[media] usbvision: Replace memcpy with struct assignment
Author: Ezequiel Garcia <elezegarcia@gmail.com>
This kind of memcpy() is error-prone. Its replacement with a struct
assignment is prefered because it's type-safe and much easier to read.
Found by coccinelle. Hand patched and reviewed.
Tested by compilation only.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
identifier struct_name;
struct struct_name to;
struct struct_name from;
expression E;
-memcpy(&(to), &(from), E);
+to = from;
Signed-off-by: Peter Senna Tschudin
Signed-off-by: Ezequiel Garcia
Signed-off-by: Mauro Carvalho Chehab
drivers/media/usb/usbvision/usbvision-i2c.c | 3 +--
1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/drivers/media/usb/usbvision/usbvision-i2c.c b/drivers/media/usb/usbvision/usbvision-i2c.c
index 89fec02..ba262a3 100644
--- a/drivers/media/usb/usbvision/usbvision-i2c.c
+++ b/drivers/media/usb/usbvision/usbvision-i2c.c
@@ -189,8 +189,7 @@ int usbvision_i2c_register(struct usb_usbvision *usbvision)
if (usbvision->registered_i2c)
return 0;
- memcpy(&usbvision->i2c_adap, &i2c_adap_template,
- sizeof(struct i2c_adapter));
+ usbvision->i2c_adap = i2c_adap_template;
sprintf(usbvision->i2c_adap.name, "%s-%d-%s", i2c_adap_template.name,
usbvision->dev->bus->busnum, usbvision->dev->devpath); |
return 0;
