+		put_page(page);
 		 * Make sure that we aren't completely killing
@@ -2574,7 +2574,7 @@ bad_swap:
 out:
 	if (page && !IS_ERR(page)) {
 		kunmap(page);
+		put_page(page);
 	if (name)
 		putname(name);
diff --git a/mm/truncate.c b/mm/truncate.c
index 7598b55..b002728 100644
--- a/mm/truncate.c
+++ b/mm/truncate.c
@@ -118,7 +118,7 @@ truncate_complete_page(struct address_space *mapping, struct page *page)
 		return -EIO;
 	if (page_has_private(page))
 	 * Some filesystems seem to re-dirty the page even after
@@ -159,8 +159,8 @@ int truncate_inode_page(struct address_space *mapping, struct page *page)
 	if (page_mapped(page)) {
 		unmap_mapping_range(mapping,
-				   (loff_t)page->index << PAGE_CACHE_SHIFT,
-				   PAGE_CACHE_SIZE, 0);
+				   (loff_t)page->index << PAGE_SHIFT,
+				   PAGE_SIZE, 0);
 	return truncate_complete_page(mapping, page);
@@ -241,8 +241,8 @@ void truncate_inode_pages_range(struct address_space *mapping,
 		return;
 	/* Offsets within partial pages */
-	partial_start = lstart & (PAGE_CACHE_SIZE - 1);
-	partial_end = (lend + 1) & (PAGE_CACHE_SIZE - 1);
+	partial_start = lstart & (PAGE_SIZE - 1);
+	partial_end = (lend + 1) & (PAGE_SIZE - 1);
 	 * 'start' and 'end' always covers the range of pages to be fully
@@ -250,7 +250,7 @@ void truncate_inode_pages_range(struct address_space *mapping,
 	 * start of the range and 'partial_end' at the end of the range.
 	 * Note that 'end' is exclusive while 'lend' is inclusive.
-	start = (lstart + PAGE_CACHE_SIZE - 1) >> PAGE_CACHE_SHIFT;
+	start = (lstart + PAGE_SIZE - 1) >> PAGE_SHIFT;
 	if (lend == -1)
 		 * lend == -1 indicates end-of-file so we have to set 'end'
@@ -259,7 +259,7 @@ void truncate_inode_pages_range(struct address_space *mapping,
 		end = -1;
 	else
-		end = (lend + 1) >> PAGE_CACHE_SHIFT;
+		end = (lend + 1) >> PAGE_SHIFT;
 	index = start;
@@ -298,7 +298,7 @@ void truncate_inode_pages_range(struct address_space *mapping,
 	if (partial_start) {
 		struct page *page = find_lock_page(mapping, start - 1);
 		if (page) {
 			if (start > end) {
 				/* Truncation within a single page */
 				top = partial_end;
@@ -311,7 +311,7 @@ void truncate_inode_pages_range(struct address_space *mapping,
 				do_invalidatepage(page, partial_start,
 						  top - partial_start);
 			unlock_page(page);
+			put_page(page);
 	if (partial_end) {
@@ -324,7 +324,7 @@ void truncate_inode_pages_range(struct address_space *mapping,
 						  partial_end);
 			unlock_page(page);
+			put_page(page);
@@ -538,7 +538,7 @@ invalidate_complete_page2(struct address_space *mapping, struct page *page)
 	if (mapping->a_ops->freepage)
 		mapping->a_ops->freepage(page);
-	page_cache_release(page);	/* pagecache ref */
+	put_page(page);	/* pagecache ref */
 	return 1;
 failed:
 	spin_unlock_irqrestore(&mapping->tree_lock, flags);
@@ -608,18 +608,18 @@ int invalidate_inode_pages2_range(struct address_space *mapping,
 					 * Zap the rest of the file in one hit.
