mfd: twl-core: Return directly after a failed platform_device_alloc() in add_numbered_child()
Author: Markus Elfring <elfring@users.sourceforge.net>
The platform_device_put() function was called in one case by the
add_numbered_child() function during error handling even if the passed
variable "pdev" contained a null pointer.
Return directly in this case.
This issue was detected by using the Coccinelle software.
Signed-off-by: Markus Elfring
Signed-off-by: Lee Jones
 drivers/mfd/twl-core.c | 7 ++-----
 1 file changed, 2 insertions(+), 5 deletions(-)
diff --git a/drivers/mfd/twl-core.c b/drivers/mfd/twl-core.c
index 831696e..9458c6d 100644
--- a/drivers/mfd/twl-core.c
+++ b/drivers/mfd/twl-core.c
@@ -622,11 +622,8 @@ add_numbered_child(unsigned mod_no, const char *name, int num,
 	twl = &twl_priv->twl_modules[sid];
 	pdev = platform_device_alloc(name, num);
-	if (!pdev) {
-		dev_dbg(&twl->client->dev, "can't alloc dev\n");
-		status = -ENOMEM;
-		goto err;
+	if (!pdev)
+		return ERR_PTR(-ENOMEM);
 	pdev->dev.parent = &twl->client->dev;
BtrLinux
Privacy Overview
