MIPS: Alchemy: Use kmemdup rather than duplicating its implementation
Author: Thomas Meyer <thomas@m3y3r.de>
The semantic patch that makes this change is available
in scripts/coccinelle/api/memdup.cocci.
Signed-off-by: Thomas Meyer
Cc: linux-mips@linux-mips.org
Cc: linux-kernel@vger.kernel.org
Patchwork: https://patchwork.linux-mips.org/patch/3058/
Signed-off-by: Ralf Baechle
 arch/mips/alchemy/common/platform.c | 10 ++++------
 1 file changed, 4 insertions(+), 6 deletions(-)
diff --git a/arch/mips/alchemy/common/platform.c b/arch/mips/alchemy/common/platform.c
index 95cb911..c0f3ce6 100644
--- a/arch/mips/alchemy/common/platform.c
+++ b/arch/mips/alchemy/common/platform.c
@@ -334,13 +334,12 @@ static void __init alchemy_setup_macs(int ctype)
 	if (alchemy_get_macs(ctype) < 1)
 		return;
-	macres = kmalloc(sizeof(struct resource) * MAC_RES_COUNT, GFP_KERNEL);
+	macres = kmemdup(au1xxx_eth0_resources[ctype],
+			 sizeof(struct resource) * MAC_RES_COUNT, GFP_KERNEL);
 	if (!macres) {
 		printk(KERN_INFO "Alchemy: no memory for MAC0 resources\n");
 		return;
-	memcpy(macres, au1xxx_eth0_resources[ctype],
-	       sizeof(struct resource) * MAC_RES_COUNT);
 	au1xxx_eth0_device.resource = macres;
 	i = prom_get_ethernet_addr(ethaddr);
@@ -356,13 +355,12 @@ static void __init alchemy_setup_macs(int ctype)
 	if (alchemy_get_macs(ctype) < 2)
 		return;
+	macres = kmemdup(au1xxx_eth1_resources[ctype],
 	if (!macres) {
 		printk(KERN_INFO "Alchemy: no memory for MAC1 resources\n");
 		return;
-	memcpy(macres, au1xxx_eth1_resources[ctype],
 	au1xxx_eth1_device.resource = macres;
 	ethaddr[5] += 1;	/* next addr for 2nd MAC */
BtrLinux
Privacy Overview
