[media] wl128x: Replace memcpy with struct assignment
Author: Ezequiel Garcia <elezegarcia@gmail.com>
This kind of memcpy() is error-prone. Its replacement with a struct
assignment is prefered because it's type-safe and much easier to read.
Found by coccinelle. Hand patched and reviewed.
Tested by compilation only.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
identifier struct_name;
struct struct_name to;
struct struct_name from;
expression E;
-memcpy(&(to), &(from), E);
+to = from;
Signed-off-by: Peter Senna Tschudin
Signed-off-by: Ezequiel Garcia
Signed-off-by: Mauro Carvalho Chehab
drivers/media/radio/wl128x/fmdrv_common.c | 3 +--
1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/drivers/media/radio/wl128x/fmdrv_common.c b/drivers/media/radio/wl128x/fmdrv_common.c
index 602ef7a..a002234 100644
--- a/drivers/media/radio/wl128x/fmdrv_common.c
+++ b/drivers/media/radio/wl128x/fmdrv_common.c
@@ -1563,8 +1563,7 @@ int fmc_prepare(struct fmdev *fmdev)
fmdev->irq_info.mask = FM_MAL_EVENT;
/* Region info */
- memcpy(&fmdev->rx.region, ®ion_configs[default_radio_region],
- sizeof(struct region_info));
+ fmdev->rx.region = region_configs[default_radio_region];
fmdev->rx.mute_mode = FM_MUTE_OFF;
fmdev->rx.rf_depend_mute = FM_RX_RF_DEPENDENT_MUTE_OFF; |
/* Region info */
