MIPS: Alchemy: Correct code taking the size of a pointer
sizeof(dp) is just the size of the pointer.  Change it to the size of the
referenced structure.
A simplified version of the semantic patch that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
expression *x;
expression f;
type T;
*f(...,(T)x,...)
Signed-off-by: Julia Lawall
Patchwork: http://patchwork.linux-mips.org/patch/789/
Signed-off-by: Ralf Baechle
 arch/mips/alchemy/common/dbdma.c | 4 ++--
 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/mips/alchemy/common/dbdma.c b/arch/mips/alchemy/common/dbdma.c
index 19c1c82..5c68569 100644
--- a/arch/mips/alchemy/common/dbdma.c
+++ b/arch/mips/alchemy/common/dbdma.c
@@ -613,7 +613,7 @@ u32 _au1xxx_dbdma_put_source(u32 chanid, void *buf, int nbytes, u32 flags)
 	dma_cache_wback_inv((unsigned long)buf, nbytes);
 	dp->dscr_cmd0 |= DSCR_CMD0_V;	/* Let it rip */
 	au_sync();
-	dma_cache_wback_inv((unsigned long)dp, sizeof(dp));
+	dma_cache_wback_inv((unsigned long)dp, sizeof(*dp));
 	ctp->chan_ptr->ddma_dbell = 0;
 	/* Get next descriptor pointer.	*/
@@ -676,7 +676,7 @@ _au1xxx_dbdma_put_dest(u32 chanid, void *buf, int nbytes, u32 flags)
 	dma_cache_inv((unsigned long)buf, nbytes);
 	au_sync();
BtrLinux
Privacy Overview
