[media] drivers/staging/media/davinci_vpfe/vpfe_mc_capture.c: use correct structure type name in sizeof
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Correct typo in the name of the type given to sizeof.  Because it is the
size of a pointer that is wanted, the typo has no impact on compilation or
execution.
This problem was found using Coccinelle (http://coccinelle.lip6.fr/).  The
semantic patch used can be found in message 0 of this patch series.
[Replace sizeof(type) by sizeof(variable)]]
Signed-off-by: Julia Lawall
Signed-off-by: Laurent Pinchart
Signed-off-by: Mauro Carvalho Chehab
 drivers/staging/media/davinci_vpfe/vpfe_mc_capture.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/staging/media/davinci_vpfe/vpfe_mc_capture.c b/drivers/staging/media/davinci_vpfe/vpfe_mc_capture.c
index 01df068..69b678c 100644
--- a/drivers/staging/media/davinci_vpfe/vpfe_mc_capture.c
+++ b/drivers/staging/media/davinci_vpfe/vpfe_mc_capture.c
@@ -227,7 +227,7 @@ static int vpfe_enable_clock(struct vpfe_device *vpfe_dev)
 		return 0;
 	vpfe_dev->clks = kcalloc(vpfe_cfg->num_clocks,
-				 sizeof(struct clock *), GFP_KERNEL);
+				 sizeof(*vpfe_dev->clks), GFP_KERNEL);
 	if (vpfe_dev->clks == NULL)
 		return -ENOMEM;
