MIPS: bcm63xx: Use irq_set_handler_locked()
Author: Thomas Gleixner <tglx@linutronix.de>
Use irq_set_handler_locked() as it avoids a redundant lookup of the
irq descriptor.
Search and replacement was done with coccinelle.
Signed-off-by: Thomas Gleixner
Cc: Jiang Liu
Cc: Julia Lawall
Cc: Ralf Baechle
Cc: linux-mips@linux-mips.org
Cc: LKML
Patchwork: https://patchwork.linux-mips.org/patch/10701/
Signed-off-by: Ralf Baechle
 arch/mips/bcm63xx/irq.c | 4 ++--
 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/mips/bcm63xx/irq.c b/arch/mips/bcm63xx/irq.c
index 02983b9..1a47ec2 100644
--- a/arch/mips/bcm63xx/irq.c
+++ b/arch/mips/bcm63xx/irq.c
@@ -365,9 +365,9 @@ static int bcm63xx_external_irq_set_type(struct irq_data *d,
 	irqd_set_trigger_type(d, flow_type);
 	if (flow_type & (IRQ_TYPE_LEVEL_LOW | IRQ_TYPE_LEVEL_HIGH))
-		__irq_set_handler_locked(d->irq, handle_level_irq);
+		irq_set_handler_locked(d, handle_level_irq);
 	else
-		__irq_set_handler_locked(d->irq, handle_edge_irq);
+		irq_set_handler_locked(d, handle_edge_irq);
 	return IRQ_SET_MASK_OK_NOCOPY;
BtrLinux
Privacy Overview