 					   (loff_t)(1 + end - index)
-							 << PAGE_CACHE_SHIFT,
-					    0);
+							 << PAGE_SHIFT,
+							 0);
 					did_range_unmap = 1;
 				} else {
 					 * Just zap this page
+					   PAGE_SIZE, 0);
 			BUG_ON(page_mapped(page));
@@ -744,14 +744,14 @@ void pagecache_isize_extended(struct inode *inode, loff_t from, loff_t to)
 	WARN_ON(to > inode->i_size);
-	if (from >= to || bsize == PAGE_CACHE_SIZE)
+	if (from >= to || bsize == PAGE_SIZE)
 		return;
 	/* Page straddling @from will not have any hole block created? */
 	rounded_from = round_up(from, bsize);
-	if (to <= rounded_from || !(rounded_from & (PAGE_CACHE_SIZE - 1)))
+	if (to <= rounded_from || !(rounded_from & (PAGE_SIZE - 1)))
 		return;
-	index = from >> PAGE_CACHE_SHIFT;
+	index = from >> PAGE_SHIFT;
 	page = find_lock_page(inode->i_mapping, index);
 	/* Page not cached? Nothing to do */
 	if (!page)
@@ -763,7 +763,7 @@ void pagecache_isize_extended(struct inode *inode, loff_t from, loff_t to)
 	if (page_mkclean(page))
 	unlock_page(page);
+	put_page(page);
 EXPORT_SYMBOL(pagecache_isize_extended);
diff --git a/mm/userfaultfd.c b/mm/userfaultfd.c
index 9f3a029..af817e5 100644
--- a/mm/userfaultfd.c
+++ b/mm/userfaultfd.c
@@ -93,7 +93,7 @@ out_release_uncharge_unlock:
 	pte_unmap_unlock(dst_pte, ptl);
 out_release:
+	put_page(page);
 	goto out;
@@ -287,7 +287,7 @@ out_unlock:
 	up_read(&dst_mm->mmap_sem);
 out:
 	if (page)
+		put_page(page);
 	BUG_ON(copied < 0);
 	BUG_ON(err > 0);
 	BUG_ON(!copied && !err);
diff --git a/mm/zswap.c b/mm/zswap.c
index bf14508..91dad80 100644
--- a/mm/zswap.c
+++ b/mm/zswap.c
@@ -869,7 +869,7 @@ static int zswap_writeback_entry(struct zpool *pool, unsigned long handle)
 	case ZSWAP_SWAPCACHE_EXIST:
 		/* page is already in the swap cache, ignore for now */
+		put_page(page);
 		ret = -EEXIST;
 		goto fail;
@@ -897,7 +897,7 @@ static int zswap_writeback_entry(struct zpool *pool, unsigned long handle)
 	/* start writeback */
 	__swap_writepage(page, &wbc, end_swap_bio_write);
+	put_page(page);
 	zswap_written_back_pages++;
 	spin_lock(&tree->lock);
diff --git a/net/ceph/messenger.c b/net/ceph/messenger.c
index 1831f63..a550289 100644
--- a/net/ceph/messenger.c
+++ b/net/ceph/messenger.c
@@ -269,7 +269,7 @@ static void _ceph_msgr_exit(void)
 	BUG_ON(zero_page == NULL);
-	page_cache_release(zero_page);
+	put_page(zero_page);
 	zero_page = NULL;
 	ceph_msgr_slab_exit();
@@ -282,7 +282,7 @@ int ceph_msgr_init(void)
 	BUG_ON(zero_page != NULL);
 	zero_page = ZERO_PAGE(0);
-	page_cache_get(zero_page);
+	get_page(zero_page);
 	 * The number of active work items is limited by the number of
@@ -1602,7 +1602,7 @@ static int write_partial_skip(struct ceph_connection *con)
 	dout("%s %p %d left\n", __func__, con, con->out_skip);
