[media] drivers/media/rc/redrat3.c: fix error return code
Author: Peter Senna Tschudin <peter.senna@gmail.com>
Convert a nonnegative error return code to a negative one, as returned
elsewhere in the function.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
if@p1 (\(ret < 0\|ret != 0\))
{ ... return ret; }
ret@p1 = 0
... when != ret = e1
when != &ret
*if(...)
... when != ret = e2
when forall
return ret;
Signed-off-by: Peter Senna Tschudin
Signed-off-by: Mauro Carvalho Chehab
drivers/media/rc/redrat3.c | 5 +++--
1 file changed, 3 insertions(+), 2 deletions(-)
diff --git a/drivers/media/rc/redrat3.c b/drivers/media/rc/redrat3.c
index 2878b0e..49731b1 100644
--- a/drivers/media/rc/redrat3.c
+++ b/drivers/media/rc/redrat3.c
@@ -1217,9 +1217,10 @@ static int __devinit redrat3_dev_probe(struct usb_interface *intf,
rr3->carrier = 38000;
rr3->rc = redrat3_init_rc_dev(rr3);
- if (!rr3->rc)
+ if (!rr3->rc) {
+ retval = -ENOMEM;
goto error;
setup_timer(&rr3->rx_timeout, redrat3_rx_timeout, (unsigned long)rr3);
/* we can register the device now, as it is ready */ |
- if (!rr3->rc)
+ if (!rr3->rc) {
+ retval = -ENOMEM;
goto error;
