[media] tuners: Refactoring for m88rs6000t_sleep()
Author: Markus Elfring <elfring@users.sourceforge.net>
This issue was detected by using the Coccinelle software.
1. Let us return directly if a call of the regmap_write() function failed.
2. Delete the jump label "err" then.
3. Return zero as a constant at the end.
Signed-off-by: Markus Elfring
Signed-off-by: Mauro Carvalho Chehab
 drivers/media/tuners/m88rs6000t.c | 11 +++++------
 1 file changed, 5 insertions(+), 6 deletions(-)
diff --git a/drivers/media/tuners/m88rs6000t.c b/drivers/media/tuners/m88rs6000t.c
index 504bfbc..9f3e0fd 100644
--- a/drivers/media/tuners/m88rs6000t.c
+++ b/drivers/media/tuners/m88rs6000t.c
@@ -461,13 +461,12 @@ static int m88rs6000t_sleep(struct dvb_frontend *fe)
 	dev_dbg(&dev->client->dev, "%s:\n", __func__);
 	ret = regmap_write(dev->regmap, 0x07, 0x6d);
-	if (ret)
-		goto err;
-	usleep_range(5000, 10000);
-err:
-	if (ret)
+	if (ret) {
 		dev_dbg(&dev->client->dev, "failed=%d\n", ret);
-	return ret;
+		return ret;
+	usleep_range(5000, 10000);
+	return 0;
 static int m88rs6000t_get_frequency(struct dvb_frontend *fe, u32 *frequency)
BtrLinux
Privacy Overview
