[media] drivers/media/radio/radio-cadet.c: fix error return code
Author: Peter Senna Tschudin <peter.senna@gmail.com>
Convert a nonnegative error return code to a negative one, as returned
elsewhere in the function.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
if@p1 (\(ret < 0\|ret != 0\))
 { ... return ret; }
ret@p1 = 0
... when != ret = e1
    when != &ret
*if(...)
  ... when != ret = e2
      when forall
 return ret;
Signed-off-by: Peter Senna Tschudin
Signed-off-by: Mauro Carvalho Chehab
 drivers/media/radio/radio-cadet.c | 3 ++-
 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/drivers/media/radio/radio-cadet.c b/drivers/media/radio/radio-cadet.c
index 697a421..643d80a 100644
--- a/drivers/media/radio/radio-cadet.c
+++ b/drivers/media/radio/radio-cadet.c
@@ -645,7 +645,8 @@ static int __init cadet_init(void)
 	set_bit(V4L2_FL_USE_FH_PRIO, &dev->vdev.flags);
 	video_set_drvdata(&dev->vdev, dev);
-	if (video_register_device(&dev->vdev, VFL_TYPE_RADIO, radio_nr) < 0)
+	res = video_register_device(&dev->vdev, VFL_TYPE_RADIO, radio_nr);
+	if (res < 0)
 		goto err_hdl;
 	v4l2_info(v4l2_dev, "ADS Cadet Radio Card at 0x%x\n", dev->io);
 	return 0;
BtrLinux
Privacy Overview
