[media] USB: Deletion of unnecessary checks before three function calls
Author: Markus Elfring <elfring@users.sourceforge.net>
GIT_AUTHOR_DATE=1416486805
The functions pvr2_hdw_destroy(), rc_unregister_device() and vfree() perform
also input parameter validation. Thus the test around the call is not needed.
This issue was detected by using the Coccinelle software.
Signed-off-by: Markus Elfring
Signed-off-by: Mauro Carvalho Chehab
 drivers/media/usb/au0828/au0828-input.c     | 3 +--
 drivers/media/usb/em28xx/em28xx-input.c     | 3 +--
 drivers/media/usb/pvrusb2/pvrusb2-context.c | 2 +-
 drivers/media/usb/s2255/s2255drv.c          | 3 +--
 4 files changed, 4 insertions(+), 7 deletions(-)
diff --git a/drivers/media/usb/au0828/au0828-input.c b/drivers/media/usb/au0828/au0828-input.c
index 63995f9..11a8dae 100644
--- a/drivers/media/usb/au0828/au0828-input.c
+++ b/drivers/media/usb/au0828/au0828-input.c
@@ -363,8 +363,7 @@ void au0828_rc_unregister(struct au0828_dev *dev)
 	if (!ir)
 		return;
-	if (ir->rc)
-		rc_unregister_device(ir->rc);
+	rc_unregister_device(ir->rc);
 	/* done */
 	kfree(ir);
diff --git a/drivers/media/usb/em28xx/em28xx-input.c b/drivers/media/usb/em28xx/em28xx-input.c
index 23f8f6a..85ac7dd 100644
--- a/drivers/media/usb/em28xx/em28xx-input.c
+++ b/drivers/media/usb/em28xx/em28xx-input.c
@@ -841,8 +841,7 @@ static int em28xx_ir_fini(struct em28xx *dev)
 	if (!ir)
 		goto ref_put;
-	if (ir->rc)
 	kfree(ir->i2c_client);
diff --git a/drivers/media/usb/pvrusb2/pvrusb2-context.c b/drivers/media/usb/pvrusb2/pvrusb2-context.c
index 7c19ff7..c8761c7 100644
--- a/drivers/media/usb/pvrusb2/pvrusb2-context.c
+++ b/drivers/media/usb/pvrusb2/pvrusb2-context.c
@@ -80,7 +80,7 @@ static void pvr2_context_set_notify(struct pvr2_context *mp, int fl)
 static void pvr2_context_destroy(struct pvr2_context *mp)
 	pvr2_trace(PVR2_TRACE_CTXT,"pvr2_context %p (destroy)",mp);
-	if (mp->hdw) pvr2_hdw_destroy(mp->hdw);
+	pvr2_hdw_destroy(mp->hdw);
 	pvr2_context_set_notify(mp, 0);
 	mutex_lock(&pvr2_context_mutex);
 	if (mp->exist_next) {
diff --git a/drivers/media/usb/s2255/s2255drv.c b/drivers/media/usb/s2255/s2255drv.c
index a56a05b..e03b155 100644
--- a/drivers/media/usb/s2255/s2255drv.c
+++ b/drivers/media/usb/s2255/s2255drv.c
@@ -1974,8 +1974,7 @@ static int s2255_release_sys_buffers(struct s2255_vc *vc)
 	unsigned long i;
 	for (i = 0; i < SYS_FRAMES; i++) {
-		if (vc->buffer.frame[i].lpvbits)
-			vfree(vc->buffer.frame[i].lpvbits);
+		vfree(vc->buffer.frame[i].lpvbits);
 		vc->buffer.frame[i].lpvbits = NULL;
 	return 0;
BtrLinux
Privacy Overview
