MIPS/pci: Fix race in installing chained IRQ handler
Author: Thomas Gleixner <tglx@linutronix.de>
Fix a race where a pending interrupt could be received and the handler
called before the handler's data has been setup, by converting to
irq_set_chained_handler_and_data().
Search and conversion was done with coccinelle:
expression E1, E2, E3;
-if (irq_set_chained_handler(E1, E3) != 0)
-   BUG();
-irq_set_chained_handler(E1, E3);
-irq_set_handler_data(E1, E2);
+irq_set_chained_handler_and_data(E1, E3, E2);
-   BUG();
Reported-by: Russell King
Signed-off-by: Thomas Gleixner
Cc: Julia Lawall
Cc: Ralf Baechle
Cc: Wolfram Sang
Cc: Sergey Ryazanov
Cc: linux-mips@linux-mips.org
 arch/mips/pci/pci-ar2315.c | 4 ++--
 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/mips/pci/pci-ar2315.c b/arch/mips/pci/pci-ar2315.c
index 07a1822..9627c93 100644
--- a/arch/mips/pci/pci-ar2315.c
+++ b/arch/mips/pci/pci-ar2315.c
@@ -384,8 +384,8 @@ static void ar2315_pci_irq_init(struct ar2315_pci_ctrl *apc)
 	apc->irq_ext = irq_create_mapping(apc->domain, AR2315_PCI_IRQ_EXT);
-	irq_set_chained_handler(apc->irq, ar2315_pci_irq_handler);
-	irq_set_handler_data(apc->irq, apc);
+	irq_set_chained_handler_and_data(apc->irq, ar2315_pci_irq_handler,
+					 apc);
 	/* Clear any pending Abort or external Interrupts
 	 * and enable interrupt processing */
BtrLinux
Privacy Overview
