[media] timblogiw: Introduce the use of the managed version of kzalloc
Author: Himangi Saraogi <himangi774@gmail.com>
This patch moves data allocated using kzalloc to managed data allocated
using devm_kzalloc and cleans now unnecessary kfrees in probe and remove
functions.The label err_register is removed as it is no longer required.
The following Coccinelle semantic patch was used for making the change:
@platform@
identifier p, probefn, removefn;
struct platform_driver p = {
  .probe = probefn,
  .remove = removefn,
@prb@
identifier platform.probefn, pdev;
expression e, e1, e2;
probefn(struct platform_device *pdev, ...) {
- e = kzalloc(e1, e2)
+ e = devm_kzalloc(&pdev->dev, e1, e2)
?-kfree(e);
@rem depends on prb@
identifier platform.removefn;
expression e;
removefn(...) {
- kfree(e);
Signed-off-by: Himangi Saraogi
Signed-off-by: Hans Verkuil
Signed-off-by: Mauro Carvalho Chehab
 drivers/media/platform/timblogiw.c | 8 ++------
 1 file changed, 2 insertions(+), 6 deletions(-)
diff --git a/drivers/media/platform/timblogiw.c b/drivers/media/platform/timblogiw.c
index ccdadd6..fbfdada 100644
--- a/drivers/media/platform/timblogiw.c
+++ b/drivers/media/platform/timblogiw.c
@@ -800,7 +800,7 @@ static int timblogiw_probe(struct platform_device *pdev)
 	if (!pdata->encoder.module_name)
 		dev_info(&pdev->dev, "Running without decoder\n");
-	lw = kzalloc(sizeof(*lw), GFP_KERNEL);
+	lw = devm_kzalloc(&pdev->dev, sizeof(*lw), GFP_KERNEL);
 	if (!lw) {
 		err = -ENOMEM;
 		goto err;
@@ -820,7 +820,7 @@ static int timblogiw_probe(struct platform_device *pdev)
 	strlcpy(lw->v4l2_dev.name, DRIVER_NAME, sizeof(lw->v4l2_dev.name));
 	err = v4l2_device_register(NULL, &lw->v4l2_dev);
 	if (err)
-		goto err_register;
+		goto err;
 	lw->video_dev.v4l2_dev = &lw->v4l2_dev;
@@ -837,8 +837,6 @@ static int timblogiw_probe(struct platform_device *pdev)
 err_request:
 	v4l2_device_unregister(&lw->v4l2_dev);
-err_register:
-	kfree(lw);
 err:
 	dev_err(&pdev->dev, "Failed to register: %d\n", err);
@@ -853,8 +851,6 @@ static int timblogiw_remove(struct platform_device *pdev)
-	kfree(lw);
 	return 0;
BtrLinux
Résumé de la politique de confidentialité
Ce site utilise des cookies afin que nous puissions vous fournir la meilleure expérience utilisateur possible. Les informations sur les cookies sont stockées dans votre navigateur et remplissent des fonctions telles que vous reconnaître lorsque vous revenez sur notre site Web et aider notre équipe à comprendre les sections du site que vous trouvez les plus intéressantes et utiles.
