MIPS: BCM63xx: delete double assignment
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Delete successive assignments to the same location.  In each case, the
duplicated assignment is modified to be in line with other nearby code.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
expression i;
*i = ...;
 i = ...;
Signed-off-by: Julia Lawall
Cc: joe@perches.com
Cc: kernel-janitors@vger.kernel.org
Cc: linux-mips@linux-mips.org
Cc: linux-kernel@vger.kernel.org
Patchwork: https://patchwork.linux-mips.org/patch/7565/
Signed-off-by: Ralf Baechle
 arch/mips/bcm63xx/irq.c | 4 ++--
 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/mips/bcm63xx/irq.c b/arch/mips/bcm63xx/irq.c
index 37eb2d1..b94bf44d 100644
--- a/arch/mips/bcm63xx/irq.c
+++ b/arch/mips/bcm63xx/irq.c
@@ -434,7 +434,7 @@ static void bcm63xx_init_irq(void)
 		irq_stat_addr[0] += PERF_IRQSTAT_3368_REG;
 		irq_mask_addr[0] += PERF_IRQMASK_3368_REG;
 		irq_stat_addr[1] = 0;
-		irq_stat_addr[1] = 0;
+		irq_mask_addr[1] = 0;
 		irq_bits = 32;
 		ext_irq_count = 4;
 		ext_irq_cfg_reg1 = PERF_EXTIRQ_CFG_REG_3368;
@@ -443,7 +443,7 @@ static void bcm63xx_init_irq(void)
 		irq_stat_addr[0] += PERF_IRQSTAT_6328_REG(0);
 		irq_mask_addr[0] += PERF_IRQMASK_6328_REG(0);
 		irq_stat_addr[1] += PERF_IRQSTAT_6328_REG(1);
-		irq_stat_addr[1] += PERF_IRQMASK_6328_REG(1);
+		irq_mask_addr[1] += PERF_IRQMASK_6328_REG(1);
 		irq_bits = 64;
 		ext_irq_count = 4;
 		is_ext_irq_cascaded = 1;
BtrLinux
Privacy Overview
