[media] platform: Deletion of unnecessary checks before two function calls
Author: Markus Elfring <elfring@users.sourceforge.net>
The functions i2c_put_adapter() and release_firmware() test whether their
argument is NULL and then return immediately. Thus the test around the call
is not needed.
This issue was detected by using the Coccinelle software.
Signed-off-by: Markus Elfring
Signed-off-by: Mauro Carvalho Chehab
 drivers/media/platform/exynos4-is/fimc-is.c   | 6 ++----
 drivers/media/platform/s3c-camif/camif-core.c | 3 +--
 2 files changed, 3 insertions(+), 6 deletions(-)
diff --git a/drivers/media/platform/exynos4-is/fimc-is.c b/drivers/media/platform/exynos4-is/fimc-is.c
index 3d49ce0..2a0cbef 100644
--- a/drivers/media/platform/exynos4-is/fimc-is.c
+++ b/drivers/media/platform/exynos4-is/fimc-is.c
@@ -428,8 +428,7 @@ static void fimc_is_load_firmware(const struct firmware *fw, void *context)
 	 * needed around for copying to the IS working memory every
 	 * time before the Cortex-A5 is restarted.
-	if (is->fw.f_w)
-		release_firmware(is->fw.f_w);
+	release_firmware(is->fw.f_w);
 	is->fw.f_w = fw;
 done:
 	mutex_unlock(&is->lock);
@@ -937,8 +936,7 @@ static int fimc_is_remove(struct platform_device *pdev)
 	vb2_dma_contig_cleanup_ctx(is->alloc_ctx);
 	fimc_is_put_clocks(is);
 	fimc_is_debugfs_remove(is);
-	if (is->fw.f_w)
 	fimc_is_free_cpu_memory(is);
 	return 0;
diff --git a/drivers/media/platform/s3c-camif/camif-core.c b/drivers/media/platform/s3c-camif/camif-core.c
index b385747..3b09b5b 100644
--- a/drivers/media/platform/s3c-camif/camif-core.c
+++ b/drivers/media/platform/s3c-camif/camif-core.c
@@ -256,8 +256,7 @@ static void camif_unregister_sensor(struct camif_dev *camif)
 	v4l2_device_unregister_subdev(sd);
 	camif->sensor.sd = NULL;
 	i2c_unregister_device(client);
-	if (adapter)
-		i2c_put_adapter(adapter);
+	i2c_put_adapter(adapter);
 static int camif_create_media_links(struct camif_dev *camif)
BtrLinux
Privacy Overview
