[media] drivers/media/platform/mx2_emmaprp.c: use devm_kzalloc and devm_clk_get
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Using devm_kzalloc simplifies the code and ensures that the use of
devm_request_irq is safe.  When kzalloc and kfree were used, the interrupt
could be triggered after the handler's data argument had been freed.
This also introduces some missing initializations of the return variable
ret, and uses devm_request_and_ioremap instead of the combination of
devm_request_mem_region and devm_ioremap.
The problem of a free after a devm_request_irq was found using the
following semantic match (http://coccinelle.lip6.fr/)
@r exists@
expression e1,e2,x,a,b,c,d;
identifier free;
position p1,p2;
  devm_request_irq@p1(e1,e2,...,x)
  ... when any
      when != e2 = a
      when != x = b
  if (...) {
    ... when != e2 = c
        when != x = d
    free@p2(...,x,...);
    return ...;
Signed-off-by: Julia Lawall
Signed-off-by: Mauro Carvalho Chehab
 drivers/media/platform/mx2_emmaprp.c | 31 ++++++++++++-------------------
 1 file changed, 12 insertions(+), 19 deletions(-)
diff --git a/drivers/media/platform/mx2_emmaprp.c b/drivers/media/platform/mx2_emmaprp.c
index 2810015..dab380a 100644
--- a/drivers/media/platform/mx2_emmaprp.c
+++ b/drivers/media/platform/mx2_emmaprp.c
@@ -896,7 +896,7 @@ static int emmaprp_probe(struct platform_device *pdev)
 	int irq_emma;
 	int ret;
-	pcdev = kzalloc(sizeof *pcdev, GFP_KERNEL);
+	pcdev = devm_kzalloc(&pdev->dev, sizeof(*pcdev), GFP_KERNEL);
 	if (!pcdev)
 		return -ENOMEM;
@@ -904,27 +904,24 @@ static int emmaprp_probe(struct platform_device *pdev)
 	pcdev->clk_emma_ipg = devm_clk_get(&pdev->dev, "ipg");
 	if (IS_ERR(pcdev->clk_emma_ipg)) {
-		ret = PTR_ERR(pcdev->clk_emma_ipg);
-		goto free_dev;
+		return PTR_ERR(pcdev->clk_emma_ipg);
 	pcdev->clk_emma_ahb = devm_clk_get(&pdev->dev, "ahb");
-		ret = PTR_ERR(pcdev->clk_emma_ahb);
-		goto free_dev;
+		return PTR_ERR(pcdev->clk_emma_ahb);
 	irq_emma = platform_get_irq(pdev, 0);
 	res_emma = platform_get_resource(pdev, IORESOURCE_MEM, 0);
 	if (irq_emma < 0 || res_emma == NULL) {
 		dev_err(&pdev->dev, "Missing platform resources data\n");
-		ret = -ENODEV;
-		goto free_dev;
+		return -ENODEV;
 	ret = v4l2_device_register(&pdev->dev, &pcdev->v4l2_dev);
 	if (ret)
-		goto free_dev;
+		return ret;
 	mutex_init(&pcdev->dev_mutex);
@@ -946,21 +943,20 @@ static int emmaprp_probe(struct platform_device *pdev)
 	platform_set_drvdata(pdev, pcdev);
-	if (devm_request_mem_region(&pdev->dev, res_emma->start,
-	    resource_size(res_emma), MEM2MEM_NAME) == NULL)
-		goto rel_vdev;
-	pcdev->base_emma = devm_ioremap(&pdev->dev, res_emma->start,
-					resource_size(res_emma));
-	if (!pcdev->base_emma)
+	pcdev->base_emma = devm_request_and_ioremap(&pdev->dev, res_emma);
+	if (!pcdev->base_emma) {
+		ret = -ENXIO;
 		goto rel_vdev;
 	pcdev->irq_emma = irq_emma;
 	pcdev->res_emma = res_emma;
 	if (devm_request_irq(&pdev->dev, pcdev->irq_emma, emmaprp_irq,
-			     0, MEM2MEM_NAME, pcdev) < 0)
+			     0, MEM2MEM_NAME, pcdev) < 0) {
+		ret = -ENODEV;
 		goto rel_vdev;
 	pcdev->alloc_ctx = vb2_dma_contig_init_ctx(&pdev->dev);
 	if (IS_ERR(pcdev->alloc_ctx)) {
@@ -993,8 +989,6 @@ rel_vdev:
 	video_device_release(vfd);
 unreg_dev:
 	v4l2_device_unregister(&pcdev->v4l2_dev);
-free_dev:
-	kfree(pcdev);
 	return ret;
@@ -1009,7 +1003,6 @@ static int emmaprp_remove(struct platform_device *pdev)
 	v4l2_m2m_release(pcdev->m2m_dev);
 	vb2_dma_contig_cleanup_ctx(pcdev->alloc_ctx);
-	kfree(pcdev);
 	return 0;
BtrLinux
Privacy Overview
