[media] omap3isp: Fix error return code in probe function
Author: Peter Senna Tschudin <peter.senna@gmail.com>
Convert a nonnegative error return code to a negative one, as returned
elsewhere in the function.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
if@p1 (\(ret < 0\|ret != 0\))
{ ... return ret; }
ret@p1 = 0
... when != ret = e1
when != &ret
*if(...)
... when != ret = e2
when forall
return ret;
Signed-off-by: Peter Senna Tschudin
[laurent.pinchart@ideasonboard.com Replaced EBUSY with ENODEV]
Signed-off-by: Laurent Pinchart
Signed-off-by: Mauro Carvalho Chehab
drivers/media/platform/omap3isp/isp.c | 4 +++-
1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/drivers/media/platform/omap3isp/isp.c b/drivers/media/platform/omap3isp/isp.c
index e0096e0..d7aa513 100644
--- a/drivers/media/platform/omap3isp/isp.c
+++ b/drivers/media/platform/omap3isp/isp.c
@@ -2102,8 +2102,10 @@ static int __devinit isp_probe(struct platform_device *pdev)
if (ret < 0)
goto error;
- if (__omap3isp_get(isp, false) == NULL)
+ if (__omap3isp_get(isp, false) == NULL) {
+ ret = -ENODEV;
goto error;
ret = isp_reset(isp);
if (ret < 0) |
if (ret < 0)
goto error;
+ ret = -ENODEV;
goto error;
if (ret < 0)
