[media] media: platform: exynos4-is: media-dev: Add missing of_node_put
Author: Amitoj Kaur Chawla <amitoj1606@gmail.com>
for_each_available_child_of_node and for_each_child_of_node perform an
of_node_get on each iteration, so to break out of the loop an of_node_put is
required.
Found using Coccinelle. The simplified version of the semantic patch
that is used for this is as follows:
local idexpression n;
expression e,r;
 for_each_available_child_of_node(r,n) {
   of_node_put(n);
   e = n
+  of_node_put(n);
?  break;
... when != n
Signed-off-by: Amitoj Kaur Chawla
Reviewed-by: Krzysztof Kozlowski
Signed-off-by: Mauro Carvalho Chehab
 drivers/media/platform/exynos4-is/media-dev.c | 12 +++++++++---
 1 file changed, 9 insertions(+), 3 deletions(-)
diff --git a/drivers/media/platform/exynos4-is/media-dev.c b/drivers/media/platform/exynos4-is/media-dev.c
index 662d4a5..26a4e5c 100644
--- a/drivers/media/platform/exynos4-is/media-dev.c
+++ b/drivers/media/platform/exynos4-is/media-dev.c
@@ -435,8 +435,10 @@ static int fimc_md_register_sensor_entities(struct fimc_md *fmd)
 			continue;
 		ret = fimc_md_parse_port_node(fmd, port, index);
-		if (ret < 0)
+		if (ret < 0) {
+			of_node_put(node);
 			goto rpm_put;
 		index++;
@@ -447,8 +449,10 @@ static int fimc_md_register_sensor_entities(struct fimc_md *fmd)
 	for_each_child_of_node(ports, node) {
 		ret = fimc_md_parse_port_node(fmd, node, index);
-		if (ret < 0)
+		if (ret < 0) {
 			break;
 		index++;
 rpm_put:
@@ -656,8 +660,10 @@ static int fimc_md_register_platform_entities(struct fimc_md *fmd,
 			ret = fimc_md_register_platform_entity(fmd, pdev,
 							plat_entity);
 		put_device(&pdev->dev);
-		if (ret < 0)
+		if (ret < 0) {
 			break;
 	return ret;
BtrLinux
Privacy Overview