 	while (con->out_skip > 0) {
-		size_t size = min(con->out_skip, (int) PAGE_CACHE_SIZE);
+		size_t size = min(con->out_skip, (int) PAGE_SIZE);
 		ret = ceph_tcp_sendpage(con->sock, zero_page, 0, size, true);
 		if (ret <= 0)
diff --git a/net/ceph/pagelist.c b/net/ceph/pagelist.c
index c7c220a..6864007 100644
--- a/net/ceph/pagelist.c
+++ b/net/ceph/pagelist.c
@@ -56,7 +56,7 @@ int ceph_pagelist_append(struct ceph_pagelist *pl, const void *buf, size_t len)
 		size_t bit = pl->room;
 		int ret;
-		memcpy(pl->mapped_tail + (pl->length & ~PAGE_CACHE_MASK),
+		memcpy(pl->mapped_tail + (pl->length & ~PAGE_MASK),
 		       buf, bit);
 		pl->length += bit;
 		pl->room -= bit;
@@ -67,7 +67,7 @@ int ceph_pagelist_append(struct ceph_pagelist *pl, const void *buf, size_t len)
 			return ret;
-	memcpy(pl->mapped_tail + (pl->length & ~PAGE_CACHE_MASK), buf, len);
+	memcpy(pl->mapped_tail + (pl->length & ~PAGE_MASK), buf, len);
 	pl->length += len;
 	pl->room -= len;
 	return 0;
diff --git a/net/ceph/pagevec.c b/net/ceph/pagevec.c
index 10297f7..00d2601 100644
--- a/net/ceph/pagevec.c
+++ b/net/ceph/pagevec.c
@@ -95,19 +95,19 @@ int ceph_copy_user_to_page_vector(struct page **pages,
 					 loff_t off, size_t len)
 	int i = 0;
-	int po = off & ~PAGE_CACHE_MASK;
+	int po = off & ~PAGE_MASK;
 	int left = len;
 	int l, bad;
 	while (left > 0) {
-		l = min_t(int, PAGE_CACHE_SIZE-po, left);
+		l = min_t(int, PAGE_SIZE-po, left);
 		bad = copy_from_user(page_address(pages[i]) + po, data, l);
 		if (bad == l)
 			return -EFAULT;
 		data += l - bad;
 		left -= l - bad;
 		po += l - bad;
-		if (po == PAGE_CACHE_SIZE) {
+		if (po == PAGE_SIZE) {
 			po = 0;
 			i++;
@@ -121,17 +121,17 @@ void ceph_copy_to_page_vector(struct page **pages,
 	int i = 0;
-	size_t po = off & ~PAGE_CACHE_MASK;
+	size_t po = off & ~PAGE_MASK;
 	size_t left = len;
 	while (left > 0) {
-		size_t l = min_t(size_t, PAGE_CACHE_SIZE-po, left);
+		size_t l = min_t(size_t, PAGE_SIZE-po, left);
 		memcpy(page_address(pages[i]) + po, data, l);
 		data += l;
 		left -= l;
 		po += l;
 			po = 0;
 			i++;
@@ -144,17 +144,17 @@ void ceph_copy_from_page_vector(struct page **pages,
 	int i = 0;
 	size_t left = len;
 	while (left > 0) {
 		memcpy(data, page_address(pages[i]) + po, l);
 		data += l;
 		left -= l;
 		po += l;
 			po = 0;
 			i++;
@@ -168,25 +168,25 @@ EXPORT_SYMBOL(ceph_copy_from_page_vector);
 void ceph_zero_page_vector_range(int off, int len, struct page **pages)
-	int i = off >> PAGE_CACHE_SHIFT;
+	int i = off >> PAGE_SHIFT;
-	off &= ~PAGE_CACHE_MASK;
+	off &= ~PAGE_MASK;
 	dout("zero_page_vector_page %u~%u\n", off, len);
 	/* leading partial page? */
 	if (off) {
-		int end = min((int)PAGE_CACHE_SIZE, off + len);
