[media] media/rc/imon.c: use USB API functions rather than constants
Author: Himangi Saraogi <himangi774@gmail.com>
This patch introduces the use of the function usb_endpoint_type.
The Coccinelle semantic patch that makes these changes is as follows:
@@ struct usb_endpoint_descriptor *epd; @@
- (epd->bmAttributes & \(USB_ENDPOINT_XFERTYPE_MASK\|3\))
+ usb_endpoint_type(epd)
Signed-off-by: Himangi Saraogi
Acked-by: Julia Lawall
Signed-off-by: Mauro Carvalho Chehab
 drivers/media/rc/imon.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/media/rc/imon.c b/drivers/media/rc/imon.c
index cd511a7..74dacee 100644
--- a/drivers/media/rc/imon.c
+++ b/drivers/media/rc/imon.c
@@ -2123,7 +2123,7 @@ static bool imon_find_endpoints(struct imon_context *ictx,
 	for (i = 0; i < num_endpts && !(ir_ep_found && display_ep_found); ++i) {
 		ep = &iface_desc->endpoint[i].desc;
 		ep_dir = ep->bEndpointAddress & USB_ENDPOINT_DIR_MASK;
-		ep_type = ep->bmAttributes & USB_ENDPOINT_XFERTYPE_MASK;
+		ep_type = usb_endpoint_type(ep);
 		if (!ir_ep_found && ep_dir == USB_DIR_IN &&
 		    ep_type == USB_ENDPOINT_XFER_INT) {
BtrLinux
Privacy Overview
