[media] usbvision: Use setup_timer
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Convert a call to init_timer and accompanying intializations of
the timer's data and function fields to a call to setup_timer.
A simplified version of the semantic match that fixes this problem is as
follows: (http://coccinelle.lip6.fr/)
expression t,f,d;
-init_timer(&t);
+setup_timer(&t,f,d);
-t.data = d;
-t.function = f;
The semantic patch also changes the cast to long to a cast to unsigned
long in the data initializer, as unsigned long is the type of the data field.
Signed-off-by: Julia Lawall
Signed-off-by: Hans Verkuil
Signed-off-by: Mauro Carvalho Chehab
drivers/media/usb/usbvision/usbvision-core.c | 5 ++---
1 file changed, 2 insertions(+), 3 deletions(-)
diff --git a/drivers/media/usb/usbvision/usbvision-core.c b/drivers/media/usb/usbvision/usbvision-core.c
index 2144b7b..44b0c28 100644
--- a/drivers/media/usb/usbvision/usbvision-core.c
+++ b/drivers/media/usb/usbvision/usbvision-core.c
@@ -2194,9 +2194,8 @@ static void usbvision_power_off_timer(unsigned long data)
void usbvision_init_power_off_timer(struct usb_usbvision *usbvision)
- init_timer(&usbvision->power_off_timer);
- usbvision->power_off_timer.data = (long)usbvision;
- usbvision->power_off_timer.function = usbvision_power_off_timer;
+ setup_timer(&usbvision->power_off_timer, usbvision_power_off_timer,
+ (unsigned long)usbvision);
void usbvision_set_power_off_timer(struct usb_usbvision *usbvision) |