+		int end = min((int)PAGE_SIZE, off + len);
 		dout("zeroing %d %p head from %d\n", i, pages[i],
 		     (int)off);
 		zero_user_segment(pages[i], off, end);
 		len -= (end - off);
 		i++;
-	while (len >= PAGE_CACHE_SIZE) {
+	while (len >= PAGE_SIZE) {
 		dout("zeroing %d %p len=%d\n", i, pages[i], len);
-		zero_user_segment(pages[i], 0, PAGE_CACHE_SIZE);
-		len -= PAGE_CACHE_SIZE;
+		zero_user_segment(pages[i], 0, PAGE_SIZE);
+		len -= PAGE_SIZE;
 		i++;
 	/* trailing partial page? */
diff --git a/net/sunrpc/auth_gss/auth_gss.c b/net/sunrpc/auth_gss/auth_gss.c
index 8c6bc79..15612ff 100644
--- a/net/sunrpc/auth_gss/auth_gss.c
+++ b/net/sunrpc/auth_gss/auth_gss.c
@@ -1728,8 +1728,8 @@ alloc_enc_pages(struct rpc_rqst *rqstp)
 		return 0;
-	first = snd_buf->page_base >> PAGE_CACHE_SHIFT;
-	last = (snd_buf->page_base + snd_buf->page_len - 1) >> PAGE_CACHE_SHIFT;
+	first = snd_buf->page_base >> PAGE_SHIFT;
+	last = (snd_buf->page_base + snd_buf->page_len - 1) >> PAGE_SHIFT;
 	rqstp->rq_enc_pages_num = last - first + 1 + 1;
 	rqstp->rq_enc_pages
 		= kmalloc(rqstp->rq_enc_pages_num * sizeof(struct page *),
@@ -1775,10 +1775,10 @@ gss_wrap_req_priv(struct rpc_cred *cred, struct gss_cl_ctx *ctx,
 	status = alloc_enc_pages(rqstp);
 	if (status)
 		return status;
 	inpages = snd_buf->pages + first;
 	snd_buf->pages = rqstp->rq_enc_pages;
-	snd_buf->page_base -= first << PAGE_CACHE_SHIFT;
+	snd_buf->page_base -= first << PAGE_SHIFT;
 	 * Give the tail its own page, in case we need extra space in the
 	 * head when wrapping:
diff --git a/net/sunrpc/auth_gss/gss_krb5_crypto.c b/net/sunrpc/auth_gss/gss_krb5_crypto.c
index d94a8e1..045e11e 100644
--- a/net/sunrpc/auth_gss/gss_krb5_crypto.c
+++ b/net/sunrpc/auth_gss/gss_krb5_crypto.c
@@ -465,7 +465,7 @@ encryptor(struct scatterlist *sg, void *data)
 	page_pos = desc->pos - outbuf->head[0].iov_len;
 	if (page_pos >= 0 && page_pos < outbuf->page_len) {
 		/* pages are not in place: */
-		int i = (page_pos + outbuf->page_base) >> PAGE_CACHE_SHIFT;
+		int i = (page_pos + outbuf->page_base) >> PAGE_SHIFT;
 		in_page = desc->pages[i];
 	} else {
 		in_page = sg_page(sg);
diff --git a/net/sunrpc/auth_gss/gss_krb5_wrap.c b/net/sunrpc/auth_gss/gss_krb5_wrap.c
index 765088e4..a737c2d 100644
--- a/net/sunrpc/auth_gss/gss_krb5_wrap.c
+++ b/net/sunrpc/auth_gss/gss_krb5_wrap.c
@@ -79,9 +79,9 @@ gss_krb5_remove_padding(struct xdr_buf *buf, int blocksize)
 		len -= buf->head[0].iov_len;
 	if (len <= buf->page_len) {
 		unsigned int last = (buf->page_base + len - 1)
-					>>PAGE_CACHE_SHIFT;
+					>>PAGE_SHIFT;
 		unsigned int offset = (buf->page_base + len - 1)
-					& (PAGE_CACHE_SIZE - 1);
+					& (PAGE_SIZE - 1);
 		ptr = kmap_atomic(buf->pages[last]);
 		pad = *(ptr + offset);
