mfd: menelaus: Fix error return code
Author: Julia Lawall <julia.lawall@lip6.fr>
Convert a zero return value on error to a negative one, as returned
elsewhere in the function.
Additionally, converted 1 << 7 to BIT(7) at the suggestion of Lee Jones.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
if@p1 (\(ret < 0\|ret != 0\))
{ ... return ret; }
ret@p1 = 0
... when != ret = e1
when != &ret
*if(...)
... when != ret = e2
when forall
return ret;
Signed-off-by: Julia Lawall
Signed-off-by: Lee Jones
drivers/mfd/menelaus.c | 8 ++++----
1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/drivers/mfd/menelaus.c b/drivers/mfd/menelaus.c
index 18ff56f..9f01aef 100644
--- a/drivers/mfd/menelaus.c
+++ b/drivers/mfd/menelaus.c
@@ -1183,7 +1183,7 @@ static int menelaus_probe(struct i2c_client *client,
const struct i2c_device_id *id)
struct menelaus_chip *menelaus;
- int rev = 0, val;
+ int rev = 0;
int err = 0;
struct menelaus_platform_data *menelaus_pdata =
dev_get_platdata(&client->dev);
@@ -1236,10 +1236,10 @@ static int menelaus_probe(struct i2c_client *client,
pr_info("Menelaus rev %d.%d\n", rev >> 4, rev & 0x0f);
- val = menelaus_read_reg(MENELAUS_VCORE_CTRL1);
- if (val < 0)
+ err = menelaus_read_reg(MENELAUS_VCORE_CTRL1);
+ if (err < 0)
goto fail;
- if (val & (1 << 7))
+ if (err & BIT(7))
menelaus->vcore_hw_mode = 1;
else
menelaus->vcore_hw_mode = 0; |
- int rev = 0, val;
+ int rev = 0;
int err = 0;
- if (val < 0)
+ if (err < 0)
goto fail;
+ if (err & BIT(7))
else
