memory: tegra: Delete unneeded of_node_put()
Author: Julia Lawall <julia.lawall@lip6.fr>
for_each_child_of_node() performs an of_node_put() on each iteration, so
putting an of_node_put() before a continue results in a double put.
The semantic match that finds this problem is as follows
(http://coccinelle.lip6.fr):
expression root,e;
local idexpression child;
iterator name for_each_child_of_node;
 for_each_child_of_node(root, child) {
   ... when != of_node_get(child)
*  of_node_put(child);
*  continue;
Signed-off-by: Julia Lawall
Signed-off-by: Thierry Reding
 drivers/memory/tegra/mc.c           | 4 +---
 drivers/memory/tegra/tegra124-emc.c | 4 +---
 2 files changed, 2 insertions(+), 6 deletions(-)
diff --git a/drivers/memory/tegra/mc.c b/drivers/memory/tegra/mc.c
index a1ae0cc..85ce4be 100644
--- a/drivers/memory/tegra/mc.c
+++ b/drivers/memory/tegra/mc.c
@@ -206,10 +206,8 @@ static int tegra_mc_setup_timings(struct tegra_mc *mc)
 	for_each_child_of_node(mc->dev->of_node, node) {
 		err = of_property_read_u32(node, "nvidia,ram-code",
 					   &node_ram_code);
-		if (err || (node_ram_code != ram_code)) {
-			of_node_put(node);
+		if (err || (node_ram_code != ram_code))
 			continue;
 		err = load_timings(mc, node);
 		if (err)
diff --git a/drivers/memory/tegra/tegra124-emc.c b/drivers/memory/tegra/tegra124-emc.c
index 02a6317..06cc781 100644
--- a/drivers/memory/tegra/tegra124-emc.c
+++ b/drivers/memory/tegra/tegra124-emc.c
@@ -997,10 +997,8 @@ tegra_emc_find_node_by_ram_code(struct device_node *node, u32 ram_code)
 		u32 value;
 		err = of_property_read_u32(np, "nvidia,ram-code", &value);
-		if (err || (value != ram_code)) {
-			of_node_put(np);
+		if (err || (value != ram_code))
 			continue;
 		return np;
BtrLinux
Privacy Overview