 		kunmap_atomic(ptr);
diff --git a/net/sunrpc/cache.c b/net/sunrpc/cache.c
index 008c25d..553bf95 100644
--- a/net/sunrpc/cache.c
+++ b/net/sunrpc/cache.c
@@ -881,7 +881,7 @@ static ssize_t cache_downcall(struct address_space *mapping,
 	char *kaddr;
 	ssize_t ret = -ENOMEM;
-	if (count >= PAGE_CACHE_SIZE)
+	if (count >= PAGE_SIZE)
 		goto out_slow;
 	page = find_or_create_page(mapping, 0, GFP_KERNEL);
@@ -892,7 +892,7 @@ static ssize_t cache_downcall(struct address_space *mapping,
 	ret = cache_do_downcall(kaddr, buf, count, cd);
 	kunmap(page);
 	unlock_page(page);
+	put_page(page);
 	return ret;
 out_slow:
 	return cache_slow_downcall(buf, count, cd);
diff --git a/net/sunrpc/rpc_pipe.c b/net/sunrpc/rpc_pipe.c
index 31789ef..fc48eca 100644
--- a/net/sunrpc/rpc_pipe.c
+++ b/net/sunrpc/rpc_pipe.c
@@ -1390,8 +1390,8 @@ rpc_fill_super(struct super_block *sb, void *data, int silent)
 	struct sunrpc_net *sn = net_generic(net, sunrpc_net_id);
 	int err;
 	sb->s_magic = RPCAUTH_GSSMAGIC;
 	sb->s_op = &s_ops;
 	sb->s_d_op = &simple_dentry_operations;
diff --git a/net/sunrpc/socklib.c b/net/sunrpc/socklib.c
index 2df87f7..de70c78 100644
--- a/net/sunrpc/socklib.c
+++ b/net/sunrpc/socklib.c
@@ -96,8 +96,8 @@ ssize_t xdr_partial_copy_from_skb(struct xdr_buf *xdr, unsigned int base, struct
 	if (base || xdr->page_base) {
 		pglen -= base;
 		base += xdr->page_base;
-		ppage += base >> PAGE_CACHE_SHIFT;
-		base &= ~PAGE_CACHE_MASK;
+		ppage += base >> PAGE_SHIFT;
+		base &= ~PAGE_MASK;
 	do {
 		char *kaddr;
@@ -113,7 +113,7 @@ ssize_t xdr_partial_copy_from_skb(struct xdr_buf *xdr, unsigned int base, struct
-		len = PAGE_CACHE_SIZE;
+		len = PAGE_SIZE;
 		kaddr = kmap_atomic(*ppage);
 		if (base) {
 			len -= base;
diff --git a/net/sunrpc/xdr.c b/net/sunrpc/xdr.c
index 4439ac4..1e6aba0 100644
--- a/net/sunrpc/xdr.c
+++ b/net/sunrpc/xdr.c
@@ -181,20 +181,20 @@ _shift_data_right_pages(struct page **pages, size_t pgto_base,
 	pgto_base += len;
 	pgfrom_base += len;
-	pgto = pages + (pgto_base >> PAGE_CACHE_SHIFT);
-	pgfrom = pages + (pgfrom_base >> PAGE_CACHE_SHIFT);
+	pgto = pages + (pgto_base >> PAGE_SHIFT);
+	pgfrom = pages + (pgfrom_base >> PAGE_SHIFT);
-	pgto_base &= ~PAGE_CACHE_MASK;
-	pgfrom_base &= ~PAGE_CACHE_MASK;
+	pgto_base &= ~PAGE_MASK;
+	pgfrom_base &= ~PAGE_MASK;
 	do {
 		/* Are any pointers crossing a page boundary? */
 		if (pgto_base == 0) {
-			pgto_base = PAGE_CACHE_SIZE;
+			pgto_base = PAGE_SIZE;
 			pgto--;
 		if (pgfrom_base == 0) {
-			pgfrom_base = PAGE_CACHE_SIZE;
+			pgfrom_base = PAGE_SIZE;
 			pgfrom--;
@@ -236,11 +236,11 @@ _copy_to_pages(struct page **pages, size_t pgbase, const char *p, size_t len)
 	char *vto;
 	size_t copy;
-	pgto = pages + (pgbase >> PAGE_CACHE_SHIFT);
