mfd: htc-egpio: Consolidate chained IRQ handler install/remove
Author: Thomas Gleixner <tglx@linutronix.de>
Chained irq handlers usually set up handler data as well. We now have
a function to set both under irq_desc->lock. Replace the two calls
with one.
Search and conversion was done with coccinelle:
Reported-by: Russell King
Signed-off-by: Thomas Gleixner
Signed-off-by: Lee Jones
 drivers/mfd/htc-egpio.c | 4 ++--
 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/mfd/htc-egpio.c b/drivers/mfd/htc-egpio.c
index c9d5e3f..9131cdc 100644
--- a/drivers/mfd/htc-egpio.c
+++ b/drivers/mfd/htc-egpio.c
@@ -353,8 +353,8 @@ static int __init egpio_probe(struct platform_device *pdev)
 			irq_clear_status_flags(irq, IRQ_NOREQUEST | IRQ_NOPROBE);
 		irq_set_irq_type(ei->chained_irq, IRQ_TYPE_EDGE_RISING);
-		irq_set_handler_data(ei->chained_irq, ei);
-		irq_set_chained_handler(ei->chained_irq, egpio_handler);
+		irq_set_chained_handler_and_data(ei->chained_irq,
+						 egpio_handler, ei);
 		ack_irqs(ei);
 		device_init_wakeup(&pdev->dev, 1);
