MIPS: rt3883: Prepare rt3883_pci_irq_handler for irq argument removal
Author: Thomas Gleixner <tglx@linutronix.de>
The irq argument of most interrupt flow handlers is unused or merily
used instead of a local variable. The handlers which need the irq
argument can retrieve the irq number from the irq descriptor.
Search and update was done with coccinelle and the invaluable help of
Julia Lawall.
Signed-off-by: Thomas Gleixner
Cc: Julia Lawall
Cc: Jiang Liu
Cc: linux-mips@linux-mips.org
Cc: LKML
Patchwork: https://patchwork.linux-mips.org/patch/10706/
Signed-off-by: Ralf Baechle
 arch/mips/pci/pci-rt3883.c | 4 ++--
 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/mips/pci/pci-rt3883.c b/arch/mips/pci/pci-rt3883.c
index c156f48..53c8efa 100644
--- a/arch/mips/pci/pci-rt3883.c
+++ b/arch/mips/pci/pci-rt3883.c
@@ -129,7 +129,7 @@ static void rt3883_pci_write_cfg32(struct rt3883_pci_controller *rpc,
 	rt3883_pci_w32(rpc, val, RT3883_PCI_REG_CFGDATA);
-static void rt3883_pci_irq_handler(unsigned int irq, struct irq_desc *desc)
+static void rt3883_pci_irq_handler(unsigned int __irq, struct irq_desc *desc)
 	struct rt3883_pci_controller *rpc;
 	u32 pending;
@@ -145,7 +145,7 @@ static void rt3883_pci_irq_handler(unsigned int irq, struct irq_desc *desc)
 	while (pending) {
-		unsigned bit = __ffs(pending);
+		unsigned irq, bit = __ffs(pending);
 		irq = irq_find_mapping(rpc->irq_domain, bit);
 		generic_handle_irq(irq);