-	pgbase &= ~PAGE_CACHE_MASK;
+	pgto = pages + (pgbase >> PAGE_SHIFT);
+	pgbase &= ~PAGE_MASK;
 	for (;;) {
-		copy = PAGE_CACHE_SIZE - pgbase;
+		copy = PAGE_SIZE - pgbase;
 		if (copy > len)
 			copy = len;
@@ -253,7 +253,7 @@ _copy_to_pages(struct page **pages, size_t pgbase, const char *p, size_t len)
 			break;
 		pgbase += copy;
-		if (pgbase == PAGE_CACHE_SIZE) {
+		if (pgbase == PAGE_SIZE) {
 			flush_dcache_page(*pgto);
 			pgbase = 0;
 			pgto++;
@@ -280,11 +280,11 @@ _copy_from_pages(char *p, struct page **pages, size_t pgbase, size_t len)
 	char *vfrom;
 	size_t copy;
-	pgfrom = pages + (pgbase >> PAGE_CACHE_SHIFT);
+	pgfrom = pages + (pgbase >> PAGE_SHIFT);
 	do {
 		if (copy > len)
 			copy = len;
@@ -293,7 +293,7 @@ _copy_from_pages(char *p, struct page **pages, size_t pgbase, size_t len)
 		kunmap_atomic(vfrom);
 		pgbase += copy;
 			pgbase = 0;
 			pgfrom++;
@@ -1038,8 +1038,8 @@ xdr_buf_subsegment(struct xdr_buf *buf, struct xdr_buf *subbuf,
 	if (base < buf->page_len) {
 		subbuf->page_len = min(buf->page_len - base, len);
 		base += buf->page_base;
-		subbuf->page_base = base & ~PAGE_CACHE_MASK;
-		subbuf->pages = &buf->pages[base >> PAGE_CACHE_SHIFT];
+		subbuf->page_base = base & ~PAGE_MASK;
+		subbuf->pages = &buf->pages[base >> PAGE_SHIFT];
 		len -= subbuf->page_len;
 		base = 0;
 	} else {
@@ -1297,9 +1297,9 @@ xdr_xcode_array2(struct xdr_buf *buf, unsigned int base,
 		todo -= avail_here;
-		ppages = buf->pages + (base >> PAGE_CACHE_SHIFT);
-		avail_page = min_t(unsigned int, PAGE_CACHE_SIZE - base,
+		ppages = buf->pages + (base >> PAGE_SHIFT);
+		avail_page = min_t(unsigned int, PAGE_SIZE - base,
 					avail_here);
 		c = kmap(*ppages) + base;
@@ -1383,7 +1383,7 @@ xdr_xcode_array2(struct xdr_buf *buf, unsigned int base,
 			avail_page = min(avail_here,
-				 (unsigned int) PAGE_CACHE_SIZE);
+				 (unsigned int) PAGE_SIZE);
 		base = buf->page_len;  /* align to start of tail */
@@ -1479,9 +1479,9 @@ xdr_process_buf(struct xdr_buf *buf, unsigned int offset, unsigned int len,
 		if (page_len > len)
 			page_len = len;
 		len -= page_len;
-		page_offset = (offset + buf->page_base) & (PAGE_CACHE_SIZE - 1);
-		i = (offset + buf->page_base) >> PAGE_CACHE_SHIFT;
-		thislen = PAGE_CACHE_SIZE - page_offset;
+		page_offset = (offset + buf->page_base) & (PAGE_SIZE - 1);
+		i = (offset + buf->page_base) >> PAGE_SHIFT;
+		thislen = PAGE_SIZE - page_offset;
 		do {
 			if (thislen > page_len)
 				thislen = page_len;
@@ -1492,7 +1492,7 @@ xdr_process_buf(struct xdr_buf *buf, unsigned int offset, unsigned int len,
 			page_len -= thislen;
 			i++;
 			page_offset = 0;
-			thislen = PAGE_CACHE_SIZE;
+			thislen = PAGE_SIZE;
 		} while (page_len != 0);
 		offset = 0;
BtrLinux
Privacy Overview
