[media] drivers/media/usb/dvb-usb-v2: constify mxl111sf_tuner_config structure
Author: Julia Lawall <Julia.Lawall@lip6.fr>
This mxl111sf_tuner_config structure is never modified, so declare it as
const.
There are some indentation changes to remain within 80 columns.
Done with the help of Coccinelle.
Signed-off-by: Julia Lawall
Reviewed-by: Michael Ira Krufky
Signed-off-by: Hans Verkuil
Signed-off-by: Mauro Carvalho Chehab
 drivers/media/usb/dvb-usb-v2/mxl111sf-tuner.c | 6 +++---
 drivers/media/usb/dvb-usb-v2/mxl111sf-tuner.h | 8 ++++----
 drivers/media/usb/dvb-usb-v2/mxl111sf.c       | 2 +-
 3 files changed, 8 insertions(+), 8 deletions(-)
diff --git a/drivers/media/usb/dvb-usb-v2/mxl111sf-tuner.c b/drivers/media/usb/dvb-usb-v2/mxl111sf-tuner.c
index 444579b..7d16252 100644
--- a/drivers/media/usb/dvb-usb-v2/mxl111sf-tuner.c
+++ b/drivers/media/usb/dvb-usb-v2/mxl111sf-tuner.c
@@ -36,7 +36,7 @@ MODULE_PARM_DESC(debug, "set debugging level (1=info (or-able)).");
 struct mxl111sf_tuner_state {
 	struct mxl111sf_state *mxl_state;
-	struct mxl111sf_tuner_config *cfg;
+	const struct mxl111sf_tuner_config *cfg;
 	enum mxl_if_freq if_freq;
@@ -489,8 +489,8 @@ static struct dvb_tuner_ops mxl111sf_tuner_tuner_ops = {
 struct dvb_frontend *mxl111sf_tuner_attach(struct dvb_frontend *fe,
-					   struct mxl111sf_state *mxl_state,
-					   struct mxl111sf_tuner_config *cfg)
+				struct mxl111sf_state *mxl_state,
+				const struct mxl111sf_tuner_config *cfg)
 	struct mxl111sf_tuner_state *state = NULL;
diff --git a/drivers/media/usb/dvb-usb-v2/mxl111sf-tuner.h b/drivers/media/usb/dvb-usb-v2/mxl111sf-tuner.h
index e6caab2..509b550 100644
--- a/drivers/media/usb/dvb-usb-v2/mxl111sf-tuner.h
+++ b/drivers/media/usb/dvb-usb-v2/mxl111sf-tuner.h
@@ -63,13 +63,13 @@ struct mxl111sf_tuner_config {
 #if IS_ENABLED(CONFIG_DVB_USB_MXL111SF)
 extern
-					   struct mxl111sf_tuner_config *cfg);
+				const struct mxl111sf_tuner_config *cfg);
 #else
 static inline
 	printk(KERN_WARNING "%s: driver disabled by Kconfig\n", __func__);
 	return NULL;
diff --git a/drivers/media/usb/dvb-usb-v2/mxl111sf.c b/drivers/media/usb/dvb-usb-v2/mxl111sf.c
index e7978e4..5d676b5 100644
--- a/drivers/media/usb/dvb-usb-v2/mxl111sf.c
+++ b/drivers/media/usb/dvb-usb-v2/mxl111sf.c
@@ -856,7 +856,7 @@ static int mxl111sf_ant_hunt(struct dvb_frontend *fe)
 	return 0;
-static struct mxl111sf_tuner_config mxl_tuner_config = {
+static const struct mxl111sf_tuner_config mxl_tuner_config = {
 	.if_freq         = MXL_IF_6_0, /* applies to external IF output, only */
 	.invert_spectrum = 0,
 	.read_reg        = mxl111sf_read_reg,
BtrLinux
Résumé de la politique de confidentialité
Ce site utilise des cookies afin que nous puissions vous fournir la meilleure expérience utilisateur possible. Les informations sur les cookies sont stockées dans votre navigateur et remplissent des fonctions telles que vous reconnaître lorsque vous revenez sur notre site Web et aider notre équipe à comprendre les sections du site que vous trouvez les plus intéressantes et utiles.
