[media] e4000: fix error return code
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Set the return variable to an error code as done elsewhere in the function.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
if@p1 (\(ret < 0\|ret != 0\))
 { ... return ret; }
ret@p1 = 0
... when != ret = e1
    when != &ret
*if(...)
  ... when != ret = e2
      when forall
 return ret;
Signed-off-by: Julia Lawall
Cc: Antti Palosaari
Signed-off-by: Mauro Carvalho Chehab
 drivers/media/tuners/e4000.c | 16 ++++++++++++----
 1 file changed, 12 insertions(+), 4 deletions(-)
diff --git a/drivers/media/tuners/e4000.c b/drivers/media/tuners/e4000.c
index 72971a8..40c1da7 100644
--- a/drivers/media/tuners/e4000.c
+++ b/drivers/media/tuners/e4000.c
@@ -243,8 +243,10 @@ static int e4000_set_params(struct dvb_frontend *fe)
 			break;
-	if (i == ARRAY_SIZE(e4000_pll_lut))
+	if (i == ARRAY_SIZE(e4000_pll_lut)) {
+		ret = -EINVAL;
 		goto err;
 	 * Note: Currently f_vco overflows when c->frequency is 1 073 741 824 Hz
@@ -271,8 +273,10 @@ static int e4000_set_params(struct dvb_frontend *fe)
 			break;
-	if (i == ARRAY_SIZE(e400_lna_filter_lut))
+	if (i == ARRAY_SIZE(e400_lna_filter_lut)) {
+		ret = -EINVAL;
 		goto err;
 	ret = e4000_wr_reg(priv, 0x10, e400_lna_filter_lut[i].val);
 	if (ret < 0)
@@ -284,8 +288,10 @@ static int e4000_set_params(struct dvb_frontend *fe)
 			break;
-	if (i == ARRAY_SIZE(e4000_if_filter_lut))
+	if (i == ARRAY_SIZE(e4000_if_filter_lut)) {
+		ret = -EINVAL;
 		goto err;
 	buf[0] = e4000_if_filter_lut[i].reg11_val;
 	buf[1] = e4000_if_filter_lut[i].reg12_val;
@@ -300,8 +306,10 @@ static int e4000_set_params(struct dvb_frontend *fe)
 			break;
-	if (i == ARRAY_SIZE(e4000_band_lut))
+	if (i == ARRAY_SIZE(e4000_band_lut)) {
+		ret = -EINVAL;
 		goto err;
 	ret = e4000_wr_reg(priv, 0x07, e4000_band_lut[i].reg07_val);
 	if (ret < 0)
BtrLinux
Privacy Overview
