MIPS: kspd: Adjust confusing if indentation
Indent the branch of an if.
The semantic match that finds this problem is as follows:
(http://coccinelle.lip6.fr/)
@r disable braces4@
position p1,p2;
statement S1,S2;
if (...) { ... }
if (...) S1@p1 S2@p2
@script:python@
p1 << r.p1;
p2 << r.p2;
if (p1[0].column == p2[0].column):
  cocci.print_main("branch",p1)
  cocci.print_secs("after",p2)
Signed-off-by: Julia Lawall
To: linux-mips@linux-mips.org
To: linux-kernel@vger.kernel.org
To: kernel-janitors@vger.kernel.org
Patchwork: https://patchwork.linux-mips.org/patch/1539/
Signed-off-by: Ralf Baechle
 arch/mips/kernel/kspd.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/mips/kernel/kspd.c b/arch/mips/kernel/kspd.c
index 80e2ba6..29811f0 100644
--- a/arch/mips/kernel/kspd.c
+++ b/arch/mips/kernel/kspd.c
@@ -251,7 +251,7 @@ void sp_work_handle_request(void)
  		memset(&tz, 0, sizeof(tz));
  		if ((ret.retval = sp_syscall(__NR_gettimeofday, (int)&tv,
 					     (int)&tz, 0, 0)) == 0)
-		ret.retval = tv.tv_sec;
+			ret.retval = tv.tv_sec;
 		break;
  	case MTSP_SYSCALL_EXIT:
BtrLinux
Privacy Overview
