microblaze: Convert to new irq function names
Author: Thomas Gleixner <tglx@linutronix.de>
Namespace conversion scripted with coccinelle.
Also retrieve the irq type from irq_data in intc_enable_or_unmask()
Signed-off-by: Thomas Gleixner
 arch/microblaze/kernel/intc.c    | 6 +++---
 arch/microblaze/pci/pci-common.c | 2 +-
 2 files changed, 4 insertions(+), 4 deletions(-)
diff --git a/arch/microblaze/kernel/intc.c b/arch/microblaze/kernel/intc.c
index e466128..5ba7e16 100644
--- a/arch/microblaze/kernel/intc.c
+++ b/arch/microblaze/kernel/intc.c
@@ -50,7 +50,7 @@ static void intc_enable_or_unmask(struct irq_data *d)
 	 * ack function since the handle_level_irq function
 	 * acks the irq before calling the interrupt handler
-	if (irq_to_desc(d->irq)->status & IRQ_LEVEL)
+	if (irqd_is_level_type(d))
 		out_be32(INTC_BASE + IAR, mask);
@@ -157,11 +157,11 @@ void __init init_IRQ(void)
 	for (i = 0; i < nr_irq; ++i) {
 		if (intr_type & (0x00000001 << i)) {
-			set_irq_chip_and_handler_name(i, &intc_dev,
+			irq_set_chip_and_handler_name(i, &intc_dev,
 				handle_edge_irq, intc_dev.name);
 			irq_clear_status_flags(i, IRQ_LEVEL);
 		} else {
 				handle_level_irq, intc_dev.name);
 			irq_set_status_flags(i, IRQ_LEVEL);
diff --git a/arch/microblaze/pci/pci-common.c b/arch/microblaze/pci/pci-common.c
index 1e01a12..5359906 100644
--- a/arch/microblaze/pci/pci-common.c
+++ b/arch/microblaze/pci/pci-common.c
@@ -237,7 +237,7 @@ int pci_read_irq_line(struct pci_dev *pci_dev)
 		virq = irq_create_mapping(NULL, line);
 		if (virq != NO_IRQ)
-			set_irq_type(virq, IRQ_TYPE_LEVEL_LOW);
+			irq_set_irq_type(virq, IRQ_TYPE_LEVEL_LOW);
 	} else {
 		pr_debug(" Got one, spec %d cells (0x%08x 0x%08x...) on %s\n",
 			 oirq.size, oirq.specifier[0], oirq.specifier[1],
BtrLinux
Privacy Overview
