[media] drivers/media/dvb-frontends/sp8870.c: removes unnecessary semicolon
Author: Peter Senna Tschudin <peter.senna@gmail.com>
Found by Coccinelle: http://coccinelle.lip6.fr/
Signed-off-by: Peter Senna Tschudin
Signed-off-by: Mauro Carvalho Chehab
 drivers/media/dvb-frontends/sp8870.c | 6 +++---
 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/drivers/media/dvb-frontends/sp8870.c b/drivers/media/dvb-frontends/sp8870.c
index e37274c..2aa8ef7 100644
--- a/drivers/media/dvb-frontends/sp8870.c
+++ b/drivers/media/dvb-frontends/sp8870.c
@@ -188,7 +188,7 @@ static int configure_reg0xc05 (struct dtv_frontend_properties *p, u16 *reg0xc05)
 		break;
 	default:
 		return -EINVAL;
 	switch (p->hierarchy) {
 	case HIERARCHY_NONE:
@@ -207,7 +207,7 @@ static int configure_reg0xc05 (struct dtv_frontend_properties *p, u16 *reg0xc05)
 		break;
 	default:
 		return -EINVAL;
 	switch (p->code_rate_HP) {
 	case FEC_1_2:
@@ -229,7 +229,7 @@ static int configure_reg0xc05 (struct dtv_frontend_properties *p, u16 *reg0xc05)
 		break;
 	default:
 		return -EINVAL;
 	if (known_parameters)
 		*reg0xc05 |= (2 << 1);	/* use specified parameters */
BtrLinux
Privacy Overview
