mlxsw: fix error return code
Author: Julia Lawall <julia.lawall@lip6.fr>
Return a negative error code on failure.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
identifier ret; expression e1,e2;
if (\(ret < 0\|ret != 0\))
 { ... return ret; }
ret = 0
... when != ret = e1
    when != &ret
*if(...)
  ... when != ret = e2
      when forall
 return ret;
Signed-off-by: Julia Lawall
Acked-by: Jiri Pirko
Signed-off-by: David S. Miller
 drivers/net/ethernet/mellanox/mlxsw/pci.c | 1 +
 1 file changed, 1 insertion(+)
diff --git a/drivers/net/ethernet/mellanox/mlxsw/pci.c b/drivers/net/ethernet/mellanox/mlxsw/pci.c
index a34f474..045f98f 100644
--- a/drivers/net/ethernet/mellanox/mlxsw/pci.c
+++ b/drivers/net/ethernet/mellanox/mlxsw/pci.c
@@ -1726,6 +1726,7 @@ static int mlxsw_pci_probe(struct pci_dev *pdev, const struct pci_device_id *id)
 						mlxsw_pci_dbg_root);
 	if (!mlxsw_pci->dbg_dir) {
 		dev_err(&pdev->dev, "Failed to create debugfs dir\n");
+		err = -ENOMEM;
 		goto err_dbg_create_dir;
BtrLinux
Privacy Overview
