[media] v4l: xilinx-vipp: add missing of_node_put
Author: Julia Lawall <Julia.Lawall@lip6.fr>
for_each_child_of_node performs an of_node_get on each iteration, so
a break out of the loop requires an of_node_put.
A simplified version of the semantic patch that fixes this problem is as
follows (http://coccinelle.lip6.fr):
expression root,e;
local idexpression child;
 for_each_child_of_node(root, child) {
   ... when != of_node_put(child)
       when != e = child
   return child;
+  of_node_put(child);
?  return ...;
Signed-off-by: Julia Lawall
Reviewed-by: Laurent Pinchart
Signed-off-by: Mauro Carvalho Chehab
 drivers/media/platform/xilinx/xilinx-vipp.c | 4 +++-
 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/drivers/media/platform/xilinx/xilinx-vipp.c b/drivers/media/platform/xilinx/xilinx-vipp.c
index 7b7cb9c..b9bf24f 100644
--- a/drivers/media/platform/xilinx/xilinx-vipp.c
+++ b/drivers/media/platform/xilinx/xilinx-vipp.c
@@ -476,8 +476,10 @@ static int xvip_graph_dma_init(struct xvip_composite_device *xdev)
 	for_each_child_of_node(ports, port) {
 		ret = xvip_graph_dma_init_one(xdev, port);
-		if (ret < 0)
+		if (ret < 0) {
+			of_node_put(port);
 			return ret;
 	return 0;
BtrLinux
Privacy Overview
