mfd: twl6040: Fix error return code
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Convert a zero return value on error to a negative one, as returned
elsewhere in the function.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
if@p1 (\(ret < 0\|ret != 0\))
 { ... return ret; }
ret@p1 = 0
... when != ret = e1
    when != &ret
*if(...)
  ... when != ret = e2
      when forall
 return ret;
Signed-off-by: Julia Lawall
Signed-off-by: Lee Jones
 drivers/mfd/twl6040.c | 1 +
 1 file changed, 1 insertion(+)
diff --git a/drivers/mfd/twl6040.c b/drivers/mfd/twl6040.c
index f9c06c5..9687645 100644
--- a/drivers/mfd/twl6040.c
+++ b/drivers/mfd/twl6040.c
@@ -679,6 +679,7 @@ static int twl6040_probe(struct i2c_client *client,
 	if (twl6040->rev < 0) {
 		dev_err(&client->dev, "Failed to read revision register: %d\n",
 			twl6040->rev);
+		ret = twl6040->rev;
 		goto gpio_err;
BtrLinux
Privacy Overview
