[media] drivers/media/dvb-frontends/stb6100.c: Removes useless kfree()
Author: Peter Senna Tschudin <peter.senna@gmail.com>
Remove useless kfree() and clean up code related to the removal.
The semantic patch that finds this problem is as follows:
(http://coccinelle.lip6.fr/)
@r exists@
position p1,p2;
expression x;
if (x@p1 == NULL) { ... kfree@p2(x); ... return ...; }
@unchanged exists@
position r.p1,r.p2;
expression e <= r.x,x,e1;
iterator I;
statement S;
if (x@p1 == NULL) { ... when != I(x,...) S
                        when != e = e1
                        when != e += e1
                        when != e -= e1
                        when != ++e
                        when != --e
                        when != e++
                        when != e--
                        when != &e
@ok depends on unchanged exists@
position any r.p1;
position r.p2;
expression x;
... when != true x@p1 == NULL
kfree@p2(x);
@depends on !ok && unchanged@
position r.p2;
expression x;
*kfree@p2(x);
Signed-off-by: Peter Senna Tschudin
Signed-off-by: Mauro Carvalho Chehab
 drivers/media/dvb-frontends/stb6100.c | 8 ++------
 1 file changed, 2 insertions(+), 6 deletions(-)
diff --git a/drivers/media/dvb-frontends/stb6100.c b/drivers/media/dvb-frontends/stb6100.c
index 2e93e65..45f9523 100644
--- a/drivers/media/dvb-frontends/stb6100.c
+++ b/drivers/media/dvb-frontends/stb6100.c
@@ -575,8 +575,8 @@ struct dvb_frontend *stb6100_attach(struct dvb_frontend *fe,
 	struct stb6100_state *state = NULL;
 	state = kzalloc(sizeof (struct stb6100_state), GFP_KERNEL);
-	if (state == NULL)
-		goto error;
+	if (!state)
+		return NULL;
 	state->config		= config;
 	state->i2c		= i2c;
@@ -587,10 +587,6 @@ struct dvb_frontend *stb6100_attach(struct dvb_frontend *fe,
 	printk("%s: Attaching STB6100 \n", __func__);
 	return fe;
-error:
-	kfree(state);
-	return NULL;
 static int stb6100_release(struct dvb_frontend *fe)
BtrLinux
Privacy Overview
