[media] drivers/media/pci/ttpci/budget-av.c: fix error return code
Author: Peter Senna Tschudin <peter.senna@gmail.com>
Convert a nonnegative error return code to a negative one, as returned
elsewhere in the function.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
if@p1 (\(ret < 0\|ret != 0\))
 { ... return ret; }
ret@p1 = 0
... when != ret = e1
    when != &ret
*if(...)
  ... when != ret = e2
      when forall
 return ret;
Signed-off-by: Peter Senna Tschudin
Signed-off-by: Mauro Carvalho Chehab
 drivers/media/pci/ttpci/budget-av.c | 4 ++--
 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/media/pci/ttpci/budget-av.c b/drivers/media/pci/ttpci/budget-av.c
index 12ddb53..1f8b1bb 100644
--- a/drivers/media/pci/ttpci/budget-av.c
+++ b/drivers/media/pci/ttpci/budget-av.c
@@ -1477,8 +1477,8 @@ static int budget_av_attach(struct saa7146_dev *dev, struct saa7146_pci_extensio
 	if (saa7113_init(budget_av) == 0) {
 		budget_av->has_saa7113 = 1;
-		if (0 != saa7146_vv_init(dev, &vv_data)) {
+		err = saa7146_vv_init(dev, &vv_data);
+		if (err != 0) {
 			/* fixme: proper cleanup here */
 			ERR("cannot init vv subsystem\n");
 			return err;
BtrLinux
Privacy Overview
