[media] msi2500: Delete an unnecessary check in msi2500_set_usb_adc()
Author: Markus Elfring <elfring@users.sourceforge.net>
This issue was detected by using the Coccinelle software.
Return the value from a call of the msi2500_ctrl_msg() function
without using an extra check for the variable "ret" at the end.
Signed-off-by: Markus Elfring
Signed-off-by: Mauro Carvalho Chehab
 drivers/media/usb/msi2500/msi2500.c | 2 --
 1 file changed, 2 deletions(-)
diff --git a/drivers/media/usb/msi2500/msi2500.c b/drivers/media/usb/msi2500/msi2500.c
index c104315..2d33033 100644
--- a/drivers/media/usb/msi2500/msi2500.c
+++ b/drivers/media/usb/msi2500/msi2500.c
@@ -839,8 +839,6 @@ static int msi2500_set_usb_adc(struct msi2500_dev *dev)
 		goto err;
 	ret = msi2500_ctrl_msg(dev, CMD_WREG, reg3);
-	if (ret)
-		goto err;
 err:
 	return ret;
BtrLinux
Privacy Overview
