[media] USB: as102_usb_drv.c: Remove useless return variables
Author: Peter Senna Tschudin <peter.senna@gmail.com>
This patch remove variables that are initialized with a constant,
are never updated, and are only used as parameter of return.
Return the constant instead of using a variable.
Verified by compilation only.
The coccinelle script that find and fixes this issue is:
type T;
constant C;
identifier ret;
- T ret = C;
... when != ret
- return ret;
+ return C;
Signed-off-by: Peter Senna Tschudin
Signed-off-by: Mauro Carvalho Chehab
 drivers/staging/media/as102/as102_usb_drv.c | 7 +++----
 1 file changed, 3 insertions(+), 4 deletions(-)
diff --git a/drivers/staging/media/as102/as102_usb_drv.c b/drivers/staging/media/as102/as102_usb_drv.c
index e4a6945..e6f6278 100644
--- a/drivers/staging/media/as102/as102_usb_drv.c
+++ b/drivers/staging/media/as102/as102_usb_drv.c
@@ -249,7 +249,7 @@ static void as102_free_usb_stream_buffer(struct as102_dev_t *dev)
 static int as102_alloc_usb_stream_buffer(struct as102_dev_t *dev)
-	int i, ret = 0;
+	int i;
 	dev->stream = usb_alloc_coherent(dev->bus_adap.usb_dev,
 				       MAX_STREAM_URB * AS102_USB_BUF_SIZE,
@@ -280,7 +280,7 @@ static int as102_alloc_usb_stream_buffer(struct as102_dev_t *dev)
 		dev->stream_urb[i] = urb;
-	return ret;
+	return 0;
 static void as102_usb_stop_stream(struct as102_dev_t *dev)
@@ -458,7 +458,6 @@ exit:
 static int as102_release(struct inode *inode, struct file *file)
-	int ret = 0;
 	struct as102_dev_t *dev = NULL;
 	dev = file->private_data;
@@ -467,7 +466,7 @@ static int as102_release(struct inode *inode, struct file *file)
 		kref_put(&dev->kref, as102_usb_release);
-	return ret;
+	return 0;
 MODULE_DEVICE_TABLE(usb, as102_usb_id_table);
BtrLinux
Privacy Overview
