[media] drivers/media/platform/davinci/vpfe_capture.c: fix error return code
Author: Peter Senna Tschudin <peter.senna@gmail.com>
Convert a nonnegative error return code to a negative one, as returned
elsewhere in the function.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
if@p1 (\(ret < 0\|ret != 0\))
{ ... return ret; }
ret@p1 = 0
... when != ret = e1
when != &ret
*if(...)
... when != ret = e2
when forall
return ret;
Signed-off-by: Peter Senna Tschudin
Cc: Prabhakar Lad
Signed-off-by: Mauro Carvalho Chehab
drivers/media/platform/davinci/vpfe_capture.c | 15 ++++++++-------
1 file changed, 8 insertions(+), 7 deletions(-)
diff --git a/drivers/media/platform/davinci/vpfe_capture.c b/drivers/media/platform/davinci/vpfe_capture.c
index 843b138..f99198c 100644
--- a/drivers/media/platform/davinci/vpfe_capture.c
+++ b/drivers/media/platform/davinci/vpfe_capture.c
@@ -1131,11 +1131,11 @@ static int vpfe_s_input(struct file *file, void *priv, unsigned int index)
ret = -EBUSY;
goto unlock_out;
- if (vpfe_get_subdev_input_index(vpfe_dev,
- &subdev_index,
- &inp_index,
- index) < 0) {
+ ret = vpfe_get_subdev_input_index(vpfe_dev,
+ &subdev_index,
+ &inp_index,
+ index);
+ if (ret < 0) {
v4l2_err(&vpfe_dev->v4l2_dev, "invalid input index\n");
goto unlock_out;
@@ -1748,8 +1748,9 @@ static long vpfe_param_handler(struct file *file, void *priv,
"Error setting parameters in CCDC\n");
goto unlock_out;
- if (vpfe_get_ccdc_image_format(vpfe_dev,
- &vpfe_dev->fmt) < 0) {
+ ret = vpfe_get_ccdc_image_format(vpfe_dev,
+ &vpfe_dev->fmt);
+ if (ret < 0) {
v4l2_dbg(1, debug, &vpfe_dev->v4l2_dev,
"Invalid image format at CCDC\n");
goto unlock_out; |
ret = -EBUSY;
goto unlock_out;
- &subdev_index,
- &inp_index,
- index) < 0) {
+ &subdev_index,
+ &inp_index,
+ index);
+ if (ret < 0) {
goto unlock_out;
goto unlock_out;
+ &vpfe_dev->fmt);
+ if (ret < 0) {
goto unlock_out;
